H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
06-Port Correlation Configuration Command
06-Port Correlation Configuration Command 236 KB
Table of Contents
Chapter 1 Ethernet Interface Configuration Commands. 1-1
1.1 General Ethernet Interface Configuration Commands. 1-1
1.1.1 broadcast-suppression. 1-1
1.1.2 copy configuration. 1-2
1.1.3 description. 1-3
1.1.4 display brief interface. 1-3
1.1.5 display interface. 1-6
1.1.6 display loopback-detection. 1-10
1.1.7 display port 1-10
1.1.8 display port-group manual 1-11
1.1.9 duplex. 1-12
1.1.10 flow-control 1-13
1.1.11 flow-interval 1-14
1.1.12 group-member 1-15
1.1.13 interface. 1-15
1.1.14 jumboframe enable. 1-16
1.1.15 loopback. 1-17
1.1.16 loopback-detection control enable. 1-18
1.1.17 loopback-detection enable. 1-19
1.1.18 loopback-detection interval-time. 1-20
1.1.19 loopback-detection per-vlan enable. 1-20
1.1.20 mdi 1-21
1.1.21 multicast-suppression. 1-22
1.1.22 port-group. 1-23
1.1.23 port link-type. 1-24
1.1.24 reset counters interface. 1-25
1.1.25 shutdown. 1-25
1.1.26 speed. 1-26
1.1.27 unicast-suppression. 1-27
1.1.28 virtual-cable-test 1-28
Chapter 2 Link Aggregation Configuration Commands. 2-1
2.1 Link Aggregation Configuration Commands. 2-1
2.1.1 display lacp system-id. 2-1
2.1.2 display link-aggregation interface. 2-1
2.1.3 display link-aggregation summary. 2-4
2.1.4 display link-aggregation verbose. 2-5
2.1.5 lacp port-priority. 2-7
2.1.6 lacp system-priority. 2-8
2.1.7 link-aggregation group description. 2-9
2.1.8 link-aggregation group mode. 2-9
2.1.9 port link-aggregation group. 2-10
2.1.10 port-group aggregation. 2-11
2.1.11 reset lacp statistics. 2-11
Chapter 3 Port Isolation Configuration Commands. 3-1
3.1 Port Isolation Configuration Commands. 3-1
3.1.1 display port-isolate group. 3-1
3.1.2 port-isolate enable. 3-2
broadcast-suppression { ratio | pps max-pps }
undo broadcast-suppression
View
Ethernet interface view/port group view
Parameter
ratio: Specifies the maximal ratio of broadcast traffic for an Ethernet interface. It ranges between 1 to 100 and defaults to 100. The smaller the ratio, the less broadcast traffic allowed through the interface.
pps max-pps: Specifies the maximal broadcast packet number per second for an Ethernet interface. It ranges between 1 to 1,488,000 for GigabitEthernet port(s) and 1 to 1,488,0000 for 10GE port(s) in pps, representing packets per second.
Use the broadcast-suppression command to configure broadcast storm suppression ratio.
Use the undo broadcast-suppression command to restore the broadcast suppression ratio.
By default, all broadcast traffic is allowed to go through an Ethernet interface, that is, broadcast traffic is not suppressed.
The above commands apply to the current port only while executed under Ethernet interface view, or to all ports in a port group while executed under port group view.
Note that when broadcast traffic exceeds the maximum value configured, system will discard the extra packets so that the traffic ratio falls below the limit again to ensure network functions proper.
Example
# Allow 20% of broadcast traffic to pass through the interface GigabitEthernet 1/0/28, that is, configure the broadcast suppression ratio to 80%.
[Sysname] interface GigabitEthernet 1/0/28
[Sysname-GigabitEthernet1/0/28] broadcast-suppression 20
# Allow 20% of multicast traffic to pass through the interface GigabitEthernet1/0/1, that is, configure the multicast suppression ratio to 80%.
[Sysname] port-group manual group1
[Sysname-port-group-manual-group1] group-member Gigabitethernet1/0/1 to Gigabitethernet1/0/5
[Sysname-port-group-manual-group1] broadcast-suppression 20
copy configuration source interface-type interface-number destination  interface-list
View
Parameter
interface-type: Type of a specified interface.
interface-number: Number of a specified interface.
interface-list: Destination Ethernet interface list, in the format of
interface-type interface-number [ to interface-type interface-number ] &<1-10>, where &<1-10> indicates that you can specify up to 10 port ranges.
Use the copy configuration command to copy configurations on a specific interface to other interface(s). The configuration can be copied include port configuration, GVRP, STP, Port-isolate, VLAN, LACP, QoS and QINQ.
Example
# Copy configurations from the interface GigabitEthernet 1/0/1 to the interface GigabitEthernet 1/0/2.
<SYSNAME> system-view
[SYSNAME] copy configuration source GigabitEthernet 1/0/1 destination GigabitEthernet 1/0/2
Copying speed/duplex configuration...
 Copying GVRP configuration...
 Copying STP configuration...
 Copying Port-isolate configuration...
 Copying VLAN configuration...
 Copying LACP configuration...
 Copying QoS configuration...
 Copying QINQ and BPDU tunnel configuration...
1.1.3  description
View
Parameter
text: The description of an Ethernet interface, a string of 1 to 80 characters.
