H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
24-NTP Command
24-NTP Command 144 KB
Chapter 1  NTP Configuration Commands
&  Note:
For H3C S5500-SI series Ethernet switches, local clock cannot serve as NTP reference clock. Therefore, any switch mentioned in this document for setting local clock as reference clock is not an H3C S5500-SI switch.
1.1  NTP Configuration Commands
1.1.1  display ntp-service sessions
display ntp-service sessions [ verbose ]
View
Parameter
verbose: Displays the detailed information of all NTP sessions.
Use the display ntp-service sessions command to view the information of all NTP sessions. Without the verbose keyword, this command will display only the brief information of all NTP service sessions.
Example
# View the brief information of NTP service sessions
<Sysname> display ntp-service sessions
        source        reference      stra  reach  poll  now  offset  delay  disper
[12345] 10.1.1.2    127.127.1.0       3     377    64   178     0.0   40.1    22.8
note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured Total associations :  1
Table 1-1 Description on the fields of the display ntp-service sessions command
source
IP address of the clock source
reference
Reference clock ID of the clock source
If the reference clock is the local clock, the value of this field is related to the value of the stra field: When the value of the stra field is 0 or 1, this field will be “LOCL”; when the stra field has another value, this filed will be the IP address of the local clock
If the reference clock is the clock of another device on the network, the value of this field will be the IP address of that device.
stra
Stratum level of the clock source
reach
Reachability count of the clock source. 0 indicates that the clock source in unreachable
poll
Poll interval, namely the maximum interval between successive NTP messages.
now
The length of time in minutes from when the last NTP message was received or when the local clock was last updated to the current time
offset
The offset of the system clock relative to the reference clock, in milliseconds
delay
the roundtrip delay from the local device to the clock source, in milliseconds
disper
The maximum error of the local clock relative to the reference source.
[12345]
1: Clock source selected by the system, namely the current reference source, with a system clock stratum level of 15
2: Stratum level of this system source is 15
3: This clock source has passed the clock selection process
4: This clock source is a candidate clock source
5: This clock source was created by a configuration command
Total associations
Total number of associations
&  Note:
When a device is working in the NTP broadcast/multicast server mode, the display ntp-service sessions command executed on the device will not display the NTP session information corresponding to the broadcast/multicast server, but the sessions will be counted in the total number of associations.
1.1.2  display ntp-service status
View
Parameter
None
Use the display ntp-service status command to view the NTP service status information.
Example
# View the NTP service status information.
<Sysname> display ntp-service status
 Clock status: unsynchronized
 Clock stratum: 16
 Reference clock ID: none
 Nominal frequency: 100.0000 Hz
 Actual frequency: 100.0000 Hz
 Clock precision: 2^18
 Clock offset: 0.0000 ms
 Root delay: 0.00 ms
 Root dispersion: 0.00 ms
 Peer dispersion: 0.00 ms
 Reference time: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
Table 1-2 Description on the fields of the display ntp-service status command
Clock status
Status of the system clock
Clock stratum
Stratum level of the local clock
Reference clock ID
After the system clock is synchronized to a remote time server or a local reference source, this field indicates the address of the remote time server or the identifier of the local clock source (when the local clock has a stratum level of 1, the value of this field is “LOCL”; when the local clock has another value, the value of this filed is the IP address of the local clock)
Nominal frequency
The nominal frequency of the local system hardware clock
Actual frequency
The actual frequency of the local system hardware clock
Clock precision
The precision of the system clock.
Clock offset
The offset of the system clock relative to the reference source
Root delay
The roundtrip delay from the local device to the primary reference source
Root dispersion
The maximum error of the system clock relative to the primary reference source.
Peer dispersion
The maximum error of the system clock relative to the reference source
Reference time
Reference timestamp
1.1.3  display ntp-service trace
View
Parameter
None
Use the display ntp-service trace command view the brief information of each NTP server along the NTP server chain from the local device back to the primary reference source.
The display ntp-service trace command is available only if the local device can ping through all the devices on the NTP server chain; otherwise, this command will fail to display all the NTP servers on the NTP chain due to timeout.
Example
# Display the brief information of each NTP server from the local device back to the primary reference source.
<Sysname> display ntp-service trace
 server 127.0.0.1,stratum 2, offset -0.013500, synch distance 0.03154
 server 133.1.1.1,stratum 1, offset -0.506500, synch distance 0.03429
 refid LOCL
The information above shows an NTP server chain for the server 127.0.0.1: The server 127.0.0.1 is synchronized to the server 133.1.1.1 and the server 133.1.1.1 is synchronized to the local clock source.
Table 1-3 Description on the fields of the display ntp-service trace command
server
IP address of the NTP server
stratum
The stratum level of the corresponding system clock
offset
The clock offset relative to the upper-level clock
synch distance
The synchronization distance relative to the upper-level clock
refid
Identifier of the primary reference source. When the stratum level of the primary reference clock is 0, it is displayed as LOCL; otherwise, it is displayed as the IP address of the primary reference clock.
