04-静态VLAN-group典型配置
本章节下载: 04-静态VLAN-group典型配置 (228.73 KB)
本文档介绍通过静态VLAN-group实现客户端平均加入VLAN-group中不同VLAN的典型配置。
如图1所示,Switch作为DHCP服务器为AP和Client分配IP地址,在AC上配置两个VLAN组,VLAN-group test1和VLAN-group test2。现要求:Client分别接入不同VLAN组,VLAN组可以为Client随机分配组内的VLAN,使Client被均衡地分配在所有VLAN中。
图1 VLAN-group为Client静态分配VLAN组网图
设备 |
接口 |
IP地址 |
设备 |
接口 |
IP地址 |
AC |
Vlan-int2 |
192.12.0.2/16 |
Switch |
Vlan-int2 |
192.12.0.1/16 |
Vlan-int10 |
192.10.0.2/16 |
Vlan-int10 |
192.10.0.1/16 |
Vlan-int20 |
192.20.0.2/16 |
Vlan-int20 |
192.20.0.1/16 |
Vlan-int30 |
192.30.0.2/16 |
Vlan-int30 |
192.30.0.1/16 |
Vlan-int40 |
192.40.0.2/16 |
Vlan-int40 |
192.40.0.1/16 |
(1) 配置AC的接口
# 创建VLAN 2及其对应的VLAN接口,并为该接口配置IP地址192.12.0.2/16。AP将获取该IP地址与AC建立CAPWAP隧道。
<AC> system-view
[AC] vlan 2
[AC-vlan2] quit
[AC] interface vlan-interface 2
[AC-Vlan-interface2] ip address 192.12.0.2 16
[AC-Vlan-interface2] quit
# 创建VLAN 10作为客户端接入的业务VLAN,并为该接口配置IP地址192.10.0.2/16。
[AC] vlan 10
[AC-vlan10] quit
[AC] interface vlan-interface 10
[AC-Vlan-interface10] ip address 192.10.0.2 16
[AC-Vlan-interface10] quit
# 创建VLAN 20作为客户端接入的业务VLAN,并为该接口配置IP地址192.20.0.2/16。
[AC] vlan 20
[AC-vlan20] quit
[AC] interface vlan-interface 20
[AC-Vlan-interface20] ip address 192.20.0.2 16
[AC-Vlan-interface20] quit
# 创建VLAN 30作为客户端接入的业务VLAN,并为该接口配置IP地址192.30.0.2/16。
[AC] vlan 30
[AC-vlan30] quit
[AC] interface vlan-interface 30
[AC-Vlan-interface30] ip address 192.30.0.2 16
[AC-Vlan-interface30] quit
# 创建VLAN 40作为客户端接入的业务VLAN,并为该接口配置IP地址192.40.0.2/16。
[AC] vlan 40
[AC-vlan40] quit
[AC] interface vlan-interface 40
[AC-Vlan-interface40] ip address 192.40.0.2 16
[AC-Vlan-interface40] quit
# 将与Switch相连的接口GigabitEthernet 1/0/1的链路类型配置为Trunk,并允许VLAN 2、VLAN 10、VLAN 20、VLAN 30和VLAN 40通过。
[AC-GigabitEthernet1/0/1] port trunk permit vlan 2 10 20 30 40
# 将与AP相连的接口GigabitEthernet 1/0/2的链路类型配置为Trunk,并允许VLAN 2通过。
[AC] interface gigabitethernet 1/0/2
[AC-GigabitEthernet1/0/2] port link-type trunk
[AC-GigabitEthernet1/0/2] port trunk permit vlan 2
[AC-GigabitEthernet1/0/2] quit
(2) 配置VLAN-group
# 创建VLAN-group test1,为客户端分配VLAN 10和VLAN 20。
[AC] vlan-group test1
[AC-vlan-group-test1] vlan-list 10 20
# 创建VLAN-group test2,为客户端分配VLAN 30和VLAN 40。
[AC] vlan-group test2
[AC-vlan-group-test2] vlan-list 30 40
(3) 配置无线接入服务
# 创建无线服务模板1并进入无线服务模板视图。
[AC] wlan service-template 1
# 配置无线服务的SSID为service。
[AC-wlan-st-1] ssid service
# 配置身份认证与密钥管理模式为PSK模式,配置PSK密钥为明文字符串12345678。
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# 配置加密套件为CCMP,安全信息元素为RSN。
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# 配置无线客户端的数据报文转发位置在AC上。(如果客户端数据报文的缺省转发位置与本配置相同,请跳过此步骤)
[AC-wlan-st-1] client forwarding-location ac
# 配置给客户端分配的VLAN为静态模式,客户端首次上线被随机分配VLAN-group中的VLAN,再次上线时VLAN保持不变。
[AC-wlan-st-1] client vlan-alloc static
当配置客户端的VLAN分配方式为动态模式时,会出现客户端无法主动更换地址,导致连接断开的情况,请配置VLAN分配方式为静态模式。