Use the description command to configure the description of an Ethernet interface.
Use the undo description command to remove the description.
Default to interface name followed by the “interface” string. For example ”GigabitEthernet1/0/1 Interface”.
Example
# Configure the description for interface GigabitEthernet 1/0/2 to “lanswitch-interface”.
[Sysname-GigabitEthernet1/0/2] description lanswitch-interface
display brief interface [ interface-type [ interface-number ] ] [ | { begin | include | exclude } regular-expression ]
View
Parameter
|: Uses regular expression to filter output configuration.
begin: Displays information that begins with the specified string.
include: Displays information that contains the specified string.
exclude: Displays information that do not contain the specified string.
regular-expression: Regular expression, in the range of 1 to 256 characters, excluding spaces.
Table 1-1 Special characters in regular expressions
Special Characters
Special Meaning
Notes on Use
_
Underscore, similar to a wildcard character, can represent one of the following: (^|$|[,(){}])
a space, the beginning of the string, the end of the string
If the regular expression does not begin with an underscore (-), then, other than the limit imposed by the command line length, there is no other limit on the number of underscore (-).
If the regular expression begins with an underscore (-), then the number of consecutive underscores (-) should be less than five.
If the underscores (-) are not consecutive, then the first group of underscores (-) can be used to filter the routing table. The following underscores will be ignored.
Left paraphrase, represents a pull in stack.
Users are recommended not to use this character in a regular expression.
Full stop, wildcard character, matches any single character, including white space.
None
Star character, matches expressions with 0 or more single-character or multiple-character
 zo* matches z and zoo.
plus, matches expressions with 1 or more single-character or multiple-character
zo+ matches zo and zoo, but not z.
Use the display brief interface command to display brief interface information,
l           Brief information of interface(s) under route mode, including simple interface name, link state, protocol link state, protocol type, and main IP address.
l           Brief information of interface(s) under bridge mode, including port name, link state, port speed, duplex, link type, Default VLAN ID.
Note that:
l           If neither interface type nor interface number is specified, all interface information will be displayed;
l           If only interface type is specified, then only information of this particular type of interface will be displayed.
l           If both interface type and interface number are specified, then only information of the specified interface will be displayed.
Example
# Display brief information of interface(s).
<Sysname> display brief interface
The brief information of interface(s) under route mode:
Interface            Link      Protocol-link  Protocol type    Main IP
NULL0                UP        UP(spoofing)   NULL             --
Vlan1                UP        UP             ETHERNET         192.168.0.52
Vlan2                DOWN      DOWN           ETHERNET         --
Vlan100              DOWN      DOWN           ETHERNET         --
The brief information of interface(s) under bridge mode:
Interface            Link      Speed     Duplex   Link-type  PVID
GE1/0/1              DOWN      auto      auto     trunk      100
GE1/0/2              DOWN      auto      auto     access     1
GE1/0/3              DOWN      auto      auto     access     1
GE1/0/4              DOWN      auto      auto     access     1
GE1/0/5              DOWN      auto      auto     access     1
GE1/0/6              UP        100M(a)   full(a)  access     1
GE1/0/7              DOWN      auto      auto     access     1
GE1/0/8              DOWN      auto      auto     access     1
GE1/0/9              DOWN      auto      auto     access     1
GE1/0/10             DOWN      auto      auto     access     1
GE1/0/11             DOWN      auto      auto     access     1
GE1/0/12             DOWN      auto      auto     access     1
GE1/0/13             DOWN      auto      auto     access     1
GE1/0/14             DOWN      auto      auto     access     1
# Display brief interface information that contains the string “DOWN”.
<Sysname> display brief interface | include DOWN
Table 1-2 Description on the fields of the display brief interface command.
Interface name
Link
Interface physical link state, which can be up or down
Protocol-link
Interface protocol link state, which can be up or down
Protocol type
Interface protocol type
Main IP
Main IP
Speed
 Interface rate, in bps
Duplex
Duplex mode, which can be half, full, or auto.
Link-type
Link-type
PVID
Default VLAN ID
display interface [ interface-type [ interface-number ] ]
View
Parameter
Use the display interface command to display the current state of a specified interface and related information.
Example
# Display the current state of interface GigabitEthernet 1/0/1 and related information.
<Sysname> display interface GigabitEthernet 1/0/1
GigabitEthernet1/0/1 current state: DOWN
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0000-5600-0001
 Description: GigabitEthernet1/0/1 Interface
 Loopback is not set
Media type is twisted pair
 Port hardware type is 1000_BASE_T
1000Mbps-speed mode, full-duplex mode
 Flow-control is not enabled
 The Maximum Frame Length is 9216
 Broadcast MAX-ratio: 100%
 Unicast MAX-ratio: 100%
 Multicast MAX-ratio: 100%
 Allow jumbo frame to pass
 PVID: 1
 Mdi type: auto
 Port link-type: access
  Tagged   VLAN ID : 1
  Untagged VLAN ID : none
Port priority: 0
 Last 300 seconds input:  0 packets/sec 0 bytes/sec
 Last 300 seconds output:  0 packets/sec 0 bytes/sec
 Input (total):  0 packets, 0 bytes
          0 broadcasts, 0 multicasts
 Input (normal):  0 packets, 0 bytes
          0 CRC, - frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
          0 broadcasts, 0 multicasts, 0 pauses
 Output (normal): - packets, - bytes
          - broadcasts, - multicasts, - pauses
 Output: 0 output errors, 0 underruns, - buffer failures
          0 lost carrier, - no carrier
Table 1-3 Description on the fields of the display interface  command.
