H3C WX3000 Series Unified Switches Switching Engine Configuration Guide-6W103
HomeSupportWirelessWX3000 Series Unified SwitchesConfigure & DeployConfiguration GuidesH3C WX3000 Series Unified Switches Switching Engine Configuration Guide-6W103
36-PoE-PoE Profile Configuration
36-PoE-PoE Profile Configuration 100.44 KB
When configuring PoE, go to these sections for information you are interested in:
l          PoE Overview
l          PoE Configuration
l          PoE Configuration Example
The terms switching engine and Ethernet switch used throughout this documentation refer to a switching device in a generic sense or the switching engine of a unified switch in the WX3000 series.
PoE Overview
Introduction to PoE
Power over Ethernet (PoE)-enabled devices use twisted pairs through electrical ports to supply power to the remote powered devices (PD) in the network and implement power supply and data transmission simultaneously.
Advantages of PoE
l          Reliability: The centralized power supply provides backup convenience, unified management, and safety.
l          Easy connection: Network terminals only require an Ethernet cable, but no external power supply.
l          Standard: PoE conforms to the 802.3af standard and uses a globally uniform power interfaces;
l          Bright application prospect: PoE can be applied to IP phones, wireless access points (APs), chargers for portable devices, card readers, network cameras, and data collection system.
PoE components
PoE consists of three components: power sourcing equipment (PSE), PD, and power interface (PI).
l          PSE: PSE is comprised of the power and the PSE functional module. It can implement PD detection, PD power information collection, PoE, power supply monitoring, and power-off for devices.
l          PD: PDs receive power from the PSE. PDs include standard PDs and nonstandard PDs. Standard PDs conform to the 802.3af standard, including IP phones, Wireless APs, network cameras and so on.
l          PI: PIs are RJ45 interfaces which connect PSE/PDs to network cables.
PoE Features Supported by the Device
Table 1-1 Power supply parameters of PoE device
Device
Input power supply
Number of electrical ports supplying power
Maximum PoE distance
Maximum power provided by each electrical port
Total Maximum PoE output power
WX3024
DC input
24
100 m (328.08 ft.)
25 W
600 W
AC input
370 W
WX3010
DC input
8
100 m (328.08 ft.)
25 W
125 W
WX3008
DC input
4
100 m (328.08 ft.)
25 W
125 W
A PoE-enabled device has the following features:
l          As the PSE, it supports the IEEE802.3af standard. It can also supply power to some PDs that do not support the 802.3af standard.
l          It can deliver data and current simultaneously through data wires (1,2,3,6) of category-3/5 twisted pairs.
l          The PSE processing software on the device can be upgraded online.
l          The device provides statistics about power supplying on each port and the whole equipment, which you can query through the display command.
l          The device provides two modes (auto and manual) to manage the power feeding to ports in the case of PSE power overload.
l          The device provides over-temperature protection mechanism. When the internal temperature of the device exceeds the PoE protection temperature, the device disables the PoE feature on all ports for self-protection.
l          The device supports the PoE profile feature, that is, different PoE policies can be set for different user groups. These PoE policies are each saved in the corresponding PoE profile and applied to ports of the user groups.
l          When you use the PoE-enabled device to supply power, the PDs need no external power supply.
l          If a remote PD has an external power supply, the PoE-enabled device and the external power supply will backup each other for the PD.
l          Only the Ethernet electrical ports of the PoE-enabled device support the PoE feature.
PoE Configuration
PoE Configuration Task List
Complete the following tasks to configure PoE:
Remarks
Enabling the PoE Feature on a Port
Required
Setting the Maximum Output Power on a Port
Optional
Setting PoE Management Mode and PoE Priority of a Port
Optional
Setting the PoE Mode on a Port
Optional
Configuring the PD Compatibility Detection Function
Optional
Upgrading the PSE Processing Software Online
Optional
Displaying and Maintaining PoE Configuration
Optional
Follow these steps to enable the PoE feature on a port:
To do…
Use the command…
Remarks
Enter system view
Enter Ethernet port view
Enable the PoE feature on a port
poe enable
Required
l          By default, the PoE function on a port is enabled by the default configuration file when the device is delivered.
l          If you delete the default configuration file without specifying another one, the PoE function on a port will be disabled after you restart the device.
