- 03-IP Routing Volume
- 00-IP Routing Volume Organization
- 01-IP Routing Overview
- 02-Static Routing Configuration
- 03-RIP Configuration
- 04-OSPF Configuration
- 05-IS-IS Configuration
- 06-BGP Configuration
- 07-IPv6 Static Routing Configuration
- 08-IPv6 Ripng Configuration
- 09-IPv6 OSPFv3 Configuration
- 10-IPv6 IS-IS Configuration
- 11-IPv6 BGP Configuration
- 12-Routing Policy Configuration
| 11-IPv6 BGP Configuration | 257.74 KB |
Table of Contents
Configuring IPv6 BGP Basic Functions
Configuring a Preferred Value for Routes from a Peer/Peer Group
Specifying the Source Interface for Establishing TCP Connections
Allowing the establishment of a Non-Direct eBGP connection
Configuring a Description for an IPv6 Peer/Peer Group
Disabling Session Establishment to an IPv6 Peer/Peer Group
Logging IPv6 Peer/Peer Group State Changes
Controlling Route Distribution and Reception
Configuring IPv6 BGP Route Redistribution
Advertising a Default Route to an IPv6 Peer/Peer Group
Configuring Outbound Route Filtering
Configuring Inbound Route Filtering
Configuring IPv6 BGP and IGP Route Synchronization
Configuring IPv6 BGP Route Attributes
Configuring IPv6 BGP Preference and Default LOCAL_PREF and NEXT_HOP Attributes
Configuring the AS_PATH Attribute
Tuning and Optimizing IPv6 BGP Networks
Configuring IPv6 BGP Soft Reset
Configuring the Maximum Number of Load-Balanced Routes
Configuring a Large Scale IPv6 BGP Network
Configuring IPv6 BGP Peer Group
Configuring IPv6 BGP Community
Configuring an IPv6 BGP Route Reflector
Displaying and Maintaining IPv6 BGP
Resetting IPv6 BGP Connections
IPv6 BGP Configuration Examples
IPv6 BGP Route Reflector Configuration
Troubleshooting IPv6 BGP Configuration
No IPv6 BGP Peer Relationship Established
l The term “router” in this document refers to a router in a generic sense or a Layer 3 switch.
l This chapter describes only configuration for IPv6 BGP. For BGP related information, refer to BGP Configuration in the IP Routing Volume.
l EA boards (such as LSQ1GP12EA and LSQ1TGX1EA) do not support IPv6 features.
When configuring IPv6 BGP, go to these sections for information you are interested in:
l Configuring IPv6 BGP Basic Functions
l Controlling Route Distribution and Reception
l Configuring IPv6 BGP Route Attributes
l Tuning and Optimizing IPv6 BGP Networks
l Configuring a Large Scale IPv6 BGP Network
l Displaying and Maintaining IPv6 BGP
l IPv6 BGP Configuration Examples
l Troubleshooting IPv6 BGP Configuration
IPv6 BGP Overview
BGP-4 was designed to carry only IPv4 routing information, and thus other network layer protocols such as IPv6 are not supported.
To support multiple network layer protocols, IETF extended BGP-4 by introducing Multiprotocol BGP (MP-BGP), which is defined in RFC 2858 (multiprotocol extensions for BGP-4).
MP-BGP for IPv6 is referred to as IPv6 BGP for short.
IPv6 BGP puts IPv6 network layer information into the attributes of network layer reachable information (NLRI) and NEXT_HOP.
The NLRI attribute of IPv6 BGP involves:
l MP_REACH_NLRI: Multiprotocol Reachable NLRI, for advertising reachable route and next hop information.
l MP_UNREACH_NLRI: Multiprotocol Unreachable NLRI, for withdrawal of unreachable routes.
The NEXT_HOP attribute of IPv6 BGP is identified by an IPv6 unicast address or IPv6 local link address.
IPv6 BGP has the same messaging and routing mechanisms as BGP.
Configuration Task List
Complete the following tasks to configure IPv6 BGP:
Task |
Remarks |
Required |
Optional |
Configuring a Preferred Value for Routes from a Peer/Peer Group |
Optional |
Specifying the Source Interface for Establishing TCP Connections |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Configuring IPv6 BGP Preference and Default LOCAL_PREF and NEXT_HOP Attributes |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Before configuring this task, you need to:
l Specify IP addresses for interfaces.
l Enable IPv6.
