H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
16-Multicast Protocol Command
16-Multicast Protocol Command 311 KB
Table of Contents
Chapter 1 IGMP Snooping Configuration Commands. 1-1
1.1 IGMP Snooping Configuration Commands. 1-1
1.1.1 display igmp-snooping group. 1-1
1.1.2 display igmp-snooping statistics. 1-2
1.1.3 fast-leave. 1-3
1.1.4 group-policy. 1-4
1.1.5 host-aging-time. 1-5
1.1.6 igmp-snooping. 1-6
1.1.7 igmp-snooping drop-unknown. 1-7
1.1.8 igmp-snooping enable. 1-7
1.1.9 igmp-snooping fast-leave. 1-8
1.1.10 igmp-snooping general-query source-ip. 1-9
1.1.11 igmp-snooping group-limit 1-10
1.1.12 igmp-snooping group-policy. 1-11
1.1.13 igmp-snooping host-aging-time. 1-12
1.1.14 igmp-snooping host-join. 1-13
1.1.15 igmp-snooping last-member-query-interval 1-14
1.1.16 igmp-snooping max-response-time. 1-15
1.1.17 igmp-snooping overflow-replace. 1-16
1.1.18 igmp-snooping querier 1-17
1.1.19 igmp-snooping query-interval 1-17
1.1.20 igmp-snooping router-aging-time. 1-18
1.1.21 igmp-snooping source-deny. 1-19
1.1.22 igmp-snooping special-query source-ip. 1-19
1.1.23 igmp-snooping static-group. 1-20
1.1.24 igmp-snooping static-router-port 1-22
1.1.25 igmp-snooping version. 1-23
1.1.26 last-member-query-interval 1-23
1.1.27 max-response-time. 1-24
1.1.28 overflow-replace. 1-25
1.1.29 reset igmp-snooping group. 1-26
1.1.30 reset igmp-snooping statistics. 1-26
1.1.31 router-aging-time. 1-27
1.1.32 source-deny. 1-27
Chapter 2 MLD Snooping Configuration Commands. 2-1
2.1 MLD Snooping Configuration Commands. 2-1
2.1.1 display mld-snooping group. 2-1
2.1.2 display mld-snooping statistics. 2-2
2.1.3 fast-leave. 2-3
2.1.4 group-policy. 2-4
2.1.5 host-aging-time. 2-5
2.1.6 last-member-query-interval 2-6
2.1.7 max-response-time. 2-7
2.1.8 mld-snooping. 2-7
2.1.9 mld-snooping drop-unknown. 2-8
2.1.10 mld-snooping enable. 2-9
2.1.11 mld-snooping fast-leave. 2-9
2.1.12 mld-snooping general-query source-ip. 2-10
2.1.13 mld-snooping group-limit 2-11
2.1.14 mld-snooping group-policy. 2-12
2.1.15 mld-snooping host-aging-time. 2-13
2.1.16 mld-snooping host-join. 2-14
2.1.17 mld-snooping last-member-query-interval 2-15
2.1.18 mld-snooping max-response-time. 2-16
2.1.19 mld-snooping overflow-replace. 2-17
2.1.20 mld-snooping querier 2-18
2.1.21 mld-snooping query-interval 2-18
2.1.22 mld-snooping report-aggregation. 2-19
2.1.23 mld-snooping router-aging-time. 2-20
2.1.24 mld-snooping source-deny. 2-20
2.1.25 mld-snooping special-query source-ip. 2-21
2.1.26 mld-snooping static-group. 2-22
2.1.27 mld-snooping static-router-port 2-23
2.1.28 overflow-replace. 2-24
2.1.29 reset mld-snooping group. 2-25
2.1.30 reset mld-snooping statistics. 2-26
2.1.31 router-aging-time. 2-26
2.1.32 source-deny. 2-27
Chapter 3 Multicast VLAN Configuration Commands. 3-1
3.1 Multicast VLAN Configuration Commands. 3-1
3.1.1 display multicast-vlan. 3-1
3.1.2 multicast-vlan enable. 3-1
3.1.3 multicast-vlan subvlan. 3-2
display igmp-snooping group [ vlan vlan-id ] [ verbose ]
View
Parameter
vlan vlan-id: Displays the multicast group information in the specified VLAN, where vlan-id is in the range of 1 to 4094. If you do not specify a VLAN, this command will display the multicast group information in all VLANs.
verbose: Specifies to display the detailed information of multicast groups.
Use the display igmp-snooping group command to view the multicast group information learned by IGMP Snooping.
Example
# View the detailed information of multicast groups in VLAN 2 learned by IGMP Snooping.
<H3C> display igmp-snooping group vlan 2 verbose
    Total 1 IP Group(s).
    Total 1 IP Source(s).
    Total 1 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, A-Aggregation port, C-Copy port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):2.
    Router port(s):total 1 port.
            GigabitEthernet1/0/2                                    (D) ( 00:01:30 )
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:224.1.1.1
        (1.1.1.1, 224.1.1.1):
          Attribute:    Host Port
          Host port(s):total 1 port.
            GigabitEthernet1/0/1                                    (D) ( 00:03:23 )
    MAC group(s):
      MAC group address:0100-5e01-0101
Table 1-1 Description of the fields of the display igmp-snooping group command
Total number of IP multicast groups
Total number of multicast sources
Total number of MAC multicast groups
Port flags: D for dynamic port, S for static port, A for aggregation port, C for port copied from a (*, G) entry to an (S, G) entry
Sub-VLAN flags: R for real egress sub-VLAN under the current entry, C for sub-VLAN copied from a (*, G) entry to an (S, G) entry
Router port(s)
Number of router ports
IP group address
Address of IP multicast group
MAC group address
Address of MAC multicast group
Attribute
Attribute of IP multicast group
Host port(s)
Number of host member ports
View
Parameter
None
Use the display igmp-snooping statistics command to view the statistics information of IGMP messages learned by IGMP Snooping.
Example
# View the statistics information of IGMP messages learned by IGMP Snooping. .
<H3C> display igmp-snooping statistics
  Received IGMP general  query packet(s) number:0.
  Received IGMP V1 report packet(s) number:0.
  Received IGMP V2 report packet(s) number:19.
  Received IGMP leave  packet(s) number:0.
  Received IGMP V2 specific query packet(s) number:0.
