05-接口管理
01-HH3C-IF-EXT-MIB
本章节下载 01-HH3C-IF-EXT-MIB  (827.35 KB)
01-HH3C-IF-EXT-MIB
  录
HH3C-IF-EXT-MIB
功能介绍
MIB文件名
告警信息
hh3cIfPortUp
hh3cIfPortDown
hh3cIfMonInputUsageRising
hh3cIfMonInputUsageResume
hh3cIfMonOutputUsageRising
hh3cIfMonOutputUsageResume
hh3cIfMonInputErrorAlarmRising
hh3cIfMonInputErrorAlarmResume
hh3cIfMonOutputErrorAlarmRising
hh3cIfMonOutputErrorAlarmResume
hh3cIfMonSdhErrorRising
hh3cIfMonSdhErrorResume
hh3cIfMonSdhB1ErrorRising
hh3cIfMonSdhB1ErrorResume
hh3cIfMonSdhB2ErrorRising
hh3cIfMonSdhB2ErrorResume
hh3cIfMonCRCErrorRising
hh3cIfMonCRCErrorResume
hh3cIfMonRxPauseFrameRising
hh3cIfMonRxPauseFrameResume
hh3cIfMonTxPauseFrameRising
hh3cIfMonTxPauseFrameResume
hh3cIfPfcOutRising
hh3cIfBufferInDiscardAlarm
hh3cIfBufferInDiscardResume
hh3cIfHalfDuplexRising
hh3cIfChangeMultiChassis
hh3cIfChangeMultiChassisResume
hh3cIfCfgRecoverOverSlot
hh3cIfCfgRecoverOverSubSlot
hh3cIfInterfaceDelete
hh3cIfErrordown
hh3cIfErrordownRecovery
hh3cIfHalfDuplexClear
hh3cIfEgressDropAlarm
hh3cIfEgressDropRecover
hh3cIfBoardEgressDropAlarm
hh3cIfBoardEgressDropRecover
hh3cIfComboTypeChange
hh3cIfIngressAgingDropAlarm
hh3cIfIngressAgingDropResume
hh3cIfMonInputJamDiscardAlarm
hh3cIfMonInputJamDiscardResume
hh3cIfMonOutputJamDiscardAlarm
hh3cIfMonOutputJamDiscardResume
hh3cIfMonPktDropRateRising
hh3cIfMonPktDropRateRecover
hh3cIfMonBadBytesErrorRising
hh3cIfMonBadBytesErrorResume
hh3cIfMonPortCrcRateExceed
hh3cIfMonPortErrorRateExceed
hh3cIfMonInBCRapidChange
hh3cIfMonInBCRapidRecover
hh3cIfMonPortCrcRateExceedResume
hh3cIfFlowControlDLAlarm
hh3cIfFlowControlDLAlarmResume
hh3cIfOutputErrorAlarm
hh3cIfOutputErrorAlarmResume
hh3cIfCableSnrAbnormal
hh3cIfCableSnrNormal
hh3cIfCableSnrDetectNotSupport
hh3cIfSfpNotSupportSingleFiber
hh3cIfLRMStateAbnormal
hh3cIfSfpWorkOnlyNonNego
hh3cIfPfcDeadLockAlarm
hh3cIfPfcDeadLockResume
hh3cIfPfcTurnOffAlarm
hh3cIfPfcTurnOffResume
hh3cIfQueueAlarm
hh3cIfQueueResume
hh3cIfQueueStatDiscardAlarm
hh3cIfQueueStatDiscardResume
hh3cIfQueueEgressCongestionAlarm
hh3cIfQueueEgressCongestionClear
hh3cIfAggPortBwChange
hh3cIfRateOfTrafficRising
HH3C-IF-EXT-MIB
功能介绍
HH3C-IF-EXT-MIB 用于提供对接口进行管理和描述的信息
MIB文件名
hh3c-if-ext.mib
告警信息
hh3cIfPortUp
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.5
物理端口的物理状态由DOWN变为UP告警
恢复告警
重要
开启
【触发原因】
当物理端口的物理状态从DOWN变为UP时候生成该告警。
产出此告警的可能原因包括:
在接口上执行了undo shutdown命令。
接口或链路故障被恢复。
接口物理状态变为Up。
【系统影响】
接口能正常转发报文。
【状态控制】
开启
命令行:snmp-agent trap enable standard linkup
关闭
命令行:undo snmp-agent trap enable standard linkup
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
1.3.6.1.2.1.2.2.1.1 (ifIndex)
接口索引
ifIndex
Integer32
同MIB标准取值
1.3.6.1.2.1.2.2.1.2 (ifDescr)
接口描述
ifIndex
OCTET STRING
OCTET STRING(0..255)
【处理建议】
正常运行信息,无需处理。
hh3cIfPortDown
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.6
物理端口的物理状态由UP变为DOWN告警
故障告警
重要
1.3.6.1.4.1.25506.2.40.3.0.5 (hh3cIfPortUp)
开启
【触发原因】
当物理端口的物理状态从UP变为DOWN时候生成该告警。
产出此告警的可能原因包括:
接口物理链路变为Down,链路断开。
接口被shutdown。
【系统影响】
接口不能正常转发报文。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
1.请在接口视图下执行命令display this,查看两端接口是否被shutdown。如被shutdown请在接口视图下执行undo shutdown命令。
2.请查看物理链接是否正常(包括网线、光模块等硬件是否松动或脱落),请正确连接物理线路。
3.如果问题无法解决,请联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.1
入方向带宽利用率超过高门限告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.2 (hh3cIfMonInputUsageResume)
开启
【触发原因】
当入方向的带宽利用率大于高门限时,发送告警。
【系统影响】
当接口入方向带宽利用率接近100%时,业务流量可能出现延时或丢包。
【状态控制】
开启
命令行:snmp-agent trap enable ifmonitor input-usage
关闭
命令行:undo snmp-agent trap enable ifmonitor input-usage
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.1 (hh3cIfMonInputUsageLowThres)
入方向带宽利用率低门限
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.2.1.1.2 (hh3cIfMonInputUsageHighThres)
入方向带宽利用率高门限
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.1.1.1.1 (hh3cIfMonInputUsageStatistics)
入方向带宽利用率统计
hh3cIfMonInputRateStatistics
Counter64
同MIB标准取值
【处理建议】
请检查接口下的高门限是否设置过低。
● 若设置过低,可以通过port ifmonitor input-usage命令修改门限值。
● 如果设置合理,请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
入方向带宽利用率恢复正常
恢复告警
警告
开启
【触发原因】
当入方向的带宽利用率从高门限恢复到低门限以下时,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
入方向带宽利用率低门限
Unsigned32
0-100
入方向带宽利用率高门限
Unsigned32
0-100
入方向带宽利用率统计
Counter64
同MIB标准取值
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.3
出方向带宽利用率超过高门限告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.4 (hh3cIfMonOutputUsageResume)
开启
【触发原因】
当出方向的带宽利用率大于高门限时,发送告警。
