H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
20-QoS Command
20-QoS Command 227 KB
Table of Contents
Chapter 1 QoS Overview Commands. 1-1
1.1 QoS Overview Commands. 1-1
1.1.1 display qos lr interface. 1-1
1.1.2 qos lr 1-2
Chapter 2 QoS Policy Configuration Commands. 2-1
2.1 QoS Policy Configuration Commands. 2-1
2.1.1 accounting. 2-1
2.1.2 car 2-1
2.1.3 classifier behavior 2-3
2.1.4 display qos policy. 2-4
2.1.5 display qos policy interface. 2-5
2.1.6 display traffic behavior 2-6
2.1.7 display traffic classifier 2-7
2.1.8 filter 2-8
2.1.9 if-match. 2-9
2.1.10 qos apply policy. 2-12
2.1.11 qos policy. 2-12
2.1.12 redirect 2-13
2.1.13 remark dot1p. 2-14
2.1.14 remark dscp. 2-15
2.1.15 remark ip-precedence. 2-16
2.1.16 remark local-precedence. 2-17
2.1.17 traffic behavior 2-17
2.1.18 traffic classifier 2-18
Chapter 3 WRR Queue Configuration Commands. 3-1
3.1 WRR Queue Configuration Commands. 3-1
3.1.1 display qos sp. 3-1
3.1.2 display qos wrr interface. 3-1
3.1.3 qos sp. 3-2
3.1.4 qos wrr 3-3
Chapter 4 Priority Mapping Configuration Commands. 4-1
4.1 Priority Mapping Configuration Commands. 4-1
4.1.1 display qos map-table. 4-1
4.1.2 qos map-table. 4-2
4.1.3 qos priority. 4-2
Chapter 5 VLAN Policy Commands. 5-1
5.1 VLAN Policy Commands. 5-1
5.1.1 display qos vlan-policy. 5-1
5.1.2 qos vlan-policy. 5-3
5.1.3 reset qos vlan-policy. 5-4
Chapter 6 Traffic Mirroring Configuration Commands. 6-1
6.1 Traffic Mirroring Configuration Commands. 6-1
6.1.1 display qos policy user-defined. 6-1
6.1.2 display traffic behavior user-defined. 6-2
6.1.3 mirror-to interface. 6-3
View
Parameter
interface-type: Port type.
interface-number: Port number.
Use the display qos lr interface command to display the LR configuration and statistics information of a certain interface or all interfaces.
If the interface argument is not specified, this command will display the LR configuration and statistics information of all the interfaces.
Example
# Display the LR configuration and statistics information of all the interfaces.
<H3C> display qos lr interface
Direction: Outbound
 CIR 64000 (kbps),  CBS 4000000 (byte)
Table 1-1 Description on the fields of the display qos lr command
Port name, composed of port type and port number
Direction
Specify the direction of limited rate as outbound
CIR
Committed information rate, in kbps
CBS
Committed burst size, namely, the depth of the token bucket that holds the burst traffic, in byte
1.1.2  qos lr
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
View
Ethernet interface view/port group view
Parameter
outbound: Limits the rate of the outbound traffic.
cir committed-information-rate: Specifies the committed information rate in kbps. The committed-information-rate argument ranges from 64 to 1,000,000 and must be a multiple of 64.
cbs committed-burst-size: Specifies the committed burst size in bytes.
l           The committed-burst-size argument ranges from 4,000 to 16,000,000.
l           If the cbs keyword is not used, the system uses the default committed burst size, that is, 500 ms x committed-information-rate, or 16,000,000 if the multiplication is more than 16,000.000.
Use the qos lr command to limit the rate of outbound traffic via physical interfaces.
Use the undo qos lr command to cancel the limit.
Example
# Limit the rate of the physical port GigabitEthernet1/0/1 to send packets. CIR is 64 kbps and CBS is 9,216 bytes.
<H3C> system-view
[H3C] interface GigabitEthernet 1/0/1
[H3C-GigabitEthernet1/0/1] qos lr outbound cir 64 cbs 9216
2.1.1  accounting
accounting
undo accounting
View
Traffic behavior view
Parameter
None
Use the accounting command to configure the accounting action for the traffic behavior.
Use the undo accounting command to remove the accounting configuration.
Related command: qos policy, traffic behavior, and classifier behavior.
