H3C S3610[S5510]系列以太网交换机 命令手册-Release 5303(V1.01)
10-IPv6配置命令
本章节下载 10-IPv6配置命令  (411.1 KB)
10-IPv6配置命令
  录
第1章 IPv6基础配置命令
1.1 IPv6基础配置命令
1.1.1 display dns ipv6 dynamic-host
1.1.2 display dns ipv6 server
1.1.3 display ipv6 fib
1.1.4 display ipv6 fibcache
1.1.5 display ipv6 host
1.1.6 display ipv6 interface
1.1.7 display ipv6 neighbors
1.1.8 display ipv6 neighbors count
1.1.9 display ipv6 pathmtu
1.1.10 display ipv6 socket
1.1.11 display ipv6 statistics
1.1.12 display tcp ipv6 statistics
1.1.13 display tcp ipv6 status
1.1.14 display udp ipv6 statistics
1.1.15 dns server ipv6
1.1.16 ipv6
1.1.17 ipv6 address
1.1.18 ipv6 address auto link-local
1.1.19 ipv6 address eui-64
1.1.20 ipv6 address link-local
1.1.21 ipv6 fibcache
1.1.22 ipv6 fib-loadbalance-type hash-based
1.1.23 ipv6 host
1.1.24 ipv6 icmp-error
1.1.25 ipv6 icmpv6 multicast-echo-reply enable
1.1.26 ipv6 nd autoconfig managed-address-flag
1.1.27 ipv6 nd autoconfig other-flag
1.1.28 ipv6 nd dad attempts
1.1.29 ipv6 nd hop-limit
1.1.30 ipv6 nd ns retrans-timer
1.1.31 ipv6 nd nud reachable-time
1.1.32 ipv6 nd ra halt
1.1.33 ipv6 nd ra interval
1.1.34 ipv6 nd ra prefix
1.1.35 ipv6 nd ra router-lifetime
1.1.36 ipv6 neighbor
1.1.37 ipv6 neighbors max-learning-num
1.1.38 ipv6 pathmtu
1.1.39 ipv6 pathmtu age
1.1.40 reset dns ipv6 dynamic-host
1.1.41 reset ipv6 fibcache
1.1.42 reset ipv6 neighbors
1.1.43 reset ipv6 pathmtu
1.1.44 reset ipv6 statistics
1.1.45 reset tcp ipv6 statistics
1.1.46 reset udp ipv6 statistics
1.1.47 tcp ipv6 timer fin-timeout
1.1.48 tcp ipv6 timer syn-timeout
1.1.49 tcp ipv6 window
第2章 双协议栈配置命令
2.1 双协议栈配置命令
2.1.1 display switch-mode
2.1.2 ipv6
2.1.3 ipv6 address
2.1.4 ipv6 address auto link-local
2.1.5 ipv6 address eui-64
2.1.6 ipv6 address link-local
2.1.7 switch-mode
第3章 隧道技术配置命令
3.1 隧道技术配置命令
3.1.1 aggregation-group
3.1.2 destination
3.1.3 display interface tunnel
3.1.4 display ipv6 interface tunnel
3.1.5 expediting enable
3.1.6 expediting subnet
3.1.7 interface tunnel
3.1.8 mtu (Tunnel Interface view)
3.1.9 source
3.1.10 tunnel-protocol
第1章  IPv6基础配置命令
1.1  IPv6基础配置命令
【描述】
display dns ipv6 dynamic-host命令用来显示IPv6动态域名缓存信息。
# 显示IPv6动态域名缓存信息。
<Sysname> display dns ipv6 dynamic-host
No.    Host              IPv6 Address      TTL
1      aaa                2001::2            6
表1-1 display dns ipv6 dynamic-host命令显示信息描述表
No.
序列号
Host
主机名
IPv6 Address
主机名对应的IPv6地址
TTL
表项可以缓存的时间,单位为秒
&  说明:
display dns ipv6 dynamic-host命令显示信息中的主机名字段最长为21个字符。如果解析的主机名超过21个字符,则只显示前21个字符。
display dns ipv6 server [ dynamic ]
dynamic:显示通过DHCP等协议动态获得的IPv6域名服务器信息。
【描述】
display dns ipv6 server命令用来显示IPv6域名服务器的相关信息。
# 显示IPv6域名服务器的相关信息。
<Sysname> display dns ipv6 server
 Type:
  D:Dynamic    S:Static
DNS Server  Type  IPv6 Address                                   (Interface Name)
     1        S      1::1
     2        S      FE80:1111:2222:3333:4444:5555:6666:7777  Vlan2
表1-2 display dns ipv6 server命令显示信息描述表
DNS Server
域名服务器的序号,系统自动给所配置的服务器编号,从1开始
域名服务器类型,S表示静态指定的域名服务器,D表示通过DHCP等协议动态获得的域名服务器信息
IPv6 Address
域名服务器IPv6地址
Interface Name
接口名称,只有将服务器地址配置为IPv6链路本地地址时,才会存在对应的接口名称
display ipv6 fib [ ipv6-address ]
ipv6-address:显示目的地址为指定IPv6地址的FIB转发信息表项。
【描述】
display ipv6 fib命令用来显示IPv6 FIB转发信息表项。
如果不指定任何参数,则显示所有的IPv6 FIB转发信息表项。
# 显示所有的IPv6 FIB转发信息表项。
<Sysname> display ipv6 fib
FIB Table:
 Total number of Routes : 1
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
Destination: ::1                         PrefixLength    : 128
NextHop    : ::1                         Flag            : HU
Label          : NULL                            Tunnel ID   : 0
TimeStamp      : Date- 12/5/2004, Time- 9:15:18
Interface      : InLoopBack0
表1-3 display ipv6 fib命令显示信息描述表
FIB表中路由的总数
Destination
转发的目的地址
PrefixLength
转发的目的地址的前缀长度
NextHop
向目的地址转发报文的下一跳地址
Flag
路由的标志:
l      U:表示路由可用
l      G:表示网关路由
l      H:表示主机路由
l      B:表示黑洞路由
l      D:表示动态路由
l      S:表示静态路由
Label
标签
Tunnel ID
隧道ID
TimeStamp
FIB表项的生成时间
转发报文的出接口
【描述】
display ipv6 fibcache命令用来显示IPv6 FIB缓存中的路由总数。
# 显示IPv6 FIB缓存中的路由总数。
<Sysname> display ipv6 fibcache
FIB Cache:
 Total number of Routes : 0
display ipv6 host
【描述】
display ipv6 host命令用来显示静态域名解析表中所有主机名与IPv6地址的对应关系。
# 显示静态域名解析表中所有主机名与IPv6地址的对应关系。
<Sysname> display ipv6 host