  Sent     IGMP V2 specific query packet(s) number:0.
  Received IGMP V3 report packet(s) number:1.
  Received IGMP V3 specific query packet(s) number:0.
  Received IGMP V3 specific sg query packet(s) number:0.
  Sent     IGMP V3 specific query packet(s) number:0.
  Sent     IGMP V3 specific sg query packet(s) number:0.
  Received error IGMP packet(s) number:19.
Table 1-2 Description of the fields of the display igmp-snooping statistics command
General query message(s)
Group-specific query message(s)
report packet(s)
Report message(s)
leave packet(s)
Leave message(s)
Group- and source-specific query message(s)
1.1.3  fast-leave
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
View
IGMP Snooping view
Parameter
vlan vlan-list: Configures the fast leave feature in the specified VLAN. Here vlan-list is a VLAN list. You can specify multiple VLANs or VLAN ranges by providing this argument in the form of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is in the range of 1 to 4094, and &<1-10> means that you can specify up to 10 VLANs or VLAN ranges for this argument.
Use the fast-leave command to enable the fast leave feature globally.
Use the undo fast-leave command to disable the fast leave feature globally.
By default, the fast leave feature is disabled.
Note that:
l           This command works on an IGMP Snooping–enabled VLAN or on a VLAN with IGMP enabled on its VLAN interface.
l           If you do not specify any VLAN, the command will take effect for all VLANs; if you specify a VLAN or multiple VLANs, the command will take effect for the specified VLAN(s) only.
Related command: igmp-snooping fast-leave.
Example
# Enable the fast leave feature globally in VLAN 2.
<H3C> system-view
[H3C] igmp-snooping
[H3C-igmp-snooping] fast-leave vlan 2
1.1.4  group-policy
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
View
IGMP Snooping view
Parameter
acl-number: Basic ACL number, in the range of 2000 to 2999.
vlan vlan-list: Configures a multicast group filter in the specified VLAN(s). Here vlan-list is a VLAN list. You can specify multiple VLANs or VLAN ranges by providing this argument in the form of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is in the range of 1 to 4094, and &<1-10> means that you can specify up to 10 VLANs or VLAN ranges for this argument.
Use the group-policy command to configure a global multicast group filter.
Use the undo group-policy command to remove the configured global multicast group filter.
By default, no global multicast group filter is configured, namely a host can join any multicast group.
Note that:
l           If the specified ACL rule does not exist or the ACL rule is null, all multicast groups will be filtered out.
l           You can configure different ACL rules for a port in different VLANs, and the newly configured ACL rules will override the existing ones.
Related command: igmp-snooping group-policy.
Example
# Configure ACL 2000 as the multicast group filter in VLAN 2.
<H3C> system-view
[H3C] igmp-snooping
[H3C-igmp-snooping] group-policy 2000 vlan 2
host-aging-time interval
undo host-aging-time
View
IGMP Snooping view
Parameter
interval: Member port aging time, in units of seconds. The effective range is 200 to 1,000.
Use the host-aging-time command to configure the aging time of group member ports
globally..
Use the undo host-aging-time command to restore the default setting.
By default, the aging time of group member ports is 260 seconds.
This command works only on an IGMP Snooping–enabled VLAN, but not on a VLAN with IGMP enabled on its VLAN interface.
Related command: igmp-snooping host-aging-time.
Example
# Set the aging time of group member ports globally to 300 seconds.
<H3C> system-view
[H3C] igmp-snooping
[H3C-igmp-snooping] host-aging-time 300
1.1.6  igmp-snooping
igmp-snooping
undo igmp-snooping
View
Parameter
None
Use the igmp-snooping command to enable IGMP Snooping globally and enter IGMP Snooping view.
Use the undo igmp-snooping command to disable IGMP Snooping globally.
By default, IGMP Snooping is disabled.
Related command: igmp-snooping enable.
Example
Enable IGMP Snooping globally and enter IGMP Snooping view
<H3C> system-view
[H3C] igmp-snooping
[H3C-igmp-snooping]
undo igmp-snooping drop-unknown
View
VLAN view
Parameter
None
Use the igmp-snooping drop-unknown command to enable the function of silently dropping unknown multicast data in the current VLAN.
Use the undo igmp-snooping drop-unknown command to disable the function of silently dropping unknown multicast data in the current VLAN.
By default, this function is disabled, that is, unknown multicast data is flooded.
This command takes effect only if IGMP Snooping is enabled in the VLAN.
Related command: drop-unknown.
Example
# In VLAN 2, enable the function of silently dropping unknown multicast data.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] igmp-snooping drop-unknown
undo igmp-snooping enable
View
VLAN view
Parameter
None
Use the igmp-snooping enable command to enable IGMP Snooping in the current VLAN.
Use the undo igmp-snooping enable command to disable IGMP Snooping in the current VLAN.
By default, IGMP Snooping is disabled in a VLAN.
IGMP Snooping must be enabled globally before it can be enabled in a VLAN.
Related command: igmp-snooping.
Example
# Enable IGMP Snooping in VLAN 2.
<H3C> system-view
[H3C] igmp-snooping
[H3C-igmp-snooping] quit
[H3C] vlan 2
[H3C-vlan2] igmp-snooping enable
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
View
Ethernet port view/Port group view
Parameter
Use the igmp-snooping fast-leave command to enable the fast leave feature on the current port or group of ports.
Use the undo igmp-snooping fast-leave command to disable the fast leave feature on the current port or group of ports.
Note that:
l           If you do not specify any VLAN in Ethernet port view, the command will take effect for the port no matter which VLAN the port belongs to; if you specify a VLAN or multiple VLANs, the command will take effect for the port only if the port belongs to the specified VLAN(s).
l           If you do not specify any VLAN in port-group view, the command will take effect for all the ports in this group no matter which VLANs these port belong to; if you specify a VLAN or multiple VLANs, the command will take effect for those ports in this group that belong to the specified VLAN(s).
Related command: fast-leave.
