24-VXLAN命令参考
01-VXLAN命令
本章节下载: 01-VXLAN命令  (319.68 KB)
01-VXLAN命令
1 VXLAN
1.1 VXLAN基础配置命令
1.1.1 arp suppression enable
1.1.2 description
1.1.3 display arp suppression vsi
1.1.4 display l2vpn interface
1.1.5 display l2vpn mac-address
1.1.6 display l2vpn vsi
1.1.7 display vxlan tunnel
1.1.8 flooding disable
1.1.9 l2vpn enable
1.1.10 l2vpn rewrite inbound tag
1.1.11 mac-address static
1.1.12 mtu
1.1.13 reset arp suppression vsi
1.1.14 reset l2vpn mac-address
1.1.15 selective-flooding mac-address
1.1.16 shutdown
1.1.17 tunnel
1.1.18 tunnel global source-address
1.1.19 vsi
1.1.20 vxlan
1.1.21 vxlan invalid-udp-checksum discard
1.1.22 vxlan invalid-vlan-tag discard
1.1.23 vxlan local-mac report
1.1.24 vxlan tunnel mac-learning disable
1.1.25 vxlan udp-port
1.1.26 xconnect vsi
1.2 VXLAN IP网关配置命令
1.2.1 bandwidth
1.2.2 default
1.2.3 description
1.2.4 display interface vsi-interface
1.2.5 distributed-gateway local
1.2.6 gateway subnet
1.2.7 gateway vsi-interface
1.2.8 interface vsi-interface
1.2.9 mac-address
1.2.10 mtu
1.2.11 reset counters interface vsi-interface
1.2.12 shutdown
1.2.13 vtep group member local
1.2.14 vtep group member remote
1.2.15 vxlan tunnel arp-learning disable
1.3 ENDP配置命令
1.3.1 display vxlan neighbor-discovery client member
1.3.2 display vxlan neighbor-discovery client statistics
1.3.3 display vxlan neighbor-discovery client summary
1.3.4 display vxlan neighbor-discovery server member
1.3.5 display vxlan neighbor-discovery server statistics
1.3.6 display vxlan neighbor-discovery server summary
1.3.7 network-id
1.3.8 vxlan neighbor-discovery authentication
1.3.9 vxlan neighbor-discovery client enable
1.3.10 vxlan neighbor-discovery client register-interval
1.3.11 vxlan neighbor-discovery server enable
1 VXLAN
设备各款型使用的命令行形式有所不同,详细差异信息如下:
命令行形式
款型
集中式
·     MSR810/810-W/810-W-DB/810-LM/810-W-LM/810-10-PoE/810-LM-HK/810-W-LM-HK
·     MSR810-LMS/810-LUS
·     MSR2600-6-X1/2600-10-X1/2630
·     MSR3600-28/3600-51/3600-28-SI/3600-51-SI
·     MSR3610-X1/3610-X1-DP/3610-X1-DC/3610-X1-DP-DC
·     MSR 3610/3620/3620-DP/3640/3660
·     MSR810-W-WiNet/810-LM-WiNet/830-4LM-WiNet
·     MSR830-5BEI-WiNet/830-6EI-WiNet/830-10BEI-WiNet
·     MSR830-6BHI-WiNet/830-10BHI-WiNet
·     MSR2600-10-X1-WiNet/2630-WiNet
·     MSR3600-28-WiNet/3610-X1-WiNet
·     MSR3610-WiNet/3620-10-WiNet/3620-DP-WiNet/3620-WiNet/3660-WiNet
·     MSR810-LM-GL/810-W-LM-GL
·     MSR830-6EI-GL/830-10EI-GL/830-6HI-GL/830-10HI-GL
·     MSR2600-6-X1-GL/3600-28-SI-GL
分布式
MSR5620/5660/5680
设备各款型对于本节所描述的特性的支持情况有所不同,详细差异信息如下:
型号
特性
MSR810/810-W/810-W-DB/810-LM/810-W-LM/810-10-PoE/810-LM-HK/810-W-LM-HK/810-LMS/810-LUS
VXLAN
仅MSR810-LMS/810-LUS不支持
支持
MSR 2630
支持
MSR3600-28/3600-51
支持
MSR3600-28-SI/3600-51-SI
不支持
支持
支持
MSR5620/5660/5680
支持
型号
VXLAN
支持
MSR830-4LM-WiNet
支持
支持
支持
MSR2600-10-X1-WiNet
支持
MSR2630-WiNet
支持
MSR3600-28-WiNet
支持
MSR3610-X1-WiNet
支持
支持
型号
特性
MSR810-LM-GL
VXLAN
支持
MSR810-W-LM-GL
支持
MSR830-6EI-GL
支持
MSR830-10EI-GL
支持
MSR830-6HI-GL
支持
MSR830-10HI-GL
支持
MSR2600-6-X1-GL
支持
MSR3600-28-SI-GL
不支持
1.1  VXLAN基础配置命令
arp suppression enable命令用来开启ARP泛洪抑制功能。
undo arp suppression enable命令用来关闭ARP泛洪抑制功能。
ARP泛洪抑制功能处于关闭状态。
VSI视图
为了避免广播发送的ARP请求报文过多占用核心网络带宽,VTEP从本地站点、VXLAN隧道接收到ARP请求和ARP应答报文后,根据该报文在本地建立ARP泛洪抑制表项。后续当VTEP收到本站点内虚拟机请求其它虚拟机MAC地址的ARP请求时,优先根据ARP泛洪抑制表项进行代答。如果没有对应的表项,则将ARP请求泛洪到核心网。ARP泛洪抑制功能可以大大减少ARP泛洪的次数。
# 在VSI vsi1下开启ARP泛洪抑制功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
·     display arp suppression vsi
·     reset arp suppression vsi
1.1.2  description
description命令用来配置VSI的描述信息。
undo description命令用来恢复缺省情况。
未配置VSI的描述信息。
VSI视图
text:VSI的描述信息,为1~80个字符的字符串,区分大小写。
# 配置名为vpn1的VSI的描述信息为“vsi for vpn1”。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
·     display l2vpn vsi
display arp suppression vsi命令用来显示VSI的ARP泛洪抑制表项信息。
集中式设备-独立运行模式:
display arp suppression vsi [ name vsi-name ] [ count ]
分布式设备-独立运行模式/集中式设备-IRF模式:
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
分布式设备-IRF模式:
display arp suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
name vsi-name:显示指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ARP泛洪抑制表项。
slot slot-number:显示指定单板的ARP泛洪抑制表项。slot-number表示单板所在的槽位号。如果不指定本参数,将显示主用主控板上的ARP泛洪抑制表项。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的ARP泛洪抑制表项。slot-number表示设备在IRF中的成员编号。如果不指定本参数,将显示主设备上的ARP泛洪抑制表项。(集中式设备-IRF模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ARP泛洪抑制表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示全局主用主控板上的ARP泛洪抑制表项。(分布式设备-IRF模式)
count:显示ARP泛洪抑制表项的个数。
# 显示所有VSI的ARP泛洪抑制表项信息。(集中式设备-独立运行模式)
<Sysname> display arp suppression vsi
IP address      MAC address    Vsi Name                        Link ID    Aging
1.1.1.2         000f-e201-0101 vsi1                            0x70000    14
1.1.1.3         000f-e201-0202 vsi1                            0x80000    18
