- H3C S12500R Ethernet Switch Router Series Config Examples-Release 36xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-Ethernet Link Aggregation Configuration Examples
- 05-Port Isolation Configuration Examples
- 06-Spanning Tree Configuration Examples
- 07-VLAN Configuration Examples
- 08-VLAN Tagging Configuration Examples
- 09-DHCP Snooping Configuration Examples
- 10-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 11-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 12-GRE Tunnel Configuration Examples
- 13-GRE with OSPF Configuration Examples
- 14-OSPF Configuration Examples
- 15-IS-IS Configuration Examples
- 16-BGP Configuration Examples
- 17-Policy-Based Routing Configuration Examples
- 18-OSPFv3 Configuration Examples
- 19-IPv6 IS-IS Configuration Examples
- 20-Routing Policy Configuration Examples
- 21-IGMP Snooping Configuration Examples
- 22-IGMP Configuration Examples
- 23-MLD Snooping Configuration Examples
- 24-Basic MPLS Configuration Examples
- 25-MPLS L3VPN Configuration Examples
- 26-ACL Configuration Examples
- 27-Control Plane-Based QoS Policy Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Priority Mapping and Queue Scheduling Configuration Examples
- 31-Traffic Filtering Configuration Examples
- 32-AAA Configuration Examples
- 33-SSH Configuration Examples
- 34-IP Source Guard Configuration Examples
- 35-Ethernet OAM Configuration Examples
- 36-CFD Configuration Examples
- 37-DLDP Configuration Examples
- 38-VRRP Configuration Examples
- 39-BFD Configuration Examples
- 40-NTP Configuration Examples
- 41-SNMP Configuration Examples
- 42-NQA Configuration Examples
- 43-Mirroring Configuration Examples
- 44-sFlow Configuration Examples
- 45-OpenFlow Configuration Examples
- 46-MAC Address Table Configuration Examples
- 47-Static Multicast MAC Address Entry Configuration Examples
- 48-IP Unnumbered Configuration Examples
- 49-Congestion Avoidance and Queue Scheduling Configuration Examples
- 50-Attack Protection Configuration Examples
- 51-Smart Link Configuration Examples
- 52-RRPP Configuration Examples
- 53-BGP Route Selection Configuration Examples
- 54-IS-IS Route Summarization Configuration Examples
- 55-MPLS OAM Configuration Examples
- 56-MPLS TE Configuration Examples
- 57-VXLAN Configuration Examples
- 58-NetStream Configuration Examples
- 59-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-MPLS SR Configuration Examples
- 63-Puppet Configuration Examples
| 44-sFlow Configuration Examples | 126.11 KB |
H3C S12500R Switch Router Series |
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. The information in this document is subject to change without notice.
Introduction
This document provides sFlow configuration examples.
This document assumes that you have basic knowledge of sFlow.
General restrictions and guidelines
When you configure sFlow, follow these restrictions and guidelines:
· You can specify only the random sampling mode (the default).
· For the remote sFlow collector to receive sFlow packets, the IP address of the sFlow collector specified on the sFlow agent must be the same with that of the remote sFlow collector.
· If the number of packets sampled by an interface is too much in a heavy traffic network, increase the flow sampling interval. If an interface samples insufficient packets in a light traffic network, decrease the flow sampling interval.
· If an interface collects data too frequently in a heavy traffic network, increase the counter sampling interval. If the sampling statistics is not accurate in a light traffic network, decrease the counter sampling interval.
Example: Configuring sFlow
As shown in Figure 1, perform the following tasks:
· Configure flow sampling to sample packets on Device A and Device B.
· Configure counter sampling to periodically collect the counter information on Device A and Device B.
Analysis
To obtain interface counter information and packet information, you must configure both flow sampling and counter sampling.
Software versions used
This configuration example was created and verified on R3606.
