- H3C SR8800-X Router Series Installation Guide-5W105
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Router
- 03-Chapter 3 Installing FRUs
- 04-Chapter 4 Connecting Your Router to the Network
- 05-Chapter 5 Troubleshooting
- 06-Chapter 6 Replacement Procedures
- 07-Appendix A Chassis Views and Technical Specifications
- 08-Appendix B FRUs and Compatibility Matrixes
- 09-Appendix C LEDs
- 10-Appendix D Slot arrangement and port numbering
- 11-Appendix E Cables
- 12-Appendix F Engineering Labels for Cables and Devices
- 13-Appendix G Cabling Recommendations
- 14-Appendix H Repackaging the Router
| 08-Appendix B FRUs and Compatibility Matrixes | 319.00 KB |
Appendix B FRUs and compatibility matrixes
For compatibility between the cards and the software release, see the release notes.
For compatibility between the cards and transceiver modules, see the card and transceiver module compatibility matrix for the device.
MPUs
MPU model |
SDRAM |
Ports |
Port speed |
Cables and max transmission distance |
Applicable router models |
SR05SRP1L1 |
8 GB |
· 1 × console port · 1 × USB console port · 1 × network management port · 1 × CF card slot · 1 × USB 2.0 port |
· Console port: ≤ 115200 bps (default: 9600 bps) · USB console port: ≤ 115200 bps (default: 9600 bps) · Network management port: 10/100/1000 Mbps |
· Console port: ≤ 15 m (49.21 ft) over ordinary asynchronous serial cables · USB console port: ≤ 2 m (6.56 ft) over USB-AB cables · Network management port: 100 m (328.08 ft) over Category 5 or higher twisted pair cables |
SR8804-X, SR8808-X, and SR8812-X |
SR05SRP1L3 |
8 GB or 16 GB |
· 1 × console port · 1 × USB console port · 1 × network management port · 1 × CF card slot · 1 × USB 2.0 port · 2 × SMB coaxial clock output ports · 2 × SMB coaxial clock input ports · 2 × high-precision time synchronization ports (default: input ports) |
· Console port: ≤ 115200 bps (default: 9600 bps) · USB console port: ≤ 115200 bps (default: 9600 bps) · Network management port: 10/100/1000 Mbps · SMB coaxial clock port: 2.048 Mbps · High-precision time synchronization port: 9600 bps |
· Console port: ≤ 15 m (49.21 ft) over ordinary asynchronous serial cables · USB console port: ≤ 2 m (6.56 ft) over USB-AB cables · Network management port: 100 m (328.08 ft) over Category 5 or higher twisted pair cables · SMB coaxial clock port: 75-ohm coaxial cables · High-precision time synchronization port: Category 5 or higher twisted pair cables |
CSR05SRP1P1 |
8 GB |
· 1 × console port · 1 × USB console port · 2 × network management ports (port 1 reserved) · 1 × USB 2.0 port |
SR8808H-X and SR8816-X |
SR05SRP1P3 |
16 GB |
· 1 × console port · 1 × USB console port · 2 × network management ports (port 1 reserved) · 1 × CF card slot · 1 × USB 2.0 port · 2 × SMB coaxial clock output ports · 2 × SMB coaxial clock input ports · 2 × high-precision time synchronization ports (default: input ports) |
CSR05SRP1P3-G |
16 GB |
· 1 × RJ-45 console port · 1 × mini USB console port · 2 × RJ-45 network management ports · 1 × USB 2.0 port · 2 × SMB coaxial clock output ports · 2 × SMB coaxial clock input ports · 2 × RJ-45 high-precision time synchronization ports |
· Console port: ≤ 115200 bps (default: 9600 bps) · Network management port: 1000 Mbps, full duplex · SMB coaxial clock port: 2.048 Mbps · High-precision time synchronization port: 9600 bps |
· Console port: ≤ 15 m (49.21 ft) over ordinary asynchronous serial cables · Network management port: 100 m (328.08 ft) over Category 5 or higher twisted pair cables · SMB coaxial clock port: 75-ohm coaxial cables · High-precision time synchronization port: Category 5 or higher twisted pair cables |
CSR05SRP1R3 |
2 × 16 GB |
· 1 × console port · 1 × USB console port · 2 × network management ports (port 1 reserved) · 1 × USB 2.0 port · 2 × SMB coaxial clock output ports · 2 × SMB coaxial clock input ports · 2 × high-precision time synchronization ports (default: input ports) |
