- H3C SecPath M9000 Multi Service Security Gateway Configuration Examples(V7)(E9X71)-6W700
- 01-About the configuration examples
- 02-Web Login Configuration Examples
- 03-Internet Access Through a Static IP Address Configuration Examples
- 04-Internet access through PPPoE configuration examples
- 05-License Configuration Examples
- 06-Signature Library Upgrade Configuration Examples
- 07-Software Upgrade Examples
- 08-Routing deployment configuration examples
- 09-Transparent deployment configuration examples
- 10-Static routing configuration examples
- 11-RIP configuration examples
- 12-OSPF configuration examples
- 13-BGP configuration examples
- 14-Policy-based routing configuration examples
- 15-Security Policy Configuration Examples
- 16-APR-Based Security Policy Configuration Examples
- 17-Object Group Configuration Examples
- 18-User identification configuration examples
- 19-Attack defense configuration examples
- 20-Request Limit Configuration Examples
- 21-IPS Configuration Examples
- 22-URL Filtering Configuration Examples
- 23-Anti-Virus Configuration Examples
- 24-File Filtering Configuration Examples
- 25-Data Filtering Configuration Examples
- 26-WAF Configuration Examples
- 27-IP Reputation Configuration Examples
- 28-APT Defense Configuration Examples
- 29-NetShare Control Configuration Examples
- 30-Bandwidth Management Configuration Examples
- 31-IPsec configuration examples
- 32-SSL VPN IP access configuration examples
- 32-SSL VPN TCP access configuration examples
- 32-SSL VPN Web access configuration examples
- 33-L2TP Configuration Examples
- 34-NAT configuration examples
- 35-NPTv6 Configuration Examples
- 36-Policy-based NAT configuration examples
- 37-NAT hairpin configuration examples
- 38-NAT Flow Logging Configuration Examples
- 39-Inbound Link Load Balancing Configuration Examples
- 40-Outbound Link Load Balancing Configuration Examples
- 41-Server Load Balancing Configuration Examples
- 42-Transparent DNS Proxy Configuration Examples
- 43-Hot Backup Configuration Examples
- 44-Context Configuration Examples
- 45-DNS configuration examples
- 46-Server Connection Detection Configuration Examples
- 47-Connection Limit Configuration Examples
- 48-Public key management configuration examples
- 49-SSL Decryption Configuration Examples
- 50-MAC Address Learning Through a Layer 3 Device Configuration Examples
- 51-4G Configuration Examples
- 52-WLAN Configuration Examples
| 07-Software Upgrade Examples | 105.33 KB |
The following information provides Web-based software upgrade examples.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of the software upgrade feature.
To upgrade device software, follow these restrictions and guidelines:
· To reduce impact on users, upgrade software when user traffic is low.
· Before upgrading software, back up the current software images.
· Make sure the connection between the configuration terminal and the device is not closed during the upgrade.
· When the device was shipped, HTTPS was enabled and the following settings were configured:
¡ Username admin.
¡ Password admin.
¡ User role network-admin.
¡ Management interface IP address 192.168.0.1/24.
By default, you can connect a configuration terminal to the management interface and use the settings to log in to the Web interface of the device to manage the device.
As shown in Figure 1, use the host to log in to the device and upgrade device software.
Software versions used
This example was created and verified on E9671 of the M9000-X06 device and F9571 of the F5030-D device.
Configuring the host
1. Use an Ethernet cable to connect the host to management interface MGE 1/0/0/0 on the device.
2. Assign IP address 192.168.0.2/24 to the host.
This IP address belongs to the same subnet as management interface GE 1/0/0. The host and the device can reach each other.
3. Launch the Web browser and enter https://192.168.0.1 in the address bar.
The Web interface login page opens.
4. Enter the username admin and password admin, select a language, and click Login.
IMPORTANT: For device security, change the password for the factory-default account immediately. |
Upgrading software
1. On the top navigation bar, click System.
2. From the navigation pane, select Upgrade Center > Software Upgrade.
3. Click Upgrade immediately.
4. Click Select and select the .ipe upgrade file for the service card and MPU.
5. Select Delete all startup files to make sure the MPU and service card have sufficient storage space for the upgrade.
6. Verify that the Reboot the device immediately option is selected.
7. Click OK.
Figure 2 Upgrading software
The Upgrade Immediately page displays the software upgrade progress, as shown in Figure 3.
# On the top navigation bar, click System.
# From the navigation pane, select Maintenance > About > Version Info.
# View the version information.
