- 02-Typical configuration example
- 01-AAA_Configuration_Examples
- 02-ACL_Configuration_Examples
- 03-ATM_Configuration_Examples
- 04-IGMP_Configuration_Examples
- 05-IP_Source_Guard_Configuration_Examples
- 06-Ethernet_OAM_Configuration_Examples
- 07-NQA_Configuration_Examples
- 08-QinQ_Configuration_Examples
- 09-OSPF_Configuration_Examples
- 10-MPLS_TE_Configuration_Examples
- 11-OpenFlow_Configuration_Examples
- 12-NAT_Configuration_Examples
- 13-RBAC_Configuration_Examples
- 14-IRF_Configuration_Examples
- 15-POS_Interface_Configuration_Examples
- 16-CPOS_Interface_Configuration_Examples
- 17-DLDP_Configuration_Examples
- 18-IS-IS_Configuration_Examples
- 19-MPLS_L3VPN_Configuration_Examples
- 20-SSH_Configuration_Examples
- 21-Login_Management_Configuration_Examples
- 22-SNMP_Configuration_Examples
- 23-Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 24-Multicast_VPN_Configuration_Examples
- 25-BGP_Configuration_Examples
- 26-HoVPN_Configuration_Examples
- 27-L2TP_Configuration_Examples
- 28-VRRP_Configuration_Examples
- 29-Traffic_Filtering_Configuration_Examples
- 30-Samplers_and_IPv4_NetStream_Configuration_Examples
- 31-Software_Upgrade_Examples
- 32-MPLS_L2VPN_Configuration_Examples
- 33-NetStream_Configuration_Examples
- 34-Policy-Based_Routing_Configuration_Examples
- 35-Traffic_Policing_Configuration_Examples
- 36-BFD_Configuration_Examples
- 37-OSPFv3_Configuration_Examples
- 38-VPLS_Configuration_Examples
- 39-GTS_and_Rate_Limiting_Configuration_Examples
- 40-IPv6_IS-IS_Configuration_Examples
- 41-MPLS OAM_Configuration_Examples
- 42-BGP_Route_Selection_Configuration_Examples
- 43-IS-IS_Route_Summarization_Configuration_Examples
- 44-Attack_Protection_Configuration_Examples
| 14-IRF_Configuration_Examples | 177.48 KB |
General restrictions and guidelines
Example: Setting up a LACP MAD-enabled IRF fabric
Verifying the link backup function of multichassis aggregations
Verifying the link backup function of IRF connections
Introduction
This document provides examples for deploying two-chassis IRF fabrics.
This document assumes that you have basic knowledge of H3C IRF.
When you set up and configure an IRF fabric, follow the restrictions and guidelines in this section. For more information about IRF configuration restrictions and guidelines, see Virtual Technologies Configuration Guide for your devices.
Hardware requirements
To establish an IRF fabric successfully, make sure all member devices use the same MPU models.
To establish an IRF fabric successfully, make sure the member device models, their IRF physical interfaces, MPUs, and switching fabric modules meet the compatibility requirements in Table 1.
Table 1 Hardware compatibility matrix for IRF establishment
Hardware platform |
IRF members |
MPUs |
IRF physical interfaces |
Switching fabric module requirements |
CR16006-F CR16010-F CR16014-F CR16010H-F CR16018-F CR16010H-FA CR16018-FA |
All members are the same model. |
All member devices use same model MPUs. |
10-GE, 40-GE, or 100-GE Ethernet fiber ports on the following cards: · CSPEX-1304X · CSPEX-1404X · CSPEX-1504X · CSPEX-1602X · CSPEX-1804X · CSPEX-1612X · CEPC-XP24LX · CEPC-XP48RX · CEPC-CP4RX-L |
All member devices use same model switching fabric modules. |
Software requirements for IRF
All IRF member devices must run the same software image version. Make sure the software auto-update feature is enabled on all member devices.
IRF fabric size
This router series supports establish IRF fabrics that have a maximum of two member devices.
IRF port connection
When you connect neighboring IRF members, connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other (see Figure 1). On neighboring members, IRF ports with the same port index cannot have physical connections.
