H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
22-Cluster Command
22-Cluster Command 297 KB
Chapter 1  HGMPv2 Configuration Commands
1.1  NDP Configuration Commands
1.1.1  display ndp
display ndp [ interface interface-list ]
View
Parameter
interface interface-list: Specifies a list of ports. The list can contain consecutive or separated ports, or the combination of the both. You need to provide the interface-list argument in the form of interface-type interface-number [ to interface-type interface-number ] &<1-10>, where interface-type specifies the port type, and interface-number specifies the port number (in the form of slot number/port number).to: Specifies a port range. &<1-10> means that you can provide up to ten port indexes/port index ranges for this argument.
Use the display ndp command to display the global NDP configuration information, including the interval to send NDP packets, the holdtime of NDP information, and the information about the neighbors of all the ports.
Example
# Display NDP configuration information.
<aaa_0.Sysname> display ndp
Neighbor Discovery Protocol is enabled.
 Neighbor Discovery Protocol Ver: 1, Hello Timer: 60(s), Aging Timer: 180(s)
 Interface: GigabitEthernet 1/0/1
    Status: Enabled, Pkts Snd: 0, Pkts Rvd: 0, Pkts Err: 0
 Interface: GigabitEthernet 1/0/2
 Interface: GigabitEthernet 1/0/3
 Interface: GigabitEthernet 1/0/4
    Status: Enabled, Pkts Snd: 28440, Pkts Rvd: 27347, Pkts Err: 0
    Neighbor 1:  Aging Time: 122(s)
       MAC Address : 00e0-fc00-2579
       Port Name   : GigabitEthernet 1/0/4
       Software Ver: V100R002B01D002
       Device Name : H3C S5500-28C-SI
       Port Duplex : AUTO
       Product Ver : ESS 1204SP01
       BootROM Ver : 114
 Interface: GigabitEthernet 1/0/5
 Interface: GigabitEthernet 1/0/6
 Interface: GigabitEthernet 1/0/7
 Interface: GigabitEthernet 1/0/8
 Interface: GigabitEthernet 1/0/9
 Interface: GigabitEthernet 1/0/10
    Status: Enabled, Pkts Snd: 28450, Pkts Rvd: 26520, Pkts Err: 0
    Neighbor 1:  Aging Time: 134(s)
       MAC Address : 00e0-fc00-3133
       Port Name   : GigabitEthernet 1/0/11
       Port Duplex : AUTO
       BootROM Ver : 114
 Interface: GigabitEthernet 1/0/11
 Interface: GigabitEthernet 1/0/12
 Interface: GigabitEthernet 1/0/13
 Interface: GigabitEthernet 1/0/14
 Interface: GigabitEthernet 1/0/15
 Interface: GigabitEthernet 1/0/16
 Interface: GigabitEthernet 1/0/17
 Interface: GigabitEthernet 1/0/18
 Interface: GigabitEthernet 1/0/19
 Interface: GigabitEthernet 1/0/20
 Interface: GigabitEthernet 1/0/21
 Interface: GigabitEthernet 1/0/22
 Interface: GigabitEthernet 1/0/23
 Interface: GigabitEthernet 1/0/24
Interface: GigabitEthernet1/0/25
 Interface: GigabitEthernet1/0/26
 Interface: GigabitEthernet1/0/27
 Interface: GigabitEthernet1/0/28
Table 1-1 Description on the fields of the display ndp command
NDP is enabled globally on the switch
NDP version
Hello Timer
The interval to send NDP packets
Aging Timer
The holdtime of the NDP information sent by the local switch
Port index to specify a specific port
Status
NDP is enabled on the port
Pkts Snd
Number of the NDP packets transmitted through the port
Pkts Rvd
Number of the NDP packets received through the port
Pkts Err
Number of the error NDP packets received through the port
The holdtime of the NDP information received from the neighbors connected to the port
MAC Address
MAC address of a neighbor device
Host Name
Host Name of a neighbor device
Port Name
Port name of a neighbor device
Software Ver
Neighbor device software version
Device Name
Device name of a neighbor device
Port Duplex
Port duplex mode of a neighbor device
Product Ver
Product version of a neighbor device
BootROM Ver
BootROM version of a neighbor device
1.1.2  ndp enable
ndp enable [ interface interface-list ]
undo ndp enable [ interface interface-list ]
View
System view, Ethernet interface view
Parameter
Use the ndp enable command to enable NDP globally or on a port.
Use the undo ndp enable command to disable NDP globally or on a port.
By default, NDP is enabled both globally and on an Ethernet port.
Note that:
l           The NDP cannot operate if it is enabled on a port where NDP is disabled.
l           When being executed in system view, the ndp enable command enables NDP globally if you do not provide the interface interface-list argument. And if you specify the interface interface-list argument, the command enables NDP for the specified Ethernet port(s).
l           When being executed in Ethernet interface view, this command enables NDP for the current Ethernet port only. In this case, the interface-list argument is not needed.
l           When a port of an aggregation group is connected with a device in a cluster, the NDP feature must be enabled on all the ports of the aggregation group before the feature can work properly.
Example
# Enable NDP globally.
[Sysname] ndp enable
1.1.3  ndp timer aging
ndp timer aging aging-time
undo ndp timer aging
View
Parameter
aging-time : Holdtime (in seconds) to be set of the NDP information sent by the local switch. This argument ranges from 5 to 255.
Use the ndp timer aging command to set the holdtime of the NDP information sent by the local switch, that is, to specify how long a device will hold the NDP packets received from the local device. After the aging timer expires, the device removes the received NDP neighbor node information.
Use the undo timer aging command to restore the default NDP information holdtime.