1.1.1.4         000f-e201-0203 vsi2                            0x90000    10
# 显示所有VSI的ARP泛洪抑制表项个数。(集中式设备-独立运行模式)
<Sysname> display arp suppression vsi count
Total entries: 3
# 显示主用主控板上的ARP泛洪抑制表项信息。(分布式设备-独立运行模式)
# 显示主用主控板上的ARP泛洪抑制表项个数。(分布式设备-独立运行模式)
Total entries: 3
# 显示主设备上的ARP泛洪抑制表项信息。(集中式设备-IRF模式)
# 显示主设备上的ARP泛洪抑制表项个数。(集中式设备-IRF模式)
Total entries: 3
# 显示全局主用主控板上的ARP泛洪抑制表项信息。(分布式设备-IRF模式)
# 显示全局主用主控板上的ARP泛洪抑制表项个数。(分布式设备-IRF模式)
Total entries: 3
表1-1 display arp suppression vsi命令显示信息描述表
IP address
ARP泛洪抑制表项的IP地址
MAC address
ARP泛洪抑制表项的MAC地址
Vsi Name
VSI名称
Link ID
MAC表项的出链路标识符,用来在VSI内唯一标识一条AC或一条VXLAN隧道
Aging
ARP泛洪抑制表项的老化时间,单位为分钟
Total entries
ARP泛洪抑制表项的数目
·     arp suppression enable
display l2vpn interface命令用来显示与VSI关联的三层接口的L2VPN信息。
display l2vpn interface [ vsi vsi-name | interface-type interface-number ] [ verbose ]
vsi vsi-name:显示与指定VSI关联的三层接口的L2VPN信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
interface-type interface-number:显示指定接口的L2VPN信息。interface-type interface-number为接口类型和接口编号。
verbose:显示详细信息。如果未指定本参数,则显示简要信息。
执行本命令时,如果未指定任何参数,则显示所有与VSI关联的三层接口的L2VPN信息。
# 显示所有与VSI关联的三层接口的L2VPN简要信息。
<Sysname> display l2vpn interface
Total number of interfaces: 2, 1 up, 1 down
Interface                Owner                           Link ID   State    Type
GE1/0/1                  vxlan3                          1         Up       VSI
GE1/0/2                  vxlan4                          2         Down     VSI
表1-2 display l2vpn interface命令显示信息描述表
与VSI关联的三层接口的总数,及处于up和down状态的接口数目
与VSI关联的三层接口的名称
Owner
VSI名称
Link ID
接口对应AC在VSI内的链路标识符
接口的物理状态,取值包括Up和Down
接口对应的L2VPN类型,在VXLAN中取值为VSI
# 显示所有与VSI关联的三层接口的L2VPN详细信息。
<Sysname> display l2vpn interface verbose
Interface: GE1/0/1
    Owner         : vsi1
    Link ID       : 0
    State         : Up
    Type          : VSI
Interface: GE1/0/2
    Owner         : vsi2
    Link ID       : 0
    State         : Down
    Type          : VSI
表1-3 display l2vpn interface verbose命令显示信息描述表
接口名称
Owner
与接口关联的VSI名称
Link ID
接口对应AC在VSI内的链路标识符
接口的物理状态,取值包括Up和Down
display l2vpn mac-address命令用来显示VSI的MAC地址表信息。
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count ]
vsi vsi-name:显示指定VSI的MAC地址表信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的MAC地址表信息。
dynamic:显示通过源MAC地址动态学习的MAC地址表项。如果不指定本参数,则显示所有类型的MAC地址表项,包括通过源MAC地址动态学习的本地和远端MAC地址表项、通过IS-IS协议学习的远端MAC地址表项、通过BGP EVPN协议学习的远端MAC地址表项、静态配置的远端MAC地址表项和通过OpenFlow下发的远端MAC地址表项。VXLAN不支持静态配置本地MAC地址表项。
count:显示MAC地址表项的数目。如果不指定本参数,则显示MAC地址表项的具体信息。
# 显示所有VSI的MAC地址表信息。
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name  Aging
0000-0000-000a   Dynamic  vpn1                            1             Aging
0000-0000-000b   Static   vpn1                            Tunnel10      NotAging
0000-0000-000c   Dynamic  vpn1                            Tunnel60      Aging
0000-0000-000d   Dynamic  vpn1                            Tunnel99      Aging
--- 4 mac address(es) found  ---
# 显示所有VSI的MAC地址表项总数。
<Sysname> display l2vpn mac-address count
表1-4 display l2vpn mac-address命令显示信息描述表
MAC Address
MAC地址
MAC地址的状态,取值包括:
·     Dynamic:表示通过源MAC地址动态学习的本地或远端MAC地址表项
·     Static:表示静态配置的远端MAC地址表项
·     IS-IS:表示通过IS-IS协议学习的远端MAC地址表项
·     EVPN:表示通过BGP EVPN协议学习的远端MAC地址表项
·     OpenFlow:表示通过OpenFlow下发的远端MAC地址表项
VSI Name
VSI名称
Link ID/Name
对于本端MAC地址,为MAC地址的出链路标识符,即AC在VSI内的链路标识符;对于远端MAC地址,为MAC地址对应的隧道接口名称
Aging
MAC地址表项是否老化,取值包括Aging和NotAging
XX mac address(es) found
VSI的MAC地址表项的总数
·     reset l2vpn mac-address
display l2vpn vsi命令用来显示VSI的信息。
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name:显示指定VSI的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的信息。
verbose:显示VSI的详细信息。如果不指定本参数,则显示VSI的简要信息。
# 显示所有VSI的简要信息。
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpna                            0               1500   Up
表1-5 display l2vpn vsi命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
MTU
VSI上配置的最大传输单元
VSI的状态,取值包括:
·     Up:up状态。只有VXLAN关联了处于up状态的隧道和AC,VSI才会处于up状态
·     Down:down状态
·     Admin down:通过shutdown命令手工关闭VSI
# 显示所有VSI的详细信息。
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : Unlimited
  Broadcast Restrain      : 5120 kbps
  Multicast Restrain      : 5120 kbps
  Unknown Unicast Restrain: 5120 kbps
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : Disabled
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood proxy
    Tunnel1              0x5000001  Up     Manual    Disabled
    Tunnel2              0x5000002  Up     Manual    Disabled
  ACs:
    AC                               Link ID    State
    GE1/0/1                          0          Up
表1-6 display l2vpn vsi verbose命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
VSI Description
VSI的描述信息,如果不配置,则此行不显示
VSI State
VSI的状态,取值包括:
·     Down:down状态
·     Administratively down:通过shutdown命令手工关闭VSI
