H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
31-PKI Command
31-PKI Command 136 KB
Chapter 1  PKI Configuration Commands
1.1  PKI Configuration Commands
1.1.1  attribute
attribute id { alt-subject-name { fqdn | ip } | { issuer-name | subject-name } { dn | fqdn | ip } } { ctn | equ | nctn | nequ} attribute-value
undo attribute { id | all }
view
Certificate attribute group view
Parameter
Id: Serial number of the certificate attribute, in the range 1 to 16.
alt-subject-name: Name of the alternative certificate subject.
issuer-name: Name of the certificate issuer.
subject-name: Name of the certificate subject.
dn: DN of the entity.
fqdn: FQDN of the entity.
ip: IP address of the entity.
ctn: Contain operation.
equ: Equal operation.
nctn: Not-contain operation.
nequ: Not-equal operation.
attribute-value: Attribute value of the certificate, a case-insensitive string of 1 to 128 characters.
all: All the certificate attributes.
Use the attribute command to configure the attribute of the certificate issuer name, certificate subject name and alternative certificate subject name.
Use the undo attribute command to delete the attribute of one or all of these certificate names.
There is no restriction on the issuer name, the subject name and the alternative subject name of the certificate by default.
Note that the attribute of the alternative certificate subject name does not appear as a domain name, there is no dn in the configuration.
Example
# Create a certificate attribute which defines that the DN of the subject name includes a string of abc.
[Sysname] pki certificate attribute-group mygroup
[Sysname-pki-cert-attribute-group-mygroup] attribute 1 subject-name dn ctn abc
# Create a certificate attribute which defines that the FQDN of the issuer name is not equal to the string abc.
[Sysname-pki-cert-attribute-group-mygroup] attribute 2 issuer-name fqdn nequ abc
# Create a certificate attribute which defines that the IP address of the alternative subject name is not equal to 10.0.0.1.
[Sysname-pki-cert-attribute-group-mygroup] attribute 3 alt-subject-name ip nequ 10.0.0.1
1.1.2  ca identifier
ca identifier name
undo ca identifier
View
PKI domain view
Parameter
name: Identifier of the trusted CA, in a case-insensitive string of 1 to 63 characters
Use the ca identifier command to specify the trusted CA, and bind the device with CA name.
Use the undo ca identifier command to remove the configuration.
By default, no trusted CA is specified.
The request, retrieval, revocation and query of a certificate are all carried out by the trusted CA as long as the CA is not deleted.
Example
# Specify the name of the trusted CA.
[Sysname] pki domain 1
[Sysname-pki-domain-1] ca identifier new-ca
1.1.3  certificate request entity
certificate request entity entity-name
undo certificate request entity
View
PKI domain view
Parameter
entity-name: Name of the entity used for certificate request, in a case-insensitive string of 1 to 15 characters.
Use the certificate request entity command to specify the name of the entity used for certificate request.
Use the undo certificate request entity command to remove the configuration.
By default, no entity name is specified.
Related command: pki entity.
Example
# Specify to use entity1 for certificate request.
[Sysname-pki-domain-1] certificate request entity entity1
1.1.4  certificate request from
certificate request from { ca | ra }
undo certificate request from
View
PKI domain view
Parameter
ca: Indicates that the entity requests a certificate from CA.
ra: Indicates that the entity requests a certificate from RA.
Use the certificate request from command to configure the registration authority (RA) for certificate request for the entity.
Use the undo certificate request from command to remove the configuration.
By default, no RA is specified.
Example
# Specify that the entity requests a certificate from CA.
[Sysname-pki-domain-1] certificate request from ca
1.1.5  certificate request mode
certificate request mode { auto [ key-length key-length | password { cipher | simple } password ]* | manual }
undo certificate request mode
View
PKI domain view
Parameter
auto: Specifies to request a certificate in auto mode.
key-length: Length of the RSA key, in the range 512 to 2048 bits. It is 1024 bits by default.
cipher: Specifies to display the password in cipher text.
simple: Specifies to display the password in clear text.
password: Password used for revoking a certificate, a case-sensitive string of 1 to 31 characters.
manual: Specifies to request a certificate in manual mode.