Host                 Age           Flags           IPv6Address
aaa                  0             static           2002::1
bbb                  0             static           2002::2
表1-4 display ipv6 host命令显示信息描述表
Host
主机名
Age
该表项的生存时间,静态配置的显示为0
Flags
主机名与IPv6地址映射的类型标志,静态解析显示为static
IPv6Address
主机名对应的IPv6地址
display ipv6 interface [ brief ] [ interface-type [ interface-number ] ]
brief:显示接口的IPv6摘要信息。
interface-type:显示指定类型接口的IPv6信息。
interface-number:显示指定接口的IPv6信息。
【描述】
display ipv6 interface命令用来显示可以配置IPv6地址的接口的IPv6信息。
如果不指定接口类型和接口编号,则显示所有可以配置IPv6地址的接口的IPv6信息;如果只指定接口类型,不指定接口编号,则显示所有可以配置IPv6地址的指定类型接口的IPv6信息;如果同时指定接口类型和接口编号,则显示指定接口的IPv6信息。
# 查看VLAN接口2上的IPv6信息。
<Sysname> display ipv6 interface vlan-interface 2
Vlan-interface2 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::1234:56FF:FE65:4322
  Global unicast address(es):
    2001::1, subnet is 2001::/64
  Joined group address(es):
    FF02::1:FF00:1
    FF02::1:FF65:4322
    FF02::2
    FF02::1
  MTU is 1500 bytes
表1-5 display ipv6 interface命令显示信息描述表
接口状态
接口的链路层协议状态
IPv6 is enabled
接口的IPv6转发功能状态(该例中处于使能状态)
link-local address
接口上配置的链路本地地址
接口上配置的全球单播地址
接口加入的组播组地址
MTU
接口的最大传输单元
重复地址检测功能是否使能(该例中使能)及重复地址检测的次数
ND reachable time
保持邻居可达的时间
邻居请求消息重传时间间隔
主机采用无状态自动配置的方式获取IPv6地址
# 查看所有可以配置IPv6地址的接口的IPv6摘要信息。
<Sysname> display ipv6 interface brief
*down: administratively down
(s): spoofing
Interface                                Physical        Protocol        IPv6 Address
Vlan-interface1                      down            down            Unassigned
Vlan-interface2                      up          up          2001::1
Vlan-interface100                        up          down            Unassigned
表1-6 display ipv6 interface brief命令显示信息描述表
*down
接口处于管理down状态,即采用shutdown命令关闭了该接口
(s)
接口的欺骗属性,即接口的链路协议状态显示是up的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立的
接口的名称
Physical
接口的物理状态
Protocol
接口的链路层协议状态
IPv6 Address
接口的IPv6地址,只显示配置的第一个IPv6地址(如果未配置则显示“Unassigned”)
display ipv6 neighbors { ipv6-address | all | dynamic | interface interface-type interface-number | static | vlan vlan-id } [ | { begin | exclude | include } text ]
ipv6-address:显示指定IPv6地址的邻居信息。
all:显示所有邻居的信息,包括动态获取的和静态配置的邻居信息。
dynamic:显示所有动态获取的邻居信息。
static:显示所有静态配置的邻居信息。
interface interface-type interface-number:显示指定接口的邻居信息。interface-type interface-number为接口类型和接口编号。
vlan vlan-id:显示指定VLAN的邻居信息。vlan-id的取值范围为1~4094。
|:使用输出信息过滤功能。
begin:从第一个包含指定字符串的邻居信息项开始显示。
include:只显示那些包含指定字符串的邻居信息项。
exclude:只显示那些不包含指定字符串的邻居信息项。
text:字符串。
【描述】
display ipv6 neighbors命令用来显示邻居信息。
# 查看所有的邻居信息。
<Sysname> display ipv6 neighbors all
                Type: S-Static    D-Dynamic
IPv6 Address                 Link-layer       VID  Interface     State  T   Age
FE80::200:5EFF:FE32:B800  0000-5e32-b800   N/A  Eth1/0         REACH  S   -
表1-7 display ipv6 neighbors命令显示信息描述表
IPv6 Address
邻居的IPv6地址
Link-layer
链路层地址(邻居的MAC地址)
VID
与邻居相连的接口所属的VLAN
与邻居相连的接口
邻居的状态,包括:
l      INCMP:正在解析地址,邻居的链路层地址尚未确定;
l      REACH:邻居可达;
l      STALE:未确定邻居是否可达,设备不会再验证邻居的可达性,除非有数据发送给该邻居;
l      DELAY:未确定邻居是否可达,延迟一段时间发送邻居请求报文;
l      PROBE:未确定邻居是否可达,发送邻居请求报文来验证邻居的可达性。
T
邻居信息的类型,S表示静态配置,D表示动态获取
Age
静态项显示“–”,动态项显示上次可达以来经过的时间(单位为秒),如果始终不可达则显示“#”(只适用于动态项)
display ipv6 neighbors { all | dynamic | interface interface-type interface-number | static | vlan vlan-id } count
all:显示所有邻居表项的总个数,包括动态获取的和静态配置的邻居信息。
dynamic:显示所有动态获取的邻居表项的总个数。
static:显示所有静态配置的邻居表项的总个数。
interface interface-type interface-number:显示指定接口的邻居表项的总个数。interface-type interface-number为接口类型和接口编号。
vlan vlan-id:显示指定VLAN的邻居表项的总个数。vlan-id的取值范围为1~4094。
【描述】
display ipv6 neighbors count命令用来显示符合指定条件的邻居表项的总个数。
# 显示动态获取的邻居表项的总个数。
<Sysname> display ipv6 neighbors dynamic count
Total dynamic entry(ies):  2
display ipv6 pathmtu { ipv6-address | all | dynamic | static }
ipv6-address:显示到达指定IPv6地址的PMTU信息。
all:显示所有PMTU信息。
dynamic:显示所有动态PMTU信息。
static:显示所有静态PMTU信息。
【描述】
display ipv6 pathmtu命令用来显示IPv6的PMTU信息。
# 显示所有PMTU信息。
<Sysname> display ipv6 pathmtu all
IPv6 Destination Address ZoneID  PathMTU     Age     Type
 fe80::12                    0       1300            40      Dynamic
 2222::3                 0       1280            --      Static
表1-8 display ipv6 pathmtu命令显示信息描述表
IPv6目的地址
ZoneID
地址区域,目前没有作用
PathMTU
对应IPv6地址的PMTU值
Age
PMTU的老化时间(单位为分钟),如果是静态PMTU项,则显示为“--”
