H3C WX3000 Series Unified Switches Switching Engine Configuration Guide-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesConfigure & DeployConfiguration GuidesH3C WX3000 Series Unified Switches Switching Engine Configuration Guide-6W103
10-Port Isolation Configuration
10-Port Isolation Configuration 62.35 KB
l          The term switch used throughout this chapter refers to a switching device in a generic sense or the switching engine of a unified switch in the WX3000 series.
l          The sample output information in this manual was created on the WX3024. The output information on your device may vary.
Port Isolation Overview
Introduction to Port Isolation
Through the port isolation feature, you can add the ports to be controlled into an isolation group to isolate the Layer 2 data between each port in the isolation group. Thus, you can improve the network security and network in a more flexible way.
Currently, you can configure only one isolation group on a switch. The number of Ethernet ports an isolation group can accommodate is not limited.
The port isolation function is independent of VLAN configuration.
Follow these steps to add an Ethernet port to an isolation group:
To do…
Use the command…
Remarks
Enter system view
Enter Ethernet port view
interface interface-type interface-num
Add the Ethernet port to the isolation group
port isolate
Required
By default, an isolation group contains no port.
l          When a member port of an aggregation group is added to an isolation group, the other ports in the same aggregation group are added to the isolation group automatically.
l          When a member port of an aggregation group is deleted from an isolation group, the other ports in the same aggregation group are deleted from the isolation group automatically.
Displaying and Maintaining Port Isolation
To do…
Use the command…
Remarks
Display the information about the Ethernet ports added to the isolation group.
display isolate port
Available in any view
Port Isolation Configuration Example
Network requirements
As shown in Figure 1-1:
l          PC 2, PC 3 and PC 4 are connected to GigabitEthernet 1/0/2, GigabitEthernet 1/0/3, and GigabitEthernet 1/0/4.
l          The switch connects to the Internet through GigabitEthernet 1/0/1.
l          It is desired that PC 2, PC 3 and PC 4 cannot communicate with each other.
Figure 1-1 Network diagram for port isolation configuration
Configuration procedure
# Add GigabitEthernet 1/0/2, GigabitEthernet 1/0/3, and GigabitEthernet 1/0/4 to the isolation group.
<device> system-view
[device] interface GigabitEthernet1/0/2
[device-GigabitEthernet1/0/2] port isolate
[device-GigabitEthernet1/0/2] quit
[device] interface GigabitEthernet1/0/3
[device-GigabitEthernet1/0/3] port isolate
[device-GigabitEthernet1/0/3] quit
[device] interface GigabitEthernet1/0/4
[device-GigabitEthernet1/0/4] port isolate
[device-GigabitEthernet1/0/4] quit
[device]
# Display the information about the ports in the isolation group.
[device] display isolate port
 Isolated port(s) on UNIT 1:
 GigabitEthernet1/0/2, GigabitEthernet1/0/3, GigabitEthernet1/0/4
