02-二层静态聚合典型配置
本章节下载: 02-二层静态聚合典型配置 (142.01 KB)
本文档介绍二层静态聚合的典型配置。
如图1所示,AC与Switch通过各自的二层以太网接口GigabitEthernet1/0/1和GigabitEthernet1/0/2相互连接,具体要求如下:
· 通过以太网链路聚合增加AC与Switch间的链路带宽和可靠性。
· AC与Switch上分别配置二层静态链路聚合组实现AC与Switch间VLAN 10和VLAN 20分别互通。
(1) 配置VLAN
# 创建VLAN 10,并将端口GigabitEthernet1/0/3加入到该VLAN中。
<AC> system-view
[AC] vlan 10
[AC-vlan10] port gigabitethernet 1/0/3
[AC-vlan10] quit
# 创建VLAN 20,并将端口GigabitEthernet1/0/4加入到该VLAN中。
[AC] vlan 20
[AC-vlan20] port gigabitethernet 1/0/4
[AC-vlan20] quit
(2) 配置二层聚合接口
# 创建二层聚合接口1,并进入二层聚合接口1视图。
[AC] interface bridge-aggregation 1
[AC-Bridge-Aggregation1] quit
# 将端口GigabitEthernet1/0/1加入到聚合组1中。
[AC-GigabitEthernet1/0/1] port link-aggregation group 1
# 将端口GigabitEthernet1/0/2加入到聚合组1中。
[AC] interface gigabitethernet1/0/2
[AC-GigabitEthernet1/0/2] port link-aggregation group 1
[AC-GigabitEthernet1/0/2] quit
# 配置二层聚合接口1为Trunk类型,并允许VLAN 10和20的报文通过。
[AC-Bridge-Aggregation1] port link-type trunk
[AC-Bridge-Aggregation1] port trunk permit vlan 10 20
(1) 配置VLAN
<Switch> system-view
[Switch] vlan 10
[Switch-vlan10] port gigabitethernet 1/0/3
[Switch-vlan10] quit
[Switch] vlan 20
[Switch-vlan20] port gigabitethernet 1/0/4
[Switch-vlan20] quit
(2) 配置二层聚合接口
[Switch] interface bridge-aggregation 1
[Switch-Bridge-Aggregation1] quit
[Switch-GigabitEthernet1/0/1] port link-aggregation group 1
[Switch-GigabitEthernet1/0/2] port link-aggregation group 1
[Switch-Bridge-Aggregation1] port link-type trunk
[Switch-Bridge-Aggregation1] port trunk permit vlan 10 20
(1) 在AC上使用命令display link-aggregation verbose查看聚合组1的详细信息。两个成员端口都处于聚合组1中且为选中状态。
<AC> display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H – Expired
Role: P -- Primary, S -- Secondary
Aggregation Mode: Static
Management VLANs: None
Port Status Priority Oper-Key Role
GE1/0/1 S 32768 2 None
GE1/0/2 S 32768 2 None
(2) 在AC上使用命令display interface bridge-aggregation查看聚合组1的带宽是成员物理接口带宽之和。
<AC> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 741f-4a05-3db8
Description: Bridge-Aggregation1 Interface
Bandwidth: 2000000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Trunk
VLAN Passing: 1(default vlan), 10
VLAN permitted: 1(default vlan), 10, 20
Trunk port encapsulation: IEEE 802.1q
Last 300 seconds input: 2 packets/sec 308 bytes/sec 0%
Last 300 seconds output: 0 packets/sec 0 bytes/sec 0%
Input (total): 12659 packets, 1290752 bytes
177 unicasts, 9919 broadcasts, 2563 multicasts, 0 pauses
Input (normal): 12659 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, - throttles
0 CRC, - frame, 0 overruns, 0 aborts
- ignored, - parity errors
Output (total): 316 packets, 295765 bytes
307 unicasts, 9 broadcasts, 0 multicasts, 0 pauses
Output (normal): 316 packets, - bytes
Output: 0 output errors, 0 underruns, - buffer failures
- lost carrier, - no carrier
· AC:
vlan 10
vlan20
interface Bridge-Aggregation1
port trunk permit vlan 1 10 20
· Switch:
vlan 10
vlan 20
《H3C无线控制器产品 配置指导》中的“网络互通配置指导”。
《H3C无线控制器产品 命令参考》中的“网络互通命令参考”。