PMTU的类型,Dynamic表示动态协商的PMTU,Static表示静态配置的PMTU
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ]
socktype socket-type:显示指定类型套接字的相关信息。socket-type为套接字类型,取值范围为1~3,其中1表示套接字类型为TCP,2表示套接字类型为UDP,3表示套接字类型为raw IP。
task-id:显示指定任务的套接字相关信息。task-id为任务ID,取值范围为1~100。
socket-id:显示指定套接字的相关信息。socket-id为套接字ID,取值范围为0~3072。
【描述】
display ipv6 socket命令用来显示套接字的相关信息。
# 查看套接字的相关信息。
<Sysname> display ipv6 socket
SOCK_STREAM:
Task = VTYD(14), socketid = 4, Proto = 6,
LA = ::->22, FA = ::->0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_REUSEPORT SO_SENDVPNID,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(14), socketid = 3, Proto = 6,
LA = ::->23, FA = ::->0,
SOCK_DGRAM:
SOCK_RAW:
表1-9 display ipv6 socket命令显示信息描述表
SOCK_STREAM
套接口类型为TCP
SOCK_DGRAM
套接口类型为UDP
SOCK_RAW
套接口类型为raw IP
创建套接字的任务ID
socketid
内核为创建的套接字分配的套接字号
Proto
协议ID
LA
本端地址与本端端口号
FA
远端地址与远端端口号
sndbuf
发送缓冲区大小
rcvbuf
接收缓冲区大小
sb_cc
发送缓冲区发送的字节数
rb_cc
接收缓冲区接收的字节数
socket option
应用程序设置的套接字选项
socket state
套接字状态
【描述】
display ipv6 statistics命令用来显示IPv6报文及ICMPv6报文的统计信息。
# 查看IPv6报文及ICMPv6报文的统计信息。
<Sysname> display ipv6 statistics
  IPv6 Protocol:
    Sent packets:
      Total:      0
        Local sent out:      0            forwarded:         0
        raw packets:     0            discarded:         0
        routing failed:      0            fragments:         0
        fragments failed:    0
    Received packets:
      Total:      0
        local host:          0            hopcount exceeded: 0
        format error:        0            option error:          0
        protocol error:      0            fragments:         0
        reassembled:     0            reassembly failed: 0
        reassembly timeout:  0
  ICMPv6 protocol:
    Sent packets:
      Total:      0
        Unreached:           0             too big:              0
        hopcount exceeded:   0             reassembly timeout:   0
        parameter problem:   0
        echo request:        0             echo replied:     0
        neighbor solicit:    0             neighbor advert:      0
        router solicit:      0             router advert:        0
        redirected:          0
      Send failed:
        ratelimited:     0             other errors:     0
    Received packets:
      Total:      0
        checksum error:      0             too short:            0
        bad code:            0
        unreached:           0             too big:              0
        parameter problem:   0             unknown error type:   0
        echoed:          0             echo replied:     0
        redirected:          0             router renumbering:   0
        unknown info type:   0
      Deliver failed:
        bad length:          0             ratelimited:          0
表1-10 display ipv6 statistics命令显示信息描述表
IPv6 Protocol:
IPv6报文统计信息
Sent packets:
 Total:      0
  fragments failed:     0
发送IPv6报文的统计信息,包括:
l      发送报文总数
l      本地发送报文数
l      转发报文数
l      使用raw socket发送的报文数
l      丢弃报文数
l      路由失败报文数
l      发送分片报文数
l      分片报文发送失败的个数
Received packets:
 Total:      0
接收IPv6报文的统计信息,包括:
l      接收报文总数
l      本地接收报文数
l      超出跳数范围的报文数
l      格式错误的报文数
l      选项错误的报文数
l      协议错误的报文数
l      接收的分片报文数
l      重组报文数
l      重组失败的报文数
l      重组超时的报文数
ICMPv6 protocol:
ICMPv6报文的统计信息
Sent packets:
 Total:      0
  router solicit:      0  router advert        0
  redirected:        0
 Send failed:
发送ICMPv6报文的统计信息,包括:
l      发送报文总数
l      目的不可达报文数
l      报文太大的报文数
l      超出跳数限制的报文数
l      分片重组超时报文数
l      参数错误报文数
l      回应请求报文数
l      回应响应报文数
l      邻居请求报文数
l      邻居通告报文数
l      路由器请求报文数
l      路由器通告报文数
l      重定向报文数
l      因速率超过限制而未发送的报文数
l      其他错误的报文数
Received packets:
 Total:      0
  bad code:          0
  redirected:        0  router renumbering  0
  Deliver failed:
接收ICMPv6报文的统计信息,包括:
l      接收报文总数
l      校验和错误的报文数
l      报文太小的报文数
l      错误代码的报文数
l      不可达报文数
l      报文太长的报文数
l      超出跳数限制的报文数
l      分片重组超时的报文数
l      参数错误报文数
l      未知错误报文数
l      回应请求报文数
l      回应响应报文数
l      邻居请求报文数
l      邻居通告报文数
l      路由器请求报文数
l      路由器通告报文数
l      重定向报文数
l      路由器重计数
l      未知信息报文数
l      长度错误的报文数
l      因速率超过限制而未接收的报文数
【描述】
display tcp ipv6 statistics命令用来显示TCP6连接的统计信息。
# 查看TCP6连接的统计信息。
<Sysname> display tcp ipv6 statistics
Received packets:
