H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
07-MAC Address Table Management Command
07-MAC Address Table Management Command 50 KB
Chapter 1  MAC Address Table Management Commands
1.1  MAC Address Table Management Commands
1.1.1  display mac-address aging-time
View
Parameter
None
Use the display mac-address aging-time command to display the aging time of the dynamic entry in the MAC address table.
Related command: mac-address, mac-address timer, display mac-address.
Example
# Display the aging time for the dynamic entries in the MAC address table.
<Sysname> display mac-address aging-time
Mac address aging time: 300s
The above information indicates that the aging time for the dynamic entries in the MAC address is 300 seconds.
1.1.2  display mac-address
display mac-address [ mac-address [ vlan vlan-id ] | [ blackhole | dynamic | static ] [ interface  interface-type interface-number ] [ vlan vlan-id ] [ count ] ]
View
Parameter
mac-address: MAC address whose MAC address table entry is to be displayed. Provide this argument in the format of H-H-H.
static: Specifies to display the static entries in the MAC address table.
dynamic: Specifies to display the dynamic entries in the MAC address table.
blackhole: Specifies to display the blackhole MAC address entries in the MAC address table.
interface-type interface-number: Port whose MAC address table entry is to be displayed. interface-type and interface-number indicate port type and port number.
vlan-id: VLAN whose MAC address table entry is to be displayed. This argument ranges from 1 to 4,094.
count: Specifies to display the total number of MAC addresses in the MAC address table.
Use the display mac-address command to display MAC address table information.
Related command: mac-address, mac-address timer.
Example
# Display the information about a specified entry in the MAC address table.
<Sysname> display mac-address 00e0-fc01-0101
MAC ADDR         VLAN ID STATE      PORT INDEX         AGING TIME(s)
00e0-fc01-0101   1       Learned     GigabitEthernet1/0/7    NOAGED
Table 1-1 Descriptions on the fields of the display mac-address command
MAC ADDR
MAC address
VLAN ID
The ID of the MAC address’ native VLAN
STATE
MAC address state, which can be:
l      Config static: Static MAC address entry configured by the user
l      Config dynamic: Dynamic MAC address entry configured by the user
l      Learned: MAC address entry learned by the switch
l      Blackhole: Blackhole MAC address entry
PORT INDEX
Port index
 AGING TIME(s)
Aging time, which could be:
 “AGING”, indicating that the entry can be aged;
 “NOAGED”, indicating that the entry cannot be aged.
1.1.3  mac-address (System view)
mac-address { blackhole | dynamic | static } mac-address interface interface-type interface-number vlan vlan-id
undo mac-address [ [ blackhole | dynamic | static ] mac-address [ interface interface-type interface-number ] [ vlan vlan-id ] ]
View
Parameter
blackhole: Specifies a blackhole MAC table entry.
dynamic: Specifies a dynamic entry in the MAC address table.
static: Specifies a static entry in the MAC address table.
mac-address: MAC address, in the format of H-H-H.
interface-type interface-number: Port to be specified by type and number.
vlan-id: VLAN ID to be specified, in the range of 1 to 4,094.
Use the mac-address command to add or modify a MAC address table entry.
Use the undo mac-address command to delete a MAC address table entry.
Note the following:
l           MAC address entry attribute follows the following rules: If the existing address is a dynamic address, it can be modified as a static or blackhole MAC address, if the existing address is a static or blackhole MAC address, the system will prompt that the entry already exists and will not be modified.
l           All the addresses on a certain interface can be deleted. The user can choose to delete dynamic addresses, static addresses, or blackhole MAC addresses.
l           If you have not saved the configuration, all table entries will be lost after system resetting. If you have saved the configuration, after system resetting, static and blackhole MAC address entries will be kept, while dynamic table entries will be lost.
Related command: display mac-address.
Example
# Configure the port number corresponding to the MAC address 00e0-fc01-0101 as GigabitEthernet1/0/7 in the address table, and set this entry as a static entry and set its native VLAN as VLAN 2.
[Sysname] mac-address static 00e0-fc01-0101 interface gigabitethernet 1/0/7 vlan 2
1.1.4  mac-address (Ethernet port view)
mac-address { blackhole | dynamic | static } mac-address vlan vlan-id
undo mac-address [ { blackhole | dynamic | static } mac-address  vlan vlan-id ]
View
Ethernet port view,
Parameter
blackhole: Specifies a blackhole table entry.
mac-address: MAC address to be specified, in the format of H-H-H.
vlan-id: VLAN ID to be specified , in the range of 1 to 4,094.
Use the mac-address command to add or modify the MAC address table entry on a specified interface.
Use the undo mac-address command to delete the MAC address table entry.
Note:
l           If the input address already exists in the address table, the original entry will be modified. That is, replace the VLAN ID pointed by this address with the new value.
l           All the addresses on a certain interface can be deleted. The user can choose to delete dynamic addresses or static addresses.
Example
# Add the MAC address 00e0-fc01-0101 on the interface GigabitEthernet1/0/1. Set its native VLAN as VLAN 2.
[Sysname-GigabitEthernet1/0/1] mac-address static 00e0-fc01-0101 vlan 2
1.1.5  mac-address max-mac-count
undo mac-address max-mac-count
View
Ethernet port view / port group view
Parameter
count: Number of MAC addresses that a port can learn, ranging from 0 to 4096. A value of 0 means that the port is not allowed to learn any MAC address.
Use the mac-address max-mac-count command to configure the maximum number of MAC addresses that can be learned by a specified Ethernet port.
Use the undo mac-address max-mac-count command to remove the limit on the maximum number of MAC addresses that can be learned by a specified Ethernet port.
By default, the maximum number of MAC addresses that can be learned by an Ethernet port is not configured.
Use this command to set a limit on the number of MAC addresses that can be learned by a specified Ethernet interface. If the maximum number is set to count, then after the number of learned MAC addresses has reached count, the interface will no longer learn any more MAC addresses. Use the undo mac-address max-mac-count command to restore the default maximum number of MAC addresses that can be learned by a specified Ethernet port.
Example
# Set the maximum number of MAC addresses that can be learned by the interface GigabitEthernet 1/0/5 to be 600.
[Sysname] interface GigabitEthernet 1/0/5
[Sysname-GigabitEthernet1/0/5] mac-address max-mac-count 600
1.1.6  mac-address timer
undo mac-address timer aging
View
Parameter
aging seconds: Specifies the aging time (in seconds) of dynamic MAC address table entries. The seconds argument ranges from 10 to 1,000,000
no-aging: Specifies that dynamic MAC address table entries are not to be aged.
Use the mac-address timer command to configure the aging time of the dynamic address table entry.
Use the undo mac-address timer command to restore the default value.
By default, the aging time for dynamic MAC address entries is 300 seconds.
Setting the aging time too short will result in MAC addresses being deleted prematurely and a large number of packets being broadcast because no MAC addresses can be found. This will degrade the device’s performance.
If the aging time is set too long, a large number of outdated MAC addresses will be stored in the MAC address table, preventing the device from updating MAC address table in a timely manner. In this case, moving the device from one interface to another will result in delay.
Example
# Configure the aging time for dynamic address table entries as 500 seconds.