Current physical link state of the Ethernet interface, which can be up or down (Interface physical link state is down) or administratively down (Use the shutdown command can shut down the port manually).
Frame type of the Ethernet interface
Hardware address
Hardware address
Description of the port
Loopback is not set
Loopback is not configured
Media type
Media type
Port hardware type
Port hardware type
Current speed mode and duplex mode
Link speed and duplex status ( force or auto-negotiation )
The maximum frame length allowed on an interface
Broadcast-suppression ratio(%)
Broadcast storm suppression ratio (the maximum ratio of allowed number of broadcast packets to overall traffic through an interface)
Unicast MAX-ratio
Unicast storm suppression ratio (the maximum ratio of allowed number of unicast packets to overall traffic through an interface)
Multicast MAX-ratio
Multicast storm suppression ratio (the maximum ratio of allowed number of multicast packets to overall traffic through an interface)
Allow jumbo frame to pass through
PVID
Default VLAN ID
Mdi type
Cable type
Port link-type
Interface link type, which could be access, trunk, and hybrid.
Tagged   VLAN ID
Identify the VLANs that need Tag markers
Untagged VLAN ID
Identify the VLANs that do not need Tag markers
Port priority
Port priority
Average input rate over the last 300 seconds
Average output rate over the last 300 seconds
Statistics on the total incoming packets (including normal packets, error packets) on the port
The “-” indicates that the corresponding entry is invalid
Statistics on the normal incoming packets on the port
Statistics on the abnormal incoming packets on the port
Statistics on the total outgoing packets (including normal packets, error packets) on the port
          - broadcasts, - multicasts, -pauses
Statistics on the normal outgoing packets on the port
Output: 0 output errors, 0 underruns, 0 buffer failures
0 aborts, 0 deferred, 0 collisions, 0 late collisions          0 lost carrier, - no carrier
Statistics on the abnormal outgoing packets on the port
View
Parameter
None
Use the display loopback-detection command to display loopback detection information on a port
If loopback detection is already enabled, this command will also display the detection interval and information on the ports currently detected with a loopback.
Example
# Display loopback detection information on a port.
<Sysname> display loopback-detection
Loopback-detection is running
Detection interval time is 30 seconds
There is no port existing loopback link
Table 1-4 Description on the fields of the display loopback-detection command.
Detection interval is 30 seconds
No port is currently being detected with a loopback
1.1.7  display port
display port { hybrid | trunk I combo }
View
Parameter
hybrid: Displays the current Hybrid port(s).
trunk: Displays the current Trunk port(s).
combo: Displays the current Combo port(s) and the corresponding optical and electrical ports.
Use the display port command to display information on the current ports of a specified type.
Example
# Display the current Trunk port(s).
<Sysname> display port trunk
Interface           PVID  VLAN passing
GE1/0/8             2     1-4, 6-100, 145, 177, 189-200, 244, 289, 400
Table 1-5 Description on the fields of the display port command.
Interface name
PVID
Default VLAN ID of the interface
VLAN passing
VLAN ID of VLANs that the ports can pass through
display port-group manual [ all | name port-group-name ]
View
Parameter
all: All manual port groups.
name port-group-name: Name of a specified manual port group, a string of 1 to 32 characters.
Use the display port-group manual command to display information on a specified manual port group.
l           name port-group-name: Displays the details for a specified manual port group, including its name and the Ethernet interface ports included.
l           all: Displays the details for all manual port groups, including their names and the Ethernet interface ports included.
l           Absence of parameters indicates that the names of all port groups will be displayed.
Example
# Display details for the port group 1.
<Sysname> display port-group manual name group1
 Member of group1:
    GigabitEthernet1/0/1     GigabitEthernet1/0/2     GigabitEthernet1/0/3
# Display the names of all port groups.
The following manual port group exist(s):
group1                                    group2
# Display details for all manual port groups.
<Sysname> display port-group manual all
Member of group1:
GigabitEthernet1/0/1     GigabitEthernet 1/0/2  GigabitEthernet1/0/3           GigabitEthernet1/0/4         GigabitEthernet 1/0/5
Member of group2:
GigabitEthernet1/0/7       GigabitEthernet1/0/8          GigabitEthernet 1/0/9
    GigabitEthernet1/0/10
    GigabitEthernet1/0/4     GigabitEthernet1/0/5
Table 1-6 Description on the fields of the display port-group manual command
Member of group1
Member of the manual port group
Interface name in the port group(s)
The existing manual port group(s)
1.1.9  duplex
duplex { auto | full | half }
undo duplex
View
Parameter
auto: Indicates that the interface is in an auto-negotiation state.
full: Indicates that the interface is in a full-duplex state.
half: Indicates that the interface is in a half-duplex state.
Use the duplex command to configure the duplex mode for an Ethernet interface.