     Total: 0
     packets in sequence: 0 (0 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 0 (0 bytes), partially duplicate packets: 0 (0 bytes)
     out-of-order packets: 0 (0 bytes)
     packets with data after window: 0 (0 bytes)
     packets after close: 0
     ACK packets: 0 (0 bytes)
     duplicate ACK packets: 0, too much ACK packets: 0
Sent packets:
     Total: 0
     urgent packets: 0
     control packets: 0 (including 0 RST)
     data packets: 0 (0 bytes) data packets retransmitted: 0 (0 bytes)
     ACK only packets: 0 (0 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
表1-11 display tcp ipv6 statistics命令显示信息描述表
Received packets:
     Total: 0
接收报文统计信息,包括:
l      接收报文总数
l      顺序接收报文数
l      窗口探测报文数
l      窗口大小更新的报文数
l      校验和错误的报文数
l      偏移量错误的报文数
l      总长度短于报文头中设置值的报文数
l      重复的报文数
l      部分复制报文数
l      无序报文数
l      超出接收窗口的报文数
l      连接关闭后接收到的报文数
l      接收到的ACK报文数
l      接收到的重复ACK报文数
l      接收到的过多ACK报文数
Sent packets:
     Total: 0
     urgent packets: 0
发送报文的统计信息,包括:
l      发送报文总数
l      含有紧急指示符的报文数
l      发送的控制报文数
l      发送的窗口探测报文数
l      发送的窗口更新报文数
l      发送的数据报文数
l      重发的数据报文数
l      单独ACK报文数
重传超时报文数
重传超时断开的连接数
Keepalive timeout
Keepalive超时数
keepalive probe
Keepalive探测数
Keepalive响应超时而断开的连接数
发起的连接数
接受的连接数
建立的连接数
Closed connections
关闭的连接数
dropped
意外丢弃连接数(收到对端SYN之后)
initiated dropped
主动连接失败数(收到对端SYN之前)
【描述】
display tcp ipv6 status命令用来显示TCP6连接的状态信息。
# 查看TCP6连接的状态信息。
<Sysname> display tcp ipv6 status
TCP6CB       Local Address       Foreign Address      State
045d8074    ::->21                ::->0                  Listening
表1-12 display tcp ipv6 status命令显示信息描述表
TCP6CB
TCP6的控制块地址(十六进制)
Local Address
本端IPv6地址及端口号
Foreign Address
对端IPv6地址及端口号
TCP6的连接状态,包括:Closed、Listening、Syn_Sent、Syn_Rcvd、Established、Close_Wait、Fin_Wait1、Closing、Last_Ack、Fin_Wait2及Time_Wait
【描述】
display udp ipv6 statistics命令用来显示UDP6的统计信息。
# 显示UDP6的统计信息。
<Sysname> display udp ipv6 statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
表1-13 display udp ipv6 statistics命令显示信息描述表
Total
接收/发送报文总数
checksum error
校验和出错的报文总数
shorter than header
报文长度小于报文头长度的UDP6报文总数
数据长度超过报文长度的报文总数
端口上接收的无套接字的单播报文总数
端口上接收的无套接字的广播/组播报文数
接收缓冲区满后,未处理报文数
input packet missing pcb cache
没有匹配PCB缓存的报文数
dns server ipv6 ipv6-address [ interface-type interface-number ]
undo dns server ipv6 ipv6-address [ interface-type interface-number ]
ipv6-address:DNS服务器的IPv6地址。
interface-type interface-number:出接口类型及接口号。当DNS服务器的IPv6地址为链路本地地址时,需要指定此参数。
【描述】
dns server ipv6命令用来配置DNS服务器的IPv6地址。undo dns server ipv6命令用来删除已配置的DNS服务器。
缺省情况下,没有配置DNS服务器。
# 配置DNS服务器的IPv6地址为2002::1。
[Sysname] dns server ipv6 2002::1
1.1.16  ipv6
ipv6
undo ipv6
【描述】
ipv6命令用来使能IPv6报文转发功能。undo ipv6命令用来关闭IPv6报文转发功能。
缺省情况下,IPv6报文转发功能处于关闭状态。
# 使能对IPv6报文的转发功能。
[Sysname] ipv6
1.1.17  ipv6 address
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ]
ipv6-address:IPv6地址。
prefix-length:前缀长度,取值范围为1~128。
【描述】
ipv6 address命令用来手工配置接口的IPv6站点本地地址或全球单播地址。undo ipv6 address命令用来删除接口的IPv6地址。
缺省情况下,接口上没有配置站点本地地址和全球单播地址。
需要注意的是,undo ipv6 address命令不带参数则删除该接口的所有IPv6地址,但自动配置的链路本地地址除外。
# 指定VLAN接口100的IPv6全球单播地地址为2001::1/64。
[Sysname-Vlan-interface100] ipv6 address 2001::1/64
undo ipv6 address auto link-local
【描述】
ipv6 address auto link-local命令用来配置系统自动为接口生成链路本地地址。undo ipv6 address auto link-local命令用来删除接口自动生成的链路本地地址。
缺省情况下,当接口配置了IPv6站点本地地址或全球单播地址后,会自动生成链路本地地址。
# 配置VLAN接口100自动生成链路本地地址。
[Sysname-Vlan-interface100] ipv6 address auto link-local
ipv6 address ipv6-address/prefix-length eui-64
undo ipv6 address ipv6-address/prefix-length eui-64
ipv6-address/prefix-length:IPv6地址/前缀长度,共同指定采用EUI-64格式形成的IPv6地址的前缀。
【描述】
ipv6 address eui-64命令用来给接口配置EUI-64格式的站点本地地址或全球单播地址。undo ipv6 address eui-64命令用来删除接口上已配置的EUI-64格式的站点本地地址或全球单播地址。
缺省情况下,接口上没有配置EUI-64格式的站点本地地址和全球单播地址。
需要注意的是,在配置EUI-64地址时前缀长度取值不能大于64。
# 配置VLAN接口100采用EUI-64格式形成IPv6地址。
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 eui-64
undo ipv6 address ipv6-address link-local
ipv6-address:IPv6链路本地地址,地址前面10位必须为1111111010(二进制标识),即地址最前面的一组十六进制数为FE80~FEBF。
【描述】
ipv6 address link-local命令用来手动配置指定接口的链路本地地址。undo ipv6 address link-local命令用来删除接口上手动配置的链路本地地址。
# 配置VLAN接口100的链路本地地址。
[Sysname-Vlan-interface100] ipv6 address fe80::1 link-local
ipv6 fibcache
undo ipv6 fibcache
【描述】
