03-接口管理命令参考
03-WAN接口命令
本章节下载: 03-WAN接口命令  (731.14 KB)
03-WAN接口命令
1 WAN接口
1.1 WAN接口公共命令
1.1.1 bandwidth
1.1.2 default
1.1.3 description
1.1.4 shutdown
1.1.5 timer-hold
1.1.6 timer-hold retry
1.2 同步串口、异步串口、同/异步串口配置命令
1.2.1 async-mode
1.2.2 baudrate
1.2.3 clock
1.2.4 code
1.2.5 crc
1.2.6 detect dcd
1.2.7 detect dsr-dtr
1.2.8 display interface async
1.2.9 display interface serial
1.2.10 eliminate-pulse
1.2.11 idle-code
1.2.12 interface async
1.2.13 interface serial
1.2.14 invert receive-clock
1.2.15 invert transmit-clock
1.2.16 itf
1.2.17 link-protocol
1.2.18 loopback
1.2.19 loopback-test
1.2.20 mtu
1.2.21 phy-mru
1.2.22 physical-mode
1.2.23 reset counters interface
1.2.24 reset counters interface
1.2.25 reverse-rts
1.2.26 virtualbaudrate
1.3 AM接口配置命令
1.3.1 async-mode
1.3.2 display interface analogmodem
1.3.3 eliminate-pulse
1.3.4 interface analogmodem
1.3.5 loopback
1.3.6 mtu
1.3.7 phy-mru
1.3.8 reset counters interface
1.4 FCM接口配置命令
1.4.1 display interface fcm
1.4.2 interface fcm
1.4.3 mtu
1.4.4 pcm
1.4.5 reset counters interface
1.5 ISDN BRI接口配置命令
1.5.1 activate
1.5.2 display interface bri
1.5.3 interface bri
1.5.4 loopback
1.5.5 mtu
1.5.6 reset counters interface
1.6 CE1/PRI接口基本配置命令
1.6.1 alarm-detect
1.6.2 cable (CE1/PRI interface)
1.6.3 cable-type
1.6.4 channel-set (CE1/PRI interface)
1.6.5 clock (CE1/PRI interface)
1.6.6 clock-change auto
1.6.7 code (CE1/PRI interface)
1.6.8 controller e1
1.6.9 data-coding (CE1/PRI interface)
1.6.10 detect-ais
1.6.11 display controller e1
1.6.12 frame-format (CE1/PRI interface)
1.6.13 idle-code (CE1/PRI interface)
1.6.14 itf (CE1/PRI interface)
1.6.15 loopback (CE1/PRI interface)
1.6.16 pri-set (CE1/PRI interface)
1.6.17 reset counters controller e1
1.6.18 using (CE1/PRI interface)
1.6.19 work-mode
1.7 CT1/PRI接口基本配置命令
1.7.1 alarm-detect
1.7.2 alarm-threshold
1.7.3 bert (CT1/PRI interface)
1.7.4 cable (CT1/PRI interface)
1.7.5 channel-set (CT1/PRI interface)
1.7.6 clock (CT1/PRI interface)
1.7.7 code (CT1/PRI interface)
1.7.8 controller t1
1.7.9 data-coding (CT1/PRI interface)
1.7.10 display controller t1
1.7.11 fdl
1.7.12 frame-format (CT1/PRI interface)
1.7.13 idle-code (CT1/PRI interface)
1.7.14 itf (CT1/PRI interface)
1.7.15 loopback (CT1/PRI interfacei)
1.7.16 pri-set (CT1/PRI interface)
1.7.17 reset counters controller t1
1.7.18 sendloopcode
1.8 E1-F接口配置命令
1.8.1 clock-change auto
1.8.2 crc
1.8.3 display fe1
1.8.4 fe1 alarm-detect
1.8.5 fe1 cable
1.8.6 fe1 cable-type
1.8.7 fe1 clock
1.8.8 fe1 code
1.8.9 fe1 data-coding
1.8.10 fe1 detect-ais
1.8.11 fe1 frame-format
1.8.12 fe1 idle-code
1.8.13 fe1 itf
1.8.14 fe1 loopback
1.8.15 fe1 timeslot-list
1.8.16 fe1 unframed
1.8.17 mtu
1.8.18 reset counters interface
1.9 T1-F接口配置命令
1.9.1 crc
1.9.2 display ft1
1.9.3 ft1 alarm-detect
1.9.4 ft1 alarm-threshold
1.9.5 ft1 bert
1.9.6 ft1 cable
1.9.7 ft1 clock
1.9.8 ft1 code
1.9.9 ft1 data-coding
1.9.10 ft1 fdl
1.9.11 ft1 frame-format
1.9.12 ft1 idle-code
1.9.13 ft1 itf
1.9.14 ft1 loopback
1.9.15 ft1 sendloopcode
1.9.16 ft1 timeslot-list
1.9.17 mtu
1.9.18 reset counters interface
1.10 CE3接口配置命令
1.10.1 bert
1.10.2 clock
1.10.3 controller e3
1.10.4 display controller e3
1.10.5 e1 bert
1.10.6 e1 channel-set
1.10.7 e1 clock
1.10.8 e1 frame-format
1.10.9 e1 loopback
1.10.10 e1 shutdown
1.10.11 e1 unframed
1.10.12 fe3
1.10.13 loopback
1.10.14 national-bit
1.10.15 reset counters controller e3
1.10.16 using
1.11 CT3接口配置命令
1.11.1 alarm
1.11.2 bert
1.11.3 cable
1.11.4 clock
1.11.5 controller t3
1.11.6 display controller t3
1.11.7 feac
1.11.8 frame-format
1.11.9 ft3
1.11.10 loopback
1.11.11 mdl
1.11.12 reset counters controller t3
1.11.13 t1 alarm
1.11.14 t1 bert
1.11.15 t1 channel-set
1.11.16 t1 clock
1.11.17 t1 fdl
1.11.18 t1 frame-format
1.11.19 t1 loopback
1.11.20 t1 sendloopcode
1.11.21 t1 show
1.11.22 t1 shutdown
1.11.23 t1 unframed
1.11.24 using
1 WAN接口
本命令需要在设备具有相关接口的前提下支持,设备具有的接口请参见设备的安装手册和接口模块手册。
1.1  WAN接口公共命令
1.1.1  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbit/s)。
串口视图/串口子接口视图/AM接口视图/FCM接口视图/ISDN BRI接口视图/E1-F接口视图/T1-F接口视图
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbit/s。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 设置串口Serial2/1/0的期望带宽为50kbit/s。
[Sysname] interface serial 2/1/0
[Sysname-Serial2/1/0] bandwidth 50
1.1.2  default
default命令用来恢复当前接口的缺省配置。
default
串口视图/串口子接口视图/AM接口视图/FCM接口视图/ISDN BRI接口视图/E1-F接口视图/T1-F接口视图/CE3接口视图/CT3接口视图
CE1/PRI接口视图
CT1/PRI接口视图
# 将串口Serial2/1/0恢复为缺省配置。
[Sysname-Serial2/1/0] default
1.1.3  description
description命令用来设置当前接口的描述信息。
undo description命令用来恢复缺省情况。
接口的描述信息为“该接口的接口名 Interface”,比如:Serial2/1/0 Interface。
CE1/PRI接口视图
CT1/PRI接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 配置串口Serial2/1/0的描述信息为“router-interface”。
[Sysname-Serial2/1/0] description router-interface
1.1.4  shutdown
shutdown命令用来关闭接口。
undo shutdown命令用来恢复缺省情况。
shutdown
接口处于打开状态。
CE1/PRI接口视图
CT1/PRI接口视图
# 关闭串口Serial2/1/0。
[Sysname-Serial2/1/0] shutdown
1.1.5  timer-hold
timer-hold命令用来配置Keepalive报文的发送周期。
undo timer-hold命令用来恢复缺省情况。
timer-hold seconds
undo timer-hold
Keepalive报文的发送周期为10秒。
串口视图/AM接口视图/FCM接口视图/ISDN BRI接口视图/E1-F接口视图/T1-F接口视图
seconds:Keepalive报文的发送周期,取值范围为0~32767,单位为秒。
当接口上封装的链路层协议为PPP、FR或HDLC时,链路层会定期(可通过本命令修改)向对端发送Keepalive报文。如果在一段时间内无法收到对端发来的Keepalive报文,链路层会认为对端故障,从而上报链路层down。
在速率非常低的链路上,Keepalive报文的发送周期不能过小,因为大报文在低速链路上可能需要很长时间才能传送完毕,这样就会延迟Keepalive报文的收发。而接口在若干个(可通过timer-hold retry命令修改)Keepalive报文发送周期后仍未收到对端发来的Keepalive报文,就认为链路发生故障,从而拆除链路。
# 在串口Serial2/1/0上配置Keepalive报文的发送周期为15秒。
[Sysname-Serial2/1/0] timer-hold 15
·     timer-hold retry
timer-hold retry命令用来配置发送Keepalive报文的重试次数。
undo timer-hold retry命令用来恢复缺省情况。
timer-hold retry retries
发送Keepalive报文的重试次数为5。
retries:发送Keepalive报文的重试次数,取值范围为1~255。
当接口上封装的链路层协议为PPP、FR或HDLC时,链路层会定期(可通过timer-hold命令修改)向对端发送Keepalive报文。如果在一段时间内无法收到对端发来的Keepalive报文,链路层会认为对端故障,上报链路层Down。
在速率非常低的链路上,Keepalive报文的发送周期不能过小,因为大报文在低速链路上可能需要很长时间才能传送完毕,会延迟Keepalive报文的收发。而接口在retries个Keepalive报文发送周期后仍未收到对端发来的Keepalive报文,就认为链路发生故障,从而拆除链路。
# 在串口Serial2/1/0上,配置发送Keepalive报文的重试次数为10次。
[Sysname-Serial2/1/0] timer-hold retry 10
·     timer-hold
1.2.1  async-mode
async-mode命令用来设置异步串口的工作模式。
undo async-mode命令用来恢复缺省情况。
async-mode { flow | protocol }
undo async-mode
异步串口工作在协议模式(protocol)。
异步串口视图
同/异步串口视图
flow:流模式,也称交互模式。指物理连接建立之后,链路的两端进行交互,主叫端向被叫端发送配置命令(与用户从远端手工键入配置命令效果相同),设置被叫端的链路层协议工作参数,然后建立链路。一般用于拨号等人机交互的情况。
protocol:协议模式。指物理连接建立之后,接口直接采用已有的链路层协议配置参数建立链路。
同/异步串口只有通过命令physical-mode async切换到异步模式后才能配置async-mode命令。当异步串口工作在流模式时,不允许进行PPP的配置;当异步串口工作在协议模式时,允许进行PPP的配置。
# 设置异步串口Async2/4/0的工作模式为流模式。
[Sysname] interface async 2/4/0
[Sysname-Async2/4/0] async-mode flow
# 设置同/异步串口Serial2/1/0的工作模式为流模式。
[Sysname-Serial2/1/0] async-mode flow
·     physical-mode
1.2.2  baudrate
baudrate命令用来设置同步串口的波特率。
undo baudrate命令用来恢复缺省情况。
baudrate baudrate
undo baudrate
同步串口的波特率为64000bps。
同步串口视图
baudrate:同步串口的波特率,单位为bps。
同步串口支持的波特率有:
1200bps、2400bps、4800bps、9600bps、19200bps、38400bps、56000bps、57600bps、64000bps、72000bps、115200bps、128000bps、192000bps、256000bps、384000bps、512000bps、1024000bps、2048000bps、4096000bps。
在设置同步串口波特率时,需要注意同步串口外接电缆的电气规程等因素,另外同步串口对于不同的物理电气规程,所支持的波特率范围有所不同。
·     V.24 DTE/DCE:1200bps~64000bps
·     V.35 DCE/DCE、X.21 DTE/DCE、EIA/TIA-449 DTE/DCE以及EIA-530 DTE/DCE:1200bps~8192000bps
DCE设备和DTE设备之间线路传输的波特率,由DCE设备决定。
# 设置DCE设备的同步串口Serial2/1/0的波特率为115200bps。
[Sysname-Serial2/1/0] baudrate 115200
·     virtualbaudrate
1.2.3  clock
clock命令用来设置同步串口的时钟选择方式。
undo clock命令用来恢复缺省情况。
clock { dteclk1 | dteclk2 | dteclk3 | dteclk4 | dteclk5 | dteclkauto }
clock { dceclk1 | dceclk2 | dceclk3 }
undo clock
同步串口DTE侧的时钟为dteclk1,同步串口DCE侧的时钟为dceclk1。
同步串口视图
dteclk1:设置接口时钟方式为DTE时钟选择方式1。
dteclk2:设置接口时钟方式为DTE时钟选择方式2。
dteclk3:设置接口时钟方式为DTE时钟选择方式3。
dteclk4:设置接口时钟方式为DTE时钟选择方式4。
dteclk5:设置接口时钟方式为DTE时钟选择方式5。
dteclkauto:设置接口时钟方式为DTE自动协商。
dceclk1:设置接口时钟方式为DCE时钟选择方式1。
dceclk2:设置接口时钟方式为DCE时钟选择方式2。
dceclk3:设置接口时钟方式为DCE时钟选择方式3。
当接口工作在DTE方式时,支持命令clock { dteclk1 | dteclk2 | dteclk3 | dteclk4 | dteclk5 | dteclkauto };当接口工作在DCE方式时,支持命令clock { dceclk1 | dceclk2 | dceclk3 }。
同步串口有两种工作方式:DTE和DCE,不同的工作方式有不同的工作时钟选择。
·     如果同步串口作为DCE侧,则需要向对端DTE侧提供时钟DCEclk;
·     如果同步串口作为DTE侧,则需要接受对端DCE侧提供的时钟,由于同步设备的接收和发送时钟是独立的,则DTE侧的接收时钟可以选择DCE侧的发送或接收时钟,DTE侧的发送时钟也可以选择DCE侧的发送或接收时钟,由此产生五种组合,即在DTE侧可以有五种时钟选择。
图1-1 同步串口时钟选择示意图
其中,TxClk为发送时钟,RxClk为接收时钟。
时钟选择方法规定如下表所示。
表1-1 同步串口DTE侧时钟的选择方法
选择方法
意义
DTEclk1
TxClk = TxClk, RxClk = RxClk
DTEclk2
TxClk = TxClk, RxClk = TxClk
DTEclk3
TxClk = RxClk, RxClk = TxClk
DTEclk4
TxClk = RxClk, RxClk = RxClk
DTEclk5
TxClk = Local, RxClk = Local
其中,‘=’前为DTE侧时钟,‘=’后为DCE侧时钟。
表1-2 同步串口DCE侧时钟的选择方法
选择方法
意义
DCEclk1
DCEclk2
TxClk = Local, RxClk = Line
DCEclk3
TxClk = Line, RxClk = Line
其中,‘=’前为DCE侧时钟,‘=’后为时钟信号来源。
# 设置同步串口Serial2/1/0作为DTE侧的时钟选择方式为DTEclk2。
[Sysname-Serial2/1/0] clock dteclk2
1.2.4  code
code命令用来配置同步串口的数字信号编码格式。
undo code命令用来恢复缺省情况。
code { nrz | nrzi }
undo code
同步串口的数字信号编码格式为NRZ。
同步串口视图
nrz:采用NRZ(Non-Return to Zero,不归零)的数字信号编码格式。
nrzi:采用NRZI(Non-Return to Zero Inverted,反向不归零)的数字信号编码格式。
# 配置同步串口Serial2/1/0的数字信号编码格式为NRZI。
[Sysname-Serial2/1/0] code nrzi
1.2.5  crc
crc命令用来配置同步串口的CRC校验模式。
undo crc命令用来恢复缺省情况。
crc { 16 | 32 | none }
undo crc
使用16位CRC校验。
同步串口视图
16:同步串口使用16位CRC校验。
32:同步串口使用32位CRC校验。
none:同步串口不进行CRC校验。
# 配置同步串口Serial2/1/0使用32位CRC校验。
[Sysname-Serial2/1/0] crc 32
1.2.6  detect dcd
detect dcd命令用来打开数据载波检测功能。即检测DSU/CSU的DCD(Data Carrier Detect,数据载波检测)信号。
undo detect dcd命令用来关闭数据载波检测功能。
detect dcd
undo detect dcd
数据载波检测功能处于打开状态。
同步串口视图
系统在判断同步串口的状态(up或down)时,缺省情况下将同时检测DSR信号、DCD信号以及接口是否外接电缆。只有当三个信号全部有效时,系统才认为同步串口处于up状态,否则为down状态。
# 打开同步串口Serial2/1/0的数据载波检测功能。
[Sysname-Serial2/1/0] detect dcd
·     detect dsr-dtr
detect dsr-dtr命令用来打开电平检测功能,即检测DSU/CSU(Data Service Unit/Channel Service Unit,数据服务单元/信道服务单元,表示数字MODEM)的DSR(Data Set Ready,数据置位就绪)和DTR(Data Terminal Ready,数据终端就绪)信号。
undo detect dsr-dtr命令用来关闭电平检测功能。
detect dsr-dtr
undo detect dsr-dtr
电平检测功能处于打开状态。
同步串口视图/异步串口视图
同/异步串口视图
如果禁止异步串口进行电平检测,系统将不检测异步串口是否外接电缆,自动向用户报告异步串口的状态为up,且DTR = up、DSR = up;如果允许异步串口进行电平检测,则系统将不仅检测异步串口是否外接电缆,同时还要检测DSR信号,只有当该信号有效时,系统才认为异步串口处于up状态,否则,为down状态。
系统在判断同步串口的状态(up或down)时,缺省情况下将同时检测DSR信号、DCD信号以及接口是否外接电缆。只有当三个信号全部有效时,系统才认为同步串口处于up状态,否则为down状态。如果禁止同步串口进行电平检测,系统检测到外接电缆后,接口状态为up,且DTR = up、DSR = up。
# 打开同步串口Serial2/1/0的电平检测功能。
[Sysname-Serial2/1/0] detect dsr-dtr
# 打开异步串口Async2/4/0的电平检测功能。
[Sysname-Async2/4/0] detect dsr-dtr
·     detect dcd
display interface async命令用来显示异步串口的相关信息。
display interface [ async [ interface-number ] ] [ brief [ description | down ] ]
interface-number:显示指定异步串口的信息。
如果不指定async参数,将显示设备支持的所有接口的相关信息。
如果指定async参数,不指定interface-number参数,将显示所有已创建的异步串口的相关信息。
# 显示异步串口Async2/4/0的详细信息。
<Sysname> display interface async 2/4/0
Async2/4/0
Current state: DOWN
Line protocol state: DOWN
Description: Async2/4/0 Interface
Bandwidth: 9kbps
Hold timer: 10 seconds, retry times: 5
Link layer protocol: PPP
LCP: initial
Last link flapping: 6 hours 39 minutes 25 seconds
Current system time:2017-11-11 10:01:44
Last time when physical state changed to up:2017-11-11 10:01:41
Last time when physical state changed to down:2017-11-11 10:00:17
