H3C WX3000 Series Unified Switches Switching Engine Configuration Guide-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesConfigure & DeployConfiguration GuidesH3C WX3000 Series Unified Switches Switching Engine Configuration Guide-6W103
22-Mirroring Configuration
22-Mirroring Configuration 129.72 KB
1  Mirroring Configuration
l          The term switch used throughout this chapter refers to a switching device in a generic sense or the switching engine of a unified switch in the WX3000 series.
l          The sample output information in this manual was created on the WX3024. The output information on your device may vary.
Mirroring Overview
Mirroring refers to the process of copying packets of one or more ports (source ports) to a destination port which is connected to a data detection device. Users can then use the data detection device to analyze the mirrored packets on the destination port for monitoring and troubleshooting the network.
Figure 1-1 Mirroring
The device supports four kinds of port mirroring:
l          Local port mirroring: a device copies packets passing through one or more source ports of the device to the destination port.
l          Remote port mirroring implements port mirroring through the remote source mirroring group and remote destination mirroring group. The device copies the packets of the source port to the reflector port, which then broadcasts the packets in the remote-probe VLAN. After the remote device receives the packets, it compares the VLAN ID of the packets with that of the remote-probe VLAN on the remote device. If the VLAN IDs are identical, the remote device forwards the packets to the destination port of the remote destination mirroring group.
l          MAC-based mirroring: a device copies packets matching a specified MAC address to the destination port.
l          VLAN-based mirroring: a device copies packets of a specified VLAN to the destination port.
Local Port Mirroring
In local port mirroring, packets passing through one or more source ports of a device are copied to the destination port on the same device for packet analysis and monitoring. In this case, the source ports and the destination port must be located on the same device.
Remote Port Mirroring
Remote port mirroring does not require the source and destination ports to be on the same device. The source and destination ports can be located on multiple devices across the network. Therefore, administrators can monitor the traffic on remote devices conveniently.
To implement remote port mirroring, a special VLAN, called remote-probe VLAN, is needed. All mirrored packets are sent from the reflector port of the source switch to the monitor port (destination port) of the destination switch through the remote-probe VLAN, so as to implement the monitoring of packets received on and sent from the source switch on the destination switch. Figure 1-2 illustrates the implementation of remote port mirroring.
Figure 1-2 Remote port mirroring application
The switches involved in the remote port mirroring implementation play the following three roles.
l          Source switch: The monitored port resident switch. It copies traffic to the reflector port, which then transmits the traffic to an intermediate switch or destination switch through the remote-probe VLAN.
l          Intermediate switch: Switches between the source switch and destination switch on the network. An intermediate switch forwards mirrored traffic flows to the next intermediate switch or the destination switch through the remote-probe VLAN. No intermediate switch is present if the source and destination switches directly connect to each other.
l          Destination switch: The remote mirroring destination port resident switch. It forwards mirrored traffic flows it received from the remote-probe VLAN to the monitoring device through the destination port.
Table 1-1 describes how the ports on various switches are involved in the mirroring operation.
Table 1-1 Ports involved in the mirroring operation
Switch
Ports involved
Function
Source switch
Source port
Port monitored. It copies packets to the reflector port through local port mirroring. There can be more than one source port.
Reflector port
Receives packets from the source port and broadcasts the packets in the remote-probe VLAN.
Trunk port
Sends mirrored packets to the intermediate switch or the destination switch.
Intermediate switch
Trunk port
Sends mirrored packets to the destination switch.
Two trunk ports are necessary for the intermediate switch to connect the devices at the source switch side and the destination switch side.
Destination switch
Trunk port
Receives remote mirrored packets.
Destination port
Receives packets forwarded from the trunk port and transmits the packets to the data detection device.
l          Do not configure a default VLAN, a management VLAN, or a dynamic VLAN as the remote-probe VLAN.
l          Configure all ports connecting the devices in the remote-probe VLAN as trunk ports, and ensure the Layer 2 connectivity from the source switch to the destination switch over the remote-probe VLAN.
l          Do not configure a Layer 3 interface for the remote-probe VLAN, run other protocol packets, or carry other service packets on the remote-prove VLAN and do not use the remote-prove VLAN as the voice VLAN and protocol VLAN; otherwise, remote port mirroring may be affected.