MTU
VSI上配置的最大传输单元
Bandwidth
VSI的已知单播流量的最大带宽值,单位为kbps
Broadcast Restrain
VSI的广播抑制带宽值,单位为kbps
Multicast Restrain
VSI的组播抑制带宽值,单位为kbps
VSI的未知单播抑制带宽值,单位为kbps
MAC Learning
是否使能了MAC地址学习功能
MAC Table Limit
VSI内MAC地址表项的最大数目
Drop Unknown
当VSI内学习到的MAC地址数达到最大值后,是否禁止转发源MAC地址不在MAC地址表里的报文
Flooding
是否使能VSI的泛洪功能,取值包括:
·     Enabled:表示使能了VSI的泛洪功能,即VTEP会将目的MAC地址未知的单播数据帧发送给所有本地和远端站点
·     Disabled:表示禁止VSI的泛洪功能,即VTEP只将目的MAC地址未知的单播数据帧发送给所有本地站点
Gateway Interface
VSI网关虚接口编号
VXLAN ID
VXLAN编号
Tunnels
与VXLAN关联的隧道信息
Tunnel Name
隧道名称
Link ID
隧道在VSI内的链路标识符
隧道状态,取值包括:
·     Up:Tunnel接口状态Up,隧道可正常转发数据
·     Blocked:该隧道为备用代理隧道,不进行数据转发,Tunnel接口状态Up
·     Down:Tunnel接口状态Down,隧道停止数据转发
VXLAN和VXLAN隧道的关联方式:
·     Auto:表示自动关联,分为以下两种:
¡     通过VXLAN ISIS协商VXLAN ID后,自动将VXLAN和VXLAN隧道关联
¡     通过EVPN自动将VXLAN和VXLAN隧道关联
¡     在组播路由方式下,自动创建用于转发泛洪流量的组播VXLAN隧道(MTunnel),并将其与VXLAN关联
·     Manual:表示手动关联VXLAN和VXLAN隧道
Flood proxy
隧道是否开启了泛洪代理功能,取值包括:
·     Enabled:开启隧道的泛洪代理功能,即VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP
·     Disabled:关闭隧道的泛洪代理功能
ACs
VSI的AC列表
AC
接入电路
Link ID
AC在VSI内的链路标识符
AC的状态,取值包括Up和Down
display vxlan tunnel命令用来显示与VXLAN关联的VXLAN隧道的信息。
display vxlan tunnel [ vxlan-id vxlan-id ]
vxlan-id:显示与指定VXLAN关联的隧道的信息。vxlan-id为VXLAN的编号,取值范围为0~16777215。不指定此参数,则显示所有与VXLAN关联的隧道的信息。
# 显示所有与VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3(3up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State  Type         Flood proxy
Tunnel0              0x5000000  Up     Manual       Disabled
# 显示与编号为10的VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel vxlan-id 10
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3 (3 up, 0 down, 0 defect, 0 blocked)
表1-7 display vxlan tunnel命令显示信息描述表
已创建的VXLAN的总数
VXLAN ID
VXLAN ID
VSI name
VXLAN所属的VSI名称
Total tunnels
与VXLAN关联的隧道的总数,包括处于Up和Down状态的隧道总数
Tunnel name
隧道名称
Link ID
隧道在VXLAN内的链路标识符
隧道的状态,取值包括:
VXLAN和VXLAN隧道的关联方式:
Flood proxy
隧道是否开启了泛洪代理功能,取值包括:
·     Enabled:开启隧道的泛洪代理功能。即该VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP
·     tunnel
·     vxlan
flooding disable命令用来关闭VSI的泛洪功能。
undo flooding disable命令用来开启VSI的泛洪功能。
flooding disable
VSI的泛洪功能处于开启状态。
VSI视图
缺省情况下,VTEP从本地站点内接收到目的MAC地址未知的单播数据帧后,会在该VXLAN内除接收接口外的所有本地接口和VXLAN隧道上泛洪该数据帧,将该数据帧发送给VXLAN内的所有站点。如果用户希望把该类数据帧限制在本地站点内,不通过VXLAN隧道将其转发到远端站点,则可以通过本命令手工禁止VXLAN对应VSI的泛洪功能。
# 关闭名称为vsi1的VSI的泛洪功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable
1.1.9  l2vpn enable
l2vpn enable命令用来开启L2VPN功能。
undo l2vpn enable命令用来关闭L2VPN功能。
l2vpn enable
undo l2vpn enable
L2VPN功能处于关闭状态。
只有开启L2VPN功能后,才能进行L2VPN的相关配置。
# 开启L2VPN功能。
[Sysname] l2vpn enable
l2vpn rewrite inbound tag命令用来配置入方向报文的VLAN标签处理规则。
undo l2vpn rewrite inbound命令用来恢复缺省情况。
l2vpn rewrite inbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark 1-to-2 s-vid vlan-id c-vid vlan-id } [ symmetric ]
不对入方向报文的VLAN标签进行处理。
三层以太网接口视图
三层聚合接口视图
nest:表示添加标签。
c-vid:表示内层标签。
vlan-id:表示VLAN的编号,取值范围为1~4094。
s-vid:表示外层标签。
remark:表示映射标签。
1-to-2:表示1:2标签映射,即将原有报文中的一层标签映射为两层标签。
symmetric:表示对出方向报文进行相反的标签操作,即为报文剥离一层标签。如果不指定本参数,则表示不对出方向报文的VLAN标签进行处理。
不能通过重复执行本命令修改入方向报文的VLAN标签处理规则。如需修改,请先通过undo l2vpn rewrite inbound命令删除入方向报文的VLAN标签处理规则,再执行l2vpn rewrite inbound tag命令。
执行本命令时,需要注意:
·     l2vpn rewrite inbound tag nest s-vid vlan-id c-vid vlan-id命令只对不携带VLAN tag的报文生效。
·     l2vpn rewrite inbound tag remark 1-to-2命令只对携带一层VLAN tag的报文生效。
# 在三层以太网接口上配置为入方向报文添加外层VLAN标签100,并剥离出方向报文的外层VLAN标签。
[Sysname] interface
[Sysname-] l2vpn rewrite inbound tag nest s-vid 100 symmetric
mac-address static命令用来添加静态远端MAC地址表项。
undo mac-address static命令用来删除指定的静态远端MAC地址表项。
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] [ interface tunnel tunnel-number ] vsi vsi-name
不存在静态的远端MAC地址表项。
mac-address:MAC地址,格式为H-H-H,不支持组播MAC地址、全F和全0的MAC地址。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
interface tunnel tunnel-number:指定远端MAC地址对应的VXLAN隧道接口。tunnel-number为VXLAN隧道接口的编号,取值范围为0~10239。指定的隧道接口必须已经创建。
vsi vsi-name:指定远端MAC地址所属的VSI。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
远端MAC地址是指VTEP连接的远端站点内虚拟机的MAC地址。远端MAC地址既可以通过本命令静态配置,也可以通过报文中的源MAC地址、BGP EVPN协议等学习。
对于远端MAC地址表项,interface tunnel interface-number参数指定的隧道接口必须与vsi vsi-name参数指定的VSI对应的VXLAN关联,否则配置将失败。
执行undo mac-address static vsi命令时如果没有指定任何参数,则删除该VSI下的所有静态MAC地址表项。
建议不要将ENDP动态创建的隧道接口指定为远端MAC地址对应的VXLAN隧道接口。否则,配置恢复时,ENDP会重新创建隧道,隧道接口的编号可能发生变化,从而导致静态远端MAC地址表项的配置无法恢复。
# 添加一条静态远端MAC地址表项:MAC地址为000f-e201-0101,VXLAN隧道接口为Tunnel1,MAC地址所属的VSI为vsi1。
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
·     vxlan tunnel mac-learning disable
1.1.12  mtu
mtu命令用来配置VSI的MTU(Maximum Transmission Unit,最大传输单元)值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
VSI的MTU值为1500字节。
VSI视图
VSI下创建VXLAN后,该VSI的MTU值是指从AC上接收且通过VXLAN隧道转发的用户报文的最大长度。VSI内的其他报文不受该MTU值的限制。
如果MTU为缺省值1500或者用户报文长度小于等于MTU值,则不需要对报文进行分片;如果用户报文长度大于MTU值,则需要分片。
# 配置名为vxlan1的VSI的MTU值为1400字节。
[Sysname] vsi vxlan1