You can specify how long an adjacent device will hold the NDP information sent by the local device. An adjacent device holds the NDP information of the local switch according to the holdtime carried in the NDP packets received from the local switch and removes the NDP information when the aging timer expires.
The default holdtime is 180 seconds.
Note that NDP information holdtime is longer than the interval to send NDP packets normally. Otherwise, the neighbor information table of an NDP port will become unstable.
Example
# Configure the holdtime of the NDP information sent by the local switch to be 60 seconds.
[Sysname] ndp timer aging 60
1.1.4  ndp timer hello
ndp timer hello hello-time
undo ndp timer hello
View
Parameter
Hello-time: Interval (in seconds) to send NDP packets ranging from 5 to 254.
Use the ndp timer hello command to set the interval to send NDP packets.
Use the undo ndp timer hello command to restore the default interval to send NDP packets.
By default, the interval to send NDP packets is 60 seconds.
NDP information in a neighbor information table is updated regularly. This enables neighbor information table to contain the actual network topology information. You can use these two commands to adjust the updating frequency of NDP information.
Example
# Configure the interval to send NDP packets to be 80 seconds.
[Sysname] ndp timer hello 80
1.1.5  reset ndp statistics
reset ndp statistics [ interface interface-list ]
View
Parameter
Use the reset ndp statistics command to clear NDP statistics.
Example
# Clear NDP statistics.
<Sysname> reset ndp statistics
1.2  NTDP Configuration Commands
1.2.1  display ntdp
display ntdp
View
Parameter
None
Use the display ntdp command to display the global NTDP information. The information includes the range (in hop count) within which topology information is collected, the interval to collect topology information (the NTDP timer), the delay time for a device to forward topology-collection requests, the delay time for a topology-collection request to be forwarded through a port, and the time cost during the last topology collection.
Example
# Display the global NTDP information.
<Sysname> display ntdp
 NTDP is running.
 Hops      : 4
 Timer     : 0 min(disable)
 Hop Delay : 100 ms
 Port Delay: 10 ms
 Last collection total time: 92ms
Table 1-2 Description on the fields of the display ntdp command
NTDP is running.
NTDP is enabled globally on the local device.
Hops
Hop count for topology collection
Timer
Interval to collect topology information
(disable) means that the device is not the command switch and does not perform periodical topology collection
Hop Delay
Delay time for the device to forward topology collection requests
Port Delay
Delay time for a topology-collection request to be forwarded through a port
Time cost during the last collection
1.2.2  display ntdp device-list
display ntdp device-list [ verbose ]
View
Parameter
verbose: Displays the detailed device information.
Use the display ntdp device-list command to display the device information collected through NTDP.
Example
# Display the device list collected through NTDP.
<Sysname> display ntdp device-list
MAC               HOP    IP               Device
 0012-a990-2241  2    192.168.0.39/24     S3928P-EI
 00e0-fc00-5503  2    192.168.0.59/24     3Com Switch 4500G 48-Port PWR
 00e0-fc00-5502  0    192.168.0.52/16     Sysname S5500-28C-SI
 00e0-fc00-5601  3    192.168.0.56/24     Sysname S5500-28C-SI
 00e0-fc00-5111  2    192.168.0.51/24     Sysname S5500-28C-SI
 00e0-fc02-2180  1    192.168.0.35/24     Sysname S3552G
 000f-e221-616e  2    192.168.0.31/24     S3100-52P
 000f-e200-2200  2    192.168.0.36/24     Sysname S3952P-V6
 000f-e218-d0d0  2    192.168.0.68/24      H3C S3610-52P
Table 1-3 Description on the fields of the display ntdp device-list command
MAC
MAC address of a device
HOP
Hops to the collecting device
IP
IP address and mask length of the management VLAN interface on the device
Device
Platform information about a device
# Display the detailed device information collected through NTDP.
<Sysname> display ntdp device-list verbose
Hostname  : Sysname
 MAC       : 000f-e200-3133
 Hop       : 2
 Device  : : H3C S5500-52C-SI
 IP        :
 Version   :
H3C Versatile Routing Platform Software
Comware Software, Version 5.20
Copyright (c) 2004-2007 Hangzhou H3C Technologies Co., Ltd. All rights reserved.
Release 1205
 Cluster   :  Member switch of cluster aaa , Administrator MAC: 000f-e200-1751
 Stack     :  Candidate switch
 Peer MAC        Peer Port ID            Native Port ID          Speed Duplex
 00e0-fc00-3199  GigabitEthernet 1/0/3      GigabitEthernet 1/0/3      200   FULL
 00e0-fc00-2579  GigabitEthernet 1/0/2      GigabitEthernet 1/0/2      400   FULL
Table 1-4 Description on the fields of the display ntdp device-list verbose command
Hostname
System name of the device
MAC
MAC address of the device
Hop
Hops to the devices that collect topology information
Device
Device name
IP
IP address and subnet mask length of the management VLAN interface on the device
Version
Version information
Cluster
Cluster information
Administrator MAC
MAC address of the management device
Stack
Stack information
Peer MAC
Peer Port ID
Name of the peer port connected to the local port
Native Port ID
Name of the local port to which a neighbor device is connected
Speed
Speed of the local port to which a neighbor device is connected
Duplex
Duplex mode of the local port to which a neighbor device is connected
1.2.3  ntdp enable
ntdp enable
undo ntdp enable
View
Parameter
None
Use the ntdp enable command to enable NTDP globally or on a port.
Use the undo ntdp enable command to disable NTDP globally or on a port.
By default, NTDP is enabled globally and on ports.
Note that the NDTP cannot operate if it is enabled on a port where NDP is disabled.