Physical layer: asynchronous, Baudrate: 9600 bps
Last 300 seconds input rate: 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
Last 300 seconds output rate: 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
Input:
  1 packets, 0 bytes
  0 broadcasts, 0 multicasts
  1 errors, 0 runts, 0 giants
  0 crc, 0 align errors, 0 overruns
0 aborts, 0 no buffers, 1 frame errors
Output:
  0 packets, 0 bytes
  0 errors, 0 underruns, 0 collisions
  0 deferred
DCD: DOWN, DTR: UP, DSR: DOWN, RTS: UP, CTS: DOWN
# 显示异步串口Async2/4/0的概要信息。
<Sysname> display interface async 2/4/0 brief
Protocol: (s) - spoofing
Asy2/4/0             DOWN DOWN     --
# 显示当前物理状态为down的异步串口的信息以及down的原因。
<Sysname> display interface async brief down
Asy2/4/0             ADM  Administratively
表1-3 display interface async命令显示信息描述表
Async2/4/0
Current state
接口当前的物理状态和管理状态,可能的取值及含义如下:
·     DOWN(Administratively):表示该接口已经通过shutdown命令被关闭,即管理状态为关闭
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     UP:该接口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态,可能的状态及含义如下:
·     UP:表示数据链路层协议状态为开启
·     DOWN:表示数据链路层协议状态为关闭
接口的描述信息
Bandwidth
接口的期望带宽
接口的最大传输单元
Hold timer
当前接口发送keepalive报文的周期
retry times
在多少个keepalive周期内没有收到keepalive报文的应答就拆除链路
网络层协议处理状况
链路层封装的协议
LCP: initial
LCP(链路控制协议)初始化完成
输出队列(紧急队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
输出队列(协议队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
输出队列(先进先出队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
Last link flapping
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过)
最近一次使用reset counters interface命令清除接口下的统计信息的时间。如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never
Current system time
当前系统时间
接口最近一次物理状态up的时间
接口最近一次物理状态down的时间
Physical layer
物理层链路信息
Baudrate
接口的波特率
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的报文数
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的报文数
Input:
  1 packets, 0 bytes
接口收到的总报文数和总字节数:
·     broadcasts:接收的广播报文的数目
·     multicasts:接收的组播报文的数目
·     errors:在物理层检测时发现的错误报文数目
·     runts:接口接收到小于规定的最小报文长度报文数
·     giants:接收到长度大于规定长度的报文数目
·     crc:接收长度正常但CRC 校验错误的报文数目
·     align errors:排列错误
·     overruns:接收的报文速度大于转发处理能力导致无法处理的报文
·     aborts:接收报文的异常错误
·     no buffers:在接收报文时由于内部缓存满,导致帧丢弃
·     frame errors:帧错误
Output:
  0 packets, 0 bytes
  0 deferred
接口发送的报文数和总字节数
·     underruns:因为接口读取内存的速度小于转发的速度而无法发送报文数目
·     collisions:发送报文时,检测到冲突的报文数目
·     deferred:因为延时或超时无法发送报文的数目
DCD(Data Carrier Detect)信号处于down状态,DTR(Data Terminal Ready)信号处于up状态,DSR(Data Set Ready)信号处于down状态,关于DCD、DTR和DSR请参考detect命令
RTS(Request to Send)处于up状态,CTS(Clear to Send)处于down状态
三层接口的概要信息
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
接口名称缩写
Link
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被手工关闭了,需要执行undo shutdown命令才能打开接口
·     Stby:表示该接口是一个备份接口
Protocol
接口数据链路层协议状态,取值可能为:
·     UP:表示接口的数据链路层是连通的
·     DOWN:表示接口的数据链路层不通
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
Primary IP
接口主IP地址
用户通过description命令给接口配置的描述信息。使用display interface brief命令,不指定description参数时,该字段最多显示27个字符;指定description参数时,可显示配置的全部描述信息
Cause
接口物理连接状态为down的原因,取值为Administratively时表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态;取值为Not connected时表示没有物理连接(可能没有插网线或者网线故障)
·     reset counters interface
display interface serial命令用来显示Serial接口的相关信息。
display interface [ serial [ interface-number ] ] [ brief [ description | down ] ]
interface-number:显示指定Serial接口的信息。
如果不指定serial参数,将显示设备支持的所有接口的相关信息。
如果指定serial参数,不指定interface-number参数,将显示所有已创建的Serial接口的相关信息。
# 显示同步串口Serial2/1/0的详细信息。
<Sysname> display interface serial 2/1/0
Serial2/1/0
Current state: UP
Line protocol state: UP
Description: Serial2/1/0 Interface
Bandwidth: 64kbps
Hold timer:10 seconds, retry times: 5
Internet Address: 9.9.9.6/24 Primary
LCP: opened
Physical layer: synchronous, Baudrate: 64000 bps
Interface: DCE
Cable type: V35
Clock mode: DCECLK1
Last 300 seconds input rate: 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Last 300 seconds output rate: 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Input:
  6668 packets, 80414 bytes
  0 errors, 0 runts, 0 giants
  0 aborts, 0 no buffers, 0 frame errors
Output:
  6670 packets, 80446 bytes
  0 deferred
DCD: UP, DTR: UP, DSR: UP, RTS: UP, CTS: UP
# 显示同步串口Serial2/1/0的概要信息。
<Sysname> display interface serial 2/1/0 brief
Ser2/1/0             UP   UP(s)    --
# 显示当前物理状态为down的Serial接口的信息以及down的原因。
<Sysname> display interface serial brief down
Ser2/1/0             ADM  Administratively
表1-4 display interface serial命令显示信息描述表
Serial2/1/0
Current state
串口当前的物理状态和管理状态,可能的取值及含义如下:
·     DOWN(Administratively):表示该串口已经通过shutdown命令被关闭,即管理状态为关闭
·     DOWN:表示该串口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     UP:该串口的管理状态和物理状态均为开启
Line protocol state
该接口的链路层协议状态,可能的状态及含义如下:
·     UP:表示数据链路层协议状态为开启
接口的描述信息
Bandwidth
接口的期望带宽
接口的最大传输单元
Hold timer
retry times
Internet Address
接口的IP地址
Link layer protocol
串口的数据链路层协议
LCP: opened
表示PPP连接建立成功
Last link flapping
Current system time
当前系统时间
接口最近一次物理状态up的时间
接口最近一次物理状态down的时间
Physical layer
物理层链路信息
Baudrate
串口的波特率
Interface: DCE
Cable type: V35
Clock mode: DCECLK1
同步串口DCE侧的时钟选择方式
Last 300 seconds input rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Last 300 seconds output rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Input:
接口收到的总报文数和总字节数:
·     crc:接收长度正常但CRC校验错误的报文数目
·     align errors:排列错误
·     aborts:接收报文的异常错误
·     frame errors:帧错误
Output:
  0 deferred
接口发送的报文数和总字节数
DCD(Data Carrier Detect)、DTR(Data Terminal Ready)和DSR(Data Set Ready)信号处于up状态,关于DCD、DTR和DSR请参考detect命令
RTS(Request to Send)和CTS(Clear to Send)处于up状态
三层接口的概要信息
接口名称缩写
Link
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     Stby:表示该接口是一个备份接口
Protocol
接口数据链路层协议状态,取值可能为:
·     UP:表示接口的数据链路层是连通的
·     DOWN:表示接口的数据链路层不通
Primary IP
接口主IP地址
Cause
eliminate-pulse命令用来消除脉冲宽度小于3.472μs的脉冲。
undo eliminate-pulse命令用来恢复缺省情况。
eliminate-pulse
消除脉冲宽度小于1.472μs的脉冲。
异步串口视图
同/异步串口视图
同/异步串口只有通过命令physical-mode async切换到异步模式后才能配置eliminate-pulse命令。
波特率等于115200bps时不能配置该命令;配置该命令后,波特率不能等于115200bps。
本命令仅用于8ASE/16ASE接口卡/模块。
在线路干扰较大时可以配置本命令,增加信号的可靠性。
# 配置异步串口Async2/4/0消除脉冲宽度小于3.472μs的脉冲。
[Sysname-Async2/4/0] eliminate-pulse
# 配置同/异步串口Serial2/1/0消除脉冲宽度小于3.472μs的脉冲。
[Sysname-Serial2/1/0] eliminate-pulse
·     physical-mode
1.2.11  idle-code
idle-code命令用来设置同步串口的线路空闲码类型。
undo idle-code命令用来恢复缺省情况。
idle-code { 7e | ff }
undo idle-code
同步串口的线路空闲码类型为0x7e。
同步串口视图
7e:线路空闲码为0x7e类型。
ff:线路空闲码为0xff类型。
通常情况下,同步串口使用0x7e来表示线路的空闲状态,而有的设备在空闲时间采用0xff(即全“1”的高电平)来表示线路的空闲状态。为了更好的兼容这种设备,需要设置同步串口的线路空闲码。
# 设置同步串口Serial2/1/0的线路空闲码为“0xFF”。
[Sysname-Serial2/1/0] idle-code ff
interface async命令用来进入异步串口视图。
interface async interface-number
interface-number:异步串口的编号。
# 进入异步串口Async2/4/0的视图。
interface serial命令用来进入串口视图或创建串口子接口并进入串口子接口视图。如果指定的串口子接口已经存在,则直接进入串口子接口视图
undo interface serial命令用来删除串口子接口。
interface serial { interface-number | interface-number.subnumber [ p2mp | p2p ] }
undo interface serial interface-number.subnumber
不存在串口子接口。
interface-number:串口编号。
interface-number.subnumber:串口子接口编号,其中interface-number为主接口编号;subnumber为子接口编号,取值范围为0~1023。
p2mp:点到多点子接口。子接口缺省为p2mp类型。
p2p:点到点子接口。
只有串口主接口上封装的链路层协议为FR时,才能创建子接口。
# 创建串口接口Serial2/0.1。
[Sysname] interface serial 2/0.1
[Sysname-Serial2/0.1]
·     link-protocol
invert receive-clock命令用来允许翻转DTE侧同步串口的接收时钟信号。
undo invert receive-clock命令用来恢复缺省情况。
同步串口作为DTE侧时,禁止翻转接收时钟信号。
同步串口视图
在某些特殊情况下,为了消除线路上半个时钟周期的时延,可以将DTE侧同步串口的接收时钟信号翻转。只有连接某些特殊的DCE设备时,DTE侧需要配置该命令,对于通常的应用,时钟不应作翻转。
# 将DTE侧同步串口Serial2/1/0的接收时钟翻转。
[Sysname-Serial2/1/0] invert receive-clock
·     invert transmit-clock
invert transmit-clock命令用来允许翻转DTE侧同步串口的发送时钟信号。
undo invert transmit-clock命令用来恢复缺省情况。
同步串口作为DTE侧时,禁止翻转发送时钟信号。
同步串口视图
在某些特殊情况下,为了消除线路上半个时钟周期的时延,可以将DTE侧同步串口的发送时钟信号翻转。只有连接某些特殊的DCE设备时,DTE侧需要配置该命令,对于通常的应用,时钟不应作翻转。
# 将DTE侧同步串口Serial2/1/0的发送时钟翻转。
[Sysname-Serial2/1/0] invert transmit-clock
·     invert receive-clock
1.2.16  itf
itf命令用来设置帧间填充字节的个数。
undo itf命令用来恢复缺省情况。
itf number number
undo itf number
帧间填充字节个数为4。
同步串口视图
number number:设置帧间填充字节的个数,取值范围为0~14,单位为字节。
# 设置同步串口Serial2/1/0的帧间填充字节个数为5。
[Sysname-Serial2/1/0] itf number 5
link-protocol命令用来设置接口的链路层协议。
link-protocol { fr | hdlc | ppp | mfr | stlp }
同步串口使用PPP作为链路层协议。
同步串口视图
同/异步串口视图
fr:使用帧中继作为接口的链路层协议。
hdlc:使用HDLC作为接口的链路层协议。
mfr:使用MFR作为接口的链路层协议。
ppp:使用PPP作为接口的链路层协议。
stlp:使用STLP作为接口的链路层协议。
# 设置同步串口Serial2/1/0的链路层协议为HDLC。
[Sysname-Serial2/1/0] link-protocol hdlc
1.2.18  loopback
loopback命令用来开启对内自环功能。
undo loopback命令用来关闭对内自环功能。
loopback
undo loopback
对内自环功能处于关闭状态。
同步串口视图/异步串口视图
同/异步串口视图
只有在进行某些特殊功能测试时,才将接口设为对内自环。
# 配置同步串口Serial2/1/0对内自环。
[Sysname-Serial2/1/0] loopback
# 配置异步串口Async2/4/0对内自环。
[Sysname-Async2/4/0] loopback
loopback-test命令用来检测线路是否环回。
loopback-test [ -c count | -p { pattern | special { ascending | descending | random } } | -s packetsize | -t timeout ] * interface interface-type interface-number
不进行线路的环回检测。
-c count:设置发送测试报文次数,取值范围为1~4294967295,缺省为5次。
-p pattern:设置测试报文的填充内容,取值范围为16进制数0~FFFFFFFF,如-p ff将报文全部填充为ff,缺省填充方式为0x55和0xAA交替填充。
ascending:设置循环使用0x00~0xff的递增序列,逐字节填充测试报文。
descending:设置循环使用0xff~0x00的递减序列,逐字节填充测试报文。
random:设置使用0x00~0xff范围内的随机数序列,逐字节填充测试报文。
-s packetsize:设置测试报文长度(不包括报文头的8字节),取值范围为0~1688,单位为字节,缺省为52字节。
-t timeout:设置发送测试报文后等待接收的超时时间,范围为0~5000,单位为毫秒,缺省为2000毫秒。
interface interface-type interface-number:接口类型及接口编号。
只有E1、T1、E1-F、T1-F产生的同步串口支持本命令。
loopback-test命令执行过程为:在接口上发送测试报文,如果接口线路远端环回,则接口会收到刚刚发送的测试报文。
loopback-test命令可以用来测试线路是否环回,也可以用来检查环回线路的传输质量。其输出信息包括:
·     每个环回测试报文的接收情况。如果在超时时间内没有收到环回的测试报文,则输出“Wait time out.”;否则,显示收到的测试报文的字节数、报文序号、延时等。
·     环回测试报文的统计信息,包括发送报文个数、接收报文个数、未收到报文个数、接收到内容错误的报文个数、未收到报文数百分比、接收到内容错误的报文数百分比、延时的最小、最大和平均值以及环回与否的测试结论。
如果线路传输速度较慢,可以适当加大等待接收报文的超时时间。
# 检查接口Serial1/0/0及其连接的线路是否环回。
<Sysname> loopback-test interface serial 1/0/0
 Loopback test on Serial1/0/0: 52 data bytes, Press CTRL_C to break
    Received from Serial1/0/0: bytes=52  sequence=1  time=1 ms
    Received from Serial1/0/0: bytes=52  sequence=2  time=1 ms
    Received from Serial1/0/0: bytes=52  sequence=3  time=1 ms
    Received from Serial1/0/0: bytes=52  sequence=4  time=1 ms
    Received from Serial1/0/0: bytes=52  sequence=5  time=1 ms
  --- Serial1/0/0 loopback test statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0 packet(s) lost
    0 packet(s) error
    0.00% packet loss
    0.00% packet error
    Round-trip min/avg/max = 1/1/1 ms
    Test result: Loopback is enabled on the remote end。
表1-5 looptest命令显示信息描述表
  Loopback test on Serial1/0/0: 52 data bytes, press CTRL_C to break
检查Serial1/0/0线路是否存在环回。每个环回测试报文中的数据为52字节,按组合键Ctrl+C可以终止环回测试
收到Serial1/0/0接口发送来的测试报文,具体显示信息如下:
·     bytes表示测试报文中的数据字节数
·     sequence表示测试报文序号,用来判断报文是否有分组丢失、失序或重复
·     time表示响应时间
若没有收到测试报文,显示Wait time out超时,报文丢失
环回测试中收发数据的统计结果
发送的测试报文数
收到的测试报文数
0 packet(s) lost
未响应测试报文数
0 packet(s) error
收到错误报文数
0.00% packet loss
未响应测试报文占发送的总测试报文的百分比
0.00% packet error
错误报文占发送的总测试报文的百分比
响应时间的最小值、平均值、最大值,单位为毫秒
Test result: Loopback is enabled on the remote end.
测试结果:远端环回
若没有环回, Test result: Loopback is not enabled on the remote end.
可能存在远端环回,Test result: Loopback might be enabled on the remote end.