MAC-Based Mirroring
With MAC-based mirroring configured, a device mirrors packets matching the specified MAC address to the destination port, including:
l          Packets with the source MAC address matching the specified MAC address.
l          Packets with the destination MAC address matching the specified MAC address.
Compared with port mirroring, MAC-based mirroring is more precise and it can be used to monitor packets of specific device in the network.
VLAN-Based Mirroring
With VLAN-based mirroring configured, a device mirrors packets received on all ports in the specified VLAN to the destination port.
Compared with port mirroring, VLAN-based mirroring is more extensive and it can be used to monitor packets of a specific VLAN or VLANs in the network.
Complete the following tasks to configure mirroring:
Remarks
Configuring Local Port Mirroring
Optional
Configuring Remote Port Mirroring
Optional
Configuring MAC-Based Mirroring
Optional
Configuring VLAN-Based Mirroring
Optional
Configuration prerequisites
l          The source port is determined and the direction in which the packets are to be mirrored is determined.
l          The destination port is determined.
Configuration procedure
Follow these steps to configure local port mirroring:
To do…
Use the command…
Remarks
Enter system view
Create a port mirroring group
mirroring-group group-id local
Required
Configure the source port for the port mirroring group
In system view
mirroring-group group-id mirroring-port mirroring-port-list { both | inbound | outbound }
Use either approach
You can configure multiple source ports at a time in system view, or you can configure the source port in specific port view. The configurations in the two views have the same effect.
In port view
mirroring-group group-id mirroring-port { both | inbound | outbound }
Configure the destination port for the port mirroring group
In system view
mirroring-group group-id monitor-port monitor-port-id
Use either approach
In port view
When configuring local port mirroring, note that:
l          You need to configure the source and destination ports for the local port mirroring to take effect.
l          The source port and the destination port cannot be a member port of an existing mirroring group; besides, the destination port cannot be a member port of an aggregation group or a port enabled with LACP or STP.
The device can serve as a source switch, an intermediate switch, or a destination switch in a remote port mirroring networking environment.
Configuration on the device acting as a source switch
1)        Configuration prerequisites
l          The source port, the reflector port, and the remote-probe VLAN are determined.
l          Layer 2 connectivity is ensured between the source and destination switches over the remote-probe VLAN.
l          The direction of the packets to be monitored is determined.
2)        Configuration procedure
Follow these steps to configure the source switch:
To do…
Use the command…
Remarks
Enter system view
Create a VLAN and enter the VLAN view
vlan vlan-id
vlan-id is the ID of the remote-probe VLAN.
Configure the current VLAN as the remote-probe VLAN
remote-probe vlan enable
Required
Return to system view
Enter the view of the Ethernet port that connects to the intermediate switch or destination switch
Configure the current port as trunk port
port link-type trunk
Required
By default, the port type is Access.
Configure the trunk port to permit packets from the remote-probe VLAN
port trunk permit vlan remote-probe-vlan-id
Required
Create a remote source mirroring group
mirroring-group group-id remote-source
Required
Configure source port(s) for the remote source mirroring group
Required
Configure the reflector port for the remote source mirroring group
mirroring-group group-id reflector-port reflector-port
Required
Configure the remote-probe VLAN for the remote source mirroring group
mirroring-group group-id remote-probe vlan remote-probe-vlan-id
Required
When configuring the source switch, note that:
l          All ports of a remote source mirroring group are on the same device. Each remote source mirroring group can be configured with only one reflector port.
l          The reflector port cannot be a member port of an existing mirroring group, a member port of an aggregation group, or a port enabled with LACP or STP. It must be an access port and cannot be configured with the functions like VLAN-VPN, port loopback detection, QoS, port security, and so on.
l          You cannot modify the duplex mode, port rate, and MDI attribute of a reflector port.
l          Only an existing static VLAN can be configured as the remote-probe VLAN. To remove a remote-probe VLAN, you need to restore it to a normal VLAN first. A remote port mirroring group gets invalid if the corresponding remote port mirroring VLAN is removed.
l          Do not configure a port connecting the intermediate switch or destination switch as the mirroring source port. Otherwise, traffic disorder may occur in the network.
Configuration on the device acting as an intermediate switch
l          The trunk ports and the remote-probe VLAN are determined.