Example
# Enable NTDP globally.
[Sysname] ntdp enable
# Enable NTDP for port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ntdp enable
1.2.4  ntdp explore
ntdp explore
View
Parameter
None
Use the ntdp explore command to start topology information collection manually.
Normally, NTDP collects network topology information periodically. You can also start topology information collection manually whenever needed by executing this command. When you execute this command, NTDP collects the NDP information of every device and the information about the connections between the local switch and all of its neighbor switches in the specified network scope. The information is useful for the management device or network management system to acquire the network topology and to manage and monitor the devices.
Example
# Start the topology collection.
<Sysname> ntdp explore
1.2.5  ntdp hop
ntdp hop hop-value
undo ntdp hop
View
Parameter
hop-value: Maximum hops for collecting topology information, ranging from 1 to 16.
Use the ntdp hop command to set a range (in terms of hop count) for topology information collection.
Use the undo ntdp hop command to restore the default range for topology information collection.
By default, the value is 3.
Note that:
l           With the ntdp hop command, you can specify to collect the topology information of the devices within a specified range to avoid infinitive collection. The limit is performed by controlling the permitted hops from collection origination. For example, if you set the hop number limit to 2, only the switches less than 2 hops away from the switch starting the topology collection are collected.
l           Note that this command is only applicable to the topology-collecting device. A broader collection scope requires more memory of the topology-collecting device.
Example
# Set the hop count for topology information collection to 5.
<aaa_0.Sysname> system-view
[aaa_0.Sysname] ntdp hop 5
1.2.6  ntdp timer
ntdp timer interval-time
undo ntdp timer
View
Parameter
interval-time: Interval (in minutes) to collect topology information, ranging from 0 to 65,535. This argument defaults to 1, argument 0 specifies not to collect topology information.
Use the ntdp timer command to configure the interval to collect topology information.
Use the undo ntdp timer command to restore the default interval.
By default, the interval to collect topology information is 1 minute.
Note that:
l           The (disable) prompt in the timer field of the display ntdp command means that the device is not the member of the cluster and does not perform periodical topology collection.
l           After the cluster is set up, the S5500-SI switch will collect the topology information in the network at the set interval and add the detected candidate switches into the cluster automatically.
l           If it is unnecessary to add the candidate switches into the cluster automatically, you can set the interval of topology collection to 0.
Example
# Set the interval to collect topology information to 30 minutes.
[aaa_0.Sysname] ntdp timer 30
1.2.7  ntdp timer hop-delay
ntdp timer hop-delay time
undo ntdp timer hop-delay
View
Parameter
time: Delay time (in milliseconds) for a switch to forward topology-collection request packets. This argument ranges from 1 to 1,000.
Use the ntdp timer hop-delay command to set the delay time for a switch to forward topology-collection request packets.
Use the undo ntdp timer hop-delay command to restore the default delay time.
By default, the delay time for a switch to forward topology-collection request packets is 200 milliseconds.
Note that:
l           To avoid network congestion caused by large amount of topology response packets received in short periods, a switch delays for specific period before it forwards a received topology-collection request packet through its first ports. You can use the ntdp timer hop-delay command to set the delay time.
l           These two commands are intended for switches that collect topology information. They actually set the hop-delay value for topology-collection request packets sent by these switches. The hop-delay value determines the delay time for a switch receiving topology-collection request packets to forward them through its first port.
Example
# Set the delay time for the switch to forward topology-collection request packets through the first port to 300 ms.
[aaa_0.Sysname] ntdp timer hop-delay 300
1.2.8  ntdp timer port-delay
ntdp timer port-delay time
undo ntdp timer port-delay
View
Parameter
time: Delay time (in milliseconds) for a switch to forward a topology-collection request packet through its successive ports. This argument ranges from 1 to 100 and defaults to 20.
Use the ntdp timer port-delay command to set the delay time for a switch to forward a received topology-collection request packet through its successive ports.
Use the undo ntdp timer port-delay command to restore the default delay time.
By default, the delay time for a switch to forward a received topology-collection request packet through its successive ports is 20 milliseconds.
Note that:
l           To avoid network congestion caused by large amount of topology response packets received in short periods, a switch delays for specific period before it forwards a received topology-collection request packet through the next port. You can use the ntdp timer port-delay command to set the delay time.
l           These two commands are intended for switches that collect topology information. They actually set the port-delay value for topology-collection request packets sent by these switches. The port-delay value determines the delay time for a switch receiving topology-collection request packets to forward them through the next port.
Example
# Set the delay time for the switch to forward topology-collection request packets through the successive ports to 40 ms.
[aaa_0.Sysname] ntdp timer port-delay 40
1.3  Cluster Configuration Commands
1.3.1  add-member
add-member [ member- number] mac-address mac-address [ password password ]
View
Cluster view
Parameter
member-number: Member number assigned to the candidate device to be added to a cluster. This argument ranges from 1 to 255.
mac-address: MAC address of the candidate device (in hexadecimal).
password: Password of the candidate device, a string comprising 1 to 16 characters. The password is required when you add a candidate device to a cluster. However, this argument is not needed if the candidate device is not configured with a password.
Use the add-member command to add a candidate device to a cluster.
Note that:
l           You can add a candidate device to a cluster on the management device only.
l           If you do not specify the member number when adding a cluster member, the management device assigns the least available member number to it.
l           After a candidate device is added to a cluster, its device password becomes the management device password.
  Caution:
If the number of the routing table entries of a candidate device reaches the maximum number allowed when the candidate is added to a cluster, it will be added to and removed from the cluster repeatedly.
Example
# Add a candidate device to the cluster, setting the member number to 6. (Assume that the MAC address and user password of the candidate device are 00E0-fc00-35e7 and 123456.)