·     loopback
·     fe1 loopback
·     ft1 loopback
1.2.20  mtu
mtu命令用来设置接口的MTU(Maximum Transmission Unit,最大传输单元)值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
串口的MTU值为1500字节。
同步串口视图/异步串口视图/串口子接口视图
同/异步串口视图
接口的MTU值影响IP协议报文在该接口上传输时的分片与重组。
需要注意的是,配置了mtu命令后需要执行命令shutdown和undo shutdown,这样该配置才能在接口上生效。
# 配置同步串口Serial2/1/0的MTU值为1430字节。
[Sysname-Serial2/1/0] mtu 1430
# 配置异步串口Async2/4/0的MTU值为1430字节。
[Sysname-Async2/4/0] mtu 1430
1.2.21  phy-mru
phy-mru命令用来配置异步串口在流模式下接收包的最大长度。
undo phy-mru命令用来恢复缺省情况。
phy-mru mrusize
undo phy-mru
异步串口在流模式下接收包的最大长度为1700字节。
异步串口视图
同/异步串口视图
mrusize:异步串口在流模式下接收包的最大长度,取值范围为4~1700,单位为字节。
phy-mru命令只有在异步流模式下能够成功配置。
# 设置异步串口Async2/4/0在流模式下接收包的最大长度为1500字节。
[Sysname-Async2/4/0] phy-mru 1500
# 设置同/异步串口Serial2/1/0在流模式下接收包的最大长度为1500字节。
[Sysname-Serial2/1/0] physical-mode async
[Sysname-Serial2/1/0] phy-mru 1500
·     async-mode
·     physical-mode
physical-mode命令用来设置同/异步串口的工作方式。
undo physical-mode命令用来恢复缺省情况。
physical-mode { async | sync }
undo physical-mode
同/异步串口工作在同步(sync)方式。
同/异步串口视图
async:设置同/异步串口工作在异步方式。
sync:设置同/异步串口工作在同步方式。
# 设置同/异步串口Serial2/1/0工作在异步方式。
reset counters interface命令用来清除指定Serial接口的统计信息。
reset counters interface [ serial [ interface-number ] ]
serial interface-number:指定Serial接口。
·     如果不指定serial和interface-number,则清除所有接口的统计信息;
·     如果指定serial而不指定interface-number,则清除所有Serial接口的统计信息;
·     如果同时指定serial和interface-number,则清除指定Serial接口的统计信息。
# 清除同步串口Serial2/1/0的统计信息。
<Sysname> reset counters interface serial 2/1/0
·     display interface serial
reset counters interface命令用来清除指定异步串口的统计信息。
reset counters interface [ async [ interface-number ] ]
async interface-number:指定异步串口。
·     如果不指定async和interface-number,则清除所有接口的统计信息;
·     如果指定async而不指定interface-number,则清除所有异步串口的统计信息;
·     如果同时指定async和interface-number,则清除指定异步串口的统计信息。
# 清除异步串口Async2/4/0的统计信息。
<Sysname> reset counters interface async 2/4/0
·     display interface async
1.2.25  reverse-rts
reverse-rts命令用来配置翻转RTS信号。
undo reverse-rts命令用来恢复缺省情况。
reverse-rts
undo reverse-rts
不翻转RTS信号。
同步串口视图
配置reverse-rts命令后,本端发送数据时不允许对端发送数据。
只在特定的调试需要时,才需要翻转RTS信号。
# 设置同步串口Serial2/1/0翻转RTS信号。
[Sysname-Serial2/1/0] reverse-rts
virtualbaudrate命令用来配置DTE接口的虚拟波特率。
undo virtualbaudrate命令用来取消虚拟波特率的配置。
virtualbaudrate virtualbaudrate
同步串口的虚拟波特率为64000bps。
同步串口视图
virtualbaudrate:指定的波特率,需要与DCE侧的配置保持一致。其取值范围为1200、2400、4800、9600、19200、38400、56000、57600、64000、72000、115200、128000、192000、256000、384000、512000、1024000、2048000、4096000,单位为bps。
当串口工作为DTE模式时,接口波特率通过协商从对端(DCE侧)获得。virtualbaudrate命令给用户提供一种手工配置DTE侧波特率的方式。
如果接口时钟方式为dteclk5时钟模式,配置的虚拟波特率就是线路速率。
接口波特率(通过baudrate命令配置)和虚拟波特率(通过virtualbaudrate命令配置)的区别在于:
·     波特率和虚拟波特率不能在链路的同一端配置,波特率用于DCE端,虚拟波特率用于DTE端(仅同步模式)
·     在DCE端,通过display interface命令看到的是接口的波特率;而在DTE端,通过display interface命令看到的是接口的虚拟波特率。
# 设置DTE设备的同步串口Serial2/1/0的虚拟波特率为19200bps。
[Sysname-Serial2/1/0] virtualbaudrate 19200
·     baudrate
·     clock
1.3  AM接口配置命令
1.3.1  async-mode
async-mode命令用来设置AM接口的工作模式。
undo async-mode
AM接口工作在流模式(flow)。
AM接口视图
flow:流模式,也称交互模式。指物理连接建立之后,链路的两端进行交互,主叫端向接收端发送配置命令(与用户从远端手工键入配置命令效果相同),设置接收端的链路层协议工作参数,然后建立链路。一般用于拨号等人机交互的情况。
# 设置AM接口Analogmodem2/4/0的工作模式为协议模式。
[Sysname] interface analogmodem 2/4/0
[Sysname-Analogmodem2/4/0] async-mode protocol
display interface analogmodem命令用来显示AM接口的相关信息。
display interface [ analogmodem [ interface-number ] ] [ brief [ description | down ] ]
interface-number:显示指定AM接口的信息。
如果不指定analogmodem参数,将显示设备支持的所有接口的相关信息。
如果指定analogmodem参数,不指定interface-number参数,将显示所有已创建的AM接口的相关信息。
# 显示AM接口Analogmodem2/4/0的详细信息。
<Sysname> display interface analogmodem 2/4/0
Analogmodem2/4/0
Current state: DOWN
Description: Analogmodem2/4/0 Interface
Bandwidth: 57kbps
LCP: initial
Physical layer: asynchronous, Baudrate: 57600 bps
Input:
  0 packets, 0 bytes
Output:
  0 packets, 0 bytes
  0 deferred
DCD: DOWN, DTR: UP, DSR: UP, RTS: UP, CTS: UP
# 显示AM接口Analogmodem2/4/0的概要信息。
<Sysname> display interface analogmodem 2/4/0 brief
AM2/4/0              DOWN DOWN     --
# 显示当前物理状态为down的AM接口的信息以及down的原因。
<Sysname> display interface analogmodem brief down
AM2/4/0              ADM  Administratively
表1-6 display interface analogmodem命令显示信息描述表
Analogmodem2/4/0
Current state
Line protocol state
·     UP:表示数据链路层协议状态为开启
接口的描述信息
Bandwidth
接口的期望带宽
接口的最大传输单元
Hold timer
retry times
网络层协议处理状况
链路层封装的协议
LCP: initial
LCP(链路控制协议)初始化完成
Output queue - Protocol queuing: Size/Length/Discards)
Last link flapping
Current system time
当前系统时间
接口最近一次物理状态up的时间
接口最近一次物理状态down的时间
Physical layer
物理层链路信息
Baudrate
接口的波特率
Input:
  0 packets, 0 bytes
接口收到的总报文数和总字节数:
·     align errors:排列错误
·     aborts:接收报文的异常错误
·     frame errors:帧错误
Output:
  0 packets, 0 bytes
  0 deferred
接口发送的报文数和总字节数
DCD(Data Carrier Detect)信号处于down状态,DTR(Data Terminal Ready)和DSR(Data Set Ready)信号处于up状态,RTS(Request to Send)和CTS(Clear to Send)处于up状态
三层接口的概要信息
接口名称缩写
Link
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     Stby:表示该接口是一个备份接口
Protocol
接口数据链路层协议状态,取值可能为:
·     UP:表示接口的数据链路层是连通的
·     DOWN:表示接口的数据链路层不通
Primary IP
接口主IP地址
Cause
eliminate-pulse命令用来消除脉冲宽度小于3.472μs的脉冲,增加信号的可靠性。
eliminate-pulse
消除脉冲宽度小于1.472μs的脉冲。
AM接口视图
波特率等于115200bps时不能配置该命令,同时配置该命令后,波特率不能等于115200bps。
在线路干扰较大时可以配置本命令。
# 配置AM接口Analogmodem2/4/0消除脉冲宽度小于3.472μs的脉冲。
[Sysname-Analogmodem2/4/0] eliminate-pulse
interface analogmodem命令用来进入AM接口视图。
interface analogmodem { interface-number | interface-number:15 }
interface-number:AM接口的编号。
interface-number:15:由CE1/PRI接口生成的AM接口的编号,其中interface-number是CE1/PRI接口的编号。
# 进入AM接口Analogmodem2/4/0的接口视图。
# 进入AM接口Analogmodem2/4/0:15的接口视图。
[Sysname] interface analogmodem 2/4/0:15
[Sysname-Analogmodem2/4/0:15]
1.3.5  loopback
loopback
undo loopback
对内自环功能处于关闭状态。
AM接口视图
# 配置AM接口Analogmodem2/4/0对内自环。
[Sysname-Analogmodem2/4/0] loopback
1.3.6  mtu
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
AM接口的MTU值为1500字节。
AM接口视图
# 设置AM接口Analogmodem2/4/0的MTU值为1430字节。
[Sysname-Analogmodem2/4/0] mtu 1430
1.3.7  phy-mru
phy-mru命令用来配置AM接口在流模式下接收包的最大长度。
phy-mru mrusize
undo phy-mru
AM接口在流模式下接收包的最大长度为1700字节。
AM接口视图
mrusize:AM接口在流模式下接收包的最大长度,取值范围为4~1700,单位为字节。
# 设置AM接口Analogmodem2/4/0在流模式下接收包的最大长度为1500字节。
[Sysname-Analogmodem2/4/0] async-mode flow
[Sysname-Analogmodem2/4/0] phy-mru 1500
·     async-mode
reset counters interface命令用来清除指定AM接口的统计信息。
reset counters interface [ analogmodem [ interface-number ] ]
analogmodem interface-number:指定AM接口。
·     如果不指定analogmodem和interface-number,则清除所有接口的统计信息;
·     如果指定analogmodem而不指定interface-number,则清除所有AM接口的统计信息;
·     如果同时指定analogmodem和interface-number,则清除指定AM接口的统计信息。
# 清除AM接口Analogmodem2/4/0的统计信息。
<Sysname> reset counters interface analogmodem 2/4/0
·     display interface analogmodem
1.4  FCM接口配置命令
display interface fcm命令用来显示FCM接口的相关信息。
display interface [ fcm [ interface-number ] ] [ brief [ description | down ] ]
interface-number:显示指定FCM接口的信息。interface-number表示FCM接口的编号。
如果不指定fcm参数,将显示设备支持的所有接口的相关信息;
如果指定fcm参数,不指定interface-number参数,将显示所有已创建的FCM接口的相关信息。
# 显示接口FCM2/4/0:15.1的详细信息。
<Sysname> display interface fcm 2/4/0:15.1
Fcm2/4/0:15.1
Current state: DOWN
Description: Fcm2/4/0:15.1 Interface
Bandwidth: 9kbps
Input:
  0 packets, 0 bytes
  0 CRC, 0 align errors, 0 overruns
  0 frame errors, 0 aborts, 0 no buffers
Output:
  0 packets, 0 bytes
  0 deferred
# 显示接口FCM2/4/0:15的概要信息。
<Sysname> display interface fcm 2/4/0:15 brief
Fcm2/4/0:15         DOWN    DOWN       --
# 显示当前物理状态为down的FCM接口的信息以及down的原因。
<Sysname> display interface fcm brief down
Fcm2/4/0:15        ADM     Administratively
表1-7 display interface fcm命令显示信息描述表
Fcm2/4/0:15
Current state
接口当前的物理状态,可能的取值及含义如下:
·     UP:该接口的物理状态为开启
·     DOWN(Administratively):表示该接口已经通过shutdown命令被关闭,需要通过undo shutdown命令开启
Line protocol state
·     UP:表示数据链路层协议状态为开启
接口的描述信息
Bandwidth
接口的期望带宽
接口的最大传输单元
Hold timer
retry times
网络层协议处理状况
Current system time
当前系统时间
接口最近一次物理状态up的时间
接口最近一次物理状态down的时间
Input:
  0 packets, 0 bytes
接口收到的总报文数和总字节数:
·     CRC:接收长度正常但CRC校验错误的报文数目
·     align errors:排列错误
·     frame errors:帧错误
·     aborts:接收报文的异常错误
Output:
  0 packets, 0 bytes
  0 deferred
接口发送的报文数和总字节数
三层接口的概要信息
接口名称缩写
Link
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
Protocol
接口数据链路层协议状态,取值可能为:
·     UP:表示接口的数据链路层是连通的
·     DOWN:表示接口的数据链路层不通
Primary IP
接口主IP地址
Cause
1.4.2  interface fcm
interface fcm命令用来进入FCM接口视图。
interface fcm { interface-number | interface-number:15 }
interface-number:物理FCM接口的编号。
interface-number:15:由CE1/PRI接口生成的FCM接口的编号,其中interface-number是CE1/PRI接口的编号。
# 进入FCM2/4/0接口视图。
[Sysname] interface fcm 2/4/0
[Sysname-Fcm2/4/0]
# 进入FCM2/4/0:15接口视图。
[Sysname] interface fcm 2/4/0:15
[Sysname-Fcm2/4/0:15]
1.4.3  mtu
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
FCM接口的MTU值为1500字节。
FCM接口视图
# 设置接口FCM2/4/0:15的MTU值为1430字节。
[Sysname-Fcm2/4/0:15] mtu 1430
1.4.4  pcm
pcm命令用来设置FCM接口的PCM对数压扩律。
undo pcm命令用来恢复缺省情况。
pcm { a-law | u-law }
undo pcm
FCM接口的PCM为a-law。
FCM接口视图
a-law:对数压扩律A律,中国、欧洲、非洲和南美等国家使用。
µ-law:对数压扩律µ律,美国使用。
为了减少噪声,提高信噪比,保证语音质量,实际应用中一般使用对数压扩律对信号进行非均匀量化。
根据CCITT规定,使用µ律压扩的国家负责将信号转换为A律。
# 设置接口FCM2/4/0:15脉冲编码调制的对数压扩率为μ律。
[Sysname] interface fcm2/4/0:15
[Sysname-Fcm2/4/0:15] pcm u-law
reset counters interface命令用来清除FCM接口的统计信息。
reset counters interface [ fcm [ interface-number ] ]
fcm:清除FCM接口的统计信息。
interface-number:FCM接口的编号。
·     如果不指定fcm和interface-number,则清除所有接口的统计信息;
·     如果指定fcm而不指定interface-number,则清除所有FCM接口的统计信息;
·     如果同时指定fcm和interface-number,则清除指定FCM接口的统计信息。
# 清除接口FCM2/4/0:15的统计信息。
<Sysname> reset counters interface fcm 2/4/0:15
·     display interface fcm
1.5  ISDN BRI接口配置命令
1.5.1  activate
activate命令用来激活BRI接口。
activate
BRI接口处于未激活状态。
ISDN BRI接口视图
BRI接口不存在呼叫时,ISDN BRI接口处于未激活状态,本命令用来手工激活BRI接口。
# 手工激活BRI接口2/4/0。
[Sysname] interface bri 2/4/0
[Sysname-Bri2/4/0] activate
display interface bri命令用来显示BRI接口的相关信息。
display interface [ bri [ interface-number ] ] [ brief [ description | down ] ]
interface-number:显示指定BRI接口的信息。
如果不指定bri参数,将显示设备支持的所有接口的相关信息;
如果指定bri参数,不指定interface-number参数,将显示所有已创建的BRI接口的相关信息。
# 显示BRI接口2/4/0的详细信息。
<Sysname> display interface bri 2/4/0
Bri2/4/0
Current state: DOWN ( Administratively )
Line protocol state: UP (spoofing)
Description: Bri2/4/0 Interface
Bandwidth: 128kbps
Baudrate: 128000 bps
Timeslot(s) Used: 1, 2
LCP: initial
Last 5 seconds input rate: 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
Last 5 seconds output rate: 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
Input:
  0 packets, 0 bytes
  0 errors, 0 runts, 0 giants,
  0 crc, 0 align errors, 0 overruns,
  0 frame errors
Output:
  0 packets, 0 bytes
  0 deferred
# 显示BRI接口2/4/0的概要信息。
<Sysname> display interface bri 2/4/0 brief
Bri2/4/0             ADM  UP(s)    --
# 显示当前物理状态为down的BRI接口的信息以及down的原因。
<Sysname> display interface bri brief down
Bri2/4/0               ADM  Administratively
表1-8 display interface bri命令显示信息描述表
Bri2/4/0
Current state
Line protocol state
·     UP:表示数据链路层协议状态为开启
接口的描述信息
Bandwidth
接口的期望带宽
接口的最大传输单元
Hold timer
retry times
Baudrate
接口的波特率
Timeslot(s) Used
使用的时隙
网络层协议处理状况
链路层封装的协议
LCP: initial
LCP(链路控制协议)初始化完成
Last link flapping
Current system time
当前系统时间
接口最近一次物理状态改变为up的时间
接口最近一次物理状态改变为down的时间
最近5秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的报文数
最近5秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的报文数
Input:
  0 packets, 0 bytes
  0 frame errors
接口收到的总报文数和总字节数:
·     align errors:排列错误
·     aborts:接收报文的异常错误
·     frame errors:帧错误
Output:
  0 packets, 0 bytes
  0 deferred
接口发送的报文数和总字节数
三层接口的概要信息
接口名称缩写
Link
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     Stby:表示该接口是一个备份接口
Protocol
接口数据链路层协议状态,取值可能为:
·     UP:表示接口的数据链路层是连通的
·     DOWN:表示接口的数据链路层不通
Primary IP
接口主IP地址
Cause
1.5.3  interface bri
interface bri命令用来进入BRI接口视图。
interface bri interface-number
interface-number:BRI接口的编号。
# 进入BRI接口2/4/0的视图。
[Sysname-Bri2/4/0]
1.5.4  loopback
loopback命令用来配置BRI接口的对外自环模式。
undo loopback命令用来恢复缺省情况。
loopback { b1 | b2 | both | remote }
undo loopback
ISDN BRI接口不对外自环。
ISDN BRI接口视图
b1:B1通道对外自环。
b2:B2通道对外自环。
both:B1和B2通道同时对外自环。
remote:B1、B2和D通道同时对外自环。
所谓自环,是指将从线路来的数据返回线路。ISDN BRI接口支持B1、B2通道对外自环、B1和B2通道同时对外自环以及B1、B2和D通道同时对外自环。
# 配置BRI接口的B1和B2通道同时对外自环。
[Sysname-Bri2/4/0] loopback both
1.5.5  mtu
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
BRI接口的MTU值为1500字节。
ISDN BRI接口视图
# 配置BRI接口的MTU值为1430字节。
[Sysname-Bri2/4/0] mtu 1430
reset counters interface命令用来清除BRI接口的统计信息。
reset counters interface [ bri [ interface-number ] ]
bri:清除BRI接口的统计信息。
·     如果不指定bri和interface-number,则清除所有接口的统计信息;
·     如果指定bri而不指定interface-number,则清除所有BRI接口的统计信息;
·     如果同时指定bri和interface-number,则清除指定BRI接口的统计信息。
# 清除BRI接口的统计信息。
<Sysname> reset counters interface bri 2/4/0
·     display interface bri
1.6  CE1/PRI接口基本配置命令
1.6.1  alarm-detect
alarm-detect命令用来配置检测远端告警信号。
undo alarm-detect命令用来取消检测远端告警信号。
alarm-detect rai
undo alarm-detect rai
检测远端告警信号。
CE1/PRI接口视图
rai:Remote Alarm Indication,即远端告警指示信号。
在CE1方式的情况下,可以使用该命令。
# 配置CE1/PRI接口E1 2/3/0检测远端告警信号。
[Sysname] controller e1 2/3/0
[Sysname-E1 2/3/0] alarm-detect rai
cable命令用来配置CE1/PRI接口匹配的传输线路类型。
undo cable命令用来恢复缺省情况。
cable { long | short }
undo cable
CE1/PRI接口匹配的传输线路类型为long。
CE1/PRI接口视图
long:表示接收器的衰减为-43db。
short:表示接收器的衰减为-10db。
# 配置CE1/PRI接口E1 2/3/0匹配的传输线路类型为short。
[Sysname-E1 2/3/0] cable short
1.6.3  cable-type
提示
只有E1T1接口切换为E1模式时支持本命令。
cable-type命令用来配置CE1/PRI接口的电缆阻抗类型。
undo cable-type命令用来恢复缺省情况。
cable-type { 75 | 120 }
undo cable-type
CE1/PRI接口的电缆阻抗类型为75欧。
CE1/PRI接口视图
75:表示设置电缆阻抗类型为75欧。
120:表示设置电缆阻抗类型为120欧。
# 配置CE1/PRI接口E1 2/3/0的电缆阻抗类型为120欧。
[Sysname-E1 2/3/0] cable-type 120
channel-set命令用来将CE1/PRI接口的时隙捆绑为通道组(channel set)。
undo channel-set命令用来取消已有的通道组。
channel-set set-number timeslot-list list
undo channel-set [ set-number ]
接口上不存在通道组。
CE1/PRI接口视图
set-number:该接口上时隙捆绑形成的channel set编号,取值范围为0~30。
timeslot-list list:被捆绑的时隙。list为时隙编号,取值范围为1~31。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
CE1/PRI接口使用CE1/PRI工作方式时,它在物理上分为32个时隙,对应编号为0~31。
使用时,可以将除0时隙外的全部时隙分成若干通道组(channel set),每组时隙捆绑以后,将自动创建一个Serial接口,其逻辑特性与同步串口相同。
Serial接口的名称是serial interface-number:set-number。其中interface-number是CE1/PRI接口的编号,set-number是channel set的编号。
# 将CE1/PRI接口E1 2/3/0的1、2、5、10-15和18时隙捆绑为0号channel-set。
[Sysname-E1 2/3/0] channel-set 0 timeslot-list 1,2,5,10-15,18
·     pri-set
clock命令用来配置CE1/PRI接口的时钟模式。
clock { master | slave }
undo clock
CE1/PRI接口的时钟模式为从时钟模式(slave)。
CE1/PRI接口视图
master:主时钟模式,使用内部时钟信号。
slave:从时钟模式,使用线路提供的时钟信号。
当CE1/PRI接口作为DCE侧使用时,应使用主时钟模式;作为DTE侧使用时,应使用从时钟模式。
# 设置CE1/PRI接口E1 2/3/0使用主时钟模式。
[Sysname-E1 2/3/0] clock master
clock-change auto命令用来开启接口的时钟自动切换功能。即接口在slave模式下收到AIS/LOS/LOF告警后,自动切换成master模式。当告警消除后,接口自动切换成用户配置的时钟模式。
undo clock-change auto命令用来关闭接口的时钟自动切换功能,接口恢复成当前用户配置的时钟模式。
clock-change auto
时钟自动切换功能处于关闭状态。
CE1/PRI接口视图
# 开启CE1/PRI接口E1 2/3/0的时钟自动切换功能。
[Sysname-E1 2/3/0] clock-change auto
·     clock
code命令用来配置CE1/PRI接口的线路编解码格式。
code { ami | hdb3 }
undo code
CE1/PRI接口的线路编解码格式为hdb3。
CE1/PRI接口视图
ami:采用AMI(Alternate Mark Inversion,信号交替反转码)线路编码格式。
hdb3:采用HDB3(High Density Bipolar 3,3阶高密度双极性码)线路编码格式。
配置接口的线路编解码格式时,请注意与对端设备保持一致。
线路编码采用ami方式时,在该接口上需要同时配置data-coding inverted,才能保证接口正常工作。
# 配置CE1/PRI接口E1 2/3/0的线路编解码格式为ami。
[Sysname-E1 2/3/0] code ami
·     data-coding
1.6.8  controller e1
controller e1命令用来进入CE1/PRI接口视图。
controller e1 interface-number
interface-number:CE1/PRI接口的编号。
# 进入CE1/PRI接口E1 2/3/0的视图。
[Sysname-E1 2/3/0]
data-coding命令用来设置CE1/PRI接口是否对用户数据进行翻转。
undo data-coding命令用来恢复缺省情况。
data-coding { inverted | normal }
undo data-coding
CE1/PRI接口不对用户数据进行翻转。
CE1/PRI接口视图
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当E1接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现过多连0的缺陷。
需要注意的是,只有通信的E1线路两端的CE1/PRI接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置CE1/PRI接口E1 2/3/0对用户数据进行翻转。
[Sysname-E1 2/3/0] data-coding inverted
1.6.10  detect-ais
detect-ais命令用来配置当前接口进行AIS检测。
undo detect-ais命令用来取消AIS检测。
detect-ais
undo detect-ais
进行AIS检测。
CE1/PRI接口视图
CE1/PRI接口工作在E1方式时,可以使用该命令。
# 设置CE1/PRI接口E1 2/3/0进行AIS检测。
[Sysname-E1 2/3/0] detect-ais
display controller e1命令用来显示CE1/PRI接口的相关信息。
display controller e1 [ interface-number ]
interface-number:CE1/PRI接口的编号。不指定本参数,将显示所有CE1/PRI接口的相关信息。
# 显示CE1/PRI接口E1 2/2/2/1的相关信息。
<Sysname> display controller e1 2/2/2/1
E1 2/2/2/1
Current state: UP
Description: E1 2/2/2/1 Interface
Current system time:2017-11-11 15:51:05
Last time when physical state changed to up:2017-11-11 15:51:00
Last time when physical state changed to down:2017-11-11 15:50:51
Basic Configuration:
  Work mode: E1 framed, Cable type: 75 Ohm unbalanced
  Frame-format: no-crc4, Line code: hdb3, Source clock: slave
  Idle code: 7e, Itf type: 7e, Itf number: 4, Loop back: not set
Alarm State:
  Receiver alarm state is None.