1.1.4  ntp-service access
ntp-service access { peer | query | server | synchronization } acl-number
undo ntp-service access { peer | query | server | synchronization }
View
Parameter
peer: Specifies to permit full access.
query: Specifies to permit control query.
server: Specifies to permit server access and query.
synchronization: Specifies to permit server access only.
acl-number: ACL number, in the range of 2000 to 2999
Use the ntp-service access command to configure the NTP service access-control right to the local device.
Use the undo ntp-service access command to remove the configured NTP service access-control right to the local device.
By default, the local NTP service access-control right is set to peer.
From the highest NTP service access-control right to the lowest one are peer, server, synchronization, and query. When a device receives an NTP request, it will perform an access-control right match and will use the first matched right.
&  Note:
l      The ntp-service access command provides only a minimum degree of security protection. A more secure method is identity authentication.
l      Before specifying an ACL number in the ntp-service access command, make sure you have already created and configured this ACL.
Example
# Configure devices on the subnet 10.10.0.0/16 to have the full access right to the local device.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ntp-service access peer 2001
1.1.5  ntp-service authentication enable
undo ntp-service authentication enable
View
Parameter
None
Use the ntp-service authentication enable command to enable NTP authentication.
Use the undo ntp-service authentication enable command to disable NTP authentication.
By default, NTP authentication is disabled.
Example
# Enable NTP authentication.
[Sysname] ntp-service authentication enable
1.1.6  ntp-service authentication-keyid
ntp-service authentication-keyid keyid authentication-mode md5 value
undo ntp-service authentication-keyid keyid
View
Parameter
keyid: Authentication key ID, in the range of 1 to 4294967295.
authentication-mode md5: Specifies to use the MD5 algorithm for key authentication.
value: Authentication key, a string of 1 to 32 characters.
Use the ntp-service authentication-keyid command to set the NTP authentication key.
Use the undo ntp-service authentication-keyid command to remove the set NTP authentication key.
By default, no NTP authentication key is set.
  Caution:
l      Presently H3C S5500-SI Series Ethernet Switches support only the MD5 algorithm for key authentication.
l      You can set a maximum of 1,024 keys for each device.
Example
# Set an MD5 authentication key, with the key ID of 10 and key value of “BetterKey”.
[Sysname] ntp-service authentication-keyid 10 authentication-mode md5 BetterKey
1.1.7  ntp-service broadcast-client
undo ntp-service broadcast-client
View
Interface view
Parameter
None
Use the ntp-service broadcast-client command to configure the device to work in the NTP broadcast client mode.
Use the undo ntp-service broadcast-client command to remove the device as an NTP broadcast client.
Example
# Configure the device to work in the broadcast client mode and receive NTP broadcast messages on VLAN interface 1.
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] ntp-service broadcast-client
1.1.8  ntp-service broadcast-server
undo ntp-service broadcast-server
View
Interface view
Parameter
authentication-keyid keyid: Specifies the key ID to be used for sending broadcast messages to broadcast clients, where keyid is in the range of 1 to 4294967295. This parameter is not meaningful if authentication is not required.
version number: Specifies the NTP version, where number is in the range of 1 to 3 and defaults to 3.
Use the ntp-service broadcast-server command to configure the device to work in the NTP broadcast server mode.
Use the undo ntp-service broadcast-server command to remove the device as an NTP broadcast server.
Example
# Configure the device to work in the broadcast server mode and send NTP broadcast messages on VLAN interface 1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service broadcast-server authentication-keyid 4 version 3
1.1.9  ntp-service max-dynamic-sessions
undo ntp-service max-dynamic-sessions
View
Parameter
number: Maximum number of dynamic NTP sessions to be set up, in the range of 0 to 100.
Use the ntp-service max-dynamic-sessions command to set the maximum number of dynamic NTP sessions.
Use the undo ntp-service max-dynamic-sessions command to restore the maximum number of dynamic NTP sessions to the system default.
By default, the number is 100.
Example
# Set the maximum number of dynamic NTP sessions to 50.
[Sysname] ntp-service max-dynamic-sessions 50
1.1.10  ntp-service multicast-client
undo ntp-service multicast-client [ ip-address ]
View
Interface view
Parameter
ip-address: Multicast IP address.
Use the ntp-service multicast-client command to configure the device to work in the NTP multicast client mode.
Use the undo ntp-service multicast-client command to remove the device as an NTP multicast client.
The multicast address defaults to 224.0.1.1.
Example
# Configure the device to work in the multicast client mode and receive NTP multicast messages on VLAN 1, and set the multicast address to 224.0.1.1.
[Sysname-Vlan-interface1] ntp-service multicast-client 224.0.1.1
1.1.11  ntp-service multicast-server
undo ntp-service multicast-server [ ip-address ]
View
Interface view
Parameter
ip-address: Multicast IP address, defaulting to 224.0.1.1.
authentication-keyid keyid: Specifies the key ID to be used for sending multicast messages to multicast clients, where keyid is in the range of 1 to 4294967295. This parameter is not meaningful if authentication is not required.
ttl ttl-number: Specifies the TTL of NTP multicast messages, where ttl-number is in the range of 1 to 255 and defaults to 16.