Use the undo duplex command to restore the duplex mode for an Ethernet interface to the default.
By default, the duplex mode for an Ethernet interface is auto.
Related command: speed.
Example
# Configure the interface GigabitEthernet 1/0/2 to work in full-duplex mode.
[Sysname-GigabitEthernet1/0/2] duplex full
1.1.10  flow-control
flow-control
undo flow-control
View
Parameter
None
Use the flow-control command to turn on flow control on an Ethernet interface.
 Use the undo flow-control command to turn off flow control on an Ethernet interface.
By default, flow control on an Ethernet interface is turned off.
&  Note:
This command is only applicable when the peer Ethernet interface also supports flow control. Therefore, it is recommended that you align the configurations with the peer.
Example
# Turn on flow control on interface GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-control
flow-interval interval
undo flow-interval
View
Parameter
interval: Time interval at which interface statistics is collected, in the range of 5 to 300 seconds, a multiple of 5.
Use the flow-interval command to configure the time interval for collecting interface statistics.
Use the undo flow-interval command to restore the default interval.
By default, the default interval for collecting interface statistics is 300 seconds.
When you use the display interface interface-type interface-number command to display the information of a port, the system performs statistical analysis on the traffic flow passing through the port during the specified interval and displays the average rates in the interval. For example, if you set this interval to 100 seconds, the displayed information is as follows:
 Last 100 seconds input:  0 packets/sec 0 bytes/sec
 Last 100 seconds output:  0 packets/sec 0 bytes/sec
Related command: display interface.
Example
# Set the time interval for collecting interface statistics to 100 seconds on interface GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-interval 100
1.1.12  group-member
group-member interface-list
undo group-member interface-list
View
Manual port group view
Parameter
interface-list: Ethernet interface list, in the format of
Use the group-member command to add an Ethernet interface to a specified manual port group.
Use the undo group-member command to remove a specified Ethernet interface from a manual port group.
By default, a manual port group is empty, that is, there is no Ethernet interface in it.
Example
# Add the interface GigabitEthernet 1/0/1 and GigabitEthernet1/0/5 to the manual port group1.
[Sysname-port-group-manual-group1] group-member GigabitEthernet 1/0/1 to GigabitEthernet 1/0/5
1.1.13  interface
View
Parameter
interface-type: Port type, which can be GigabitEthernet, TenGigabitEthernet, LoopBack, NULL or Vlan-interface.
interface-number: Port number, in the format of slot number/subslot number/port number, where:
l           slot number only can be 1;
l           On the front panel, the subslot number is 0, on the rear panel, the two expansion slot number is 1 and 2;
l           The port number is relevant to the device.
For example, GigabitEthernet1/0/1 indicates the Gigabit Ethernet port with number of 1/0/1, this port is on the front panel and port number is 1.
Use the interface command to enter the related interface view.
Example
# Enter interface view of the interface GigabitEthernet 1/0/1.
jumboframe enable
undo jumboframe enable
View
Parameter
None
Use the jumboframe enable command to allow jumbo frames that are not larger than 9216 bytes to pass through the current Ethernet port.
Use the undo jumboframe enable command to allow frames that are not larger than 1536 bytes to pass through the current Ethernet port.
By default, frames that are not larger than 9216 bytes are allowed to pass through the Ethernet port.
l           Execution of this command under Ethernet interface view will only apply the configurations to the current Ethernet interface.
l           Execution of this command under port group view will apply the configurations to the Ethernet interface(s) in the port group.
Example
# Enable jumbo frames that are not larger than 1536 bytes to pass through the interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] jumboframe enable
1.1.15  loopback
undo loopback
View
Parameter
external: Enable external loopback testing on an Ethernet interface.
internal: Enable internal loopback testing on an Ethernet interface.
Use the loopback command to enable Ethernet interface loopback testing.
By default, Ethernet interface loopback testing is disabled.
&  Note:
l      Ethernet interface loopback testing should be enabled while testing certain functionalities, such as during the initial identification of any network failure.
l      While enabled, Ethernet interface loopback testing will work in a full-duplex mode. The interface will return to its original state upon completion of the loopback testing.
Example
# Configure to enable loopback testing for the interface GigabitEthernet 1/0/2.
[Sysname-GigabitEthernet1/0/2] loopback internal
undo loopback-detection control enable
View
Parameter
None
Use the loopback-detection control enable command to enable loopback detection for a Trunk port or Hybrid port.
Use the undo loopback-detection control enable command to disable loopback detection for a Trunk port or Hybrid port.
By default, loopback detection for a Trunk port or Hybrid port is disabled.
l           When the loopback detection is enabled, if a port has been detected with loopback, it will be shutdown. A Trap message will be sent to the terminal and the corresponding MAC address forwarding entries will be deleted.
l           When the loopback detection is disabled, if a port has been detected with loopback, a Trap message will be sent to the terminal. The port is still working properly.
Note that this command is inapplicable to an Access port as its loopback detection is enabled by default.
Example
# Enable loopback detection for the Trunk port GigabitEthernet 1/0/1.
[Sysname] loopback-detection enable
[Sysname-GigabitEthernet1/0/1] loopback-detection enable
[Sysname-GigabitEthernet1/0/1] loopback-detection control enable
undo loopback-detection enable
View
System view/Ethernet interface view
Parameter
None
Use the loopback-detection enable command to enable loopback detection globally or on a specified port.
