H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
33-Appendix
33-Appendix 89 KB
Appendix A  Command Index
The command index includes all the commands in the VRP Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
access-limit
AAA-RADIUS-HWTACACS
1-1
accounting
QoS
2-1
accounting default
AAA-RADIUS-HWTACACS
1-2
accounting lan-access
AAA-RADIUS-HWTACACS
1-3
accounting login
AAA-RADIUS-HWTACACS
1-4
accounting optional
AAA-RADIUS-HWTACACS
1-5
acl
Login
2-1
acl
ACL
1-4
acl ipv6 (basic or advanced IPv6 ACL)
ACL
2-1
activation-key
Login
1-1
active region-configuration
MSTP
1-1
add-member
Cluster
1-16
administrator-address
Cluster
1-17
apply cost
IPv4 Routing
3-1
apply cost
IPv6  Routing
3-1
apply ip-address next-hop
IPv4 Routing
3-2
apply ipv6 next-hop
IPv6  Routing
3-2
apply poe-profile
PoE-PoE Profile
1-1
apply poe-profile interface
PoE-PoE Profile
1-2
apply preference
IPv4 Routing
3-3
apply preference
IPv6  Routing
3-2
apply tag
IPv4 Routing
3-3
apply tag
IPv6  Routing
3-3
arp check enable
ARP
1-1
arp max-learning-num
ARP
1-1
arp static
ARP
1-2
arp timer aging
ARP
1-3
ascii
File System Management
2-4
attribute
AAA-RADIUS-HWTACACS
1-6
attribute
PKI
1-1
authentication default
AAA-RADIUS-HWTACACS
1-7
authentication lan-access
AAA-RADIUS-HWTACACS
1-8
authentication login
AAA-RADIUS-HWTACACS
1-9
authentication-mode
Login
1-2
authorization command
AAA-RADIUS-HWTACACS
1-11
authorization default
AAA-RADIUS-HWTACACS
1-11
authorization lan-access
AAA-RADIUS-HWTACACS
1-13
authorization login
AAA-RADIUS-HWTACACS
1-14
auto-build
Cluster
1-18
auto-execute command
Login
1-3
B
backup startup-configuration
1-11
binary
2-5
black-list add-mac
Cluster
1-20
black-list delete-mac
Cluster
1-20
boot-loader
Basic System Configuration and Maintenance
3-1
bootrom
3-2
bootrom-update security-check enable
3-2
bpdu-tunnel dot1q enable
QinQ-BPDU TUNNEL
2-1
bpdu-tunnel dot1q stp
QinQ-BPDU TUNNEL
2-2
broadcast-suppression
Port Correlation Configuration
1-1
build
Cluster
1-21
bye
2-5
bye
SSH Terminal Service
1-30
C
ca identifier
PKI
1-2
car
QoS
2-1
cd
1-1
cd
2-6
cd
1-31
cdup
2-6
cdup
1-32
certificate request entity
PKI
1-3
certificate request from
PKI
1-3
certificate request mode
PKI
1-4
certificate request polling
PKI
1-5
certificate request url
PKI
1-6
check region-configuration
MSTP
1-2
checkzero
IPv4 Routing
2-1
checkzero
IPv6  Routing
2-1
ciphersuite
SSL-HTTPS
1-1
classifier behavior
QoS
2-3
client-verify enable
SSL-HTTPS
1-2
clock datetime
1-1
clock summer-time
1-1
clock timezone
1-3
close
2-7
close-mode wait
SSL-HTTPS
1-2
cluster
Cluster
1-22
cluster enable
Cluster
1-22
cluster switch-to
Cluster
1-23
command-privilege
1-4
common-name
PKI
1-6
copy
1-1
copy configuration
1-2
count
NQA
1-1
country
PKI
1-7
crl check
PKI
1-8
crl update-period
PKI
1-8
crl url
PKI
1-9
cut connection
AAA-RADIUS-HWTACACS
1-15
D
databits
Login
1-4
datafill
NQA
1-2
data-flow-format
AAA-RADIUS-HWTACACS
1-29
data-flow-format
AAA-RADIUS-HWTACACS
1-57
datasize
NQA
1-2
debugging
2-4
default cost
IPv4 Routing
2-2
default cost
IPv6  Routing
2-2
default-route originate
IPv4 Routing
2-2
delete
1-2
delete
2-7
delete
1-32
delete ipv6 static-routes all
IPv6  Routing
1-1
delete static-routes all
IPv4 Routing
1-1
delete-member
Cluster
1-25
description
VLAN
1-1
description
1-3
description
ACL
1-5
description
ACL
2-2
description
NQA
1-3
destination-ip
NQA
1-4
destination-port
NQA
1-5
dhcp enable
DHCP
1-1
dhcp relay address-check
DHCP
1-2
dhcp relay information enable
DHCP
1-2
dhcp relay information format
DHCP
1-3
dhcp relay information strategy
DHCP
1-4
dhcp relay release
DHCP
1-5
dhcp relay security static
DHCP
1-6
dhcp relay security tracker
DHCP
1-6
dhcp relay server-detect
DHCP
1-7
dhcp relay server-group
DHCP
1-8
dhcp relay server-select
DHCP
1-9
dhcp select relay
DHCP
1-9
dhcp-snooping
DHCP
2-1
dhcp-snooping trust
DHCP
2-2
dir
1-3
dir