ipv6 fibcache命令用来使能IPv6 FIB缓存功能。undo ipv6 fibcache命令用来关闭IPv6 FIB缓存功能。
缺省情况下,IPv6 FIB缓存功能处于关闭状态。
需要注意的是,使能FIB缓存功能后,仅对转发的报文起作用。
# 使能IPv6 FIB缓存功能。
[Sysname] ipv6 fibcache
undo ipv6 fib-loadbalance-type hash-based
【描述】
ipv6 fib-loadbalance-type hash-based命令用来指定转发报文时采用基于hash算法的负载分担方式。undo ipv6 fib-loadbalance-type hash-based命令用来恢复负载分担方式为缺省的轮询方式。
缺省情况下,采用轮询方式,即在转发报文时,轮流使用每条等价路由。
# 配置转发报文时采用基于hash算法的负载分担方式。
[Sysname] ipv6 fib-loadbalance-type hash-based
1.1.23  ipv6 host
ipv6 host hostname ipv6-address
undo ipv6 host hostname [ ipv6-address ]
hostname:主机名,为1~20个字符的字符串,字符串中可以包含字母、数字、“_”、“-”或“.”,且至少包含一个字母。
【描述】
ipv6 host命令用来配置主机名与IPv6地址的对应关系。undo ipv6 host命令用来取消已配置的主机名与IPv6地址的对应关系。
每个主机名只能对应1个IPv6地址。
# 配置主机名与IPv6地址的对应关系。
[Sysname] ipv6 host aaa 2001::1
ipv6 icmp-error { bucket bucket-size | ratelimit interval } *
undo ipv6 icmp-error
bucket bucket-size:令牌桶中容纳的令牌数,bucket-size取值范围为1~200。
ratelimit interval:令牌桶的刷新周期,interval取值范围为0~2147483647,单位为毫秒。取值为0时,表示不限制ICMPv6差错报文的发送。
【描述】
ipv6 icmp-error命令用来控制ICMPv6差错报文发送的令牌桶容量和刷新周期。undo ipv6 icmp-error命令用来恢复缺省情况。
缺省情况下,令牌桶容量为10,令牌桶的刷新周期为100毫秒,即每一个刷新周期内最多可以发送10个ICMPv6差错报文。
# 设置令牌桶容量为50个,令牌桶的刷新周期为100毫秒。
[Sysname] ipv6 icmp-error bucket 50 ratelimit 100
undo ipv6 icmpv6 multicast-echo-reply
【描述】
ipv6 icmpv6 multicast-echo-reply enable命令用来配置允许设备回复组播形式的Echo request报文。undo ipv6 icmpv6 multicast-echo-reply命令用来配置不允许设备回复组播形式的Echo request报文。
缺省情况下,不允许设备回复组播形式的Echo request报文。
# 配置允许设备回复组播形式的Echo request报文。
[Sysname] ipv6 icmpv6 multicast-echo-reply enable
undo ipv6 nd autoconfig managed-address-flag
【描述】
ipv6 nd autoconfig managed-address-flag命令用来设置被管理地址的配置标志位为1,即主机通过有状态自动配置(例如DHCP服务器)获取IPv6地址。undo ipv6 nd autoconfig managed-address-flag命令用来恢复该标志位为缺省值0,即主机通过无状态自动配置获取IPv6地址。
缺省情况下,被管理地址标志位为0。
# 设置主机通过状态自动配置获取IPv6地址。
[Sysname-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
undo ipv6 nd autoconfig other-flag
【描述】
ipv6 nd autoconfig other-flag命令用来设置其他信息配置标志位为1,即主机通过有状态自动配置(例如DHCP服务器)获取除IPv6地址外的其他信息。undo ipv6 nd autoconfig other-flag命令用来恢复该标志位为缺省值0,即主机通过无状态自动配置获取其他信息。
缺省情况下,其他信息配置标志位为0。
# 设置主机通过无状态自动配置来获取除IPv6地址外的其他信息。
[Sysname-Vlan-interface100] undo ipv6 nd autoconfig other-flag
ipv6 nd dad attempts value
undo ipv6 nd dad attempts
value:进行重复地址检测时发送邻居请求消息的次数,取值范围为0~600。当设置为0时,表示禁止重复地址检测。
【描述】
ipv6 nd dad attempts命令用来配置进行重复地址检测时发送邻居请求消息的次数。undo ipv6 nd dad attempts命令用来恢复缺省情况。
缺省情况下,进行重复地址检测时发送邻居请求消息的次数为1。
# 配置VLAN接口100进行重复地址检测时发送邻居请求消息的次数为20次。
[Sysname-Vlan-interface100] ipv6 nd dad attempts 20
ipv6 nd hop-limit value
undo ipv6 nd hop-limit
value:跳数值,取值范围为0~255。当指定为0时,设备发布的RA消息中Hop Limit字段的值为0,即不对主机进行指定。
【描述】
ipv6 nd hop-limit命令用来配置设备发布的跳数限制。undo ipv6 nd hop-limit命令用来恢复缺省情况。
缺省情况下,设备发布的跳数限制为64。
# 配置设备发布的跳数限制为100跳。
[Sysname] ipv6 nd hop-limit 100
undo ipv6 nd ns retrans-timer
value:NS消息重传时间间隔,取值范围为1000~4294967295,单位为毫秒。
【描述】
ipv6 nd ns retrans-timer命令用来配置邻居请求消息的重传时间间隔。该时间间隔既用于本接口发送NS消息的时间间隔,同时也作为本接口发布的RA消息中Retrans Timer字段的值。undo ipv6 nd ns retrans-timer命令用来恢复缺省情况。
缺省情况下,接口发送NS消息的时间间隔为1000毫秒,接口发布的RA消息中Retrans Timer字段的值为0。
# 设置VLAN接口100发送NS消息的时间间隔为10000毫秒。
[Sysname-Vlan-interface100] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time value
undo ipv6 nd nud reachable-time
value:保持邻居可达状态的时间,取值范围为1~3600000,单位为毫秒。
【描述】
ipv6 nd nud reachable-time命令用来配置接口保持邻居可达状态的时间。该时间既用于本接口保持邻居可达状态的时间,同时也作为本接口发布的RA消息中Reachable Timer字段的值。undo ipv6 nd nud reachable-time命令用来恢复接口保持邻居可达状态的时间为缺省值,同时指定该接口发布的RA消息中Reachable Timer字段的值为0,即不对主机进行指定。
缺省情况下,接口保持邻居可达状态的时间为30000毫秒,接口发布的RA消息中Reachable Timer字段的值为0。
# 配置VLAN接口100上保持邻居可达状态的时间为10000毫秒。
[Sysname-Vlan-interface100] ipv6 nd nud reachable-time 10000
ipv6 nd ra halt
undo ipv6 nd ra halt
【描述】
ipv6 nd ra halt命令用来抑制RA消息的发布。undo ipv6 nd ra halt命令用来取消对RA消息发布的抑制。
缺省情况下,抑制发布RA消息。
# 抑制在VLAN接口100上发布RA消息。
[Sysname-Vlan-interface100] ipv6 nd ra halt
ipv6 nd ra interval max-interval-value min-interval-value
undo ipv6 nd ra interval
max-interval-value:指定RA消息发布的最大时间间隔,取值范围是4~1800,单位为秒。
min-interval-value:指定RA消息发布的最小时间间隔,取值范围是3~1350,单位为秒。
【描述】
ipv6 nd ra interval命令用来配置RA消息发布的最大时间间隔和最小时间间隔。设备在最大时间间隔与最小时间间隔之间随机选取一个值作为周期性发布RA消息的时间间隔。undo ipv6 nd ra interval命令用来恢复缺省情况。
缺省情况下,RA消息发布的最大时间间隔为600秒,最小时间间隔为200秒。
l              配置的最小时间间隔应该小于等于最大时间间隔的0.75倍;
l              RA消息发布的最大实际间隔应该小于或等于RA消息中路由器的生存时间。