[Sysname-vsi-vxlan1] mtu 1400
·     display l2vpn vsi
reset arp suppression vsi命令用来清除VSI的ARP泛洪抑制表项。
reset arp suppression vsi [ name vsi-name ]
name vsi-name:清除指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的ARP泛洪抑制表项。
# 清除所有VSI的ARP泛洪抑制表项。
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
reset l2vpn mac-address命令用来清除通过源MAC地址动态学习的MAC地址表项。
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name:清除指定VSI动态学习的MAC地址表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI动态学习的MAC地址表项。
VSI通过源MAC地址学习到错误的MAC地址表项,或学习的MAC地址表项数目达到最大值时,可以执行本命令,以便重新学习MAC地址表项。
# 清除名为vpn1的VSI通过源MAC地址动态学习的MAC地址表项。
<Sysname> reset l2vpn mac-address vsi vpn1
·     display l2vpn mac-address vsi
selective-flooding mac-addres命令用来配置VSI选择性泛洪的MAC地址。
undo selective-flooding mac-addres命令用来删除VSI的选择性泛洪MAC地址。
selective-flooding mac-addres mac-addres
undo selective-flooding mac-addres mac-addres
不存在VSI选择性泛洪MAC地址。
VSI视图
mac-address:选择性泛洪的MAC地址。该MAC地址不能为全F。
通过flooding disable命令关闭VSI的泛洪功能后,为了将某些MAC地址的数据帧泛洪到远端站点以保证某些业务的流量在站点间互通,可以配置选择性泛洪的MAC地址。当数据帧的目的MAC地址匹配选择性泛洪的MAC地址时,该数据帧可以泛洪到远端站点。
# 在VSI vsi1下配置选择性泛洪的MAC地址为000f-e201-0101。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
·     flooding disable
1.1.16  shutdown
shutdown命令用来关闭当前的VSI。
undo shutdown命令用来开启当前的VSI。
shutdown
VSI处于开启状态。
VSI视图
关闭VSI后,该VSI将不能提供二层交换服务。
关闭VSI功能通常用于暂时禁用二层交换服务,但还需要再次启用该服务的场景。关闭VSI后,该VSI所有已存在的配置保持不变。在关闭状态下还可以对VSI进行配置。VSI再次被开启后,基于最新的配置提供二层交换服务。
# 关闭名为vpn1的VSI。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
·     display l2vpn vsi
1.1.17  tunnel
tunnel命令用来配置VXLAN与指定的隧道关联。
undo tunnel命令用来取消VXLAN与指定隧道的关联。
tunnel tunnel-number [ flooding-proxy ]
undo tunnel tunnel-number
VXLAN未关联VXLAN隧道。
VXLAN视图
tunnel-number:隧道接口的编号。指定的隧道必须是VXLAN模式的隧道。
设备各款型对于本节所描述参数的支持情况有所不同,详细差异信息如下:
型号
参数
tunnel-number
MSR810/810-W/810-W-DB/810-LM/810-W-LM/810-10-PoE/810-LM-HK/810-W-LM-HK的取值范围为0~10239
MASR810-LMS/810-LUS 不支持
0~10239
MSR 2630
0~10239
MSR3600-28/3600-51
0~10239
不支持
0~10239
0~10239
MSR 5620/5660/5680
0~10239
型号
tunnel-number
0~10239
MSR830-4LM-WiNet
不支持
0~10239
0~10239
MSR2600-10-X1-WiNet
0~10239
MSR2630-WiNet
0~10239
MSR3600-28-WiNet
0~10239
MSR3610-X1-WiNet
0~10239
0~10239
型号
参数
MSR810-LM-GL
tunnel-number
0~10239
MSR810-W-LM-GL
0~10239
MSR830-6EI-GL
0~10239
MSR830-10EI-GL
0~10239
MSR830-6HI-GL
0~10239
MSR830-10HI-GL
0~10239
MSR2600-6-X1-GL
0~10239
MSR3600-28-SI-GL
0~10239
flooding-proxy:开启隧道的泛洪代理功能,即该VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP。如果未指定本参数,则表示关闭隧道的泛洪代理功能。
在VXLAN组网中,用户可以手工将VXLAN与VXLAN隧道关联。VTEP接收到某个VXLAN的泛洪流量后,如果采用单播路由泛洪方式,则VTEP将在与该VXLAN关联的所有VXLAN隧道上发送该流量,以便将流量转发给所有的远端VTEP。
一个VXLAN可以关联32条VXLAN隧道;一条VXLAN隧道可以关联多个VXLAN。
不能通过重复执行本命令开启或关闭VXLAN隧道的泛洪代理功能。如需修改隧道的泛洪代理功能状态,请先通过undo tunnel命令取消VXLAN与指定隧道的关联,再执行tunnel命令。
一个VSI下可以配置多条开启泛洪代理功能的VXLAN隧道,第一个创建的VXLAN隧道作为主代理隧道,负责转发该VXLAN内的广播、组播和未知单播流量,其他隧道作为备用代理隧道,不转发流量。
# 配置VXLAN隧道Tunne0和Tunnel1与VXLAN 10000关联。
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 0
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
·     display vxlan tunnel
tunnel global source-address命令用来配置VXLAN隧道的全局源地址。
undo tunnel global source-address命令用来恢复缺省情况。
tunnel global source-address ip-address
未配置VXLAN隧道的全局源地址。
ip-address:隧道的全局源IP地址。
如果隧道下未配置源地址或源接口,则隧道会使用全局源地址作为隧道的源地址。
目前仅VXLAN隧道支持全局源地址,其它类型的隧道不支持全局源地址。
# 配置VXLAN隧道的全局源地址为1.1.1.1。
[Sysname] tunnel global source-address 1.1.1.1
1.1.19  vsi
vsi命令用来创建一个VSI,并进入VSI视图。如果指定的VSI已经存在,则直接进入VSI视图。
undo vsi命令用来删除指定的VSI。
vsi vsi-name
undo vsi vsi-name
不存在VSI。
vsi-name:VSI的名称,为1~31个字符的字符串,区分大小写。
VSI是VTEP上为一个VXLAN提供二层交换服务的虚拟交换实例。VSI可以看做是VTEP上的一台基于VXLAN进行二层转发的虚拟交换机,它具有传统以太网交换机的所有功能,包括源MAC地址学习、MAC地址老化、泛洪等。VSI与VXLAN一一对应。
# 创建名为vxlan10的VSI,并进入VSI视图。
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
·     display l2vpn vsi
1.1.20  vxlan
vxlan命令用来创建VXLAN,并进入VXLAN视图。如果指定的VXLAN已经存在,则直接进入VXLAN视图。
undo vxlan命令用来恢复缺省情况。
vxlan vxlan-id
undo vxlan
不存在VXLAN。
VSI视图
vxlan-id:VXLAN ID,取值范围为0~16777215。
在一个VSI下只能创建一个VXLAN。不同VSI下创建的VXLAN,其VXLAN ID不能相同。
# 在名称为vpna的VSI下创建编号为10000的VXLAN,并进入VXLAN视图。
[Sysname] vsi vpna
·     vsi
vxlan invalid-udp-checksum discard命令用来配置丢弃UDP校验和检查失败的VXLAN报文。
undo vxlan invalid-udp-checksum discard命令用来恢复缺省情况。
不会检查VXLAN报文的UDP校验和。
VTEP对二层数据帧进行封装时,将UDP校验和设置为0。缺省情况下,VTEP接收到VXLAN报文后,不会检查报文的UDP校验和。如果在VTEP上执行了本命令,则该VTEP会对接收的VXLAN报文的UDP校验和进行检查,校验和检查失败的报文将被丢弃。
为了兼容其他厂商的设备,UDP校验和为0和UDP校验和正确的报文均能通过VTEP的检查,被VTEP接收。
# 配置丢弃UDP校验和检查失败的VXLAN报文。
[Sysname] vxlan invalid-udp-checksum discard
·     vxlan invalid-vlan-tag discard
vxlan invalid-vlan-tag discard命令用来配置丢弃内层数据帧含有VLAN tag的VXLAN报文。
undo vxlan invalid-vlan-tag discard命令用来恢复缺省情况。
不会检查VXLAN报文内层封装的以太网数据帧是否携带VLAN tag。
如果在VTEP上执行了本命令,则VTEP接收到VXLAN报文并对其解封装后,若内层以太网数据帧带有VLAN tag,则丢弃该VXLAN报文。
远端VTEP上通过xconnect vsi命令的access-mode参数配置接入模式为ethernet时,VXLAN报文可能携带VLAN tag。这种情况下建议不要在本端VTEP上执行vxlan invalid-vlan-tag discard命令,以免错误地丢弃报文。