Example
# Configure the accounting action for the traffic behavior.
<H3C> system-view
[H3C] traffic behavior database
[H3C-behavior-database] accounting
2.1.2  car
car cir committed-information-rate [ cbs committed-burst-size ] [ red action ]
undo car
View
Parameter
cir committed-information-rate: Specifies the committed information rate in kbps. The committed-information-rate argument ranges from 64 to 32,000,000 and must be a multiple of 64.
l           The committed burst size argument ranges from 500 to 2,000,000.
l           If the cbs keyword is not used, the system uses the default committed burst size, that is, 500 ms x committed-information-rate, or 2,000,000 if the multiplication is more than 2,000,000.
red: The action to be taken when the traffic does not conform to cir. The default value is discard.
action: Specifies the following actions.
l           discard: Discards data packets.
l           pass: Sends data packets.
l           remark-dscp-pass new-dscp: Sets a new DSCP value and sends a data packet to the destination address, ranging from 0 to 63. Or input one of the keywords listed in Table 2-1 as the DSCP.
Table 2-1 DSCP values and the corresponding keywords
Keyword
DSCP value in decimal
DSCP value in binary
default
0
000000
af11
10
001010
af12
12
001100
af13
14
001110
af21
18
010010
af22
20
010100
af23
22
010110
af31
26
011010
af32
28
011100
af33
30
011110
af41
34
100010
af42
36
100100
af43
38
100110
cs1
8
001000
cs2
16
010000
cs3
24
011000
cs4
32
100000
cs5
40
101000
cs6
48
110000
cs7
56
111000
ef
46
101110
Use the car command to configure TP for the traffic behavior.
Use the undo car command to remove the TP configuration.
When the car command is used in the policies applied on the port, the policies can be applied in the inbound direction of the port.
If this command is used repeatedly to configure TP for the same traffic behavior, the last configuration is effective.
Example
# Configure TP for a traffic behavior. The normal traffic rate of packets is 6400 kbps.
<H3C> system-view
[H3C-behavior-database] car cir 6400
classifier tcl-name behavior behavior-name
undo classifier tcl-name
View
Policy View
Parameter
tcl-name: Defined class name, a string of 1 to 31 characters.
behavior-name: Defined behavior name, a string of 1 to 31 characters.
Use the classifier behavior command to specify the behavior for a class in the policy.
Use the undo classifier behavior command to cancel the usage of the specified class in the policy.
Each class in the policy can be associated with only one action.
Related command: qos policy.
Example
# Use the behavior “test” for the class “database” in the policy user1.
<H3C> system-view
[H3C] qos policy user1
[H3C-qospolicy-user1] classifier database behavior test
display qos policy user-defined [ policy-name [ classifier tcl-name ] ]
View
Parameter
user-defined: User-defined policies.
policy-name: Policy name, a string of 1 to 31 characters. If no policy name is specified, this command displays the configuration information of all user-defined policies.
tcl-name: Class name in the policy, a string of 1 to 31 characters.
Use the display qos policy command to display the configuration information of the specified class or all classes in the specified policy or all policies and the configuration information of behavior(s) associated with the class(es).
Example
# Display the configuration information of all classes in all user-defined policies and the configuration information of the behaviors associated with the classes.
<H3C> display qos policy user-defined
  User Defined QoS Policy Information:
  Policy: test
   Classifier: USER1
     Behavior: USER1
      Marking:
        Remark IP Precedence 3
      Committed Access Rate:
        CIR 6400 (kbps), CBS 400000 (byte)
        Red Action: discard
   Classifier: database
     Behavior: database
      Marking:
        Remark IP Precedence 5
Table 2-2 Description on the fields of the display qos policy command
Policy
Policy name
Classifier
Class name. A policy can contain multiple classes and each class has a corresponding behavior and one or more match rule. Refer to the traffic classifier command for details.
Behavior
The behavior corresponding to a class in the policy. A behavior can have multiple rules. Refer to the traffic behavior command for details.
display qos policy interface [ interface-type interface-number ] [ inbound ]
View
Parameter
inbound: Inbound direction.
Use the display qos policy interface command to display the configuration and running status of the policy on the specified ports or all ports.