Follow these steps to configure the intermediate switch:
To do…
Use the command…
Remarks
Enter system view
Create a VLAN and enter VLAN view
vlan vlan-id
Required
Enter the view of the Ethernet port connecting to the source switch, destination switch or other intermediate switch
Required
Required
Configuration on the device acting as a destination switch
l          The destination port and the remote-probe VLAN are determined.
Follow these steps to configure remote port mirroring on the destination switch:
To do…
Use the command…
Remarks
Enter system view
vlan vlan-id
Configure the current VLAN as a remote-probe VLAN
Required
Enter the view of the Ethernet port connecting to the source switch or an intermediate switch
Required
Configure trunk port to permit packets from the remote-probe VLAN
Required
Create a remote destination mirroring group
mirroring-group group-id remote-destination
Required
Configure the destination port for the remote destination mirroring group
Required
Configure the remote-probe VLAN for the remote destination mirroring group
Required
When configuring a destination switch, note that:
l          The destination port of remote port mirroring cannot be a member port of an existing mirroring group, a member port of an aggregation group, or a port enabled with LACP or STP.
l          The MAC address specified for MAC-based mirroring must be a static MAC address existing in the MAC address table.
l          You can configure MAC-based mirroring for a remote source mirroring group to implement the MAC-based remote mirroring function.
l          The MAC address to be matched is determined.
Follow these steps to configure MAC-based mirroring:
To do…
Use the command…
Remarks
Enter system view
Create a local or remote source mirroring group
mirroring-group group-id { local | remote-source }
Required
mirroring-group group-id mirroring-mac mac vlan vlan-id
Required
Configure the destination port for the mirroring group
Required
Note that you need not configure the destination port on the source switch when configuring MAC-based remote mirroring.
Configuration example
Configure MAC-based mirroring to mirror packets whose source/destination MAC addresses match 000f-e20f-0101 to port GigabitEthernet 1/0/2 on the local device.
Configuration procedure:
<device> system-view
[device] mac-address static 000f-e20f-0101 interface Gigabitethernet 1/0/1 vlan 2
[device] mirroring-group 1 local
[device] mirroring-group 1 mirroring-mac 000f-e20f-0101 vlan 2
[device] mirroring-group 1 monitor-port GigabitEthernet 1/0/2
You can configure VLAN-based mirroring for a remote source mirroring group to implement the VLAN-based remote mirroring function.
l          The VLAN to be monitored is determined.
Follow these steps to configure VLAN-based mirroring:
To do…
Use the command…
Remarks
Enter system view
Required
mirroring-group group-id mirroring-vlan vlan-id inbound
Required
Required
Note that you need not configure the destination port on the source switch when configuring VLAN-based remote mirroring.
Configure VLAN-based mirroring to mirror packets received on all ports in VLAN 2 to port GigabitEthernet 1/0/2 on the local device.
[device] mirroring-group 1 mirroring-vlan 2 inbound
Displaying and Maintaining Port Mirroring
To do…
Use the command…
Remarks
Display the information of a mirroring group.
display mirroring-group { group-id | all | local | remote-destination | remote-source }
Available in any view
Mirroring Configuration Example
Local Port Mirroring Configuration Example
Network requirements
The departments of a company connect to each other through switches, as shown in Figure 1-3:
l          Research and Development (R&D) department is connected to Switch C through GigabitEthernet 1/0/1.
l          Marketing department is connected to Switch C through GigabitEthernet 1/0/2.
l          Data detection device is connected to Switch C through GigabitEthernet 1/0/3
The administrator wants to monitor the packets received on and sent from the R&D department and the marketing department through the data detection device.
Use the local port mirroring function to meet the requirement. Perform the following configurations on Switch C.
l          Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 as mirroring source ports.
l          Configure GigabitEthernet 1/0/3 as the mirroring destination port.
Figure 1-3 Network diagram for local port mirroring
Configure Switch C:
# Create a local mirroring group.
# Configure the source ports and destination port for the local mirroring group.
[device] mirroring-group 1 mirroring-port GigabitEthernet 1/0/1 GigabitEthernet 1/0/2 both
[device] mirroring-group 1 monitor-port GigabitEthernet 1/0/3
# Display configuration information about local mirroring group 1.
[device] display mirroring-group 1
mirroring-group 1:
    type: local
    status: active
    mirroring port:
        GigabitEthernet1/0/1  both
        GigabitEthernet1/0/2  both
    mirroring mac:
    mirroring vlan:
    monitor port: GigabitEthernet1/0/3
After the configurations, you can monitor all packets received on and sent from the R&D department and the marketing department on the data detection device.