# 配置丢弃内层数据帧含有VLAN tag的VXLAN报文。
[Sysname] vxlan invalid-vlan-tag discard
·     vxlan invalid-udp-checksum discard
·     xconnect vsi
vxlan local-mac report命令用来开启本地MAC地址的日志记录功能。
undo vxlan local-mac report命令用来关闭本地MAC地址的日志记录功能。
本地MAC地址的日志记录功能处于关闭状态。
执行vxlan local-mac report命令后,VXLAN会立即根据已经学习到的本地MAC地址表项生成日志信息,之后在增加或删除本地MAC地址时也将产生日志信息。生成的日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。
# 开启本地MAC地址的日志记录功能。
[Sysname] vxlan local-mac report
vxlan tunnel mac-learning disable命令用来关闭远端MAC地址自动学习功能。
undo vxlan tunnel mac-learning disable命令用来开启远端MAC地址自动学习功能。
远端MAC地址自动学习功能处于开启状态。
远端MAC地址是指VTEP连接的远端站点内虚拟机的MAC地址。远端MAC地址可以通过报文中的源MAC地址动态学习。
缺省情况下,设备可以自动学习远端MAC地址。如果网络中存在攻击,为了避免学习到错误的远端MAC地址,可以通过本命令手工关闭远端MAC地址自动学习功能。
# 关闭远端MAC地址自动学习功能。
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port命令用来配置VXLAN报文的目的UDP端口号。
undo vxlan udp-port命令用来恢复缺省情况。
vxlan udp-port port-number
undo vxlan udp-port
VXLAN报文的目的UDP端口号为4789。
port-number:VXLAN报文的目的UDP端口号,取值范围为1~65535。
属于同一个VXLAN的VTEP设备上需要配置相同的UDP端口号。
建议不要将VXLAN报文的目的UDP端口号配置为知名端口,即1~1023之间的端口。
# 配置VXLAN报文的目的UDP端口号为6666。
[Sysname] vxlan udp-port 6666
1.1.26  xconnect vsi
xconnect vsi命令用来将AC与VSI关联。
undo xconnect vsi命令用来恢复缺省情况。
xconnect vsi vsi-name [ track track-entry-number&<1-3> ]
undo xconnect vsi
AC未关联VSI。
track track-entry-number&<1-3>:配置AC与指定Track项联动。track-entry-number为Track项的序号,取值范围为1~1024;&<1-3>表示前面的参数最多可以输入3次。指定本参数后,仅当关联的Track项中至少有一个状态为positive时,AC的状态才会up;否则,AC的状态为down。
在接口视图下执行本命令后,从接口接收到的报文将通过查找关联VSI的MAC地址表进行转发。
# 在接口GigabitEthernet1/0/1下关联名为vpn1的VSI。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-GigabitEthernet1/0/1] xconnect vsi vpn1
·     display l2vpn interface
·     vsi
1.2  VXLAN IP网关配置命令
1.2.1  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
VSI虚接口视图
bandwidth-value:接口的期望带宽,取值范围为1~400000000,单位为kbps。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 配置接口VSI-interface100的期望带宽为10000kbps。
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] bandwidth 10000
1.2.2  default
default命令用来恢复当前接口的缺省配置。
default
VSI虚接口视图
# 将接口VSI-interface100恢复为缺省配置。
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
1.2.3  description
description命令用来配置当前接口的描述信息。
接口的描述信息为“接口名 Interface”,例如:Vsi-interface100 Interface。
VSI虚接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
当设备上存在多个接口时,可以根据接口的连接信息或用途来配置接口的描述信息,以便区别和管理各接口。
本命令仅用于标识某接口,并无特别的功能。使用display interface等命令可以看到设置的描述信息。
# 配置接口VSI-interface100的描述信息为“gateway for VXLAN 10”。
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface命令用来显示VSI虚接口的相关信息。
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
vsi-interface-id:VSI虚接口的编号,只能指定设备上已创建的VSI虚接口的编号。
brief:显示接口的概要信息。如果不指定该参数,则显示接口的详细信息。
down:显示当前物理状态为down的接口的信息以及down的原因。如果不指定该参数,则不会根据接口物理状态来过滤显示信息。
如果不指定接口类型(vsi-interface),将显示设备支持的所有接口的相关信息。
如果指定接口类型,不指定接口编号(vsi-interface-id),则显示所有VSI虚接口的信息。
如果同时指定接口类型和接口编号,则显示指定VSI虚接口的信息。
# 显示接口VSI-interface100的相关信息。
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
表1-8 display interface vsi-interface命令显示信息描述表
Vsi-interface100
Current state
接口的物理状态和管理状态,取值包括:
·     DOWN:该接口的管理状态为开启,但物理状态为关闭
·     UP:该接口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态,取值包括:
·     UP:表示该接口的链路层协议状态为开启
·     UP(spoofing):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
·     DOWN:表示该接口的链路层协议状态为关闭
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口当前不能处理IP报文
Internet address
接口的主IP地址
IP报文发送帧格式
hardware address
硬件地址
IPv6报文发送帧格式
Physical
接口的物理类型,取值为Unknown
baudrate
接口的波特率,单位为kbps
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直未执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
总计输入的报文数,总计输入的字节,总计丢弃的输入报文数
总计输出的报文数,总计输出的字节,总计丢弃的输出报文数
# 显示所有VSI虚接口的概要信息。
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Vsi100               DOWN DOWN     --
# 显示接口VSI-interface100的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface vsi-interface 100 brief description
Vsi100               UP    UP      1.1.1.1         VSI-interface100
# 显示当前状态为down的接口的信息以及DOWN的原因。
Interface            Link   Cause
Vsi100               DOWN   Administratively
Vsi200               DOWN   Administratively
表1-9 display interface vsi-interface brief命令显示信息描述表
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复端口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口。
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的网络层协议状态显示是UP的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
接口名称缩写
Link
接口物理连接状态,取值包括:
·     UP:表示本链路物理上是连通的
·     DOWN:表示本链路物理上是不通的
·     ADM:表示本链路被手工关闭了,需要执行undo shutdown命令才能恢复真实的物理状态
·     Stby:表示该接口是一个备份接口。
Protocol
接口的链路层协议状态,取值包括:
·     UP (s):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
Primary IP
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址
接口的描述信息
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     Not connected:表示没有VSI关联该接口,或者关联该接口的VSI内没有AC或PW.