2-8
dir
1-33
disconnect
2-9
display acl
ACL
1-5
display acl ipv6
ACL
2-2
display arp
ARP
1-4
display arp ip-address
ARP
1-5
display arp timer aging
ARP
1-6
display boot-loader
3-3
display bootp client
DHCP
4-1
display brief interface
1-3
display channel
Information Center
1-1
display clipboard
1-5
display clock
1-6
display cluster
Cluster
1-25
display cluster base-topology
Cluster
1-27
display cluster black-list
Cluster
1-28
display cluster candidates
Cluster
1-29
display cluster current-topology
Cluster
1-30
display cluster members
Cluster
1-32
display connection
AAA-RADIUS-HWTACACS
1-16
display cpu-usage
3-4
display current-configuration
1-6
display debugging
2-5
display device
3-6
display dhcp client
DHCP
3-1
display dhcp relay
DHCP
1-10
display dhcp relay security
DHCP
1-11
display dhcp relay security statistics
DHCP
1-12
display dhcp relay security tracker
DHCP
1-12
display dhcp relay server-group
DHCP
1-13
display dhcp relay statistics
DHCP
1-14
display dhcp-snooping
DHCP
2-2
display dhcp-snooping trust
DHCP
2-3
display diagnostic-information
1-12
display dns domain
DNS
1-1
display dns dynamic-host
DNS
1-2
display dns ipv6 dynamic-host
IPv6 Configuration
1-1
display dns server
DNS
1-3
display domain
AAA-RADIUS-HWTACACS
1-17
display dot1x
802.1x-HABP-MAC Authentication
1-1
display environment
3-7
display fan
3-7
display fib
IP Address and Performance
2-1
display fib ip-address
2-3
display fib statistics
2-4
display ftp-server
2-1
display ftp-user
2-1
display garp statistics
VLAN
3-1
display garp timer
VLAN
3-1
display gvrp statistics
VLAN
3-5
display gvrp status
VLAN
3-6
display habp
2-1
display habp table
2-2
display habp traffic
2-2
display history-command
1-14
display hotkey
1-15
display hwtacacs
AAA-RADIUS-HWTACACS
1-58
display icmp statistics
2-5
display igmp-snooping group
Multicast Protocol
1-1
display igmp-snooping statistics
Multicast Protocol
1-2
display info-center
Information Center
1-2
display interface
1-6
display interface Vlan-interface
VLAN
1-2
display ip host
DNS
1-4
display ip https
SSL-HTTPS
2-1
display ip interface
1-1
display ip interface brief
1-3
display ip ip-prefix
IPv4 Routing
3-4
display ip ipv6-prefix
IPv6  Routing
3-4
display ip routing-table
Routing Overview
1-1
display ip routing-table acl
Routing Overview
1-5
display ip routing-table ip-address
Routing Overview
1-6
display ip routing-table ip-address1 ip-address2
Routing Overview
1-9
display ip routing-table ip-prefix
Routing Overview
1-10
display ip routing-table protocol
Routing Overview
1-12
display ip routing-table statistics
Routing Overview
1-13
display ip socket
2-6
display ip statistics
2-9
display ipv6 fib
IPv6 Configuration
1-1
display ipv6 host
IPv6 Configuration
1-3
display ipv6 interface
IPv6 Configuration
1-4
display ipv6 neighbors
IPv6 Configuration
1-6
display ipv6 neighbors count
IPv6 Configuration
1-7
display ipv6 pathmtu
IPv6 Configuration
1-8
display ipv6 routing-table
Routing Overview
1-14
display ipv6 routing-table acl
Routing Overview
1-15
display ipv6 routing-table ipv6-address
Routing Overview
1-16
display ipv6 routing-table ipv6-address1 ipv6-address2
Routing Overview
1-18
display ipv6 routing-table ipv6-prefix
Routing Overview
1-19
display ipv6 routing-table protocol
Routing Overview
1-19
display ipv6 routing-table statistics
Routing Overview
1-20
display ipv6 routing-table verbose
Routing Overview
1-21
display ipv6 socket
IPv6 Configuration
1-9
display ipv6 statistics
IPv6 Configuration
1-10
display lacp system-id
2-1
display link-aggregation interface
2-1
display link-aggregation summary
2-4
display link-aggregation verbose
2-5
display local-proxy-arp
ARP
2-2
display local-server statistics
AAA-RADIUS-HWTACACS
1-30
display local-user
AAA-RADIUS-HWTACACS
1-19
display logbuffer
Information Center
1-4
display logbuffer summary
Information Center
1-6
display loopback-detection
