H3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual-Release 1205-(V1.03)
18-DHCP Command
18-DHCP Command 146 KB
Chapter 1  DHCP Relay Agent Configuration Commands
l      The DHCP relay agent configuration is supported only on VLAN interfaces.
l      DHCP Snooping cannot be configured on the DHCP relay agent.
1.1  DHCP Relay Agent Configuration Commands
1.1.1  dhcp enable
dhcp enable
undo dhcp enable
View
Parameter
None
Use the dhcp enable command to enable DHCP.
Use the undo dhcp enable command to disable DHCP.
By default, DHCP is disabled.
&  Note:
For DHCP relay agent configuration, enabling DHCP first is necessary to make other configurations take effect.
Example
# Enable DHCP.
[Sysname] dhcp enable
1.1.2  dhcp relay address-check
dhcp relay address-check { disable | enable }
View
VLAN Interface view
Parameter
disable: Disables IP address match checking on the relay agent.
enable: Enables IP address match checking on the relay agent.
Use the dhcp relay address-check enable command to enable IP address match checking on the relay agent.
Use the dhcp relay address-check disable command to disable IP address match checking on the relay agent.
By default, the function is disabled.
Example
# Enable IP address match checking on the DHCP relay agent.
[Sysname-Vlan-interface1] dhcp relay address-check enable
1.1.3  dhcp relay information enable
undo dhcp relay information enable
View
VLAN Interface view
Parameter
None
Use the dhcp relay information enable command to enable the relay agent to support option 82.
Use the undo dhcp relay information enable command to disable option 82 support.
By default, option 82 support is disabled on DHCP relay agent.
Example
# Enable option 82 support on the relay agent.
[Sysname-Vlan-interface1] dhcp relay information enable
1.1.4  dhcp relay information format
dhcp relay information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
undo dhcp relay information format [ verbose node-identifier ]
View
VLAN Interface view
Parameter
normal: Specifies the normal padding format.
verbose: Specifies the verbose padding format.
node-identifier { mac | sysname | user-defined node-identifier }: Specifies access node identifier, mac indicates using MAC address as the node identifier, sysname indicates using node name as the node identifier, user-defined node-identifier indicates using a specified character string as the node identifier, in which node-identifier is a string with 1 to 50 characters.
Use the dhcp relay information format command to specify a padding format for option 82.
Use the undo dhcp relay information format command to restore the default padding format.
The option 82 padding format defaults to normal.
&  Note:
l      Using the undo dhcp relay information format command without the keyword verbose node-identifier restores the default normal padding format, or with the keyword verbose node-identifier restores the mac mode of the verbose padding format.
l      If configuring the handling strategy of the DHCP relay agent as replace, you need to configure a padding format of option 82. If the handling strategy is keep or drop, you need not configure any padding format.
Example
# Specify the normal padding format for option 82.
[Sysname-Vlan-interface1] dhcp relay information strategy replace
[Sysname-Vlan-interface1] dhcp relay information format normal
1.1.5  dhcp relay information strategy
undo dhcp relay information strategy
View
Interface view
Parameter
drop: Specifies to drop messages containing option 82.
keep: Specifies to forward messages containing option 82 without any change.
replace: Specifies to forward messages containing option 82 after replacing the original option 82 with the option 82 padded by specified padding format.
Use the dhcp relay information strategy command to configure DHCP relay agent handling strategy for messages containing option 82.
Use the undo dhcp relay information strategy command to restore the default handling strategy.
The handling strategy for messages containing option 82 defaults to replace.
Example
# Configure the DHCP relay agent handling strategy for messages containing option 82 as keep.
[Sysname-Vlan-interface1] dhcp relay information strategy keep
1.1.6  dhcp relay release
dhcp relay release client-ip client-mac [ server-ip ]
View
System view/VLAN Interface view
Parameter
client-ip: DHCP client IP address.
client-mac: DHCP client MAC address in the format H-H-H.
server-ip: DHCP server IP address.
Use the dhcp relay release command to send a DHCP-RELEASE request to a specified DHCP server or server groups for releasing a specified client IP address.