Example
# Enable the fast leave feature on GigabitEthernet 1/0/1, which belongs to VLAN 2.
<H3C> system-view
[H3C] interface GigabitEthernet 1/0/1
[H3C- GigabitEthernet 1/0/1] igmp-snooping fast-leave vlan 2
igmp-snooping general-query source-ip { current-interface | ip-address }
undo igmp-snooping general-query source-ip
View
VLAN view
Parameter
current-interface: Sets the source address of IGMP general queries to the address of the current VLAN interface. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 will be used as the source IP address of IGMP general queries.
 ip-address: Specifies the source address of IGMP general queries, which can be any legal IP address.
Use the igmp-snooping general-query source-ip command to configure the source address of IGMP general queries.
Use the undo igmp-snooping general-query source-ip command to restore the default configuration.
By default, the source IP address of IGMP general queries is 0.0.0.0. .
Example
# Set the IP address of the interface of VLAN 2 to 10.1.1.1, with the subnet mask of 255.255.255.0, and specify this IP address as the source IP address of IGMP general queries. .
<H3C> system-view
[H3C] interface vlan-interface 2
[H3C-Vlan-interface2] ip address 10.1.1.1 255.255.255.0
[H3C-Vlan-interface2] quit
[H3C] vlan 2
[H3C-vlan2] igmp-snooping general-query source-ip current-interface
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
View
Parameter
limit: Maximum number of multicast groups that can pass the port(s), in the range of 1 to 128.
vlan vlan-list: Configures the maximum number of multicast groups that can pass the ports in the specified VLAN(s). Here vlan-list is a VLAN list. You can specify multiple VLANs or VLAN ranges by providing this argument in the form of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is in the range of 1 to 4094, and &<1-10> means that you can specify up to 10 VLANs or VLAN ranges for this argument.
Use the igmp-snooping group-limit command to configure the maximum number of multicast groups that can pass the port(s).
Use the undo igmp-snooping group-limit command to restore the default setting.
By default, the maximum number of multicast groups that can pass the port(s) is 256.
Note that:
Example
# Specify to allow a maximum of 10 multicast groups to pass GigabitEthernet1/0/1, which belongs to VLAN 2.
<H3C> system-view
[H3C] interface GigabitEthernet1/0/1
[H3C-GigabitEthernet1/0/1] igmp-snooping group-limit 10 vlan 2
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
View
Parameter
 Use the igmp-snooping group-policy command to configure a multicast group filter on the current port(s).
Use the undo igmp-snooping group-policy command to remove a multicast group filter on the current port(s).
Be default, no multicast group filter is configured on an interface, namely a host can join any multicast group.
Note that:
l           You can configure different ACL rules for a port in different VLANs, and the newly configured ACL rules will override the existing one.
Related command: group-policy.
Example
# Configure ACL 2000 as the multicast group filter on GigabitEthernet1/0/1, which belongs to VLAN 2.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] igmp-snooping group-policy 2000 vlan 2
igmp-snooping host-aging-time interval
undo igmp-snooping host-aging-time
View
VLAN view
Parameter
Use the igmp-snooping host-aging-time command to configure the aging time of group member ports in the current VLAN.
Use the undo igmp-snooping host-aging-time command to restore default setting.
Related command: host-aging-time.
Example
# Set the aging time of group member ports to 300 seconds in VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] igmp-snooping host-aging-time 300
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
View
Parameter
group-address: Address of the multicast group that the simulated host is to join, in the range of 224.0.1.0 to 239.255.255.255. .
source-address: Address of the multicast source that the simulated host is to join. The value of this argument should be a valid unicast address or 0.0.0.0. If the value is 0.0.0.0, this means that no multicast source is specified.
vlan vlan-id: Specifies the VLAN that comprises the Ethernet port(s), where vlan-id is in the range of 1 to 4094.
Use the igmp-snooping host-join command to enable the function of simulating a member host of a multicast group or a multicast source/group.
Use the undo igmp-snooping host-join command to disable the function of simulating a member host of a multicast group or a multicast source/group.
By default, this function is disabled.
Note that:
l           The source-ip source-address statement in the command is meaningful only for IGMP Snooping version 3. If IGMP Snooping version 2 is running, although you can include the source-ip source-address statement in your command, the simulated host responses with only an IGMPv2 report when receiving a query message.
l           If configured in Ethernet port view, this feature takes effect on the port only if the port belongs to the specified VLAN.
l           If configured in port group view, this feature takes effect only on those ports in this port group that belong to the specified VLAN.
Example
# Enable the function of simulating a member host of a multicast source/group on Ethernet 1/0, which belongs to VLAN 2. The multicast source address is 1.1.1.1 and the multicast group address is 224.1.1.1. .
<H3C> system-view
[H3C] igmp-snooping
[H3C] vlan 2
[H3C-vlan2] igmp-snooping version 3
[H3C-vlan2] quit
[H3C-GigabitEthernet1/0/1] igmp-snooping host-join 224.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping last-member-query-interval interval
undo igmp-snooping last-member-query-interval
View
VLAN view
Parameter
interval: Interval between IGMP last-member queries, in units of seconds. The effective range is 1 to 5
Use the igmp-snooping last-member-query-interval command to configure the interval between IGMP last-member queries in the VLAN.
Use the undo igmp-snooping last-member-query-interval command to restore the default setting.
By default, the IGMP last-member query interval is 1 second.
Related command: last-member-query-interval.
Example
# Set the interval between IGMP last-member queries to 3 seconds in VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] igmp-snooping last-member-query-interval 3
igmp-snooping max-response-time interval
undo igmp-snooping max-response-time
View
VLAN view
Parameter
interval: Maximum response time to IGMP general queries, in units of seconds. The effective range is 1 to 25.
Use the igmp-snooping max-response-time command to configure the maximum response time to IGMP general queries in the VLAN.
Use the undo igmp-snooping max-response-time command to restore the default setting.
By default, the maximum response time to IGMP general queries is 10 seconds.
Related command: max-response-time and igmp-snooping query-interval.
Example
# Set the maximum response time to IGMP general queries to 5 seconds in VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] igmp-snooping max-response-time 5
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
View
Parameter
vlan vlan-list: Configures the multicast group replacement function in the specified VLAN(s). Here vlan-list is a VLAN list. You can specify multiple VLANs or VLAN ranges by providing this argument in the form of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is in the range of 1 to 4094, and &<1-10> means that you can specify up to 10 VLANs or VLAN ranges for this argument.
Use the igmp-snooping overflow-replace command to enable the multicast group replacement function on the current port(s).