1-10
display mac-address
MAC Address Table Management
1-2
display mac-address aging-time
1-1
display mac-authentication
3-1
display memory
3-8
display mirroring-group
Port Mirroring
1-1
display mld-snooping group
Multicast Protocol
2-1
display mld-snooping statistics
Multicast Protocol
2-2
display multicast-vlan
Multicast Protocol
3-1
display ndp
Cluster
1-1
display nqa
NQA
1-6
display ntdp
Cluster
1-8
display ntdp device-list
Cluster
1-9
display ntp-service sessions
NTP
1-1
display ntp-service status
NTP
1-3
display ntp-service trace
NTP
1-4
display pki certificate
PKI
1-10
display pki certificate access-control-policy
PKI
1-11
display pki certificate attribute-group
PKI
1-12
display pki crl domain
PKI
1-13
display poe device
PoE-PoE Profile
1-3
display poe interface
PoE-PoE Profile
1-4
display poe interface power
PoE-PoE Profile
1-7
display poe pse
PoE-PoE Profile
1-9
display poe-profile
PoE-PoE Profile
1-11
display poe-profile interface
PoE-PoE Profile
1-13
display port
1-10
display port-group manual
1-11
display port-isolate group
3-1
display power
3-8
display proxy-arp
ARP
2-2
display qos lr interface
QoS
1-1
display qos map-table
QoS
4-1
display qos policy
QoS
2-4
display qos policy interface
QoS
2-5
display qos policy user-defined
QoS
6-1
display qos sp
QoS
3-1
display qos vlan-policy
QoS
5-1
display qos wrr interface
QoS
3-1
display radius
AAA-RADIUS-HWTACACS
1-31
display radius statistics
AAA-RADIUS-HWTACACS
1-33
display rip
IPv4 Routing
2-3
display rip database
IPv4 Routing
2-5
display rip interface
IPv4 Routing
2-6
display rip route
IPv4 Routing
2-7
display ripng
IPv6  Routing
2-3
display ripng database
IPv6  Routing
2-4
display ripng interface
IPv6  Routing
2-5
display ripng route
IPv6  Routing
2-6
display rmon alarm
SNMP-RMON
2-1
display rmon event
SNMP-RMON
2-2
display rmon eventlog
SNMP-RMON
2-3
display rmon history
SNMP-RMON
2-4
display rmon prialarm
SNMP-RMON
2-6
display rmon statistics
SNMP-RMON
2-7
display route-policy
IPv4 Routing
3-5
IPv6  Routing
3-5
display rsa local-key-pair public
1-1
display rsa peer-public-key
1-2
display saved-configuration
1-12
display schedule reboot
3-9
display sftp client source
1-4
display snmp-agent
SNMP-RMON
1-1
display snmp-agent community
SNMP-RMON
1-1
display snmp-agent group
SNMP-RMON
1-3
display snmp-agent mib-view
SNMP-RMON
1-4
display snmp-agent statistics
SNMP-RMON
1-6
display snmp-agent sys-info
SNMP-RMON
1-8
display snmp-agent usm-user
SNMP-RMON
1-8
display ssh client source
1-4
display ssh server
1-5
display ssh server-info
1-6
display ssh user-information
1-7
display ssl client-policy
SSL-HTTPS
1-3
display ssl server-policy
SSL-HTTPS
1-4
display startup
1-15
display stop-accounting-buffer
AAA-RADIUS-HWTACACS
1-34
AAA-RADIUS-HWTACACS
1-59
display stp
MSTP
1-3
display stp region-configuration
MSTP
1-5
display tcp ipv6 statistics
IPv6 Configuration
1-14
display tcp ipv6 status
IPv6 Configuration
1-17
display tcp statistics
2-11
display tcp status
2-15
display this
1-16
display time-range
ACL
1-1
display traffic behavior
QoS
2-6
display traffic behavior user-defined
QoS
6-2
display traffic classifier
QoS
2-7
display trapbuffer
Information Center
1-7
display udp ipv6 statistics
IPv6 Configuration
1-18
display udp statistics
2-15
display udp-helper server
UDP Helper
1-1
display user-interface
Login
1-5
display users
Login
1-7
display version
1-17
display vlan
VLAN
1-3
display voice vlan oui
VLAN
2-1
display voice vlan state
VLAN
2-2
display web users
Login
1-8
dns domain
DNS
1-5
dns resolve
DNS
1-6
dns server
DNS
1-6
dns server ipv6
IPv6 Configuration
1-19
domain
AAA-RADIUS-HWTACACS
1-20
dot1x
1-4
dot1x authentication-method
1-5
dot1x guest-vlan
1-6
dot1x handshake
1-7
dot1x max-user
1-8
dot1x port-control
1-9
dot1x port-method
1-10
dot1x quiet-period
1-11
dot1x retry
1-11
dot1x timer
1-12
duplex
1-13
E