You need create a peer group before configuring basic functions for it. For related information, refer to Configuring IPv6 BGP Peer Group.
Specifying an IPv6 BGP Peer
Follow these steps to configure an IPv6 BGP peer:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Specify a router ID |
router-id router-id |
Optional Required if no IP addresses are configured for any interfaces. |
Enter IPv6 address family view |
ipv6-family |
Specify an IPv6 peer and its AS number |
peer ipv6-address as-number as-number |
Required Not configured by default. |
Injecting a Local IPv6 Route
Follow these steps to configure advertise a local route into the routing table:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Inject a local route into the IPv6 BGP routing table |
network ipv6-address prefix-length [ short-cut | route-policy route-policy-name ] |
Required Not added by default |
Follow these steps to configure a preferred value for routes received from a peer/peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Configure a preferred value for routes received from an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } preferred-value value |
Optional By default, the preferred value is 0. |
If you both reference a routing policy and use the command peer { ipv6-group-name | ipv6-address } preferred-value value to set a preferred value for routes from a peer/peer group, the routing policy sets a non-zero preferred value for routes matching it. Other routes not matching the routing policy uses the value set with the command. If the preferred value in the routing policy is zero, the routes matching it will also use the value set with the command. For information about using a routing policy to set a preferred value, refer to the command peer { group-name | ipv4-address | ipv6-address } route-policy route-policy-name { import | export } in this document, and the command apply preferred-value preferred-value in Routing Policy Commands of the IP Routing Volume.
Follow these steps to specify the source interface for establishing TCP connections to a BGP peer or peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Specify the source interface for establishing TCP connections to an IPv6 BGP peer or peer group |
peer { ipv6-group-name | ipv6-address } connect-interface interface-type interface-number |
Required By default, IPv6 BGP uses the outbound interface of the best route to the IPv6 BGP peer or peer group as the source interface for establishing a TCP connection. |
l To improve stability and reliability, you can specify a loopback interface as the source interface for establishing TCP connections to a BGP peer. By doing so, a connection failure upon redundancy availability will not affect TCP connection establishment.
l To establish multiple BGP connections to a BGP router, you need to specify on the local router the respective source interfaces for establishing TCP connections to the peers on the peering BGP router; otherwise, the local BGP router may fail to establish TCP connections to the peers when using the outbound interfaces of the best routes as the source interfaces.
Follow these steps to allow the establishment of eBGP connection to a non-directly connected peer/peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Allow the establishment of eBGP connection to a non directly connected peer/peer group |
peer { ipv6-group-name | ipv6-address } ebgp-max-hop [ hop-count ] |
In general, direct links should be available between eBGP peers. If not, you can use the peer ebgp-max-hop command to establish a multi-hop TCP connection in between. However, you need not use this command for direct eBGP connections with loopback interfaces.
Follow these steps to configure description for an IPv6 peer/peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Configure a description for an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } description description-text |
Optional Not configured by default. |
The peer group to be configured with a description must have been created.
Follow these steps to disable session establishment to a peer/peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Disable session establishment to an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } ignore |
Optional Not disabled by default |
Follow these steps to configure to log on the session and event information of an IPv6 peer/peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
Enable logging of peer changes globally |
log-peer-change |
Optional Enabled by default. |
ipv6-family |
Enable the state change logging for an IPv6 peer or peer group |
peer { ipv6-group-name | ipv6-address } log-change |
Refer to BGP Commands in the IP Routing Volume for information about the log-peer-change command.
The task includes routing information filtering, routing policy application and route dampening.
l Enable IPv6
l Configure the IPv6 BGP basic functions
Follow these steps to configure IPv6 BGP route redistribution:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Enable default route redistribution into the IPv6 BGP routing table |
default-route imported |
Optional Not enabled by default. |
Enable route redistribution from another routing protocol |
import-route protocol [ process-id ] [ med med-value | route-policy route-policy-name ] * |
Required Not enabled by default. |
If the default-route imported command is not configured, using the import-route command cannot redistribute any IGP default route.