Use the undo igmp-snooping overflow-replace command to disable the multicast group replacement function on the current port(s).
By default, the multicast group replacement function is disabled.
Note that:
Related command: overflow-replace.
Example
# Enable the multicast group replacement function on GigabitEthernet1/0/1, which belongs to VLAN 2.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] igmp-snooping overflow-replace vlan 2
undo igmp-snooping querier
View
VLAN view
Parameter
None
Use the igmp-snooping querier command to enable the IGMP Snooping querier function.
Use the undo igmp-snooping querier command to disable the IGMP Snooping querier function.
By default, the IGMP Snooping querier function is disabled.
Example
# Enable the IGMP Snooping querier function in VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] igmp-snooping querier
igmp-snooping query-interval interval
undo igmp-snooping query-interval
View
VLAN view
Parameter
interval: Interval between IGMP general queries, in units of seconds. The effective range is 2 to 300.
Use the igmp-snooping query-interval command to configure the interval between IGMP general queries.
Use the undo igmp-snooping query-interval command to restore the default setting.
By default, the IGMP general query interval is 60 seconds.
Related command: igmp-snooping querier, igmp-snooping max-response-time and max-response-time.
Example
# Set the interval between IGMP general queries to 20 seconds in VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] igmp-snooping query-interval 20
igmp-snooping router-aging-time interval
undo igmp-snooping router-aging-time
View
VLAN view
Parameter
interval: Router port aging time, in units of seconds. The effective range is 1 to 1,000.
Use the igmp-snooping router-aging-time command to configure the aging time of router ports in the current VLAN.
Use the undo igmp-snooping router-aging-time command to restore the default setting .
By default, the aging time of router ports is 180 seconds.
Related command: router-aging-time.
Example
# Set the aging time of router ports to 100 seconds in VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] igmp-snooping router-aging-time 100
undo igmp-snooping source-deny
View
Parameter
None
Use the igmp-snooping source-deny command to enable multicast source port filtering.
Use the undo igmp-snooping source-deny command to disable multicast source port filtering.
By default, multicast source port filtering is disabled.
&  Note:
When enabled to filter IPv4 multicast data based on the source ports, are automatically enabled to filter IPv6 multicast data based on the source ports.
Example
# Enable source port filtering for multicast data on GigabitEthernet 1/0/1.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] igmp-snooping source-deny
igmp-snooping special-query source-ip { current-interface | ip-address }
undo igmp-snooping special-query source-ip
View
VLAN view
Parameter
current-interface: Sets the source address of IGMP group-specific queries to the address of the current VLAN interface. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 will be used as the source IP address of IGMP group-specific queries.
ip-address: Sets the source address of IGMP group-specific queries to the specified address.
Use the igmp-snooping special-query source-ip command to configure the source IP address of IGMP group-specific queries.
Use the undo igmp-snooping special-query source-ip command to restore the default configuration.
By default, the source IP address of IGMP group-specific queries is 0.0.0.0. .
Example
# Set the IP address of the interface of VLAN 2 to 10.1.1.1, with the subnet mask of 255.255.255.0, and specify this IP address as the source IP address of IGMP group-specific queries. .
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] igmp-snooping special-query source-ip current-interface
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
View
Parameter
group-address: Address of the multicast group to be statically joined, in the range of 224.0.0.0 to 239.255.255.255. .
source-address: Address of multicast source to be statically joined. The value of this argument should be a valid unicast address or 0.0.0.0. If the value is 0.0.0.0, this means no multicast source is specified.
Use the igmp-snooping static-group command to enable the static member port function, namely to configure a port or ports as static member port(s) of a multicast group or multicast source/group.
Use the undo igmp-snooping static-group command to disable the static member port function.
By default, the static member port function is disabled.
Note that:
l           The source-ip source-address statement in the command is meaningful only for IGMP Snooping version 3. If IGMP Snooping version 2 is running, although you can include the source-ip source-address statement in your command, the configuration will not take effect. .
Example
# Configure GigabitEthernet1/0/1, which belongs to VLAN 2, to be a static member port of a multicast source/group. The multicast source address is 1.1.1.1 and the multicast group address is 224.1.1.1. .
<H3C> system-view
[H3C] igmp-snooping
[H3C] vlan 2
[H3C-vlan2] quit
[H3C-GigabitEthernet1/0/1] igmp-snooping static-group 224.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port vlan vlan-id
View
Parameter
vlan vlan-id: Specifies a VLAN in which one or more static router ports are to be configured, where vlan-id is in the range of 1 to 4094.
Use the igmp-snooping static-router-port command to enable the static router port function.
Use the undo igmp-snooping static-router-port command to disable the static router port function.
By default, the static router port function is not enabled.
Note that:
Example
# Enable the static router port function on GigabitEthernet1/0/1, which belongs to VLAN 2.
<H3C> system-view
[H3C- GigabitEthernet1/0/1] igmp-snooping static-router-port vlan 2
igmp-snooping version version-number
undo igmp-snooping version
View
VLAN view
Parameter
version-number: IGMP snooping version, in the range of 2 to 3.
Use the igmp-snooping version command to configure the IGMP Snooping version. .
Use the undo igmp-snooping version command to restore the default setting. .
By default, the IGMP version is 2.
Example
# Enable IGMP Snooping in VLAN 2, and set the IGMP Snooping version to version 3.
<H3C> system-view
[H3C] igmp-snooping
[H3C] vlan 2
undo last-member-query-interval
View
IGMP Snooping view
Parameter
interval: Interval between IGMP last-member queries, in units of seconds. The effective range is 1 to 5.
Use the last-member-query-interval command to configure the interval between IGMP last-member queries globally.
Use the undo last-member-query-interval command to restore the default setting.
By default, the interval between IGMP last-member queries is 1 second.
Related command: igmp-snooping last-member-query-interval.
Example
# Set the interval between IGMP last-member queries globally to 3 seconds.
<H3C> system-view
[H3C] igmp-snooping
[H3C-igmp-snooping] last-member-query-interval 3
undo max-response-time
View
IGMP Snooping view
Parameter
Use the max-response-time command to configure the maximum response time to IGMP general queries globally.
Use the undo max-response-time command to restore the default value.
Related command: igmp-snooping max-response-time and igmp-snooping query-interval.
