H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
30-SSL-HTTPS Command
30-SSL-HTTPS Command 76 KB
Chapter 1  SSL Configuration Commands
1.1  SSL Configuration Commands
1.1.1  ciphersuite
ciphersuite [ rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha ] *
View
SSL server policy view
Parameter
rsa_3des_ede_cbc_sha: Specifies to adopt RSA for key exchange algorithm, 3DES_EDE_CBC for data encryption algorithm and SHA for MAC algorithm.
rsa_aes_128_cbc_sha: Specifies to adopt RSA for key exchange algorithm, 128 bits AES_CBC for data encryption algorithm and SHA for MAC(message authentication mode) algorithm.
rsa_aes_256_cbc_sha: Specifies to adopt RSA for key exchange algorithm, 256 bits AES_CBC for data encryption algorithm and SHA for MAC algorithm.
rsa_des_cbc_sha: Specifies to adopt RSA for key exchange algorithm, DES_CBC for data encryption algorithm and SHA for MAC algorithm.
rsa_rc4_128_md5: Specifies to adopt RSA for key exchange algorithm, 128 bits RC4 for data encryption algorithm and MD5 for MAC algorithm.
rsa_rc4_128_sha: Specifies to adopt RSA for key exchange algorithm, 128 bits RC4 for data encryption algorithm and SHA for MAC algorithm.
Use the ciphersuite command to configure the cipher suites supported by an SSL server policy.
By default, an SSL server policy supports the above-mentioned six types of cipher suite.
If no parameter is specified, an SSL server policy supports the above-mentioned six types of cipher suite.
Example
# Specify the cipher suites supported by an SSL server policy as rsa_rc4_128_md5 and rsa_rc4_128_sha.
[Sysname] ssl server-policy policy1
[Sysname-ssl-server-policy-policy1] ciphersuite rsa_rc4_128_md5 rsa_rc4_128_sha
1.1.2  client-verify enable
undo client-verify enable
View
Parameter
None
Use the client-verify enable command to enable certificate-based SSL client authentication, meaning in SSL handshake process the server performs certificate-based authentication to the client.
Use the undo client-verify enable command to restore the default.
By default, no certificate-based SSL client authentication is available.
# Configure the server to perform certificate-based authentication to the client in the process of handshake.
[Sysname-ssl-server-policy-policy1] client-verify enable
1.1.3  close-mode wait
close-mode wait
undo close-mode wait
View
Parameter
None
Use the close-mode wait command to configure the close mode for SSL connection as wait, meaning after sending a close-notify alert message to a client, the server does not close the session until it receives a close-notify alert message from the client.
Use the undo close-mode wait command to restore the default.
By default, the server sends a close-notify alert message to the client and close the session without waiting for the close-notify alert message from the client.
Example
# Set the close mode for an SSL connection to wait.
[Sysname-ssl-server-policy-policy1] close-mode wait
1.1.4  display ssl client-policy
display ssl client-policy { policy-name | all }
View
Parameter
policy-name: Displays information about the specified SSL client policy.
all: Displays information about all SSL client policies.
Use the display ssl client-policy command to view information about one or all SSL client policies.
Example
# Display information about SSL client policy policy1.
<Sysname> display ssl client-policy policy1
 SSL Client Policy: policy1
     SSL Version: SSL 3.0
     PKI Domain: 1
     Prefer Ciphersuite:
         RSA_RC4_128_SHA
Table 1-1 Description on the fields of the display ssl client-policy command
SSL Client Policy
SSL client policy name
SSL Version
Version of the protocol adopted by the SSL client policy
PKI Domain
PKI domain adopted by the SSL client policy
Prefer Ciphersuite
Preferred cipher suite for the SSL client policy
1.1.5  display ssl server-policy
display ssl server-policy { policy-name | all }
View
Parameter
policy-name: Displays information for the specified SSL server policy, which is a string of 1 to 16 characters.
all: Displays information about all SSL server policies.
Use the display ssl server-policy command to view information about a specified or all SSL server policies.