enable snmp trap updown
SNMP-RMON
1-9
escape-key
Login
1-9
execute
1-4
exit
1-34
F
fast-leave
Multicast Protocol
1-3
fast-leave
Multicast Protocol
2-3
file prompt
1-5
filename
NQA
1-10
filter
QoS
2-8
filter-policy export
IPv4 Routing
2-9
IPv6  Routing
2-7
filter-policy import
IPv4 Routing
2-10
IPv6  Routing
2-8
fixdisk
1-5
flow-control
Login
1-10
flow-control
1-13
flow-interval
1-14
format
1-6
fqdn
PKI
1-14
free user-interface
Login
1-11
free web-users
Login
2-2
frequency
NQA
1-11
ftp
2-9
ftp ipv6
2-10
ftp ipv6
IPv6 Configuration
2-1
ftp server enable
2-2
ftp timeout
2-2
ftp update
2-3
ftp-operation
NQA
1-12
ftp-server
Cluster
1-34
G
garp timer
VLAN
3-2
garp timer leaveall
VLAN
3-4
get
2-11
get
1-34
gratuitous-arp-learning enable
ARP
1-7
gratuitous-arp-sending enable
ARP
1-7
group-member
1-15
group-policy
Multicast Protocol
1-4
group-policy
Multicast Protocol
2-4
gvrp
VLAN
3-7
gvrp registration
VLAN
3-8
H
habp enable
2-3
habp server vlan
2-4
habp timer
2-5
handshake timeout
SSL-HTTPS
1-5
header
Login
1-12
header
1-18
help
1-35
history-command max-size
Login
1-14
history-records
NQA
1-12
holdtime
Cluster
1-35
host-aging-time
Multicast Protocol
1-5
host-aging-time
Multicast Protocol
2-5
host-route
IPv4 Routing
2-11
hotkey
1-20
http-operation
NQA
1-13
http-string
NQA
1-14
hwtacacs nas-ip
AAA-RADIUS-HWTACACS
1-60
hwtacacs scheme
AAA-RADIUS-HWTACACS
1-61
I
idle-cut
AAA-RADIUS-HWTACACS
1-21
idle-timeout
Login
1-15
if-match
QoS
2-9
if-match acl
IPv4 Routing
3-6
if-match cost
IPv4 Routing
3-7
if-match cost
IPv6  Routing
3-6
if-match interface
IPv4 Routing
3-7
if-match interface
IPv6  Routing
3-7
if-match ip
IPv4 Routing
3-8
if-match ip-prefix
IPv4 Routing
3-9
if-match ipv6
IPv6  Routing
3-8
if-match tag
IPv4 Routing
3-10
if-match tag
IPv6  Routing
3-9
igmp-snooping
Multicast Protocol
1-6
igmp-snooping drop-unknown
Multicast Protocol
1-7
igmp-snooping enable
Multicast Protocol
1-7
igmp-snooping fast-leave
Multicast Protocol
1-8
igmp-snooping general-query source-ip
Multicast Protocol
1-9
igmp-snooping group-limit
Multicast Protocol
1-10
igmp-snooping group-policy
Multicast Protocol
1-11
igmp-snooping host-aging-time
Multicast Protocol
1-12
igmp-snooping host-join
Multicast Protocol
1-13
igmp-snooping last-member-query-interval
Multicast Protocol
1-14
igmp-snooping max-response-time
Multicast Protocol
1-15
igmp-snooping overflow-replace
Multicast Protocol
1-16
igmp-snooping querier
Multicast Protocol
1-17
igmp-snooping query-interval
Multicast Protocol
1-17
igmp-snooping router-aging-time
Multicast Protocol
1-18
igmp-snooping source-deny
Multicast Protocol
1-19
igmp-snooping special-query source-ip
Multicast Protocol
1-19
igmp-snooping static-group
Multicast Protocol
1-20
igmp-snooping static-router-port
Multicast Protocol
1-22
igmp-snooping version
Multicast Protocol
1-23
import-route
IPv4 Routing
2-12
import-route
IPv6  Routing
2-9
info-center channel name
Information Center
1-9
info-center console channel
Information Center
1-9
info-center enable
Information Center
1-10
info-center logbuffer
Information Center
1-11
info-center loghost
Information Center
1-12
info-center loghost source
Information Center
1-13
info-center monitor channel
Information Center
1-13
info-center snmp channel
Information Center
1-14
info-center source
Information Center
1-15
info-center synchronous
Information Center
1-16
info-center timestamp
Information Center
1-17
info-center timestamp loghost
Information Center
1-18
info-center trapbuffer
Information Center
1-19
instance
MSTP
1-6
interface
1-16
VLAN
1-4
ip
PKI
1-15
ip address
VLAN
1-5
ip address
1-4
ip address bootp-alloc
DHCP
4-2
ip address dhcp-alloc
DHCP
3-3
ip forward-broadcast (system view)
2-17
ip forward-broadcast (VLAN interface view)
2-17
ip host
DNS
1-7
ip http acl
Login
2-2
ip http enable
Login
1-16
ip https acl
SSL-HTTPS
2-2
ip https certificate access-control-policy