· Console port: ≤ 115200 bps (default: 9600 bps) · USB console port: ≤ 115200 bps (default: 9600 bps) · Network management port: 1000 Mbps, full duplex · SMB coaxial clock port: 2.048 Mbps · High-precision time synchronization port: 9600 bps |
IMPORTANT: The USB port on the router does not support extension cables. |
Service modules
IMPORTANT: For adequate ventilation and cooling, install the CEPC-CP4RX, CEPC-XP48RX, CEPC-XP24LX, CSPEX-1602X, IM-MSUX, IM-NGFWX-IV, IM-IPSX-IV, and IM-ACG1000X-IV cards in the following slots only when the other slots are not available. · SR8808-X router—Slots 0, 8 and 9. · SR8812-X router—Slots 0 and 13. |
NOTE: A card has a mark on it for identification. The card models in this section are card marks. |
SPC/CSPC cards
Table 2 SPC/CSPC card specifications
Model |
Connector |
Number of ports |
Port speed |
SPC-GT48LA1 |
48-port 10/100/1000BASE-T Ethernet interface module (RJ45) (A Type) |
RJ-45 |
48 |
10/100/1000 Mbps |
CSPC-GE24L-E |
24-port 1000BASE-X Ethernet combo interface line processing unit (E Type) |
RJ-45 |
24 |
10/100/1000 Mbps |
LC |
24 |
1000 Mbps |
SPC-GP24LA1 |
16-port 1000BASE-X Ethernet optical interface (SFP, LC) + 8-port combo interface module (A Type) |
RJ-45 |
8 |
10/100/1000 Mbps |
LC |
24 |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
SPC-GP48LA1 |
48-port 1000BASE-X Ethernet optical interface module (SFP, LC) (A Type) |
LC |
48 |
100 Mbps |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
SPC-GP48LB |
48-port enhanced 1000BASE-X Ethernet optical interface module (SFP, LC) (B Type) |
LC |
48 |
100 Mbps |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
SPC-GP24XP2LA |
16-port 1000BASE-X Ethernet optical interface (SFP, LC) + 8-port combo interface + 2-port 10GE optical interface module (XFP, LC) (A Type) |
RJ-45 |
8 |
10/100/1000 Mbps |
LC |
24 |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
2 |
10 Gbps |
SPC-GP24XP2LB |
16-port 1000BASE-X optical interface (SFP, LC) + 8-port combo interface + 2-port 10GE optical interface module (XFP, LC) (B Type) |
RJ-45 |
8 |
10/100/1000 Mbps |
LC |
24 |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
2 |
10 Gbps |
CSPC-GP24GE8XP2L-E |
24-port 1000BASE-X Ethernet optical interface (SFP, LC) + 8-port 1000BASE-X Ethernet combo interface + 2-port 10GBASE-R/W Ethernet optical interface line processing unit (SFP+, LC) (E Type) |
RJ-45 |
8 |
10/100/1000 Mbps |
LC |
32 |
1000 Mbps |
2 |
10 Gbps |
CSPC-GE16XP4L-E |
16-port 1000BASE-X Ethernet combo interface + 4-port 10GBASE-R/W Ethernet optical interface line processing unit (SFP+,LC) (E Type) |
RJ-45 |
16 |
10/100/1000 Mbps |
LC |
16 |
1000 Mbps |
4 |
10 Gbps |
SPC-GP44XP4LAX |
44-port 1000BASE-X Ethernet optical interface module (SFP, LC) + 4-port 10GBASE Ethernet optical interface module (SFP+, LC) (A Type) |
LC |
44 |
100 Mbps |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
4 |
10 Gbps |
SPC-GP44XP4LCX |
44-port 1000BASE-X Ethernet optical interface module (SFP, LC) + 4-port 10GBASE Ethernet optical interface module (SFP+, LC) (C Type) |
LC |
44 |
100 Mbps |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
4 |
10 Gbps |
SPC-XP2LA1 |
2-port 10GBASE Ethernet optical interface module (XFP, LC) (A Type) |
LC |
2 |
10 Gbps |
SPC-XP4LA1 |
4-port 10GBASE Ethernet optical interface module (XFP, LC) (A Type) |
LC |
4 |
10 Gbps |
SPC-XP4LB |
4-port Enhanced 10GBASE Ethernet optical interface module (XFP, LC) (B Type) |
LC |
4 |
10 Gbps |
SPC-XP8LA |
8-port 10GBASE Ethernet optical interface module (SFP+, LC) (A Type) |
LC |
8 |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
SPC-XP8LB |
8-port Enhanced 10GBASE Ethernet optical interface module (SFP+, LC) (B Type) |
LC |
8 |
10 Gbps |
SPC-XP12LCX |
12-port 10GBASE Ethernet optical interface module (SFP+, LC) (C Type) |
LC |
12 |
10 Gbps |
SPC-XP12LAX |
12-port 10GBASE Ethernet optical interface module (SFP+, LC) (A Type) |
LC |
12 |
10 Gbps |
SPC-XP24LAX |
24-port 10GBASE Ethernet optical interface module (SFP+, LC) (A Type) |
LC |
24 |
10 Gbps |
SPC-XP24LCX |
LC |
24 |