【系统影响】
当接口出方向带宽利用率接近100%时,业务流量可能出现延时或丢包。
【状态控制】
开启
命令行:snmp-agent trap enable ifmonitor output-usage
关闭
命令行:undo snmp-agent trap enable ifmonitor output-usage
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.3 (hh3cIfMonOutputUsageLowThres)
出方向带宽利用率低门限
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.2.1.1.4 (hh3cIfMonOutputUsageHighThres)
出方向带宽利用率高门限
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.1.1.1.2 (hh3cIfMonOutputUsageStatistics)
出方向带宽利用率统计
Counter64
同MIB标准取值
【处理建议】
请检查接口下的高门限是否设置过低。
● 若设置过低,可以通过port ifmonitor output-usage命令修改门限值。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
出方向带宽利用率恢复正常
恢复告警
警告
开启
【触发原因】
当出方向的带宽利用率从高门限恢复到低门限以下时,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
出方向带宽利用率低门限
Unsigned32
1-4294967295
出方向带宽利用率高门限
Unsigned32
1-4294967295
出方向带宽利用率统计
Counter64
同MIB标准取值
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.5
入方向错包个数大于高门限告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.6 (hh3cIfMonInputErrorAlarmResume)
开启
【触发原因】
当在设定的时间内,统计入方向的错报个数大于高门限时,发送告警。
产出此告警的可能原因包括:
光模块故障。
光纤或者链路故障。
【系统影响】
可能会导致业务流量被丢弃。
【状态控制】
开启
命令行:snmp-agent trap enable ifmonitor input-error
关闭
命令行:undo snmp-agent trap enable ifmonitor input-error
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.6 (hh3cIfMonInputErrorAlarmHighThres)
入方向错误告警高门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.5 (hh3cIfMonInputErrorAlarmLowThres)
入方向错误告警低门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.3 (hh3cIfMonInputErrorAlarmStatistics)
入方向错误告警统计
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.7 (hh3cIfMonInputErrorAlarmInterval)
入方向错误告警统计时间间隔
Unsigned32
0-65535
【处理建议】
1.更换光模块,检查告警是否恢复。
2.更换光纤或者链路,检查故障是否恢复。
3.请检查接口下的高门限是否设置过低。
  - 若设置过低,可以通过port ifmonitor input-error命令修改门限值。
  - 如果设置合理,请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
入方向错包个数恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,统计入方向的错报个数从高门限降低到低门限时,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
开启
关闭
命令行:undo snmp-agent trap enable ifmonitor input -error
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
入方向错误告警低门限
Unsigned32
1-4294967295
入方向错误告警高门限
Unsigned32
1-4294967295
入方向错误告警统计
Counter64
1-4294967295
入方向错误告警统计时间间隔
Unsigned32
0-65535
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.7
出方向错包个数大于高门限告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.8 (hh3cIfMonOutputErrorAlarmResume)
开启
【触发原因】
当在设定的时间内,统计出方向的错报个数大于高门限时,发送告警。
【系统影响】
可能会导致业务流量被丢弃。
【状态控制】
开启
命令行:snmp-agent trap enable ifmonitor output-error
关闭
命令行:undo snmp-agent trap enable ifmonitor output-error
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.9 (hh3cIfMonOutputErrorAlarmHighThres)
出方向错误告警高门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.8 (hh3cIfMonOutputErrorAlarmLowThres)
出方向错误告警低门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.4 (hh3cIfMonOutputErrorAlarmStatistics)
出方向错误告警统计
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.10 (hh3cIfMonOutputErrorAlarmInterval)
出方向错误告警统计时间间隔
Unsigned32
0-65535
【处理建议】
1.请检查光纤是否插好,插好光纤后检查是否恢复。
2.检查物理链路是否正常。
3.执行命令display interface命令查看故障接口的光模块接收光功率(Tx Power)是否处于正常范围,查看设备两端的协商模式配置、时钟模式及扰码模式(Link protocol,clock,scramble)是否一致,如不一致请修改设备两端的协商模式配置,然后查看告警是否消除。
4.请检查接口下的高门限是否设置过低,若设置过低,可以通过port ifmonitor output-error命令修改门限值,
5.如果设置合理,请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
出方向错包个数恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,统计出方向的错包个数从高门限恢复到低门限,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
出方向错误告警高门限
Unsigned32
1-4294967295
出方向错误告警低门限
Unsigned32
1-4294967295
出方向错误告警统计
Counter64
1-4294967295
出方向错误告警统计时间间隔
Unsigned32
0-65535
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.9
Sdh错包个数大于高门限告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.10 (hh3cIfMonSdhErrorResume)
开启
【触发原因】
当在设定的时间内,统计Sdh的错包个数大于高门限时,发送告警。
产出此告警的可能原因包括:
光模块故障。
光纤故障。
【系统影响】
可能会导致业务流量被丢弃。
【状态控制】
开启
命令行:snmp-agent trap enable ifmonitor sdh-error
关闭
命令行:undo snmp-agent trap enable ifmonitor sdh-error
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.11 (hh3cIfMonSdhErrorLowThres)
Sdh错误低门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.12 (hh3cIfMonSdhErrorHighThres)
Sdh错误高门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.5 (hh3cIfMonSdhErrorStatistics)
Sdh错误统计
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.13 (hh3cIfMonSdhErrorInterval)
Sdh错误统计时间间隔
Unsigned32
0-65535
【处理建议】
1.更换光模块,检查告警是否恢复。
2.更换光纤,检查故障是否恢复。