Figure 1 Connecting IRF physical interfaces
As shown in Figure 2:
· Use Device A and Device B to set up an IRF fabric at the core layer of the network.
· Use multichassis link aggregations to connect the IRF fabric to the access switches and the upstream egress routers.
· Use LACP MAD to detect IRF split.
· Run OSPF between the IRF fabric and the egress routers.
Table 2 VLAN and IP address assignment
Device |
VLAN interface |
IP address |
Router A |
VLAN-interface 30 |
172.24.2.2/24 |
VLAN-interface 40 |
172.24.40.2/24 |
VLAN-interface 50 |
172.24.1.2/24 |
Router B |
VLAN-interface 30 |
172.24.2.3/24 |
VLAN-interface 41 |
172.24.41.3/24 |
VLAN-interface 50 |
172.24.4.2/24 |
IRF fabric |
VLAN-interface 10 |
172.24.10.254/24 |
VLAN-interface 20 |
172.24.20.254/24 |
VLAN-interface 40 |
172.24.40.254/24 |
VLAN-interface 41 |
172.24.41.254/24 |
Analysis
For LACP MAD to run correctly, ensure that the intermediate device (SW 1 in this example) supports extended LACPDUs for LACP MAD.
To avoid single points of failure, use multichassis link aggregations to connect the IRF fabric to the downstream and upstream devices.
You do not need to run LACP MAD on all link aggregations. You can detect IRF split effectively by running LACP MAD on one dynamic link aggregation.
If you change the operating mode to IRF before binding IRF physical interfaces to IRF ports, use the following steps to ensure successful IRF setup:
1. Configure IRF port settings and other required settings.
2. Execute the save command to save the running configuration.
3. Execute the irf-port-configuration active command to activate the IRF port settings.
Procedures
Setting up the IRF fabric
1. Configure Device A:
# Assign member ID 1 to Device A.
[DeviceA] irf member 1
# Bind Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 to IRF-port 2.
[DeviceA] interface ten-gigabitethernet 3/1/1
[DeviceA-Ten-GigabitEthernet3/1/1] port link-mode bridge
[DeviceA-Ten-GigabitEthernet3/1/1] quit
[DeviceA] interface ten-gigabitethernet 3/1/2
[DeviceA-Ten-GigabitEthernet3/1/2] port link-mode bridge
[DeviceA-Ten-GigabitEthernet3/1/2] quit
[DeviceA] irf-port 2
[DeviceA-irf-port2] port group interface ten-gigabitethernet 3/1/1
[DeviceA-irf-port2] port group interface ten-gigabitethernet 3/1/2
[DeviceA-irf-port2] quit
# Save the running configuration to the main next-startup configuration file before changing the operating mode to IRF.
IMPORTANT: IRF mode change requires a system reboot. This step prevents the loss of unsaved settings upon system reboot. |
[DeviceA] save
# Enable IRF mode.
[DeviceA] chassis convert mode irf
The device will switch to IRF mode and reboot. Continue?[Y/N]:y
You are recommended to save the current running configuration and specify the configuration file for the next startup. Now save the running configuration to the next-startup configuration file? [Y/N]:y
Please input the file name(*.cfg)[cfa0:/test.cfg]
cfa0:/test.cfg exists, overwrite? [Y/N]:y
Do you want to convert the content of the next startup configuration file cfa0:/
test.cfg to make it available in IRF mode? [Y/N]:y
Now rebooting, please wait...
2. Configure Device B:
# Assign member ID 2 to Device B.
[DeviceB] irf member 2
# Bind Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 to IRF-port 1.
[DeviceB] interface ten-gigabitethernet 3/1/1
[DeviceB-Ten-GigabitEthernet3/1/1] port link-mode bridge
[DeviceB-Ten-GigabitEthernet3/1/1] quit
[DeviceB] interface ten-gigabitethernet 3/1/2
[DeviceB-Ten-GigabitEthernet3/1/2] port link-mode bridge
[DeviceB-Ten-GigabitEthernet3/1/2] quit
[DeviceB] irf-port 1
[DeviceB-irf-port1] port group interface ten-gigabitethernet 3/1/1
[DeviceB-irf-port1] port group interface ten-gigabitethernet 3/1/2
[DeviceB-irf-port1] quit
# Save the configuration.
[DeviceB] save
# Connect the physical interfaces of IRF-port 2 on Device A to the physical interfaces of IRF-port 1 on Device B, as shown in Figure 2. (Details not shown.)