Example
# Set the maximum response time to IGMP general queries globally to 5 seconds.
<H3C> system-view
[H3C] igmp-snooping
[H3C-igmp-snooping] max-response-time 5
undo overflow-replace [ vlan vlan-list ]
View
IGMP Snooping view
Parameter
Use the overflow-replace command to enable the multicast group replacement function globally.
Use the undo overflow-replace command to disable the multicast group replacement function globally.
Note that:
Related command: igmp-snooping overflow-replace.
Example
# Enable the multicast group replacement function in VLAN 2.
<H3C> system-view
[H3C] igmp-snooping
[H3C-igmp-snooping] overflow-replace vlan 2
reset igmp-snooping group { group-address | all } [ vlan vlan-id ]
View
Parameter
group-address: Address of the multicast group of which the IGMP Snooping entries are to be cleared. The value range is 224.0.1.0 to 239.255.255.255. .
all: Specifies to clear all IGMP Snooping entries.
vlan vlan-id: Specifies a VLAN in which all IGMP Snooping entries are to be cleared, where vlan-id is in the range of 1 to 4094.
Use the reset igmp-snooping group command to clear IGMP Snooping entries.
Note that:
l           This command works only on an IGMP Snooping–enabled VLAN, but not on a VLAN with IGMP enabled on its VLAN interface.
l           This command cannot clear IGMP Snooping forwarding entries derived from static configuration.
Example
# Clear all IGMP Snooping entries saved in the switch.
<H3C> reset igmp-snooping group all
View
Parameter
None
Use the reset igmp-snooping statistics command to clear the statistics information of IGMP messages learned by IGMP Snooping.
Example
# Clear the statistics information of all kinds of IGMP messages learned by IGMP Snooping.
<H3C> reset igmp-snooping statistics
undo router-aging-time
View
IGMP Snooping view
Parameter
Use the router-aging-time command to configure the aging time of router ports globally.
Use the undo router-aging-time command to restore the default setting.
By default, the aging time of router ports is 105 seconds.
Related command: igmp-snooping router-aging-time.
Example
# Set the aging time of router ports globally to 100 seconds.
<H3C> system-view
[H3C] igmp-snooping
[H3C-igmp-snooping] router-aging-time 100
1.1.32  source-deny
undo source-deny port interface-list
View
IGMP Snooping view
Parameter
interface-list: Ethernet port list. You can specify multiple Ethernet ports or port ranges by providing the this argument in the form of interface-list = { interface-type interface-number [ to interface-type interface-number ] }, where interface-type is port type and interface-number is port number,
Use the source-deny command to enable multicast source port filtering so that all multicast data packets are blocked.
Use the undo source-deny command to disable multicast source port filtering.
By default, multicast source port filtering is not enabled.
&  Note:
Example
# Enable source port filtering for multicast data on interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4
<H3C> system-view
[H3C] igmp-snooping
[H3C-igmp-snooping] source-deny port GigabitEthernet 1/0/1 to GigabitEthernet 1/0/4
display mld-snooping group [ vlan vlan-id ] [ verbose ]
View
Parameter
vlan vlan-id: Displays the IPv6 multicast group information in the specified VLAN, where vlan-id is in the range of 1 to 4094, If you do not specify a VLAN, this command will display the information of IPv6 multicast groups in all VLANs.
verbose: Displays the detailed IPv6 multicast group information.
Use the display mld-snooping group command to view the IPv6 multicast group information learned by MLD Snooping.
Example
# View the detailed information of IPv6 multicast groups in VLAN 2 learned by MLD Snooping.
<H3C> display mld-snooping group vlan 2 verbose
  Vlan(id):2.
            GigabitEthernet 1/0/2                                   (D) ( 00:01:30 )
      IP group address:FF1E::1
        (::, FF1E::1):
            GigabitEthernet 1/0/1                                     (D) ( 00:03:57 )
    MAC group(s):
        MAC group address:3333-0000-0001
Table 2-1 Description on the fields of the display mld-snooping group command
Total number of IPv6 multicast groups
Total number of IPv6 multicast sources
Router port(s)
IP group address
Address of IPv6 multicast group
MAC group address
Attribute
Attribute of IPv6 multicast group
Host port(s)
View
Parameter
None
Use the display mld-snooping statistics command to view the statistics information of MLD messages learned by MLD Snooping.
Example
# View the statistics information of all kinds of MLD messages learned by MLD Snooping.
<H3C> display mld-snooping statistics
  Received MLD general query packet(s) number:0.
  Received MLD specific query packet(s) number:0.
  Received MLD V1 report packet(s) number:0.
  Received MLD done packet(s) number:0.
  Sent MLD specific query packet(s) number:0.
  Received error MLD packet(s) number:10.
Table 2-2 Description on the fields of the display mld-snooping statistics command
report packet(s)
Report message(s)
done packet(s)
Done message(s)
error MLD packet(s)
Error MLD message(s)
2.1.3  fast-leave
View
MLD Snooping view
Parameter
By default, the fast leave feature is disabled globally.
Note that:
l           This command works on an MLD Snooping–enabled VLAN or on a VLAN with MLD enabled on its VLAN interface.
Related command: mld-snooping fast-leave.
Example
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping] fast-leave vlan 2
2.1.4  group-policy
group-policy acl6-number [ vlan vlan-list ]
View
MLD Snooping view
Parameter
Acl6-number: Basic IPv6 ACL number, in the range of 2000 to 2999.
vlan vlan-list: Configures an IPv6 multicast group filter in the specified VLAN(s). Here vlan-list is a VLAN list. You can specify multiple VLANs or VLAN ranges by providing this argument in the form of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is in the range of 1 to 4094, and &<1-10> means that you can specify up to 10 VLANs or VLAN ranges for this argument.
Use the group-policy command to configure a global IPv6 multicast group filter.
Use the undo group-policy command to remove the configured global IPv6 multicast group filter.
By default, no IPv6 multicast group filter is configured globally, namely any host can join any IPv6 multicast group.
Note that:
l           If the specified IPv6 ACL rule does not exist or the ACL rule is null, all IPv6 multicast groups will be filtered out.
l           You can configure different IPv6 ACL rules for each port in different VLANs, and the newly configured IPv6 ACL rules will override the existing ones.
Related command: mld-snooping group-policy.