Use the certificate request mode command to configure the certificate request mode.
Use the undo certificate request mode command to restore it to the default request mode.
By default, certificate request is carried out manually.
For auto mode, an entity automatically requests a certificate from RA when it has not its own certificate. Furthermore, the entity automatically requests a new one when the existing certificate is about to expire. For manual mode, all the operations associated with certificate request are carried out manually.
Related command: pki request-certificate.
Example
# Specify to request a certificate in auto mode.
[Sysname-pki-domain-1] certificate request mode auto
1.1.6  certificate request polling
certificate request polling { count count | interval minutes }
undo certificate request polling { count | interval }
View
PKI domain view
Parameter
count: Polling times, in the range 1 to 100.
minutes: Polling period, in the range 5 to 168 minutes.
Use the certificate request polling command to specify the polling period and polling times for certificate request.
Use the undo certificate request polling command to restore it to the default parameters.
By default, polling is executed for 50 times at the interval of 20 minutes.
After an entity makes a certificate request, if CA validates the request manually, it takes a long time to issue a certificate. The entity therefore needs to periodically poll the request status so that it can acquire the certificate as soon as CA issues a certificate.
Related command: display pki certificate.
Example
# Specify to execute polling for 40 times at the interval of 15 minutes.
[Sysname-pki-domain-1] certificate request polling interval 15
[Sysname-pki-domain-1] certificate request polling count 40
1.1.7  certificate request url
certificate request url url-string
undo certificate request url
View
PKI domain view
Parameter
url-string: RA server URL, in a case-insensitive string of 1 to 127 characters, including the location of RA server and the location of CA CGI command interface script in the format of http: //server_location/ca_script_location, where server_location is generally expressed by IP address.
Use the certificate request url command to specify the URL of the RA server that the device makes a certificate request through SCEP protocol.
Use the undo certificate request url command to remove the configuration.
By default, no URL is specified.
Example
# Specify the URL of RA server.
[Sysname-pki-domain-1] certificate request url
http://169.254.0.100/certsrv/mscep/mscep.dll
1.1.8  common-name
common-name name
undo common-name
View
PKI entity view
Parameter
name: Common name of an entity, in a case-insensitive string of 1 to 31 characters.
Use the common-name command to configure the common name of an entity, such as the user name
Use the undo common-name command to remove the configuration.
By default, no common name is specified.
Example
# Configure the common name of an entity as test.
[Sysname] pki entity 1
[Sysname-pki-entity-1] common-name test
1.1.9  country
country country-code-str
undo country
View
PKI entity view
Parameter
country-code-str: 2-character country code.
Use the country command to specify the code of the country to which an entity belongs. It is a standard 2-character code, e.g., CN for China.
Use the undo country command to remove the configuration.
By default, no country code is specified.
Example
# Set the country code of an entity to CN.
[Sysname-pki-entity-1] country CN
1.1.10  crl check
crl check { disable | enable }
View
PKI domain view
Parameter
disable: Specifies to disable CRL checking.
enable: Specifies to enable CRL checking.
Use the crl check command to enable or disable CRL checking.
By default, CRL checking is enabled.
CRL (Certificate Revocation Lists) is a file issued by CA to indicate that some certificate is revoked. The revocation may occur before the expiration of the period of the certificate validity.
Example
# Disable CRL checking.
[Sysname-pki-domain-1] crl check disable
1.1.11  crl update-period
crl update-period hours
undo crl update-period
View
PKI domain view
Parameter
hours: Update period, in the range 1 to 720 hours.
Use the crl update-period command to specify the update period of CRL.
Use the undo crl update-period command to restore it to the default value.
By default, CRL update period depends on the next update domain in the CRL file.
The CRL update period is the interval at which a PKI entity with a certificate downloads a CRL from LDAP server.
Example
# Set the CRL update period to 20 hours.
[Sysname-pki-domain-1] crl update-period 20
1.1.12  crl url
crl url url-string
undo crl url
View
PKI domain view
Parameter
url-string: URL of CRL distribution point, in a case-insensitive string of 1 to 127 characters in the format of ldap: //server_location, where server_location is generally expressed by IP address.