10 Gbps |
SPC-XLP6LAX |
6-port 40GBASE Ethernet optical interface module (QSFP+, MPO) (A Type) |
LC/MPO |
6 |
40 Gbps |
SPC-XLP6LCX |
6-port 40GBASE Ethernet optical interface module (QSFP+, MPO) (C Type) |
LC/MPO |
6 |
40 Gbps |
SPC-CP1LAX |
1-port 100GBASE Ethernet optical interface module (CFP, LC) (A Type) |
LC |
1 |
100 Gbps |
SPC-CP1LCX |
1-port 100GBASE Ethernet optical interface module (CFP, LC) (C Type) |
LC |
1 |
100 Gbps |
SPC-CP2LA |
2-port 100GBASE Ethernet optical interface module (CFP, LC) (A Type) |
LC |
2 |
100 Gbps |
SPC-CP2LB |
2-port 100GBASE Ethernet optical interface module (CFP, LC) (B Type) |
LC |
2 |
100 Gbps |
NOTE: A combo interface is a logical interface that contains an SFP port and an RJ-45 Ethernet port. Only one of them can be activated at a time. |
Table 3 Compatibility matrixes between SPC/CSPC cards and routers
Model |
SR8804-X/SR8808-X/SR8812-X |
SR8808H-X/SR8816-X |
SPC-GT48LA1 |
Supported |
Not supported |
CSPC-GE24L-E |
Supported |
Not supported |
SPC-GP24LA1 |
Supported |
Not supported |
SPC-GP24XP2LA |
Supported |
Not supported |
SPC-GP24XP2LB |
Supported |
Not supported |
Supported |
Not supported |
CSPC-GE16XP4L-E |
Supported |
Not supported |
SPC-XP2LA1 |
Supported |
Not supported |
SPC-XP4LA1 |
Supported |
Not supported |
SPC-XP4LB |
Supported |
Not supported |
SPC-XP8LA |
Supported |
Not supported |
SPC-XP8LB |
Supported |
Not supported |
SPC-GP48LA1 |
Supported |
Not supported |
SPC-GP48LB |
Supported |
Not supported |
SPC-GP44XP4LCX |
Supported |
Not supported |
SPC-GP44XP4LAX |
Supported |
Not supported |
SPC-XP24LCX |
Supported |
Not supported |
SPC-XP24LAX |
Supported |
Not supported |
SPC-XP12LCX |
Supported |
Not supported |
SPC-XP12LAX |
Supported |
Not supported |
SPC-XLP6LCX |
Supported |
Not supported |
SPC-XLP6LAX |
Supported |
Not supported |
SPC-CP1LCX |
Supported |
Not supported |
SPC-CP1LAX |
Supported |
Not supported |
SPC-CP2LB |
Supported |
Not supported |
SPC-CP2LA |
Supported |
Not supported |
CEPC cards
Table 4 CEPC card specifications
Model |
Connector |
Number of ports |
Port speed |
CEPC-XP4LX |
4-port 10GBASE-R/W Ethernet optical interface line processing unit module (SFP+, LC) |
LC |
4 |
10 Gbps |
CEPC-XP24LX |
24-port 10GBASE-R/W Ethernet optical interface line processing unit (SFP+, LC) |
LC |
24 |
10 Gbps |
CEPC-XP48RX |
48-port 10GBASE-R/W Ethernet optical interface module (SFP+, LC) |
LC |
48 |
10 Gbps |
CEPC-CP4RX |
4-port 100GBASE Ethernet optical interface module (CFP2) |
LC |
4 |
100 Gbps |
CEPC-CP4RX-L |
4-port 100G Ethernet optical interface line processing unit (QSFP28, LC) |
LC |
4 |
100 Gbps |
40 Gbps |
CEPC-CQ8L |
8-port 100G Ethernet optical interface line processing unit (QSFP28, LC) |
LC |
8 |
100 Gbps |
CEPC-CQ16L1 |
16-port 100G Ethernet optical interface line processing unit (QSFP28,LC) |
LC |
16 |
100 Gbps |
Table 5 Compatibility matrixes between CEPC cards and routers
Model |
SR8804-X |
SR8808-X/SR8812-X |
CEPC-CP4RX |
Not supported |
Supported |
Supported |
CEPC-CP4RX-L |
Not supported |
Supported |
Supported |
CEPC-XP48RX |
Not supported |
Supported |
Supported |
CEPC-XP24LX |
Not supported |
Supported |
Supported |
CEPC-XP4LX |
Supported |
Supported |
Supported |
CEPC-CQ8L |
Not supported |
Not supported |
Supported |
CEPC-CQ16L1 |
Not supported |
Not supported |
Supported |
SPEX/CSPEX base cards
IMPORTANT: An SR8804-X router installed with Type-A switching fabric modules does not support the CSPEX-1304X, CSPEX-1404X, or CSPEX-1504X cards. |
Table 6 SPEX/CSPEX base card specifications
Model |
Subslot quantity |
SPEX-1204 |
4 |
CSPEX-1104-E |
4 |
CSPEX-1304X |
4 |
CSPEX-1404X |
4 |
CSPEX-1502X |
2 |
CSPEX-1504X |
4 |
CSPEX-1602X |
2 |
CSPEX-1802X |
2 |
CSPEX-1802XB |
2 |
CSPEX-1804X |
4 |
CSPEX-1512X |
2 |
CSPEX-1612X |
2 |
CSPEX-1812X |
2 |
CSPEX-1812X-E |
2 |
CSPEX-2304X-G |
4 |
CSPEX-2612X-E |
2 |
Table 7 Compatibility matrixes between SPEX/CSPEX base cards and routers
Model |
SR8804-X |
SR8808-X |
SR8812-X |