Follow these steps to advertise a default route to an IPv6 peer/peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Advertise a default route to an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } default-route-advertise [ route-policy route-policy-name ] |
Required Not advertised by default. |
With the peer default-route-advertise command executed, the local router advertises a default route with itself as the next hop to the specified IPv6 peer/peer group, regardless of whether the default route is available in the routing table.
Follow these steps to configure outbound route filtering:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Configure the filtering of outgoing routes |
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol process-id ] |
Apply a routing policy to routes advertised to an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } route-policy route-policy-name export |
Required Not applied by default. |
Specify an IPv6 ACL to filer routes advertised to an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } filter-policy acl6-number export |
Required Not specified by default. |
Specify an AS path ACL to filer routes advertised to an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } as-path-acl as-path-acl-number export |
Specify an IPv6 prefix list to filer routes advertised to an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } ipv6-prefix ipv6-prefix-name export |
IPv6 BGP advertises routes passing the specified policy to peers. Using the protocol argument can filter only the routes redistributed from the specified protocol. If no protocol is specified, IPv6 BGP filters all routes to be advertised, including redistributed routes and routes imported with the network command.
Follow these steps to configure inbound route filtering:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Configure inbound route filtering |
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import |
Apply a routing policy to routes from an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } route-policy route-policy-name import |
Specify an ACL to filter routes imported from an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } filter-policy acl6-number import |
Specify an AS path ACL to filter routing information imported from an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } as-path-acl as-path-acl-number import |
Specify an IPv6 prefix list to filter routing information imported from an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } ipv6-prefix ipv6-prefix-name import |
Specify the upper limit of prefixes allowed to receive from an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } route-limit limit [ percentage ] |
Optional Unlimited by default. |
l Only routes passing the configured filtering can be added into the local IPv6 BGP routing table.
l Members of a peer group can have different inbound route filtering policies.
With this feature enabled and when a non-BGP router is responsible for forwarding packets in an AS, IPv6 BGP speakers in the AS cannot advertise routing information to outside ASs unless all routers in the AS know the latest routing information.
By default, when a BGP router receives an iBGP route, it only checks the reachability of the route’s next hop before advertisement. If the synchronization feature is configured, only the iBGP route is advertised by IGP can the route be advertised to eBGP peers.
Follow these steps to configure IPv6 BGP and IGP route synchronization:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Enable route synchronization between IPv6 BGP and IGP |
synchronization |
Currently, the system does not support synchronization. Therefore, the configuration of this command does not actually take effect.
Configuring Route Dampening
Follow these steps to configure BGP route dampening:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Configure IPv6 BGP route dampening parameters |
dampening [ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ]* |
This section describes how to use IPv6 BGP route attributes to modify BGP routing policy. These attributes are:
l IPv6 BGP protocol preference
l Default LOCAL_PREF attribute
l MED attribute
l NEXT_HOP attribute
l AS_PATH attribute
Before configuring this task, you have:
l Enabled IPv6 function
l Configured IPv6 BGP basic functions
Follow these steps to perform this configuration:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Configure preference values for IPv6 BGP external, internal, local routes |
preference { external-preference internal-preference local-preference | route-policy route-policy-name } |
Optional The default preference values of external, internal and local routes are 255, 255, 130 respectively. |
Configure the default local preference |
default local-preference value |
Optional The value defaults to 100. |
Advertise routes to an IPv6 peer/peer group with the local router as the next hop |
peer { ipv6-group-name | ipv6-address } next-hop-local |
Required By default, IPv6 BGP specifies the local router as the next hop for routes sent to an IPv6 eBGP peer/peer group, but not for routes sent to an IPv6 iBGP peer/peer group. |
l To make sure an iBGP peer can find the correct next hop, you can configure routes advertised to the IPv6 iBGP peer/peer group to use the local router as the next hop. If BGP load balancing is configured, the local router specifies itself as the next hop of routes sent to an IPv6 iBGP peer/peer group regardless of whether the peer next-hop-local command is configured.
l In a “third party next hop" network, that is, the two IPv6 eBGP peers reside in a common broadcast subnet, the router does not specify itself as the next hop for routes sent to the IPv6 eBGP peer/peer group by default, unless the peer next-hop-local command is configured.