The maximum power that can be supplied by each Ethernet electrical port of a PoE-enabled device to its PD is 25,000 mW. In practice, you can set the maximum power on a port depending on the actual power of the PD, in the range of 1,000 to 25,000 mW and in the granularity of 1 mW.
Follow these steps to set the maximum output power on a port:
To do…
Use the command…
Remarks
Enter system view
Set the maximum output power on the port
poe max-power max-power
Required
25,000 mW by default.
When the device is close to its full load in supplying power, you can adjust the power supply of the device through the cooperation of the PoE management mode and the port PoE priority settings. The device supports two PoE management modes, auto and manual. The auto mode is adopted by default.
l          auto: When the device is close to its full load in supplying power, it will first supply power to the PDs that are connected to the ports with critical priority, and then supply power to the PDs that are connected to the ports with high priority. For example: Port A has the priority of critical. When the device PoE is close to its full load and a new PD is now added to port A, the device will power down the PD connected to the port with the lowest priority and turn to supply power to this new PD. If more than one port has the same lowest priority, the device will power down the PD connected to the port with larger port number.
l          manual: When the device is close to its full load in supplying power, it will not make change to its original power supply status based on its priority when a new PD is added. For example: Port A has the priority critical. When the device PoE is close to its full load and a new PD is now added to port A, the device just gives a prompt that a new PD is added and will not supply power to this new PD.
After the PoE feature is enabled on the port, perform the following configuration to set the PoE management mode and PoE priority of a port.
Follow these steps to set the PoE management mode and PoE priority of a port:
To do…
Use the command…
Remarks
Enter system view
Set the PoE management mode for the device
poe power-management { auto | manual }
Required
auto by default.
Se the PoE priority of a port
poe priority { critical | high | low }
Required
low by default.
PoE mode of a port falls into two types, signal mode and spare mode.
l          Signal mode: DC power is carried over the data pairs (1,2,3,6) of category-3/5 twisted pairs.
l          Spare mode: DC power is carried over the spare pairs (4,5,7,8) of category-3/5 twisted pairs.
Currently, the device does not support the spare mode.
After the PoE feature is enabled on the port, perform the following configuration to set the PoE mode on a port.
Follow these steps to set the PoE mode on a port:
To do…
Use the command…
Remarks
Enter system view
Set the PoE mode on the port to signal
poe mode signal
Optional
signal by default.
After the PD compatibility detection function is enabled, the device can detect the PDs that do not conform to the 802.3af standard and supply power to them.
After the PoE feature is enabled, perform the following configuration to enable the PD compatibility detection function.
Follow these steps to configure the PD compatibility detection function:
To do…
Use the command…
Remarks
Enter system view
Enable the PD compatibility detection function
poe legacy enable
Required
Disabled by default.
The online upgrading of PSE processing software can update the processing software or repair the software if it is damaged. Before performing the following configuration, download the PSE processing software to the flash of the device .
Follow these steps to upgrade PSE processing software online:
To do…
Use the command…
Remarks
Enter system view
Upgrade the PSE processing software online
poe update { refresh | full } filename
Required
The specified PSE processing software is a file with the extension .s19.
l          In the case that the PSE processing software is damaged (that is, no PoE command can be executed successfully), use the full update mode to upgrade and thus restore the software.
l          The refresh update mode is to upgrade the original processing software in the PSE through refreshing the software, while the full update mode is to delete the original processing software in PSE completely and then reload the software.
l          Generally, the refresh update mode is used to upgrade the PSE processing software.
l          When the online upgrading procedure is interrupted for some unexpected reason (for example, the device restarts due to some errors), if the upgrade in full mode fails after restart, you must upgrade in full mode after power-off and restart of the device, and then restart the device manually. In this way, the former PoE configuration is restored.