3.请检查接口下的高门限是否设置过低,可以通过port ifmonitor sdh-error命令修改门限值。
4.请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
Sdh错包个数恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,统计Sdh的错包个数从高门限恢复到低门限,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
Sdh错误低门限
Unsigned32
1-4294967295
Sdh错误高门限
Unsigned32
1-4294967295
Sdh错误统计
Counter64
1-4294967295
Sdh错误统计时间间隔
Unsigned32
0-65535
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.11
SdhB1错包个数大于高门限告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.12 (hh3cIfMonSdhB1ErrorResume)
开启
【触发原因】
当在设定的时间内,统计SdhB1的错包个数大于高门限时,设备发送此告警。
【系统影响】
可能会导致业务流量被丢弃。
【状态控制】
开启
命令行:snmp-agent trap enable ifmonitor sdh-b1-error
关闭
命令行:undo snmp-agent trap enable ifmonitor sdh-b1-error
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.14 (hh3cIfMonSdhB1ErrorLowThres)
SdhB1错误低门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.15 (hh3cIfMonSdhB1ErrorHighThres)
SdhB1错误高门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.6 (hh3cIfMonSdhB1ErrorStatistics)
SdhB1错误统计
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.16 (hh3cIfMonSdhB1ErrorInterval)
SdhB1错误统计时间间隔
Unsigned32
0-65535
【处理建议】
1.请检查链路(包括光纤、光模块、传输设备、跳线架等部件)是否存在故障,更换故障部件,并将链路连接正常,检查是否恢复。
2.请检查接口下的高门限是否设置过低,可以通过port ifmonitor sdh-b1-error命令修改门限值。
3.请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
SdhB1错包个数恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,统计SdhB1的错包个数从高门限恢复到低门限,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
SdhB1错误低门限
Unsigned32
1-4294967295
SdhB1错误高门限
Unsigned32
1-4294967295
SdhB1错误统计
Counter64
1-4294967295
SdhB1错误统计时间间隔
Unsigned32
0-65535
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.13
SdhB2错包个数大于高门限告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.14 (hh3cIfMonSdhB2ErrorResume)
开启
【触发原因】
当在设定的时间内,统计SdhB2的错包个数大于高门限时,发送告警。
【系统影响】
可能会导致业务流量被丢弃。
【状态控制】
开启
命令行:snmp-agent trap enable ifmonitor sdh-b2-error
关闭
命令行:undo snmp-agent trap enable ifmonitor sdh-b2-error
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.17 (hh3cIfMonSdhB2ErrorLowThres)
SdhB2错误低门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.18 (hh3cIfMonSdhB2ErrorHighThres)
SdhB2错误高门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.7 (hh3cIfMonSdhB2ErrorStatistics)
SdhB2错误统计
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.19 (hh3cIfMonSdhB2ErrorInterval)
SdhB2错误统计时间间隔
Unsigned32
0-65535
【处理建议】
1.请检查链路(包括光纤、光模块、传输设备、跳线架等部件)是否存在故障。
2.更换故障部件,并将链路连接正常,检查是否恢复。
3.请检查接口下的高门限是否设置过低,相关配置命令:port ifmonitor sdh-b2-error,如果设置合理,请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
SdhB2错包个数恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,统计SdhB2的错包个数从高门限恢复到低门限,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
SdhB2错误低门限
Unsigned32
1-4294967295
SdhB2错误高门限
Unsigned32
1-4294967295
SdhB2错误统计
Counter64
1-4294967295
SdhB2错误统计时间间隔
Unsigned32
0-65535
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.15
CRC错包个数大于高门限告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.16 (hh3cIfMonCRCErrorResume)
开启
【触发原因】
当在设定的时间内,统计CRC的错包个数大于高门限时,发送告警。
产出此告警的可能原因包括:
光模块故障。
光纤或者链路故障。
【系统影响】
可能会导致业务流量被丢弃。
【状态控制】
开启
命令行:snmp-agent trap enable ifmonitor crc-error
关闭
命令行:undo snmp-agent trap enable ifmonitor crc-error
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.21 (hh3cIfMonCRCErrorHighThres)
CRC错误高门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.20 (hh3cIfMonCRCErrorLowThres)
CRC错误低门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.8 (hh3cIfMonCRCErrorStatistics)
CRC错误统计
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.22 (hh3cIfMonCRCErrorInterval)
CRC错误统计时间间隔
Unsigned32
0-65535
1.3.6.1.4.1.25506.2.40.5.2.1.1.23 (hh3cIfMonCRCErrType)
CRC错误统计类型
INTEGER
1-2
【处理建议】
3.请检查接口下的高门限是否设置过低,相关配置命令:port ifmonitor crc-error,如果设置合理,请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
CRC错包个数恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,统计CRC的错包个数从高门限恢复到低门限,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
CRC错误高门限
Unsigned32
1-4294967295
CRC错误低门限
Unsigned32
1-4294967295
CRC错误统计
Counter64
1-4294967295
CRC错误统计时间间隔
Unsigned32
0-65535
CRC错误统计类型
INTEGER
1-2
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.17
接收到的Rx-pause帧数大于高门限告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.18 (hh3cIfMonRxPauseFrameResume)
开启
【触发原因】
当在设定的时间内,统计接收到的Rx-pause帧数大于高门限时,发送此告警信息。
产出此告警的可能原因包括:
pause帧接收率超过门限。
连续收到pause帧的时间较长。
【系统影响】
可能会导致业务流量被丢弃。
【状态控制】
开启
命令行:snmp-agent trap enable ifmonitor rx-pause
关闭