Example
# Display the configuration and running status of the policy on GigabitEthernet 1/0/1.
<H3C> display qos policy interface GigabitEthernet 1/0/1
  Direction: Inbound
  Policy: test
   Classifier: USER1
     Operator: AND
     Rule(s) : if-match ip-precedence 5
     Behavior: USER1
      Marking:
        CIR 640 (kbps), CBS 40000 (byte)
        Red Action: discard
     Operator: AND
     Rule(s) : if-match acl 3131
     Behavior: database
      Marking:
Table 2-3 Description on the fields of the display qos policy interface command
Direction
The application direction of the policy on the port
Policy
The name of the policy  applied on the port
Classifier
The classification rule in the policy and the corresponding configuration information
Operator
The logic relationship among different classification rules in a class
Rule(s)
Classification rule(s) of the class
Behavior
The name and configuration information of the behavior in the policy. Refer to the commands related with behavior for details
display traffic behavior user-defined [ behavior-name ]
View
Parameter
user-defined: User-defined behaviors.
behavior-name: Behavior name, a string of 1 to 31 characters. If no behavior name is specified, the command displays the information about all user-defined behaviors.
Use the display traffic behavior command to display the configured traffic behavior information.
If no behavior name is specified, this command displays the information about all behaviors.
Example
# Display the information about user-defined traffic behaviors .
<H3C> display traffic behavior user-defined
  User Defined Behavior Information:
    Behavior: test
      Marking:
        Remark IP precedence 3
        Red Action: discard
Table 2-4 Description on the fields of the display traffic behavior user-defined command
Type of behavior: user-defined
Behavior
The name and content of the behavior. The content can involve multiple types
Marking
Remarking configuration
Traffic limiting configuration
display traffic classifier user-defined [ tcl-name ]
View
Parameter
user-defined: User-defined class.
tcl-name: Class name, a string of 1 to 31 characters.
Use the display traffic classifier command to display the configured class information.
If no class name is specified, this command displays the information about all classes.
Example
# Display the user-defined class information.
<H3C> display traffic classifier user-defined
User Defined Classifier Information:
 Classifier: USER1
  Operator: OR
 Operator: OR
Table 2-5 Description on the fields of the display traffic classifier user-defined command
Type of class: user-defined
Classifier
The name and content of the class. The content can involve multiple types.
Operator
The logic relationship among the classification rules
Rule
2.1.8  filter
filter { deny | permit }
undo filter
View
Parameter
discard: Drops packets.
permit: Sends packets.
Use the filter command to configure the traffic filter action for the traffic behavior.
Use the undo filter command to remove the configuration.
  Caution:
Except for the accounting command, the filter deny command cannot be used together with any other commands that are used to configure actions for traffic behavior.
Example
# Configure the filter action of dropping packets for the traffic behavior.
<H3C> system-view
[H3C-behavior-database] filter deny
2.1.9  if-match
if-match match-criteria
undo if-match match-criteria
View
Class view
Parameter
match-criteria: Match rule of the class. Refer to Table 2-6 for the value range.
Table 2-6 The match rule values of the class
Value
acl access-list-number
Defines a rule that matches an ACL. The value range of access-list-number is from 2000 to 4999
acl ipv6 access-list-number
Defines an IPv6 ACL rule. The value of the access-list-number argument is in the range of 2,000 to 3,999.
IPv6 ACL rules can only be implemented by referencing ACL6 rules.
any
Defines a rule to match all packets
dot1p dot1p-list
Defines a rule that matches 802.1p priority. The value of 802.1p priority is in the range of 0 to 7
dscp dscp-list
Defines a rule that matches DSCP. dscp-list is the list of DSCP values, The DSCP values range from 0 to 63
destination-mac mac-address
Defines a rule that matches the destination MAC address
ip-precedence ip-precedence-list
Defines a rule that matches IP precedence. ip-precedence-list is the list of IP precedence values, The IP precedence values range from 0 to 7
source-mac mac-address
Defines a rule that matches the source MAC address
customer-vlan-id vlan-id-list
Defines a rule that matches VLAN IDs of the user network. vlan-id-list is the list of VLAN IDs , The VLAN IDs range from 1 to 4094
service-vlan-id vlan-id-list
Defines a rule that matches VLAN IDs of the operator network. vlan-id-list is the list of VLAN IDs, The VLAN IDs range from 1 to 4094
Use the if-match command to define a rule for all the packets matching the specified rule.