If the server-ip is not specified in system view, the relay agent will send the DHCP-RELEASE request to DHCP server groups corresponding to all interfaces working in DHCP relay agent mode; if the server-ip is not specified in interface view, the relay agent will send the DHCP-RELEASE request to the DHCP server group corresponding to the current interface.
If a server-ip is specified, the relay agent will send the DHCP-RELEASE request to the specified DHCP server.
Example
# Send a DHCP-RELEASE request to the DHCP server correlated to the interface VLAN interface1 for releasing the IP address 1.1.1.1 that was obtained by the client whose MAC is 00e0-0000-0001.
[Sysname-Vlan-interface1] dhcp relay release 1.1.1.1 00e0-0000-0001
# Send a DHCP-RELEASE request to all correlated DHCP servers for releasing the IP address 1.1.1.1 that was obtained by the client whose MAC is 00e0-0000-0001.
[Sysname] dhcp relay release 1.1.1.1 00e0-0000-0001
1.1.7  dhcp relay security static
dhcp relay security static ip-address mac-address
undo dhcp relay security { ip-address | all | dynamic | static }
View
Parameter
ip-address: Specifies a client IP address for creating a static binding.
mac-address: Specifies a client MAC address for creating a static binding, in the format H-H-H.
all: Specifies all entries of client IP-to-MAC bindings.
dynamic: Specifies entries of dynamic client IP-to-MAC bindings.
static: Specifies entries of manual client IP-to-MAC bindings.
Use the dhcp relay security static command to configure a manual IP-to-MAC binding on the relay agent.
Use the undo dhcp relay security command to remove specified entries of client IP-to-MAC bindings from the relay agent.
No manual IP-to-MAC binding is configured by default.
Related command: display dhcp relay security.
Example
# Configure a static mapping between IP address 1.1.1.1 to MAC address 0005-5d02-f2b3.
[Sysname] dhcp relay security static 1.1.1.1 0005-5d02-f2b3
1.1.8  dhcp relay security tracker
dhcp relay security tracker { interval | auto }
undo dhcp relay security tracker [ interval ]
View
Parameter
interval: Sets a refreshing interval value a string of 1 to 120 seconds.
auto: Specifies the auto refreshing interval, which is the value of 60 seconds divided by the number of binding entries. Thus, the more entries are, the shorter interval is, but the shortest interval is no less than 500 ms.
Use the dhcp relay security tracker command to set a refreshing interval at which the relay agent contacts the DHCP server for refreshing dynamic bindings.
Use the undo dhcp relay security tracker command to restore the default interval.
The default handshake interval is auto, the value of 60 seconds divided by the number of binding entries.
Example
# Set the handshake interval as 100 seconds.
[Sysname] dhcp relay security tracker 100
1.1.9  dhcp relay server-detect
undo dhcp relay server-detect
View
Parameter
None
Use the dhcp relay server-detect command to enable pseudo DHCP server detection on the DCHP relay agent.
Use the undo dhcp relay server-detect command to disable pseudo DHCP server detection.
By default, pseudo DHCP server detection is disabled.
Example
# Enable pseudo DHCP server detection on the DCHP relay agent.
[Sysname] dhcp relay server-detect
1.1.10  dhcp relay server-group
dhcp relay server-group group- ip ip-address
undo dhcp relay server-group group-id [ ip ip-address ]
View
Parameter
group-id: Specifies a DHCP server group number, a string of 0 to 19.
ip-address: Specifies a DHCP server IP address.
Use the dhcp relay server-group command to specify a DHCP server for a DHCP server group.
Use the undo dhcp relay server-group command to remove a DHCP server from a DHCP server group, if no ip ip-address is specified, all servers in the DHCP server group and the server group itself will be removed.
By default, no DHCP server is specified for a DHCP server group.
Note that:
l           You can specify up to twenty DHCP server groups on the relay agent.
l           You can configure up to eight DHCP servers for a server group.
l           The IP address of any DHCP server in a DHCP server group cannot be on the same network segment with the IP address of any interface used by the DHCP relay agent to connect to a client; otherwise, the client may not be able to obtain an IP address.
l           If a DHCP server group has been associated with some interfaces, you must remove these associations before you can delete the DHCP server group.
Related command: display dhcp relay server-group.