Before configuring sFlow, configure routes on devices to ensure that they can reach each other at Layer 3.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring Device A
# Create VLAN 10. Assign HundredGigE 1/0/1 through HundredGigE 1/0/3 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port hundredgige 1/0/1 to hundredgige 1/0/3
[DeviceA-vlan10] quit
# Assign an IP address to VLAN-interface 10.
[DeviceA-Vlan-interface10] ip address 10.1.1.1 255.255.255.0
# Assign IP addresses to other interfaces. (Details not shown.)
# Assign an IP address to the sFlow agent.
[DeviceA] sflow agent ip 10.1.1.1
# Specify the sFlow collector ID as 1, IP address as 30.1.1.2, and port number as 5000.
[DeviceA] sflow collector 1 ip 30.1.1.2 port 5000
# Enable counter sampling and set the counter sampling interval to 120 seconds on HundredGigE 1/0/1.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling on HundredGigE 1/0/1.
[DeviceA-HundredGigE1/0/1] sflow counter collector 1
[DeviceA-HundredGigE1/0/1] quit
# Enable counter sampling and set the counter sampling interval to 120 seconds on HundredGigE 1/0/2.
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling on HundredGigE 1/0/2.
[DeviceA-HundredGigE1/0/2] sflow counter collector 1
[DeviceA-HundredGigE1/0/2] quit
# Enable flow sampling and set the sampling interval to 100000 on HundredGigE 1/0/1.
[DeviceA-HundredGigE1/0/1] sflow sampling-rate 100000
# Specify sFlow collector 1 for flow sampling on HundredGigE 1/0/1.
[DeviceA-HundredGigE1/0/1] sflow flow collector 1
# Enable flow sampling and set the sampling interval to 100000 on HundredGigE 1/0/2.
[DeviceA-HundredGigE1/0/2] sflow sampling-rate 100000
# Specify sFlow collector 1 for flow sampling on HundredGigE 1/0/2.
[DeviceA-HundredGigE1/0/2] sflow flow collector 1
Configuring Device B
# Create VLAN 20. Assign HundredGigE 1/0/1 and HundredGigE 1/0/2 to VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] port hundredgige 1/0/1 to hundredgige 1/0/2
[DeviceB-vlan20] quit
# Assign an IP address to VLAN-interface 20.
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] ip address 20.1.1.1 255.255.255.0
[DeviceB-Vlan-interface20] quit
[DeviceB] sflow agent ip 20.1.1.1
[DeviceB] sflow collector 1 ip 30.1.1.2 port 5000
# Enable counter sampling and set the counter sampling interval to 30 seconds on HundredGigE 1/0/1.
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] sflow counter interval 30
[DeviceB-HundredGigE1/0/1] sflow counter collector 1
# Enable flow sampling and set the sampling interval to 20000 on HundredGigE 1/0/1.
[DeviceB-HundredGigE1/0/1] sflow sampling-rate 20000
[DeviceB-HundredGigE1/0/1] sflow flow collector 1
[DeviceB-HundredGigE1/0/1] quit
# Verify the following items on Device A:
· HundredGigE 1/0/1 and HundredGigE 1/0/2 enabled with sFlow are active.
· The counter sampling interval is 120 seconds.
· The flow sampling interval is 100000.
[DeviceA] display sflow
sFlow datagram version: 5
Global information:
Agent IP: 10.1.1.1(CLI)
Source address:
Collector information:
ID IP Port Aging Size VPN-instance Description
1 30.1.1.2 5000 N/A 1400 CLI Collector
Port information:
Interface CID Interval(s) FID MaxHLen Rate Mode Status
HGE1/0/1 1 120 1 128 100000 random Active
HGE1/0/2 1 120 1 128 100000 random Active
Configuration files
· Device A:
vlan 10
interface Vlan-interface10
sflow collector 1 ip 30.1.1.2 port 5000 description "CLI Collector"
interface HundredGigE1/0/1
port access vlan 10
interface HundredGigE1/0/2
port access vlan 10
interface HundredGigE1/0/3
port access vlan 10
· Device B:
vlan 20
interface Vlan-interface20
port access vlan 20
port access vlan 20
Related documentation
· H3C S12500R Switch Router Series Network Management and Monitoring Configuration Guide-R3606
· H3C S12500R Switch Router Series Network Management and Monitoring Command Reference-R3606