命令行:undo snmp-agent trap enable ifmonitor rx-pause
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.25 (hh3cIfMonRxPauseFrameHighThres)
暂停帧高门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.24 (hh3cIfMonRxPauseFrameLowThres)
暂停帧低门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.9 (hh3cIfMonRxPauseFrameStatistics)
暂停帧统计
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.26 (hh3cIfMonRxPauseFrameInterval)
暂停帧统计时间间隔
Unsigned32
0-65535
【处理建议】
1.减少对端接口接收的业务流量,检查告警是否恢复。
2.请检查接口下的高门限是否设置过低,相关配置命令:port ifmonitor rx-pause,如果设置合理,请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
接收到的pause帧数恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,统计接收到的Rx-pause帧数从高门限恢复到低门限时,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
暂停帧高门限
Unsigned32
1-4294967295
暂停帧低门限
Unsigned32
1-4294967295
暂停帧统计
Counter64
1-4294967295
暂停帧统计时间间隔
Unsigned32
0-65535
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.19
发送的Tx-pause帧数大于高门限告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.20 (hh3cIfMonTxPauseFrameResume)
开启
【触发原因】
当在设定的时间内,统计发送的Tx-pause帧数大于高门限时,发送此告警信息。
产出此告警的可能原因包括:
pause帧发送率超过门限。
连续发送pause帧的时间较长。
【系统影响】
可能会导致业务流量被丢弃。
【状态控制】
开启
命令行:snmp-agent trap enable ifmonitor tx-pause
关闭
命令行:undo snmp-agent trap enable ifmonitor tx-pause
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.28 (hh3cIfMonTxPauseFrameHighThres)
出方向暂停帧高门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.27 (hh3cIfMonTxPauseFrameLowThres)
出方向暂停帧低门限
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.10 (hh3cIfMonTxPauseFrameStatistics)
出方向暂停帧统计
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.29 (hh3cIfMonTxPauseFrameInterval)
出方向暂停帧统计时间间隔
Unsigned32
0-65535
【处理建议】
1.减少对端接口发送的业务流量,检查告警是否恢复。
2.请检查接口下的高门限是否设置过低,相关配置命令:port ifmonitor tx-pause,如果设置合理,请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
发送的Tx-pause帧数恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,统计发送的Tx-pause帧数从高门限恢复到低门限时,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
开启
关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
出方向暂停帧高门限
Unsigned32
1-4294967295
出方向暂停帧低门限
Unsigned32
1-4294967295
出方向暂停帧统计
Counter64
1-4294967295
出方向暂停帧统计时间间隔
Unsigned32
0-65535
【处理建议】
正常运行信息,无需处理。
hh3cIfPfcOutRising
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.7
PFC实际发送帧速率超过早期预警门限
事件告警
警告
开启
【触发原因】
PFC实际发送帧速率大于等于配置的早期预警门限阈值。
【系统影响】
可能导致出方向PFC报文丢失。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.2.2.5.1.1 (hh3cIfPfcDot1pValue)
接口队列优先级
INTEGER
0-7
1.3.6.1.4.1.25506.2.40.2.2.5.1.3 (hh3cIfPfcDot1pOutPps)
指定优先级的出方向速率
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.2.2.5.1.5 (hh3cIfPfcDot1pOutPpsThreshold)
指定优先级的出方向速率门限
Unsigned32
1-4294967295
【处理建议】
1.请检查接口下的高门限是否设置过低,如果设置合理,请检查是否是端口故障。
● 如果PFC流接收速率超出门限,检查对端设备是否故障。
● 如果PFC流发送速率超出门限,检查本端设备是否故障。
● 如果PFC流发送和接收速率均超出门限,检查本端和对端设备是否故障。
2.请检查接口下的高门限是否设置过低,相关配置命令:priority-flow-control early-warning dot1p dot1p-list outpps pps-value,如果设置合理,请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.14
单板入方向缓存中有流量被丢弃
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.15 (hh3cIfBufferInDiscardResume)
开启
【触发原因】
单板入方向缓存中有流量被丢弃。
【系统影响】
单板入方向缓存流量被丢弃,单板入方向流量超出网板链路带宽。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
1.3.6.1.4.1.25506.2.40.1.6 (hh3cIfChassisIndex)
框索引
Integer32
0-65535
1.3.6.1.4.1.25506.2.40.1.7 (hh3cIfSlotIndex)
板索引
Integer32
0-65535
【处理建议】
优化网络,调整流量方案。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
单板上行流量从丢弃状态中恢复
恢复告警
警告
开启
【触发原因】
当在设定的时间内,网络已缓解网络拥塞,发送恢复告警。
【系统影响】
对系统没有影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框索引
Integer32
0-65535
板索引
Integer32
0-65535
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.16
端口在半双工模式发生告警
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.52 (hh3cIfHalfDuplexClear)
开启
【触发原因】
端口在半双工模式发生告警。
【系统影响】
端口工作在半双工模式下可能会丢包。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
0-65535
接口描述
ifIndex
OCTET STRING
【处理建议】
将端口设置为全双工模式。相关配置命令:duplex full。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.17
单框设备扩容到多框设备,接口信息发生变化
事件告警
通知
1.3.6.1.4.1.25506.2.40.3.0.18 (hh3cIfChangeMultiChassisResume)
开启
【触发原因】
单框设备扩容到多框设备,接口信息发生变化。
【系统影响】
接口名称从三维扩展到四维。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
0-65535
接口描述
ifIndex
OCTET STRING
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
多框设备回退单框设备,接口信息发生变化
事件告警
通知
开启
【触发原因】
多框设备回退单框设备,接口信息发生变化。
【系统影响】
接口名称从四维回退到三维。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
0-65535
接口描述
ifIndex
OCTET STRING