[aaa_0.Sysname] cluster
[aaa_0.Sysname-cluster] add-member 6 mac-address 00E0-fc00-35e7 password 123456
1.3.2  administrator-address
administrator-address mac-address name name
undo administrator-address
View
Cluster view
Parameter
mac-address: MAC address of the management device(in hexadecimal).
name name: Name of an existing cluster, a string comprising up to 8 characters, which  can only be alphanumeric characters, subtraction sign (-), and underline (_).
Use the administrator-address command to set the MAC address of the management device on a member device.
Use the undo administrator-address command to remove a member device from the cluster, usually for debugging or restoration.
By default, a switch belongs to no cluster.
Note that:
l           administrator-address only can be executed on a candidate device, undo administrator-address only can be executed on a member device.
l           A cluster contains one (and only one) management device. After rebooting, a member device identifies the management device by the MAC address of the management device.
l           You are recommended to use the delete-member command to remove a cluster member from a cluster on the management device.
Example
# Remove a member device from the cluster.
[aaa_0.Sysname] undo administrator-address
1.3.3  auto-build
auto-build [ recover ]
View
Cluster view
Parameter
recover: Establishes communication with all the member devices again.
Use the auto-build command to build a cluster automatically.
Note that:
l           This command can be executed on a candidate device or a management device.
l           When you use this command on a candidate device, you will be required to enter the cluster name and build a cluster. Then the system will collect candidates and add the collected candidates into the cluster automatically.
l           When you use this command on a management device, the system will collect candidates directly and add them into the cluster automatically.
l           The recover keyword is used to recover a cluster. Using the auto-build recover command, you can find the members that are not currently in the member list and add them to the cluster again.
l           Ensure that NTDP is enabled, because it is the basis of candidate and member collection. The collection range is also decided through NTDP. You can use the hop command in system view to modify the collection range.
l           If a member is configured with a password different from the password of the management device, it cannot be added to the cluster automatically.
  Caution:
When you configure a cluster, if the number of routing table entries reaches the maximum number allowed, no more routing table entries can be configured on a management device and candidate devices, which will result in the unreachability of handshake packets and the repeated add and removal of the device to and from the cluster:
l      If the routing table entries of the management device reach the maximum number allowed when a cluster is created, all candidate devices will be added to and removed from the cluster repeatedly.
l      If the number of the routing table entries of a candidate device reaches the maximum number allowed when the candidate device is added to a cluster, it will be added to and removed from the cluster repeatedly.
Example
# Set up a cluster automatically.
[Sysname] cluster
[Sysname-cluster] auto-build
Restore topology from local flash file,for there is no base topology.
(Please confirm in 30 seconds, default No) (Y/N)n
 Please input cluster name:aa.
 Collecting candidate list, please wait...
 Candidate list:
 Name                       Hops  MAC Address     Device
 Sysname                     1     00e0-fc02-2180  Sysname S3552G
 Sysname                     2     00e0-fc00-5502  Sysname S5528C-SI
 Sysname                     2     00e0-fc00-5601  S5600
 a                           2     0012-a990-2241  S3900
 2024C                       2     000f-e200-00cc  Sysname S2024C
 Processing...please wait
 Cluster auto-build Finish!
 2 member(s) added successfully.
 [aa_0.Sysname-cluster]
1.3.4  black-list add-mac
black-list add-mac mac-address
View
Cluster view
Parameter
mac-address: MAC address of the device that will be added into the blacklist, in the format of H-H-H.
Use the black-list add-mac command to add a device into the blacklist.
This command can be executed only on the management device.
Example
# Insert the device to black-list.
<aa_0.Sysname>system-view
[aa_0.Sysname]cluster
[aa_0.Sysname-cluster] black-list add-mac 0ec0-fc00-0001
Insert the MAC to the black-list successful!
1.3.5  black-list delete-mac
black-list delete-mac { all | mac-address }
View
Cluster view
Parameter
mac-address: MAC address of the device that will be deleted from the blacklist, in the format of H-H-H. This command can be executed only on the management device.
Use the black-list delete-mac command to delete a device from the blacklist.
This command must be executed on the management device.
Example
# Delete the device from black-list.
[aa_0.Sysname-cluster] black-list delete-mac 0ec0-fc00-0001
The black-list is cleared!
# Clear all the device from black-list
[aa_0.Sysname-cluster] black-list delete-mac all
1.3.6  build
build name
undo build
View
Cluster view
Parameter
name: Cluster name, a string comprising up to 8 characters, which  can only be alphanumeric characters, subtraction sign (-), and underline (_).
Use the build command to configure the current device as the management device and specify a name for it. When executing this command, you will be asked whether you want to create a standard topology map or not.
Use the undo build command to remove a cluster.
If the build command is executed on the candidate device, the current switch will be configured as the management device and assigned with a cluster name.
If the build command is executed on the management device, the cluster name will be modified.
Note that:
l           This command can only be applied to devices that are capable to be a management device and are not members of other clusters. The command takes no effect if you execute the command on a device which is already a member of another cluster. If you execute this command on a management device, you will replace the cluster name with the one you specify.
l           The member number of a management device is 0.
After the cluster is set up, the S5500-SI switch will collect the topology information of the network at the set interval and add the detected candidate devices into the cluster automatically. If it is unnecessary to add the candidate switches into the cluster automatically, you can set the interval of topology collection to 0, that is, topology collection is not performed periodically.
Example
# Configure the current switch to be a management device and specify the cluster name to be aabbcc.
<Sysname>system-view
[Sysname]cluster
[Sysname-cluster] build aabbcc
(Please confirm in 30 seconds, default No). (Y/N)
n
[aabbcc_0.Sysname-cluster]
1.3.7  cluster
cluster
View
Parameter
None
Use the cluster command to enter cluster view.