Example
# Configure ACL 2000 as the IPv6 multicast group filter in VLAN 2.
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping] group-policy 2000 vlan 2
View
MLD Snooping view
Parameter
Use the host-aging-time command to configure the global aging time of group member ports.
By default, the aging time of member ports is 260 seconds.
This command works only on an MLD Snooping–enabled VLAN, but not on a VLAN with MLD enabled on its VLAN interface.
Related command: mld-snooping host-aging-time.
Example
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping] host-aging-time 300
View
MLD Snooping view
Parameter
interval: Interval between MLD last-member queries, in units of seconds. The effective range is 1 to 5.
Use the last-member-query-interval command to configure the interval between MLD last-member queries globally.
By default, the interval between MLD last-member queries is 1 second.
Related command: mld-snooping last-member-query-interval.
Example
# Set the interval between MLD last-member queries globally to 3 seconds.
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping] last-member-query-interval 3
View
MLD Snooping view
Parameter
interval: Maximum response time to MLD general queries, in units of seconds. The effective range is 1 to 25.
Use the max-response-time command to configure the maximum response time to MLD general queries globally.
Use the undo max-response-time command to restore the default setting.
By default, the maximum response time to MLD general queries is 10 seconds.
Related command: mld-snooping max-response-time and mld-snooping query-interval.
Example
# Set the maximum response time to MLD general queries globally to 5 seconds.
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping] max-response-time 5
2.1.8  mld-snooping
mld-snooping
undo mld-snooping
View
Parameter
None
Use the mld-snooping command to enable MLD Snooping globally and enter MLD Snooping view.
Use the undo mld-snooping command to disable MLD Snooping globally.
By default, MLD Snooping is disabled.
Related command: mld-snooping enable.
Example
# Enable MLD Snooping globally and enter MLD Snooping view.
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping]
undo mld-snooping drop-unknown
View
VLAN view
Parameter
None
Use the mld-snooping drop-unknown command to enable the function of silently dropping unknown IPv6 multicast data in the current VLAN.
Use the undo mld-snooping drop-unknown command to disable the function of silently dropping unknown IPv6 multicast data in the current VLAN.
By default, this function is disabled, unknown IPv6 multicast data is flooded.
This command takes effect only if MLD Snooping is enabled in the VLAN.
Example
# In VLAN 2, enable the function of silently dropping unknown IPv6 multicast data.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] mld-snooping drop-unknown
mld-snooping enable
undo mld-snooping enable
View
VLAN view
Parameter
None
Use the mld-snooping enable command to enable MLD Snooping in the current VLAN.
Use the undo mld-snooping enable command to disable MLD Snooping in the current VLAN.
By default, MLD Snooping is disabled in a VLAN.
MLD Snooping must be enabled globally before it can be enabled in a VLAN
Related command: mld-snooping.
Example
# Enable MLD Snooping in VLAN 2.
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping] quit
[H3C] vlan 2
[H3C-vlan2] mld-snooping enable
undo mld-snooping fast-leave [ vlan vlan-list ]
View
Ethernet port view/Port-group view
Parameter
Use the mld-snooping fast-leave command to enable the fast leave feature on the current port or group of ports.
Use the undo mld-snooping fast-leave command to disable the fast leave feature on the current port or group of ports.
Note that:
Example
<H3C> system-view
[H3C]interface GigabitEthernet 1/0/1
[H3C-GigabitEthernet1/0/1]mld-snooping fast-leave vlan 2
mld-snooping general-query source-ip { current-interface | ipv6-address }
undo mld-snooping general-query source-ip
View
VLAN view
Parameter
current-interface: Sets the source IPv6 address of MLD general queries to the IPv6 address of the current VLAN interface. If the current VLAN interface does not have an IPv6 address, the default IPv6 address fe80::02ff:ffff:fe00:0001 will be used as the source IPv6 address of MLD general queries.
ipv6-address: Specifies the source IPv6 address of MLD general queries, which can be any legal IPv6 address.
Use the mld-snooping general-query source-ip command to configure the source IPv6 address of MLD general queries.
Use the undo mld-snooping general-query source-ip command to restore the default configuration.
By default, the source IPv6 address of MLD general queries is fe80::02ff:ffff:fe00:0001.
Example
# Set the IPv6 address of the interface of VLAN 2 to fec0:0:0:1::1/64 and specify this IPv6 address as the source IPv6 address of MLD general queries.
<H3C> system-view
[H3C-Vlan-interface2] ipv6 address fec0:0:0:1::1/64
[H3C] vlan 2
[H3C-vlan2] mld-snooping general-query source-ip current-interface
undo mld-snooping group-limit [ vlan vlan-list ]
View
Parameter
limit: Maximum number of IPv6 multicast groups that can pass the port(s), in the range of 1 to 128
vlan vlan-list: Configures the maximum number of IPv6 multicast groups that can pass the ports in the specified VLAN(s). Here vlan-list is a VLAN list. You can specify multiple VLANs or VLAN ranges by providing this argument in the form of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is in the range of 1 to 4094, and &<1-10> means that you can specify up to 10 VLANs or VLAN ranges for this argument.
Use the mld-snooping group-limit command to configure the maximum number of IPv6 multicast groups that can pass the port(s).
Use the undo mld-snooping group-limit command to restore the default setting.
By default, a maximum of 128 IPv6 multicast groups can pass a port.
Note that:
Example
# Specify to allow a maximum of 10 IPv6 multicast groups to pass GigabitEthernet 1/0/1, which belongs to VLAN 2.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] mld-snooping group-limit 10 vlan 2
mld-snooping group-policy acl-number [ vlan vlan-list ]
undo mld-snooping group-policy [ vlan vlan-list ]
View
Parameter
acl6-number: Basic IPv6 ACL number, in the range of 2000 to 2999.
Use the mld-snooping group-policy command to configure an IPv6 multicast group filter on the current port(s).
Use the undo mld-snooping group-policy command to remove the configured IPv6 multicast group filter on the current port(s).
By default, no IPv6 multicast group filter is configured on a port, namely a host can join any IPv6 multicast group.
Note that:
l           If the specified ACL rule does not exist or the ACL rule is null, all IPv6 multicast groups will be filtered out.
