- 03-IP Routing Volume
- 00-IP Routing Volume Organization
- 01-IP Routing Overview
- 02-Static Routing Configuration
- 03-RIP Configuration
- 04-OSPF Configuration
- 05-IS-IS Configuration
- 06-BGP Configuration
- 07-IPv6 Static Routing Configuration
- 08-IPv6 Ripng Configuration
- 09-IPv6 OSPFv3 Configuration
- 10-IPv6 IS-IS Configuration
- 11-IPv6 BGP Configuration
- 12-Routing Policy Configuration
| 00-IP Routing Volume Organization | 47.16 KB |
Manual Version
20091105-C-1.03
Product Version
Release 6300 series
Organization
The IP Routing Volume is organized as follows:
Features |
IP Routing Overview |
This document describes: l Introduction to IP routing and routing table l Routing protocol overview |
Static Routing |
A static route is manually configured by the administrator. The proper configuration and usage of static routes can improve network performance and ensure bandwidth for important network applications. This document describes: l Static route configuration |
RIP |
Routing Information Protocol (RIP) is a simple Interior Gateway Protocol (IGP), mainly used in small-sized networks. This document describes: l RIP basic functions configuration l RIP advanced functions configuration l RIP network optimization configuration |
OSPF |
Open Shortest Path First (OSPF) is an Interior Gateway Protocol based on the link state developed by IETF. This document describes: l Configuring OSPF Network Types l Configuring
IS-IS |
Intermediate System-to-Intermediate System (IS-IS) is a link state protocol, which uses the shortest path first (SPF) algorithm. This document describes: l Configuring IS-IS Basic Functions l Configuring IS-IS Routing Information Control l Tuning and Optimizing IS-IS Networks l Configuring IS-IS Authentication l Configuring System ID to Host Name Mappings |
BGP |
Border gateway protocol (BGP) is an inter-autonomous system (inter-AS) dynamic route discovery protocol. This document describes: l Configuring BGP Basic Functions l Controlling Route Generation l Controlling Route Distribution and Reception l
Configuring l Tuning and Optimizing BGP Networks |
IPv6 Static Routing |
Static routes are special routes that are manually configured by network administrators. Similar to IPv4 static routes, IPv6 static routes work well in simple IPv6 network environments. This document describes: l IPv6 static route configuration |
IPv6 RIPng |
RIP next generation (RIPng) is an extension of RIP-2 for IPv4. RIPng for IPv6 is IPv6 RIPng. This document describes: l Configuring RIPng Basic Functions |
IPv6 OSPFv3 |
OSPFv3 is OSPF version 3 for short, supporting IPv6 and compliant with RFC2740 (OSPF for IPv6). This document describes: l Configuring OSPFv3 Area Parameters l Configuring OSPFv3 Network Types l Configuring OSPFv3 Routing Information Control |
IPv6 IS-IS |
The IS-IS routing protocol supports multiple network protocols, including IPv6. IS-IS with IPv6 support is called IPv6 IS-IS dynamic routing protocol. This document describes: |
IPv6 BGP |
To support multiple network layer protocols, IETF extended BGP-4 by introducing IPv6 BGP. This document describes: l Configuring IPv6 BGP Basic Functions l Controlling Route Distribution and Reception l Configuring IPv6 BGP Route Attributes |
Routing Policy |
Routing policy is used on the router for route inspection, filtering, attributes modifying when routes are received, advertised, or redistributed. This document describes: l Route policy configuration |