Example
# Enter cluster view.
[Sysname] cluster
[Sysname-cluster]
1.3.8  cluster enable
cluster enable
undo cluster enable
View
Parameter
None
Use the cluster enable command to enable the cluster function on a switch.
Use the undo cluster enable command to disable the cluster function on a switch.
By default, the cluster function is enabled on all the devices supporting cluster.
Note that:
l           These two commands can be used on any device supporting the cluster function.
l            When you execute the undo cluster enable command on a management device, the cluster is removed, and the switch stop operating as a management device.
l            When you execute the undo cluster enable command on a member device, the cluster function is disabled on the switch, and the switch quit the cluster.
l           When you execute the undo cluster enable command on a switch that belongs to no cluster, the cluster function is disabled on the switch.
Example
# Enable the cluster function on a switch.
[Sysname] cluster enable
1.3.9  cluster switch-to
cluster switch-to { member-number | mac-address mac-address | administrator }
View
Parameter
member-number: Member number of a switch in a cluster, ranging from 1 to 255.
mac-address mac-address: Specifies the MAC address of a member device, in the format of H-H-H..
administrator: Redirects from a member device to the management device.
Use the cluster switch-to command to switch between the management device and member devices for configuration and management.
Note that Telnet connection is used on the switch between the management device and member devices. Note the following when switching between them:
l           Authentication is required when you switch the management device to a member device. If the super password of the device to be switched is inconsistent with the super password of the device to be logged in, the switch fails.
l           When a candidate device is added to a cluster, its super password will be automatically synchronized to the management device. Therefore, after a cluster is established, you are not recommended to modify the super password of the member (including management device and member devices) of the cluster; otherwise, the switch may fail because of authentication failure.
l           When switching from the management device to a member device, your user level on the management device is retained.
l           When you switch from the member view to the management view, your user level is allocated according to the predefined level by the management device.
l           If the Telnet users on the device to be logged in reach the maximum number, the switch fails.
l           If the member device identified by the member-number argument does not exist when you execute this command on the management device, an error occurs.
Example
# Switch from the management device to the member device numbered 6 and then switch back to the management device.
<aa_0.Sysname> cluster switch-to 6
Trying ...
Press CTRL+K to abort
Connected ...
* Copyright(c) 2004-2007 Hangzhou H3C Tech. Co., Ltd. All rights reserved. *
*  Without the owner's prior written consent,                                  *
*  no decompiling or reverse-engineering shall be allowed.                     *
<aa_6.Sysname>quit
The connection was closed by the remote host!
<aa_0.Sysname>
1.3.10  delete-member
delete-member member-number  [ to-black-list ]
View
Cluster view
Parameter
to-black-list: Remove the device from the cluster meanwhile add it to the black-list, the device which added to blacklist will no longer add to cluster again.
Use the delete-member command to remove a member device from the cluster.
Perform the operation to remove a member device from a cluster on the management device only. Otherwise, errors occur.
Example
# Remove the member device numbered 2 from the cluster.
[aaa_0.Sysname-cluster] delete-member 2
# Remove the member device numbered 2 from the cluster and add it to the black-list.
<aaa_0.Sysname>system-view
[aaa_0.Sysname]cluster
[aaa_0.Sysname-cluster] delete-member 2 to-black-list
  Insert the MAC to the black-list successfull
1.3.11  display cluster
display cluster
View
Parameter
None
Use the display cluster command to display the state and statistics of the cluster to which the current switch belongs.
Note that:
l           When being executed on a member device, this command displays the information such as cluster name, member number of the current switch, the MAC address and state of the management device, holdtime, and the interval to send packets.
l           When being executed on a management device, this command displays the information such as cluster name, the number of the member devices in the cluster, cluster state, holdtime and the interval to send packets.
l           Errors occur if you execute this command on a switch that does not belong to any cluster.
Example
# Display cluster information (assuming that the current switch is a management device).
<aa_0.Sysname> display cluster
Cluster name:"aa"
 Role:Administrator
 Management-vlan:1(default vlan)
 Handshake timer:10 sec
 Handshake hold-time:60 sec
 IP-Pool:33.33.33.1/29
 No logging host configured
 No SNMP host configured
 No FTP server configured
 No TFTP server configured
 5 member(s) in the cluster, and 0 of them down.
# Display cluster information (assuming that the current switch is a member device).
<aa_4.Sysname> display cluster
Cluster name:"aa"
 Role:Member
 Member number:4
 Administrator device IP  address:1.1.3.1
 Administrator device mac address:00e0-fc00-1751
 Administrator status:Up
Table 1-5 Description on the fields of the display cluster command
Cluster name
Name of the cluster
Role
Cluster role of the switch
Member number
Member number of the switch
Handshake timer
Value of handshake timer
Handshake hold-time
Handshake holdtime
IP address of the management device
State of the management device
1.3.12  display cluster base-topology
display cluster base-topology [ mac-address mac-address | member-id member-number ]
View
Parameter
mac-address: Specify a node according to the MAC address.
member-number : Specify the starting member number in the topology display.
Use the display cluster topology command to display the standard topology view of the cluster.
You can create a standard topology view by using the build or auto-build command or save the current topology view as a standard topology view by using the topology accept command. This command can be executed only on the management device.