Historical Statistics:
Data in current interval (3398 seconds elapsed):
  Loss Frame Alignment: 0 seconds, Framing Error: 1 seconds
  CRC Error: 0 seconds, Alarm Indication: 0 seconds
  Loss-of-signals: 1 seconds, Code Violations: 1 seconds
  Slip: 0 seconds, E-Bit error: 0 seconds
表1-9 display controller e1命令显示信息描述表
E1 2/3/0
Current state
E1接口当前的状态
E1接口的描述信息
清零记录
Current system time
当前系统时间
接口最近一次物理状态up的时间
接口最近一次物理状态down的时间
Basic Configuration
E1接口基本配置
Work mode
E1接口的工作模式(E1/CE1)
Cable type
E1接口的线缆类型
Frame-format
E1接口的帧格式
Line Code
线路码(Ami/hdb3)
Source Clock
接口的源时钟(master/slave)
Idle Code
空闲码(7e/ff)
Itf type
帧间填充码(7e/ff)
Itf number
帧间填充码的个数
Loopback
接口是否设置了环回
Alarm State
告警状态
历史统计数据
当前时间间隔内的各种错误发生持续的时间统计,错误包括:帧没对齐,帧错误,警告,丢信号,违规码时间,滑帧
·     reset counters controller e1
frame-format命令用来设置CE1接口的帧格式。
undo frame-format命令用来恢复缺省情况。
frame-format { crc4 | no-crc4 }
undo frame-format
CE1接口的帧格式为no-crc4。
CE1/PRI接口视图
crc4:设置CE1接口的帧格式为CRC4帧格式。
no-crc4:设置CE1接口的帧格式为非CRC4帧格式。
当CE1/PRI接口工作在CE1方式下时,支持crc4和no-crc4两种帧格式。其中crc4帧格式支持对物理帧进行4比特的循环冗余校验,而no-crc4帧格式则不支持对物理帧进行4比特的循环冗余校验。
# 设置接口E1 2/3/0的帧格式为crc4。
[Sysname-E1 2/3/0] frame-format crc4
idle-code命令用来设置CE1/PRI接口的线路空闲码类型。
undo idle-code
CE1/PRI接口的线路空闲码类型为0x7e。
CE1/PRI接口视图
7e:线路空闲码为0x7e类型。
ff:线路空闲码为0xff类型。
CE1/PRI接口的线路空闲码类型是指在未被绑定到逻辑通道的时隙上发送的码型。
CE1/PRI接口的线路空闲码类型有两种:0x7e和0xff。
# 设置CE1/PRI接口E1 2/3/0的线路空闲码类型为0x7e。
[Sysname-E1 2/3/0] idle-code 7e
itf命令用来设置CE1/PRI接口的帧间填充符类型和个数。
undo itf命令用来恢复缺省情况。
itf { number number | type { 7e | ff } }
undo itf { number | type }
CE1/PRI接口的帧间填充符类型为0x7e,帧间填充字节个数为4个。
CE1/PRI接口视图
type:设置帧间填充符类型。
7e:表示帧间填充符为0x7e格式。
ff:表示帧间填充符为0xff格式。
CE1/PRI接口的帧间填充符是指已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。
CE1/PRI接口的帧间填充符类型有两种:0x7e和0xff。
当CE1/PRI接口工作在E1方式,且帧间填充符配置为0xff格式时,在没有业务数据时,线路上会发送全“1”的数据,容易产生AIS告警。在此情况下,建议用户通过undo detect-ais命令取消AIS检测,以免系统产生AIS告警。
# 设置CE1/PRI接口E1 2/3/0的帧间填充符类型为0xff。
[Sysname-E1 2/3/0] itf type ff
# 设置CE1/PRI接口E1 2/3/0的帧间填充字节个数为5。
[Sysname-E1 2/3/0] itf number 5
loopback命令用来开启CE1/PR接口的环回检测功能并设置检测方式。
loopback { local | payload | remote }
undo loopback
环回检测功能处于关闭状态。
CE1/PRI接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
自环、环回功能主要用于检测接口或电缆本身的状况,正常工作时应关闭这些功能。
对于将CE1/PRI接口时隙经捆绑而形成的串口,如果串口的链路层协议配置为PPP,在设置自环后,其链路层协议状态将上报为down,这属于正常情况。
# 设置CE1/PRI接口E1 2/3/0对内自环。
[Sysname-E1 2/3/0] loopback local
pri-set命令用来将CE1/PRI接口的时隙捆绑为pri set。
undo pri-set命令用来取消已有的捆绑。
pri-set [ timeslot-list list ]
undo pri-set
未捆绑任何pri set。
CE1/PRI接口视图
在进行pri set捆绑时,CE1/PRI接口上的16时隙将被作为D信道使用,因此,这个时隙不能被单独捆绑。如果捆绑的时隙只有一个16时隙,捆绑将会失败。
将CE1/PRI接口时隙捆绑为pri set时,0时隙被用作传输同步信息,16时隙被用作D通道传输信令,其余时隙被用作B通道传输数据。捆绑时可以将除0时隙之外的时隙捆绑为一个pri set(16时隙作为D信道会被自动捆绑)。在捆绑为pri set时,如果不指定捆绑的时隙,则为捆绑除0时隙外的其它所有时隙。
在同一个CE1/PRI接口上,pri set不能和其它方式同时使用。
# 将CE1/PRI接口E1 2/3/0的1、2、8~12时隙捆绑为pri set。
[Sysname-E1 2/3/0] pri-set timeslot-list 1,2,8-12
·     channel-set
reset counters controller e1命令用来清除CE1/PRI接口的统计信息。
reset counters controller e1 [ interface-number ]
interface-number:CE1/PRI接口的编号。不指定本参数,将清除所有CE1/PRI接口的统计信息。
单独清除CE1/PRI接口的统计信息只能使用reset counters controller e1命令,不能使用reset counters interface命令。
CE1/PRI接口的统计信息可以用display controller e1命令来查看。
# 清除CE1/PRI接口E1 2/3/0的统计信息。
<Sysname> reset counters controller e1 2/3/0
·     display controller e1
using命令用来设置CE1/PRI接口的工作方式。
undo using命令用来恢复缺省情况。
using { ce1 | e1 }
undo using
CE1/PRI接口的工作方式为CE1/PRI工作方式。
CE1/PRI接口视图
ce1:接口工作在CE1/PRI工作方式。
e1:接口工作在E1工作方式。
CE1/PRI接口有两种工作方式:非通道化工作方式和通道化工作方式。非通道化工作方式也称为E1工作方式,通道化工作方式也称为CE1/PRI工作方式。
·     当CE1/PRI接口使用E1工作方式时,它相当于一个不分时隙、数据带宽为2.048Mbps的接口,其逻辑特性与同步串口相同,接口名是serial interface-number:0。其中interface-number是CE1/PRI接口的编号。
·     当CE1/PRI接口使用CE1/PRI工作方式时,它在物理上分为32个时隙,对应编号为0~31,其中0时隙用于传输同步信息。对该接口有两种使用方法:CE1方式和PRI方式。
# 设置CE1/PRI接口E1 2/3/0的工作在E1工作方式。
[Sysname-E1 2/3/0] using e1
1.6.19  work-mode
work-mode命令用来配置CE1/PRI接口的同步或异步模式。
undo work-mode命令用来恢复缺省情况。
work-mode { async | sync }
undo work-mode
CE1/PRI接口工作在同步模式。
CE1/PRI接口视图
async:配置CE1/PRI接口工作在异步模式。
sync:配置CE1/PRI接口工作在同步模式。
CE1/PRI接口支持同步和异步两种工作模式,同步和异步是根据POS机的拨号方式来区分的(POS机通过设置拨号方式来进行刷卡和升级业务):
·     当POS机工作在同步拨号方式时,CE1/PRI接口应配置为工作在同步模式,这样,POS机会选择DHMIM-1E1POS1DM单板上的E1POS扣卡(即通过CE1/PRI接口生成的Serial接口和FCM接口)进行刷卡交易业务。
·     当POS机工作在异步拨号方式时,CE1/PRI接口应配置为工作在异步模式,这样,POS机会选择DHMIM-1E1POS1DM单板上的DM扣卡(即通过CE1/PRI接口生成的Serial接口和AM接口)进行POS机升级业务。
需要注意的是,只有DHMIM-1E1POS1DM单板上的CE1/PRI接口(该CE1/PRI接口的物理类型为PHY_E1POSDM)支持本命令。
# 配置CE1/PRI接口E1 2/3/0工作在异步模式。
[Sysname-E1 2/3/0] work-mode async
·     pri-set
1.7  CT1/PRI接口基本配置命令
1.7.1  alarm-detect
alarm-detect rai
检测远端告警信号。
CT1/PRI接口视图
在接口帧格式采用esf的情况下,可以使用该命令。
# 配置CT1/PRI接口T1 2/4/0检测远端告警信号。
[Sysname] controller t1 2/4/0
[Sysname-T1 2/4/0] alarm-detect rai
alarm-threshold命令用来配置CT1/PRI接口的告警门限值。
undo alarm-threshold命令用来恢复缺省情况。
alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
对于AIS告警,缺省值为level-1。
对于LFA告警,缺省值为level-1。
对于LOS告警,pulse-detection参数的值为176,pulse-recovery的值为22,即如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失,LOS告警产生。
CT1/PRI接口视图
ais:AIS(Alarm Indication Signal,告警指示信号)告警的门限值。AIS告警有两个门限值,分别为level-1和level-2。level-1的门限为在一个SF/ESF帧内,比特流中的0的个数小等于2,则AIS告警产生;level-2的门限在SF格式时为,一个SF帧内码流的0个数小等于3;在ESF格式时为一个ESF帧内码流的0个数小等于5。
lfa:LFA(Loss of Frame Alignment,帧失步)告警的门限值。LFA告警有四个门限值可以配置,分别为level-1、level-2、level-3和level-4。level-1为4个帧同步比特中丢失了2个;level-2为5个帧同步比特中丢失了2个;leve-3为6个帧同步比特中丢失了2个;level-4仅仅对ESF格式有效,在连续4个ESF帧中出现错误时产生LFA告警。
los:LOS(Loss Of Signal,信号丢失)告警的门限值。LOS告警有两个门限值,分别为pulse-detection和pulse-recovery,pulse-detection配置LOS的检测时长门限,取值范围为16~4096,这个时长门限的单位为“脉冲周期”;pulse-recovery配置LOS的脉冲门限,取值范围为1~256,就是在检测时长内(即pulse-detection配置的若干个脉冲周期内),检测到的脉冲个数如果小于pulse-recovery所配置的值,则LOS告警产生。
# 将LOS告警的检测时长配置为300个脉冲周期。
[Sysname-T1 2/4/0] alarm-threshold los pulse-detection 300
bert命令用来进行线路位(Bit)错误率的测试。
undo bert命令用来取消进行线路位(Bit)错误率的测试。
bert pattern { 2^20 | 2^15 } time minutes [ unframed ]
undo bert
不进行线路位错误率的测试。
CT1/PRI接口视图
pattern:设置BERT测试模式,包括2^15(测试码流长度为2的15次方个bit)和2^20(测试码流长度为2的20次方个bit)。
time minutes:设置BERT测试时间,取值范围为1~1440,单位为分钟。
unframed:设置测试数据流覆盖帧的开销位。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前CT1/PRI接口支持2^20和2^15两种测试模式。
BERT测试方式为,本端发出测试数据流,经过线路某处环回来,检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对方设置远端环回等。利用bert命令配置好测试模式,指定测试时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。
BERT测试状态和测试结果详见CT1接口显示部分。
# 执行2^20格式的BERT测试10分钟。
[Sysname-T1 2/4/0] bert pattern 2^20 time 10
cable命令用来配置CT1/PRI接口匹配的传输线路类型。
cable { long { 0db | -7.5db | -15db | -22.5db } | short { 133ft | 266ft | 399ft | 533ft | 655ft } }
undo cable
CT1/PRI接口匹配的传输线路类型为long 0db。
CT1/PRI接口视图
long:匹配655英尺以上的传输线路,可选参数有0db、-7.5db、-15db、-22.5db,可根据接收端信号质量选择不同的衰减参数,当线路质量越差时,信号衰减越大,需要用户对这种衰减进行相应补偿,此时,不需要外接CSU。
short:匹配655英尺以下的传输线路,可选参数有133ft、266ft、399ft、533ft、655ft,可根据传输线路的长度,选择相应的长度参数。
本命令主要作用是配置发送时的信号波形,以适应不同传输需要。实际使用中,可根据接收端收到的信号质量的好坏,来决定是否使用此命令。如果信号质量较好,可以使用缺省设置。使用缺省配置时,CT1/PRI接口不需外接CSU设备。
# 配置CT1/PRI接口T1 2/4/0匹配的传输线路类型为133英尺。
[Sysname-T1 2/4/0] cable short 133ft
channel-set命令用来将CT1/PRI接口的时隙捆绑为通道组(channel set)。
channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
接口上不存在通道组。
CT1/PRI接口视图
set-number:该接口上时隙捆绑形成的channel set编号,取值范围为0~23。
timeslot-list list:被捆绑的时隙。list为时隙编号,取值范围为1~24。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
speed { 56k | 64k }:时隙捆绑速率,单位为kbps。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。系统默认为64K。
CT1/PRI接口在物理上分为24个时隙,对应编号为1~24。使用时,可以将全部时隙分成若干通道组(channel set),每组时隙捆绑以后,系统将自动创建一个Serial接口,其逻辑特性与同步串口相同。
Serial接口的名称是serial interface-number:set-number。其中interface-number是CT1/PRI接口的编号,set-number是channel set的编号。
# 将CT1/PRI接口T1 2/4/0的1、2、5、10-15和18时隙捆绑为0号channel-set。
[Sysname-T1 2/4/0] channel-set 0 timeslot-list 1,2,5,10-15,18
·     pri-set
clock命令用来配置CT1/PRI接口的时钟模式。
undo clock
CT1/PRI接口的时钟模式为从时钟模式(slave)。
CT1/PRI接口视图
当CT1/PRI接口作为DCE侧使用时,应使用主时钟模式;作为DTE侧使用时,应使用从时钟模式。
当两台路由器的CT1/PRI接口直接相连时,必须使两端分别工作在从时钟模式和主时钟模式。当路由器的CT1/PRI接口与交换机连接时,交换机是DCE侧,负责提供时钟;而路由器的接口需工作在从时钟模式。
# 设置CT1/PRI接口T1 2/4/0使用主时钟模式。
[Sysname-T1 2/4/0] clock master
code命令用来配置CT1/PRI接口的线路编解码格式。
code { ami | b8zs }
undo code
CT1/PRI接口的线路编解码格式为b8zs。
CT1/PRI接口视图
b8zs:采用B8ZS(Bipolar 8-zero substitution,双极性8zero替换码)线路编码格式。
# 配置CT1/PRI接口T1 2/4/0的线路编解码格式为ami。
[Sysname-T1 2/4/0] code ami
·     data-coding
1.7.8  controller t1
controller t1命令用来进入CT1/PRI接口视图。
controller t1 interface-number
interface-number:CT1/PRI接口的编号。
# 进入CT1/PRI接口T1 2/4/0的视图。
[Sysname-T1 2/4/0]
data-coding命令用来设置CT1/PRI接口是否对用户数据进行翻转。
undo data-coding
CT1/PRI接口不对用户数据进行翻转。
CT1/PRI接口视图
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当T1接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现过多连0的缺陷。
需要注意的是,只有通信的T1线路两端的CT1/PRI接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置CT1/PRI接口T1 2/4/0对用户数据进行翻转。
[Sysname-T1 2/4/0] data-coding inverted
display controller t1命令用来显示CT1/PRI接口的相关信息。
display controller t1 [ interface-number ]
interface-number:CT1/PRI接口的编号。不指定本参数,将显示所有CT1/PRI接口的相关信息。
# 显示CT1/PRI接口T1 2/4/0的相关信息。
<Sysname> display controller t1 2/4/0
T1 2/4/0
Current state: UP
Description: T1 2/2/2/1 Interface
Current system time:2017-11-11 16:11:54
Last time when physical state changed to up:2017-11-11 16:04:52
Last time when physical state changed to down:2017-11-11 16:04:49
  Work mode: T1 framed, Cable type: 100 Ohm balanced
  Frame-format: esf, fdl: none, Line code: b8zs
  Source clock: slave, Data-coding: normal
  Idle code: ff, Itf type: ff, Itf number: 2
  Loop back: not set
Alarm State:
  Receiver alarm state is Loss-of-Signal
  Transmitter is sending remote alarm
  Pulse density violation detected
SendLoopCode History:
  Inband-llb-up: 0 times, Inband-llb-down: 0 times
  Fdl-ansi-llb-up: 0 times, Fdl-ansi-llb-down: 0 times
  Fdl-ansi-plb-up: 0 times, Fdl-ansi-plb-down: 0 times
  Fdl-att-plb-up: 0 times, Fdl-att-plb-down: 0 times
BERT state:(stopped, not completed)
  Test pattern: 2^15, Status: Not Sync, Sync Detected: 0
    Time: 0 minutes, Time past: 0 minutes
    Bit Errors (since test started): 0 bits
    Bits Received (since test started): 0 Kbits
    Bit Errors (since latest sync): 0 bits
    Bits Received (since latest sync): 0 Kbits
  Data in current interval (285 seconds elapsed):
    Line Code Violations: 0, Path Code Violations: 0
    Ais Alarm: 0 seconds, Los Alarm: 286 seconds
    Slip: 7 seconds, Fr Loss: 286 seconds
    Line Err: 0 seconds, Degraded: 0 minutes
    Errored: 0 seconds, Bursty Err: 0 seconds
    Severely Err: 0 seconds, Unavail: 286 seconds
  Data in Interval 1:
    Ais Alarm: 0 seconds, Los Alarm Secs: 901 seconds
    Slip: 22 seconds, Fr Loss: 901 seconds
    Severely Err: 0 seconds, Unavail: 901 seconds
  Data in Interval 2:
    Ais Alarm: 0 seconds, Los Alarm: 900 seconds
    Slip: 23 seconds, Fr Loss: 900 seconds
    Severely Err: 0 seconds, Unavail: 900 seconds
  Total Data (last 2 15 minute intervals):
    Ais Alarm: 0 seconds, Los Alarm: 2087 seconds
    Slip: 52 seconds, Fr Loss: 2087 seconds
    Severely Err: 0 seconds, Unavail: 2087 seconds
表1-10 display controller t1命令显示信息描述表
T1 2/4/0
Current state
T1接口当前的状态
T1接口的描述信息
Current system time
当前系统时间
接口最近一次物理状态改变为up的时间
Basic Configuration
T1接口基本配置
Work mode
T1接口的工作模式(T1/CT1)
Cable type
T1接口的线缆类型
Frame-format
T1接口的帧格式(esf/sf)
fdl
FDL格式(ansi/att/none)
Line code
线路编码格式(b8zs/ami)
Source clock
接口的时钟源模式(master/slave)
Data-coding
包括正常和数据翻转两种模式(normal/inverted)
Idle code