Use the undo if-match command to delete the rule for all packets matching the specified match rule.
&  Note:
Please obey the following restrictions when defining a rule; otherwise you will fail to apply the policies.
l      If the customer-vlan-id, dot1p, dscp, ip-precedence or service-vlan-id is to be matched, do not configure multiple values in a rule at the same time when you use the if-match command to define match rules.
l      Do not configure multiple values in a rule at the same time when you use the if-match command to define match rules.
l      When you specify the logic relation as AND, if you configure the ACL IPv6 matching rule, you cannot configure other rules except if-match any at the same time.
Related command: traffic classifier.
Example
# Define the match rule of class1 to match packets whose destination MAC address is 0050-ba27-bed3.
<H3C> system-view
[H3C] traffic classifier class1
[H3C-classifier-class1] if-match destination-mac 0050-ba27-bed3
# Define the match rule of class2 to match packets whose source MAC address is 0050-ba27-bed2.
<H3C> system-view
[H3C] traffic classifier class2
[H3C-classifier-class2] if-match source-mac 0050-ba27-bed2
# Define the match rule of class1 to match ACL 3101.
<H3C> system-view
[H3C-classifier-class1] if-match acl 3101
# Define a rule that matches all packets.
<H3C> system-view
[H3C-classifier-class1] if-match any
# Define the match rule of class1 to match packets whose DSCP value is 1.
<H3C> system-view
[H3C-classifier-class1] if-match dscp 1
# Define the match rule of class1 to match packets whose IP precedence value is 1.
<H3C> system-view
[H3C-classifier-class1] if-match ip-precedence 1
# Define the match rule of class1 to match packets whose VLAN ID of the user network is 1.
<H3C> system-view
[H3C-classifier-class1] if-match customer-vlan-id 1
# Define the match rule of class1 to match packets whose VLAN ID of the operator network is 1.
<H3C> system-view
[H3C-classifier-class1] if-match service-vlan-id 1
undo qos apply policy inbound
View
Parameter
policy policy-name: Specifies the policy name, a string of 1 to 31 characters.
Use the qos apply policy command to apply the associated policy on the port.
Use the undo apply policy command to delete the associated policy.
Example
# Apply the policy named USER1 to the inbound direction of GigabitEthernet1/0/1.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] qos apply policy USER1 inbound
2.1.11  qos policy
qos policy policy-name
undo qos policy policy-name
View
Parameter
policy policy-name: Policy name, a string of 1 to 31 characters.
Use the qos policy command to define a policy and enter policy view.
Use the undo qos policy command to delete a policy.
If the policy is applied on a certain port, it is not allowed to delete the policy. To delete it, you must first cancel the application of the policy on this port and then use the undo qos policy command to delete the policy.
Related command: classifier behavior, and qos apply policy.
Example
# Define a policy named USER1.
<H3C> system-view
2.1.12  redirect
redirect interface interface-type interface-number
undo redirect
View
Parameter
Use the redirect command to configure the traffic redirect action for the traffic behavior.
Use the undo redirect command to remove the configuration.
Example
# Define the traffic redirect action for the traffic behavior to redirect the traffic to GigabitEthernet1/0/1.
<H3C> system-view
[H3C-behavior-database] redirect interface GigabitEthernet 1/0/1
2.1.13  remark dot1p
remark dot1p 8021p
undo remark dot1p
View
Parameter
8021p: Specifies a 802.1p priority , ranging from 0 to 7.
Use the remark dot1p command to configure the 802.1p priority of a packet.
Use the undo remark dot1p command to cancel the 802.1p priority of the packet.
  Caution:
remark dot1p and remark local-precedence cannot be configured at the same time.
Example
# Configure the 802.1p priority of the packet as 2.
<H3C> system-view
[H3C-behavior-database] remark dot1p 2
2.1.14  remark dscp
remark dscp dscp-value
undo remark dscp
View
Parameter
dscp-value: Specifies a DSCP value, ranging from 0 to 63. It also can be a key word, as shown in the following table.
Table 2-7 Relationship between DSCP keywords and values
Key word
DSCP value (binary)
DSCP value (decimal)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
Use the remark dscp command to configure the DSCP value of a packet.
