H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
17-ARP Command
17-ARP Command 69 KB
Chapter 1  ARP Configuration Commands
1.1  ARP Configuration Commands
1.1.1  arp check enable
arp check enable
undo arp check enable
View
Parameter
None
Use the arp check enable command to enable ARP entry check, preventing the device from learning multicast MAC addresses.
Use the undo arp check enable command to disable the function, allowing the device to add multicast MAC addresses into the ARP mapping table.
By default, ARP entry check is enabled.
Example
# Enable the device to add multicast MAC addresses into the ARP mapping table.
[Sysname] undo arp check enable
1.1.2  arp max-learning-num
arp max-learning-num number
undo arp max-learning-num
View
VLAN interface view
Parameter
number: Maximum number of dynamic ARP entries that an interface can learn,it ranges from 1 to 2048 and defaults to 2048.
Use the arp max-learning-num command to set the maximum number of dynamic ARP entries that an interface can learn.
Use the undo arp max-learning-num command to restore the default.
Example
# Specify Vlan-interface 40 to learn up to 500 dynamic ARP entries.
[Sysname] interface vlan-interface 40
[Sysname-Vlan-interface40]arp max-learning-num 500
1.1.3  arp static
arp static ip-address mac-address [ vlan-id interface-type interface-number ]
undo arp ip-address
View
Parameter
ip-address: IP address in an ARP entry.
mac-address: MAC address in an ARP entry, in the format H-H-H.
vlan-id: ID of a VLAN to which a static ARP entry belongs to, in the range 1 to 4094.
interface-type interface-number: Specifies a port by its type and number.
Use the arp static command to configure a static ARP entry in the ARP mapping table.
Use the undo arp command to remove an ARP entry.
Note that:
l           A static ARP entry is effective when the device works normally. However, when the VLAN to which an ARP entry of the device corresponds is deleted, the entry is deleted accordingly.
l           The vlan-id argument is used to configure ARP entries on the device and must be the ID of an existing VLAN. In addition, the Ethernet interfaces following the argument must belong to that VLAN.
Related command: reset arp, and display arp.
Example
# Bind the IP address 202.38.10.2 to the MAC address 00e0-fc01-0000 for GE1/0/2 of VLAN 10.
[Sysname] arp static 202.38.10.2 00e0-fc01-0000 10 GigabitEthernet1/0/2
# Bind the IP address 129.102.0.1 to the MAC address 00e0-fc01-0000.
[Sysname] arp static 129.102.0.1 00e0-fc01-0000
1.1.4  arp timer aging
arp timer aging aging-time
undo arp timer aging
View
Parameter
aging-time: Aging time for dynamic ARP entries in minutes. It ranges from 1 to 1,440 and defaults to 20.
Use the arp timer aging command to set aging time for dynamic ARP entries.
Use the undo arp timer aging command to restore the default.
Related command: display arp timer aging.
Example
# Set aging time for dynamic ARP entries to 10 minutes.
[Sysname] arp timer aging 10
1.1.5  display arp
display arp { { all | dynamic | static } | vlan vlan-id | interface interface-type interface-number } [ [| { begin | exclude | include } text ] | count ]
View
Parameter
all: Displays all ARP entries.
dynamic: Displays dynamic ARP entries.
static: Displays static ARP entries.
vlan-id: Displays the ARP entries of the specified VLAN. The VLAN ID ranges from 1 to 4094.
interface-type interface-number: Displays the ARP entries of the specified port.
|: Uses a regular expression to specify the ARP entries to be displayed.
begin: Displays ARP entries from the first one containing the specified string.
exclude: Displays the ARP entries that do not contain the specified string.
include: Displays the ARP entries containing the specified string.
text: A string for matching.
count: Displays the number of ARP entries.
Use the display arp command to display ARP entries in the ARP mapping table.
Related command: arp static, and reset arp.
Example
# Display the detailed information of all ARP entries.
<Sysname> display arp all
                Type: S-Static    D-Dynamic
IP Address       MAC Address     VLAN ID  Interface              Aging Type
20.1.1.1         00e0-fc00-0001  N/A      N/A                    N/A   S
193.1.1.70       00e0-fe50-6503  100      GE1/0/1                14    D
192.168.0.115    000d-88f7-9f7d  1        GE1/0/4                18    D
Table 1-1 Description on the fields of the display arp command
IP Address
MAC Address
VLAN ID
ID of the VLAN to which an ARP entry belongs
Interface to which an ARP entry belongs
Aging
Aging time for a dynamic ARP entry in minutes
ARP entry type: D stands for dynamic and S for static.