Configuring the MED Attribute
Follow these steps to configure the MED attribute:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Configure a default MED value |
default med med-value |
Optional Defaults to 0 |
Enable the comparison of MED for routes from different eBGP peers |
compare-different-as-med |
Enable the comparison of MED for routes from each AS |
bestroute compare-med |
Optional Disabled by default |
Enable the comparison of MED for routes from confederation peers |
bestroute med-confederation |
Follow these steps to configure the AS_PATH attribute:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Allow the local AS number to appear in AS_PATH of routes from a peer/peer group and specify the repeat times |
peer { ipv6-group-name | ipv6-address } allow-as-loop [ number ] |
Optional Not allowed by default |
Specify a fake AS number for an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } fake-as as-number |
Optional Not specified by default. |
Disable IPv6 MBGP from considering the AS_PATH during best route selection |
bestroute as-path-neglect |
Configure to carry only the public AS number in updates sent to a peer/peer group |
peer { ipv6-group-name | ipv6-address } public-as-only |
Optional By default, IPv6 BGP updates carry private AS number. |
Substitute the local AS number for the AS number of an IPv6 peer/peer group identified in the AS_PATH attribute |
peer { ipv6-group-name | ipv6-address } substitute-as |
Optional Not substituted by default |
This section describes configurations of IPv6 BGP timers, IPv6 BGP connection soft reset and the maximum number of load balanced routes.
l IPv6 BGP timers
After establishing an IPv6 BGP connection, two routers send keepalive messages periodically to each other to keep the connection. If a router receives no keepalive message from the peer after the holdtime elapses, it tears down the connection.
When establishing an IPv6 BGP connection, the two parties compare their holdtimes, taking the shorter one as the common holdtime. If the holdtime is 0, neither keepalive massage is sent, nor holdtime is checked.
l IPv6 BGP connection soft reset
After modifying a route selection policy, you have to reset IPv6 BGP connections to make the new one take effect, causing a short time disconnection. The current IPv6 BGP implementation supports the route-refresh feature that enables dynamic IPv6 BGP routing table refresh without needing to disconnect IPv6 BGP links.
With this feature enabled on all IPv6 BGP routers in a network, when a routing policy modified on a router, the router advertises a route-refresh message to its peers, which then send their routing information back to the router. Therefore, the local router can perform dynamic routing information update and apply the new policy without tearing down connections.
If a peer not supporting route-refresh exists in the network, you need to configure the peer keep-all-routes command on the router to save all routes from the peer. When the routing policy is changed, the system will update the IPv6 BGP routing table and apply the new policy.
Before configuring IPv6 BGP timers, you need to:
l Enable IPv6
l Configure IPv6 BGP basic functions
Configuring IPv6 BGP Timers
Follow these steps to configure IPv6 BGP timers:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Configure IPv6 BGP timers |
Specify keepalive interval and holdtime |
timer keepalive keepalive hold holdtime |
Optional The keepalive interval defaults to 60 seconds, holdtime defaults to 180 seconds. |
Configure keepalive interval and holdtime for an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } timer keepalive keepalive hold holdtime |
Configure the interval for sending the same update to an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } route-update-interval interval |
Optional The interval for sending the same update to an iBGP peer or an eBGP peer defaults to 15 seconds or 30 seconds |
l Timers configured using the timer command have lower priority than timers configured using the peer timer command.
l The holdtime interval must be at least three times the keepalive interval.
Enable route refresh
Follow these steps to enable route refresh:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Enable route refresh |
peer { ipv6-group-name | ipv6-address } capability-advertise route-refresh |
Perform manual soft-reset
Follow these steps to perform manual soft reset:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Save all routes from an IPv6 peer/peer group, not letting them go through the inbound policy |
peer { ipv6-group-name | ipv6-address } keep-all-routes |
Optional Not saved by default. |
Return to user view |
return |
Required |
Soft-reset BGP connections manually |
refresh bgp ipv6 { all | ipv6-address | group ipv6-group-name | external | internal } { export | import } |
If the peer keep-all-routes command is used, all routes from the peer/peer group will be saved regardless of whether the filtering policy is available. These routes will be used to generate IPv6 BGP routes after soft-reset is performed.