Use the undo loopback-detection enable command to disable loopback detection globally or on a specified port.
By default, loopback detection is disabled for an Access, Trunk, or Hybrid port.
l           If an Access port has been detected with loopback, it will be shutdown. A Trap message will be sent to the terminal and the corresponding MAC address forwarding entries will be deleted.
l           If a Trunk port or Hybrid port has been detected with loopback, a Trunk message will be sent to the terminal. They will be shutdown if the loopback testing function is enabled on them. In addition, a Trap message will be sent to the terminal and the corresponding MAC address forwarding entries will be deleted.
  Caution:
l      Loopback detection on a given port is enabled only after the loopback-detection enable command has been issued in both system view and the interface view of the port.
l      Loopback detection on all ports will be disabled after the issuing of the undo loopback-detection enable command under system view.
Related command: loopback-detection control enable.
Example
# Enable loopback detection on the interface GigabitEthernet 1/0/1.
loopback-detection interval-time time
undo loopback-detection interval-time
View
Parameter
time: Time interval for external loopback detection, in the range of 5 to 300 seconds.
Use the loopback-detection interval-time command to configure time interval for external loopback detection.
Use the undo loopback-detection interval-time command to restore the default time interval for external loopback detection.
By default, the default interval for external loopback detection is 30 seconds.
Related command: display loopback-detection.
Example
# Configure time interval for external loopback detection to 10 seconds.
[Sysname] loopback-detection interval-time 10
undo loopback-detection per-vlan enable
View
Parameter
None
Use the loopback-detection per-vlan enable command to enable loopback detection in all VLANs with Trunk ports or Hybrid ports.
Use the undo loopback-detection per-vlan enable command to enable loopback detection in the default VLAN with Trunk ports or Hybrid ports.
By default, loopback detection is only enabled in the default VLAN(s) with Trunk ports or Hybrid ports.
Note that the loopback-detection per-vlan enable command is not applicable to Access ports.
Example
# Enable loopback detection in all VLANs to which the Trunk port GigabitEthernet 1/0/1 belong.
[Sysname-GigabitEthernet1/0/1] loopback-detection per-vlan enable
1.1.20  mdi
mdi { across | auto | normal }
undo mdi
View
Parameter
across: Configures an Ethernet interface to use cross over cable.
auto: Configures an Ethernet interface to use auto-detection cable.
normal: Configures an Ethernet interface to use straight through cable.
Use the mdi command to configure the cable type for an Ethernet interface.
Use the undo mdi command to restore the cable type for an Ethernet interface.
By default, an Ethernet interface uses auto-detection cable.
&  Note:
l      The Combo port and 10 GE port does not support this command.
l      S5500-SI Series Ethernet Switches only support mdi auto.
Example
# Configure the interface GigabitEthernet 1/0/1 to use auto-detection cable.
[Sysname-GigabitEthernet1/0/1] mdi auto
multicast-suppression { ratio | pps max-pps }
undo multicast-suppression
View
Parameter
ratio: Specifies the maximal ratio of multicast traffic for an Ethernet interface. Ranges between 1 to 100. The smaller the ratio, the less multicast traffic allowed through the interface.
pps max-pps: Specifies the maximal multicast packet number per second for an Ethernet interface, It ranges between 1 to 1,488,000 for GE port(s) and ranges between 1 to 14,880,000 for 10GE port(s) in pps, representing packets per second.
Use the multicast-suppression command to configure multicast storm suppression ratio.
Use the undo multicast-suppression command to restore multicast suppression ratio.
 By default, all multicast traffic is allowed to go through an Ethernet interface, that is, multicast traffic is not suppressed.
Note that when multicast traffic exceeds the maximum value configured, system will discard the extra packets so that the traffic ratio falls below the limit again to ensure network functions proper.
Example
[Sysname-GigabitGigabitEthernet1/0/1] multicast-suppression 20
On all ports of the manual port group “Group1”, allow multicast traffic equivalent to 20% of the total transmission capability of each port to pass and suppress excessive multicast packets.
[Sysname-port-group manual group1] group-member ethernet 2/0
[Sysname-port-group manual group1] group-member ethernet 2/1
[Sysname-port-group manual group1] multicast-suppression 20
1.1.22  port-group
port-group { manual port-group-name | aggregation agg-id }
undo port-group manual port-group-name
View
Parameter
manual port-group-name: Name of a specified manual port group, a string of 1 to 32 characters.
aggregation agg-id: Number of the specified port aggregation group. The specified port aggregation group must already exist. You can use the display link-aggregation summary command to display brief information of all existing port aggregation groups.
l           Use the port-group manual command to enter a specified manual port group view. If the manual port group does not exist, you need to create it first before entering its view.
l           Use the port-group aggregation command to enter a port group aggregation view.
l           Use the undo port-group manual command to delete a specified manual port group.
By default, no manual port group is configured.
Example
# Create a manual port group 1.
undo port link-type
View
Parameter
access: Specifies the link type of a port as Access.
hybrid: Specifies the link type of a port as Hybrid.
trunk: Specifies the link type of a port as Trunk.