Example
# Display information about SSL server policy policy1.
<Sysname> display ssl server-policy policy1
 SSL Server Policy: policy1
     PKI Domain: domain1
     Ciphersuite:
         RSA_RC4_128_MD5
         RSA_RC4_128_SHA
         RSA_DES_CBC_SHA
         RSA_3DES_EDE_CBC_SHA
         RSA_AES_128_CBC_SHA
         RSA_AES_256_CBC_SHA
     Handshake Timeout: 3600
     Close-mode: wait disabled
     Session Timeout: 3600
     Session Cachesize: 500
     Client-verify: disabled
Table 1-2 Description on the fields of the display ssl server-policy command
SSL Server Policy
SSL server policy name
PKI Domain
PKI domain to which the SSL server policy belongs
Ciphersuite
The cipher suite supported by the SSL server policy
Handshake Timeout
Handshake timeout time specified in the SSL server policy
Close-mode
Close mode specified in the SSL server policy
Session Timeout
Session timeout time specified in the SSL server policy
Session Cachesize
Maximum number of sessions that can be buffered in the SSL server policy
Client-verify
Client authentication mode specified in the SSL server policy
1.1.6  handshake timeout
handshake timeout time
undo handshake timeout
View
Parameter
time: Handshake timeout time, in the range 180 to 7200 seconds.
Use the handshake timeout command to configure handshake timeout time in an SSL server policy.
Use the undo handshake timeout command to restore the default.
By default, the handshake timeout time specified in an SSL server policy is 3600 seconds.
Example
# Configure the handshake timeout time in SSL server policy policy1 as 3000 seconds.
[Sysname-ssl-server-policy-policy1] handshake timeout 3000
1.1.7  pki-domain
pki-domain domain-name
undo pki-domain
View
SSL server policy view/SSL client policy view
Parameter
domain-name: Name of a PKI domain, a string of 1 to 15 characters.
Use the pki-domain command to configure the PKI domain used for an SSL server policy or SSL client policy.
Use the undo pki-domain command to restore the default.
No PKI domain is configured for an SSL server policy or SSL client policy by default.
Example
# Configure the PKI domain used for SSL server policy policy1 as server-domain.
[Sysname-ssl-server-policy-policy1] pki-domain server-domain
# Configure the PKI domain used for SSL client policy policy1 as client-domain.
[Sysname] ssl client-policy policy1
[Sysname-ssl-client-policy-policy1] pki-domain client-domain
1.1.8  prefer-cipher
prefer-cipher { rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha }
undo prefer-cipher
View
Parameter
rsa_aes_128_cbc_sha: Specifies to adopt RSA for key exchange algorithm, 128 bits AES_CBC for data encryption algorithm and SHA for MAC algorithm.
Use the prefer-cipher command to configure the preferred cipher suite for the SSL client policy.
Use the undo prefer-cipher command to restore the default.
By default, the preferred cipher suite for the SSL client policy is rsa_rc4_128_md5.
Example
# Configure the preferred cipher suite for SSL client policy policy1 as rsa_aes_256_cbc_sha.
[Sysname-ssl-client-policy-policy1] prefer-cipher rsa_aes_256_cbc_sha
1.1.9  session
undo session { cachesize | timeout } *
View
Parameter
size: Maximum number of sessions that can be buffered, in the range 100 to 1000.
time: Session timeout time, in the range 1800 to 72000.
Use the session command to configure the maximum number of sessions that can be buffered and the session timeout time.
Use the undo session command to restore the default.
By default, the maximum number of sessions that can be buffered is 500 and the session timeout time is 3600 seconds.
SSL stops buffering a new session if the maximum session number is reached. SSL removes a buffered session if the session is timed out.
Example
# Configure the timeout time for a session that can be buffered as 4000 seconds, and the maximum session number as 600.
[Sysname-ssl-server-policy-policy1] session timeout 4000 cachesize 600
1.1.10  ssl client-policy
ssl client -policy policy-name
undo ssl client-policy { policy-name | all }
View
Parameter
policy-name: SSL client policy name, a string of 1 to 16 characters, which cannot be “a”, “al” and “all” and is not case sensitive.
all: All SSL client policies.
Use the ssl client-policy command to create an SSL policy and enter its view.