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.19
接口板配置已经恢复
事件告警
通知
开启
【触发原因】
接口板配置已经恢复。
【系统影响】
表明接口板配置恢复已经完成,该接口板进入可使用状态。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框索引
Integer32
0-65535
板索引
Integer32
0-65535
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.20
接口卡配置已经恢复
事件告警
通知
开启
【触发原因】
接口卡配置已经恢复。
【系统影响】
表明接口卡配置恢复已经完成,该接口卡进入可使用状态。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框索引
Integer32
0-65535
槽索引
Integer32
0-65535
1.3.6.1.4.1.25506.2.40.1.8 (hh3cIfSubSlotIndex)
子卡索引
Integer32
0-65535
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.21
接口被删除
事件告警
通知
开启
【触发原因】
接口被删除。
【系统影响】
相关依赖接口的业务可能会受影响。
【状态控制】
该告警无法关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口描述
ifIndex
OCTET STRING
【处理建议】
正常运行信息,无需处理。
hh3cIfErrordown
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.22
接口发生Error-down
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.23 (hh3cIfErrordownRecovery)
开启
【触发原因】
Error-Down是指设备检测到故障后将接口状态设置为ERROR DOWN状态,此时接口不能收发报文,接口指示灯为常灭接口发生Error-down。
产出此告警的可能原因包括:
接口CRC错包过多。
接口频繁震荡不稳定。
【系统影响】
接口流量不通,业务会中断。
【状态控制】
该告警无法关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
0-65535
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.1.9 (hh3cIfErrDownDesc)
Error down 原因描述
OCTET STRING
1:CRC error packets actively report physical down events. , 2:All serdes between interface cards and switching fabric modules fail., 3:IRF fabric configuration conflicts cause the IRF port to go down., 4:The optical powers of transceiver modules are low., 5:IRF physical interfaces receive a large number of protocol packets or IRF fabric error packets within a short period of time.,  6:STP Down, 7:The interface is shut down on the data link layer because the MACsec module has not successfully negotiated the communication encryption parameters for the interface. , 8:The interface is shut down because the unknown unicast, multicast, or broadcast traffic on the interface exceeds the corresponding upper threshold. , 9:Standby bit, 10:Loop detection, 11:Link-Aggregation interface down, 12:Monitor-Link uplink down, 13:IRF-link-down, 14:MAD Down, 15:Used by FC aggregation, 16:Tunnel-Bundle administratively down, 17:FC port security, 18:Used by the NPV feature of an FC interface, 19:Used by M-LAG MAD, 20:Used by MAC flapping, 21:ETH-rddc Down, 22:Used by CFD collaboration, 23:Used by LLDP, 24:OFP DOWN, 25:The interface is shut down on the data link layer because DLDP has detected unidirectional links on the interface, 26:Used by POSA, 27:Used by collaboration group, 28:DRNI MAD Down, 29:Link-Flap DOWN
【处理建议】
1.排查链路故障。
2.请收集告警信息和配置信息,并联系H3C技术支持工程师。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
接口Error-down恢复
恢复告警
警告
开启
【触发原因】
加入到堆叠逻辑端口的物理端口Error-down恢复。
【系统影响】
对系统没有影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
0-65535
接口描述
ifIndex
OCTET STRING
Error down 原因描述
OCTET STRING
同hh3cIfErrordown节点
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
接口自协商恢复成全双工模式
恢复告警
警告
开启
【触发原因】
接口自协商由半双工模式恢复成全双工模式时发送此告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.53
端口存在丢包
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.54 (hh3cIfEgressDropRecover)
开启
【触发原因】
当在设定的时间内,端口存在丢包时,发送此告警。
【系统影响】
端口出方向流量被丢弃。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.2.2.6.1.1 (hh3cIfQueId)
接口缓存队列id
hh3cIfQueId
INTEGER
que0(1),, que1(2),, que2(3),, que3(4),, que4(5),, que5(6),, que6(7),, que7(8)
【处理建议】
优化网络,调整流量方案。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
端口丢包情况恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,端口丢包情况恢复正常,发送恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.55
单板出方向单播流量被丢弃
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.56 (hh3cIfBoardEgressDropRecover)
开启
【触发原因】
当在设定的时间内,单板出方向单播流量被丢弃,发送告警。
【系统影响】
单板出方向单播流量被丢弃。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框索引
Integer32
0-65535
板索引
Integer32
0-65535
1.3.6.1.4.1.25506.2.40.1.21 (hh3cIfCpuId)
单板CPU ID
Unsigned32
Unsigned32 (0..4294967295)
【处理建议】
优化网络,调整流量方案。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
单板出方向单播流量被丢弃情况恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,单板出方向单播流量被丢弃情况恢复正常,发送恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框索引
Integer32
0-65535
板索引
Integer32
0-65535
单板CPU ID
Unsigned32
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.57
combo类型由于命令行配置发生变化
事件告警
通知
开启
【触发原因】
combo enable { copper | fiber }命令行配置发生变化时,发送告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.1.22 (hh3cIfOldComboType)