# Enable IRF mode.
[DeviceB] chassis convert mode irf
Configuring software features
This example provides only basic software feature configuration.
Configuring the IRF fabric
After the IRF fabric is formed, the master's system name becomes the fabric's system name. You can configure software features on the fabric as you do on a standalone device.
1. Configure link aggregations:
# Create Layer 2 aggregate interface Bridge-Aggregation 1, set its mode to dynamic, and enable LACP MAD on the aggregate interface.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation1] mad enable
[Current domain is: 0]:
The assigned domain ID is: 0
MAD LACP only enable on dynamic aggregation interface.
[DeviceA-Bridge-Aggregation1] quit
# Assign the downlink ports that connect to SW 1 to the aggregation group of Bridge-Aggregation 1.
[DeviceA] interface ten-gigabitethernet 1/3/1/3
[DeviceA-Ten-GigabitEthernet1/3/1/3] port link-mode bridge
[DeviceA-Ten-GigabitEthernet1/3/1/3] port link-aggregation group 1
[DeviceA-Ten-GigabitEthernet1/3/1/3] quit
[DeviceA] interface ten-gigabitethernet 2/3/1/3
[DeviceA-Ten-GigabitEthernet2/3/1/3] port link-mode bridge
[DeviceA-Ten-GigabitEthernet2/3/1/3] port link-aggregation group 1
[DeviceA-Ten-GigabitEthernet2/3/1/3] quit
# Create Bridge-Aggregation 2 and assign the downlink ports that connect to SW 2 to the aggregation group.
[DeviceA] interface bridge-aggregation 2
[DeviceA-Bridge-Aggregation2] quit
[DeviceA] interface ten-gigabitethernet 1/3/1/4
[DeviceA-Ten-GigabitEthernet1/3/1/4] port link-mode bridge
[DeviceA-Ten-GigabitEthernet1/3/1/4] port link-aggregation group 2
[DeviceA-Ten-GigabitEthernet1/3/1/4] quit
[DeviceA] interface ten-gigabitethernet 2/3/1/4
[DeviceA-Ten-GigabitEthernet2/3/1/4] port link-mode bridge
[DeviceA-Ten-GigabitEthernet2/3/1/4] port link-aggregation group 2
[DeviceA-Ten-GigabitEthernet2/3/1/4] quit
# Create Bridge-Aggregation 1023 and assign the uplink ports that connect to Router A to Bridge-Aggregation 1023.
[DeviceA] interface bridge-aggregation 1023
[DeviceA-Bridge-Aggregation1023] quit
[DeviceA] interface ten-gigabitethernet 1/3/1/7
[DeviceA-Ten-GigabitEthernet1/3/1/7] port link-mode bridge
[DeviceA-Ten-GigabitEthernet1/3/1/7] port link-aggregation group 1023
[DeviceA-Ten-GigabitEthernet1/3/1/7] quit
[DeviceA] interface ten-gigabitethernet 2/3/1/7
[DeviceA-Ten-GigabitEthernet2/3/1/7] port link-mode bridge
[DeviceA-Ten-GigabitEthernet2/3/1/7] port link-aggregation group 1023
[DeviceA-Ten-GigabitEthernet2/3/1/7] quit
# Create Bridge-Aggregation 1024 and assign the uplink ports that connect to Router B to Bridge-Aggregation 1024.
[DeviceA] interface bridge-aggregation 1024
