02-Typical configuration example
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration ExamplesH3C CR16000-F Routers Configuration Examples All-In-One-R838x-6W10002-Typical configuration example
Table of Contents
Related Documents
32-MPLS_L2VPN_Configuration_Examples
32-MPLS_L2VPN_Configuration_Examples 228.53 KB
Introduction
This document provides MPLS L2VPN configuration examples.
MPLS L2VPN is an MPLS-based Layer 2 VPN technology. It can transparently transmit Layer 2 data for different data link layer protocols over an MPLS network.
MPLS L2VPN can be implemented through the following PWs:
·     LDP PWs.
·     BGP PWs.
This document assumes that you have basic knowledge of MPLS L2VPN.
Example: Configuring LDP PWs
As shown in Figure 1, the MPLS network provides L2VPN services for a customer. Configure LDP PWs between PE 1 and PE 2 so the R&D and Marketing departments use different VPN connections to achieve data isolation.
Figure 1 Network diagram
Analysis
To use LDP PWs to implement MPLS L2VPN, configure two levels of labels:
·     Inner labels—PW labels dynamically generated by LDP.
·     Outer labels—Public tunnel labels dynamically generated by LDP in this example.
To identify packets to be transported by MPLS L2VPN, configure subinterfaces on the CE-facing ports of PEs.
Procedures
1.     Configure OSPF on the MPLS backbone to ensure IP connectivity within the backbone:
# On PE 1, configure an IP address for Loopback 0.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
# On PE 1, configure an IP address for Ten-GigabitEthernet 3/1/2.
[PE1] interface Ten-GigabitEthernet 3/1/2
[PE1-Ten-GigabitEthernet3/1/2] ip address 10.1.1.1 24
[PE1-Ten-GigabitEthernet3/1/2] quit
# On PE 1, configure OSPF.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# On P, configure an IP address for Loopback 0.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
# On P, configure an IP address for Ten-GigabitEthernet 3/1/1.
[P] interface Ten-GigabitEthernet3/1/1
[P-Ten-GigabitEthernet3/1/1] ip address 10.1.2.1 24
[P-Ten-GigabitEthernet3/1/1] quit
# On P, configure an IP address for Ten-GigabitEthernet 3/1/2.
[P] interface Ten-GigabitEthernet3/1/2
[P-Ten-GigabitEthernet3/1/2] ip address 10.1.1.2 24
[P-Ten-GigabitEthernet3/1/2] quit
# On P, configure OSPF.
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# On PE 2, configure an IP address for Loopback 0.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