Use the crl url command to specify the URL for the CRL distribution point.
Use the undo crl url command to remove the configuration.
By default, no URL is specified for the CRL distribution point.
Note that when the URL of the CRL distribution point is not set, you should acquire CA certificate and a local certificate, and then acquire a CRL through SCEP.
Example
# Specify the URL of the CRL distribution point.
[Sysname-pki-domain-1] crl url ldap://169.254.0 30
1.1.13  display pki certificate
display pki certificate { { ca | local } domain domain-name | request-status }
View
Parameter
ca: Displays CA certificate.
local: Displays local certificate.
request-status: Displays the status of the certificate request after being delivered.
domain-name: Domain of the certificate to be verified. It is configured by using the pki domain command.
Use the display pki certificate command to display the contents of a certificate.
Related command: pki retrieval-certificate, pki domain and certificate request polling.
Example
# Display local certificate.
<Sysname> display pki certificate local domain 1
Data:
        Version: 3 (0x2)
        Serial Number:
            10B7D4E3 00010000 0086
        Signature Algorithm:  md5WithRSAEncryption
        Issuer:
            [email protected]
            C=CN
            ST=Country A
            L=City X
            O=abc
            OU=bjs
            CN=new-ca
        Validity
            Not Before:  Jan 13 08: 57: 21 2004 GMT
            Not After :  Jan 20 09: 07: 21 2005 GMT
        Subject:
            C=CN
            ST=Country B
            L=City Y
            CN=pki test
        Subject Public Key Info:
            Public Key Algorithm:  rsaEncryption
            RSA Public Key:  (512 bit)
                Modulus (512 bit):
                    00D41D1F …
                Exponent:  65537 (0x10001)
        X509v3 extensions:
            X509v3 Subject Alternative Name:
            DNS: hyf.xxyyzz.net
        A3A5A447 4D08387D …
Table 1-1 Description on the fields of the display pki certificate command
Version
Version of the certificate
Serial Number
Signature Algorithm
Signature algorithm
Issuer
Issuer of the certificate
Validity
Validity period of the certificate
Subject
Subject of the certificate
Public key information
X509v3 extensions
Extensions of X509 (version 3) certificate
X509v3 CRL Distribution Points
Distribution points of X509 (version 3) CRL
1.1.14  display pki certificate access-control-policy
display pki certificate access-control-policy { policy-name | all }
View
Parameter
policy-name: Name of the access control policy of a certificate attribute, a string of 1 to 16 characters.
all: Access control policies of all the certificate attributes.
Use the display pki certificate access-control-policy command to display the access control policy information of a certificate attribute.
Example
# Display the information of the access control policy mypolicy of certificate attribute.
<Sysname> display pki certificate access-control-policy mypolicy
 access-control-policy name: mypolicy
     rule  1 deny    mygroup1
     rule  2 permit  mygroup2
Table 1-2 Description on the fields of the display pki certificate access-control-policy command
Access control policy name of certificate attribute
rule number
Control rule number
1.1.15  display pki certificate attribute-group
display pki certificate attribute-group { group-name | all }
View
Parameter
group-name: Name of a certificate attribute group.
all: All the certificate attribute groups.
Use the display pki certificate attribute-group command to display the information of a certificate attribute group.
Example
# Display the information of certificate attribute group mygroup.
<Sysname> display pki certificate attribute-group mygroup
 attribute group name: mygroup
      attribute  2 issuer-name      fqdn  nctn  apple
Table 1-3 Description on the fields of the display pki certificate attribute-group command
attribute number
Attribute number
1.1.16  display pki crl domain
display pki crl domain domain-name
View
Parameter
Use the display pki crl domain command to display the locally saved CRL.
Related command: pki retrieval-crl and pki domain.