[DeviceA-Bridge-Aggregation1024] quit
[DeviceA] interface ten-gigabitethernet 1/3/1/8
[DeviceA-Ten-GigabitEthernet1/3/1/8] port link-mode bridge
[DeviceA-Ten-GigabitEthernet1/3/1/8] port link-aggregation group 1024
[DeviceA-Ten-GigabitEthernet1/3/1/8] quit
[DeviceA] interface ten-gigabitethernet 2/3/1/8
[DeviceA-Ten-GigabitEthernet2/3/1/8] port link-mode bridge
[DeviceA-Ten-GigabitEthernet2/3/1/8] port link-aggregation group 1024
[DeviceA-Ten-GigabitEthernet2/3/1/8] quit
2. Configure VLAN, IP address, and routing settings:
# Create VLAN 10, assign an IP address to VLAN-interface 10, and assign Bridge-Aggregation 1 (the interface connected to SW 1) to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 172.24.10.254 24
[DeviceA-Bridge-Aggregation1] port link-type trunk
[DeviceA-Bridge-Aggregation1] undo port trunk permit vlan 1
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10
# Create VLAN 20, assign an IP address to VLAN-interface 20, and assign Bridge-Aggregation 2 (the interface connected to SW 2) to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] quit
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] ip address 172.24.20.254 24
[DeviceA-Vlan-interface20] quit
[DeviceA-Bridge-Aggregation2] port link-type trunk
[DeviceA-Bridge-Aggregation2] undo port trunk permit vlan 1
[DeviceA-Bridge-Aggregation2] port trunk permit vlan 20
# Create VLAN 40, assign an IP address to VLAN-interface 40, and assign Bridge-Aggregation 1023 (the interface connected to Router A) to VLAN 40.
[DeviceA] vlan 40
[DeviceA-vlan40] quit
[DeviceA] interface vlan-interface 40
[DeviceA-Vlan-interface40] ip address 172.24.40.254 24
[DeviceA-Vlan-interface40] quit
[DeviceA-Bridge-Aggregation1023] port access vlan 40
# Create VLAN 41, assign an IP address to VLAN-interface 41, and assign Bridge-Aggregation 1024 (the interface connected to Router B) to VLAN 41.
[DeviceA] vlan 41
[DeviceA-vlan41] quit
[DeviceA] interface vlan-interface 41
[DeviceA-Vlan-interface41] ip address 172.24.41.254 24
[DeviceA-Vlan-interface41] quit
[DeviceA-Bridge-Aggregation1024] port access vlan 41
3. Configure OSPF between the IRF fabric and the egress routers.
[DeviceA] ospf
[DeviceA-ospf-1] import-route direct
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 172.24.40.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 172.24.41.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
Configuring SW 1
1. Configure a link aggregation:
# Create Bridge-Aggregation 1 and enable the dynamic aggregation mode. You must enable the dynamic aggregation mode because this link aggregation will be used for LACP MAD.