Use the port link-type command to configure Ethernet port link type.
Use the undo port link-type command to restore the system default Ethernet port link type, which is “Access”.
 By default, link type for all Ethernet interfaces is Access.
Example
# Configure the interface GigabitEthernet 1/0/1 to be Trunk port.
[Sysname-GigabitEthernet 1/0/1] port link-type trunk
# Configure all the member ports of the manual port group “Group1”( from GigabitEthernet 1/0/1 to GigabitEthernet 1/0/5 ) as Hybrid ports.
[Sysname-port-group-manual-group1] port link-type hybrid
reset counters interface [ interface-type [ interface-number ] ]
View
Parameter
interface-type: Interface type.
interface-number: Interface number
Use the reset counters interface command to reset statistics for a specified interface.
To sample network traffic within a period of time for an interface, you need to reset the original interface statistics.
l           If neither interface type nor interface number is specified, all interface information will be reset;
l           If only interface type is specified, then only information of this particular type of interface will be reset.
l           If both interface type and interface number are specified, then only information of the specified interface will be reset.
Example
# Reset statistics for the interface GigabitEthernet 1/0/1.
<Sysname> reset counters interface GigabitEthernet 1/0/1
1.1.25  shutdown
shutdown
View
Parameter
None
Use the shutdown command to shut down an Ethernet interface.
Use the undo shutdown command to turn on Ethernet interface.
By default, Ethernet interface is enabled.
In certain circumstances, modification to the interface parameters does not immediately take effect, and therefore, you need to shut down the relative interface to make the modification work.
Example
# Shut down the interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] shutdown
# Turn on the interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo shutdown
1.1.26  speed
speed { 10 | 100 | 1000 | auto }
undo speed
View
Parameter
10: Indicates that the interface rate is 10 Mbps.
100: Indicates that the interface rate is 100 Mbps.
1000: Indicates that the interface rate is 1000 Mbps.
auto: Indicates that the interface rate is automatically negotiated between peer Ethernet interfaces.
Use the speed command to configure Ethernet interface data rate.
Use the undo speed command to restore Ethernet interface data rate.
By default, Ethernet interface data rate is automatically negotiated between peer Ethernet interfaces.
l           Combo port only supports speed auto and speed 1000.
l           10GE port cannot support speed command.
Note that he Combo port does not support the speed command.
Example
# Configure data rate for the interface GigabitEthernet 1/0/2 to 100 Mbps.
[Sysname-GigabitEthernet1/0/2] speed 100
unicast-suppression { ratio | pps max-pps }
undo unicast-suppression
View
Parameter
ratio: Specifies the maximal ratio of unicast traffic for an Ethernet interface. Ranges between 1 to 100. The smaller the ratio, the less unicast traffic allowed through the interface.
pps max-pps: Specifies the maximal unicast packet number per second for an Ethernet interface. It ranges between 1 to 1,488,000 for GigabitEthernet port(s) and 1 to 1,488,0000 for 10GE port(s) in pps, representing packets per second.
Use the unicast-suppression command to configure unicast storm suppression ratio.
Use the undo unicast-suppression command to restore unicast suppression ratio.
By default, all unicast traffic is allowed to go through an Ethernet interface, that is, unicast traffic is not suppressed.
Note that when unicast traffic exceeds the maximum value configured, system will discard the extra packets so that the traffic ratio falls below the limit again to ensure network functions proper.
Example
# Allow 20% of unicast traffic to pass through the interface GigabitEthernet 1/0/28, that is, configure the unicast suppression ratio to 80%.
[Sysname-GigabitEthernet1/0/28] unicast-suppression 20
# On all ports of the manual port group “Group1” ( from GigabitEthernet 1/0/1 to GigabitEthernet 1/0/5 ), allow unknown unicast traffic equivalent to 20% of the total transmission capability of each port to pass and suppress excessive unknown unicast packets.
[Sysname-port-group-manual-group1] unicast-suppression 20
virtual-cable-test
View
Parameter
None
Use the virtual-cable-test command to enable the virtual cable test for an Ethernet interface and to display the testing result. The tested items include:
l           Cable status: Could be normal, abnormal, abnormal-open, abnormal-short, and failure;
l           Cable length;
l           Pair Impedance mismatch;
l           Pair skew;
l           Pair swap;
l           Pair polarity;
l           Insertion loss;
l           Return loss;
l           Near-end crosstalk.
By default, virtual cable test is disabled.
Note that:
l           When the cable is functioning properly, the cable length in the test result represents no meaning;
l           When the cable is not functioning properly, the cable length in the test result represents the length from the current interface to the failed position.
l           Currently the S5500-SI Series Ethernet Switches support the tested items include: cable status and cable length.
Example
# Enable the virtual cable test for the interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] virtual-cable-test
Cable status: abnormal(open), 0 metres
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: - db
View
Parameter
None
Use the display lacp system-id command to display the local system ID, which comprises system LACP priority and system MAC address.
Example
# Display the local system ID.
<Sysname> display lacp system-id
 Actor System ID: 0x8000, 00e0-fc00-0100
Table 2-1 Description on the fields of the display lacp system-id command
Actor System ID
The local system ID which comprises system LACP priority and system MAC address.
display link-aggregation interface interface-type interface-number [ to interface-type interface-number ]
View
Parameter
interface interface-type interface-number [ to interface-type interface-number ]: Specifies an interface range or an interface if the to keyword and the second interface are not specified.