SSL-HTTPS
2-2
ip https enable
SSL-HTTPS
2-3
ip https ssl-server-policy
SSL-HTTPS
2-4
ip ip-prefix
IPv4 Routing
3-10
ip ipv6-prefix
IPv6  Routing
3-9
ip redirects enable
2-18
ip route-static
IPv4 Routing
1-2
ip route-static default-preference
IPv4 Routing
1-3
ip ttl-expires enable
2-19
ip unreachables enable
2-19
ip-pool
Cluster
1-36
ipv6
IPv6 Configuration
1-20
ipv6 address
IPv6 Configuration
1-20
ipv6 address auto link-local
IPv6 Configuration
1-21
ipv6 address eui-64
IPv6 Configuration
1-22
ipv6 address link-local
IPv6 Configuration
1-23
ipv6 host
IPv6 Configuration
1-23
ipv6 icmp-error
IPv6 Configuration
1-24
IPv6 Configuration
1-25
ipv6 nd autoconfig other-flag
IPv6 Configuration
1-25
ipv6 nd dad attempts
IPv6 Configuration
1-26
ipv6 nd hop-limit
IPv6 Configuration
1-27
ipv6 nd ns retrans-timer
IPv6 Configuration
1-27
ipv6 nd nud reachable-time
IPv6 Configuration
1-28
ipv6 nd ra halt
IPv6 Configuration
1-29
ipv6 nd ra interval
IPv6 Configuration
1-29
ipv6 nd ra prefix
IPv6 Configuration
1-30
ipv6 nd ra router-lifetime
IPv6 Configuration
1-31
ipv6 neighbor
IPv6 Configuration
1-32
ipv6 neighbors max-learning-num
IPv6 Configuration
1-33
ipv6 pathmtu
IPv6 Configuration
1-33
ipv6 pathmtu age
IPv6 Configuration
1-34
ipv6 route-static
IPv6  Routing
1-2
J
jitter-interval
NQA
1-15
jitter-packetnum
NQA
1-15
jumboframe enable
1-16
K
key
AAA-RADIUS-HWTACACS
1-35
key
AAA-RADIUS-HWTACACS
1-61
L
lacp enable
2-8
lacp port-priority
2-8
lacp system-priority
2-9
language-mode
1-22
Multicast Protocol
1-23
Multicast Protocol
2-6
lcd
2-12
ldap-server
PKI
1-16
level
AAA-RADIUS-HWTACACS
1-22
link-aggregation group description
2-9
link-aggregation group mode
2-10
locality
PKI
1-16
local-proxy-arp enable
ARP
2-1
local-server
AAA-RADIUS-HWTACACS
1-37
local-user
AAA-RADIUS-HWTACACS
1-23
local-user password-display-mode
AAA-RADIUS-HWTACACS
1-24
lock
Login
1-16
logging-host
Cluster
1-37
loopback
1-17
loopback-detection control enable
1-18
loopback-detection enable
1-19
loopback-detection interval-time
1-20
loopback-detection per-vlan enable
1-21
ls
2-12
ls
1-35
M
mac-address (Ethernet port view)
1-4
mac-address (System view)
1-3
mac-address max-mac-count
1-5
mac-address timer
1-6
mac-authentication
3-2
mac-authentication domain
3-4
mac-authentication timer
3-4
management-vlan
Cluster
1-38
max-response-time
Multicast Protocol
1-24
max-response-time
Multicast Protocol
2-7
mdi
1-21
mirroring-group
Port Mirroring
1-2
mirroring-group mirroring-port
Port Mirroring
1-3
mirroring-group monitor-port
Port Mirroring
1-4
mirroring-port
Port Mirroring
1-5
mirror-to interface
QoS
6-3
mkdir
1-6
mkdir
2-14
mkdir
1-36
mld-snooping
Multicast Protocol
2-7
mld-snooping drop-unknown
Multicast Protocol
2-8
mld-snooping enable
Multicast Protocol
2-9
mld-snooping fast-leave
Multicast Protocol
2-9
mld-snooping general-query source-ip
Multicast Protocol
2-10
mld-snooping group-limit
Multicast Protocol
2-11
mld-snooping group-policy
Multicast Protocol
2-12
mld-snooping host-aging-time
Multicast Protocol
2-13
mld-snooping host-join
Multicast Protocol
2-14
mld-snooping last-member-query-interval
Multicast Protocol
2-15
mld-snooping max-response-time
Multicast Protocol
2-16
mld-snooping overflow-replace
Multicast Protocol
2-17
mld-snooping querier
Multicast Protocol
2-18
mld-snooping query-interval
Multicast Protocol
2-18
mld-snooping report-aggregation
Multicast Protocol
2-19
mld-snooping router-aging-time
Multicast Protocol
2-20
mld-snooping source-deny
Multicast Protocol
2-20
mld-snooping special-query source-ip
Multicast Protocol
2-21
mld-snooping static-group
Multicast Protocol
2-22
mld-snooping static-router-port
Multicast Protocol
2-23
monitor-port
Port Mirroring
1-5
more
1-7
move
1-8
multicast-suppression
1-22
multicast-vlan enable
Multicast Protocol
3-1
multicast-vlan subvlan
Multicast Protocol
3-2
N