<SW1> system-view
[SW1] interface bridge-aggregation 1
[SW1-Bridge-Aggregation1] link-aggregation mode dynamic
[SW1-Bridge-Aggregation1] quit
# Assign the uplink ports that connect to the IRF fabric to Bridge-Aggregation 1.
[SW1] interface ten-gigabitethernet 4/0/1
[SW1-Ten-GigabitEthernet4/0/1] port link-aggregation group 1
[SW1-Ten-GigabitEthernet4/0/1] quit
[SW1] interface ten-gigabitethernet 4/0/2
[SW1-Ten-GigabitEthernet4/0/2] port link-aggregation group 1
[SW1-Ten-GigabitEthernet4/0/2] quit
2. Configure VLAN settings:
# Create all VLANs.
[SW1] vlan all
# Configure VLAN settings on the uplink aggregate interface that connects to the IRF fabric.
[SW1-Bridge-Aggregation1] port link-type trunk
[SW1-Bridge-Aggregation1] undo port trunk permit vlan 1
[SW1-Bridge-Aggregation1] port trunk permit vlan 10
# Configure VLAN settings on the port that connects to Server Group 1.
[SW1] interface gigabitethernet 3/0/1
[SW1-GigabitEthernet3/0/1] port link-type trunk
[SW1-GigabitEthernet3/0/1] port trunk permit vlan all
[SW1-GigabitEthernet3/0/1] undo port trunk permit vlan 1
[SW1-GigabitEthernet3/0/1] quit
Configuring SW 2
# Create Bridge-Aggregation 1.
<SW2>system-view
[SW2] interface bridge-aggregation 1
[SW2-Bridge-Aggregation1] quit
[SW2] interface ten-gigabitethernet 4/0/1
[SW2-Ten-GigabitEthernet4/0/1] port link-aggregation group 1
[SW2-Ten-GigabitEthernet4/0/1] quit
[SW2] interface ten-gigabitethernet 4/0/2
[SW2-Ten-GigabitEthernet4/0/2] port link-aggregation group 1
[SW2-Ten-GigabitEthernet4/0/2] quit
# Create all VLANs.
[SW2] vlan all
[SW2-Bridge-Aggregation1] port link-type trunk
[SW2-Bridge-Aggregation1] undo port trunk permit vlan 1
[SW2-Bridge-Aggregation1] port trunk permit vlan 20
# Configure VLAN settings on the port that connects to Server Group 2.
[SW2] interface gigabitethernet 3/0/1
[SW2-GigabitEthernet3/0/1] port link-type trunk
[SW2-GigabitEthernet3/0/1] port trunk permit vlan all
[SW2-GigabitEthernet3/0/1] undo port trunk permit vlan 1
[SW2-GigabitEthernet3/0/1] quit
Configuring Router A
This example provides only settings for connectivity to the IRF fabric. Settings for external connectivity are beyond the scope of this example.
# Create Bridge-Aggregation 1 and assign the downlink ports that connect to the IRF fabric to Bridge-Aggregation 1.
[RouterA] interface bridge-aggregation 1
[RouterA-Bridge-Aggregation1] quit
[RouterA] interface ten-gigabitethernet 4/0/1
[RouterA-Ten-GigabitEthernet4/0/1] port link-mode bridge
[RouterA-Ten-GigabitEthernet4/0/1] port link-aggregation group 1
[RouterA-Ten-GigabitEthernet4/0/1] quit
[RouterA] interface ten-gigabitethernet 2/0/1
[RouterA-Ten-GigabitEthernet2/0/1] port link-mode bridge
[RouterA-Ten-GigabitEthernet2/0/1] port link-aggregation group 1
[RouterA-Ten-GigabitEthernet2/0/1] quit
# Create Bridge-Aggregation 2 and assign the ports that connect to Router B to Bridge-Aggregation 2.
[RouterA] interface bridge-aggregation 2
[RouterA-Bridge-Aggregation2] quit
[RouterA] interface ten-gigabitethernet 4/0/2
[RouterA-Ten-GigabitEthernet4/0/2] port link-mode bridge
[RouterA-Ten-GigabitEthernet4/0/2] port link-aggregation group 2
[RouterA-Ten-GigabitEthernet4/0/2] quit
[RouterA] interface ten-gigabitethernet 2/0/2
[RouterA-Ten-GigabitEthernet2/0/2] port link-mode bridge
[RouterA-Ten-GigabitEthernet2/0/2] port link-aggregation group 2
[RouterA-Ten-GigabitEthernet2/0/2] quit
2. Configure VLAN, IP address, and internal routing protocol settings:
# Create VLAN 40, assign an IP address to VLAN-interface 40, and assign Bridge-Aggregation 1 (the interface connected to the IRF fabric) to VLAN 40.
[RouterA] vlan 40
[RouterA-vlan40] quit
[RouterA] interface vlan-interface 40
[RouterA-vlan-interface40] ip address 172.24.40.2 24
[RouterA-vlan-interface40] quit
[RouterA-Bridge-Aggregation1] port access vlan 40
# Create VLAN 30, assign an IP address to VLAN-interface 30, and assign Bridge-Aggregation 2 (the interface connected to Router B) to VLAN 30.
[RouterA] vlan 30
[RouterA-vlan30] quit
[RouterA] interface vlan-interface 30
[RouterA-vlan-interface30] ip address 172.24.2.2 24
[RouterA-vlan-interface30] quit
[RouterA-Bridge-Aggregation2] port link-type access
[RouterA-Bridge-Aggregation2] port access vlan 30
# Create VLAN 50, assign an IP address to VLAN-interface 50, and assign Ten-GigabitEthernet 4/0/3 (the interface connected to the external network) to VLAN 50.