Follow these steps to configure the maximum number of load balanced routes:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Configure the maximum number of load balanced routes |
balance number |
Required By default, no load balancing is enabled. |
In a large-scale IPv6 BGP network, configuration and maintenance become no convenient due to too many peers. In this case, configuring peer groups makes management easier and improves route distribution efficiency. Peer group includes iBGP peer group, where peers belong to the same AS, and eBGP peer group, where peers belong to different ASs. If peers in an eBGP group belong to the same external AS, the eBGP peer group is a pure eBGP peer group, and if not, a mixed eBGP peer group.
In a peer group, all members enjoy a common policy. Using the community attribute can make a set of IPv6 BGP routers in multiple ASs enjoy the same policy, because sending of community between IPv6 BGP peers is not limited by AS.
To guarantee connectivity between iBGP peers, you need to make them fully meshed, but it becomes unpractical when there are too many iBGP peers. Using route reflectors or confederation can solve it. In a large-scale AS, both of them can be used.
Confederation configuration of IPv6 BGP is identical to that of BGP4, so it is not mentioned here. The following describes:
l Configuring IPv6 BGP peer groups
l Configuring IPv6 BGP community
l Configuring IPv6 BGP route reflectors
Before configuring IPv6 BGP peer groups, you need to:
l Make peer nodes accessible to each other at the network layer
l Enable BGP and configure a router ID.
Configuring an iBGP peer group
Follow these steps to configure an iBGP group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Create an iBGP peer group |
group ipv6-group-name [ internal ] |
Required |
Add a peer into the group |
peer ipv6-address group ipv6-group-name [ as-number as-number ] |
Creating a pure eBGP peer group
Follow these steps to configure a pure eBGP group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Create an eBGP peer group |
group ipv6-group-name external |
Required |
Configure the AS number for the peer group |
peer ipv6-group-name as-number as-number |
Add an IPv6 peer into the peer group |
peer ipv6-address group ipv6-group-name |
l To create a pure eBGP peer group, you need to specify an AS number for the peer group.
l If a peer was added into an eBGP peer group, you cannot specify any AS number for the peer group.
Creating a mixed eBGP peer group
Follow these steps to create a mixed eBGP peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Required |
Specify the AS number of an IPv6 peer |
Add the IPv6 peer into the peer group |
When creating a mixed eBGP peer group, you need to create a peer and specify its AS number that can be different from AS numbers of other peers, but you cannot specify AS number for the eBGP peer group.
Advertise community attribute to an IPv6 peer/peer group
Follow these steps to advertise community attribute to an IPv6 peer/peer group:
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Advertise community attribute to an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } advertise-community |
Advertise extended community attribute to an IPv6 peer/peer group |
peer { ipv6-group-name | ipv6-address } advertise-ext-community |
Apply a routing policy to routes advertised to a peer/peer group
Follow these steps to apply a routing policy to routes advertised to a peer/peer group:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
l When configuring IPv6 BGP community, you need to configure a routing policy to define the community attribute, and apply the routing policy to route advertisement.
l For routing policy configuration, refer to Routing Policy Configuration in the IP Routing Volume.
Follow these steps to configure an IPv6 BGP route reflector:
Use the command… |
Remarks |
Enter system view |
system-view |
Enter BGP view |
bgp as-number |
ipv6-family |
Configure the router as a route reflector and specify an IPv6 peer/peer group as a client |
peer { ipv6-group-name | ipv6-address } reflect-client |
Enable route reflection between clients |
reflect between-clients |
Configure the cluster ID of the route reflector |
reflector cluster-id cluster-id |
Optional By default, a route reflector uses its router ID as the cluster ID |
l In general, since the route reflector forwards routing information between clients, it is not required to make clients of a route reflector fully meshed. If clients are fully meshed, it is recommended to disable route reflection between clients to reduce routing costs.
l If a cluster has multiple route reflectors, you need to specify the same cluster ID for these route reflectors to avoid routing loops.