空闲码(7e/ff)
Itf type
帧间填充码(7e/ff)
Itf number
帧间填充码的个数
Loop back
接口是否设置了环回(local/payload/remote/no set)
Alarm State
告警状态
收到的告警类型:none、LOS、LOF、RAI、AIS
发出的告警类型:RAI、none
脉冲密度不符合规范要求
向对端发送环回码的历史记录,包括每种码的发送次数和最近发送的是哪种码
BERT state
BERT测试状态:completed(自然完成)还是stopped(人为中止)还是running(正在测试)
Test pattern
测试模式(2^20/2^15)
Status
是否处于同步状态
Sync Detected
测试以来检测到的同步次数
Time
预设的测试时间
Time past
已经过去的测试时间
测试以来收到的错误的比特数
测试以来收到的总比特数
最近的同步以来收到的错误的比特数
最近的同步以来收到的总比特数
当前时间间隔内的统计信息(15分钟为一个时间间隔)。这些数据是按照T1规范对物理层所作的各种信息统计,如AIS告警、RAI告警、LOS信号、LFA等。详细解释参见T1规范ANSI T1.403和AT&T TR 54016
  Data in Interval 1:
第1间隔内的统计信息
统计内容同上
  Data in Interval 2:
第2间隔内的统计信息
统计内容同上
所有间隔内的统计信息
统计内容同上
·     reset counters controller t1
1.7.11  fdl
fdl命令用来配置CT1/PRI接口在ESF格式时FDL比特位的使用模式。
undo fdl命令用来恢复缺省情况。
fdl { ansi | att | both | none }
undo fdl
禁止FDL(none)。
CT1/PRI接口视图
ansi:使能FDL,遵循ANSI T1.403规范。
att:使能FDL,遵循AT&T TR 54016规范。
both:使能FDL,同时遵循ANSI T1.403规范和AT&T TR 54016规范。
none:禁止FDL。
FDL(Facility Data Link,设备数据链路)是T1的ESF帧格式中4kbps的一个带宽,CT1/PRI接口在配置为ESF(Extended Super Frame,扩展超帧)格式时,其中的FDL位可用来传递报警信息、性能信息及环回码等,相关的规范包括ANSI T1.403和ATT TR 54016。在实际应用中,经常需要对FDL的使用及规范进行各种配置,包括:禁止FDL、使能并遵循ANSI规范、使能并遵循AT&T规范或者使能并遵循这两种规范。
实际应用中,可以根据对方FDL的模式调整本端FDL的模式。
# 设置CT1/PRI接口T1 2/4/0 FDL使能并遵循AT&T规范。
[Sysname-T1 2/4/0] fdl att
frame-format命令用来设置CT1/PRI接口的帧格式。
frame-format { esf | sf }
undo frame-format
CT1/PRI接口的帧格式为esf。
CT1/PRI接口视图
esf:设置CT1/PRI接口的帧格式为ESF(Extended Super Frame,扩展超帧)格式。
sf:设置CT1/PRI接口的帧格式为SF(Super Frame,超帧)格式。
CT1/PRI接口支持超帧和扩展超帧两种帧格式。在超帧格式中,多个帧可以共享相同的帧同步信息和信令信息,从而有更多的有效位来传送用户数据。实际应用中,经常需要对系统进行测试,扩展超帧技术可以用来满足在测试时不影响正常业务运行的要求。
# 设置CT1/PRI接口T1 2/4/0的帧格式为超帧格式。
[Sysname-T1 2/4/0] frame-format sf
idle-code命令用来设置CT1/PRI接口的线路空闲码类型。
undo idle-code
CT1/PRI接口的线路空闲码类型为0x7e。
CT1/PRI接口视图
7e:线路空闲码为0x7e类型。
ff:线路空闲码为0xff类型。
CT1/PRI接口的线路空闲码类型是指在未被绑定到逻辑通道的时隙上发送的码型。
CT1/PRI接口的线路空闲码类型有两种:0x7e和0xff。
# 设置CT1/PRI接口T1 2/4/0的线路空闲码类型为0x7e。
[Sysname-T1 2/4/0] idle-code 7e
itf命令用来设置CT1/PRI接口的帧间填充符类型和个数。
undo itf命令用来恢复缺省情况。
CT1/PRI接口的帧间填充符类型为0x7e,帧间填充字节个数为4个。
CT1/PRI接口视图
type:设置帧间填充符类型。
7e:表示帧间填充符为0x7e格式。
ff:表示帧间填充符为0xff格式。
CT1/PRI接口的帧间填充符是指已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。
CT1/PRI接口的帧间填充符类型有两种:0x7e和0xff。
# 设置CT1/PRI接口T1 2/4/0的帧间填充符类型为0xff。
[Sysname-T1 2/4/0] itf type ff
# 设置CT1/PRI接口T1 2/4/0的帧间填充字节个数为5。
[Sysname-T1 2/4/0] itf number 5
loopback命令用来开启CT1/PR接口的环回检测功能并设置检测方式。
undo loopback
环回检测功能处于关闭状态。
CT1/PRI接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
自环环回功能主要用于检测接口或电缆本身的状况,正常工作时应关闭这些功能。
对于将CT1/PRI接口时隙经捆绑而形成的串口,如果串口的链路层协议配置为PPP,在设置自环后,其链路层协议状态将上报为down,这属于正常情况。
# 设置CT1/PRI接口T1 2/4/0对内自环。
[Sysname-T1 2/4/0] loopback local
pri-set命令用来将CT1/PRI接口的时隙捆绑为pri set。
undo pri-set
未捆绑任何pri set。
CT1/PRI接口视图
在进行pri set捆绑时,CT1/PRI接口上的24时隙将被作为D信道使用,因此,这个时隙不能被单独捆绑。如果捆绑的时隙只有一个24时隙,捆绑将会失败。
将CT1/PRI接口时隙捆绑为pri set时,24时隙被用作D通道传输信令,其余时隙被用作B通道传输数据。捆绑时可以将任意时隙捆绑为一个pri set(24时隙作为D信道会被自动捆绑),其逻辑特性与ISDN PRI接口相同。在捆绑为pri set时,如果不指定捆绑的时隙,则会将所有时隙捆绑起来,形成一个类似23B+D的ISDN PRI接口。
在同一个CT1/PRI接口上,pri set不能和其它方式同时使用。
# 将CT1/PRI接口T1 2/4/0的1、2、8~12时隙捆绑为pri set。
[Sysname-T1 2/4/0] pri-set timeslot-list 1,2,8-12
·     channel-set
reset counters controller t1命令用来清除CT1/PRI接口的统计信息。
reset counters controller t1 [ interface-number ]
interface-number:CT1/PRI接口的编号。不指定本参数,将清除所有CT1/PRI接口的统计信息。
单独清除CT1/PRI接口的统计信息只能使用reset counters controller t1命令,不能使用reset counters interface命令。
CT1/PRI接口的统计信息可以用display controller t1命令来查看。
# 清除CT1/PRI接口T1 2/4/0的统计信息。
<Sysname> reset counters controller t1 2/4/0
·     display controller t1
1.7.18  sendloopcode
sendloopcode命令用来配置发送远程环回控制码。
sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
不发送远程环回控制码。
CT1/PRI接口视图
fdl-ansi-llb-down:发送FDL承载的符合ANSI规范的线路环回去激活码,解除远端环回。
fdl-ansi-llb-up:发送FDL承载的符合ANSI规范的线路环回激活码,启动远端环回。
fdl-ansi-plb-down:发送FDL承载的符合ANSI规范的净荷环回去激活码,解除远端环回。
fdl-ansi-plb-up:发送FDL承载的符合ANSI规范的净荷环回激活码,启动远端环回。
fdl-att-plb-down:发送FDL承载的符合AT&T规范的净荷环回去激活码,解除远端环回。
fdl-att-plb-up:发送FDL承载的符合AT&T规范的净荷环回激活码,启动远端环回。
inband-llb-down:发送符合ANSI规范和AT&T规范的带内线路环回去激活码,解除远端环回。
inband-llb-up:发送符合ANSI规范和AT&T规范的带内线路环回激活码,启动远端环回。
CT1/PRI接口下可以通过发送环回控制码对远端的CT1/PRI接口进行环回的自动配置。LLB(Line loopback,线路环回)这种方式下,一个T1的PCM帧的全部193位(包括1位同步位及192位有效净荷)都被环回;PLB(Payload loopback,净荷环回)这种方式下,仅192位有效净荷被环回。环回码的格式规范包括ANSI T1.403和AT&T TR 54016。SF格式下的LLB环回码占用有效带宽;ESF格式下对LLB和PLB的环回码均使用ESF帧的FDL比特位收发。
这条命令需要和远端T1设备配合使用,当对方能检测符合上述格式的各种环回码时,对方能够根据检测到的环回码类型设置相应的环回模式。持续发送5秒钟,不影响其它接口的正常工作。
配置该命令时要求远端的CT1/PRI接口能自动检测到来自网上的环回控制码。
# 发送带内线路环回激活码。
[Sysname-T1 2/4/0] sendloopcode inband-llb-up
1.8  E1-F接口配置命令
clock-change auto
时钟自动切换功能处于关闭状态。
E1-F接口视图
# 打开E1-F接口Serial2/1/0时钟自动切换功能。
[Sysname-Serial2/1/0] clock-change auto
·     fe1 clock
1.8.2  crc
crc命令用来配置E1-F接口的CRC校验模式。
undo crc命令用来恢复缺省情况。
undo crc
使用16位CRC校验。
E1-F接口视图
16:E1-F接口使用16位CRC校验。
32:E1-F接口使用32位CRC校验。
none:E1-F接口不进行CRC校验。
# 配置E1-F接口Serial2/1/0使用32位CRC校验。
1.8.3  display fe1
display fe1命令用来显示E1-F接口的相关信息。
display fe1 [ serial interface-number ]
serial interface-number:显示指定E1-F接口的信息。interface-number为串口编号。如果不指定接口,则显示所有的E1-F接口的信息。
若指定的接口不是E1-F接口而是一个普通串口,则系统会提示该串口不是E1-F接口。
# 显示E1-F接口Serial2/1/0的相关信息。
<Sysname> display fe1 serial 2/1/0
Serial2/1/0
    Frame format: no-crc4
    Loopback: not set
  Alarm State:
    Transmitter is sending remote alarm.
    Data in current interval (19349 seconds elapsed):
      Loss Frame Alignment: 129 seconds, Framing Error: 0 seconds
      Loss-of-signals: 129 seconds, Code Violations: 0 seconds
      Slip: 0 seconds, E-Bit Error: 0 seconds
表1-11 display fe1命令显示信息描述表
Basic Configuration
接口基本配置
Work mode
接口的工作模式
Cable type
接口的线缆类型(75欧非平衡/120欧平衡)
Frame format
帧格式(crc4/no-crc4)
Line Code
线路编码格式(ami/hdb3)
Source Clock
Idle code
空闲码(7e/ff)
Itf type
帧间填充码(7e/ff)
Itf number
帧间填充码的个数
Loopback
接口是否设置了环回
Alarm State
告警状态
历史统计信息
fe1 alarm-detect命令用来配置检测远端告警信号。
undo fe1 alarm-detect命令用来取消检测远端告警信号。
fe1 alarm-detect rai
undo fe1 alarm-detect rai
检测远端告警信号。
E1-F接口视图
在成帧方式的情况下,可以使用该命令。
# 配置E1-F接口Serial2/1/0检测远端告警信号。
[Sysname-Serial2/1/0] fe1 alarm-detect rai
·     fe1 unframed
1.8.5  fe1 cable
fe1 cable命令用来设置接口支持的电缆类型。
undo fe1 cable命令用来恢复缺省情况。
fe1 cable { long | short }
undo fe1 cable
E1-F接口支持长电缆类型。
E1-F接口视图
long:表示设置支持长电缆类型。
short:表示设置支持短电缆类型。
# 设置E1-F接口Serial2/1/0支持的电缆类型为short。
[Sysname-Serial2/1/0] fe1 cable short
提示
只有E1T1-F接口切换为E1-F模式时支持本命令。
fe1 cable-type命令用来配置接口的电缆阻抗类型。
undo fe1 cable-type命令用来恢复缺省情况。
fe1 cable-type { 75 | 120 }
undo fe1 cable-type
E1-F接口的电缆阻抗类型为75欧。
E1-F接口视图
75:表示设置电缆阻抗类型为75欧。
# 设置E1-F接口Serial2/1/0的电缆阻抗类型为120欧。
[Sysname-Serial2/1/0] fe1 cable-type 120
1.8.7  fe1 clock
fe1 clock命令用来设置E1-F接口的时钟模式。
undo fe1 clock命令用来恢复缺省情况。
fe1 clock { master | slave }
undo fe1 clock
E1-F接口视图
当E1-F接口作为DCE侧使用时,应使用主时钟模式;作为DTE侧使用时,应使用从时钟模式。
# 设置E1-F接口Serial2/1/0使用主时钟模式。
[Sysname-Serial2/1/0] fe1 clock master
·     clock-change auto
1.8.8  fe1 code
fe1 code命令用来设置E1-F接口的线路编解码格式。
undo fe1 code命令用来恢复缺省情况。
fe1 code { ami | hdb3 }
undo fe1 code
E1-F接口的线路编解码格式为hdb3。
E1-F接口视图
线路编码采用ami方式时,在该接口上需要同时配置fe1 data-coding inverted,才能保证接口正常工作。
# 设置E1-F接口Serial2/1/0的线路编解码格式为ami。
[Sysname-Serial2/1/0] fe1 code ami
·     fe1 data-coding
1.8.9  fe1 data-coding
fe1 data-coding命令用来设置E1-F接口是否对用户数据进行翻转。
undo fe1 data-coding命令用来恢复缺省情况。
fe1 data-coding { inverted | normal }
E1-F接口不对用户数据进行翻转。
E1-F接口视图
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当E1-F接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现的过多连0的缺陷。
需要注意的是,只有通信的E1-F线路两端的E1-F接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置E1-F接口Serial2/1/0对用户数据进行翻转。
[Sysname-Serial2/1/0] fe1 data-coding inverted
·     fe1 code
1.8.10  fe1 detect-ais
fe1 detect-ais命令用来配置当前接口进行AIS(Alarm Indication Signal,告警指示信号)检测。
undo fe1 detect-ais命令用来取消AIS检测。
fe1 detect-ais
undo fe1 detect-ais
进行AIS检测。
E1-F接口视图
在非成帧方式的情况下,可以使用该命令。
# 设置E1-F接口Serial2/1/0进行AIS检测。
[Sysname-Serial2/1/0] fe1 detect-ais
·     fe1 unframed
1.8.11  fe1 frame-format
fe1 frame-format命令用来设置E1-F接口的帧格式。
undo fe1 frame-format命令用来恢复缺省情况。
fe1 frame-format { crc4 | no-crc4 }
E1-F接口的帧格式为no-crc4。
E1-F接口视图
crc4:设置E1-F接口的帧格式为CRC4帧格式。
no-crc4:设置E1-F接口的帧格式为非CRC4帧格式。
E1-F接口工作在成帧方式下时,支持crc4和no-crc4两种帧格式。其中crc4帧格式支持对物理帧进行4比特的循环冗余校验,而no-crc4帧格式则不支持。
# 设置E1-F接口Serial2/1/0的帧格式为crc4。
[Sysname-Serial2/1/0] fe1 frame-format crc4
·     fe1 unframed
1.8.12  fe1 idle-code
fe1 idle-code命令用来设置E1-F接口的线路空闲码类型。
undo fe1 idle-code命令用来恢复缺省情况。
fe1 idle-code { 7e | ff }
undo fe1 idle-code
E1-F接口的线路空闲码类型为0x7e。
E1-F接口视图
7e:线路空闲码为0x7e类型。
ff:线路空闲码为0xff类型。
E1-F接口的线路空闲码类型是指在未被绑定到逻辑通道的时隙上发送的码型。
E1-F接口的线路空闲码类型有两种:0x7e和0xff。
# 设置E1-F接口Serial2/1/0的线路空闲码类型为0x7e。
[Sysname-Serial2/1/0] fe1 idle-code 7e
1.8.13  fe1 itf
fe1 itf命令用来设置E1-F接口的帧间填充符类型和个数。
undo fe1 itf命令用来恢复缺省情况。
fe1 itf { number number | type { 7e | ff } }
undo fe1 itf { number | type }
E1-F接口的帧间填充符类型为0x7e,帧间填充字节个数为4个。
E1-F接口视图
type:设置帧间填充符类型。
7e:表示帧间填充符为0x7e格式。
ff:表示帧间填充符为0xff格式。
E1-F接口的帧间填充符是指在已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。
E1-F接口的帧间填充符类型有两种:0x7e和0xff。
# 设置E1-F接口Serial2/1/0的帧间填充符类型为0xff。
[Sysname] interface serial 2/1/0
[Sysname-serial2/1/0] fe1 itf type ff
# 设置E1-F接口Serial2/1/0的帧间填充字节个数为5。
[Sysname-Serial2/1/0] fe1 itf number 5
1.8.14  fe1 loopback
fe1 loopback命令用来开启E1-F接口的环回检测功能并设置检测方式。
undo fe1 loopback命令用来恢复缺省情况。
fe1 loopback { local | payload | remote }
undo fe1 loopback
环回检测功能处于关闭状态。
E1-F接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
在接口上,本命令可以分别打开对内自环、对外净荷环回或者对外环回功能,但不能同时启用。
# 设置E1-F接口Serial2/1/0进行对内自环。
[Sysname-Serial2/1/0] fe1 loopback local
1.8.15  fe1 timeslot-list
fe1 timeslot-list命令用来设置E1-F接口的时隙捆绑。
undo fe1 timeslot-list命令用来恢复缺省情况。
fe1 timeslot-list list
E1-F接口捆绑所有的时隙,即E1-F接口的缺省速率为1984kbps。
E1-F接口视图
list:被捆绑的时隙编号,取值范围为1~31。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以用number1,number2-number3的形式同时指定多个时隙。
在对E1-F接口进行时隙捆绑后,接口的速率会同时改变。例如,当用户将1~10这十个时隙捆绑之后,接口的速率就会变为10×64kbps。
与CE1/PRI接口不同的是,在E1-F接口上只能捆绑出一个通道组(channel set),捆绑出的通道组就对应当前的同步串口。而在CE1/PRI接口上可以捆绑出多个通道组,并且每捆绑一个通道组,系统都会自动生成一个与之相对应的同步串口。
因为E1-F接口的0时隙被用于传输同步信息,所以,当对E1-F接口的时隙进行全部捆绑时,实际捆绑的时隙为1~31时隙。
当E1-F接口的工作方式为非成帧方式时,不能配置fe1 timeslot-list命令。
# 将E1-F接口Serial2/1/0上的1、2、5、10~15、18时隙捆绑起来。
[Sysname-Serial2/1/0] fe1 timeslot-list 1,2,5,10-15,18
·     fe1 unframed
1.8.16  fe1 unframed
fe1 unframed命令用来设置E1-F接口的工作方式为非成帧方式。
undo fe1 unframed命令用来恢复缺省情况。
fe1 unframed
undo fe1 unframed
E1-F接口工作在成帧方式。
E1-F接口视图
当E1-F接口工作在非成帧的工作方式时,它相当于一个不分时隙、数据带宽为2048kbps的接口,其逻辑特性与同步串口相同。
当E1-F接口工作在成帧的工作方式时,它在物理上分为32个时隙,对应编号为0~31,其中0时隙用于传输同步信息。
# 设置E1-F接口Serial2/1/0的工作方式为非成帧方式。
[Sysname-Serial2/1/0] fe1 unframed
·     fe1 timeslot-list
1.8.17  mtu
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
E1-F接口的MTU值为1500字节。
E1-F接口视图
# 设置E1-F接口Serial2/1/0的MTU值为1430字节。
1.8.18  reset counters interface
reset counters interface命令用来清除指定接口的统计信息。
# 清除E1-F接口Serial2/1/0的统计信息。
1.9  T1-F接口配置命令
1.9.1  crc
crc命令用来配置T1-F接口的CRC校验模式。
undo crc命令用来恢复缺省情况。
undo crc
使用16位CRC校验。
T1-F接口视图
16:T1-F接口使用16位CRC校验。
32:T1-F接口使用32位CRC校验。
none:T1-F接口不进行CRC校验。
# 配置T1-F接口Serial2/1/0使用32位CRC校验。
1.9.2  display ft1
display ft1命令用来显示T1-F接口的相关信息。
display ft1 [ serial interface-number ]
serial interface-number:显示指定T1-F接口的信息。interface-number为串口编号。如果不指定接口,则显示所有的T1-F接口的信息。
若指定的接口不是T1-F接口而是一个普通串口,则系统会提示该串口不是T1-F接口。
# 显示T1-F接口2/1/0的相关信息。
<Sysname> display ft1 serial 2/1/0
Serial2/1/0
  Loopback: not set
Alarm State:
  Receiver alarm state is Loss-of-Signal.