[RouterA] vlan 50
[RouterA-vlan50] quit
[RouterA] interface vlan-interface 50
[RouterA-vlan-interface50] ip address 172.24.1.2 24
[RouterA-vlan-interface50] quit
[RouterA] interface ten-gigabitethernet 4/0/3
[RouterA-Ten-GigabitEthernet4/0/3] port link-mode bridge
[RouterA-Ten-GigabitEthernet4/0/3] port access vlan 50
[RouterA-Ten-GigabitEthernet4/0/3] quit
3. Configure OSPF between Router A and the IRF fabric.
[RouterA] ospf
[RouterA-ospf-1] import-route direct
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 172.24.40.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 172.24.2.0 0.0.0.255
[RouterA-ospf-1] quit
Configuring Router B
<RouterB> system-view
[RouterB] interface bridge-aggregation 1
[RouterB-Bridge-Aggregation1] quit
[RouterB] interface ten-gigabitethernet 4/0/1
[RouterB-Ten-GigabitEthernet4/0/1] port link-mode bridge
[RouterB-Ten-GigabitEthernet4/0/1] port link-aggregation group 1
[RouterB-Ten-GigabitEthernet4/0/1] quit
[RouterB] interface ten-gigabitethernet 2/0/1
[RouterB-Ten-GigabitEthernet2/0/1] port link-mode bridge
[RouterB-Ten-GigabitEthernet2/0/1] port link-aggregation group 1
[RouterB-Ten-GigabitEthernet2/0/1] quit
# Create Bridge-Aggregation 2 and assign the ports that connect to Router A to Bridge-Aggregation 2.
[RouterB] interface bridge-aggregation 2
[RouterB-Bridge-Aggregation2] quit
[RouterB] interface ten-gigabitethernet 4/0/2
[RouterB-Ten-GigabitEthernet4/0/2] port link-mode bridge
[RouterB-Ten-GigabitEthernet4/0/2] port link-aggregation group 2
[RouterB-Ten-GigabitEthernet4/0/2] quit
[RouterB] interface ten-gigabitethernet 2/0/2
[RouterB-Ten-GigabitEthernet2/0/2] port link-mode bridge
[RouterB-Ten-GigabitEthernet2/0/2] port link-aggregation group 2
[RouterB-Ten-GigabitEthernet2/0/2] quit
# Create VLAN 41, assign an IP address to VLAN-interface 41, and assign Bridge-Aggregation 1 (the interface connected to the IRF fabric) to VLAN 41.
[RouterB] vlan 41
[RouterB-vlan41] quit
[RouterB] interface vlan-interface 41
[RouterB-vlan-interface41] ip address 172.24.41.3 24
[RouterB-vlan-interface41] quit
[RouterB-Bridge-Aggregation1] port access vlan 41
# Create VLAN 30, assign an IP address to VLAN-interface 30, and assign Bridge-Aggregation 2 (the interface connected to Router A) to VLAN 30.
[RouterB] vlan 30
[RouterB-vlan30] quit
[RouterB] interface vlan-interface 30
[RouterB-vlan-interface30] ip address 172.24.2.3 24
[RouterB-vlan-interface30] quit
[RouterB-Bridge-Aggregation2] port link-type access
[RouterB-Bridge-Aggregation2] port access vlan 30
[RouterB] vlan 50
[RouterB-vlan50] quit
[RouterB] interface vlan-interface 50
[RouterB-vlan-interface50] ip address 172.24.4.3 24
[RouterB-vlan-interface50] quit
[RouterB] interface ten-gigabitethernet 4/0/3
[RouterB-Ten-GigabitEthernet4/0/3] port link-mode bridge
[RouterB-Ten-GigabitEthernet4/0/3] port access vlan 50
[RouterB-Ten-GigabitEthernet4/0/3] quit
3. Configure OSPF between Router B and the IRF fabric.
[RouterB] ospf
[RouterB-ospf-1] import-route direct
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 172.24.41.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 172.24.2.0 0.0.0.255
