08-Configuration Examples
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W40208-Configuration Examples
Table of Contents
Related Documents
02-Internet Access Through a Static IP Address Configuration Examples
Internet access through a static IP address configuration examples
Introduction
The following information provides the configuration examples of using a static IP address to access the Internet.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of IP features.
Example: Configuring Internet access through a static IP address
As shown in Figure 1, a device is deployed as the egress device that connects the internal network to the ISP. Perform the following tasks to allow the internal users to access the Internet:
·     Configure the DHCP server on the device to assign private IP addresses and the DNS server address to the hosts.
·     Allow the internal users to access the Web server on the Internet. The website of the Web server is www.example.com.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on F9345 of the F1060 device.
When you configure the DHCP server on the device, perform the following tasks:
·     Allow traffic from security zones Trust (to which the DHCP server belongs) to Local to ensure that the DHCP clients can obtain IP addresses.
·     Enable DNS proxy on the device to convey DNS requests between the DNS server and the DNS clients.
Procedures
Configuring the device
1.     Configure a static IP address.
# On the top navigation bar, click System.
# From the navigation pane, select Configuration Wizard > Internet Access.
Figure 2 Internet access configuration page
# Select the routing mode and click Configure.
# Configure the WAN interface as shown in Figure 3.
Figure 3 WAN interface configuration
# Click Next.
# Configure the LAN interface as shown in Figure 4.
Figure 4 LAN interface configuration
# Click Next. Skip the configuration for the DMZ interface, security configuration, and WAN acceleration.
# Configure flow control, as shown in Figure 5.
Figure 5 Flow control configuration
# Click Next. The following page opens.
Figure 6 Verify the configuration
# Verify the configuration and click Finish. The following page opens.
Figure 7 Interface access configuration
# The system also creates a dynamic NAT policy after you finish the Internet access configuration. To view the NAT policy:
a.     On the top navigation bar, click Policies.
b.     From the navigation pane, select NAT > Dynamic NAT > Policy Configuration.
Figure 8 Outbound dynamic NAT configuration
2.     Configure a security policy.
# After you configure the Internet access through a static IP address, the system automatically creates a security policy named GuideSecPolicy.
# To view the security policy:
b.     From the navigation pane, select Security Policies > Security Policies.
Figure 9 Security policy configuration page
# Click the Edit icon for this security policy.
# In the dialog box that opens, add security zone Local to the source zones, and add security zones Trust and Local to the destination zones.
Figure 10 Editing the security policy
3.     Configure DHCP.
# On the top navigation bar, click Network.
# From the navigation pane, select DHCP > DHCP Address Pools.
# Click the Address Pool Options tab, and configure the settings as shown in Figure 11.
Figure 11 Address pool option configuration
4.     Configure DNS proxy.
# From the navigation pane, select DNS > Advanced Settings.
# Enable the DNS proxy.
Figure 12 DNS proxy configuration page
Configuring the host
# Configure the host to obtain an IP address through DHCP.
1.     Display the IP address that the host obtains.
C:\>ipconfig /all
Ethernet adapter Ethernet 1:
   Connection-specific DNS SUffix.:
   Description....................: Intel(R) 82579LM Gigabit Network Connection
   Physical Address...............: E8-39-35-5C-92-B8
   DHCP Enabled ..................: Yes
   Autoconfiguration Enabled......: Yes
   Link-local IPv6 Address........: fe80::b8dd:d091:201a:6db2%13(Preferred)
   IPv4 Address...................: 172.16.1.3(Preferred)
   Subnet Mask....................: 255.255.255.0
   Lease Obtained.................: Monday, October 8, 2018 2:44:36 AM
   Lease Expires..................: Tuesday, October 9, 2018 2:44:36 AM
   Default Gateway................: 172.16.1.254
   DHCP Server....................: 172.16.1.254
   DHCPv6 IAID....................: 384317749
   DHCPv6 Client DUID.............: 00-01-00-01-1F-B4-A3-F5-B8-A3-86-6F-0F-02
   DNS Server.....................: 219.141.136.102
   NetBIOS over Tcpip.............: Enabled
2.     Verify that you can ping a domain name on the public network from the host.
C:\>ping www.example.com
Pinging www.example.com [192.168.100.201] with 32 bytes of data:
Reply from 192.168.100.201: bytes=32 time<1ms TTL=253
Ping statistics for 192.168.100.201:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Minimum = 0ms, Maximum = 0ms, Average = 0ms