·     reset counters interface
distributed-gateway local命令用来配置VSI虚接口为分布式网关接口。
undo distributed-gateway local命令用来恢复缺省情况。
VSI虚接口不是分布式网关接口。
VSI虚接口视图
在分布式VXLAN IP网关组网中,多个网关上同一VXLAN的VSI虚接口需要配置相同的IP地址。为了避免IP地址冲突,需要在VSI虚接口上执行本命令,以防止VSI虚接口上报地址冲突,导致VSI虚接口不可用。
# 配置接口Vsi-interface100为分布式网关接口。
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet命令用来配置VSI所属的子网网段。
undo gateway subnet命令用来删除VSI所属的子网网段。
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
未指定VSI所属的子网网段。
VSI视图
ipv4-address:IPv4子网网段地址,为点分十进制格式。
wildcard-mask:IPv4地址掩码的反码,即将IPv4地址的掩码取反(0变1,1变0)。例如:子网掩码255.0.0.0的反码为0.255.255.255。其中,反码中的“1”表示忽略IPv4地址中对应的位,“0”表示必须保留此位。
ipv6-address prefix-length:IPv6地址及前缀长度。prefix-length为IPv6前缀长度,取值范围为1~128。
为了节省分布式VXLAN IP网关设备上的三层接口资源,在网关设备上多个VXLAN可以共用一个VSI虚接口,为VSI虚接口配置一个主IPv4地址和多个从IPv4地址、或多个IPv6地址,分别作为不同VXLAN内虚拟机的网关地址。
多个VXLAN共用一个VSI虚接口时,网关设备无法判断从VSI虚接口接收到的报文属于哪个VXLAN。为了解决该问题,需要在VSI视图下通过本命令指定VSI所属的子网网段,通过子网网段判断报文所属的VSI,并在该VSI内转发报文,从而限制广播报文范围,有效地节省带宽资源。但是每个VXLAN都有各自的IP地址子网网段以及网关IP,因此需要VSI虚接口支持按VXLAN设置子网网段。
一个VSI视图下最多可以配置8个子网网段,包括IPv4子网和IPv6子网。
在VSI视图下配置子网网段前,必须先为该VSI指定网关接口。取消为VSI指定网关接口时,会自动删除为该VSI指定的子网网段。
不能为指定了相同网关接口的不同VSI配置相同的子网网段。
# 配置名称为vxlan的VSI所属的子网网段为100.0.10.0/24。
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface命令用来为VSI指定网关接口。
undo gateway vsi-interface命令用来恢复缺省情况。
gateway vsi-interface vsi-interface-id
未指定VSI的网关接口。
VSI视图
vsi-interface-id:VSI网关虚接口的编号,接口编号的取值范围为0~8191。
一个VSI只能指定一个网关接口。
不同的VSI可以指定相同的网关接口。
# 为VSI指定网关接口为Vsi-interface100。
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
·     interface vsi-interface
interface vsi-interface命令用来创建VSI虚接口,并进入VSI虚接口视图。如果指定的VSI虚接口已经存在,则直接进入VSI虚接口视图。
undo interface vsi-interface命令用来删除指定的VSI虚接口。
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
不存在VSI虚接口。
vsi-interface-id:VSI虚接口的编号。
设备各款型对于本节所描述的参数的支持情况有所不同,详细差异信息如下:
型号
参数
vsi-interface-id
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR 2630
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR3600-28/3600-51
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
不支持
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR 5620/5660/5680
接口编号的取值范围为0~8191;
最多支持创建1024个VSI虚接口
型号
vsi-interface-id
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR830-4LM-WiNet
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR2600-10-X1-WiNet
接口编号的取值范围为0~8191;
MSR2630-WiNet
最多支持创建256个VSI虚接口
MSR3600-28-WiNet
接口编号的取值范围为0~8191;
MSR3610-X1-WiNet
最多支持创建256个VSI虚接口
接口编号的取值范围为0~8191;
型号
参数
MSR810-LM-GL
vsi-interface-id
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR810-W-LM-GL
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR830-6EI-GL
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR830-10EI-GL
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR830-6HI-GL
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口;
MSR830-10HI-GL
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR2600-6-X1-GL
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
MSR3600-28-SI-GL
接口编号的取值范围为0~8191;
最多支持创建256个VSI虚接口
# 创建VSI虚接口100,并进入VSI虚接口视图。
·     gateway vsi-interface
1.2.9  mac-address
mac-address命令用来配置VSI虚接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
缺省情况下,VSI虚接口未指定MAC地址。
VSI虚接口视图
mac-address:MAC地址,形式为H-H-H。
# 配置VSI虚接口100的MAC地址为0001-0001-0001。
[Sysname-Vsi-interface100] mac-address 1-1-1
1.2.10  mtu
mtu命令用来配置接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
缺省情况下,接口的MTU值为1500字节。
VSI虚接口视图
# 配置接口VSI-interface100的MTU值为1430字节。
[Sysname-Vsi-interface100] mtu 1430
reset counters interface vsi-interface命令用来清除VSI虚接口的统计信息。
reset counters interface [ vsi-interface [ vsi-interface-id ] ]
如果不指定接口类型(vsi-interface),则清除所有接口的统计信息;
如果指定接口类型,不指定接口编号(vsi-interface-id),则清除所有VSI虚接口的统计信息;
如果同时指定接口类型和接口编号,则清除指定VSI虚接口的统计信息。
# 清除接口VSI-interface100的统计信息。
<Sysname> reset counters interface vsi-interface 100
·     display interface
1.2.12  shutdown
shutdown命令用来关闭当前接口。
undo shutdown命令用来开启当前接口。
shutdown
VSI虚接口均处于开启状态。
VSI虚接口视图
# 关闭接口VSI-interface100。
[Sysname-Vsi-interface100] shutdown
vtep group member local命令用来将本设备加入VXLAN IP网关保护组,并配置本设备的成员地址。
undo vtep group member local命令用来取消本设备加入指定的VXLAN IP网关保护组。
vtep group group-ip member local member-ip
undo vtep group group-ip member local
设备未加入VXLAN IP网关保护组。
group-ip:VXLAN IP网关保护组的VTEP IP地址,该地址必须是本设备上已经存在的地址。
member-ip:本设备在VXLAN IP网关保护组内的成员地址,该地址必须是设备上已经配置的地址。
成员地址不能和保护组的VTEP IP相同;同一个保护组中不同成员的成员地址也不能相同。
# 配置本设备加入VXLAN IP保护组,保护组的VTEP IP地址是1.1.1.1,本设备的成员地址为2.2.2.2。
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
·     vtep group member remote
vtep group member remote命令用来配置VXLAN IP网关保护组的成员地址列表。
undo vtep group member remote命令用来删除指定VXLAN IP网关保护组的成员地址列表。
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
未配置VXLAN IP网关保护组的成员地址列表。
group-ip:VXLAN IP网关保护组的VTEP IP地址。
member-ip&<1-8>:VXLAN IP网关保护组成员IP地址列表。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