Example
# Specify DHCP server 1.1.1.1 for DHCP server group 1 on the relay agent.
[Sysname] dhcp relay server-group 1 ip 1.1.1.1
1.1.11  dhcp relay server-select
dhcp relay server-select group-id
undo dhcp relay server-select
View
VLAN interface view
Parameter
group-id: Specifies a DHCP group number to be correlated, a string of 0 to 19. The specified group must be an existing group containing at least a DHCP server.
Use the dhcp relay server-select command to correlate specified interface(s) to a specified DHCP server group.
Use the undo dhcp relay server-select command to remove a configured correlation.
By default, no correlation is configured for an interface on the relay agent.
Note that an interface on the relay agent can only be correlated to one DHCP server group, and a newly configured correlation overwrites the previous one. If the server group in the new correlation does not exist, the new configuration will not work. The interface still maintains the previous correlation.
Example
# Correlate VLAN interface 1 to DHCP server group 1.
[Sysname-Vlan-interface1] dhcp relay server-select 1
1.1.12  dhcp select relay
dhcp select relay
undo dhcp select relay
View
VLAN interface view
Parameter
None
Use the dhcp select relay command to enable the relay agent on the current interface, specified or all interfaces. Upon receiving requests from an enabled interface, the relay agent will forward these requests to outside DHCP servers for IP address allocation.
Use the undo dhcp select relay command to restore the default on interface(s).
By default, an interface does not operate in any DHCP mode.
Example
# Enable the DHCP relay agent on the interface VLAN interface1.
[Sysname-Vlan-interface1] dhcp select relay
1.1.13  display dhcp relay
display dhcp relay { all | interface interface-type interface-number }
View
Parameter
all: Specifies all interfaces correlated to which to display information about DHCP server groups.
interface interface-type interface-number: Specifies an interface correlated to which to display information about DHCP server groups.
Use the display dhcp relay command to display information about DHCP server groups correlated to an interface or all interfaces.
Example
# Display information about DHCP server groups correlated to all interfaces.
<Sysname> display dhcp relay all
    Interface name            Server-group
    Vlan-interface2                  2
Table 1-1 Description on fields of the display dhcp relay all command
Interface name
Interface name
Server-group
DHCP server group number correlated to the interface.
1.1.14  display dhcp relay security
display dhcp relay security [ ip-address | dynamic | static ]
View
Parameter
ip-address: Displays the binding information of an IP address.
dynamic: Displays information about dynamic bindings.
static: Displays information about static bindings.
Use the display dhcp relay security command to display information about bindings of DHCP relay agents. If no parameter is specified, information about all bindings will be displayed.
Example
# Display information about all bindings.
[Sysname] display dhcp relay security
IP Address      MAC Address     Type
 10.1.1.1       00e0-0000-0001  Static
 10.1.1.5       00e0-0000-0000  Static
---   2 dhcp-security item(s) found   ---
Table 1-2 Description on fields of the display dhcp relay security command
IP Address
Client IP address
MAC Address
Client MAC address
Type of binding, including dynamic and static
1.1.15  display dhcp relay security statistics
View
Parameter
None
Use the display dhcp relay security statistics command to display statistics information about bindings of DHCP relay agents.
Example
# Display statistics about client address binding entries.
<Sysname> display dhcp relay security statistics
Static Items     :0
Dynamic Items        :0
Temporary Items  :0
All Items            :0
Table 1-3 Description on fields of display dhcp relay security statistics
Static Items
Static client address binding items
Dynamic Items
Dynamic client address binding items
Temporary Items
Temporary client address binding items
All Items
All client address binding items
1.1.16  display dhcp relay security tracker
View
Parameter
None
Use the display dhcp relay security tracker command to display the interval for refreshing dynamic bindings on the relay agent.
Example
# Display the interval for refreshing dynamic bindings on the relay agent.
[Sysname] display dhcp relay security tracker
Current tracker interval: 10s (Specified by user)
The interval is 10 seconds.
1.1.17  display dhcp relay server-group
display dhcp relay server-group { group-id | all }
View
Parameter
group-id: Displays the information of the specified DHCP server group numbered from 0 to 19.
all: Displays the information of all DHCP server groups.
Use the display dhcp relay server-group command to display the configuration information of a specified or all DHCP server groups.