  Pulse density violation detected.
  Data in Interval 1:
    Ais Alarm: 0 seconds, Los Alarm: 901 seconds
  Data in Interval 2:
表1-12 display ft1命令显示信息描述表
Basic Configuration
接口的基本配置
Work mode
T1-F接口的工作模式(T1/CT1)
Cable type
T1-F接口的线缆类型(100 Ohm balanced)
Frame-format
T1-F接口的帧格式(esf/sf)
fdl
Line code
线路编码格式(b8zs/ami)
Source clock
Data-coding
Idle code
空闲码(7e/ff)
Itf type
帧间填充码的类型(7e/ff)
Itf number
帧间填充码的字节数为2个
Loopback
接口是否设置了环回(local/payload/remote/not set)
Alarm State
告警状态
发出的告警类型:RAI、none
脉冲密度不符合规范要求
BERT state
BERT测试状态:completed(完成)还是stopped, not completed(人为中止)还是running(正在测试)
Test pattern
测试模式(2^20/2^15)
Status
是否处于同步状态,Not Sync表示不处于同步状态
Sync Detected
测试以来检测到的同步次数
Time
预设的测试时间
Time past
已经过去的测试时间
测试以来收到的比特错误数
测试以来收到的比特总数
最近的同步以来收到的比特错误数
最近的同步以来收到的比特总数
历史信息
当前时间间隔内的统计信息(15分钟为一个时间间隔)。 这些数据是按照T1规范对物理层所作的各种信息统计,如AIS告警、RAI告警、LOS信号、LFA等。详细解释参见T1规范ANSI T1.403和AT&T TR 54016
  Data in Interval 1:
第1间隔内的统计信息
统计内容同上
  Data in Interval 2:
第2间隔内的统计信息
统计内容同上
所有间隔内的统计信息
统计内容同上
1.9.3  ft1 alarm-detect
ft1 alarm-detect命令用来配置检测远端告警信号。
undo ft1 alarm-detect命令用来取消检测远端告警信号。
ft1 alarm-detect rai
undo ft1 alarm-detect rai
检测远端告警信号。
T1-F接口视图
# 配置T1-F接口Serial2/1/0检测远端告警信号。
[Sysname-Serial2/1/0] ft1 alarm-detect rai
·     ft1 frame-format
1.9.4  ft1 alarm-threshold
ft1 alarm-threshold命令用来配置T1-F接口告警的门限值。
undo ft1 alarm-threshold命令用来恢复缺省情况。
ft1 alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo ft1 alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
T1-F接口视图
ais:AIS(Alarm Indication Signal,告警指示信号)告警的门限值。AIS告警有两个门限值,分别为level-1和level-2。level-1的门限为在一个SF/ESF帧内,比特流中的0的个数小等于2,则AIS告警产生;level-2的门限在SF格式时为,一个SF帧内码流的0个数小等于3;在ESF格式时为一个ESF帧内码流的0个数小等于5。缺省情况下,AIS告警门限值为level-1。
lfa:LFA(Loss of Frame Alignment,帧失步)告警的门限值。LFA告警有四个门限值可以配置,分别为level-1、level-2、level-3和level-4。level-1为4个帧同步比特中丢失了2个;level-2为5个帧同步比特中丢失了2个;leve-3为6个帧同步比特中丢失了2个;level-4仅仅对ESF格式有效,在连续4个ESF帧中出现错误时产生LFA告警。缺省情况下,LFA告警门限值为level-1。
los:LOS(Loss Of Signal,信号丢失)告警的门限值。LOS告警有两个门限值,分别为pulse-detection和pulse-recovery,pulse-detection配置LOS的检测时长门限,取值范围为16~4096,这个时长门限的单位为“脉冲周期”;pulse-recovery配置LOS的脉冲门限,取值范围为1~256,就是在检测时长内(即pulse-detection配置的若干个脉冲周期内),检测到的脉冲个数如果小于pulse-recovery所配置的值,则LOS告警产生。在缺省情况,pulse-detection参数的值为176,pulse-recovery的值为22,即如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失,LOS告警产生。
# 将T1-F接口Serial2/1/0的LOS告警的检测时长配置为300个脉冲周期。
[Sysname-Serial2/1/0] ft1 alarm-threshold los pulse-detection 300
·     ft1 frame-format
1.9.5  ft1 bert
ft1 bert命令用来进行线路位(Bit)错误率的测试。
undo ft1 bert命令用来取消进行线路位(Bit)错误率的测试。
ft1 bert pattern { 2^20 | 2^15 } time minutes [ unframed ]
undo ft1 bert
不进行线路位错误率的测试。
T1-F接口视图
time minutes:设置BERT测试的持续时间,取值范围为1~1440,单位为分钟。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前T1-F接口支持2^20和 2^15两种测试模式。
BERT测试方式为,本端发出测试数据流,经过线路某处环回来,检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对方设置远端环回等。利用ft1 bert命令配置好测试模式,指定测试时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。
BERT测试状态和测试结果详见T1-F接口显示部分。
# 设置T1-F接口Serial2/1/0执行2^20格式的BERT测试10分钟。
[Sysname-Serial2/1/0] ft1 bert pattern 2^20 time 10
·     display ft1
1.9.6  ft1 cable
ft1 cable命令用来设置T1-F接口匹配的传输线路的衰减或长度。
undo ft1 cable命令用来恢复缺省情况。
ft1 cable { long decibel | short length }
undo ft1 cable
T1-F接口匹配的传输线路衰减为long 0db。
T1-F接口视图
long decibel:匹配655英尺以上的传输线路,参数decibel的值可以为0db、-7.5db、-15db、-22.5db,可根据接收端信号质量选择不同的衰减参数,此时不需要外接CSU。
short length:匹配655英尺以下的传输线路,参数length的值可以为133ft、266ft、399ft、533ft、655ft,可根据传输线路的长度选择相应的长度参数。
本命令主要作用是配置发送时的信号波形,以适应不同传输需要。实际使用中可根据接收端收到的信号质量的好坏来决定是否使用此命令。如果信号质量较好可以使用缺省设置。
# 设置T1-F接口Serial2/1/0匹配的传输线路设为133英尺。
[Sysname-Serial2/1/0] ft1 cable short 133ft
·     ft1 frame-format
1.9.7  ft1 clock
ft1 clock命令用来设置T1-F接口的时钟模式。
undo ft1 clock命令用来恢复缺省情况。
ft1 clock { master | slave }
undo ft1 clock
T1-F接口视图
当T1-F接口作为DCE侧使用时,应使用主时钟模式;作为DTE侧使用时,应使用从时钟模式。
当两台路由器的T1-F接口直接相连时,必须使两端分别工作在从时钟模式和主时钟模式。当路由器的T1-F接口与交换机连接时,交换机是DCE侧,负责提供时钟;而路由器的接口需工作在从时钟模式。
# 设置T1-F接口Serial2/1/0使用主时钟模式。
[Sysname-Serial2/1/0] ft1 clock master
1.9.8  ft1 code
ft1 code命令用来设置T1-F接口的线路编解码格式。
undo ft1 code命令用来恢复缺省情况。
ft1 code { ami | b8zs }
undo ft1 code
T1-F接口的线路编解码格式为b8zs。
T1-F接口视图
线路编码采用ami方式时,在该接口上需要同时配置ft1 data-coding inverted,才能保证接口正常工作。
# 设置T1-F接口Serial2/1/0的线路编解码格式为ami。
[Sysname-Serial2/1/0] ft1 code ami
·     ft1 data-coding
1.9.9  ft1 data-coding
ft1 data-coding命令用来设置T1-F接口是否对用户数据进行翻转。
undo ft1 data-coding命令用来恢复缺省情况。
ft1 data-coding { inverted | normal }
T1-F接口不对用户数据进行翻转。
T1-F接口视图
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当T1-F接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现的过多连0的缺陷。
需要注意的是,只有通信的T1-F线路两端的T1-F接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置T1-F接口Serial2/1/0对用户数据进行翻转。
[Sysname-Serial2/1/0] ft1 data-coding inverted
·     ft1 code
1.9.10  ft1 fdl
ft1 fdl命令用来配置T1-F接口在ESF格式时FDL比特位的使用模式。
undo ft1 fdl命令用来恢复缺省情况。
ft1 fdl { ansi | att | both | none }
undo ft1 fdl
禁止FDL(none)。
T1-F接口视图
none:禁止FDL。
FDL(Facility Data Link,设备数据链路)是T1的ESF帧格式中4kbps的一个带宽,可以用来传递性能信息或者环回码之类。
# 设置T1-F接口Serial2/1/0的FDL支持ANSI规范。
[Sysname-Serial2/1/0] ft1 fdl ansi
·     ft1 frame-format
1.9.11  ft1 frame-format
ft1 frame-format命令用来设置T1-F接口的帧格式。
undo ft1 frame-format命令用来恢复缺省情况。
ft1 frame-format { esf | sf }
T1-F接口的帧格式为esf。
T1-F接口视图
esf:设置T1-F接口的帧格式为ESF(Extended Super Frame,扩展超帧)格式。
sf:设置T1-F接口的帧格式为SF(Super Frame,超帧)格式。
T1-F接口支持超帧和扩展超帧两种帧格式。在超帧格式中,多个帧可以共享相同的帧同步信息和信令信息,从而有更多的有效位来传送用户数据。实际应用中,经常需要对系统进行测试,扩展超帧技术可以用来满足在测试时不影响正常业务运行的要求。
# 设置T1-F接口Serial2/1/0的帧格式为超帧格式。
[Sysname-Serial2/1/0] ft1 frame-format sf
·     ft1 fdl
1.9.12  ft1 idle-code
ft1 idle-code命令用来设置T1-F接口的线路空闲码类型。
undo ft1 idle-code命令用来恢复缺省情况。
ft1 idle-code { 7e | ff }
undo ft1 idle-code
T1-F接口的线路空闲码类型为0x7e。
T1-F接口视图
7e:线路空闲码为0x7e类型。
ff:线路空闲码为0xff类型。
T1-F接口的线路空闲码类型是指在未被绑定到逻辑通道的时隙上发送的码型。
T1-F接口的线路空闲码类型有两种:0x7e和0xff。
# 设置T1-F接口Serial2/1/0的线路空闲码类型为0x7e。
[Sysname-Serial2/1/0] ft1 idle-code 7e
1.9.13  ft1 itf
ft1 itf命令用来设置T1-F接口的帧间填充符类型和个数。
undo ft1 itf命令用来恢复缺省情况。
ft1 itf { number number | type { 7e | ff } }
undo ft1 itf { number | type }
T1-F接口的帧间填充符类型为0x7e,帧间填充字节个数为4个。
T1-F接口视图
type:设置帧间填充符类型。
7e:表示帧间填充符为0x7e格式。
ff:表示帧间填充符为0xff格式。
T1-F接口的帧间填充符是指在已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。
T1-F接口的帧间填充符类型有两种:0x7e和0xff。
同时配置了ft1 code ami命令和ft1 data-coding inverted命令后,不能配置ft1 itf type ff命令,否则T1-F接口不能正常工作。
# 设置T1-F接口Serial2/1/0的帧间填充符类型为0xff。
[Sysname-Serial2/1/0] ft1 itf type ff
# 设置T1-F接口Serial2/1/0的帧间填充字节个数为5。
[Sysname-Serial2/1/0] ft1 itf number 5
·     ft1 code
·     ft1 data-coding
1.9.14  ft1 loopback
ft1 loopback命令用来开启T1-F接口的环回检测功能并设置检测方式。
undo ft1 loopback命令用来恢复缺省情况。
ft1 loopback { local | payload | remote }
undo ft1 loopback
环回检测功能处于关闭状态。
T1-F接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
# 设置T1-F接口Serial2/1/0进行对内自环。
[Sysname-Serial2/1/0] ft1 loopback local
1.9.15  ft1 sendloopcode
ft1 sendloopcode命令用来配置发送远程环回控制码。
ft1 sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
不发送远程环回控制码。
T1-F接口视图
T1-F接口下可以通过发送环回控制码对远端的T1-F接口进行环回的自动配置。
SF格式下的LLB环回码占用有效带宽(1-24时隙);ESF格式下对LLB和PLB的环回码均使用ESF帧的FDL比特位收发。
# 设置T1-F接口Serial2/1/0发送带内线路环回激活码。
[Sysname-Serial2/1/0] ft1 sendloopcode inband-llb-up
·     ft1 frame-format
1.9.16  ft1 timeslot-list
ft1 timeslot-list命令用来设置T1-F接口的时隙捆绑。
undo ft1 timeslot-list命令用来恢复缺省情况。
ft1 timeslot-list list [ speed { 56k | 64k } ]
T1-F接口捆绑所有的时隙,时隙的缺省速率为64kbps,即T1-F接口的缺省速率为1536kbps。
T1-F接口视图
list:被捆绑的时隙编号,取值范围为1~24。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以用number1,number2-number3的形式同时指定多个时隙。
speed { 56k | 64k }:时隙捆绑速率,单位为kbps。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。时隙的缺省速率为64kbps。
在对T1-F接口进行时隙捆绑后,接口的速率会同时改变。例如,当用户将1~10这十个时隙捆绑之后,接口的速率就会变为10×64kbps(或10×56kbps)。
与CT1/PRI接口不同的是,在T1-F接口上只能捆绑出一个通道组(channel set),捆绑出的通道组就对应当前的同步串口。而在CT1/PRI接口上,可以捆绑出多个通道组,并且每捆绑一个通道组,系统都会自动生成一个同步串口,与之相对应。
# 将T1-F接口Serial2/1/0上的1、2、5、10~15、18时隙捆绑起来。
[Sysname-Serial2/1/0] ft1 timeslot-list 1,2,5,10-15,18
1.9.17  mtu
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
T1-F接口的MTU值为1500字节。
T1-F接口视图
接口的MTU影响IP协议报文在该接口上传输时的分片与重组。
# 设置T1-F接口Serial2/1/0的MTU值为1430字节。
1.9.18  reset counters interface
# 清除T1-F接口Serial2/1/0的统计信息。
1.10  CE3接口配置命令
1.10.1  bert
bert pattern { 2^7 | 2^11 | 2^15 | qrss } time number [ unframed ]
undo bert
不进行线路位错误率的测试。
CE3接口视图
pattern:设置BERT测试模式,包括2^7,2^11,2^15和QRSS。
2^7:发送的码流长度为2的7次方个bit。
2^11:发送的码流长度为2的11次方个bit。
2^15:发送的码流长度为2的15次方个bit。
qrss:发送码流长度为2的20次方个bit,且码流中不允许连续14个以上的0。
time number:设置BERT测试的持续时间,取值范围为1~1440,单位为分钟。
unframed:设置测试数据流填充帧的开销位。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前CE3接口支持2^7,2^11,2^15和QRSS这几种测试模式。
BERT测试方式为,本端发出测试数据流,经过线路某处环回回来,本端检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对端设置为远端环回等。
利用bert命令配置好测试模式,指定测试持续时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。BERT测试状态和测试结果的说明详见CE3接口显示部分。
# 在CE3接口E3 2/4/0上执行QRSS格式的BERT测试10分钟。
[Sysname] controller e3 2/4/0
[Sysname-E3 2/4/0] bert pattern qrss time 10
1.10.2  clock
clock命令用来设置CE3接口的时钟模式。
undo clock命令用来恢复缺省情况。
undo clock
CE3接口的时钟模式为从时钟模式(slave)。
CE3接口视图
使用主时钟模式还是从时钟模式,主要根据所连接的对端设备而定,如果与传输设备相连,本端通常设置为从时钟模式。
如果是两台路由器的CE3接口直接相连,则应该把一端路由器时钟设置为主时钟模式,另一端路由器时钟设置为从时钟模式。
# 设置CE3接口E3 2/4/0使用主时钟模式。
[Sysname-E3 2/4/0] clock master
1.10.3  controller e3
controller e3命令用来进入CE3接口视图。
controller e3 interface-number
interface-number:CE3接口的编号。
# 进入CE3接口E3 2/4/0的视图。
[Sysname-E3 2/4/0]
1.10.4  display controller e3
display controller e3命令用来显示CE3接口的相关信息。
display controller e3 [ interface-number ]
interface-number:CE3接口编号。不指定本参数,将显示所有CE3接口的相关信息。
本命令可以显示CE3接口的状态信息,同时,还可以显示CE3接口工作在CE3模式时每个E1通道的相关信息。
# 显示CE3接口E3 2/4/0的相关信息。
<Sysname> display controller e3 2/4/0
E3 2/4/0
Current state: UP
Description: E3 2/4/0 Interface
Frame-format: G751, line code: HDB3, clock: slave
national-bit: 1, Current mode: CE3, loopback: not set, Alarm: none
ERROR: 2 BPV, 0 EXZ, 0 FrmErr, 0 FEBE
BERT state: (stopped, not completed)
  Test pattern: 2^7, Status: Not Sync, Sync Detected: 0
    Time: 2 minutes Time past: 2 minutes
    Bit errors (since test started): 0 bits
    Bits received (since test started): 0 Mbits
    Bit errors (since latest sync): 0 bits
    Bits received (since latest sync): 0 Mbits
E3 2/4/0  CE1 1: up
  Frame-format: NO-CRC4, clock: slave, loopback: not set
  Receiver alarm state: none
E3 2/4/0  CE1 2: up
E3 2/4/0  CE1 3: up
E3 2/4/0  CE1 4: up
E3 2/4/0  CE1 5: up
E3 2/4/0  CE1 6: up
E3 2/4/0  CE1 7: up
E3 2/4/0  CE1 8: up
E3 2/4/0  CE1 9: up
E3 2/4/0  CE1 10: up
E3 2/4/0  CE1 11: up
E3 2/4/0  CE1 12: up
E3 2/4/0  CE1 13: up
E3 2/4/0  CE1 14: up
E3 2/4/0  CE1 15: up
E3 2/4/0  CE1 16: up
表1-13 display controller e3命令显示信息描述表
E3 2/4/0
Current state
E3接口当前的状态
E3接口的描述信息
Frame-format
E3接口的帧格式(crc4/no crc4)
Line Code
线路码(Ami/hdb3)
clock
national-bit
国际通信位
Current mode
E3接口的工作模式(E3/CE3)
Loopback
接口是否设置了环回
Alarm
告警状态
BERT state
Test pattern
测试模式(2^20/2^15)
Status
是否处于同步状态