# On PE 2, configure an IP address for Ten-GigabitEthernet 3/1/2.
[PE2] interface Ten-GigabitEthernet 3/1/2
[PE2-Ten-GigabitEthernet3/1/2] ip address 10.1.2.2 24
[PE2-Ten-GigabitEthernet3/1/2] quit
# On PE 2, configure OSPF.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
2.     Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
# On PE 1, configure an LSR ID.
[PE1] mpls lsr-id 1.1.1.9
# On PE 1, enable LDP globally.
[PE1] mpls ldp
[PE1-ldp] quit
# On PE 1, enable MPLS and LDP on Ten-GigabitEthernet 3/1/2.
[PE1-Ten-GigabitEthernet 3/1/2] mpls enable
[PE1-Ten-GigabitEthernet 3/1/2] mpls ldp enable
[PE1-Ten-GigabitEthernet 3/1/2] quit
# On P, configure an LSR ID.
[P] mpls lsr-id 2.2.2.9
# On P, enable LDP globally.
[P] mpls ldp
[P-ldp] quit
# On P, enable MPLS and LDP on Ten-GigabitEthernet 3/1/1.
[P-Ten-GigabitEthernet3/1/1] mpls enable
# On P, enable MPLS and LDP on Ten-GigabitEthernet 3/1/2.
[P-Ten-GigabitEthernet3/1/2] mpls enable
# On PE 2, configure an LSR ID.
[PE2] mpls lsr-id 3.3.3.9
# On PE 2, enable LDP globally.
[PE2] mpls ldp
[PE2-ldp] quit
# On PE 2, enable MPLS and LDP on Ten-GigabitEthernet 3/1/2.
[PE2-Ten-GigabitEthernet3/1/2] mpls enable
[PE2-Ten-GigabitEthernet3/1/2] mpls ldp enable
3.     Configure a subinterface for each department and bind the subinterfaces to their respective VPN connections:
# On PE 1, enable MPLS L2VPN globally.
[PE1] l2vpn enable
# On PE 1, create subinterfaces Ten-GigabitEthernet 3/1/1.100 and Ten-GigabitEthernet 3/1/1.200.
[PE1] interface Ten-GigabitEthernet 3/1/1.100
[PE1-Ten-GigabitEthernet3/1/1.100] vlan-type dot1q vid 100
[PE1-Ten-GigabitEthernet3/1/1.100] quit
[PE1] interface Ten-GigabitEthernet 3/1/1.200
[PE1-Ten-GigabitEthernet3/1/1.200] vlan-type dot1q vid 200
[PE1-Ten-GigabitEthernet3/1/1.200] quit
# On PE 1, create cross-connect group vpna, create cross-connect ldp in the group, and bind Ten-GigabitEthernet3/1/1.100 to the cross-connect.
[PE1] xconnect-group vpna
[PE1-xcg-vpna] connection ldp
[PE1-xcg-vpna-ldp] ac interface Ten-GigabitEthernet 3/1/1.100
[PE1-xcg-vpna-ldp-Ten-GigabitEthernet3/1/1.100] quit
[PE1-xcg-vpna-ldp] peer 3.3.3.9 pw-id 100
[PE1-xcg-vpna-ldp-3.3.3.9-100] quit
[PE1-xcg-vpna-ldp] quit
[PE1-xcg-vpna] quit
# On PE 1, create cross-connect group vpnb, create cross-connect ldp in the group, and bind Ten-GigabitEthernet 3/1/1.200 to the cross-connect.
[PE1] xconnect-group vpnb
[PE1-xcg-vpnb] connection ldp
[PE1-xcg-vpnb-ldp] ac interface Ten-GigabitEthernet 3/1/1.200
[PE1-xcg-vpnb-ldp] peer 3.3.3.9 pw-id 200
[PE1-xcg-vpnb-ldp-3.3.3.9-200] quit
[PE1-xcg-vpnb-ldp] quit
[PE1-xcg-vpnb] quit
# On PE 2, enable MPLS L2VPN globally.
[PE2] l2vpn enable
# On PE 2, create subinterfaces Ten-GigabitEthernet 3/1/1.100 and Ten-GigabitEthernet 3/1/1.200.
[PE2] interface Ten-GigabitEthernet 3/1/1.100
[PE2-Ten-GigabitEthernet3/1/1.100] vlan-type dot1q vid 100
[PE2-Ten-GigabitEthernet3/1/1.100] quit
[PE2] interface Ten-GigabitEthernet 3/1/1.200
[PE2-Ten-GigabitEthernet3/1/1.200] vlan-type dot1q vid 200
[PE2-Ten-GigabitEthernet3/1/1.200] quit
# On PE 2, create cross-connect group vpna, create cross-connect ldp in the group, and bind Ten-GigabitEthernet 3/1/1.100 to the cross-connect.
[PE2] xconnect-group vpna
[PE2-xcg-vpna] connection ldp
[PE2-xcg-vpna-ldp] ac interface Ten-GigabitEthernet 3/1/1.100
[PE2-xcg-vpna-ldp-Ten-GigabitEthernet3/1/1.100] quit
# On PE 2, create an LDP PW for the cross-connect to bind the AC to the PW.
[PE2-xcg-vpna-ldp] peer 1.1.1.9 pw-id 100
[PE2-xcg-vpna-ldp-1.1.1.9-100] quit
[PE2-xcg-vpna-ldp] quit
[PE2-xcg-vpna] quit
# On PE 2, create cross-connect group vpnb, create cross-connect ldp in the group, and bind Ten-GigabitEthernet 3/1/1.200 to the cross-connect.