Example
# Display IP addresses of DHCP servers in DHCP server group 1.
<Sysname> display dhcp relay server-group 1
    No.            Group IP
    1              1.1.1.1
    2              1.1.1.2
Table 1-4 Description on fields of the display dhcp relay server-group command
No.
Sequence number
Group IP
IP address in the server group
1.1.18  display dhcp relay statistics
display dhcp relay statistics [ server-group { group-id | all } ]
View
Parameter
group-id: Specifies a server group number a string of 0 to 19 about which to display DHCP packet statistics.
all: Specifies all server groups about which to display DHCP packet statistics. Information for each group will be displayed.
Use the display dhcp relay statistics command to display DHCP packet statistics related to a specified or all DHCP server groups.
Note that if no parameter (server-group and all) is specified, all DHCP packet statistics on the relay agent will be displayed.
Example
# Display all DHCP packet statistics on the relay agent.
<Sysname> display dhcp relay statistics
     Bad packets received:                   0
     DHCP packets received from clients: 20
         DHCPDISCOVER packets received:      10
         DHCPREQUEST packets received:       10
         DHCPINFORM packets received:        0
         DHCPRELEASE packets received:       0
         DHCPDECLINE packets received:       0
         BOOTPREQUEST packets:               0
     DHCP packets received from servers: 20
         DHCPOFFER packets received:     10
         DHCPACK packets received:           10
         DHCPNAK packets received:           0
         BOOTPREPLY packets:             0
     DHCP packets relay to servers:          0
         DHCPDISCOVER packets relayed:       0
         DHCPREQUEST packets relayed:        0
         DHCPINFORM packets relayed:         0
         DHCPRELEASE packets relayed:        0
         DHCPDECLINE packets relayed:        0
         BOOTPREQUEST packets relayed:       0
     DHCP packets relay to clients:          0
         DHCPOFFER packets relayed:           0
         DHCPACK packets relayed:             0
         DHCPNAK packets relayed:             0
         BOOTPREPLY packets relayed:          0
     DHCP packets send to servers:           0
         DHCPDISCOVER packets sended:         0
         DHCPREQUEST packets sended:          0
         DHCPINFORM packets sended:           0
         DHCPRELEASE packets sended:          0
         DHCPDECLINE packets sended:          0
         BOOTPREQUEST packets sended:         0
     DHCP packets send to clients:           0
         DHCPOFFER packets sended:            0
         DHCPACK packets sended:              0
         DHCPNAK packets sended:              0
         BOOTPREPLY packets sended:           0
# Display DHCP packet statistics related to every server group on the relay agent.
<Sysname> display dhcp relay statistics server-group all
DHCP relay server-group           #2
     Packet type               Packet number
 Client -> Server:
     DHCPDISCOVER                   5
     DHCPREQUEST                5
     DHCPINFORM                         0
     DHCPRELEASE                    0
     DHCPDECLINE                    0
     BOOTPREQUEST                   0
 Server -> Client:
     DHCPOFFER                      5
     DHCPACK                        5
     DHCPNAK                        0
     BOOTPREPLY                     0
DHCP relay server-group           #3
 Client -> Server:
     DHCPDISCOVER                   5
     DHCPREQUEST                5
     DHCPINFORM                         0
     DHCPRELEASE                    0
     DHCPDECLINE                    0
     BOOTPREQUEST                   0
 Server -> Client:
     DHCPOFFER                      5
     DHCPACK                        5
     DHCPNAK                        0
     BOOTPREPLY                     0
1.1.19  reset dhcp relay statistics
reset dhcp relay statistics [ server-group group-id ]
View
Parameter
server-group group-id: Specifies a server group number a string of 0 to 19 about which to remove statistics from the relay agent.
Use the reset dhcp relay statistics command to remove statistics from the relay agent.
If no server-group is specified, all statistics will be removed from the relay agent.
Related command: display dhcp relay statistics.