nas-ip
AAA-RADIUS-HWTACACS
1-38
nas-ip
AAA-RADIUS-HWTACACS
1-62
ndp enable
Cluster
1-5
ndp timer aging
Cluster
1-6
ndp timer hello
Cluster
1-6
network
IPv4 Routing
2-13
nm-interface Vlan-interface
Cluster
1-38
nqa
NQA
1-16
nqa-agent enable
NQA
1-17
nqa-agent max-requests
NQA
1-17
nqa-server enable
NQA
1-29
nqa-server tcpconnect
NQA
1-29
nqa-server udpecho
NQA
1-30
ntdp enable
Cluster
1-11
ntdp explore
Cluster
1-12
ntdp hop
Cluster
1-12
ntdp timer
Cluster
1-13
ntdp timer hop-delay
Cluster
1-14
ntdp timer port-delay
Cluster
1-15
ntp-service access
NTP
1-5
ntp-service authentication enable
NTP
1-6
ntp-service authentication-keyid
NTP
1-7
ntp-service broadcast-client
NTP
1-8
ntp-service broadcast-server
NTP
1-9
ntp-service in-interface disable
NTP
1-13
ntp-service max-dynamic-sessions
NTP
1-9
ntp-service multicast-client
NTP
1-10
ntp-service multicast-server
NTP
1-11
ntp-service reliable authentication-keyid
NTP
1-11
ntp-service source-interface
NTP
1-12
ntp-service unicast-peer
NTP
1-14
ntp-service unicast-server
NTP
1-15
O
open
2-14
open ipv6
2-15
open ipv6
IPv6 Configuration
2-2
organization
PKI
1-17
organizational-unit
PKI
1-18
overflow-replace
Multicast Protocol
1-25
overflow-replace
Multicast Protocol
2-24
P
parity
Login
1-17
passive
2-16
password
AAA-RADIUS-HWTACACS
1-25
password
NQA
1-18
peer
IPv4 Routing
2-13
peer-public-key end
1-8
ping
2-1
ping ipv6
IPv6 Configuration
2-3
PKI
1-18
PKI
1-19
pki delete-certificate
PKI
1-20
pki domain
PKI
1-20
pki entity
PKI
1-21
pki import-certificate
PKI
1-21
pki request-certificate domain
PKI
1-22
pki retrieval-certificate
PKI
1-23
pki retrieval-crl domain
PKI
1-24
pki validate-certificate
PKI
1-24
pki-domain
SSL-HTTPS
1-6
poe disconnect
PoE-PoE Profile
1-14
poe enable
PoE-PoE Profile
1-15
poe legacy enable
PoE-PoE Profile
1-16
poe max-power
PoE-PoE Profile
1-17
poe mode
PoE-PoE Profile
1-18
poe pd-description
PoE-PoE Profile
1-19
poe pd-policy priority
PoE-PoE Profile
1-19
poe priority
PoE-PoE Profile
1-20
poe update
PoE-PoE Profile
1-21
poe utilization-threshold
PoE-PoE Profile
1-22
poe-profile
PoE-PoE Profile
1-22
port
VLAN
1-8
port access vlan
VLAN
1-9
port hybrid pvid vlan
VLAN
1-10
port hybrid vlan
VLAN
1-11
port link-aggregation group
2-11
port link-type
VLAN
1-12
port link-type
1-24
port trunk permit vlan
VLAN
1-13
port trunk pvid vlan
VLAN
1-14
port-group
1-23
port-group aggregation
2-12
port-isolate enable
3-2
prefer-cipher
SSL-HTTPS
1-6
preference
IPv4 Routing
2-14
preference
IPv6  Routing
2-10
primary accounting
AAA-RADIUS-HWTACACS
1-39
primary accounting
AAA-RADIUS-HWTACACS
1-63
primary authentication
AAA-RADIUS-HWTACACS
1-40
AAA-RADIUS-HWTACACS
1-64
primary authorization
AAA-RADIUS-HWTACACS
1-65
probe-failtimes
NQA
1-19
protocol inbound
Login
1-18
protocol inbound
1-8
proxy-arp enable
ARP
2-1
public-key-code begin
1-9
public-key-code end
1-10
put
2-17
put
1-37
pwd
1-8
pwd
2-18
pwd
1-37
Q
qinq enable
QinQ-BPDU TUNNEL
1-1
qinq ethernet-type
QinQ-BPDU TUNNEL
1-2
qinq vid
QinQ-BPDU TUNNEL
1-2
qos apply policy
QoS
2-12
qos lr
QoS
1-2
qos map-table
QoS
4-2
qos policy
QoS
2-12
qos priority
QoS
4-2
qos sp
QoS
3-2
qos vlan-policy
QoS
5-3
qos wrr
QoS
3-3
1-23
2-18
1-38
R
radius nas-ip
AAA-RADIUS-HWTACACS
1-41
radius scheme
AAA-RADIUS-HWTACACS
1-42
raw-vlan-id inbound
QinQ-BPDU TUNNEL
1-3
reboot
3-9
reboot member
Cluster
1-39
redirect
QoS
2-13
region-name
MSTP
1-7
remark dot1p
QoS
2-14
remark dscp
QoS
2-15
remark ip-precedence
QoS
2-16
remark local-precedence
QoS
2-17
remotehelp
2-19
remove
1-38
rename
1-9
rename
1-39
reset acl counter
ACL
1-6
reset acl ipv6 counter
ACL
2-3
reset arp
ARP
1-6
reset counters interface
1-25
reset dhcp relay statistics
DHCP
1-16
reset dns dynamic-host
DNS
1-7
reset dns ipv6 dynamic-host
IPv6 Configuration
1-35
reset dot1x statistics
1-14
reset garp statistics
VLAN
3-4
reset hwtacacs statistics
AAA-RADIUS-HWTACACS