切换前combo类型
INTEGER
fiber(1),, copper(2)
1.3.6.1.4.1.25506.2.40.1.23 (hh3cIfNewComboType)
切换后combo类型
INTEGER
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.58
插槽入口缓冲区中的流量将因无计划而丢弃
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.59 (hh3cIfIngressAgingDropResume)
开启
【触发原因】
当在设定的时间内,高优先级队列的报文流量超过端口带宽,导致低优先级队列的报文得不到调度,发送此告警。
【系统影响】
单板的业务流量存在丢包。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框索引
Integer32
0-65535
板索引
Integer32
0-65535
单板CPU ID
Unsigned32
【处理建议】
优化网络,调整流量方案。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
插槽入口缓冲区中的流量被丢弃情况恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,插槽入口缓冲区中的流量被丢弃情况恢复正常,发送恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框索引
Integer32
0-65535
板索引
Integer32
0-65535
单板CPU ID
Unsigned32
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.35
接口入方向网络拥塞产生的丢包数超过阈值
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.36 (hh3cIfMonInputJamDiscardResume)
开启
【触发原因】
当在设定的时间内,接口入方向网络拥塞产生的丢包数超过阈值,发送此告警。
【系统影响】
如果出现该告警,说明网络中存在严重的网络拥塞。如果不及时处理,网络拥塞会造成更多的丢包,进而对业务的正常运行产生影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.1.1.1.15 (hh3cIfMonJamDiscardStatistics)
拥塞丢包统计数
Counter64
Counter64, (0..18446744073709551615)
1.3.6.1.4.1.25506.2.40.5.2.1.1.42 (hh3cIfMonJamDiscardThres)
拥塞丢包阈值
Unsigned32
1.3.6.1.4.1.25506.2.40.5.2.1.1.43 (hh3cIfMonJamDiscardInterval)
统计拥塞丢包计数的时间间隔
Unsigned32
Unsigned32 (0..65535)
【处理建议】
1.在接口视图下执行命令display this,查看有没有配置接口入方向限速。
2.在接口视图下执行命令qos lr inbound cir cir-value [ cbs cbs-value ]修改限速配置或执行命令undo qos lr inbound删除限速配置,查看告警是否恢复。
3.根据设备的具体业务情况,在接口视图下执行命令port ifmonitor input-usage high-threshold high-value修改接口拥塞丢包告警功能的告警阈值,查看告警是否恢复。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
接口入方向网络拥塞产生的丢包数恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,接口入方向网络拥塞产生的丢包数低于阈值,发送恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
拥塞丢包统计数
Counter64
拥塞丢包阈值
Unsigned32
统计拥塞丢包计数的时间间隔
Unsigned32
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.37
接口出方向网络拥塞产生的丢包数超过阈值
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.38 (hh3cIfMonOutputJamDiscardResume)
开启
【触发原因】
当在设定的时间内,接口出方向网络拥塞产生的丢包数超过阈值,发送告警。
【系统影响】
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
拥塞丢包统计数
Counter64
拥塞丢包阈值
Unsigned32
统计拥塞丢包计数的时间间隔
Unsigned32
【处理建议】
1.在接口视图下执行命令display this,查看有没有配置接口出方向限速。
2.在接口视图下执行命令qos lr outbound cir cir-value [ cbs cbs-value ]修改限速配置或执行命令undo qos lr outbound删除限速配置,查看告警是否恢复。
3.根据设备的具体业务情况,在接口视图下执行命令port ifmonitor output-usage high-threshold high-value修改接口拥塞丢包告警功能的告警阈值,查看告警是否恢复。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
接口出方向网络拥塞产生的丢包数恢复正常
恢复告警
警告
开启
【触发原因】
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
拥塞丢包统计数
Counter64
拥塞丢包阈值
Unsigned32
统计拥塞丢包计数的时间间隔
Unsigned32
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.39
接口板上丢弃的报文数目超过配置的告警阈值
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.40 (hh3cIfMonPktDropRateRecover)
开启
【触发原因】
当在设定的时间内,接口板上丢弃的报文数目超过配置的告警阈值,发送此告警。
【系统影响】
可能会使正常协议报文上送带宽被抢占,导致协议中断,数据丢失。
【状态控制】
该告警无法关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框索引
Integer32
0-65535
板索引
Integer32
0-65535
单板CPU ID
Unsigned32
1.3.6.1.4.1.25506.2.40.1.24 (hh3cIfDropRateThreshold)
丢包速率阈值
Integer32
Integer32(1..2147483647)
1.3.6.1.4.1.25506.2.40.1.25 (hh3cIfCurrentDropRate)
当前丢包速率
Integer32
1.3.6.1.4.1.25506.2.40.1.26 (hh3cIfDropRateInterval)
丢包速率周期
Integer32
1.3.6.1.4.1.25506.2.40.1.27 (hh3cIfMessageProtocol)
报文协议
Integer32
【处理建议】
1.如果配置单板丢失报文的告警时选择配置了shutdown,当单板接收到因丢失报文超出上限告警阈值时,关闭单板下所有接口,该单板将停止转发所有报文。因单板告警被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。
2.如果配置单板丢失报文的告警时选择配置了reboot,当单板接收到因丢失报文超出上限告警阈值时,重启单板。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
接口板上丢弃的报文数目恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,接口板上丢弃的报文数目低于阈值,发送恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框索引
Integer32
0-65535
板索引
Integer32
0-65535
单板CPU ID
Unsigned32
丢包速率阈值
Integer32
当前丢包速率
Integer32
丢包速率周期
Integer32
报文协议
Integer32
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.41
坏包字节数高于设置的告警门限
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.42 (hh3cIfMonBadBytesErrorResume)
开启
【触发原因】
当在设定的时间内,坏包字节数高于设置的告警门限,发送告警。
【系统影响】
可能导致业务倒换或中断。
【状态控制】
该告警无法关闭
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.1.1.1.16 (hh3cIfMonBadBytesStatistics)
坏包字节统计数
Counter64
Counter64 (0..18446744073709551615)
1.3.6.1.4.1.25506.2.40.5.2.1.1.44 (hh3cIfMonBadBytesThreshold)