To do…
Use the command…
Remarks
Display the PoE status of a specific port or all ports of the device
display poe interface [ interface-type interface-number ]
Available in any view
Display the PoE power information of a specific port or all ports of the device
display poe interface power [ interface-type interface-number ]
Display the PSE parameters
display poe powersupply
Networking requirements
As shown in Figure 1-1, Switch A supports PoE, Switch B can be PoE powered.
l          The GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 ports of Switch A are connected to Switch B and an AP respectively; the GigabitEthernet 1/0/8 port is intended to be connected with an important AP.
l          The PSE processing software of Switch A is first upgraded online. The remotely accessed PDs are powered by Switch A.
l          The power consumption of the accessed AP is 2,500 mW, and the maximum power consumption of Switch B is 12,000 mW.
l          It is required to guarantee the power feeding to the PDs connected to the GigabitEthernet 1/0/8 port even when Switch A is under full load.
Figure 1-1 Network diagram for PoE
Configuration procedure
# Upgrade the PSE processing software online.
[SwitchA] poe update refresh 0290_021.s19
# Enable the PoE feature on GigabitEthernet 1/0/1, and set the PoE maximum output power of GigabitEthernet 1/0/1 to 12,000 mW.
[SwitchA] interface GigabitEthernet 1/0/1
[SwitchA-GigabitEthernet1/0/1] poe enable
[SwitchA-GigabitEthernet1/0/1] poe max-power 12000
[SwitchA-GigabitEthernet1/0/1] quit
# Enable the PoE feature on GigabitEthernet 1/0/2, and set the PoE maximum output power of GigabitEthernet 1/0/2 to 2500 mW.
[SwitchA] interface GigabitEthernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] poe enable
[SwitchA-GigabitEthernet1/0/2] poe max-power 2500
[SwitchA-GigabitEthernet1/0/2] quit
# Enable the PoE feature on GigabitEthernet 1/0/8, and set the PoE priority of GigabitEthernet 1/0/8 to critical.
[SwitchA] interface GigabitEthernet 1/0/8
[SwitchA-GigabitEthernet1/0/8] poe enable
[SwitchA-GigabitEthernet1/0/8] poe priority critical
[SwitchA-GigabitEthernet1/0/8] quit
# Set the PoE management mode on the device to auto (it is the default mode, so this step can be omitted).
[SwitchA] poe power-management auto
# Enable the PD compatibility detect of the device to allow the device to supply power to part of the devices noncompliant with the 802.3af standard.
[SwitchA] poe legacy enable
Introduction to PoE Profile
On a large-sized network or a network with mobile users, to help network administrators to monitor the PoE features of the device, the device provides the PoE profile features. A PoE profile is a set of PoE configurations, including multiple PoE features.
Features of PoE profile:
l          Various PoE profiles can be created. PoE policy configurations applicable to different user groups are stored in the corresponding PoE profiles. These PoE profiles can be applied to the ports used by the corresponding user groups.
l          When users connect a PD to a PoE-profile-enabled port, the PoE configurations in the PoE profile will be enabled on the port.
Configuring PoE Profile
Follow these steps to configure PoE profile:
To do…
Use the command…
Remarks
Enter system view
Create a PoE profile and enter PoE profile view
poe-profile profilename
Required
If the PoE file is created, you will enter PoE profile view directly through the command.
Configure the relevant features in PoE profile
poe enable
Required
Configure PoE mode for Ethernet ports
poe mode { signal | spare }
Optional
signal by default.
Configure the PoE priority for Ethernet ports
Optional
low by default.
Configure the maximum power for Ethernet ports
Optional
15,400 mW by default.
Quit system view
Apply the existing PoE profile to the specified Ethernet port
In system view
apply poe-profile profile-name interface interface-type interface-number [ to interface-type interface-number ]
Use either approach.