Use the display link-aggregation interface command to display detailed information about link aggregation on the specified port or ports.
l           ID of the link aggregation group of which this port is a member.
l           Local port LACP priority, operational key, LACP state flag.
l           Remote system ID, port number, port LACP priority, operational key, and LACP state flag.
l           Statistics about received, invalid, and sent LACP packets.
You may find that information about the remote system is replaced by 0 and no statistics about LACPDUs are provided for manual link aggregation groups. This is normal because this type of aggregation group has no knowledge of its partner and does not use LACPDUs for maintaining link aggregation.
Example
# Display detailed information about link aggregation for port GigabitEthernet 1/0/1 in a manual aggregation group.
<Sysname> display link-aggregation interface GigabitEthernet1/0/1
Flags:  A -- LACP_Activity, B -- LACP_timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
 GigabitEthernet1/0/1:
   Selected AggID: 3
   Local:
     Port-Priority: 32768, Oper key: 2, Flag: {}
   Remote:
     System ID: 0x0, 0000-0000-0000
     Port Number: 0, Port-Priority: 0 , Oper-key: 0, Flag: {}
# Display detailed information about link aggregation for port GigabitEthernet 1/0/2 in a static aggregation group.
<Sysname> display link-aggregation interface GigabitEthernet1/0/2
 GigabitEthernet1/0/2:
   Selected AggID: 0
   Local:
     Port-Priority:    0, Oper key: 3, Flag: {ACG}
   Remote:
     System ID: 0x8000, 0000-0000-0000
     Port Number: 0, Port-Priority: 32768 , Oper-key: 0, Flag: {EF}
   Received LACP Packets: 0 packet(s), Illegal: 0 packet(s)
   Sent LACP Packets: 0 packet(s)
Table 2-2 Description on the fields of the display link-aggregation interface command
Flags
One-octet LACP flags field indicates the actor state variables for the port. From the least to the most significant bit, they are represented by A through H as follows:
A –– Enabling/disabling of LACP, 1 for enabled and 0 for disabled
B –– Timeout control value, 1 for short timeout, and 0 for long timeout
C –– Whether the system considers this link to be aggregatable, 1 for true, and 0 for false
D –– Whether the system considers that this link is synchronized, 1 for true, and 0 for false
E –– Whether collection of incoming frames is enabled on the link, 1 for true and 0 for false
F –– Whether distribution of outgoing frames is enabled on the link, 1 for true and 0 for false
G –– Whether the receive state machine of the actor is using default operational partner information, 1 for true and 0 for false
H –– Whether the receive state machine of the actor is in the expired state, 1 for true and 0 for false
If a flag bit is set to 1, the corresponding English letter that otherwise is not output displays.
Selected AggID
Local:
Port-Priority, Oper key, Flag
Remote:
System ID, Port Number, Port-Priority, Oper-key, Flag
Received LACP Packets, Illegal, Sent LACP Packets
View
Parameter
None
Use the display link-aggregation summary command to display a summary for all link aggregation groups, which comprises Local system ID, Link aggregation group ID, Link aggregation type, Remote system ID, Number of selected ports, Number of unselected ports, Load sharing type and Master port number.
You may find that information about the remote system for a manual link aggregation group is either replaced by none or not displayed at all. This is normal because this type of aggregation group has no knowledge of its partner.
Example
# Display the link aggregation group summary.
<Sysname> display link-aggregation summary
Aggregation Group Type: S -- Static, M -- Manual
Loadsharing Type: Shar – Loadsharing, NonS – Non-Loadsharing
Actor ID: 0x8000, 0016-e0be-e200
  AL AL Partner ID           Select    Unselected  Share   Master
  ID Type                     Ports Ports   Type        Port
  1   M    none                  0      2        NonS  GigabitEthernet1/0/5
Table 2-3 Description on the fields of the display link-aggregation summary command
Actor ID
Local system ID
AL ID
AL Type
Link aggregation type: manual, static LACP
Partner ID
Remote system ID
Select Ports
Unselected Ports
Share Type
Load sharing type
Master Port
Master port number
display link-aggregation verbose [ agg-id ]
View
Parameter
agg-id: ID of an existing link aggregation group. For S5500-28C-SI and S5500-28C-PWR-SI, it is in the range of 1 to 32. For S5500-52C-SI and S5500-52C-PWR-SI, it is in the range of 1 to 56.
