08-Configuration Examples
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W40208-Configuration Examples
Table of Contents
Related Documents
12-Object Group Configuration Examples
12-Object Group Configuration Examples 226.21 KB
Object group configuration examples
Introduction
The following information provides examples for configuring IPv4 address, IPv6 address, MAC address, and service object groups and time ranges.
·     IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet.
·     IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet.
·     MAC address object group—A group of MAC address objects used to match the MAC address in a packet.
·     Service object group—A group of service objects used to match the protocol type and protocol characteristics (such as TCP/UDP source/destination port and ICMP message type and code) in a packet.
·     Time range—You can implement a service based on the time of the day by applying a time range to it. A time-based service takes effect only in time periods specified by the time range. If a time range does not exist, the service based on the time range does not take effect.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of the object group feature.
When you configure object groups, follow these restrictions and guidelines:
·     The system supports a maximum of five object group hierarchy layers. For example, if groups 1, 2, 3, and 4 use groups 2, 3, 4, and 5, respectively, group 5 cannot use another group and group 1 cannot be used by another group.
·     Two object groups cannot use each other at the same time.
As shown in Figure 1, configure an IPv4 address object group on the device to allow Host 1 to communicate with Host 2.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on F9345 of the F1060 device.
1.     Assign IP addresses to interfaces and add the interfaces to security zones.
# On the top navigation bar, click Network.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/1.
# In the dialog box that opens, configure the interface:
a.     Select the Trust security zone.
b.     On the IPv4 Address tab, enter the IP address and mask of the interface. In this example, enter 20.1.1.1/24.
c.     Click OK.
# Add GE 1/0/2 to the Untrust security zone and set its IP address to 30.1.1.1./24 in the same way you configure GE 1/0/1.
2.     Create an IPv4 address object group.
# On the top navigation bar, click Objects.
# From the navigation pane, select Object Groups > IPv4 Address Object Groups.
# Click Create.
# In the dialog box that opens, configure the IPv4 address object group:
a.     Enter a group name. In this example, enter test-a.
b.     Enter a description. In this example, enter 20.1.1.0/24.
c.     Click Add.
Figure 2 Create an IPv4 address object group
d.     In the dialog box that opens, select the Network segment object, and enter the IPv4 address and mask length 20.1.1.0/24.
e.     Click OK.
Figure 3 Create an object
f.     On the Create IPv4 Address Object Group page, click OK.
3.     Create a security policy from zone Trust to zone Untrust.
# On the top navigation bar, click Policies.
# From the navigation pane, select Security Policies > Security Policies.
# Click Create.
# In the dialog box that appears, configure a security policy:
¡     Enter policy name test-a.
¡     Select source zone Trust.
¡     Select destination zone Untrust.
¡     Select type IPv4.
¡     Select action Permit.
¡     Select source IP/MAC address test-a.
# Click OK.
# Verify that you can ping Host 2 from Host 1 successfully.
C:\Users\abc> ping 30.1.1.10
# Follow these steps to view the session information:
1.     On the top navigation bar, click Monitor.
2.     From the navigation pane, select Sessions.
Example: Configuring an IPv6 address object group
As shown in Figure 4, configure an IPv6 address object group on the device to allow Host 1 to communicate with Host 2.
Figure 4 Network diagram
1.     Assign IPv6 addresses to interfaces and add the interfaces to security zones.
b.     On the IPv6 Address tab, enter the IP address and mask of the interface. In this example, enter 20:1:1::1/112.
c.     Click OK.
# Add GE 1/0/2 to the Untrust security zone and set its IP address to 30:1:1::1/112 in the same way you configure GE 1/0/1.
2.     Create an IPv6 address object group.
# From the navigation pane, select Object Groups > IPv6 Address Object Groups.
# Click Create.
# In the dialog box that opens, configure the IPv6 address object group:
a.     Enter a group name. In this example, enter test-6a.
b.     Click Add.