1-66
reset igmp-snooping group
Multicast Protocol
1-26
reset igmp-snooping statistics
Multicast Protocol
1-26
reset ip ip-prefix
IPv4 Routing
3-12
reset ip ipv6-prefix
IPv6  Routing
3-11
reset ip routing-table statistics protocol
Routing Overview
1-23
reset ip statistics
2-20
reset ipv6 neighbors
IPv6 Configuration
1-35
reset ipv6 pathmtu
IPv6 Configuration
1-36
reset ipv6 routing-table statistics protocol
Routing Overview
1-24
reset ipv6 statistics
IPv6 Configuration
1-36
reset lacp statistics
2-12
reset logbuffer
Information Center
1-20
reset mld-snooping group
Multicast Protocol
2-25
reset mld-snooping statistics
Multicast Protocol
2-26
reset ndp statistics
Cluster
1-7
reset qos vlan-policy
QoS
5-4
reset radius statistics
AAA-RADIUS-HWTACACS
1-43
reset recycle-bin
1-9
reset rip statistics
IPv4 Routing
2-15
reset saved-configuration
1-16
reset stop-accounting-buffer
AAA-RADIUS-HWTACACS
1-44
AAA-RADIUS-HWTACACS
1-66
reset stp
MSTP
1-8
reset tcp ipv6 statistics
IPv6 Configuration
1-37
reset tcp statistics
2-21
reset trapbuffer
Information Center
1-20
reset udp ipv6 statistics
IPv6 Configuration
1-37
reset udp statistics
2-21
reset udp-helper packet
UDP Helper
1-2
reset unused porttag
3-10
restore startup-configuration
1-17
retry
AAA-RADIUS-HWTACACS
1-45
retry realtime-accounting
AAA-RADIUS-HWTACACS
1-46
retry stop-accounting
AAA-RADIUS-HWTACACS
1-47
AAA-RADIUS-HWTACACS
1-67
return
1-23
revision-level
MSTP
1-8
rip
IPv4 Routing
2-15
rip authentication-mode
IPv4 Routing
2-16
rip input
IPv4 Routing
2-17
rip metricin
IPv4 Routing
2-18
rip metricout
IPv4 Routing
2-18
rip output
IPv4 Routing
2-19
rip poison-reverse
IPv4 Routing
2-20
rip split-horizon
IPv4 Routing
2-21
rip summary-address
IPv4 Routing
2-21
rip version
IPv4 Routing
2-22
ripng
IPv6  Routing
2-11
ripng default-route
IPv6  Routing
2-12
ripng enable
IPv6  Routing
2-13
ripng metricin
IPv6  Routing
2-13
ripng metricout
IPv6  Routing
2-14
ripng poison-reverse
IPv6  Routing
2-15
ripng split-horizon
IPv6  Routing
2-15
ripng summary-address
IPv6  Routing
2-16
rmdir
1-10
rmdir
2-19
rmdir
1-39
rmon alarm
SNMP-RMON
2-9
rmon event
SNMP-RMON
2-10
rmon history
SNMP-RMON
2-11
rmon prialarm
SNMP-RMON
2-12
rmon statistics
SNMP-RMON
2-14
root-certificate fingerprint
PKI
1-25
route-policy
IPv4 Routing
3-12
route-policy
IPv6  Routing
3-11
router-aging-time
Multicast Protocol
1-27
router-aging-time
Multicast Protocol
2-26
rsa local-key-pair create
1-11
rsa local-key-pair destroy
1-11
rsa local-key-pair export
1-12
rsa peer-public-key
1-13
rule
PKI
1-26
rule (advanced IPv4 ACL)
ACL
1-9
rule (advanced IPv6 ACL)
ACL
2-6
rule (basic IPv4 ACL)
ACL
1-7
rule (basic IPv6 ACL)
ACL
2-4
rule (Ethernet frame header ACL)
ACL
1-15
rule comment
ACL
1-17
rule comment
ACL
2-11
S
save
1-17
schedule reboot at
3-10
schedule reboot delay
3-12
screen-length
Login
1-19
secondary accounting
AAA-RADIUS-HWTACACS
1-48
AAA-RADIUS-HWTACACS
1-68
secondary authentication
AAA-RADIUS-HWTACACS
1-49
AAA-RADIUS-HWTACACS
1-69
secondary authorization
AAA-RADIUS-HWTACACS
1-70
self-service-url
AAA-RADIUS-HWTACACS
1-25
send
Login
1-20
sendpacket passroute
NQA
1-19
send-trap
NQA
1-20
server-type
AAA-RADIUS-HWTACACS
1-50
service-type
Login
1-21
service-type
AAA-RADIUS-HWTACACS
1-27
service-type ftp
AAA-RADIUS-HWTACACS
1-27
session
SSL-HTTPS
1-7
set authentication password
Login
1-22
sftp
1-14
sftp client ipv6 source
1-15
sftp client source
1-16
sftp ipv6
1-17
sftp server enable
1-18
sftp server idle-timeout
1-18
shell
Login
1-24
shutdown
VLAN
1-6
shutdown
1-26
silent-interface
IPv4 Routing
2-24
snmp-agent
SNMP-RMON
1-10
Login
2-3
SNMP-RMON
1-11
snmp-agent group
Login
2-4
snmp-agent group
SNMP-RMON
1-12
snmp-agent local-engineid
SNMP-RMON
1-13
snmp-agent mib-view
SNMP-RMON
1-14
snmp-agent packet max-size
SNMP-RMON
1-15
snmp-agent sys-info
SNMP-RMON
1-15
snmp-agent target-host