Use the display link-aggregation verbose command to display detailed information about the specified or all link aggregation groups.
l           Link aggregation group ID, Link aggregation type , Load sharing type
l           Link aggregation group name
l           Detailed information about the local end, including Local system ID, member ports, port state, port LACP priority, operational key
l           Detailed information about the remote end, including corresponding local port, port ID, port LACP priority, operational key, system ID
Example
# Display detailed information about link aggregation group 1. -
<Sysname> display link-aggregation verbose
Aggregation ID: 1,  AggregationType: Static,   Loadsharing Type: Shar
Aggregation Description:
System ID: 0x8000, 00e0-fc00-0001
Port Status: S -- Selected,  U -- Unselected
Local:
  Port             Status  Priority  Oper-Key  Flag
  GE0/0/1          S       32768     1         {ACDEFG}
  GE0/0/2          U       32768     1         {ACG}
  GE0/0/3          U       32768     2         {ACG}
Remote:
  Actor            Partner Priority  Oper-Key  SystemID               Flag
  GE0/0/1          0       32768     0         0x8000,0000-0000-0000  {DEF}
  GE0/0/2          0       32768     0         0x8000,0000-0000-0000  {DEF}
  GE0/0/3          0       32768     0         0x8000,0000-0000-0000  {EF}
Table 2-4 Description on the fields of the display link-aggregation verbose command
Loadsharing Type
Load sharing type, either shar for loadsharing or NonS for non-load sharing
Flags
C –– Whether the system considers that this link is synchronized, 1 for true, and 0 for false
Aggregation ID
AggregationType
System ID
Local system ID
Port Status
Port state in a link aggregation group: selected or unselected
Local:
Port, Status, Priority, Oper-key, Flag
Other information about the local end, including member ports, port state, port LACP priority, operational key, and flags
Remote:
Actor, Partner, Priority, Oper-key, SystemID, Flag
Detailed information about the remote end, including corresponding local port, port ID, port LACP priority, operational key, system ID, and flags
lacp port-priority port-priority
undo lacp port-priority
View
Parameter
port-priority: Port LACP priority, in the range 0 to 65,535.
Use the lacp port-priority command to assign an LACP priority to the port or ports in the port group.
Use the undo lacp port-priority command to restore the default.
By default, port LACP priority is 32,768.
Example
# Assign LACP priority 64 to a port.
[Sysname-GigabitEthernet1/0/1] lacp port-priority 64
lacp system-priority system-priority
undo lacp system-priority
View
Parameter
system-priority: System LACP priority, in the range 0 to 65,535.
Use the lacp system-priority command to assign an LACP priority to the local system.
Use the undo lacp system-priority command to restore the default.
By default, system LACP priority is 32768.
Example
# Assign LACP priority 64 to the local system.
[Sysname] lacp system-priority 64
link-aggregation group agg-id description agg-name
undo link-aggregation group agg-id description
View
Parameter
agg-name: Link aggregation group name, in the range 1 to 32 characters.
Use the link-aggregation group description command to configure a name for the specified link aggregation group.
Use the undo link-aggregation group description command to remove the name of the specified link aggregation group.
By default, the name of the specified link aggregation group is not configured.
Related command: display link-aggregation verbose.
Example
# Name link aggregation group 22 as abc.
[Sysname] link-aggregation group 22 description abc
link-aggregation group agg-id mode { manual | static }
View
Parameter
manual: Manual link aggregation mode.
static: Static LACP link aggregation mode.
Use the link-aggregation group mode command to create a manual or static LACP link aggregation group.
Use the undo link-aggregation group command to remove a link aggregation group.
Related command: display link-aggregation summary.
Example
# Create manual link aggregation group 22.
[Sysname] link-aggregation group 22 mode manual
port link-aggregation group agg-id
undo port link-aggregation group
View
Parameter
Use the port link-aggregation group command to assign the Ethernet port to the specified link aggregation group (manual or static LACP).
Use the undo port link-aggregation group command to remove the Ethernet port from the specified aggregation group
Example
# Assign port GigabitEthernet 1/0/1 to link aggregation group 22.
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 22
port-group aggregation agg-id
View
Parameter
Use the port-group aggregation command to enter aggregation port group view.
Instead of being created administratively, an aggregation port group is created automatically upon the creation of a link aggregation group and assigned the ID of the link aggregation group. In aggregation port group view, you can configure aggregation related settings such as STP, VLAN, QoS, GVRP, QinQ, BPDU tunnel, and multicast, but cannot add or remove member ports.
Example
# Enter aggregation port group view.
[Sysname] port-group aggregation 10
[Sysname-port-group-aggregation-10]
reset lacp statistics [ interface interface-type interface-number [ to interface-type interface-number ] ]
View
Parameter
Use the reset lacp statistics command to clear statistics about LACP on specified or all ports.
Related command: display link-aggregation interface.
Example
# Clear statistics about LACP on all ports.
<Sysname> reset lacp statistics
View
Parameter
None
Use the display port-isolate group command to display the information of the default  Isolation Group 1.
Example
# Display the information about the Ethernet ports added to the isolation group.
<Sysname> display port-isolate group
 Port-isolate group information:
 Uplink port support: NO
 Group ID: 1
Table 3-1 Description on the output information of the display port-isolate group command
Display information of a port-isolation group
Uplink port support
Whether support uplink port
Group ID
Isolation group number
All ports name of a isolation group
port-isolate enable
undo port-isolate enable
View
Parameter
None
Use the port isolate command to add an Ethernet port to the isolation group.
Use the undo port isolate command to remove an Ethernet port from the isolation group.
By default, an isolation group contains no port.
Note that this command adds a port to the default Isolation Group 1 on the device.
Example
# Add GigabitEthernet1/0/1 port to the isolation group.
[Sysname] interface GigabitEthernet1/0/1
[Sysname-GigabitEthernet1/0/1] port-isolate enable