Example
# Display a CRL.
<Sysname> display pki crl domain 1
 Certificate Revocation List (CRL):
        Version 2 (0x1)
        Signature Algorithm:  sha1WithRSAEncryption
        Issuer:
            C=CN
            O=abc
            OU=soft
            CN=A Test Root
        Last Update:  Jan  5 08: 44: 19 2004 GMT
        Next Update:  Jan  5 21: 42: 13 2004 GMT
        CRL extensions:
            X509v3 Authority Key Identifier:
            keyid:0F71448E E075CAB8 ADDB3A12 0B747387 45D612EC
            Revoked Certificates:
            Serial Number: 05a234448E…
            Revocation Date: Sep  6 12:33:22 2004 GMT
            CRL entry extensions:…
Table 1-4 Description on the fields of the display pki crl command
Version
Version of CRL
Signature Algorithm
Signature algorithm adopted by CRL
Issuer
The CA issuing the CRL
Last Update
Last update time
Next Update
Next update time
CRL extensions
Extensions of CRL
The CA issuing the invalid certificate (i.e. CRL)
The revoked certificates
Serial Number
Serial number of a revoked certificate
Revocation Date
Revocation date
1.1.17  fqdn
fqdn name-str
undo fqdn
View
PKI entity view
Parameter
name-str: FQDN of an entity, in a case-insensitive string of 1 to 127 characters
Use the fqdn command to configure the FQDN of an entity.
Use the undo fqdn command to remove the configuration.
By default, no FQDN is specified for an entity .
FQDN (Fully Qualified Domain Name) is the unique identifier an entity has across a network. It consists of a host name and a domain name that can be resolved an IP address.  .
Example
# Configure the FQDN of an entity.
[Sysname-pki-entity-1] fqdn pki.domain-name.com
1.1.18  ip
ip ip-address
undo ip
View
PKI entity view
Parameter
ip-address: IP address of an entity.
Use the ip command to configure the IP address of an entity.
Use the undo ip command to remove the configuration.
By default, no IP address is specified for an entity.
Example
# Configure the IP address of an entity.
[Sysname-pki-entity-1] ip 161.12.2.3
1.1.19  ldap-server
ldap-server ip ip-address [ port port-number ] [ version version-number ]
undo ldap-server ip
View
PKI domain view
Parameter
ip-address: IP address of LDAP server; in the form of dotted decimal.
port-number: Port number of LDAP server, in the range 1 to 65535. By default, it is 389.
version-number: LDAP version number, alternatively 2 or 3. By default, it is 2.
Use the ldap-server ip command to configure the IP address, port number and version of LDAP server.
Use the undo ldap-server ip command to restore it to the default value.
By default, no IP address is configured for LDAP server.
Example
# Specify the IP address of LDAP server.
[Sysname-pki-domain-1] ldap-server ip 169.254.0 30
1.1.20  locality
locality locality-name
undo locality
View
PKI entity view
Parameter
locality-name: Name of the geographical locality, in a case-insensitive string of 1 to 31 characters.
Use the locality command to configure the geographical locality of an entity, for example, a city’s name.
Use the undo locality command to remove the configuration.
By default, no geographical locality is specified for an entity.
Example
# Configure the name of the city where the entity lies.
[Sysname-pki-entity-1] locality City
1.1.21  organization
organization org-name
undo organization
View
PKI entity view
Parameter
org-name: Organization name, in a case-insensitive string of 1 to 31 characters
Use the organization command to configure the name of the organization to which the entity belongs.
Use the undo organization command to remove the configuration.
By default, no organization name is specified for an entity.
Example
# Configure the name of the organization to which an entity belongs.
[Sysname-pki-entity-1] organization org-name
1.1.22  organizational-unit
organizational-unit org-unit-name
undo organizational-unit
View
PKI entity view
Parameter
org-unit-name: Organization unit name, in a case-insensitive string of 1 to 31 characters. This parameter is used to distinguish the units of an organization.
Use the organizational-unit command to specify the name of the organization unit to which this entity belongs.
Use the undo organizational-unit command to remove the configuration.
By default, no organization unit name is specified for an entity.