Example
# Display the standard topology information of the cluster.
[aa_0.Sysname] display cluster base-topology
     (PeerPort) ConnectFlag (NativePort) [SysName:DeviceMac]
[aa_0.Sysname:00e0-fc00-5502]
    └-(P_1/0/6)<-->(P_0/2)[Sysname:00e0-fc02-2180]
        ├-(P_0/22)<-->(P_1/0/4)[Sysname:00e0-fc00-5111]
        ├-(P_0/16)<-->(P_1/0/4)[aa_3.a:0012-a990-2241]
        ├-(P_0/14)<-->(P_1/0/2)[aa_2.Sysname:00e0-fc00-5601]
        ├-(P_0/4)<-->(P_0/15)[2024C:000f-e200-00cc]
        ├-(P_0/1)<-->(P_3/0/33)[Sysname:00e0-fc00-1774]
        └-(P_0/10)<-->(P_1/0/2)[aa_0.Sysname:000f-e200-2200]
Table 1-6 Description on the fields of the display cluster base-topology command
PeerPort
Port of peer
ConnectFlag
Flag of connect
NativePort
Native port
SysName
System name
1.3.13  display cluster black-list
View
Parameter
None
Use the display cluster black-list command to display the current blacklist of the cluster.
Example
# Display the current black-list of the cluster.
[Sysname] display cluster black-list
  Device ID           Access Device ID           Access port
  00e0-fc00-0010      00e0-fc00-3550             Ethernet1/0/1
1.3.14  display cluster candidates
display cluster candidates [ mac-address mac-address | verbose ]
View
Parameter
mac-address mac-address: Specifies the MAC address of a candidate device, in the format of H-H-H..
verbose: Displays the detailed information about all the candidate devices.
Use the display cluster candidates command to display the information about the candidate devices of a cluster.
Execute this command on management devices only.
Example
# Display the information about all the candidate devices.
<aaa_0.Sysname-cluster> display cluster candidates
MAC               HOP  IP                   DEVICE
00e0-fc00-3199  3                          S5500
000f-cbb8-9528  1    31.31.31.56/24      S5500
Table 1-7 Description on the fields of the display cluster candidates command (A)
MAC
Hop
Hops from a candidate device to the management device
IP
IP address of a candidate device
Device
Device of a candidate device
# Display the information about a specified candidate device.
<Sysname-cluster> display cluster candidates mac-address 00e0-fc00-3190
Hostname  : Sysname
MAC       : 00e0-fc00-3190
Hop       : 1
Device  : H3C S5500-52C-SI
IP        : 16.1.1.1/24
# Display the detailed information about all the candidate devices.
[Sysname-cluster] display cluster candidates verbose
Hostname  : Sysname
MAC       : 3900-0000-3334
Hop       : 2
IP        : 16.1.1.11/24
Hostname  : Sysname
Hop       : 1
IP        : 16.1.1.1/24
Table 1-8 Description on the fields of the display cluster candidates command (B)
Hostname
Name of a candidate device
MAC
Hop
IP
Device
Platform of a candidate device
1.3.15  display cluster current-topology
display cluster current-topology [ mac-address mac-address [ to-mac-address mac-address ] | member-id member-number [ to-member-id member-number ] ]
View
Parameter
member-number: Specifies the starting member number in the topology display or the member numbers at the starting point and ending point of a path.
mac-address: Specifies a node according to a MAC address.
Use the display cluster current-topology command to display the current topology view or the topology path between two points.
Example
# Display the current topology information of the cluster.
<aa_0.Sysname> display cluster current-topology
ConnectFlag:
     <--> normal connect      ---> odd connect     **** in blacklist
     ???? lost device         ++++ new device      -┤├- STP discarding
    └-(P_1/0/6)++++(P_0/2)[Sysname:00e0-fc02-2180]
        ├-(P_0/22)++++(P_1/0/4)[Sysname:00e0-fc00-5111]
        ├-(P_0/16)++++(P_1/0/4)[aa_5.a:0012-a990-2241]
        ├-(P_0/14)++++(P_1/0/2)[aa_4.Sysname:00e0-fc00-5601]
        ├-(P_0/10)++++(P_1/0/2)[aa_0.Sysname:000f-e200-2200]
        ├-(P_0/4)++++(P_0/15)[2024C:000f-e200-00cc]
        └-(P_0/1)++++(P_3/0/33)[Sysname:00e0-fc00-1774]
Table 1-9 Description on the fields of the display cluster current-topology command
PeerPort
Port of peer
ConnectFlag
Flag of connect
NativePort
Native port
SysName
System name
normal connect
normal connect
odd connect
odd connect
in blacklist
The device is in blacklist
lost device
lost device
new device
new device
STP discarding
STP discarding
The newly added device in the topology information is determined on the basis of the standard topology. If you have not used the topology accept command to confirm the current topology information of the cluster and save the current topology as the standard topology after a device joins in the cluster, this device will always be marked as a new one.
1.3.16  display cluster members
display cluster members [ member-number | verbose ]
View
Parameter
member-number: Member number of a switch in a cluster, ranging from 0 to 255.
verbose: Displays the detailed information about all the devices in a cluster.
Use the display cluster members command to display the information about cluster members.