[PE2] xconnect-group vpnb
[PE2-xcg-vpnb] connection ldp
[PE2-xcg-vpnb-ldp] ac interface Ten-GigabitEthernet 3/1/1.200
[PE2-xcg-vpna-ldp-Ten-GigabitEthernet3/1/1.200] quit
[PE2-xcg-vpnb-ldp] peer 1.1.1.9 pw-id 200
[PE2-xcg-vpnb-ldp-1.1.1.9-200] quit
[PE2-xcg-vpnb-ldp] quit
[PE2-xcg-vpnb] quit
4.     Allow CE access to PEs:
# On CE 1, configure the interface connected to the PE to permit tagged packets from the customer VLANs.
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
[CE1] vlan 200
[CE1-vlan200] quit
[CE1] interface Ten-GigabitEthernet 3/1/1
[CE1-Ten-GigabitEthernet3/1/1] port link-type trunk
[CE1-Ten-GigabitEthernet3/1/1] port trunk permit vlan 100 200
# Configure other CEs in the same way that CE 1 is configured. (Details not shown.)
# Display L2VPN PW information on PE 1. The output shows that two LDP PWs have been established.
[PE1] display l2vpn pw
       N - no split horizon, A - administration, ABY – ac-bypass
       PBY – pw-bypass
Total number of PWs: 2
2 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
Xconnect-group Name: vpna
Peer            PWID/RmtSite/SrvID In/Out Label   Proto  Flag Link ID  State
3.3.3.9         100                65663/65663    LDP    M    1        Up
Xconnect-group Name: vpnb
3.3.3.9         200                65662/65662    LDP    M    1        Up
# Display L2VPN PW information on PE 2. The output shows that two LDP PWs have been established.
[PE2] display l2vpn pw
       PBY – pw-bypass
1.1.1.9         100                65663/65663    LDP    M    1        Up
1.1.1.9         200                65662/65662    LDP    M    1        Up
# Verify that the host and the server in the same VLAN can ping each other. (Details not shown.)
Configuration files
·     CE 1 and CE 2:
 vlan 100
 vlan 200
 port link-mode bridge
 port trunk permit vlan 1 100 200
·     PE 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
mpls ldp
 l2vpn enable
interface LoopBack0
 ip address 1.1.1.9 255.255.255.255
 port link-mode route
interface Ten-GigabitEthernet3/1/1.100
interface Ten-GigabitEthernet3/1/1.200
 mpls enable
 mpls ldp enable
xconnect-group vpna
 connection ldp
  ac interface Ten-GigabitEthernet3/1/1.100
xconnect-group vpnb
 connection ldp
  ac interface Ten-GigabitEthernet3/1/1.200
·     P:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
 ip address 2.2.2.9 255.255.255.255
 ip address 10.1.2.1 255.255.255.0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
·     PE 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
mpls ldp
 l2vpn enable
interface LoopBack0
 ip address 3.3.3.9 255.255.255.255
 ip address 10.1.2.2 255.255.255.0
 mpls enable
 mpls ldp enable
xconnect-group vpna
 connection ldp
xconnect-group vpnb
 connection ldp
Example: Configuring a BGP PW
As shown in Figure 2, a customer has two VPN sites and will add eight sites in the future. Configure a BGP PW between PE 1 and PE 2 to allow VPN communication between the two sites and reserve enough VPN resources for future extension.
Figure 2 Network diagram
Analysis
To use BGP PWs to implement MPLS L2VPN, configure two levels of labels:
·     Inner labels—PW labels dynamically generated by BGP.
To use BGP to transmit inner labels between PEs, create a subinterface and an IBGP connection, and specify the peer PE as a BGP peer on each PE.
To simplify configuration required by future expansion of the customer network, set the maximum number of CEs in the VPN to 10.