Example
# Remove all statistics from the DHCP relay agent.
<Sysname> reset dhcp relay statistics
Chapter 2  DHCP Snooping Commands
&  Note:
l      The DHCP snooping supports no link aggregation. If an Ethernet port is added into an aggregation group, DHCP Snooping configuration on it will not take effect. When the port is removed from the group, DHCP Snooping can take effect.
l      The DHCP snooping enabled device does not work if it is between the DHCP relay agent and DHCP server, and it can work when it is between the DHCP client and relay agent or between the DHCP client and server.
l      The DHCP Snooping enabled device cannot be a DHCP server, relay agent or client, so DHCP Snooping cannot be enabled on a DHCP server, relay agent or client.
2.1  DHCP Snooping Configuration Commands
2.1.1  dhcp-snooping
dhcp-snooping
undo dhcp-snooping
View
Parameter
None
Use the dhcp-snooping command to enable DHCP snooping.
Use the undo dhcp-snooping command to disable DHCP snooping.
With DHCP snooping disabled, all ports can forward responses from any DHCP servers and does not record binding information about MAC addresses of DHCP clients and the obtained IP addresses.
By default, DHCP snooping is disabled.
Related command: display dhcp-snooping.
Example
# Enable DHCP snooping.
[Sysname] dhcp-snooping
2.1.2  dhcp-snooping trust
dhcp-snooping trust
undo dhcp-snooping trust
View
Ethernet port view
Parameter
None
Use the dhcp-snooping trust command to set a port as trusted.
Use the undo dhcp-snooping trust command to restore the default state of a port.
All ports are untrusted by default.
Related command: display dhcp-snooping trust.
Example
# Set port GigabitEthernet 1/0/1 as trusted.
[Sysname-GigabitEthernet1/0/1] dhcp-snooping trust
2.1.3  display dhcp-snooping
View
Parameter
None
Use the display dhcp-snooping command to display the binding information recorded through DHCP snooping.
Related command: dhcp-snooping.
&  Note:
Using the display dhcp-snooping command displays IP-to-MAC bindings that are present both in the DHCP-ACK and DHCP-REQUEST messages.
Example
# Display DHCP snooping address binding information.
<Sysname> display dhcp-snooping
 DHCP Snooping is enabled.
 The client binding table for all untrusted ports.
 Type : D--Dynamic , S--Static
 Type IP Address       MAC Address      Lease      VLAN Interface
D     10.1.1.1          00e0-fc00-0006   286        1     GigabitEthernet1/0/1
---   1 dhcp-snooping item(s) found   ---
Table 2-1 Description on fields of the display dhcp snooping command
Binding type
IP Address
IP address assigned to the DHCP client
MAC Address
MAC address of the DHCP client
Lease
Lease period of the IP address in seconds
VLAN
VLAN where the port connecting the DHCP client resides
Port to which the DHCP client is connected
2.1.4  display dhcp-snooping trust
View
Parameter
None
Use the display dhcp-snooping trust command to display information about trusted ports.
Related command: dhcp-snooping trust.
Example
# Display information about trusted ports.
<Sysname> display dhcp-snooping trust
 DHCP-Snooping trust becomes active.
 Interface                                       Trusted
 GigabitEthernet1/0/1                          Trusted
The above output shows that DHCP snooping is enabled, DHCP snooping trust is active, and port GigabitEthernet1/0/1 is trusted
Chapter 3  DHCP Client Configuration Commands
l      The DHCP client configuration is supported only on VLAN interfaces.
l      When multiple VLAN interfaces having the same MAC address use DHCP for IP address acquisition via a relay agent, the DHCP server cannot be the Windows 2000 Server or Windows 2003 Server.
l      DHCP Snooping cannot be configured on the DHCP client.
3.1  DHCP Client Configuration Commands
3.1.1  display dhcp client
View
Parameter
verbose: Specifies verbose DHCP client information to be displayed.
interface interface-type interface-number: Specifies an interface of which to display DHCP client information.
Use the display dhcp client command to display DHCP client information. If no interface interface-type interface-number is specified, DHCP client information of all interfaces will be displayed.