Example
# Configure ACL 2000 as the IPv6 multicast group filter on GigabitEthernet 1/0/1, which belongs to VLAN 2.
<H3C> system-view
[H3C- GigabitEthernet 1/0/1] mld-snooping group-policy 2000 vlan 2
mld-snooping host-aging-time interval
undo mld-snooping host-aging-time
View
VLAN view
Parameter
Use the mld-snooping host-aging-time command to configure the aging time of group member ports in the current VLAN.
Use the undo mld-snooping host-aging-time command to restore the current VLAN.
By default, the member port aging time is 260 seconds.
Example
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] mld-snooping host-aging-time 300
mld-snooping host-join ipv6-group-address vlan vlan-id
undo mld-snooping host-join ipv6-group-address vlan vlan-id
View
Parameter
ipv6-group-address: Address of IPv6 multicast group which the simulated host is to join. The effective range is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where x and y represent any hexadecimal number between 0 and F, inclusive.
Use the mld-snooping host-join command to enable the function of simulating a member host of an IPv6 multicast group.
Use the undo mld-snooping host-join command to disable the function of simulating a member host of an IPv6 multicast group.
Note that:
Example
# Enable the function of simulating a member host of IPv6 multicast group ff1e::1 on GigabitEthernet 1/0/1, which belongs to VLAN 2.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] mld-snooping host-join ff1e::1 vlan 2
mld-snooping last-member-query-interval interval
undo mld-snooping last-member-query-interval
View
VLAN view
Parameter
Use the mld-snooping last-member-query-interval command to configure the interval between MLD last-member queries in the VLAN.
Use the undo mld-snooping last-member-query-interval command to restore the default setting.
Example
# Set the interval between MLD last-member queries to 3 seconds in VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] mld-snooping last-member-query-interval 3
mld-snooping max-response-time interval
undo mld-snooping max-response-time
View
VLAN view
Parameter
Use the mld-snooping max-response-time command to configure the maximum response time to MLD general queries in the VLAN.
Use the undo mld-snooping max-response-time command to restore the default setting.
Related command: max-response-time and mld-snooping query-interval.
Example
# Set the maximum response time to MLD general queries to 5 seconds in VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] mld-snooping max-response-time 5
undo mld-snooping overflow-replace [ vlan vlan-list ]
View
Parameter
vlan vlan-list: Configures the IPv6 multicast group replacement function in the specified VLAN(s). Here vlan-list is a VLAN list. You can specify multiple VLANs or VLAN ranges by providing this argument in the form of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is in the range of 1 to 4094, and &<1-10> means that you can specify up to 10 VLANs or VLAN ranges for this argument.
Use the mld-snooping overflow-replace command to enable the IPv6 multicast group replacement function on the current port(s).
Use the undo mld-snooping overflow-replace command to disable the IPv6 multicast group replacement function on the current port(s).
By default, the IPv6 multicast group replacement function is disabled.
Note that:
Example
# Enable the IPv6 multicast group replacement function on GigabitEthernet 1/0/1, which belongs to VLAN 2.
<H3C> system-view
[H3C- GigabitEthernet 1/0/1] mld-snooping overflow-replace vlan 2
undo mld-snooping querier
View
VLAN view
Parameter
None
Use the mld-snooping querier command to enable the MLD Snooping querier function.
Use the undo mld-snooping querier command to disable the MLD Snooping querier function.
By default, the MLD Snooping querier function is disabled.
Example
# Enable the MLD Snooping querier function in VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] mld-snooping querier
undo mld-snooping query-interval
View
VLAN view
Parameter
interval: Interval between MLD general queries, in units of seconds. The effective range is 2 to 300.
Use the mld-snooping query-interval command to configure the interval between MLD general queries.
Use the undo mld-snooping query-interval command to restore the default setting.
By default, the interval between MLD general queries is 125 seconds.
Related command: mld-snooping querier, mld-snooping max-response-time and max-response-time.
Example
# Set the interval between MLD general queries to 20 seconds in VLAN 2.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] mld-snooping query-interval 20
undo mld-snooping report-aggregation
View
MLD Snooping view
Parameter
None
Use the mld-snooping report-aggregation command to enable MLD report suppression.
Use the undo mld-snooping report-aggregation command to disable MLD report suppression.
By default, MLD report suppression is disabled.
Example
# Disable MLD report suppression.
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping] undo mld-snooping report-aggregation
mld-snooping router-aging-time interval
undo mld-snooping router-aging-time
View
VLAN view
Parameter
Use the mld-snooping router-aging-time command to configure the aging time of router ports in the current VLAN.
Use the undo mld-snooping router-aging-time command to restore the default setting.
By default, the router port aging time is 260 seconds.
Example
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] mld-snooping router-aging-time 100
undo mld-snooping source-deny
View
Parameter
None
Use the mld-snooping source-deny command to enable IPv6 multicast source port filtering.
Use the undo mld-snooping source-deny command to disable IPv6 multicast source port filtering.
By default, IPv6 multicast source port filtering is disabled.
&  Note:
When enabled to filter IPv6 multicast data based on the source ports, are automatically enabled to filter IPv4 multicast data based on the source ports.
Example
# Enable source port filtering for IPv6 multicast data on GigabitEthernet 1/0/1.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] mld-snooping source-deny
mld-snooping special-query source-ip { current-interface | ipv6-address }
undo mld-snooping special-query source-ip
View
VLAN view
Parameter
current-interface: Sets the source IPv6 address of MLD group-specific queries to the IPv6 address of the current VLAN interface. If the current VLAN interface does not have an IPv6 address, the default IPv6 address fe80::02ff:ffff:fe00:0001 will be used as the source IPv6 address of MLD group-specific queries.
ipv6-address: Sets the source IPv6 address of MLD group-specific queries to the specified IPv6 address.
Use the mld-snooping special-query source-ip command to configure the source IPv6 address of MLD group-specific queries.
Use the undo mld-snooping special-query source-ip command to restore the default configuration.
By default, the source IPv6 address of MLD group-specific queries is fe80::02ff:ffff:fe00:0001.
Example
# Set the IPv6 address of the interface of VLAN 2 to fec0:0:0:1::1/64 and specify this IPv6 address as the source IPv6 address of MLD group-specific queries.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] mld-snooping special-query source-ip current-interface
mld-snooping static-group ipv6-group-address vlan vlan-id
undo mld-snooping static-group ipv6-group-address vlan vlan-id
View
Parameter
ipv6-group-address: Information of statically joined IPv6 multicast groups. The effective range is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where x and y represent any hexadecimal number between 0 and F, inclusive.