# 配置VXLAN IP网关保护组1.1.1.1包含的成员设备为2.2.2.2、3.3.3.3和4.4.4.4。
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
·     vtep group member local
vxlan tunnel arp-learning disable命令用来关闭远端ARP自动学习功能。
undo vxlan tunnel arp-learning disable命令用来开启远端ARP自动学习功能。
远端ARP自动学习功能处于开启状态。
缺省情况下,设备从VXLAN隧道接收到报文后可以自动学习远端虚拟机的ARP信息,即远端ARP信息。在SDN控制器组网下,当控制器和设备间进行表项同步时,可以通过vxlan tunnel arp-learning disable命令暂时关闭远端ARP自动学习功能,以节省占用的设备资源。同步完成后,再执行undo vxlan tunnel arp-learning disable命令开启远端ARP自动学习功能。
建议用户只在控制器和设备间同步表项的情况下执行vxlan tunnel arp-learning disable命令。
# 关闭远端ARP自动学习功能。
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
1.3  ENDP配置命令
display vxlan neighbor-discovery client member命令用来在ENDC上显示ENDC学到的邻居信息。
display vxlan neighbor-discovery client member [ interface tunnel interface-number | local local-ip | remote client-ip | server server-ip ]
interface tunnel interface-number:显示通过指定NVE隧道接口学到的邻居信息。interface-number为Tunnel接口的编号,取值范围为0~10239。
local local-ip:显示通过源端地址为指定IP地址的NVE隧道接口学到的邻居信息。local-ip表示NVE隧道接口的源端地址,即本地ENDC的IP地址。
remote client-ip:显示设备学到的指定邻居ENDC的信息。client-ip表示邻居ENDC的IP地址。
server server-ip:显示通过指定ENDS学到的邻居信息。server-ip表示ENDS的IP地址。
通过本命令可以查看ENDC学到的邻居信息,包括邻居的IP地址、桥MAC地址、创建时间、老化时间、邻居之间的VXLAN隧道状态等信息。
如果不指定任何参数,将显示ENDC学到的所有邻居信息。
# 显示ENDC学到的所有邻居的信息。
<Sysname> display vxlan neighbor-discovery client member
Interface: Tunnel0    Network ID: 1    Vpn-instance: [No Vrf]
Local Address: 1.1.1.1
Server Address: 1.1.1.1
Neighbor        System ID         Created Time           Expire    Status
2.2.2.2         0002-0000-0000    2014/08/01 03:39:38    71        Up
3.3.3.3         0003-0000-0000    2014/08/01 03:42:38    71        Up
表1-10 display vxlan neighbor-discovery client member命令显示信息描述表
启动ENDC功能的接口名称
Network ID
隧道的Network ID
Vpn-instance
VPN实例
Local Address
NVE隧道接口的源端地址
Server Address
ENDS的IP地址,NA表示ENDS未知
Neighbor
通过ENDS学到的邻居IP地址
System ID
邻居的桥MAC地址,NA表示桥MAC地址未知
Created Time
邻居创建的时间
Expire
邻居的老化时间,单位为秒
Status
与邻居之间VXLAN 隧道的状态:
·     Up:表示可以通过VXLAN隧道进行传输
·     Down:表示不可以通过VXLAN隧道进行传输
·     NA:表示尚未创建VXLAN隧道
display vxlan neighbor-discovery client statistics命令用来在ENDC上显示ENDC的统计信息。
display vxlan neighbor-discovery client statistics interface tunnel interface-number
interface tunnel interface-number:显示指定NVE隧道接口对应的ENDC的统计信息。interface-number为Tunnel接口的编号,取值范围为0~10239。
通过本命令可以查看开启ENDC功能后,接口收到和发送ENDP报文的统计信息。
# 显示NVE隧道接口Tunnel0对应的ENDC的统计信息。
<Sysname> display vxlan neighbor-discovery client statistics interface tunnel 0
Server Address: 10.0.0.1    Vpn-instance: [No Vrf]
Received packets:
  Reply:        170              Error:      1
Sent packets:
  Register:     170              Purge:      0
Server Address: 10.0.0.2
Received packets:
  Reply:        99               Error:      1
Sent packets:
  Register:     100              Purge:      0
表1-11 display vxlan neighbor-discovery client statistics命令显示信息描述表
Server Address
ENDC对应的ENDS的IP地址
Vpn-instance
VPN实例
Received packets
ENDC收到的报文统计信息:
·     Reply:表示注册应答报文
·     Error:表示错误指示报文
Sent packets
ENDC发送的报文统计信息:
·     Register:表示注册报文
·     Purge:表示注销报文
display vxlan neighbor-discovery client summary命令用来在ENDC上显示ENDC的运行信息。
通过本命令可以查看ENDC的运行信息,包括ENDC的配置信息、ENDC与ENDS的连接状态。
# 显示ENDC的运行信息。
<Sysname> display vxlan neighbor-discovery client summary
                         Status: I-Init  E-Establish  P-Probe
Interface    Local Address   Server Address  Network ID  Reg  Auth      Status   VPN Instance
Tunnel0      20.0.0.2        20.0.0.1        1           15   enabled   E   [No Vrf]
Tunnel0      20.0.0.2        20.0.0.3        1           15   enabled   P   [No Vrf]
Tunnel1      21.0.0.2        21.0.0.1        2           15   disabled  P   [No Vrf]
表1-12 display vxlan neighbor-discovery client summary命令显示信息描述表
启动ENDC功能的接口名称
Local Address
本地NVE隧道接口的源端地址,NA表示未配置
Server Address
ENDS的IP地址
Network ID
隧道的Network ID,NA表示未配置
Reg
注册时间间隔,单位为秒
Auth
是否开启认证功能:
·     enabled:表示已开启
·     disabled:表示未开启
Status
ENDC与ENDS的连接状态:
·     I:表示初始状态
·     E:表示已建立连接
·     P:表示未建立连接正在探测
Vpn-instance
VPN实例
·     vxlan neighbor-discovery authentication
·     vxlan neighbor-discovery client enable
·     vxlan neighbor-discovery client register-interval
display vxlan neighbor-discovery server member命令用来在ENDS上显示ENDS学到的成员信息。
display vxlan neighbor-discovery server member [ interface tunnel interface-number | local local-ip | remote client-ip ]
interface tunnel interface-number:显示通过指定NVE隧道接口学到的成员信息。interface-number为Tunnel接口的编号,取值范围为0~10239。
local local-ip:显示指定ENDS学到的成员信息。local-ip表示本地ENDS的IP地址。
remote client-ip:显示ENDS学到的指定IP地址的成员信息。client-ip表示ENDC的IP地址。
通过本命令可以查看ENDS学到的成员信息,包括成员的IP地址、桥MAC地址、创建时间、老化时间等信息。
如果不指定任何参数,将显示ENDS学到的所有成员信息。
# 显示ENDS学到的所有成员的信息。
<Sysname> display vxlan neighbor-discovery server member
IP Address: 1.1.1.1
Client Address  System ID         Expire    Created Time
1.1.1.1         0001-0000-0000    72        2014/08/01 03:34:22
2.2.2.2         0002-0000-0000    66        2014/08/01 03:39:24