# 配置设备周期性发布RA消息的最大时间间隔为1000秒,最小时间间隔为700秒。
[Sysname-Vlan-interface100] ipv6 nd ra interval 1000 700
ipv6 nd ra prefix { ipv6-address prefix-length | ipv6-address/prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] *
undo ipv6 nd ra prefix ipv6-prefix
ipv6-address:IPv6地址或IPv6前缀。
prefix-length:前缀长度。
ipv6-prefix:IPv6地址前缀。
valid-lifetime:前缀的有效存活时间,取值范围为0~4294967295,单位为秒。
preferred-lifetime:前缀用于无状态地址配置的优选项的存活时间,取值范围为0~4294967295,单位为秒。
no-autoconfig:指定前缀不用于无状态地址配置。如果不选择该参数,则指定前缀用于无状态地址配置。
off-link:指定前缀不是该链路上直连可达的。如果不选择该参数,则表示指定前缀是直连可达的。
【描述】
ipv6 nd ra prefix命令用来配置RA消息中的前缀信息。undo ipv6 nd ra prefix命令用来取消RA消息中前缀信息的配置。
缺省情况下,没有配置RA消息中的前缀信息,此时将使用发送RA消息的接口IPv6地址作为RA中的前缀信息。
# 配置VLAN接口100上RA消息中的前缀信息。
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100/64 100 10
ipv6 nd ra router-lifetime value
undo ipv6 nd ra router-lifetime
value:RA消息中路由器的生存时间,取值范围为0~9000,单位为秒。当配置为0时,表示本设备不作为默认路由器。
【描述】
ipv6 nd ra router-lifetime命令用来配置RA消息中路由器的生存时间。undo ipv6 nd ra router-lifetime命令用来恢复缺省情况。
缺省情况下,RA消息中路由器的生存时间为1800秒。
需要注意的是,RA消息中路由器的生存时间应该大于或等于RA消息的发布时间间隔。
# 配置VLAN接口100上RA消息中路由器的生存时间为1000秒。
[Sysname-Vlan-interface100] ipv6 nd ra router-lifetime 1000
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
undo ipv6 neighbor ipv6-address interface-type interface-number
ipv6-address:静态邻居表项中的IPv6地址。
mac-address:静态邻居表项中的链路层地址(48位,格式为H-H-H)。
vlan-id:静态邻居表项所对应的VLAN ID,取值范围为1~4094。
port-type port-number:静态邻居表项所对应的二层端口类型和端口号。
interface interface-type interface-number:静态邻居表项所对应的三层接口类型和接口号。
【描述】
ipv6 neighbor命令用来配置静态邻居表项。undo ipv6 neighbor命令用来删除静态邻居表项。
需要注意的是,对于VLAN接口,可以采用配置三层接口对应IPv6地址、链路层地址和配置VLAN中的端口对应IPv6地址、链路层地址两种方式来配置静态邻居表项:
l              采用第一种方式配置静态邻居表项后,该邻居表项处于INCMP状态。设备解析到VLAN对应的二层端口信息后,该邻居表项才会进入REACH状态。
l              采用第二种方式配置静态邻居表项,需要保证VLAN所对应的VLAN接口已经存在,且port-type port-number指定的二层端口属于vlan-id指定的VLAN。在配置后,设备会将VLAN所对应的VLAN接口与IPv6地址相对应来唯一标识一个静态邻居表项,并且该表项处于REACH状态。
在删除VLAN接口对应的静态邻居表项时,只需要指定VLAN对应的VLAN接口即可。
# 配置VLAN100的二层以太网端口Ethernet1/0/2对应的静态邻居表项。
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 100 ethernet 1/0/2
ipv6 neighbors max-learning-num number
undo ipv6 neighbors max-learning-num
number:接口上允许动态学习的邻居的最大个数,取值范围为1~2560。
【描述】
ipv6 neighbors max-learning-num命令用来配置指定接口上允许动态学习的邻居的最大个数。undo ipv6 neighbors max-learning-num命令用来恢复缺省情况。
# 配置VLAN接口100上允许动态学习的邻居的最大个数为10个。
[Sysname-Vlan-interface100] ipv6 neighbors max-learning-num 10
1.1.38  ipv6 pathmtu
ipv6 pathmtu ipv6-address [ value ]
undo ipv6 pathmtu ipv6-address
ipv6-address:指定的IPv6地址。
value:指定IPv6地址对应的PMTU值,单位为字节,取值范围为1280~10000。
【描述】
ipv6 pathmtu命令用来配置指定IPv6地址对应的静态PMTU。undo ipv6 pathmtu 命令用来删除指定IPv6地址的PMTU配置。
缺省情况下,没有配置静态PMTU值。
# 配置指定IPv6地址对应的静态PMTU值。
[Sysname] ipv6 pathmtu fe80::12 1300
ipv6 pathmtu age age-time
undo ipv6 pathmtu age
age-time:PMTU老化时间,取值范围为10~100,单位为分钟。
【描述】
ipv6 pathmtu age命令用来配置动态PMTU的老化时间。undo ipv6 pathmtu age命令用来恢复缺省情况。
缺省情况下,动态PMTU的老化时间为10分钟。
需要注意的是,该配置对静态PMTU不起作用。
相关配置可参考命令display ipv6 pathmtu
# 配置动态PMTU的老化时间为40分钟。
[Sysname] ipv6 pathmtu age 40
【描述】
reset dns ipv6 dynamic-host命令用来清除IPv6动态域名缓存信息。
# 清除IPv6动态域名缓存信息。
<Sysname> reset dns ipv6 dynamic-host
reset ipv6 fibcache
【描述】
reset ipv6 fibcache命令用来清除FIB缓存项。
# 清除FIB缓存项。
<Sysname> reset ipv6 fibcache
reset ipv6 neighbors { all | dynamic | interface interface-type interface-number | static }
all:清除所有接口上的静态与动态邻居信息。
dynamic:清除所有接口上的动态邻居信息。
interface interface-type interface-number:清除指定接口上的动态邻居信息。interface-type interface-number为接口类型和接口编号
static:清除所有接口上的静态邻居信息。
【描述】
reset ipv6 neighbors命令用来清除IPv6邻居信息。
# 清除所有接口上的所有邻居信息。
<Sysname> reset ipv6 neighbors all
reset ipv6 pathmtu { all | static | dynamic }
all:清除所有PMTU信息。
static:清除所有静态PMTU信息。
dynamic:清除所有动态PMTU信息。
【描述】
reset ipv6 pathmtu命令用来清除PMTU信息。
# 清除所有PMTU信息。
<Sysname> reset ipv6 pathmtu all
【描述】
reset ipv6 statistics命令用来清除IPv6报文及ICMPv6报文的统计信息。
# 清除IPv6报文及ICMPv6报文的统计信息。
<Sysname> reset ipv6 statistics
【描述】
reset tcp ipv6 statistics命令用来清除所有TCP6连接的统计信息。
# 清除所有TCP6连接的统计信息。
<Sysname> reset tcp ipv6 statistics
【描述】
reset udp ipv6 statistics命令用来清除所有UDP6统计信息。
# 清除所有UDP6统计信息。
<Sysname> reset udp ipv6 statistics
tcp ipv6 timer fin-timeout wait-time
undo tcp ipv6 timer fin-timeout
wait-time:TCP6的finwait定时器值,取值范围为76~3600,单位为秒。
【描述】
tcp ipv6 timer fin-timeout命令用来设置TCP6的finwait定时器值。undo tcp ipv6 timer fin-timeout命令用来恢复缺省情况。