SPEX-1204 |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1104-E |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1304X |
Supported |
Supported |
Supported |
Supported |
CSPEX-1404X |
Supported |
Supported |
Supported |
Supported |
CSPEX-1502X |
Not supported |
Supported |
Supported |
Supported |
CSPEX-1504X |
Supported |
Supported |
Supported |
Supported |
CSPEX-1602X |
Not supported |
Supported |
Supported |
Supported |
CSPEX-1802X |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1802XB |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1804X |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1512X |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1612X |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1812X |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1812X-E |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-2304X-G |
Supported |
Supported |
Not supported |
Supported |
CSPEX-2612X-E |
Not supported |
Not supported |
Not supported |
Supported |
Table 8 Compatibility matrixes between SPEX/CSPEX base cards and subcards (1)
Subcard model |
SPEX-1204 |
CSPEX-1304X |
CSPEX-1504X/CSPEX-1404X |
PIC-GP10L |
Supported in subslots 1 and 2 Not supported in subslot 3 or 4 |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
PIC-PSP4L |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
MIC-ET16L |
Supported |
Supported |
Supported |
MIC-CLP2L |
Supported |
Supported |
Supported |
MIC-CLP4L |
Supported |
Supported |
Supported |
MIC-SP4L |
Supported |
Supported |
Supported |
MIC-SP8L |
Supported |
Supported |
Supported |
MIC-GP4L |
Not supported in subslot 1 or 2 Supported in subslots 3 and 4 |
Supported |
Supported |
MIC-GP8L |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
MIC-GP10L-V2 |
Not supported |
Supported in subslots 1 to 3 Not supported in subcard slot 4 |
Supported |
MIC-GP20L |
Not supported |
MIC-GP20L1 |
Not supported |
Not supported |
Not supported |
MIC-XP2L |
Not supported |
Supported |
Supported |
MIC-XP2L-LAN |
Not supported |
Supported |
Supported |
MIC-XP4L1 |
Not supported |
Supported |
Supported |
MIC-XP5L |
Not supported |
Supported |
Supported |
MIC-XP5L1 |
Not supported |
Supported |
Supported |
MIC-XP8L |
Not supported |
Not supported |
Not supported |
MIC-XP20L |
Not supported |
Not supported |
Not supported |
MIC-QP1L |
Not supported |
Supported |
Supported |
MIC-CP1L |
Not supported |
Not supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
Not supported |
MIC-CP2L |
Not supported |
Not supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Not supported |
MIC-CQ2L |
Not supported |
Not supported |
Not supported |
MIC-PSP4L |
Not supported |
Supported |
Supported |
MIC-TCP8L |
Not supported |
Supported in subslots 1 to 3 Not supported in subslot 4 |
Supported |
NIC-GT20L |
Not supported |
Not supported |
Not supported |
NIC-GP20L |
Not supported |
Not supported |
Not supported |
NIC-GP24L |
Not supported |
Not supported |
Not supported |
NIC-GP24L1 |
Not supported |
Not supported |
Not supported |
NIC-GP24L1B |
Not supported |
Not supported |
Not supported |
NIC-XP5L |
Not supported |
Not supported |
Not supported |
NIC-XP10L |
Not supported |
Not supported |
Not supported |
NIC-XP20L |
Not supported |
Not supported |
Not supported |
NIC-XP20L1 |
Not supported |
Not supported |
Not supported |
NIC-XP20L1B |
Not supported |
Not supported |
Not supported |
NIC-CC1L |
Not supported |
Not supported |
Not supported |
NIC-CC2L |
Not supported |
Not supported |
Not supported |
NIC-CQ1L |
Not supported |
Not supported |
Not supported |
NIC-CQ2L |
Not supported |
Not supported |
Not supported |
NIC-CQ2LB |
Not supported |
Not supported |
Not supported |
RX-NIC-GP20L |
Not supported |
Not supported |
Not supported |
RX-NIC-XP5L |
Not supported |
Not supported |
Not supported |
RX-NIC-XP10L |
Not supported |
Not supported |
Not supported |
RX-NIC-XP20L |
Not supported |
Not supported |
Not supported |
RX-NIC-YGS4L |
Not supported |
Not supported |
Not supported |
RX-NIC-LGQ2L |
Not supported |