Example
# Configure the name of the organization unit to which an entity belongs.
[Sysname-pki-entity-1] organizational-unit soft plat
1.1.23  pki certificate access-control-policy
pki certificate access-control-policy policy-name
undo pki certificate access-control-policy { policy-name | all }
View
Parameter
policy-name: Access control policy name of a certificate attribute, in a case-insensitive string of 1 to 16 characters, excluding “a”, “al” and “all”.
Use the pki certificate access-control-policy command to create an access control policy of a certificate attribute and enter its view.
Use the undo pki certificate access-control-policy command to remove the access control policy of one or all certificate attributes.
No access control policy exists by default.
Example
# Configure an access control policy named mypolicy and enter its view.
[Sysname] pki certificate access-control-policy mypolicy
[Sysname-pki-cert-acp-mypolicy]
1.1.24  pki certificate attribute-group
pki certificate attribute-group group-name
undo pki certificate attribute-group { group-name | all }
View
Parameter
group-name: Name of a certificate attribute group, in a case-insensitive string of 1 to 16 characters, excluding “a”, “al” and “all”.
Use the pki certificate attribute-group command to create a certificate attribute group and enter its view.
Use the undo pki certificate attribute-group command to delete one or all certificate attribute groups.
No certificate attribute group exists by default.
Example
# Create a certificate attribute group named mygroup and enter its view.
1.1.25  pki delete-certificate
pki delete-certificate { ca | local } domain domain-name
View
Parameter
ca: Specifies to delete all the locally stored CA certificates.
local: Specifies to delete all the local certificates.
domain-name: PKI domain where the certificate to be deleted locates.
Use the pki delete-certificate command to delete the locally stored certificates.
Example
# Delete the local certificate in the PKI domain named cer.
[Sysname] pki delete-certificate local domain cer
1.1.26  pki domain
pki domain name
undo pki domain name
View
Parameter
name: PKI domain name, in a case-insensitive string of 1 to 15 characters, indicating the PKI domain to which this device belongs.
Use the pki domain command to create a PKI domain and enter the PKI domain view.
Use the undo pki domain command to remove the configuration.
By default, no PKI domain exists.
Example
# Enter PKI domain view.
1.1.27  pki entity
pki entity name
undo pki entity name
View
Parameter
name: Unique ID of the entity, in a case-insensitive string of 1 to 15 characters.
Use the pki entity command to name a PKI entity and enter PKI entity view.
Use the undo pki entity command to remove the name and all configurations under the name space.
By default, entity name is not specified.
You can configure a variety of attributes for an entity in PKI entity view. name is only designed for other commands reference, not for related fields of a certificate.
Example
# Enter PKI entity view.
[Sysname] pki entity en
[Sysname-pki-entity-en]
1.1.28  pki import-certificate
pki import-certificate { ca | local } domain domain-name { der | p12 | pem } [ filename filename ]
View
Parameter
ca: Specifies a CA certificate.
local: Specifies a local certificate.
domain-name: PKI domain where the certificate locates.
der: Specifies the certificate in the format of DER.
p12: Specifies the certificate in the format of P12.
pem: Specifies the certificate in the format of PEM.
filename filename: Certificate filename, in a case-insensitive string of 1 to 127 characters, which defaults to  domain-name_ca.cer or domain-name_local.cer.
Use the pki import-certificate command to import an existing CA certificate or local certificate and save locally.
Related command: pki domain.
Example
# Import the CA certificate in the PKI domain named cer in the format of PEM.
[Sysname] pki import-certificate ca domain cer pem
1.1.29  pki request-certificate domain
pki request-certificate  domain domain-name [ password ] [ pkcs10 [ filename filename ] ]
View
Parameter
domain-name: Domain name with CA or RA related information for certificate request.
password: Password needed for certificate revocation, in a case-insensitive string of 1 to 31 characters.
pkcs10: Displays the BASE64-encoded PKCS#10 certificate request on the terminal.  This message is applicable for the certificate requests delivered through phone, disk or e-mail.
filename: Name of the file for saving the PKCS#10 certificate request, in a case-insensitive string of 1 to 127 characters.