Figure 5 Create an IPv6 address object group
c.     In the dialog box that opens, select the Network segment object, and enter the IPv6 address and prefix length 20:1:1::/112.
d.     Click OK.
Figure 6 Create an object
e.     On the Create IPv6 Address Object Group page, click OK.
# Click Create.
¡     Enter policy name test-6a.
¡     Select type IPv6.
¡     Select source IP/MAC address test-6a.
# Click OK.
C:\Users\abc> ping 30:1:1::10
Example: Configuring a MAC address object group
As shown in Figure 7, configure a MAC address object group on the device to allow Host 1 to communicate with Host 2. The MAC address of Host 1 is 3C-52-82-72-03-1F.
Figure 7 Network diagram
c.     Click OK.
# Add GE 1/0/2 to the Untrust security zone and set its IP address to 30.1.1.1/24 in the same way you configure GE 1/0/1.
2.     Create a MAC address object group.
# From the navigation pane, select Object Groups > MAC Address Object Groups.
# Click Create.
# In the dialog box that opens, configure the MAC address object group:
a.     Enter a group name. In this example, enter test-mac.
b.     Enter a description. In this example, enter Host1-mac.
c.     Click Add.
Figure 8 Create a MAC address object group
d.     In the dialog box that opens, configure a MAC address object.
-     Select type MAC address.
-     Enter MAC address 3C-52-82-72-03-1F.
e.     Click OK.
Figure 9 Create an object
f.     On the Create MAC Address Object Group page, click OK.
# Click Create.
¡     Enter policy name test-mac.
¡     Select type IPv4.
¡     Select source IP/MAC address test-mac.
# Click OK.
Example: Configuring a service object group
As shown in Figure 10, configure a service object group on the device to allow Host 1 to communicate with Host 2 through ICMPv6.
Figure 10 Network diagram
c.     Click OK.
2.     Create a service object group.
# From the navigation pane, select Object Groups > Service Object Groups.
# Click Create.
# In the dialog box that opens, configure the service object group:
a.     Enter a group name. In this example, enter test-fa.
b.     Click Add.
Figure 11 Create a service object group
c.     In the dialog box that opens, configure a service object.
-     Select object Protocol name.
-     Select type ICMPv6.
d.     Click OK.
Figure 12 Create an object
e.     On the Create Service Object Group page, click OK.
# Click Create.
¡     Enter policy name test-fa.
¡     Select type IPv6.
¡     Specify the source IPv6 address as 20.1.1.0/24.
¡     Specify the destination IPv6 address as 220.0.0.0/24.
¡     Select service test-fa.
# Click OK.
Example: Configuring a time range
As shown in Figure 13, configure a service object group on the device to allow Host 1 to communicate with Host 2 through ICMPv6 in a specific time period.
Figure 13 Network diagram
c.     Click OK.
# Click Create.
b.     Click Add.
Figure 14 Create a service object group
d.     Click OK.
Figure 15 Create an object
3.     Create a time range.
# On the top navigation bar, click Object.
# From the navigation pane, select Object Groups > Time Ranges.
# Click Create.
# In the dialog box that appears, enter name test-time and then click Create for Periodic time range.
# In the dialog box that appears, configure the time range:
¡     Set the start time to 08:10.
¡     Set the end time to 17:10.
¡     Select Monday, Tuesday, Wednesday, Thursday, and Friday.
# Click OK.
Figure 16 Configure a time range
# In the Create Time Range page, click OK.
4.     Create a security policy from zone Trust to zone Untrust.
# Click Create.
¡     Enter policy name test-time.
¡     Select type IPv6.
¡     Select time range test-time.
# Click OK.
# Verify that you can ping Host 2 from Host 1 successfully in the time period specified by the time range.
# Verify that you cannot ping Host 2 from Host 1 and the corresponding session does not exist at any time beyond the time period specified by the time range.