缺省情况下,TCP6的finwait定时器值为675秒。
# 设置TCP6的finwait定时器值为800秒。
[Sysname] tcp ipv6 timer fin-timeout 800
tcp ipv6 timer syn-timeout wait-time
undo tcp ipv6 timer syn-timeout
wait-time:TCP6的synwait定时器值,取值范围为2~600,单位为秒。
【描述】
tcp ipv6 timer syn-timeout命令用来设置TCP6的synwait定时器值。undo tcp ipv6 timer syn-timeout命令用来恢复缺省情况。
缺省情况下,TCP6的synwait定时器值为75秒。
# 设置TCP6的synwait定时器值为100秒。
[Sysname] tcp ipv6 timer syn-timeout 100
tcp ipv6 window size
undo tcp ipv6 window
【描述】
tcp ipv6 window命令用来设置TCP6的接收和发送缓冲区大小。undo tcp ipv6 window命令用来恢复缺省情况。
缺省情况下,TCP6的接收和发送缓冲区大小为8KB。
# 设置TCP6的接收和发送缓冲区大小为4KB。
[Sysname] tcp ipv6 window 4
第2章  双协议栈配置命令
2.1  双协议栈配置命令
display switch-mode
【描述】
display switch-mode命令显示当前及下一次设备启动后的系统运行模式及相关系统信息。
# 显示当前及下一次设备启动后的系统运行模式及相关系统信息。
<Sysname> display switch-mode
2.1.2  ipv6
ipv6
undo ipv6
【描述】
ipv6命令用来使能IPv6报文转发功能。undo ipv6命令用来取消IPv6报文转发功能。
# 使能对IPv6报文的转发功能。
[Sysname] ipv6
2.1.3  ipv6 address
【描述】
ipv6 address命令用来手工配置接口的站点本地地址或全球单播地址。undo ipv6 address命令用来删除手工配置的接口地址。
l              一个接口上最多可以配置10个全球单播地址和站点本地地址。
l              undo ipv6 address命令不带参数则删除该接口的所有IPv6地址,但自动配置的链路本地地址除外。
【描述】
ipv6-address/prefix-length:IPv6地址/前缀长度,共同指定采用EUI-64格式形成的IPv6地址的前缀。在配置EUI-64地址时前缀长度的取值范围为1~64。
【描述】
ipv6 address eui-64命令用来为接口配置EUI-64格式的站点本地地址或全球单播地址。undo ipv6 address eui-64命令用来删除接口上已配置的EUI-64格式的站点本地地址或全球单播地址。
【描述】
ipv6 address link-local命令用来手工配置指定接口的链路本地地址。undo ipv6 address link-local命令用来删除接口上手工配置的链路本地地址。
缺省情况下,当接口配置了IPv6站点本地地址或全球单播地址后,同时会自动生成链路本地地址。
2.1.7  switch-mode
switch-mode { default | dual-ipv4-ipv6 | mce }
default:配置设备运行时仅支持IPv4的协议栈,不支持IPv6的协议栈。
dual-ipv4-ipv6:配置设备运行时支持IPv4/IPv6双协议栈模式,既支持IPv4报文的路由转发,也支持IPv6报文的路由转发。
mce:配置设备的工作模式为MCE模式。
【描述】
switch-mode命令用来切换设备运行时支持的协议栈模式。
缺省情况下,设备运行时仅支持IPv4协议栈。
&  说明:
l      执行switch-mode命令切换的协议栈只有在重启设备后才能生效。
l      在启动双协议栈功能之前,必须先将设备运行模式切换到IPv4/IPv6双协议栈模式,即执行switch-mode dual-ipv4-ipv6命令;否则,即使启动双协议栈,设备也不支持IPv6报文的转发。
l      关于MCE模式的详细介绍请参见本手册“MCE”部分。
# 配置设备运行时支持IPv4/IPv6双协议栈模式。
[Sysname] switch-mode dual-ipv4-ipv6
第3章  隧道技术配置命令
3.1  隧道技术配置命令
aggregation-group aggregation-group-id
undo aggregation-group
Tunnel接口视图
aggregation-group-id所引用的链路聚合组ID。取值范围1~26。
【描述】
aggregation-group命令用来指定隧道引用的链路聚合组。undo aggregation-group命令用来取消为隧道指定的链路聚合组。
缺省情况下,隧道未引用任何链路聚合组。
在Tunnel接口视图下指定隧道引用的链路聚合组之前,必须在系统视图下先配置链路聚合组,并设置该链路聚合组的服务类型为tunnel,然后再在Tunnel接口视图下指定隧道引用的链路聚合组。
一个Tunnel接口只能引用一个链路聚合组。
相关配置可参考本手册“链路聚合命令”中的命令link-aggregation group
# 创建并配置链路聚合组1,配置模式为manual,服务类型为tunnel。
[Sysname] link-aggregation group 1 mode manual
[Sysname] link-aggregation group 1 service-type tunnel
# 将一个二层Ethernet接口加入链路聚合组1
[Sysname] interface ethernet 1/0/2
[Sysname-Ethernet1/0/2] stp disable
[Sysname-Ethernet1/0/2] port link-aggregation group 1
[Sysname-Ethernet1/0/2] quit
# Tunnel接口视图下配置隧道引用的链路聚合组1
[Sysname] interface tunnel 2
[Sysname-Tunnel2] aggregation-group 1
3.1.2  destination
destination ip-address
undo destination
Tunnel接口视图
ip-address:指定Tunnel接口的目的端IPv4地址。
【描述】
destination命令用来指定Tunnel接口的目的端地址。undo destination命令用来删除设置的目的端地址。
缺省情况下,Tunnel接口上没有设置目的端地址。
l              Tunnel接口的目的端地址是对端接收报文的接口地址,该地址一般设置为对端Tunnel接口的源端地址。
l              对两个或两个以上使用同种封装协议的Tunnel接口,不能同时配置完全相同的源端地址和目的端地址。
相关配置可参考命令interface tunnelsource
# 配置Sysname1的Vlan-interface接口(IP地址是193.101.1.1)和Sysname2的Vlan-interface接口(IP地址是192.100.1.1)分别为两个设备间隧道的源和目的接口。
<Sysname1> system-view
[Sysname1] interface tunnel 0
[Sysname1-Tunnel0] source 193.101.1.1
[Sysname1-Tunnel0] destination 192.100.1.1
<Sysname2> system-view
[Sysname2] interface tunnel 1
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
display interface tunnel [ number ]
number:Tunnel接口号。如果不指定此参数,将显示所有Tunnel接口的信息。
【描述】
display interface tunnel命令用来显示指定Tunnel接口的相关信息,包括源地址、目的地址、封装模式等信息。
相关配置可参考命令interface tunnelsourcedestinationtunnel-protocol
# 显示Tunnel0通道接口信息。
<Sysname> display interface tunnel 0
Tunnel0 current state: UP
The Maximum Transmit Unit is 64000
Internet Address is 10.1.2.1/24 Primary
Encapsulation is TUNNEL, aggregation ID not set
Tunnel source 192.13.2.1, destination 192.13.2.2
Tunnel keepalive disable
Tunnel protocol/transport GRE/IP
    GRE key disabled
    Checksumming of GRE packets disabled
    Last 300 seconds input:  0 bytes/sec, 0 packets/sec
    Last 300 seconds output:  0 bytes/sec, 0 packets/sec