Example
# Display DHCP client information of all interfaces.
<Sysname> display dhcp client
Vlan-interface1 DHCP client information:
 Current machine state: BOUND
 Allocated IP: 40.1.1.20 255.255.255.0
 Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
 DHCP server: 40.1.1.2
# Display verbose DHCP client information.
<Sysname> display dhcp client verbose
 Lease from 2005.08.13 15:37:59   to   2005.08.16 15:37:59
 Transaction ID: 0x1c09322d
 Default router: 40.1.1.2
 DNS server: 44.1.1.11
 DNS server: 44.1.1.12
 Domain name: ddd.com
Client ID: 3030-3066-2e65-3234-
392e-3830-3438-2d56-
6c61-6e2d-696e-7465-
7266-6163-6531
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
Table 3-1  Description on fields of the display dhcp client command
Information of the interface acting as the DHCP client
DHCP client current machine state
Allocated IP
The IP address allocated by the DHCP server
Allocated lease
The allocated lease time
T1
The 1/2 lease time (in seconds) of the DHCP client IP address
T2
The 7/8 lease time (in seconds) of the DHCP client IP address
Lease from….to….
The start and end time of the lease.
DHCP Server
DHCP server IP address that assigned the IP address
Transaction ID
Transaction ID, a random number chosen by the client to identify an IP address allocation.
Default router
The gateway address assigned to the client
DNS server
The DNS server address assigned to the client
Domain name
The domain name assigned to the client
Client ID
Client ID
How long the T1 (1/2 lease time) timer will timeout.
3.1.2  ip address dhcp-alloc
ip address dhcp-alloc [ client-identifier mac interface-type interface-number ]
undo ip address dhcp-alloc
View
Interface view
Parameter
client-identifier mac interface-type interface-number: Specifies the MAC address of an interface using which as the client ID to obtain an IP address.
Use the ip address dhcp-alloc command to configure an interface to use DHCP for IP address acquisition.
Use the undo ip address dhcp-alloc command to cancel an interface from using DHCP.
If no parameter is specified, the client uses a character string comprised of the current interface name and MAC address as its ID for address acquisition.
By default, an interface does not use DHCP for IP address acquisition.
Notice that: The DHCP client sends a DHCP-RELEASE message for releasing the IP address obtained via DHCP, if the interface of the client is down, the message cannot be sent.
Example
# Configure interface VLAN interface 1 to use DHCP for IP address acquisition.
[Sysname-Vlan-interface1] ip address dhcp-alloc
Chapter 4  BOOTP Client Configuration Commands
&  Note:
l      BOOTP client configuration can only be used on VLAN interfaces.
l      If several VLAN interfaces sharing the same MAC address obtain IP addresses through a BOOTP relay agent, the BOOTP server cannot be a Windows 2000 Server or Windows 2003 Server.
l      DHCP Snooping must be disabled on a BOOTP client.
4.1  BOOTP Client Configuration Commands
4.1.1  display bootp client
View
Parameter
interface interface-type interface-number: Specifies an interface.
Use the display bootp client command to display related information about a BOOTP client.
Note:
l           If interface interface-type interface-number is not specified, the command will display information about BOOTP clients on all interfaces.
l           If interface interface-type interface-number is specified, the command will display information about the BOOTP client on the specified interface.
Example
# Display related information of the BOOTP client on Vlan-interface1.
<Sysname> display bootp client interface vlan-interface 1
Vlan-interface1 BOOTP client information:
Allocated IP: 169.254.0.2 255.255.0.0
Transaction ID = 0x3d8a7431
Mac Address  00e0-fc0a-c3ef
Table 4-1 Description on fields of the display bootp client command
Information of the interface serving as a BOOTP client
Allocated IP
BOOTP client’s IP address allocated by the BOOTP server
Transaction ID
Value of the XID field in a BOOTP message, namely, a random number used to match a response message from the BOOTP server while the BOOTP client sends a BOOTP request to the BOOTP server. If the values of the XID field are different in the BOOTP response and request, the BOOTP client will drop the BOOTP response.
Mac Address
MAC address of a BOOTP client
4.1.2  ip address bootp-alloc
undo ip address bootp-alloc
View
Interface view
Parameter
None
Use the ip address bootp-alloc command to enable an interface to obtain an IP address through BOOTP.
Use the undo ip address bootp-alloc command to disable the interface from obtaining an IP address through BOOTP.
By default, an interface does not obtain an IP address through BOOTP.
Related command: display bootp client.
Example
# Configure Vlan-interface1 to obtain IP address through BOOTP protocol
[Sysname-Vlan-interface1] ip address bootp-alloc