Use the mld-snooping static-group command to enable the static member port function, namely to configure a port or ports as static member port(s) of an IPv6 multicast group.
Use the undo mld-snooping static-group command to disable the static member port function.
Note that:
Example
# Configure GigabitEthernet 1/0/1, which belongs to VLAN 2, to be a static member port of IPv6 multicast group ff1e::1.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] mld-snooping static-group ff1e::1 vlan 2
undo mld-snooping static-router-port vlan vlan-id
View
Parameter
Use the mld-snooping static-router-port command to enable the static router port function.
Use the undo mld-snooping static-router-port command to disable the static router port function.
By default, the static router port function is disabled.
Note that:
Example
# Enable the static router port function on GigabitEthernet 1/0/1, which belongs to VLAN 2.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] mld-snooping static-router-port vlan 2
View
MLD Snooping view
Parameter
Use the overflow-replace command to enable the IPv6 multicast group replacement function globally.
Use the undo overflow-replace command to disable the IPv6 multicast group replacement function globally.
By default, the IPv6 multicast group replacement function is disabled globally.
Note that:
Related command: mld-snooping overflow-replace.
Example
# Enable the IPv6 multicast group replacement function globally in VLAN 2.
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping] overflow-replace vlan 2
reset mld-snooping group { ipv6-group-address | all } [ vlan vlan-id ]
View
Parameter
ipv6-group-address: Address of the IPv6 multicast group of which the MLD Snooping forwarding entries are to be cleared. The effective range is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where x and y represent any hexadecimal number between 0 and F, inclusive.
all: Specifies to clear all MLD Snooping entries.
vlan vlan-id: Specifies a VLAN in which all MLD Snooping entries are to be cleared, where vlan-id is in the range of 1 to 4094.
Use the reset mld-snooping group command to clear MLD Snooping entries.
Note that:
l           This command works only on an MLD Snooping–enabled VLAN, but not on a VLAN with MLD enabled on its VLAN interface.
l           This command cannot clear MLD Snooping entries derived from static configuration.
Example
# Clear all MLD Snooping entries saved in the switch.
<H3C> reset mld-snooping group all
View
Parameter
None
Use the reset mld-snooping statistics command to clear the statistics information of MLD messages learned by MLD Snooping.
Example
# Clear the statistics information of all kinds of MLD messages learned by MLD Snooping.
<H3C> reset mld-snooping statistics
View
MLD Snooping view
Parameter
Related command: mld-snooping router-aging-time.
Example
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping] router-aging-time 100
2.1.32  source-deny
View
MLD Snooping view
Parameter
interface-list: Ethernet port list. You can specify multiple Ethernet ports or port ranges by providing the this argument in the form of interface-list = { interface-type interface-number [ to interface-type interface-number ] }, where interface-type is port type and interface-number is port number.
Use the source-deny command to enable IPv6 multicast source port filtering, namely to filter out all the received IPv6 multicast packets.
Use the undo source-deny command to disable IPv6 multicast source port filtering.
&  Note:
Example
# Enable source port filtering for IPv6 multicast data on interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/1.
<H3C> system-view
[H3C] mld-snooping
[H3C-mld-snooping] source-deny port GigabitEthernet 1/0/1 to GigabitEthernet 1/0/4
display multicast-vlan [ vlan-id ]
View
Parameter
vlan-id: VLAN ID of a multicast VLAN, in the range of 1 to 4094. If this argument is not provided, the information about all multicast VLANs and their sub VLANs will be displayed.
Use the display multicast-vlan command to display the information about the specified multicast VLAN and its sub VLANs.
Example
# Display information about all multicast VLANs and their sub VLANs
<Sysname> display multicast-vlan
 multicast vlan 100's subvlan list:
   vlan 2 4-8
multicast-vlan vlan-id enable
undo multicast-vlan vlan-id enable
View
Parameter
vlan-id: Specifies a VLAN ID, in the range 1 to 4094
Use the multicast-vlan enable command to configure the specified VLAN as a multicast VLAN.
Use the undo multicast-vlan enable command to remove the specified VLAN as a multicast VLAN.
No VLAN is multicast VLAN by default.
Note that:
l           The specified VLAN must exist.
l           After a VLAN is configured into a multicast VLAN, Layer 2 multicast must be enabled in the VLAN before the multicast VLAN feature can be implemented, while it is not necessary to enable Layer 2 multicast in the sub-VLANs of the multicast VLAN.
Example
# Configure VLAN 10 as a multicast VLAN.
<H3C> system-view
[H3C] multicast-vlan 10 enable
multicast-vlan vlan-id subvlan vlan-list
undo multicast-vlan vlan-id subvlan vlan-list
View
Parameter
vlan-id: VLAN ID of a multicast VLAN, in the range 1 to 4094.
vlan-list: Sub-VLAN list, representing multiple sub-VLANs, in the form of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is the VLAN ID if a sub-VLAN, in the range of 1 to 4094, and &<1-10> means that you can specify up to 10 sub-VLANs or sub-VLAN ranges for this argument.
Use the multicast-vlan subvlan command to configure sub-VLAN(s) for the specified multicast VLAN.
Use the undo multicast-vlan subvlan command to remove the specified sub-VLAN(s) from the specified multicast VLAN.
A multicast VLAN has no sub-VLAN by default.
Note that:
l           The VLAN to be configured as the multicast VLAN and the VLANs to be configured as sub-VLANs of the multicast VLAN must exist.
l           The VLANs to be configured as sub-VLANs of the multicast VLAN must not be multicast VLANs.
l           The VLANs to be configured as the sub-VLANs of the multicast VLAN must not be sub-VLANs of another multicast VLAN.
l           The number of sub-VLANs of the multicast VLAN must not exceed the system-defined limit (Currently, S5500-SI Series Ethernet Switches only support one multicast VLAN, and each one can configure up to 63 sub-VLANs).
Example
# Configure VLAN 1 through VLAN 5 as sub-VLANs of multicast VLAN 10.
<H3C> system-view
[H3C] multicast-vlan 10 subvlan 1 to 5