Procedures
<PE1> system-view
[PE1-Ten-GigabitEthernet 3/1/2] ip address 10.1.1.1 24
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
<P> system-view
[P-LoopBack0] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
<PE2> system-view
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# On PE 1, enable MPLS L2VPN and LDP globally.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
[P] mpls ldp
[P-ldp] quit
# On PE 2, enable MPLS L2VPN and LDP globally.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
3.     Establish IBGP connections between PEs:
# On PE 1, establish an IBGP connection to PE 2.
[PE1] bgp 100
# On PE 1, enable BGP to exchange L2VPN information with PE 2.
[PE1-bgp-default] address-family l2vpn
[PE1-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE1-bgp-default-l2vpn] quit
[PE1-bgp-default] quit
# On PE 1, create subinterface Ten-GigabitEthernet3/1/1.100, and configure the subinterface to terminate packets whose outermost VLAN ID is 100.
# On PE 1, create cross-connect group vpna, create local site site 1, and create a BGP PW from site 1 to the remote site site 2.
[PE1-xcg-vpna] auto-discovery bgp
[PE1-xcg-vpna-auto] route-distinguisher 2:2
[PE1-xcg-vpna-auto] vpn-target 2:2 export-extcommunity
[PE1-xcg-vpna-auto] vpn-target 2:2 import-extcommunity
[PE1-xcg-vpna-auto] site 1 range 10 default-offset 0
[PE1-xcg-vpna-auto-1] connection remote-site-id 2
# On PE 1, bind Ten-GigabitEthernet 3/1/1.100 to the PW.
[PE1-xcg-vpna-auto-1-2] ac interface Ten-GigabitEthernet 3/1/1.100
[PE1-xcg-vpna-auto-1-2] return
# On PE 2, establish an IBGP connection to PE 1.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
# On PE 2, enable BGP to exchange L2VPN information with PE 1.
[PE2-bgp-default] address-family l2vpn
[PE2-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE2-bgp-default-l2vpn] quit
[PE2-bgp-default] quit
# On PE 2, create subinterface Ten-GigabitEthernet 3/1/1.100, and configure the subinterface to terminate packets whose outermost VLAN ID is 100.
# On PE 2, create cross-connect group vpna, create local site site 2, and create a BGP PW from site 2 to the remote site site 1.
[PE2-xcg-vpna] auto-discovery bgp
[PE2-xcg-vpna-auto] route-distinguisher 2:2
[PE2-xcg-vpna-auto] vpn-target 2:2 export-extcommunity
[PE2-xcg-vpna-auto] vpn-target 2:2 import-extcommunity
[PE2-xcg-vpna-auto] site 2 range 10 default-offset 0
[PE2-xcg-vpna-auto-2] connection remote-site-id 1
# On PE 2, bind Ten-GigabitEthernet 3/1/1.100 to the PW.
[PE2-xcg-vpna-auto-2-1] ac interface Ten-GigabitEthernet 3/1/1.100
[PE2-xcg-vpna-auto-2-1] return
# On CE 1, configure the interface connected to the PE to permit tagged packets from the customer VLAN.
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
# Display L2VPN PW information on PE 1. The output shows that a BGP PW has been established.
<PE1> display l2vpn pw
       PBY – pw-bypass
Total number of PWs: 1
1 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
3.3.3.9         2                  65538/65537    BGP    M    1        Up
# Display L2VPN PW information on PE 2. The output shows that a BGP PW has been established.
<PE2> display l2vpn pw
       PBY – pw-bypass
1.1.1.9         1                  65537/65538    BGP    M    1        Up
# Verify that the host and the server can ping each other. (Details not shown.)
Configuration files
·     CE1 and CE2:
 vlan 100
·     PE1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
mpls ldp
 l2vpn enable
interface LoopBack0
 mpls enable
 mpls ldp enable
bgp 100
 peer 3.3.3.9 connect-interface LoopBack0
  peer 3.3.3.9 enable
xconnect-group vpna
 auto-discovery bgp
·     P:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
·     PE2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
mpls ldp
 l2vpn enable
interface LoopBack0
 mpls enable
 mpls ldp enable
bgp 100
 peer 1.1.1.9 connect-interface LoopBack0
  peer 1.1.1.9 enable
xconnect-group vpna
 auto-discovery bgp
Related documentation
·     H3C CR16000-F Routers MPLS Configuration Guide-R8385P09
·     H3C CR16000-F Routers MPLS Command Reference-R8385P09