Remote Port Mirroring Configuration Example
The departments of a company connect to each other through switches, as shown in Figure 1-4:
l          Switch A, Switch B, and Switch C are WX3000 series devices.
l          Department 1 is connected to GigabitEthernet 1/0/1 of Switch A.
l          Department 2 is connected to GigabitEthernet 1/0/2 of Switch A.
l          GigabitEthernet 1/0/3 of Switch A connects to GigabitEthernet 1/0/1 of Switch B.
l          GigabitEthernet 1/0/2 of Switch B connects to GigabitEthernet 1/0/1 of Switch C.
l          The data detection device is connected to GigabitEthernet 1/0/2 of Switch C.
The administrator wants to monitor the packets sent from Department 1 and 2 through the data detection device.
Use the remote port mirroring function to meet the requirement. Perform the following configurations:
l          Use Switch A as the source switch, Switch B as the intermediate switch, and Switch C as the destination switch.
l          On Switch A, create a remote source mirroring group, configure VLAN 10 as the remote-probe VLAN, ports GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 as the source ports, and port GigabitEthernet 1/0/4 as the reflector port.
l          On Switch B, configure VLAN 10 as the remote-probe VLAN.
l          Configure GigabitEthernet 1/0/3 of Switch A, GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 of Switch B, and GigabitEthernet 1/0/1 of Switch C as trunk ports, allowing packets of VLAN 10 to pass.
l          On Switch C, create a remote destination mirroring group, configure VLAN 10 as the remote-probe VLAN, and configure GigabitEthernet 1/0/2 connected with the data detection device as the destination port.
Figure 1-4 Network diagram for remote port mirroring
1)        Configure the source switch (Switch A)
# Create remote source mirroring group 1.
[device] mirroring-group 1 remote-source
# Configure VLAN 10 as the remote-probe VLAN.
[device] vlan 10
[device-vlan10] remote-probe vlan enable
[device-vlan10] quit
# Configure the source ports, reflector port, and remote-probe VLAN for the remote source mirroring group.
[device] mirroring-group 1 mirroring-port GigabitEthernet 1/0/1 GigabitEthernet 1/0/2 inbound
[device] mirroring-group 1 reflector-port GigabitEthernet 1/0/4
[device] mirroring-group 1 remote-probe vlan 10
# Configure GigabitEthernet 1/0/3 as trunk port, allowing packets of VLAN 10 to pass.
[device] interface GigabitEthernet 1/0/3
[device-GigabitEthernet1/0/3] port link-type trunk
[device-GigabitEthernet1/0/3] port trunk permit vlan 10
[device-GigabitEthernet1/0/3] quit
# Display configuration information about remote source mirroring group 1.
mirroring-group 1:
    type: remote-source
    status: active
    mirroring port:
        GigabitEthernet1/0/1  inbound
        GigabitEthernet1/0/2  inbound
    mirroring mac:
    mirroring vlan:
    reflector port: GigabitEthernet1/0/4
    remote-probe vlan: 10
2)        Configure the intermediate switch (Switch B)
[device] vlan 10
# Configure GigabitEthernet 1/0/1 as the trunk port, allowing packets of VLAN 10 to pass.
[device] interface GigabitEthernet 1/0/1
[device-GigabitEthernet1/0/1] port link-type trunk
[device-GigabitEthernet1/0/1] port trunk permit vlan 10
[device-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/2 as the trunk port, allowing packets of VLAN 10 to pass.
[device] interface GigabitEthernet 1/0/2
[device-GigabitEthernet1/0/2] port link-type trunk
[device-GigabitEthernet1/0/2] port trunk permit vlan 10
3)        Configure the destination switch (Switch C)
# Create remote destination mirroring group 1.
[device] mirroring-group 1 remote-destination
[device] vlan 10
# Configure the destination port and remote-probe VLAN for the remote destination mirroring group.
# Display configuration information about remote destination mirroring group 1.
mirroring-group 1:
    type: remote-destination
    status: active
    monitor port: GigabitEthernet1/0/2
After the configurations, you can monitor all packets sent from Department 1 and 2 on the data detection device.