Use the undo remark dscp command to remove the DSCP value of the packet.
Example
# Configure the DSCP value of the packet as 6.
<H3C> system-view
[H3C-behavior-database] remark dscp 6
remark ip-precedence ip-precedence-value
undo remark ip-precedence
View
Parameter
ip-precedence-value: specifies an IP priority , ranging from 0 to 7.
Use the remark ip-precedence command to configure the IP priority of a packet.
Use the undo remark ip-precedence command to remove the IP priority of the packet.
Example
# Configure the IP priority of the packet as 6.
<H3C> system-view
[H3C-behavior-database] remark ip-precedence 6
remark local-precedence local-precedence
undo remark local-precedence
View
Parameter
local-precedence: Marked local precedence, in the range of 0 to 7.
Use the remark local-precedence command to configure the local precedence of a packet.
Use the undo remark local-precedence command to remove the local precedence of the packet.
  Caution:
Example
# Define the action of marking the local precedence of the packet to 2.
<H3C> system-view
[H3C-behavior-database] remark local-precedence 2
View
Parameter
behavior-name: Traffic behavior name, a string of 1 to 31 characters.
Use the traffic behavior command to define a traffic behavior and enter traffic behavior view.
Use the undo traffic behavior command to delete a traffic behavior.
Related command: qos policy, qos apply policy, and classifier behavior.
Example
# Define a traffic behavior named behavior1.
<H3C> system-view
[H3C] traffic behavior behavior1
[H3C-behavior-behavior1]
traffic classifier tcl-name [ operator { and | or }  ]
undo traffic classifier tcl-name [ operator  { and | or } ]
View
Parameter
and: Specifies the logic relationship among rules in a class as “and”, that is, a packet belongs to this class only when the packet match all the rules.
or: Specifies the logic relationship among rules in a class as “or”, that is, a packet belongs to this class as long as it matches any of the rules.
Use the traffic classifier command to define a class and enter class view.
Use the undo traffic classifier command to delete a class.
By default, the operator is and.
Example
# Define a class named class1.
<H3C> system-view
display qos sp interface [ interface-type interface-number ]
View
Parameter
Use the display qos sp interface command to display the strict priority (SP) queuing configuration on a specified port.
If no port is specified, this command displays the SP queuing configuration on all ports.
Related command: qos sp.
Example
# Display the SP queuing configuration on GigabitEthernet 1/0/1.
<H3C> display qos sp interface GigabitEthernet 1/0/1
Output queue: Strict-priority queue
display qos wrr interface [ interface-type interface-number ]
View
Parameter
Use the display qos wrr interface command to display the configuration of weighted round robin (WRR) queues of a port.
If no port number is specified, the command displays the configurations of WRR queues of all ports.
Related command: qos wrr.
Example
# Display the configuration of WRR queues of GigabitEthernet 1/0/1.
<H3C> display qos wrr interface GigabitEthernet 1/0/1
Output queue:   Weighted round robin queue
Queue ID    Group    Weight
   0         sp       N/A
   1         1        100
   2         1        100
   3         1        75
   4         1        100
   5         1        100
   6         1        100
   7         1        100
Table 3-1 Description on the fields of the display qos wrr interface command
Output queue
The type of the current output queue
Queue ID
ID of the queue
Group
Group ID, indicating which group a queue belongs to. The group ID is 1 by default.
Weight
The weight of each queue during scheduling
3.1.3  qos sp
qos sp
undo qos sp
View
Parameter
None
Use the qos sp command to configure SP queuing on the current port.
Use the undo qos sp command to restore the default queuing algorithm on the port.
By default, the switch adopts the WRR queue-scheduling algorithm.
Related command: display qos sp interface.
Example
# Configure SP queuing on GigabitEthernet 1/0/1.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] qos sp
3.1.4  qos wrr
qos wrr queue-id group { sp | group-id weight queue-weight }
undo qos wrr
View
Parameter
queue-id: ID of the queue, in the range of 0 to 7.
group-id: It can only be 1.
weight schedule-value: Specifies the scheduling weight of a queue, rang from 1 to 15.
group sp: Configures SP queuing.
Use the qos wrr weight command to configure the WRR queue or modify the parameters of the WRR queue on the port.
Use the undo qos wrr command to restore the default queue-scheduling algorithm on the port.