# 开启无线服务模板。
[AC-wlan-st-1] quit
(4) 配置AP
在大规模组网时,推荐在AP组内进行配置。
# 创建手工AP,配置AP名称为ap1,型号为WA6320,序列号为219801A28N819CE0002T。
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[AC-wlan-ap-ap1] quit
# 创建手工AP,配置AP名称为ap2,型号为WA6320,序列号为219801A28N819CE00033。
[AC] wlan ap ap2 model WA6320
[AC-wlan-ap-ap2] serial-id 219801A28N819CE00033
[AC-wlan-ap-ap2] quit
# 创建AP组group1,并配置AP名称入组规则。
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
# 将无线服务模板1绑定到AP组group1下的Radio 1上,同时指定VLAN-group test1。
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template 1 vlan-group test1
# 开启Radio 1的射频功能。
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
# 创建AP组group2,并配置AP名称入组规则。
[AC] wlan ap-group group2
[AC-wlan-ap-group-group2] ap ap2
# 将无线服务模板1绑定到AP组group2下的Radio 1上,同时指定VLAN-group test2。
[AC-wlan-ap-group-group2] ap-model WA6320
[AC-wlan-ap-group-group2-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group2-ap-model-WA6320-radio-1] service-template 1 vlan-group test2
# 开启Radio 1的射频功能。
[AC-wlan-ap-group-group2-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group2-ap-model-WA6320-radio-1] quit
[AC-wlan-ap-group-group2-ap-model-WA6320] quit
[AC-wlan-ap-group-group2] quit
(1) 配置Switch的接口
# 创建VLAN 2及其对应的VLAN接口,并为该接口配置IP地址192.12.0.1/16。
<Switch> system-view
[Switch] vlan 2
[Switch-vlan2] quit
[Switch-Vlan-interface2] ip address 192.12.0.1 16
[Switch-Vlan-interface2] quit
# 创建VLAN 10及其对应的VLAN接口,并为该接口配置IP地址192.10.0.1/16。
[Switch] vlan 10
[Switch-vlan10] quit
[Switch] interface vlan-interface 10
[Switch-Vlan-interface10] ip address 192.10.0.1 16
[Switch-Vlan-interface10] quit
# 创建VLAN 20及其对应的VLAN接口,并为该接口配置IP地址192.20.0.1/16。
[Switch] vlan 20
[Switch-vlan20] quit
[Switch] interface vlan-interface 20
[Switch-Vlan-interface20] ip address 192.20.0.1 16
[Switch-Vlan-interface20] quit
# 创建VLAN 30及其对应的VLAN接口,并为该接口配置IP地址192.30.0.1/16。
[Switch] vlan 30
[Switch-vlan30] quit
[Switch] interface vlan-interface 30
[Switch-Vlan-interface30] ip address 192.30.0.1 16
[Switch-Vlan-interface30] quit
# 创建VLAN 40及其对应的VLAN接口,并为该接口配置IP地址192.40.0.1/16。
[Switch] vlan 40
[Switch-vlan40] quit
[Switch] interface vlan-interface 40
[Switch-Vlan-interface40] ip address 192.40.0.1 16
[Switch-Vlan-interface40] quit
# 将与AC相连的接口GigabitEthernet 1/0/2的链路类型配置为Trunk,并允许VLAN 2、VLAN 10、VLAN 20、VLAN 30和VLAN 40通过。
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 2 10 20 30 40
(2) 配置DHCP服务器
# 开启DHCP功能。
[Switch] dhcp enable
# 创建DHCP地址池vlan2,为AP动态分配网段为192.2.0.0/16,网关地址为192.2.0.1。
[Switch] dhcp server ip-pool vlan2
[Switch-dhcp-pool-vlan2] network 192.12.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan2] gateway-list 192.12.0.1
[Switch-dhcp-pool-vlan2] quit
# 创建DHCP地址池vlan10,为无线客户端动态分配网段为192.10.0.0/16,网关地址为192.10.0.1,为Client分配的DNS服务器地址为网关地址(实际使用过程中请根据实际网络规划配置无线客户端的DNS服务器地址)。
[Switch] dhcp server ip-pool vlan10