Not supported |
Not supported |
RX-NIC-LGQ4L |
Not supported |
Not supported |
Not supported |
RX-NIC-CQ1LF |
Not supported |
Not supported |
Not supported |
RX-NIC-CQ2LF |
Not supported |
Not supported |
Not supported |
RX-NIC-CC1L |
Not supported |
Not supported |
Not supported |
RX-NIC-CC2L |
Not supported |
Not supported |
Not supported |
Table 9 Compatibility matrixes between SPEX/CSPEX base cards and subcards (2)
Subcard model |
CSPEX-1502X |
CSPEX-1602X |
CSPEX-1804X |
CSPEX-1512X |
CSPEX-1612X |
PIC-GP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-ET16L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CLP2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CLP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L1 |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-XP2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP2L-LAN |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP4L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP8L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP20L |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-QP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
MIC-CP2L |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ2L |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-PSP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-TCP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GT20L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
NIC-GP20L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
NIC-GP24L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
NIC-GP24L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L1B |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP5L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
NIC-XP10L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
NIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP20L1B |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CC1L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-CC2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CQ1L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-CQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CQ2LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-GP20L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
RX-NIC-XP5L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
RX-NIC-XP10L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
RX-NIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-YGS4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-LGQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-LGQ4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CQ2LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CC1L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
RX-NIC-CC2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Table 10 Compatibility matrixes between SPEX/CSPEX base cards and subcards (3)
Subcard model |
CSPEX-1812X |
CSPEX-1812X-E |
CSPEX-1802X |
CSPEX-1802XB |
CSPEX-1104-E |
CSPEX-2304X-G |
CSPEX-2612X-E |
PIC-GP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported, a maximum of 3 |
Supported |
Not supported |
MIC-GP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-CLP2L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-CLP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-SP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-ET16L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
MIC-XP2L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-XP2L-LAN |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-XP4L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
MIC-XP5L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
MIC-XP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
MIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-QP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
MIC-CQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-PSP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-TCP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