坏包字节数阈值
Unsigned32
1.3.6.1.4.1.25506.2.40.5.2.1.1.45 (hh3cIfMonBadBytesDiscardInterval)
统计坏包字节数的时间间隔
Unsigned32
【处理建议】
1.当线路衰减过大时,请更换光纤,然后查看是否出现恢复告警。
2.在网管上查询对端站的发射光功率,如果发射光功率不正常,请更换对端站对应线路板,然后查看是否出现恢复告警。
3.更换本站上报告警的线路板,然后查看是否出现恢复告警。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
坏包字节数恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,坏包字节数低于设置的告警门限,发送恢复告警。
【系统影响】
业务恢复正常。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
坏包字节统计数
Counter64
坏包字节数阈值
Unsigned32
统计坏包字节数的时间间隔
Unsigned32
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.43
CRC错包速率大于等于1000个/秒
事件告警
警告
开启
【触发原因】
一个周期内,CRC错包速率大于等于1000个/秒,发送告警。
【系统影响】
该接口上的部分业务数据被丢弃。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.1.1.1.17 (hh3cIfMonErrorRateStatistics)
错包速率统计数
Counter64
1.3.6.1.4.1.25506.2.40.5.2.1.1.46 (hh3cIfMonErrorRateThres)
错包速率阈值
Unsigned32
1.3.6.1.4.1.25506.2.40.5.2.1.1.47 (hh3cIfMonErrorRateDiscardInterval)
统计错包速率的时间间隔
Unsigned32
【处理建议】
1.更换光模块,然后执行display interface命令查看接口的CRC错包数是否继续增加。
2.更换光纤,然后执行display interface命令查看接口的CRC错包数是否继续增加。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.44
CRC、Giants和Runts 三者的平均错包速率超过1000个/秒
事件告警
警告
开启
【触发原因】
一个周期内,CRC、Giants和Runts三者的平均错包速率超过1000个/秒,发送告警。
【系统影响】
该接口上的部分业务数据可能被丢弃。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
错包速率统计数
Counter64
错包速率阈值
Unsigned32
统计错包速率的时间间隔
Unsigned32
【处理建议】
1.更换光模块,然后执行display interface命令,查看接口的错包数是否继续增加。
2.更换光纤,然后执行display interface命令,查看接口的错包数是否继续增加。
3.执行命令jumboframe enable修改接口对报文长度的限制或修改报文长度,然后再执行display interface命令查看接口的错包数是否继续增加。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.45
接口入方向广播流量突变超过阈值
故障告警
警告
1.3.6.1.4.1.25506.2.40.6.0.46 (hh3cIfMonInBCRapidRecover)
开启
【触发原因】
当在设定的时间内,接口入方向广播流量突变超过阈值时(CurrentInputBroadcastRate ≥BaseInputBroadcastRate+InputBroadcastChangeThreshold),设备发送此告警。
【系统影响】
可能存在丢包现象。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.1.28 (hh3cIfCurrentFlowThreshold)
当前流量阈值
Counter64
1.3.6.1.4.1.25506.2.40.1.29 (hh3cIfCurrentFlowValue)
当前流量阈值
Counter64
【处理建议】
1.当CurrentInputBroadcastRate ≥ BaseInputBroadcastRate +InputBroadcastChangeThreshold时,请确认是否正常的广播流量增加,如果不是请检查链路中是否存在环路。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
接口入方向广播流量突变恢复正常
恢复告警
警告
开启
【触发原因】
当在设定的时间内,接口入方向广播流量突变低于阈值时(CurrentInputBroadcastRate≤BaseInputBroadcastRate- InputBroadcastChangeThreshold),设备发送此告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
当前流量阈值
Counter64
当前流量阈值
Counter64
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.6.0.47
CRC错包速率小于于等于1000个/秒
事件告警
警告
开启
【触发原因】
一个周期内,CRC错包速率小于等于1000个/秒,发送该恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
错包速率统计数
Counter64
错包速率阈值
Unsigned32
统计错包速率的时间间隔
Unsigned32
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.63
端口未转发报文却收到pause帧或者端口发送pause帧未收到报文
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.64 (hh3cIfFlowControlDLAlarmResume)
开启
【触发原因】
产生此告警的可能原因包括:
该端口未转发报文,却从该端口接收到大量的Pause帧。
端口持续发送大量Pause帧,但没有接收到报文。
【系统影响】
端口无法转发报文。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
端口未转发报文也未收到pause帧或者端口发送pause帧并收到报文
恢复告警
警告
开启
【触发原因】
该端口发送Pause帧,并且有接收到报文;未转发报文的端口也未接收到Pause帧,上报此恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.65
端口上的部分业务数据丢弃
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.66 (hh3cIfOutputErrorAlarmResume)
开启
【触发原因】
光模块或光纤故障。
【系统影响】
该端口上的部分业务数据被丢弃。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
板索引
Integer32
0-65535
子卡索引
Integer32
0-65535
【处理建议】
1.更换光模块,检查告警是否清除。
2.更换光纤,检查故障是否清除。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
端口上没有业务数据丢弃
恢复告警
警告
开启
【触发原因】
光模块或光纤故障恢复,端口上业务数据恢复正常,发送此恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
板索引
Integer32
0-65535
子卡索引
Integer32
0-65535
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.67
网线质量较差或者受信号干扰
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.68 (hh3cIfCableSnrNormal)
开启
【触发原因】
MultiGE电口工作速率在2.5Gbit/s及以上时,网线质量不好或存在信号干扰,发送此告警信息。
【系统影响】
可能存在丢包现象。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
1.更换为高质量网线,如Cat6A网线或屏蔽网线。
2.执行speed { 100 | 1000 }或auto speed { 100 | 1000 }命令,降低MultiGE接口的工作速率。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
网线质量完好,不存在信号干扰
恢复告警
警告
开启
【触发原因】
MultiGE电口工作速率在2.5Gbit/s及以上时,网线质量完好,不存在信号干扰,上报此恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.69
MultiGE接口由Up变Down
事件告警
警告
开启
【触发原因】
网线质量无法检测,MultiGE接口由Up变Down,产生此告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
1.网线质量无法检测,请更换网线。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.70
插入接口的光模块不支持单纤功能