# Display the number of all ARP entries
<Sysname> display arp all count
Total Entry(ies): 4
1.1.6  display arp ip-address
display arp ip-address [ | { begin | exclude | include } text ]
View
Parameter
ip-address: Displays the ARP entry for the specified IP address.
begin: Displays the ARP entries from the first one containing the specified string.
Include: Displays the ARP entries that contain the specified string.
text: A character string.
Use the display arp ip-address command to display the ARP entry for a specified IP address.
Example
# Display the corresponding ARP entry for the IP address 20.1.1.1.
<Sysname> display arp 20.1.1.1
1.1.7  display arp timer aging
View
Parameter
None
Use the display arp timer aging command to display the aging time for dynamic ARP entries.
Related command: arp timer aging.
Example
# Display the aging time for dynamic ARP entries.
<Sysname> display arp timer aging
 Current ARP aging time is 10 minute(s)
1.1.8  reset arp
reset arp { all | dynamic | static | interface interface-type interface-number }
View
Parameter
all: Clears all ARP entries.
dynamic: Clears all dynamic ARP entries.
static: Clears all static ARP entries.
interface interface-type interface-number: Clears the ARP entries for the specified port.
Use the reset arp command to clear ARP entries from the ARP mapping table.
With interface interface-type interface-number specified, the command clears only dynamic entries for the port.
Related command: arp static and display arp.
Example
# Clear all static ARP entries.
<Sysname> reset arp static
1.2  Gratuitous ARP Configuration Commands
1.2.1  gratuitous-arp-sending enable
undo gratuitous-arp-sending enable
View
Parameter
None
Use the gratuitous-arp-sending enable command to enable a device to send gratuitous ARP packets.
Use the undo gratuitous-arp-sending enable command to disable a device from sending gratuitous ARP packets.
By default, a device cannot send gratuitous ARP packets.
Related command: gratuitous-arp-learning enable.
Example
# Disable a device from sending gratuitous ARP packets
[Sysname] undo gratuitous-arp-sending enable
1.2.2  gratuitous-arp-learning enable
undo gratuitous-arp-learning enable
View
Parameter
None
Use the gratuitous-arp-learning enable command to enable the gratuitous ARP packet learning function.
Use the undo gratuitous-arp-learning enable command to disable the function.
By default, the function is disabled.
Example
# Enable the gratuitous ARP packet learning function.
[Sysname] gratuitous-arp-learning enable
Chapter 2  Proxy ARP Configuration Commands
2.1  Proxy ARP Configuration Commands
2.1.1  proxy-arp enable
proxy-arp enable
undo proxy-arp enable
View
VLAN interface view
Parameter
None
Use the proxy-arp enable command to enable proxy ARP.
Use the undo proxy-arp enable command to disable proxy ARP.
Related command: display proxy-arp.
Example
# Enable proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] proxy-arp enable
2.1.2  local-proxy-arp enable
undo local-proxy-arp enable
View
VLAN interface view
Parameter
None
Use the local-proxy-arp enable command to enable local proxy ARP.
Use the undo local-proxy-arp enable command to disable local proxy ARP.
Related command: display local-proxy-arp.
Example
# Enable local proxy ARP on VLAN-interface 2.
[Sysname] interface Vlan-interface 2
[Sysname-Vlan-interface2] local-proxy-arp enable
2.1.3  display proxy-arp
display proxy-arp [ interface vlan-interface vlan-id ]
View
Parameter
vlan-id: Specifies ID of VLAN.
Use the display proxy-arp command to display the proxy ARP status.
Related command: proxy-arp enable.
Example
# Display the proxy ARP status on Vlan-interface2.
<Sysname> display proxy-arp interface Vlan-interface2
Interface Ethernet Vlan-interface2
 Proxy ARP status: disabled
2.1.4  display local-proxy-arp
display local-proxy-arp [ interface vlan-interface vlan-id ]
View
Parameter
Use the display local-proxy-arp command to display the status of the local proxy ARP.
Related command: local-proxy-arp enable.
Example
# Display the status of the local proxy ARP on VLAN-interface 2.
<Sysname> display local-proxy-arp interface vlan-interface 2
Interface Vlan-interface2
 Local Proxy ARP status: enabled