As required, you can configure part of the queues on the port to adopt the SP queue-scheduling algorithm and parts of queues to adopt the WRR queue-scheduling algorithm. Through adding the queues on a port to the SP scheduling group and WRR scheduling group (namely, group 1), the SP+WRR queue scheduling is implemented. During the queue scheduling process, the queues in the SP scheduling group is scheduled preferentially. When no packet is to be sent in the queues in the SP scheduling group, the queues in the WRR scheduling group are scheduled. The queues in the SP scheduling group are scheduled according to the strict priority of each queue, while the queues in the WRR queue scheduling group are scheduled according the weight value of each queue.
Related command: display qos wrr interface.
Example
# Apply the SP+WRR queuing on GigabitEthernet 1/0/1 and set queue 0 to sp and queue 1 to WRR with a weight of 10.
<H3C> system-view
[H3C-GigabitEthernet1/0/1]qos wrr 0 group sp
[H3C-GigabitEthernet1/0/1]qos wrr 1 group 1 weight 10
display qos map-table [ dot1p-lp ]
View
Parameter
dot1p-lp: “802.1p priority->Local precedence” mapping table.
Use the display qos map-table command to display the configuration of the specified priority mapping table.
Related command: qos map-table.
Example
# Display the configurations of the “802.1p priority->Local precedence” mapping table.
<H3C> display qos map-table dot1p-lp
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 4-1 Description on the fields of the display qos map-table command
MAP-TABLE NAME
The name of the mapping table
TYPE
The type of the mapping table
IMPORT
The import entries of the mapping table
EXPORT
The export entries of the mapping table
4.1.2  qos map-table
View
Parameter
Use the qos map-table command to enter the specified priority mapping view.
Related command: display qos map-table.
&  Note:
The S5500-SI Series Ethernet Switches support only the packet priority trust mode and do not support the edit of dot1p-lp (802.1p priority to local priority) mapping table.
Example
# Enter the “802.1p priority->Local precedence” mapping table view.
<H3C> system-view
[H3C] qos map-table dot1p-lp
[H3C-maptbl-dot1p-lp]
4.1.3  qos priority
qos priority priority-value
undo qos priority
View
Parameter
priority-value: Value of port priority.
Use the qos priority command to configure the port priority of the current port.
Use the undo qos priority command to restore the port priority to the default value.
The value of the port priority is 0 by default.
&  Note:
The port priority setting only takes effect on untagged packets; it does not take effect on tagged packets.
Example
# Set the port priority of GigabitEthernet1/0/1 to 2.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] qos priority 2
display qos vlan-policy { name policy-name | vlan [ vlan-id ] }
View
Parameter
name policy-name: Displays by the policy name. policy-name: a string of 1 to 31 characters.
vlan [ vlan-id ]: Displays by the VLAN ID.
Use the display qos vlan-policy command to display information about QoS policies applied on VLAN(s).
Example
# Display information about the VLAN policy applied on VLANs.
<H3C> display qos vlan-policy vlan
  Vlan 1
    Policy test5: inbound (active)
  Vlan 60
Table 5-1 Description on the fields of the display qos vlan-policy command
Vlan 1
VLAN ID
Name of the QoS policy, which is an inbound policy in active state now
# Display information about the QoS policy "test" applied on VLANs.
<H3C> display qos vlan-policy name test
  Policy test
    Vlan 300: inbound (active)
Table 5-2 Description on the fields of the display qos vlan-policy name command
Policy
It is followed by a QoS policy name.
Vlan 300
VLAN ID the QoS is applied to
inbound (active)
inbound: indicates the QoS policy is applied to inbound packets of the VLAN.
active: indicates the QoS policy takes effect.
# Display QoS policy information on VLAN 2.
<H3C> display qos vlan-policy vlan 2
  Vlan 2
  Direction: Inbound (active)
  Policy: vlan
   Classifier: vlan
     Operator: AND
     Rule(s) : If-match acl 2000
     Behavior: vlan
      Accounting Enable:
        0 (Packets)
        Red Action: discard
Table 5-3 Description on the fields of the display qos vlan-policy vlan command
Vlan 2
VLAN ID that you specified
Inbound (active)
Inbound: Indicates the following QoS policy is applied to inbound packets.
active: Indicates the QoS policy takes effect.