In Ethernet port view
Apply the existing PoE profile to the port
Note the following during the configuration:
1)        When the apply poe-profile command is used to apply a PoE profile to a port, some PoE features in the PoE profile can be applied successfully while some cannot. PoE profiles are applied to the devices according to the following rules:
l          When the apply poe-profile command is used to apply a PoE profile to a port, the PoE profile is applied successfully only if one PoE feature in the PoE profile is applied properly. When the display current-configuration command is used for query, it is displayed that the PoE profile is applied properly to the port.
l          If one or more features in the PoE profile are not applied properly on a port, the device will prompt explicitly which PoE features in the PoE profile are not applied properly on which ports.
l          The display current-configuration command can be used to query which PoE profile is applied to a port. However, the command cannot be used to query which PoE features in a PoE profiles are applied successfully.
2)        PoE profile configuration is a global configuration, and applies synchronously in the intelligent resilient framework (IRF) system.
3)        Combination of Unit creates a new Fabric. In the newly created Fabric, the PoE profile configuration of the Unit with the smallest Unit ID number will become the PoE profile configuration for the Fabric currently in use.
4)        Split of Fabric results in many new Fabrics. In each newly created Fabric, the PoE profile configuration of each Unit remains the same as it was before the split.
Displaying and Maintaining PoE Profile Configuration
To do…
Use the command…
Remarks
Display the detailed information about the PoE profiles created on the device
display poe-profile { all-profile | interface interface-type interface-number | name profile-name }
PoE Profile Configuration Example
PoE Profile Application Example
Network requirements
As shown in Figure 2-1, Switch A supports PoE.
GigabitEthernet 1/0/1 through GigabitEthernet 1/0/10 of Switch A are used by users of group A, who have the following requirements:
l          The PoE function can be enabled on all ports in use.
l          Signal mode is used to supply power.
l          The PoE priority for GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5 is Critical, whereas the PoE priority for GigabitEthernet 1/0/6 through GigabitEthernet 1/0/10 is High.
l          The maximum power for GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5 ports is 3,000 mW, whereas the maximum power for GigabitEthernet 1/0/6 through GigabitEthernet 1/0/10 is 15,400 mW.
Based on the above requirements, two PoE profiles are made for users of group A.
l          Apply PoE profile 1 for GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5;
l          Apply PoE profile 2 for GigabitEthernet 1/0/6 through GigabitEthernet 1/0/10.
Figure 2-1 PoE profile application
# Create Profile1, and enter PoE profile view.
[SwitchA] poe-profile Profile1
# In Profile1, add the PoE policy configuration applicable to GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5 ports for users of group A.
[SwitchA-poe-profile-Profile1] poe enable
[SwitchA-poe-profile-Profile1] poe mode signal
[SwitchA-poe-profile-Profile1] poe priority critical
[SwitchA-poe-profile-Profile1] poe max-power 3000
[SwitchA-poe-profile-Profile1] quit
# Display detailed configuration information for Profile1.
[SwitchA] display poe-profile name Profile1
Poe-profile: Profile1, 3 action
poe enable
poe max-power 3000
# Create Profile2, and enter PoE profile view.
[SwitchA] poe-profile Profile2
# In Profile2, add the PoE policy configuration applicable to GigabitEthernet 1/0/6 through GigabitEthernet 1/0/10 ports for users of group A.
[SwitchA-poe-profile-Profile2] poe enable
[SwitchA-poe-profile-Profile2] poe mode signal
[SwitchA-poe-profile-Profile2] poe priority high
[SwitchA-poe-profile-Profile2] poe max-power 15400
[SwitchA-poe-profile-Profile2] quit
# Display detailed configuration information for Profile2.
[SwitchA] display poe-profile name Profile2
Poe-profile: Profile2, 2 action
poe enable
poe priority high
# Apply the configured Profile1 to GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5 ports.
[SwitchA] apply poe-profile Profile1 interface GigabitEthernet1/0/1 to GigabitEthernet1/0/5
# Apply the configured Profile2 to GigabitEthernet 1/0/6 through GigabitEthernet 1/0/10 ports.
[SwitchA] apply poe-profile Profile2 interface GigabitEthernet1/0/6 to GigabitEthernet1/0/10