Sync Detected
测试以来检测到的同步次数
Time
预设的测试时间
Time past
已经过去的测试时间
测试以来收到的错误的比特数
测试以来收到的总比特数
最近的同步以来收到的错误的比特数
最近的同步以来收到的总比特数
E3 2/4/0  CE1 1
CE3接口下E1通道1的up/down状态
Frame-format
E1通道的帧格式,包括ESF和SF
clock
E1通道的时钟方式,包括slave和master
loopback
E1通道的环回方式,包括local、remote和payload
E1通道接收到的告警状态,包括:LOS、LOF、AIS和RAI
BERT state
BERT测试状态,包括running、complete和stopped
·     reset counters controller e3
1.10.5  e1 bert
e1 bert命令用来进行CE3接口下某E1通道的线路位(Bit)错误率的测试。
undo e1 bert命令用来取消该测试。
e1 line-number bert pattern { 2^11 | 2^15 | 2^20 | 2^23 | qrss } time number [ unframed ]
undo e1 line-number bert
不进行线路位错误率的测试。
CE3接口视图
line-number:E1通道号,取值范围为1~16。
pattern:设置BERT测试模式,包括2^11、2^15、2^20、2^23和QRSS。
2^20:发送的码流长度为2的20次方个bit。
2^23:发送的码流长度为2的23次方个bit。
qrss:发送的码流长度为2的20次方个bit,且码流中不允许连续14个以上的0。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前E1通道支持2^11、2^15、2^20、2^23和QRSS这几种测试模式。
BERT测试方式如下:本端发出测试数据流,经过线路某处环回回来,检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对端设置为远端环回等。
# 在E1通道1上执行QRSS格式的BERT测试10分钟。
[Sysname-E3 2/4/0] e1 1 bert pattern qrss time 10
1.10.6  e1 channel-set
e1 channel-set命令用来对E1通道进行时隙捆绑。
undo e1 channel-set命令用来取消时隙捆绑。
e1 line-number channel-set set-number timeslot-list list
undo e1 line-number channel-set set-number
不捆绑任何channel set。
CE3接口视图
line-number:E1通道的顺序号,取值范围为1~16。
set-number:指定E1通道上时隙捆绑形成的channel set的编号,取值范围为0~30。
CE3接口支持通道化到E1,每个E1最多可捆绑出31个通道。
当E1通道工作在成帧方式(CE1方式)时,可以对其进行时隙捆绑。系统会自动创建一个Serial接口,编号为serial number/line-number:set-number,如E3 2/4/0的第一个e1的channel-group 0生成的串口为2/4/0/1:0。此接口的速率为N×64kbps,其逻辑特性与同步串口相同,可以视其为同步串口,进行进一步的配置。
# 在接口E3 2/4/0的第一个E1通道上捆绑出一个128kbps的串口。
[Sysname-E3 2/4/0] e1 1 channel-set 1 timeslot-list 1,2
·     e1 unframed
1.10.7  e1 clock
e1 clock命令用来配置CE3接口下E1通道的时钟模式。
undo e1 clock命令用来恢复缺省情况。
e1 line-number clock { master | slave }
undo e1 line-number clock
CE3接口视图
当CE3接口工作在通道化方式下,各个E1通道均能独立设置时钟。
# 设置CE3接口E3 2/4/0下第一个E1通道使用从时钟模式。
[Sysname-E3 2/4/0] e1 1 clock slave
1.10.8  e1 frame-format
e1 frame-format命令用来配置E1通道的帧格式。
undo e1 frame-format命令用来恢复缺省情况。
e1 line-number frame-format { crc4 | no-crc4 }
undo e1 line-number frame-format
E1通道的帧格式为no-crc4。
CE3接口视图
crc4:E1通道的帧格式为CRC4帧格式。
no-crc4:E1通道的帧格式为非CRC4帧格式。
只有当E1通道工作在成帧方式时(使用命令undo e1 unframed),才能配置本命令。
# 设置CE3接口下第一个E1通道的帧格式为crc4。
[Sysname-E3 2/4/0] e1 1 frame-format crc4
·     e1 unframed
1.10.9  e1 loopback
e1 loopback命令用来开启E3接口下E1通道的环回检测功能并设置检测方式。
undo e1 loopback命令用来恢复缺省情况。
e1 line-number loopback { local | payload | remote }
undo e1 line-number loopback
环回检测功能处于关闭状态。
CE3接口视图
local:设置E1通道对内自环。
payload:设置E1通道对外净荷环回。
remote:设置E1通道对外环回。
如果E1通道的链路层协议为PPP,在设置自环或环回后,其链路层协议状态将上报为down。这属于正常情况。
# 设置E3接口下第一个E1通道进行对内自环。
[Sysname-E3 2/4/0] e1 1 loopback local
1.10.10  e1 shutdown
e1 shutdown命令用来关闭CE3接口的某个E1通道。
undo e1 shutdown命令用来恢复缺省情况。
e1 line-number shutdown
undo e1 line-number shutdown
E1通道处于打开状态。
CE3接口视图
该命令对于E1通道及其捆绑出的串口均有效。对指定E1通道执行e1 shutdown操作后,该E1通道捆绑形成的串口将shutdown,停止收发数据。如果执行undo e1 shutdown操作,则所有该E1通道捆绑形成的串口将被重新启用。
# 关闭E3接口下第一个E1通道。
[Sysname-E3 2/4/0] e1 1 shutdown
1.10.11  e1 unframed
e1 unframed命令用来配置CE3接口的E1通道工作在非成帧方式(E1方式)。
undo e1 unframed命令用来恢复缺省情况。
e1 line-number unframed
undo e1 line-number unframed
E1通道工作在成帧方式。
CE3接口视图
当E1配置成非成帧方式后,它将不包含帧控制信息,也不分时隙,不能进行时隙捆绑。此时,系统会自动创建一个Serial接口,编号为serial number/line-number:0。此接口的速率为2048kbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 设置E3接口下第一个E1通道工作在非成帧方式。
[Sysname-E3 2/4/0] e1 1 unframed
·     e1 channel-set
1.10.12  fe3
fe3命令用于配置CE3接口工作在FE3模式,并配置DSU模式或子速率。
undo fe3命令用来恢复缺省情况。
fe3 { dsu-mode { 0 | 1 } | subrate number }
undo fe3 { dsu-mode | subrate }
DSU模式为1,即Kentrox模式;子速率为34010kbps。
CE3接口视图
dsu-mode:设置FE3的DSU模式,支持常用的几家厂商的FE3 DSU模式,如下:
·     0:Digital Link,支持子速率范围为358~34010kbps,共95个速率等级,级差358kbps。
·     1:Kentrox,支持子速率范围为500~24500,34010kbps,共50个速率等级,级差500kbps。
subrate number:工作在FE3模式下的CE3接口的子速率。number的取值范围为1~34010,单位为kbps。
FE3(Fractional E3,或称Subrate E3)是E3的一种非标准应用模式。目前各厂商支持的速率等级均不一样,使用fe3命令可以使我们的设备和其它厂家设备的FE3 DSU模式兼容,实现互通。
该命令仅在支持FE3特性的CE3单板上有效,如CE3单板不支持FE3特性,系统将提示该命令无效。
该命令仅能在E3模式下使用,在CE3模式下该命令不可见。
通过fe3 subrate设置的速率值是一个大概值。由于通过fe3 dsu-mode命令配置的各DSU的子速率值是离散的,因此,当再通过fe3 subrate命令指定子速率后,E3接口会根据当前配置的DSU模式计算出与这个指定子速率最匹配的精确速率(精确到bps),并设置硬件电路支持该速率。通过display interface serial interface-number:0命令可以查看E3接口的DSU模式、子速率设置值、接口实际速率和接口的波特率。接口实际速率为不含开销在内的纯数据带宽,接口波特率(34368kbps)为E3线路的实际速率(含开销位在内)。
# 设置E3接口2/4/0工作在FE3模式,DSU模式为1,子速率为3000kbps。
[Sysname-E3 2/4/0] using e3
[Sysname-E3 2/4/0] fe3 dsu-mode 1
[Sysname-E3 2/4/0] fe3 subrate 3000
1.10.13  loopback
loopback命令用来开启CE3接口的环回检测功能并设置检测方式。
undo loopback
环回检测功能处于关闭状态。
CE3接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
只有在进行某些特殊功能测试时,才需要将CE3接口设为自环。
如果CE3接口的链路层协议配置为PPP,在设置环回后,其链路层协议状态将上报为down,这属于正常情况。
# 设置接口E3 2/4/0对内自环。
[Sysname-E3 2/4/0] loopback local
1.10.14  national-bit
national-bit命令用来配置CE3接口的National bit。
undo national-bit命令用来恢复缺省情况。
national-bit { 0 | 1 }
undo national-bit
CE3接口的National bit为1。
CE3接口视图
0:配置CE3接口的National bit为0。表明这个接口只能进行国内通信。
1:配置CE3接口的National bit为1。表明这个接口只能进行国际通信。
# 设置接口E3 2/4/0的national-bit为0。
[Sysname-E3 2/4/0] national-bit 0
1.10.15  reset counters controller e3
reset counters controller e3命令用来清除CE3接口的统计信息。
reset counters controller e3 [ interface-number ]
interface-number:CE3接口编号。不指定本参数,将清除所有CE3接口的统计信息。
单独清除CE3接口的统计信息只能使用reset counters controller e3命令,不能使用reset counters interface命令。
CE3接口的统计信息可以用display controller e3命令来查看。
# 清除接口E3 2/4/0的统计信息。
<Sysname> reset counters controller e3 2/4/0
·     display controller e3
1.10.16  using
using命令用来设置CE3接口的工作模式。
using { ce3 | e3 }
undo using
CE3接口工作在CE3模式。
CE3接口视图
ce3:设置接口工作在通道化模式(CE3模式)。
e3:设置接口工作在非通道化模式(E3模式)。
只有当CE3接口工作在通道化模式时,才能够对E1通道进行配置。
当CE3接口工作在非通道化模式时,系统会自动创建一个Serial接口,编号为serial number/0:0。此接口的速率为34.368Mbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 配置接口E3 2/4/0工作在非通道化模式。
1.11  CT3接口配置命令
1.11.1  alarm
alarm命令用来配置CT3接口的告警信号检测与发送功能。
undo alarm命令用来恢复缺省情况。
alarm { detect | generate { ais | febe | idle | rai } }
undo alarm { detect | generate { ais | febe | idle | rai } }
告警信号检测功能处于打开状态,发送功能处于关闭状态。
CT3接口视图
detect: CT3接口的定时检测各种告警的功能。
generate:发送某种告警信号,如AIS、RAI、IDLE和FEBE。可用于线路状态测试。
·     ais:Alarm Indication Signal,即告警指示信号。
·     febe:Far End Block Error,即远端块错误。
·     idle:空闲信号。
·     rai:Remote Alarm Indication,即远端告警指示信号。
上电后,CT3接口的告警信号定时检测功能是打开的,并能通过接口显示实时报告接口告警状态,如LOS、LOF、AIS、RAI等。当检测到LOS、LOF或AIS后,会向对方发送RAI告警信号。
主要的告警信号包括:LOS(Loss Of Signal,信号丢失)、LOF(Loss Of Frame,帧同步丢失)、AIS(Alarm Indication Signal,告警指示信号)、RAI(Remote Alarm Indication,远端告警指示信号)、FEBE(Far End Block Error,远端块错误)、IDLE为空闲信号。各信号具体格式遵循T3规范ANSI T1.107-1995。
接口一次只能发送一种告警信号(包括在使用detect功能时检测到LOS、LOF或AIS后而产生的RAI告警信号),发送另一种告警信号前必须使用undo alarm命令取消前一种告警信号。detect功能产生的告警信号(RAI)必须通过undo alarm detect命令取消。
告警的收发状态详见CT3接口显示部分。
# 打开CT3接口T3 2/4/0的告警检测功能。
[Sysname] controller t3 2/4/0
[Sysname-T3 2/4/0] alarm detect
# 在CT3接口T3 2/4/0上发送AIS告警信号。
 [Sysname-T3 2/4/0] alarm generate ais
1.11.2  bert
undo bert命令用来恢复缺省情况。
undo bert
不进行线路位错误率的测试。
CT3接口视图
time number :设置BERT测试的持续时间,取值范围为1~1440,单位为分钟。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前CT3接口支持2^7,2^11,2^15和QRSS这几种测试模式。
利用bert命令配置好测试模式,指定测试持续时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。BERT测试状态和测试结果的说明详见CT3接口显示部分。
# 在CT3接口T3 2/4/0上执行QRSS格式的BERT测试10分钟。
[Sysname] interface t3 2/4/0
[Sysname-T3 2/4/0] bert pattern qrss time 10
1.11.3  cable
cable 命令用来配置CT3接口所连接电缆的长度。
cable feet
undo cable
CT3接口所连接电缆的长度为49英尺。
CT3接口视图
feet:电缆长度,取值范围为0~450,单位为英尺(feet)。
CT3接口所连接电缆的长度是指从路由器到配线架之间电缆的长度。
# 设置CT3接口T3 2/4/0的电缆长度为50英尺。
[Sysname-T3 2/4/0] cable 50
1.11.4  clock
clock命令用来设置CT3接口的时钟模式。
undo clock
CT3接口视图
如果是两台路由器的CT3接口直接相连,则应该把一端路由器时钟设置为主时钟模式,另一端路由器时钟设置为从时钟模式。
# 设置CT3接口T3 2/4/0使用主时钟模式。
[Sysname-T3 2/4/0] clock master
1.11.5  controller t3
controller t3命令用来进入CT3接口视图。
controller t3 interface-number
interface-number:CT3接口的编号。
# 进入CT3接口T3 2/4/0的视图。
[Sysname-T3 2/4/0]
1.11.6  display controller t3
display controller t3命令用来显示CT3接口的相关信息。
display controller t3 [ interface-number ] [ t1 line-number ]
interface-number:CT3接口编号。不指定本参数,将显示所有CT3接口的相关信息。
t1 line-number:T1通道编号。
本命令可以显示CT3接口的状态信息,同时还可以显示CT3接口工作在CT3模式时每个T1通道的相关信息。
# 显示CT3接口T3 2/4/0的相关信息。
<Sysname> display controller t3 2/4/0
T3 2/4/0
Current state: UP
Description: T3 6/0 Interface
Current system time:2017-11-11 17:25:32
Last time when physical state changed to up:2017-11-11 17:25:26
Last time when physical state changed to down:2017-11-11 09:59:32
  Work mode: CT3, cable length: 49 feet
  Frame-format: C-BIT Parity, line code: B3ZS
  Source clock: slave, loopback: not set
Alarm state:
  Receiver alarm state is none
MDL state:
  No message is sent now.
  Message data elements:
    EIC: line, LIC: line, FIC: line, UNIT: line
    PFI: line, PORT_NO: line, GEN_NO: line
  Periodical detection: disabled
FEAC state:
  No code is sent now.
  Periodical detection is enabled, no code received now.
  Data in current interval (22 seconds elapsed):
    Line Code Violations: 0 Far End Block Error: 0
    C-Bit Coding Violation: 0
    P-bit Coding Violation: 0
    Framing Bit Err: 0, Severely Err Framing: 0 seconds
    C-bit Err: 0 seconds, C-bit Severely Err: 0 seconds
    P-bit Err: 0 seconds, P-bit Severely Err: 0 seconds
    Unavailable: 0 seconds, Line Err: 0 seconds
 T3 2/4/0  CT1 1: up
   Frame-format: ESF, clock: slave, loopback: not set
   FDL Performance Report: disabled
   Transmitter is sending none
   Line loop back deactivate code using inband signal last sent
     Test pattern: 2^11, Status: Not Sync, Sync Detected: 0
       Bits received (since test started): 0 Kbits
       Bits received (since latest sync): 0 Kbits
表1-14 display controller t3命令显示信息解释
T3 2/4/0
Current state
接口的物理up/down状态
接口描述信息
最近一次使用reset counters interface命令清除接口下的统计信息的时间。如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never
Current system time
当前系统时间
接口最近一次物理状态改变为up的时间
Basic Configuration
接口基本配置信息
Work mode
工作模式,包括通道化(CT3)和非通道化(T3)
cable length
线缆长度
Frame-format
帧格式,包括C-bit和M23
line code
线路编码
Source clock
时钟模式,包括master和slave
loopback
接口是否设置了环回
Alarm state
告警状态
显示接口收到的告警类别,包括:LOS、LOF、AIS、RAI。
当收到LOS、LOF、AIS之一时,向对方发送RAI,显示:Transmitter is sending RAI
MDL state
MDL状态
当前没有发送MDL消息
发送MDL消息(如path和idle-signal)时,显示如下:
Message sent now: path. idle signal
MDL数据元素
EIC、LIC、FIC和UNIT为四种MDL消息的公共元素,用户可设置
FI、PORT_NO和GEN_NO分别为消息path、idle-signal和test-signal的私有元素,用户可设置
Periodical detection: disabled.
MDL周期性检测被禁止。上电后默认为禁止。
当该检测功能被使能时,显示:
Periodical detection is enabled.
No message was received.
当检测到MDL消息时显示如:
Message received now: path.idle signal.
    path/FI: line
    idle Signal/PORT_NO: line
FEAC state:
FEAC状态
No code is sent now. DS3 Line Loop Back Deactivate was last sent.
当前没有FEAC信号发出,上次发出的FEAC信号为DS3 Line Loop Back Deactivate
FEAC周期性检测功能被使能。上电后默认使能。
当前未收到FEAC信号
DS3 Line Loop Back Deactivate last received.