Classifier
It is followed by the name and contents of a class
Operator
Logical relationship between classification rules
Rule(s)
Behavior
Name and contents of the traffic behavior
Accounting
Accounting for traffic behavior
Information about traffic limiting
CIR
Committed information rate, in kbps.
CBS
committed burst size (in bytes), that is, the size of the token bullet accommodating burst traffic
Red Action: discard
The discard action is taken when the traffic rate exceeds CIR.
qos vlan-policy policy-name vlan vlan-id-list inbound
undo qos vlan-policy vlan vlan-id-list inbound
View
Parameter
vlan-id-list: VLAN ID list in the form of vlan-id to vlan-id. You can enter multiple discontinuous VLAN IDs. The device allows you to specify up to eight VLAN IDs at the same time.
inbound: Apply QoS policies to inbound packets of a VLAN.
Use the qos vlan-policy command to apply a QoS policy to specified VLANs.
Use the undo qos vlan-policy command to cancel the QoS policy application on specified VLANs.
QoS polices support the following application modes:
l           Port-based application: QoS policies are effective for inbound packets of a port
l           VLAN-based application: QoS policies are effective for inbound traffic of a VLAN
VLAN-based QoS policies are also known as VLAN policies for short.
Example
# Apply the VLAN policy named test to the inbound direction of VLAN 200, VLAN 300, VLAN 400, VLAN 500, VLAN 600, VLAN 700, VLAN 800 and VLAN 900.
<H3C> system-view
[H3C] qos vlan-policy test vlan 200 300 400 500 600 700 800 900 inbound
reset qos vlan-policy [ vlan vlan-id ]
View
Parameter
vlan-id: VLAN ID, ranging from 1 to 4094.
Use the reset qos vlan-policy command to clear QoS policy statistics on VLAN(s).
If the argument of vlan vlan-id is not specified, this command will clear all QoS policy statistics.
Example
# Clear QoS policy statistics on VLAN 2.
<H3C> reset qos vlan-policy vlan 2
View
Parameter
policy-name: QoS Policy name.
tcl-name: Name of a traffic classification rule in the policy.
Use the display qos policy user-defined command to display the configuration information of one or all user-defined QoS policies.
Example
# Display the configuration information of a user-defined QoS policy.
 Policy: 1
  Classifier: 1
     Behavior: 1
     Mirror enable:
       Mirror type: interface
       Mirror destination: GigabitEthernet1/0/1
Table 6-1 Description on the fields of the display qos policy user-defined command
Policy
QoS policy name
Classifier
Traffic classification rule name
Behavior
Mirror enable
Traffic mirroring is enabled
Mirror type
Traffic mirroring type
Mirror destination
Mirroring port
View
Parameter
behavior-name: Traffic behavior name.
Use the display traffic behavior user-defined command to display the configuration information of one or all user-defined traffic behaviors.
Example
# Display the configuration information of all user-defined traffic behavior.
    Behavior: 1
      Mirror enable:
Table 6-2 Description on the fields of the display traffic behavior user-defined command
Behavior
Mirror enable
Mirror type
Mirror destination
Mirroring port
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
View
Parameter
interface-type interface-number: Type and number of the mirroring port you want to specify.
Use the mirror-to interface command to configure the action of mirroring traffic to a specified port.
Use the undo mirror-to interface command to cancel the action of mirroring traffic to a specified port.
&  Note:
l      Port mirroring cannot be performed on the packets passing through traffic mirroring. That is, if you set the traffic mirroring port to a mirrored port of a port mirroring group, the packets passing through traffic mirroring will not reach the mirroring port of the group.
l      When you configure a port (an inbound port, or a VLAN port for VLAN policy) to be both the mirrored port of traffic mirroring and the mirrored port of a port mirroring group, traffic mirroring will take precedence over port mirroring on the port. That is, the packets that match traffic rules will be mirrored to the traffic mirroring port, and the remaining packets that do not match traffic rules will be mirrored to the mirroring port of the port mirroring group.
Example
# Enter the view of traffic behavior 1 and configure the action of mirroring traffic to GigabitEthernet 1/0/1.
<H3C> system-view
[H3C] traffic behavior 1
[H3C-behavior-1] mirror-to interface GigabitEthernet 1/0/1