事件告警
警告
开启
【触发原因】
插入接口的光模块不支持单纤功能,产生此告警。
【系统影响】
接口插入的光模块导致该接口的单纤功能不可用。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
请更换为支持单纤功能的光模块。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.71
接口不支持LRM光模块
事件告警
警告
开启
【触发原因】
接口插入了不支持的LRM的光模块,产生此告警。
【系统影响】
光模块不可用,对应端口的业务中断。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
1.执行命令display transceiver查看接口当前在位的光模块类型。
2.更换在位光模块为非LRM光模块。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.72
XGE接口插入的GE光模块只能工作在非自协商1000Mbit/s模式
事件告警
警告
开启
【触发原因】
XGE接口插入的GE光模块只能工作在非自协商1000Mbit/s模式,将互联的接口速率配置为强制1000Mbit/s,发送此告警信息。
【系统影响】
XGE接口插入GE光模块导致该接口的自协商功能不可用。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
请将互联的接口配置为强制1000Mbit/s速率。。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.73
PFC死锁可能导致网络中流量不通
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.74 (hh3cIfPfcDeadLockResume)
开启
【触发原因】
PFC死锁。
【系统影响】
可能导致网络中流量不通。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
【处理建议】
1.执行display priority-flow-control命令,确认网络中出现PFC死锁的原因并优化网络,若网络优化后问题未解决,请执行第2步;
2.执行priority-flow-control deadlock cos cos-value intervalinterval命令调整PFC死锁检测周期,以满足网络实际使用需求。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
PFC死锁恢复流量流通
恢复告警
警告
开启
【触发原因】
PFC死锁恢复,流量正常转发,发送此恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.75
死锁发生次数超过PFC自动关闭的阈值
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.76 (hh3cIfPfcTurnOffResume)
开启
【触发原因】
一个检测周期内死锁发生次数超过PFC自动关闭的阈值,产生此告警。
【系统影响】
PFC功能自动关闭。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
【处理建议】
2.执行priority-flow-control deadlock cos cos-value interval interval命令调整PFC死锁检测周期,执行priority-flow-control deadlock threshold cos cos-value period period count count命令调整自动关闭PFC功能的死锁次数,以满足网络实际使用需求;
3.如果网络中PFC死锁已经解除,可在接口下先执行undo dpriority-flow-control enable来关闭PFC功能,再使用priority-flow-control enable开启PFC功能,以重新应用PFC。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
死锁发生次数低于PFC自动关闭的阈值
恢复告警
警告
开启
【触发原因】
一个检测周期内死锁发生次数低于PFC自动关闭的阈值,发送此恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
【处理建议】
正常运行信息,无需处理。
hh3cIfQueueAlarm
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.77
接口上队列的队列深度使用率超过接口上的配置值
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.78 (hh3cIfQueueResume)
开启
【触发原因】
接口上队列的队列深度使用率超过接口上的配置值时,产生此告警信息。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
1.3.6.1.4.1.25506.2.40.1.30 (hh3cIfCurrentUsedRatio)
当前队列深度使用率
Unsigned32
1.3.6.1.4.1.25506.2.40.31.0 (hh3cIfUsedRatioThershold)
队列深度使用门限
Unsigned32
【处理建议】
hh3cIfQueueResume
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
接口上队列的队列深度使用率低于接口上的配置值
恢复告警
警告
开启
【触发原因】
接口上队列的队列深度使用率低于接口上的配置值时,产生此恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
当前队列深度使用率
Unsigned32
队列深度使用门限
Unsigned32
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.79
端口队列丢弃包数/丢弃字节数/丢包率达到告警阈值
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.80 (hh3cIfQueueStatDiscardResume)
开启
【触发原因】
端口队列丢弃包数/丢弃字节数/丢包率达到告警阈值,产生此告警。
【系统影响】
存在丢包问题,可能影响接口业务。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
1.3.6.1.4.1.25506.2.40.1.32 (hh3cIfDiscardType)
丢包类型
INTEGER
discardstat(1), discardByte(2), discardrate(3)
1.3.6.1.4.1.25506.2.40.1.33 (hh3cIfDiscardThreshold)
丢包门限
Counter64
【处理建议】
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
端口队列丢弃包数/丢弃字节数/丢包率低于告警阈值
恢复告警
警告
开启
【触发原因】
端口队列丢弃包数/丢弃字节数/丢包率低于告警阈值,产生此恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
丢包类型
INTEGER
丢包门限
Counter64
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.81
接口上队列的出方向发生拥塞
故障告警
警告
1.3.6.1.4.1.25506.2.40.3.0.82 (hh3cIfQueueEgressCongestionClear)
开启
【触发原因】
接口上出方向报文发送队列产生拥塞,产生此告警信息。
【系统影响】
接口上出方向流量可能会被丢弃。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
【处理建议】
调整网络以缓解网络拥塞。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
接口上队列的出方向拥塞解除
恢复告警
警告
开启
【触发原因】
接口上队列的出方向拥塞解除时,产生此恢复告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
接口缓存队列id
hh3cIfQueId
INTEGER
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.83
Trunk接口的带宽发生改变
事件告警
通知
开启
【触发原因】
聚合接口的带宽发生改变,产生此告警。
【系统影响】
对系统无影响。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
接口索引
ifIndex
Integer32
同MIB标准取值
接口描述
ifIndex
OCTET STRING
【处理建议】
正常运行信息,无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.40.3.0.84
接口板流量大于阈值
事件告警
警告
开启
【触发原因】
接口板流量大于阈值,NP数据通道下行带宽超过80%,产生此告警。
【系统影响】
可能造成丢包。
【状态控制】
该告警无法关闭。
【绑定变量】
OID(变量名)
含义
索引节点
类型
取值范围
框索引
Integer32
0-65535
板索引
Integer32
0-65535
【处理建议】
1.调整网络拓扑,检查故障是否清除。 ·如果是,请执行步骤3。如果否,请执行步骤2;
2.请收集告警信息、日志信息和配置信息,联系技术支持人员进行处理;
3.结束。