3.3.3.3         0003-0000-0000    72        2014/08/01 03:42:34
表1-13 display vxlan neighbor-discovery server member命令显示信息描述表
启动ENDS功能的接口名称
Network ID
隧道的Network ID
Vpn-instance
VPN实例
IP Address
ENDS的IP地址
Client Address
学到的成员的IP地址
System ID
学到的成员的桥MAC地址
Expire
成员的剩余老化时间,单位为秒
Created Time
成员的创建时间
display vxlan neighbor-discovery server statistics命令用来在ENDS上显示ENDS的统计信息。
display vxlan neighbor-discovery server statistics interface tunnel interface-number
interface tunnel interface-number:显示指定NVE隧道接口对应的ENDS的统计信息。interface-number为Tunnel接口的编号,取值范围为0~10239。
通过本命令可以查看开启ENDS功能后,接口收到和发送报文的统计信息。
# 显示NVE隧道接口Tunnel0对应的ENDS的统计信息。
<Sysname> display vxlan neighbor-discovery server statistics interface tunnel 0
Received packets:
  Register:     170              Purge:      13
Sent packets:
  Reply:        170              Error:      1
表1-14 display vxlan neighbor-discovery server statistics命令显示信息描述表
Received packets
ENDS收到的报文统计信息:
·     Register:表示注册报文
·     Purge:表示注销报文
Sent packets
ENDS发送的报文统计信息:
·     Reply:表示注册应答报文
·     Error:表示错误指示报文
display vxlan neighbor-discovery server summary命令用来在ENDS上显示ENDS的运行信息。
通过本命令可以查看ENDS的运行信息,包括ENDS的配置信息、通过该ENDS学习到的ENDC个数。
# 显示ENDS的运行信息。
<Sysname> display vxlan neighbor-discovery server summary
Interface      Local Address   Network ID    Auth        Members   VPN Instance
Tunnel0        20.0.0.1        1             enabled     10        [No Vrf]
Tunnel2        21.0.0.1        2             disabled    20        [No Vrf]
Tunnel3        22.0.0.1        NA            disabled    0         [No Vrf]
表1-15 display vxlan neighbor-discovery server summary命令显示信息描述表
启动ENDS功能的接口名称
Local Address
接口的源端地址,NA表示未配置
Network ID
Auth
是否开启认证功能:
·     enabled:表示已开启
·     disabled:表示未开启
Members
通过该ENDS学习到的ENDC个数
Vpn-instance
VPN实例
·     vxlan neighbor-discovery server enable
1.3.7  network-id
network-id命令用来配置隧道的Network ID。
Undo network-id命令用来恢复缺省情况。
network-id network-id
undo network-id
未配置隧道的Network ID。
NVE模式Tunnel接口视图
number:Network ID值,取值范围为1~16777215。
VXLAN通过ENDP来自动发现远端VTEP。ENDP可以划分为多个实例,通过Network ID来标识ENDP实例。只有属于同一个ENDP实例的VTEP之间可以互相发现。
同一台设备的不同Tunnel接口下必须配置不同的Network ID。
# 配置NVE隧道Tunnel0的Network ID为123。
[Sysname] interface tunnel 0 mode nve
[Sysname-Tunnel0] network-id 123
vxlan neighbor-discovery authentication命令用来开启ENDP认证功能。
Undo vxlan neighbor-discovery authentication命令用来关闭ENDP认证功能。
vxlan neighbor-discovery authentication { cipher | simple } string
undo vxlan neighbor-discovery authentication
ENDP认证功能处于关闭状态。
NVE模式Tunnel接口视图
cipher:表示以密文方式设置密钥。
Simple:表示以明文方式设置密钥,该密钥将以密文形式存储。
String:密钥字符串,区分大小写。明文密钥为1~24个字符的字符串,密文密钥为1~65个字符的字符串。
为了安全起见,可以配置ENDP认证功能来防止恶意的节点注册到VXLAN网络。只有本端与对端设备上都未配置ENDP认证功能,或者都配置了认证功能且密钥相同,才能在二者之间成功建立VXLAN隧道。
开启ENDP认证功能后,发送ENDP报文的设备会使用配置的密钥和MD5算法对报文进行摘要运算,然后把运算结果放到报文的认证字段。对端设备收到ENDP报文后,利用本端配置的密钥和MD5算法对报文进行摘要运算,然后比较运算结果与报文认证字段携带的信息是否一致,如果一致则认为报文合法,如果不一致则认为报文非法。
在一个安全的网络中,可以不配置ENDP认证功能。
同一个VXLAN网络中所有的ENDS与ENDC必须配置相同的密钥。
# 开启ENDP认证功能,并以明文方式设置密钥为vxlan-a。
[Sysname-Tunnel0] vxlan neighbor-discovery authentication simple vxlan-a
·     display vxlan neighbor-discovery client summary
·     display vxlan neighbor-discovery server summary
vxlan neighbor-discovery client enable命令用来开启接口的ENDC功能,并指定ENDS地址。
Undo vxlan neighbor-discovery client enable命令用来关闭接口的ENDC功能。
vxlan neighbor-discovery client enable server-ip
undo vxlan neighbor-discovery client enable server-ip
ENDC功能处于关闭状态。
NVE模式Tunnel接口视图
server-ip:ENDC要连接的ENDS的IP地址。
为了防止ENDS异常导致ENDC不能加入VXLAN网络,用户可以通过重复执行本命令为每个ENDC指定两个ENDS。ENDC同时向两个ENDS注册和获取ENDC信息。
建议为地址相同、Network ID不同的ENDC指定不同的ENDS。
# 开启ENDC功能,并指定ENDS地址为11.0.0.1。
[Sysname-Tunnel0] vxlan neighbor-discovery client enable 11.0.0.1
vxlan neighbor-discovery client register-interval命令用来配置ENDC向ENDS注册的时间间隔。
Undo vxlan neighbor-discovery client register-interval命令用来恢复缺省情况。
vxlan neighbor-discovery client register-interval interval
undo vxlan neighbor-discovery client register-interval
ENDC向ENDS注册的时间间隔为15秒。
NVE模式Tunnel接口视图
interval:注册时间间隔,取值范围为5~120,单位为秒。
ENDP协议中定义了3个定时器:探测定时器、注册定时器、老化定时器。
·     探测定时器
ENDC请求加入VXLAN网络时会启用探测定时器,该定时器以5秒的时间间隔定时向ENDS发送注册报文,收到ENDS应答报文后会停止探测定时器。
·     注册定时器
ENDC加入VXLAN网络后,为了通告自己工作正常,会定时向ENDS发送注册报文,该定时器的默认时间间隔为15秒,用户可以通过配置vxlan neighbor-discovery client register-interval命令来调整该时间间隔。
如果ENDC连续发送5个注册报文,都未能收到ENDS的应答报文,则认为网络故障,此时需要清除之前学到的邻居信息,同时重新启用探测定时器。
·     老化定时器
ENDC向ENDS发送的注册报文中携带注册时间间隔,ENDS会记录该时间间隔。
ENDC加入VXLAN网络后,如果ENDS在5倍的注册时间内未收到ENDC的注册报文则认为ENDC出现故障,此时需要把ENDC从VXLAN网络中删除。
# 配置ENDC向ENDS注册的时间间隔为30秒。
[Sysname-Tunnel0] vxlan neighbor-discovery client register-interval 30
vxlan neighbor-discovery server enable命令用来开启接口的ENDS功能。
Undo vxlan neighbor-discovery server enable命令用来关闭接口的ENDS功能。
undo vxlan neighbor-discovery server enable
ENDS功能处于关闭状态。
NVE模式Tunnel接口视图
开启接口的ENDS功能时,会同时开启该接口的ENDC功能(该ENDC对应的ENDS地址为该接口的源地址)。
# 开启ENDS功能。
[Sysname-Tunnel0] vxlan neighbor-discovery server enable