上次收到的FEAC信号为DS3 Line Loop Back Deactivate
BERT状态(停止)
根据用户进行BERT操作的情况,有三种状态:
·     running-BERT测试正在进行;
·     complete-BERT测试自然完成(即达到测试时间);
·     stopped-BERT测试被提前中止
BERT测试模式,包括2^7、2^11、2^15以及QRSS等
同步状态:是否同步
子测试开始后检测到的同步次数
Time
总的测试时间
Time past
已经完成的测试时间
自测试开始后收到的错误比特数
自测试开始后收到的总比特数
自上一次同步以来收到的错误比特数
自上一次同步以来收到的总比特数
历史统计数据
当前interval(15分钟为一个interval)内的各项错误计数(已过去的时间为22秒)
线路信号错误数,包括:BPV错误、EXZ错误
Far End Block Error
远端块错误数
C-Bit Coding violation
C比特错误数
P比特错误数
Framing Bit Err
帧比特错误数
Severely Err Framing Secs
帧比特严重错误的秒数
C-bit Err Secs
C比特错误的秒数
C-bit Severely Err Secs
C比特严重错误的秒数,指1秒内C比特错误数超过44的秒
P-bit Err Secs
P比特错误的秒数
P-bit Severely Err Secs
P特严重错误的秒数,指1秒内P比特错误数超过44的秒
Unavailable Secs
服务无法获取的秒数
Line Err Secs
线路错误的秒数,包括:LOS、BPV、EXZ、C比特错误、P比特错误等
Data in Interval 1:
Interval 1内的数据
Total Data (last 17 15 minute intervals):
总的数据(前17个interval)
T3 2/4/0  CT1 1: up
CT3接口下T1通道1的up/down状态
T1通道的帧格式,包括ESF和SF
时钟方式包括slave和master,环回包括local、remote和payload
禁止用FDL链路传输性能报告信息(PPR),可用fdl ansi命令使能
T1通道发送器在发送RAI。当收到LOS、LOF或AIS时,发RAI
Receiver alarm state is LOF
T1通道接收到的告警状态,包括:LOS、LOF、AIS和RAI
Line loop back activate code using inband signal last sent
上次发送的环回码:Line loop back activate code using inband signal
·     reset counters controller t3
1.11.7  feac
feac命令用来配置CT3接口的FEAC链路信号的检测和传输功能。
undo feac命令用来取消已有的FEAC配置。
feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
undo feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
CT3接口的FEAC定时检测功能处于打开状态,传输功能处于关闭状态。
CT3接口视图
detect:CT3接口上的定时检测FEAC链路信号功能。
generate:发送FEAC信号,包括ds3-los、ds3-ais、ds3-oof、ds3-idle、ds3-eqptfail。
loopback:发送环回码,用于激活对端的线路环回(ds3-line)或者净荷环回(ds3-payload)。
FEAC(Far End Alarm and Control signal,远端告警与控制信号)是利用C-bit帧格式中第一个子帧中的第三个C比特组成的一条数据链路,可用于传输各种告警状态信号,也可用于传输环回控制码,用来激活或者取消对端的环回,进行环回测试。ANSI T1.107a中规定,FEAC可用于传输多种告警信号,并规定这条链路的数据帧为基于位的BOP(Bit Oriented Protocol)协议格式。
当用feac generate loopback { ds3-line | ds3-payload }激活对端环回后,可用undo feac generate loopback { ds3-line | ds3-payload }取消对端环回。
当利用该命令配置远端环回前,最好禁止本端的FEAC检测,以免发出的环回码在对方配好环回后被返回来,造成本端也配置为环回,引起线路上的环路死锁。
FEAC链路的收发状态的说明详见CT3接口显示部分。
# 打开CT3接口T3 2/4/0的FEAC链路数据检测功能。
[Sysname-T3 2/4/0] feac detect
# 在CT3接口T3 2/4/0上发送ds3-los信号。
[Sysname-T3 2/4/0] feac generate ds3-los
# 在CT3接口T3 2/4/0上发送环回码给对端,设置对端为线路环回。
[Sysname-T3 2/4/0] feac generate loopback ds3-line
1.11.8  frame-format
frame-format命令用来配置CT3接口所使用的帧格式。
frame-format { c-bit | m23 }
undo frame-format
CT3接口的帧格式为c-bit。
CT3接口视图
c-bit:设置帧格式为C-bit。
m23:设置帧格式为m23。
只有当CT3接口工作在通道化模式时,才能配置本命令。
# 设置CT3接口T3 2/4/0的帧格式为m23。
[Sysname-T3 2/4/0] frame-format m23
·     using
1.11.9  ft3
ft3命令用于配置CT3接口工作在FT3模式,并配置DSU模式、子速率或数据加扰功能。
undo ft3命令用来恢复缺省情况。
ft3 { dsu-mode { 0 | 1 | 2 | 3 | 4 } | subrate number | scramble }
undo ft3 { dsu-mode | subrate | scramble }
DSU模式为0,即Digital Link模式;子速率为44210kbps;数据加扰功能处于关闭状态。
CT3接口视图
dsu-mode:设置FT3的DSU模式,支持常用的几家厂商的FT3 DSU模式,如下:
·     0:Digital Link,支持子速率范围为300~44210kbps,共147个速率等级,级差300746bps。
·     1:Kentrox,支持子速率范围为1500~35000kbps及44210kbps,共69个速率等级,级差500000bps。
·     2:Larscom,支持子速率范围为3100~44210kbps,共14个速率等级,级差3157835bps。
·     3:Adtran,支持子速率范围为75~44210kbps,共588个速率等级,级差75187bps。
·     4:Verilink,支持子速率范围为1500~44210kbps,共20个速率等级,级差1578918bps。
subrate number:工作在FT3模式下的CT3接口的子速率。number的取值范围为1~44210,单位为kbps。
scramble:使能CT3接口的数据加扰功能。
FT3(Fractional T3,或称Subrate T3)是T3的一种非标准应用模式。目前各厂商支持的速率等级均不一样,使用ft3命令可以使我们的设备和其它厂家设备的FT3 DSU模式兼容,实现互通。
该命令仅在支持FT3特性的CT3单板上有效,如CT3单板不支持FT3特性,系统将提示该命令无效。
该命令仅能在T3模式下使用,在CT3模式下该命令不可见。
通过ft3 subrate设置的速率值是一个大概值。由于通过ft3 dsu-mode命令配置的各DSU的子速率值是离散的,因此,当再通过ft3 subrate命令指定子速率后,T3接口会根据当前配置的DSU模式计算出与这个指定子速率最匹配的精确速率(精确到bps),并设置硬件电路支持该速率。
通过ft3 scramble使能接口数据加扰后,数据中0和1的分布比较均匀,在线路上传输的信号质量会比较高。
通过display interface serial interface-number:0命令可以查看T3接口的DSU模式、子速率设置值、接口实际速率、接口的波特率和接口的数据加扰功能开启状态。接口实际速率为不含开销在内的纯数据带宽,接口波特率(44736kbps)为T3线路的实际速率(含开销位在内)。
# 设置T3接口T3 2/4/0工作在FT3模式,DSU模式为1,子速率为3000kbps,使能数据加扰功能。
[Sysname-T3 2/4/0] using t3
[Sysname-T3 2/4/0] ft3 dsu-mode 1
[Sysname-T3 2/4/0] ft3 subrate 3000
[Sysname-T3 2/4/0] ft3 scramble
1.11.10  loopback
loopback命令用来开启CT3接口的环回检测功能并设置检测方式。
undo loopback
环回检测功能处于关闭状态。
CT3接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
CT3接口两种对外环回的区别在于:对外载荷环回(payload)需要处理帧头开销,而对外远端环回(remote)则不对帧进行处理。
如果CT3接口的链路层协议配置为PPP,在设置环回后,其链路层协议状态将上报为down,这属于正常情况。
# 设置CT3接口T3 2/4/0对内自环。
[Sysname-T3 2/4/0] loopback local
1.11.11  mdl
mdl命令用来配置CT3接口的MDL链路消息检测与传输功能。
undo mdl命令用来恢复缺省情况。
mdl { data { eic string | fic string | gen-no string | lic string | pfi string | port-no string | unit string } | detect | generate { idle-signal | path | test-signal } }
undo mdl [ data [ eic | fic | gen-no | lic | pfi | port-no | unit ] | detect | generate [ idle-signal |  path | test-signal ] ]
上电后,CT3接口的MDL定时检测功能处于关闭状态,不发送任何消息。
CT3接口视图
data:设置MDL消息参数,其中eic、lic、fic和unit为三类MDL消息的公有参数,pfi、port-no和gen-no分别为消息path、idle signal和test signal的私有参数。这些参数为用户可定义的字符串,长度各有限制。
eic string:Equipment ID,为1~10个字符的字符串,缺省值为line。
fic string:Frame ID,为1~10个字符的字符串,缺省值为line。
gen-no string:Generator number in test signal message,test signal消息的私有参数,为1~38个字符的字符串,缺省值为line。
lic string:Location ID,为1~11个字符的字符串,缺省值为line。
pfi string:Facility ID in path message,path消息的私有参数,为1~38个字符的字符串,缺省值为line。
port-no string:Port number in idle signal message,idle signal消息的私有参数,为1~38个字符的字符串,缺省值为line。
unit string:Unit,为1~6个字符的字符串,缺省值为line。
detect:CT3接口上的定时检测MDL消息功能。
generate:按照data中配置的参数定时发送MDL消息,包括path、idle signal和test signal,可以同时发送。
MDL(Maintenance Data Link,维护数据链路)是利用C-bit帧格式中第五个子帧中的3个C比特组成的一条数据链路,可用于传输一些维护性的消息。ANSI T1.107a中规定,MDL可用于传输三种消息:path、idle signal和test signal,并规定这条链路的数据帧为LAPD协议格式。
MDL链路的收发状态详见CT3接口显示部分。
# 打开CT3接口T3 2/4/0的MDL检测功能。
[Sysname-T3 2/4/0] mdl detect
# 配置CT3接口T3 2/4/0的MDL的lic参数为字符串“hello”。
[Sysname-T3 2/4/0] mdl data lic hello
# 设置CT3接口T3 2/4/0发送path消息。
[Sysname-T3 2/4/0] mdl generate path
1.11.12  reset counters controller t3
reset counters controller t3命令用来清除CT3接口的统计信息。
reset counters controller t3 [ interface-number ]
interface-number:CT3接口编号。不指定本参数,将清除所有CT3接口的统计信息。
单独清除CT3接口的统计信息只能使用reset counters controller t3命令,不能使用reset counters interface命令。
CT3接口的统计信息可以用display controller t3命令来查看。
# 清除接口T3 2/4/0的统计信息。
<Sysname> reset counters controller t3 2/4/0
·     display controller t3
1.11.13  t1 alarm
t1 alarm命令用来配置CT3接口下某个T1通道的告警信号检测与发送功能。
undo t1 alarm命令用来恢复缺省情况。
t1 line-number alarm { detect | generate { ais | rai } }
undo t1 line-number alarm { detect | generate { ais | rai } }
CT3接口视图
line-number:T1通道号,取值范围为1~28。
detect:CT3接口下某个T1通道的告警信号检测功能。
generate:发送某种告警信号,如AIS、RAI。可用于线路状态测试。
上电后,CT3接口下各T1通道的告警信号定时检测功能是打开的,并能通过接口显示实时报告接口告警状态,如LOS、LOF、AIS、RAI等。当检测到LOS、LOF或AIS后,会向对方发送RAI告警信号。
主要的告警信号包括:LOS(Loss Of Signal,信号丢失)、LOF(Loss Of Frame,帧同步丢失)、AIS(Alarm Indication Signal,告警指示信号)、RAI(Remote Alarm Indication,远端告警指示信号)。各信号具体格式遵循T1规范ANSI T1.403。
一次只能发送一种告警信号(包括在使用detect功能时检测到LOS、LOF或AIS后而产生的RAI告警信号),发送另一种告警信号前必须使用undo t1 alarm generate命令取消前一种告警信号。detect功能产生的告警信号(RAI)必须通过undo t1 alarm detect命令取消。
告警的收发状态详见CT3接口显示部分。
# 打开CT3接口2/4/0的T1通道1的告警检测功能。
[Sysname-T3 2/4/0] t1 1 alarm detect
# 在CT3接口2/4/0的T1通道1上发送AIS告警信号。
[Sysname-T3 2/4/0] t1 1 alarm generate ais
1.11.14  t1 bert
t1 bert命令用来进行CT3接口下某T1通道的线路位(Bit)错误率的测试。
undo t1 bert命令用来恢复缺省情况。
t1 line-number bert pattern { 2^11 | 2^15 | 2^20 | 2^23 | qrss } time number [ unframed ]
undo t1 line-number bert
不进行线路位错误率的测试。
CT3接口视图
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前T1通道支持2^11、2^15、2^20、2^23和QRSS这几种测试模式。
# 在T1通道1上执行QRSS格式的BERT测试10分钟。
[Sysname-T3 2/4/0] t1 1 bert pattern qrss time 10
1.11.15  t1 channel-set
t1 channel-set命令用来对T1通道进行时隙捆绑。
undo t1 channel-set命令用来取消时隙捆绑。
t1 line-number channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
undo t1 line-number channel-set set-number
不捆绑任何channel set。
CT3接口视图
line-number:T1通道的顺序号,取值范围为1~28。
set-number:指定T1通道上时隙捆绑形成的channel set的编号,取值范围为0~23。
speed { 56k | 64k }:配置时隙捆绑的方式。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。如果不指定速率,缺省采用64kbps。
当T1通道工作在成帧方式(CT1方式)时,可以对其进行时隙捆绑。系统会自动创建一个Serial接口,编号为serial number/line-number:set-number。此接口的速率为N×64kbps(或N×56kbps),其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 在T3 2/4/0接口的第一个T1通道上捆绑出一个128kbps的串口。
[Sysname-T3 2/4/0] t1 1 channel-set 1 timeslot-list 1,2
·     t1 unframed
1.11.16  t1 clock
t1 clock命令用来配置CT3接口下T1通道的时钟模式。
undo t1 clock命令用来恢复缺省情况。
t1 line-number clock { master | slave }
undo t1 line-number clock
CT3接口下T1通道的时钟模式为从时钟模式(slave)。
CT3接口视图
master:设置T1通道的时钟模式为主时钟模式,使用内部时钟信号。
slave:设置T1通道的时钟模式为从时钟模式,使用线路提供的时钟信号。
当CT3接口工作在通道化工作方式下,各个T1通道均能独立设置时钟。
# 设置T3接口下第一个T1通道使用从时钟模式。
[Sysname-T3 2/4/0] t1 1 clock slave
1.11.17  t1 fdl
t1 fdl命令用来设置CT3接口下T1通道的FDL链路格式。
undo t1 fdl命令用来取消T1通道的FDL链路传输。
t1 line-number fdl { ansi | att | both | none }
undo t1 line-number fdl
禁止FDL(none)。
CT3接口视图
att:使能FDL,遵循AT&T TR 54016 规范。
none:禁止FDL。
FDL(Facility Data Link,设备数据链路)是T1的ESF帧格式中的一条4kbps的数据链路,可用于传输PPR(Periodical Performance Report)数据,也可传输环回控制码,配置远端环回。ANSI T1.403规范定义,PPR数据格式为LAPD协议格式,环回控制码格式为BOP(Bit Oriented Protocol)协议格式。这里的t1 fdl命令仅用于启动PPR数据传输,对环回码的发送和检测没有影响,即收发环回码无需配置fdl。
需要注意的是,只有在CT3接口下的T1通道工作在通道化模式下,且T1帧格式为ESF时候,该配置才有效。
# 设置CT3接口T3 2/4/0的T1通道1的FDL格式为ansi。
[Sysname-T3 2/4/0] t1 1 fdl ansi
·     t1 frame-format
1.11.18  t1 frame-format
t1 frame-format命令用来配置T1通道的帧格式。
undo t1 frame-format命令用来恢复缺省情况。
t1 line-number frame-format { esf | sf }
undo t1 line-number frame-format
T1通道的帧格式为esf。
CT3接口视图
line-numbe:T1通道号,取值范围为1~28。
esf:设置T1通道的帧格式为ESF(Extended Super Frame,扩展超帧)格式。
sf:设置T1通道的帧格式为SF(Super Frame,超帧)格式。
只有当T1通道工作在成帧方式时(使用命令undo t1 unframed),才能配置本命令。
# 设置T3接口下第一个T1通道的帧格式为超帧格式。
[Sysname-T3 2/4/0] t1 1 frame-format sf
·     t1 unframed
1.11.19  t1 loopback
t1 loopback命令用来开启CT3接口下T1通道的环回检测功能并设置检测方式。
undo t1 loopback命令用来恢复缺省情况。
t1 line-number loopback { local | payload | remote }
undo t1 line-number loopback
环回检测功能处于关闭状态。
CT3接口视图
local:设置T1通道对内自环。
payload:设置T1通道对外净荷环回。
remote:设置T1通道对外环回。
如果T1通道的链路层协议为PPP,在设置自环或远端环回后,其链路层协议状态将上报为down,这属于正常情况。
环回功能通常用于进行某些特殊测试,正常工作时不要启动环回。
# 设置T3接口下第一个T1通道进行对内自环。
[Sysname-T3 2/4/0] t1 1 loopback local
1.11.20  t1 sendloopcode
t1 sendloopcode命令用来设置对端CT3接口的某个T1通道的环回模式。
undo t1 sendloopcode命令用来取消对应的配置。
t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
undo t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
不设置sendloopcode。
CT3接口视图
fdl-ansi-line-up:发送FDL承载的符合ANSI规范的线路环回激活码,启动远端环回。
fdl-ansi-payload-up:发送FDL承载的符合ANSI规范的净荷环回激活码,启动远端环回。
fdl-att-payload-up:发送FDL承载的符合AT&T规范的净荷环回激活码,启动远端环回。
inband-line-up:发送符合ANSI规范和AT&T规范的带内线路环回激活码,启动远端环回。
环回测试是一种有效的问题诊断方法。除了在远端设备上通过命令行配置环回外,还可发送环回控制码,设置远端设备的环回。ANSI T1.403规范定义了T1接口下的环回控制码类型和格式。按照环回类型,可分为line环回(数据流不经过成帧器)和payload环回(数据流经过成帧器)两种;按照传输环回控制码的载体,可分为利用inband信号(即T1的192位有效数据带宽或193位全部带宽)和利用ESF帧格式中的FDL链路两种。
# 在CT3接口2/4/0发送inband信号,配置对端CT3接口的T1通道1为line环回。
[Sysname-T3 2/4/0] t1 1 sendloopcode inband-line-up
1.11.21  t1 show
t1 show命令用来快捷显示CT3接口下某个T1通道线路状态。
t1 line-number show
CT3接口视图
show:显示T1通道物理线路状态。
# 显示T1通道1的线路状态。
[Sysname-T3 2/4/0] t1 1 show
T3 2/4/0  CT1 1: up
表1-15 t1 show命令显示信息解释
T3 2/4/0  CT1 1: up
Frame-format
T1通道的帧格式,包括ESF和SF
clock
时钟模式,包括slave和master
loopback
环回设置
禁止用FDL链路传输性能报告信息(PPR),可用t1 fdl ansi命令使能
T1通道接收到的告警,包括:LOS、LOF、AIS和RAI
BERT state
BERT测试状态。包括running、complete和stopped(not completed)
Test pattern
测试模式
Status
同步状态
Sync Detected
检测到的同步次数
Time
总测试时间
Time past
已经过去的测试时间
测试以来收到的错误比特数
测试以来收到的总比特数
上次同步以来收到的错误比特数
上次同步以来收到的总比特数
1.11.22  t1 shutdown
t1 shutdown命令用来关闭CT3接口的某个T1通道。
undo t1 shutdown命令用来打开T1通道。
t1 line-number shutdown
undo t1 line-number shutdown
T1通道处于打开状态。
CT3接口视图
该命令对于T1通道及其捆绑出的串口均有效。对指定T1通道执t1 shutdown操作后,该T1通道捆绑形成的串口将shutdown,停止收发数据。如果执行undo t1 shutdown操作,则所有该T1通道捆绑形成的串口将被重新启用。
# 关闭T3接口下第一个T1通道。
[Sysname-T3 2/4/0] t1 1 shutdown
1.11.23  t1 unframed
t1 unframed命令用来配置CT3接口的T1通道工作在非成帧方式(T1方式)。
undo t1 unframed命令用来配置CT3接口的T1通道工作在成帧方式(CT1方式)。
t1 line-number unframed
undo t1 line-number unframed
T1通道工作在成帧方式。
CT3接口视图
当T1配置成非成帧方式后,它将不包含帧控制信息,也不分时隙,不能进行时隙捆绑。此时,系统会自动创建一个Serial接口,编号为serial number/line-umber:0。此接口的速率为1544kbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 设置T3接口下第一个T1通道工作在非成帧方式。
[Sysname-T3 2/4/0] t1 1 unframed
·     t1 channel-set
1.11.24  using
using命令用来配置CT3接口的工作模式。
using { ct3 | t3 }
undo using
CT3接口工作在CT3模式。
CT3接口视图
ct3:设置接口工作在通道化模式(CT3模式)。
t3:设置接口工作在非通道化模式(T3模式)。
只有当CT3接口工作在通道化模式时,才能够对T1通道进行配置。
当CT3接口工作在非通道化模式时,系统会自动创建一个Serial接口,编号为serial number/0:0。此接口的速率为44.736Mbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 配置接口T3 2/4/0工作在非通道化模式。