Example
# Display the information about all the devices in the cluster.
<Sysname> display cluster members
SN   Device              MAC Address     Status Name
0    Sysname S5528C-SI   00e0-fc00-5502 Admin    aa_0.Sysname
 3    S3100              000f-e221-616e Up       aa_3.Sysname
 5    Sysname S5150C-EI  00e0-fc00-5111 Up       aa_5.Sysname
 6    S5600-1508P01      00e0-fc00-5601 Up       aa_6.Switchb
Table 1-10 Description on the fields of the display cluster members command
SN
Number of cluster member
Device
Type of device
MAC Address
MAC Address of device
Status
Status of device
Name
Name of device
# Display the detailed information about the management device and all member devices.
<aa_0.Sysname> display cluster members verbose
 Member number:0
 Device: H3C S5500-28C52C-SI
 MAC Address: 000f-e200-5502
 Member status:Admin
 Hops to administrator device:0
 IP: 192.168.0.52/16
 Version:
Release 1205
 Member number:3
 Device:S3100-52P
 MAC Address: 000f-e2c0-c201
 Member status:Up
 Hops to administrator device:2
 IP: 192.168.0.31/24
 Version:
   H3C Comware Platform Software
  Comware Software, Version 3.10
  Copyright (c) 2004-2007 Hangzhou H3C Technologies Co.,Ltd. All rights reserved.
   H3C S3100-52P S3100-1510P02
Table 1-11 Description on the fields of the display cluster members verbose command
Member number
Device member number
Name
Name of a member device, composed of the cluster name and the host name of the member device, in the format of cluster name.hostname
When the management device type is not consistent with the member device type, if a user modifies the cluster name on the management device continuously, the cluster name may appear twice in the cluster member name, for example, “clustername.clustername.hostname”. This abnormal case can restore in a period of time.
Device
Device type
MAC Address
Member status
State of a device
Hops from the current device to the management device
IP
IP address of a device
Version
Software version of the current device
1.3.17  ftp-server
ftp-server ip-address [ user-name username password { simple | cipher } password ]
undo ftp-server
View
Cluster view
Parameter
ip-address: IP address of the FTP server to be configured for the cluster.
username: User name to telnet ftp server, a string of 1 to 32 characters.
simple :Specifies to display passwords in simple text.
cipher: Specifies to display passwords in cipher text.
Password: Password you want to set, a character string. For simple mode, the password must be in plain text. For cipher mode, the password can be either in cipher text or in plain text, which it is depends on your input. Encrypted text password string with of up to 16 consecutive characters, characters such as_(TT8F]Y\5SQ=^Q`MAF4<1!!.
Use the ftp-server command to configure an FTP server on the management device for the member devices in the cluster.
Use the undo ftp-server command to remove the FTP server configured for the member devices in the cluster.
By default, the management device acts as the FTP Server.
Example
# Configure the IP address of an FTP server on the management device.
[aaa_0.Sysname-cluster] ftp-server 1.0.0.9
1.3.18  holdtime
holdtime seconds
undo holdtime
View
Cluster view
Parameter
seconds: Holdtime (in seconds) ranging from 1 to 255.
Use the holdtime command to configure the holdtime of a switch.
Use the undo holdtime command to restore the default holdtime value.
By default, the holdtime of a device is 60 seconds.
Note that:
l           If a switch does not receive any information of a peer device during the holdtime, it sets the state of the peer device to “down”. When the communication between the two resumes, the corresponding member device is re-added to the cluster (automatically). If the downtime does not exceed the holdtime, the member device stays in the normal state and needs not to be added again.
l           Execute these two commands on management devices only. The member devices in a cluster acquire the holdtime setting from the management device.
Example
# Set the holdtime to 30 seconds.
[aaa_0.Sysname-cluster] holdtime 30
1.3.19  ip-pool
ip-pool administrator-ip-address { ip-mask | ip-mask-length }
undo ip-pool
View
Cluster view
Parameter
administrator-ip-address: IP address of the management device of a cluster.
ip-mask: Mask of the cluster IP address pool.
ip-mask-length: Mask length of the cluster IP address pool.
Use the ip-pool command to configure a private IP address range for cluster members on the switch to be configured as the management device.
Use the undo ip-pool command to cancel the IP address range configuration.
Note that:
l           Before establishing a cluster, you need to configure a private IP address pool for the switches to be added to the cluster. When a candidate device is added to a cluster, the management device assigns a private IP address to it for the candidate device to c-ommunicate with other devices in the cluster. This enables you to manage and maintain member devices in a cluster through the management device.
l           Execute these two commands on switches that belong to no cluster only. The IP address range of an existing cluster cannot be modified.
Example
# Configure the IP address range of a cluster.
[Sysname] cluster
[Sysname-cluster] ip-pool 10.200.0.1 20
1.3.20  logging-host
logging-host ip-address
undo logging-host
View
Cluster view
Parameter
ip-address: IP address of the logging host configured for the cluster. This argument ranges from 1 to 1094.
Use the logging-host command to configure a logging host on the management device for the member devices in the cluster.
Use the undo logging-host command to cancel the logging host configuration.
By default, no logging host is configured.
Note that
l           You need to configure the IP address of a logging host first for the member devices in a cluster to send log information to the logging host through the management device.
l           Execute this command on management devices only.
l           Note that you need to configure the IP address of a logging host first for the member devices in a cluster to send log information to the logging host through the management device.
Example
# Configure the IP address of the logging host on the management device.
[aaa_0.Sysname-cluster] logging-host 10.10.10.9
1.3.21  management-vlan
management-vlan vlan-id
undo management-vlan
View
Parameter
vlan-id: ID of the VLAN to be specified as the management VLAN. This argument ranges from 1 to 4094.
Use the management-vlan command to specify the management VLAN on the switch.
Use the undo management-vlan command to restore the default management VLAN.
By default, VLAN 1 is the management VLAN.
Note the following when configuring the management VLAN:
l           The management VLANs specified on different devices in the same cluster must be the same VLAN.
l           The management VLAN can only be specified before the cluster is created. Once a switch is added to a cluster, the management VLAN configuration cannot be modified. To modify management VLAN configuration on a switch belonging to a cluster, you need to cancel the cluster-related configurations on the switch, specify the desired VLAN to be the management VLAN, and then re-create the cluster.