[Switch-dhcp-pool-vlan10] network 192.10.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan10] gateway-list 192.10.0.1
[Switch-dhcp-pool-vlan10] dns-list 192.10.0.1
[Switch-dhcp-pool-vlan10] quit
# 创建DHCP地址池vlan20,为无线客户端动态分配网段为192.20.0.0/16,网关地址为192.20.0.1,为Client分配的DNS服务器地址为网关地址(实际使用过程中请根据实际网络规划配置无线客户端的DNS服务器地址)。
[Switch] dhcp server ip-pool vlan20
[Switch-dhcp-pool-vlan20] network 192.20.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan20] gateway-list 192.20.0.1
[Switch-dhcp-pool-vlan20] dns-list 192.20.0.1
[Switch-dhcp-pool-vlan20] quit
# 创建DHCP地址池vlan30,为无线客户端动态分配网段为192.30.0.0/16,网关地址为192.30.0.1,为Client分配的DNS服务器地址为网关地址(实际使用过程中请根据实际网络规划配置无线客户端的DNS服务器地址)。
[Switch] dhcp server ip-pool vlan30
[Switch-dhcp-pool-vlan30] network 192.30.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan30] gateway-list 192.30.0.1
[Switch-dhcp-pool-vlan30] dns-list 192.30.0.1
[Switch-dhcp-pool-vlan30] quit
# 创建DHCP地址池vlan40,为无线客户端动态分配网段为192.40.0.0/16,网关地址为192.40.0.1,为Client分配的DNS服务器地址为网关地址(实际使用过程中请根据实际网络规划配置无线客户端的DNS服务器地址)。
[Switch] dhcp server ip-pool vlan40
[Switch-dhcp-pool-vlan40] network 192.40.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan40] gateway-list 192.40.0.1
[Switch-dhcp-pool-vlan40] dns-list 192.40.0.1
[Switch-dhcp-pool-vlan40] quit
# 完成上述配置后,将Client 1和Client 2接入AP 1的无线网络中(SSID:service),通过display wlan client命令查看客户端信息,两个客户端被自动分配至VLAN-group test1下的VLAN 10和VLAN 20中。
[AC]display wlan client
Total number of clients: 2
MAC address User name AP name R IP address VLAN
90f0-528e-0871 N/A ap1 1 192.10.0.3 10
961b-66ea-72c5 N/A ap1 1 192.20.0.3 20
· AC:
vlan 2
vlan 10
vlan 20
vlan 30
vlan 40
vlan-group test1
vlan-list 10 20
vlan-group test2
vlan-list 30 40
ssid service
akm mode psk
preshared-key pass-phrase cipher $c$3$N//5BVbsOqdBTxi+7MJZKT6Zqh5MAmYs2ZzM
cipher-suite ccmp
security-ie rsn
interface Vlan-interface2
ip address 192.12.0.2 255.255.0.0
interface Vlan-interface10
ip address 192.10.0.2 255.255.0.0
interface Vlan-interface20
ip address 192.20.0.2 255.255.0.0
interface Vlan-interface30
ip address 192.30.0.2 255.255.0.0
interface Vlan-interface40
ip address 192.40.0.2 255.255.0.0
ap ap1
ap-model WA6320
radio 1
radio enable
ap ap2
ap-model WA6320
radio 1
radio enable
· Switch
dhcp enable
vlan 2
vlan 10
vlan 20
vlan 30
vlan 40
dns-list 192.10.0.1
dns-list 192.20.0.1
dns-list 192.30.0.1
dns-list 192.40.0.1
ip address 192.12.0.1 255.255.0.0
ip address 192.10.0.1 255.255.0.0
ip address 192.20.0.1 255.255.0.0
ip address 192.30.0.1 255.255.0.0
ip address 192.40.0.1 255.255.0.0
· 《H3C 无线控制器产品 配置指导》中的“用户接入与认证配置指导”。
· 《H3C 无线控制器产品 命令参考》中的“用户接入与认证命令参考”。
· 《H3C 无线控制器产品 配置指导》中的“WLAN接入配置指导”。
· 《H3C 无线控制器产品 命令参考》中的“WLAN接入命令参考”。
· 《H3C 无线控制器产品 配置指导》中的“AP管理配置指导”。
· 《H3C 无线控制器产品 命令参考》中的“AP管理命令参考”。