[RouterB-ospf-1] quit
Verifying the IRF function
# Verify that the IRF fabric has been established.
[DeviceA] display irf
MemberID Slot Role Priority CPU-Mac Description
*+1 0 Master 1 0210-fc01-0000 ---
2 0 Standby 1 0210-fc02-0000 ---
The Bridge MAC of the IRF is: 3822-d60f-2800
Auto upgrade : yes
Mac persistent : always
Domain ID : 0
Auto merge : yes
# Shut down Ten-GigabitEthernet 1/3/1/8, the port connected to the egress router.
[DeviceA-Ten-GigabitEthernet1/3/1/8] shutdown
# Ping an IP address on the public network from a PC in Server Group 1.
C:\Users>ping 202.108.22.5 -t
Pinging 202.108.22.5 with 32 bytes of data:
Reply from 202.108.22.5: bytes=32 time=1ms TTL=122
Reply from 202.108.22.5: bytes=32 time=13ms TTL=122
Reply from 202.108.22.5: bytes=32 time<1ms TTL=122
Request timed out.
Request timed out.
Request timed out.
The output shows that the address can be pinged after transient traffic disruption.
# Bring up Ten-GigabitEthernet 1/3/1/8 and shut down Ten-GigabitEthernet 2/3/1/8.
[DeviceA-Ten-GigabitEthernet1/3/1/8] undo shutdown
[DeviceA-Ten-GigabitEthernet2/3/1/8] shutdown
# Ping the IP address on the public network from the PC.
Request timed out.
Request timed out.
Request timed out.
# Verify that the IRF fabric does not split and can forward traffic across member chassis after one IRF connection cable is removed. (Details not shown.)
Configuration files
· IRF fabric:
irf mac-address persistent always
irf auto-update enable
irf auto-merge enable
undo irf link-delay
irf member 1 priority 1
irf member 2 priority 1
ospf 1
import-route direct
area 0.0.0.0
vlan 10
vlan 20
vlan 40
vlan 41
irf-port 1/2
port group interface Ten-GigabitEthernet1/3/1/1 mode enhanced
port group interface Ten-GigabitEthernet1/3/1/2 mode enhanced
irf-port 2/1
port group interface Ten-GigabitEthernet2/3/1/1 mode enhanced
port group interface Ten-GigabitEthernet2/3/1/2 mode enhanced
mad enable
port access vlan 40
port access vlan 41
ip address 172.24.10.254 255.255.255.0
ip address 172.24.20.254 255.255.255.0
ip address 172.24.40.254 255.255.255.0
ip address 172.24.41.254 255.255.255.0
interface Ten-GigabitEthernet 1/3/1/3
interface Ten-GigabitEthernet 1/3/1/4
interface Ten-GigabitEthernet 1/3/1/7
port access vlan 40
interface Ten-GigabitEthernet 1/3/1/8
port access vlan 41
interface Ten-GigabitEthernet 2/3/1/3
interface Ten-GigabitEthernet 2/3/1/4
interface Ten-GigabitEthernet 2/3/1/7
port access vlan 40
interface Ten-GigabitEthernet 2/3/1/8
port access vlan 41
· SW 1:
vlan 10
interface GigabitEthernet 3/0/1
port trunk permit vlan 2 to 4093
interface Ten-GigabitEthernet 4/0/1
interface Ten-GigabitEthernet 4/0/2
· SW 2:
vlan 20
· Router A:
ospf 1
import-route direct
area 0.0.0.0
vlan 30
vlan 40
vlan 50
port access vlan 40
port access vlan 30
ip address 172.24.2.2 255.255.255.0
ip address 172.24.40.2 255.255.255.0
ip address 172.24.1.2 255.255.255.0
interface Ten-GigabitEthernet 2/0/1
port access vlan 40
interface Ten-GigabitEthernet 2/0/2
port access vlan 30
port access vlan 40
port access vlan 30
interface Ten-GigabitEthernet 4/0/3
port access vlan 50
· Router B:
ospf 1
import-route direct
area 0.0.0.0
vlan 30
vlan 41
vlan 50
port access vlan 41
port access vlan 30
ip address 172.24.2.3 255.255.255.0
ip address 172.24.41.3 255.255.255.0
ip address 172.24.4.3 255.255.255.0
port access vlan 41
port access vlan 30
port access vlan 41
port access vlan 30
port access vlan 50
Related documentation
· H3C CR16000-F Routers Virtual Technologies Command Reference-R8385P09
· H3C CR16000-F Routers Virtual Technologies Configuration Guide-R8385P09