Example
# Specify VLAN 2 as the management VLAN on the current switch.
[Sysname] management-vlan 2
1.3.22  nm-interface Vlan-interface
nm-interface Vlan-interface vlan-id
undo nm-interface
View
Cluster view
Parameter
vlan-id: ID of the VLAN.
Use the nm-interface Vlan-interface command to configure the network management interface of the management switch.
Use the undo nm-interface command to restore the default network management interface.
You can specify the network management interface of the management device, so that the network administrator can access the management switch through the network management interface to manage the devices in the cluster.
&  Note:
l      By default, the network management interface is a management VLAN interface.
l      There can be only one network management interface, and the reconfigured network management interface will replace the old one.
Example
# Configure VLAN-interface 2 as the network management interface.
[Sysname] cluster
[Sysname-cluster] nm-interface Vlan-interface 2
1.3.23  reboot member
reboot member { member-number | mac-address mac-address } [ eraseflash ]
View
Cluster view
Parameter
mac-address mac-address: MAC address of the member device to be rebooted.
eraseflash: Deletes the configuration file when the member device reboots.
Use the reboot member command to reboot a specified member device on the management device.
Note that:
l           Communication between the management and member devices may be interrupted due to some configuration errors. Through the remote control function of member devices, you can control them remotely on the management device. For example, you can reboot a member device that operates improperly and specify to delete the booting configuration file when the member device reboots, and thus restore normal communication between the management and member devices.
l           The eraseflash keyword specifies to delete the booting configuration file when the member device reboots.
Example
# Reboot the member device numbered 2.
[aaa_0.Sysname-cluster] reboot member 2
1.3.24  snmp-host
snmp-host ip-address  [ community-string read string1 write string2 ]
undo snmp-host
View
Cluster view
Parameter
ip-address: IP address of a SNMP host to be configured for a cluster.
string1:Read-only string, a string containing 1 to 26 characters.
string2:Write-only string , a string containing 1 to 26 characters.
Use the snmp-host command to configure an SNMP host for the member devices inside a cluster on the management device.
Use the undo snmp-host command to cancel the SNMP host configuration.
By default, no SNMP host is configured.
Note that:
l           You need to configure the IP address of an SNMP host first for the cluster, in order that the member devices in a cluster can send trap messages to the SNMP host through the management device.
Example
# Configure an SNMP host for the cluster on the management device.
[aaa_0.Sysname-cluster] snmp-host 1.0.0.9
1.3.25  tftp-server
tftp-server ip-address
undo tftp-server
View
Cluster view
Parameter
ip-address: IP address of a TFTP server to be configured for a cluster.
Use the tftp-server command to configure a TFTP server for cluster members on the management device.
Use the undo tftp-server command to cancel the TFTP server of the cluster members.
By default, no TFTP server is configured.
Note that:
l           You need to configure the IP address of the TFTP server for the cluster, in order that the member devices in the cluster can access the TFTP server through the management device.
Example
# Configure a TFTP server on the management device.
[aaa_0.Sysname-cluster] tftp-server 1.0.0.9
1.3.26  timer
timer interval
undo timer
View
Cluster view
Parameter
Interval: Interval (in seconds) to send handshake packets. This argument ranges from 1 to 255.
Use the timer command to set the interval to send handshake packets.
Use the undo timer command to restore the default value of the interval.
By default, the interval to send handshake packets is 10 seconds.
Note that:
l           Inside a cluster, the connections between member devices and the management device are kept through transmitting handshake packets. Handshake packets in a cluster enable the management device to acquire the information about member states link states.
l           Execute these two commands on management devices only. All the member devices in a cluster acquire the handshake interval setting from the management device.
Example
# Configure the interval to send handshake packets to be 3 seconds.
[aaa_0.Sysname-cluster] timer 3
1.3.27  topology accept
topology accept { all [ save-to { ftp-server | local-flash } ] | mac-address mac-address | member-id member-number }
undo topology accept { all | mac-address mac-address | member-id member-number }
View
Cluster view
Parameter
all: All devices.
mac-address: Specifies a bridge MAC address of the device while the device authenticates the topology authenticated by the topology, in the format of H-H-H.
member-number: Specifies the member number from which the topology displays or the member numbers at the starting point and ending point of a specified path.
save-to: Configures to save a standard topology to the FTP server or the flash while saving the standard topology. This file is named topology.top universally.
Use the topology accept command to confirm the current topology information of the cluster and save that as a standard topology.
Use the undo topology accept command to delete the current topology information of the cluster.
The topology.top file is used to save standard topology information on the FTP server or the local flash. The saved information includes information of the white list and blacklist. The blacklist is a list of devices that are not allowed to join the cluster. The white list is a list of devices that can join the cluster.
Example
# Accept the current topology as a standard topology.
[aa_0.Sysname-cluster] topology accept all
1.3.28  topology restore-from
topology restore-from { ftp-server | local-flash }
View
Cluster view
Parameter
None
Use the topology restore-from command to obtain and restore the standard topology information from the local flash.
Example
# Obtain and restore the standard topology information.
[aa_0.Sysname-cluster] topology restore-from local-flash
  Begin get base topology file from local flash......
  Get file OK
  Begin build base topology from file......
  Finish building base topology from file
  Begin build blacklist from file......
  Finish building blacklist from file
1.3.29  topology save-to
topology save-to { ftp-server | local-flash }
View
Cluster view
Parameter
None
Use the topology save-to command to save the standard topology information into the local flash.
The topology includes white list and blacklist. The file is named topology.top universally.
Example
# Save the standard topology information into the local flash.
[aa_0.Sysname-cluster] topology save-to local-flash
Base topology backup to file OK