    361 packets input,  9953388 bytes
    0 input error
    361 packets output,  30324 bytes
    0 output error
表3-1 display interface tunnel命令显示信息描述表
Tunnel接口物理层通达
Tunnel接口链路层通达
Tunnel接口描述信息
Tunnel0 Interface
Tunnel接口编号
TunnelMTU的大小
封装成隧道协议
aggregation ID
隧道引用的链路聚合组ID,如果产品支持配置链路聚合组,则此处显示隧道接口下配置的链路聚合组ID,如果不支持或未配置,此处显示aggregation ID not set
Tunnel source
Tunnel源地址
destination
Tunnel目的地址
不启用GRE的 keepalive,Tunnel接口的状态不被探测
隧道的协议和传输协议
GRE key disabled
未设置GRE类型隧道接口的密钥
未使能GRE报文校验和功能
离现在最近的5分钟内,每秒输入字节数和报文数
离现在最近的5分钟内,每秒输出字节数和报文数
packets input
总计输入的报文数
input error
在所有输入的报文中,出现错误的报文数
packets output
总计输出的报文数
output error
在所有输出的报文中,出现错误的报文数
display ipv6 interface tunnel number
number:Tunnel接口号。
【描述】
display ipv6 interface tunnel命令用来显示指定Tunnel接口的IPv6相关信息,包括Tunnel接口链路状态、IPv6协议状态,Tunnel接口IPv6地址等信息。
# 显示Tunnel0通道接口信息。
<Sysname> display ipv6 interface tunnel 0
Tunnel0 current state :UP
IPv6 is enabled, link-local address is FE80::101:101
    2002:101:101::1, subnet is 2002::/16
    FF02::1:FF01:101
    FF02::1:FF00:1
    FF02::2
    FF02::1
  MTU is 1500 bytes
表3-2 display interface tunnel命令显示信息描述表
Tunnel接口物理层通达
Tunnel接口链路层通达
IPv6 is enabled
Tunnel接口IPv6使能
link-local address
Tunnel接口链路本地地址
Tunnel接口全球单播地址
Tunnel接口组播地址
MTU is 1500 bytes
Tunnel中MTU的大小,本例为1500bytes
ND reachable time
邻居发现报文可达时间
邻居发现报文重传间隔时间
主机采用IPv6地址无状态自动配置协议
expediting enable
undo expediting enable
Tunnel接口视图
【描述】
expediting enable命令用来使能快速终结功能。undo expediting enable命令用于关闭快速终结功能。
缺省情况下,快速终结功能处于关闭状态。
# 使能快速终结功能。
[Sysname-Tunnel2] expediting enable
expediting subnet ip-address mask
undo expediting subnet
Tunnel接口视图
ip-address:指定隧道的快速终结子网地址。
mask:指定隧道的快速终结子网掩码。
【描述】
expediting subnet命令用来配置快速终结子网地址和掩码。undo expediting subnet命令用来恢复缺省情况。
缺省情况下,隧道未配置快速终结子网。
l              在Tunnel接口视图下配置快速终结子网之前,必须在Tunnel接口视图下先使能快速终结。
l              对于手动隧道(如IPv6手动隧道),没有expediting subnet命令,当使能快速终结后,系统自动将隧道目的地址作为快速终结子网地址,掩码为255.255.255.255。
l              对于自动隧道(如IPv4兼容IPv6自动隧道、6to4隧道、ISATAP隧道),在配置了expediting enable命令后,需要配置expediting subnet命令指定快速终结子网和掩码。
# 在6to4隧道的Tunnel接口下配置隧道快速终结,先使能快速终结,然后配置快速终结子网地址为1.1.1.2,掩码为255.255.255.0。
[Sysname] interface Tunnel 1
[Sysname-Tunnel1] tunnel-protocol ipv6-ipv4 6to4
[Sysname-Tunnel1] expediting enable
The expediting subnet needs to be configured, or else the expediting is not available.
[Sysname-Tunnel1] expediting subnet 1.1.1.2 255.255.255.0
undo interface tunnel number
number:Tunnel接口号,取值范围为0~1023,但实际可建的Tunnel数目将受到接口总数及内存状况的限制。
【描述】
interface tunnel命令用来创建一个Tunnel接口,并进入该Tunnel接口视图。undo interface tunnel命令用来删除指定的Tunnel接口。
缺省情况下,设备上无Tunnel接口。
l              执行interface tunnel命令进入指定隧道的接口视图。如果Tunnel接口尚未创建,则先创建再进入接口视图。
l              Tunnel接口号只具有本地意义,隧道两端可以使用相同或不同的接口号。
相关配置可参考命令display interface tunnelsourcedestinationtunnel-protocol
# 创建接口Tunnel3。
[Sysname] interface tunnel 3
[Sysname-Tunnel3]
mtu mtu-size
undo mtu
Tunnel接口视图
mtu-size:Tunnel接口MTU的大小,取值范围为100~64000,单位为字节。
【描述】
mtu命令用来设置隧道接口的MTU值。undo mtu命令用来恢复缺省情况。
# 设置隧道接口的MTU值为10000。
[Sysname-Tunnel3] mtu 10000
3.1.9  source
source { ip-address | interface-type interface-number }
undo source
Tunnel接口视图
ip-address:指定Tunnel接口的源端IPv4地址。
interface-type interface-number:Tunnel接口类型及接口编号,接口类型包括:Vlan-interface和Loopback接口。
【描述】
source命令用来指定Tunnel接口的源端地址或接口。undo source命令用来删除设置的源端地址或接口。
缺省情况下,Tunnel接口上没有设置源端地址和接口。
l              Tunnel接口的源端地址是发出报文的接口地址,该地址一般设置为对端Tunnel接口的目的端地址。
l              对两个或两个以上使用同种封装协议的Tunnel接口,不能同时配置完全相同的源地址和目的端地址。
相关配置可参考命令interface tunneldestination
# 配置Tunnel5接口,此接口封装的报文实际出口为Vlan-interface 10接口(接口IP地址为192.100.1.1)。
[Sysname] interface tunnel 5
[Sysname-Tunnel5] source 192.100.1.1
或使用接口形式:
[Sysname-Tunnel5] source Vlan-interface 10
tunnel-protocol ipv6-ipv4 [ 6to4 | auto-tunnel | isatap ]
undo tunnel-protocol
Tunnel接口视图
ipv6-ipv4表示IPv6 over IPv4 手工隧道模式。
ipv6-ipv4 6to4:表示IPv6 over IPv4 6to4隧道模式。
ipv6-ipv4 auto-tunnel:表示IPv6 over IPv4自动隧道模式。
ipv6-ipv4 isatap:表示IPv6 over IPv4 ISATAP隧道模式。
【描述】
tunnel-protocol命令用来配置隧道模式。undo tunnel-protocol命令用来恢复缺省情况。
缺省情况下,采用手动隧道模式。
l              可以根据网络拓扑和应用来选择适当的隧道模式,以进行不同方式的报文封装。在隧道的两端应配置相同的隧道模式,否则可能造成报文传输失败。
l              同一隧道起点只能创建一条自动隧道。
# 配置Tunnel接口的隧道模式为手动隧道模式。
[Sysname] interface Tunnel 2
[Sysname-Tunnel2] tunnel-protocol ipv6-ipv4