Use the ntp-service multicast-server command to configure the device to work in the NTP multicast server mode.
Use the undo ntp-service multicast-server command to remove the device as an NTP multicast server.
Example
# Configure the device to work in the multicast server mode and send NTP multicast messages on VLAN interface 1 to the multicast address 224.0.1.1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service multicast-server 224.0.1.1 version 3 authentication-keyid 4
1.1.12  ntp-service reliable authentication-keyid
undo ntp-service reliable authentication-keyid keyid
View
Parameter
keyid: Authentication key number, in the range of 1 to 4294967295.
Use the ntp-service reliable authentication-keyid command to specify that the created authentication key is a trusted key. When NTP authentication enabled, a client can be synchronized only to a server that can provide a trusted authentication key.
Use the undo ntp-service reliable authentication-keyid command to remove an authentication key as a trusted key.
No authentication key is configured to be trusted by default.
Example
# Enable NTP authentication, specify to use MD5 encryption algorithm, with the key ID of 37 and key value of “BetterKey”, and specify that this key is a trusted key.
[Sysname] ntp-service authentication-keyid 37 authentication-mode md5 BetterKey
[Sysname] ntp-service reliable authentication-keyid 37
1.1.13  ntp-service source-interface
ntp-service source-interface interface-type interface-number
undo ntp-service source-interface
View
Parameter
interface-type interface-number: Type and number of the interface to be used for sending NTP messages.
Use the ntp-service source-interface command to specify an interface for sending NTP messages.
Use the undo ntp-service source-interface command to remove the configured interface for sending NTP messages.
You can use this command to specify a particular interface for sending all NTP messages. In this way, the IP address of this interface will be used as the source address of all outgoing NTP messages, and NTP response messages from other devices will use the IP address of this interface (instead of any other interface) as the destination address.
Example
# Specify that all NTP messages are to be sent out from VLAN interface 1.
[Sysname] ntp-service source-interface Vlan-interface 1
1.1.14  ntp-service in-interface disable
undo ntp-service in-interface disable
View
Interface view
Parameter
None
Use the ntp-service in-interface disable command to disable an interface from receiving NTP messages.
Use the undo ntp-service in-interface disable command to enable an interface to receive NTP messages.
By default, all interfaces are enabled to receive NTP messages.
Example
# Disable VLAN interface 1 from receiving NTP messages.
[Sysname-Vlan-interface1] ntp-service in-interface disable
1.1.15  ntp-service unicast-peer
ntp-service unicast-peer { ip-address | peer-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-peer { ip-address | peer-name }
View
Parameter
ip-address: IP address of the symmetric-passive peer. It must be a host address, rather than a broadcast address, a multicast address or the IP address of the local clock.
peer-name: Host name of the symmetric-passive peer, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the peer, where keyid is in the range of 1 to 4294967295.
priority: Specifies the peer designated by ip-address or peer-name as the first choice.
source-interface interface-type interface-number: Specifies an interface for sending NTP messages. In an NTP message the local device sends to its peer, the source IP address is the IP address of this interface.
Use the ntp-service unicast-peer command to designate a symmetric-passive peer for the device.
Use the undo ntp-service unicast-peer command to remove the symmetric-passive peer designated for the device.
No symmetric-passive peer is designated for the device by default.
&  Note:
The symmetric-active and symmetric-passive peers must run the same version of NTP; otherwise, time synchronization may fail.
Example
# Designate the device with the IP address of 10.1.1.1 as the symmetric-passive peer of the device, and configure the device to run NTP version 3, and send NTP messages through VLAN interface 1.
[Sysname] ntp-service unicast-peer 10.1.1.1 version 3 source-interface Vlan-interface 1
1.1.16  ntp-service unicast-server
ntp-service unicast-server { ip-address | server-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number  ] *
undo ntp-service unicast-server { ip-address | server-name }
View
Parameter
ip-address: IP address of the NTP server. It must be a host address, rather than a broadcast address, a multicast address or the IP address of the local clock.
server-name: Host name of the NTP server, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the NTP server, where keyid is in the range of 1 to 4294967295.
priority: Specifies this NTP server as the first choice.
source-interface interface-type interface-number: Specifies an interface for sending NTP messages. In an NTP message the local device sends to the NTP server, the source IP address is the IP address of this interface.
Use the ntp-service unicast-server command to designate an NTP server for the device.
Use the undo ntp-service unicast-server command to remove an NTP server designated for the device.
No NTP server is designated for the device by default.
&  Note:
The client and server must run the same version of NTP; otherwise, time synchronization may fail.
Example
# Designate the device with the IP address of as 10.1.1.1 an NTP server for the device.
[Sysname] ntp-service unicast-server 10.1.1.1 version 3