Displaying BGP
To do… |
Use the command… |
Remarks |
Display IPv6 BGP peer group information |
display bgp ipv6 group [ ipv6-group-name ] |
Available in any view |
Display IPv6 BGP advertised routing information |
display bgp ipv6 network |
Display IPv6 BGP AS path information |
display bgp ipv6 paths [ as-regular-expression ] |
Display IPv6 BGP peer/peer group information |
display bgp ipv6 peer [ group-name log-info | ipv4-address verbose | ipv6-address { log-info | verbose } | verbose ] |
Display IPv6 BGP routing table information |
display bgp ipv6 routing-table [ ipv6-address prefix-length ] |
Display IPv6 BGP routing information matching an AS path ACL |
display bgp ipv6 routing-table as-path-acl as-path-acl-number |
Display IPv6 BGP routing information with the specified community attribute |
display bgp ipv6 routing-table community [ aa:nn<1-13> ] [ no-advertise | no-export | no-export-subconfed ]* [ whole-match ] |
Display IPv6 BGP routing information matching an IPv6 BGP community list |
display bgp ipv6 routing-table community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16> |
Display dampened IPv6 BGP routing information |
Display IPv6 BGP dampening parameter information |
display bgp ipv6 routing-table dampening parameter |
Display IPv6 BGP routing information originated from different ASs |
display bgp ipv6 routing-table different-origin-as |
Display IPv6 BGP routing flap statistics |
display bgp ipv6 routing-table flap-info [ regular-expression as-regular-expression | as-path-acl as-path-acl-number | network-address [ prefix-length [ longer-match ] ] ] |
Display BGP routing information to or from an IPv4 or IPv6 peer |
display bgp ipv6 routing-table peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ network-address prefix-length | statistic ] |
Display IPv6 BGP routing information matching a regular expression |
display bgp ipv6 routing-table regular-expression as-regular-expression |
Display IPv6 BGP routing statistics |
display bgp ipv6 routing-table statistic |
To do… |
Use the command… |
Remarks |
Perform soft reset on IPv6 BGP connections |
refresh bgp ipv6 { ipv4-address | ipv6-address | all | external | group ipv6-group-name | internal } { export | import } |
Available in user view |
Reset IPv6 BGP connections |
reset bgp ipv6 { as-number | ipv4-address | ipv6-address [ flap-info ] | all | group group-name | external | internal } |
Clearing IPv6 BGP Information
To do… |
Use the command… |
Remarks |
Clear dampened IPv6 BGP routing information and release suppressed routes |
reset bgp ipv6 dampening [ ipv6-address prefix-length ] |
Clear IPv6 BGP route flap information |
reset bgp ipv6 flap-info [ ipv6-address/prefix-length | regexp as-path-regexp | as-path-acl as-path-acl-number ] |
Some examples for IPv6 BGP configuration are similar to those of BGP4, so refer to BGP Configuration in the IP Routing Volume for related information.
IPv6 BGP Basic Configuration
Network requirements
In the following figure are all IPv6 BGP switches. Between Switch A and Switch B is an eBGP connection. Switch B, Switch C and Switch D are fully meshed through iBGP connections.
Network diagram
Figure 1-1 IPv6 BGP basic configuration network diagram
Configuration procedure
1) Configure IPv6 addresses for interfaces (omitted)