Use the undo ssl client-policy command to remove a specified or all SSL client policies.
Example
# Create an SSL client policy named policy1 and enter its view.
1.1.11  ssl server-policy
ssl server-policy policy-name
undo ssl server-policy { policy-name | all }
View
Parameter
policy-name: SSL server policy name, a string of 1 to 16 characters, which cannot be “a”, “al” and “all” and is not case sensitive.
all: All SSL server policies.
Use the ssl server-policy command to create an SSL server policy and enter its view.
Use the undo ssl server-policy command to remove a specified or all SSL server policies.
Example
# Create an SSL server policy named policy1 and enter its view.
1.1.12  version
version { ssl3.0 | tls1.0 }
undo version
View
Parameter
ssl3.0: SSL version SSL3.0.
tls1.0: SSL version TLS1.0.
Use the version command to configure the SSL protocol version adopted by an SSL client policy.
Use the undo version command to restore the default.
By default, the SSL protocol version adopted by an SSL client policy is TLS1.0.
Example
# Configure the SSL protocol version for SSL client policy policy1 as SSL3.0.
[Sysname-ssl-client-policy-policy1] version ssl3.0
Chapter 2  HTTPS Configuration Commands
2.1  HTTPS Configuration Commands
2.1.1  display ip https
display ip https
View
Parameter
None
Use the display ip https command to display information about HTTPS.
Example
# Display information about HTTPS.
<Sysname> display ip https
SSL server policy: test
Certificate access-control-policy:
Basic ACL: 2222
Current connection: 0
Operation status: Running
Table 2-1 Description on the fields of the display ip https command
SSL server policy
The SSL server policy associated with the HTTPS service
The certificate attribute access control policy associated with the HTTPS service
Basic ACL
The basic ACL number associated with the HTTPS service
Current connection
The number of current connections
Operation status
Operation status
2.1.2  ip https acl
ip https acl acl-number
undo ip https acl
View
Parameter
acl-number: Basic ACL number, in the range 2000 to 2999.
Use the ip https acl command to associate the HTTPS service with an ACL.
Use the undo ip https acl command to remove the association.
By default, the HTTPS service is not associated with any ACL.
Example
# Configure the HTTPS service withOnly allow the clients within the 10.10.0.0/16 network segment to access the HTTPS server.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ip https acl 2001
2.1.3  ip https certificate access-control-policy
undo ip https certificate access-control-policy
View
Parameter
policy-name: Name of the certificate attribute access control policy, a string of 1 to 16 characters.
Use the ip https certificate access-control-policy command to associate the HTTPS service with a certificate attribute access control policy.
Use the undo ip https certificate access-control-policy command to remove the association.
By default, the HTTPS service is not associated with any certificate attribute access control policy.
Example
# Associate the HTTPS server to certificate attribute access control policy “myacl”.
[Sysname] ip https certificate access-control-policy myacl
2.1.4  ip https enable
ip https enable
undo ip https enable
View
Parameter
None
Use the ip https enable command to enable the HTTPS service.
Use the undo ip https enable command to disable the HTTPS service.
By default, the HTTPS servcie is disabled.
To enable the HTTPS service, an SSL handshake negotiation process will be triggered. During the process, if a local certificate of the device already exists, the SSL negotiation is successfully performed, and the HTTPS service can be started normally. If no local certificate exists, a certificate application process will be triggered by the SSL negotiation. Since the application process takes much time, the SSL negotiation often fails and the HTTPS service cannot be started normally. Therefore, the ip https enable command must be executed for multiple times to ensure normal startup of the HTTPS service.
Example
# Enable the HTTPS service.
[Sysname] ip https enable
2.1.5  ip https ssl-server-policy
View
Parameter
policy-name: Name of an SSL server policy, a string of 1 to 16 characters.
Use the ip https ssl-server-policy command to associate the HTTPS service with an SSL server-end policy.
By default, the HTTPS service is not associated with any SSL server-end policy.
Note that the HTTPS service can be enabled only after this command is configured successfully.
Example
# Configure the HTTPS service to use SSL server-end policy “myssl”.
[Sysname] ip https ssl-server-policy myssl