Use the pki request-certificate domain command to apply for a local certificate to CA through SCEP. If SCEP fails, you can print the local certificate request in BASE64 format using the optional parameter PKCS#10, copy it, and send one to CA through phone, disk or e-mail.
This operation will not be saved within the configuration.
Example
# Specify to manually apply for a certificate and display the PKCS#10 certificate request information.
[Sysname] pki request-certificate domain 1 pkcs10
1.1.30  pki retrieval-certificate
pki retrieval-certificate { ca | local } domain domain-name
View
Parameter
ca: Specifies to download a CA certificate.
local: Specifies to download a local certificate.
Use the pki retrieval-certificate command to retrieve a certificate from the certificate issuing server and then download it locally.
Example
# Retrieve a certificate.
[Sysname] pki retrieval-certificate ca domain 1
1.1.31  pki retrieval-crl domain
pki retrieval-crl domain domain-name
View
Parameter
Use the pki retrieval-crl command to retrieve the latest CRL from the CRL server for the purpose of verifying the validity of the existing certificate.
Example
# Retrieve a CRL.
[Sysname] pki retrieval-crl domain 1
1.1.32  pki validate-certificate
pki validate-certificate { ca | local } domain domain-name
View
Parameter
ca: Specifies to validate a CA certificate.
local: Specifies to validate a local certificate.
Use the pki validate-certificate command to verify the validity of a certificate.
The focus is to check the CA signature on the certificate, and to make sure that the certificate is still within the validity period and beyond revocation.
Example
# Verify the validity of a local certificate.
[Sysname] pki validate-certificate domain 1
1.1.33  root-certificate fingerprint
root-certificate fingerprint { md5 | sha1 } string
undo root-certificate fingerprint
View
PKI domain view
Parameter
md5: Specifies to use MD5 fingerprint.
sha1: Specifies to use SHA1 fingerprint.
string: Fingerprint to be used. For MD5 fingerprint, it must consist of 32 characters in hexadecimal format. For SHA1 fingerprint, it must consist of 40 characters in hexadecimal format.
Use the root-certificate fingerprint command to configure the fingerprint used for validating the CA root certificate.
Use the undo root-certificate fingerprint command to remove the configuration.
By default, no fingerprint is configured for validating the CA root certificate.
Example
# Configure MD5 fingerprint for validating the CA root certificate.
[Sysname-pki-domain-1] root-certificate fingerprint md5 12EF53FA355CD23E12EF53FA355CD23E
# Configure SHA1 fingerprint for validating the CA root certificate.
[Sysname-pki-domain-1] root-certificate fingerprint sha1 D1526110AAD7527FB093ED7FC037B0B3CDDDAD93
1.1.34  rule
rule [ id ] { deny | permit } group-name
undo rule { id | all }
View
Access control policy view
Parameter
id: Access control number of the certificate attribute, in the range 1 to 16, which is defaulted to the minimum number unused in the range 1 to 16.
deny: The certificate is thought of as invalid and cannot pass the access control policy detection  when the certificate matches with the attribute defined in the attribute group.
permit: The certificate is thought of as valid and can pass the access control policy detection  when the certificate matches with the attribute defined in the attribute group.
group-name: Name of the certificate attribute group related to the rule, in a case-insensitive string of 1 to 16 characters, excluding “a”, “al” and “all”.
all: All the control rules.
Use the rule command to create an access control rule for certificate attributes.
Use the undo rule command to delete one or all the access control rules.
No access control rule exists by default.
Note that rule-related certificate attribute group must exist.
Example
# Create an access control rule, meaning that the certificate is thought of as valid and can pass the access control policy detection when a certificate matches the attributes in the certificate attribute group mygroup.
[Sysname -pki-cert-acp-mypolicy] rule 1 permit mygroup
1.1.35  state
state state-name
undo state
View
PKI entity view
Parameter
state-name: State or province name, in a case-insensitive string of 1 to 31 characters.
Use the state command to specify the name of the state or province where an entity resides.
Use the undo state command to remove the configuration.
By default, no state is specified.
Example
# Specify the state where an entity resides.
[Sysname-pki-entity-1] state Country