SNMP-RMON
1-16
snmp-agent trap enable
SNMP-RMON
1-17
snmp-agent trap life
SNMP-RMON
1-19
snmp-agent trap queue-size
SNMP-RMON
1-19
snmp-agent trap source
SNMP-RMON
1-20
snmp-agent usm-user
Login
2-5
snmp-agent usm-user
SNMP-RMON
1-21
snmp-host
Cluster
1-40
source-deny
Multicast Protocol
1-27
source-deny
Multicast Protocol
2-27
source-interface
NQA
1-21
source-ip
NQA
1-22
source-port
NQA
1-23
speed
Login
1-24
speed
1-26
ssh client authentication server
1-19
ssh client first-time enable
1-20
ssh client ipv6 source
1-20
ssh client source
1-21
ssh server authentication-retries
1-22
ssh server authentication-timeout
1-22
ssh server compatible-ssh1x enable
1-23
ssh server enable
1-24
ssh server rekey-interval
1-24
ssh user assign rsa-key
1-25
ssh user authentication-type
1-26
ssh user service-type
1-27
ssh2
1-28
ssh2 ipv6
1-29
ssl client-policy
SSL-HTTPS
1-8
ssl server-policy
SSL-HTTPS
1-9
startup saved-configuration
1-19
state
AAA-RADIUS-HWTACACS
1-28
state
AAA-RADIUS-HWTACACS
1-50
state
PKI
1-27
step
ACL
1-18
step
ACL
2-11
stop-accounting-buffer enable
AAA-RADIUS-HWTACACS
1-52
AAA-RADIUS-HWTACACS
1-70
stopbits
Login
1-25
stp
MSTP
1-9
stp bpdu-protection
MSTP
1-10
stp bridge-diameter
MSTP
1-11
stp compliance
MSTP
1-12
stp config-digest-snooping
MSTP
1-13
stp cost
MSTP
1-14
stp edged-port
MSTP
1-15
stp loop-protection
MSTP
1-16
stp max-hops
MSTP
1-16
stp mcheck
MSTP
1-17
stp mode
MSTP
1-19
stp no-agreement-check
MSTP
1-18
stp pathcost-standard
MSTP
1-19
stp point-to-point
MSTP
1-21
stp port priority
MSTP
1-22
stp priority
MSTP
1-23
MSTP
1-24
stp root primary
MSTP
1-25
stp root secondary
MSTP
1-26
stp root-protection
MSTP
1-27
stp tc-protection
MSTP
1-28
stp timer forward-delay
MSTP
1-29
stp timer hello
MSTP
1-30
stp timer max-age
MSTP
1-31
stp timer-factor
MSTP
1-32
stp transmit-limit
MSTP
1-33
summary
IPv4 Routing
2-25
super
1-24
super password
1-25
sysname
Login
1-26
sysname
1-26
1-27
T
tcp ipv6 timer fin-timeout
IPv6 Configuration
1-38
tcp ipv6 timer syn-timeout
IPv6 Configuration
1-38
tcp ipv6 window
IPv6 Configuration
1-39
tcp timer fin-timeout
2-21
tcp timer syn-timeout
2-22
tcp window
2-23
telnet
Login
1-27
telnet ipv6
IPv6 Configuration
2-4
terminal debugging
2-6
terminal debugging
Information Center
1-21
terminal logging
Information Center
1-21
terminal monitor
Information Center
1-22
terminal trapping
Information Center
1-23
terminal type
Login
1-28
test-enable
NQA
1-23
test-failtimes
NQA
1-24
test-type
NQA
1-25
tftp get
3-2
tftp ipv6
3-2
tftp ipv6
IPv6 Configuration
2-5
tftp put
3-3
tftp sget
3-4
tftp-server
Cluster
1-41
tftp-server acl
3-1
tftp-server ipv6 acl
IPv6 Configuration
2-6
timeout
NQA
1-25
timer
Cluster
1-42
timer quiet
AAA-RADIUS-HWTACACS
1-53
timer quiet
AAA-RADIUS-HWTACACS
1-71
timer realtime-accounting
AAA-RADIUS-HWTACACS
1-53
AAA-RADIUS-HWTACACS
1-72
timer response-timeout
AAA-RADIUS-HWTACACS
1-54
AAA-RADIUS-HWTACACS
1-73
time-range
ACL
1-2
timers
IPv4 Routing
2-26
timers
IPv6  Routing
2-17
topology accept
Cluster
1-42
topology restore-from
Cluster
1-43
topology save-to
Cluster
1-44
tos
NQA
1-26
tracert
2-3
tracert ipv6
IPv6 Configuration
2-7
traffic behavior
QoS
2-17
traffic classifier
QoS
2-18
ttl
NQA
1-27
U
udp-helper enable
UDP Helper
1-2
udp-helper port
UDP Helper
1-3
udp-helper server
UDP Helper
1-4
undelete
1-11
unicast-suppression
1-27
user
2-20
user privilege level
Login
1-29
user-interface
Login
1-28
username
NQA
1-28
user-name-format
AAA-RADIUS-HWTACACS
1-55
user-name-format
AAA-RADIUS-HWTACACS
1-74
V
validate-source-address
IPv4 Routing
2-27
verbose
2-21
version
IPv4 Routing
2-27
version
SSL-HTTPS
1-9
virtual-cable-test
1-28
vlan
VLAN
1-7
vlan-mapping modulo
MSTP
1-34
voice vlan
VLAN
2-3
voice vlan aging
VLAN
2-4
voice vlan enable
VLAN
2-4
voice vlan mac-address
VLAN
2-5
voice vlan mode auto
VLAN
2-7
voice vlan security enable
VLAN
2-7
W
X
Y
Z