2) Configure iBGP connections
# Configure Switch B.
[SwitchB] ipv6
[SwitchB] bgp 65009
[SwitchB-bgp] router-id 2.2.2.2
[SwitchB-bgp] ipv6-family
[SwitchB-bgp-af-ipv6] peer 9:1::2 as-number 65009
[SwitchB-bgp-af-ipv6] peer 9:3::2 as-number 65009
[SwitchB-bgp-af-ipv6] quit
[SwitchB-bgp] quit
# Configure Switch C.
[SwitchC] ipv6
[SwitchC] bgp 65009
[SwitchC-bgp] router-id 3.3.3.3
[SwitchC-bgp] ipv6-family
[SwitchC-bgp-af-ipv6] peer 9:3::1 as-number 65009
[SwitchC-bgp-af-ipv6] peer 9:2::2 as-number 65009
[SwitchC-bgp-af-ipv6] quit
[SwitchC-bgp] quit
# Configure Switch D.
<SwitchD> system-view
[SwitchD] ipv6
[SwitchD] bgp 65009
[SwitchD-bgp] router-id 4.4.4.4
[SwitchD-bgp] ipv6-family
[SwitchD-bgp-af-ipv6] peer 9:1::1 as-number 65009
[SwitchD-bgp-af-ipv6] peer 9:2::1 as-number 65009
[SwitchD-bgp-af-ipv6] quit
[SwitchD-bgp] quit
3) Configure the eBGP connection
# Configure Switch A.
[SwitchA] ipv6
[SwitchA] bgp 65008
[SwitchA-bgp] router-id 1.1.1.1
[SwitchA-bgp] ipv6-family
[SwitchA-bgp-af-ipv6] peer 10::1 as-number 65009
[SwitchA-bgp-af-ipv6] quit
[SwitchA-bgp] quit
[SwitchB] bgp 65009
[SwitchB-bgp-af-ipv6] peer 10::2 as-number 65008
# Display IPv6 peer information on Switch B.
[SwitchB] display bgp ipv6 peer
BGP local router ID : 2.2.2.2
Local AS number : 65009
Total number of peers : 3 Peers in established state : 3
Peer V AS MsgRcvd MsgSent OutQ PrefRcv Up/Down State
10::2 4 65008 3 3 0 0 00:01:16 Established
9:3::2 4 65009 2 3 0 0 00:00:40 Established
9:1::2 4 65009 2 4 0 0 00:00:19 Established
# Display IPv6 peer information on Switch C.
[SwitchC] display bgp ipv6 peer
BGP local router ID : 3.3.3.3
Total number of peers : 2 Peers in established state : 2
9:3::1 4 65009 4 4 0 0 00:02:18 Established
9:2::2 4 65009 4 5 0 0 00:01:52 Established
Switch A and B has established an eBGP connection; Switch B, C and D have established iBGP connections with each other.
Switch B receives an eBGP update and sends it to Switch C, which is configured as a route reflector with two clients: Switch B and Switch D.
Switch B and Switch D need not establish an iBGP connection because Switch C reflects updates between them.
Network diagram
Figure 1-2 Network diagram for IPv6 BGP route reflector configuration
1) Configure IPv6 addresses for VLAN interfaces (omitted)
2) Configure IPv6 BGP basic functions
[SwitchA] ipv6
[SwitchA] bgp 100
[SwitchA-bgp-af-ipv6] peer 100::2 as-number 200
[SwitchA-bgp-af-ipv6] network 1:: 64
#Configure Switch B.
[SwitchB] ipv6
[SwitchB] bgp 200
[SwitchB-bgp-af-ipv6] peer 100::1 as-number 100
[SwitchB-bgp-af-ipv6] peer 101::1 as-number 200
[SwitchB-bgp-af-ipv6] peer 101::1 next-hop-local
[SwitchC] ipv6
[SwitchC] bgp 200
[SwitchC-bgp-af-ipv6] peer 101::2 as-number 200
[SwitchC-bgp-af-ipv6] peer 102::2 as-number 200
[SwitchD] ipv6
[SwitchD] bgp 200
[SwitchD-bgp-af-ipv6] peer 102::1 as-number 200
3) Configure route reflector
# Configure Switch C as a route reflector, Switch B and Switch D as its clients.
[SwitchC-bgp-af-ipv6] peer 101::2 reflect-client
[SwitchC-bgp-af-ipv6] peer 102::2 reflect-client
Use the display bgp ipv6 routing-table command on Switch B and Switch D respectively, you can find both of them have learned the network 1::/64.
Symptom
Display BGP peer information using the display bgp ipv6 peer command. The state of the connection to the peer cannot become established.
Analysis
To become IPv6 BGP peers, any two routers need to establish a TCP session using port 179 and exchange open messages successfully.
Processing steps
1) Use the display current-configuration command to verify the peer’s AS number.
2) Use the display bgp ipv6 peer command to verify the peer’s IPv6 address.
3) If the loopback interface is used, check whether the peer connect-interface command is configured.
4) If the peer is not directly connected, check whether the peer ebgp-max-hop command is configured.
5) Check whether a route to the peer is available in the routing table.
6) Use the ping command to check connectivity.
7) Use the display tcp ipv6 status command to check the TCP connection.
8) Check whether an ACL for disabling TCP port 179 is configured.