NIC-GT20L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP20L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L1 |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-GP24L1B |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP5L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-XP10L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-XP20L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP20L1 |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-XP20L1B |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
NIC-CC1L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CC2L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CQ1L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-CQ2L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-CQ2LB |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
RX-NIC-GP20L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-XP5L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
RX-NIC-XP10L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
RX-NIC-XP20L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
RX-NIC-YGS4L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
RX-NIC-LGQ2L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-LGQ4L |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
RX-NIC-CQ1LF |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CQ2LF |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Supported |
RX-NIC-CC1L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CC2L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
IMPORTANT: A CSPEX-1104-E base card supports a maximum of three MIC-XP4L1 or MIC-GP4L subcards or a maximum of three of them in combinations. |
MPE base cards
Table 11 MPE base card specifications
Model |
Subslot quantity |
MPE-1104 |
4 |
Table 12 Compatibility matrixes between MPE base cards and routers
Model |
SR8804-X |
SR8808-X/SR8812-X |
MPE-1104 |
Supported |
Supported |
Not supported |
Table 13 Compatibility matrixes between MPE base cards and subcards
Subcard model |
MPE-1104 |
PIC-GP10L |
Not supported |
PIC-TCP8L |
Not supported |
PIC-PSP4L |
Not supported |
PIC-PS2G4L |
Not supported |
PIC-PUP1L |
Not supported |
PIC-XP1L |
Not supported |
MIC-GT20L |
Not supported |
MIC-CLP4L |
Supported |
MIC-ET16L |
Supported |
MIC-CLP2L |
Supported |
MIC-SP8L |
Only one is supported and can be installed only in subslot 1 or 2. |
MIC-SP4L |
Supported |
MIC-GP4L |
Supported |
MIC-GP8L |
MIC-GP10L1 |
Not supported |
MIC-GP10L-V2 |
Not supported |
MIC-GP20L |
Not supported |
MIC-GP20L1 |
Not supported |
MIC-XP2L |
Not supported |
MIC-XP2L-LAN |
Not supported |
MIC-XP4L1 |
Not supported |
MIC-XP5L |
Not supported |
MIC-XP5L1 |
Not supported |
MIC-XP8L |
Not supported |
MIC-XP20L |
Not supported |
MIC-QP1L |
Not supported |
MIC-CP1L |
Not supported |
MIC-CP1L-V2 |
Not supported |
MIC-CP2L |
Not supported |
MIC-CP2L-V2 |
Not supported |
MIC-CQ1L1 |
Not supported |
MIC-CQ1L2 |
Not supported |
MIC-CQ2L |
Not supported |
MIC-PSP4L |
Not supported |
MIC-TCP8L |
Not supported |
NIC-GT20L |
Not supported |
NIC-GP20L |
Not supported |
NIC-GP24L |
Not supported |
NIC-GP24L1 |
Not supported |
NIC-GP24L1B |
Not supported |
NIC-XP5L |
Not supported |
NIC-XP10L |
Not supported |
NIC-XP20L |
Not supported |
NIC-XP20L1 |
Not supported |
NIC-XP20L1B |
Not supported |
NIC-CC1L |
Not supported |
NIC-CC2L |
Not supported |
NIC-CQ1L |
Not supported |
NIC-CQ2L |
Not supported |
NIC-CQ2LB |
Not supported |
RX-NIC-GP20L |
Not supported |
RX-NIC-XP5L |
Not supported |
RX-NIC-XP10L |
Not supported |
RX-NIC-XP20L |
Not supported |
RX-NIC-YGS4L |
Not supported |
RX-NIC-LGQ2L |
Not supported |
RX-NIC-LGQ4L |
Not supported |
RX-NIC-CQ1LF |
Not supported |
RX-NIC-CQ2LF |
Not supported |
RX-NIC-CC1L |
Not supported |
RX-NIC-CC2L |
Not supported |
NOTE: The subslot restrictions on an MPE base card depend on the subcard mode. For more information about the subcard mode, see device management in H3C SR8800-X Routers Fundamentals Configuration Guide. |
SPE base cards
Table 14 SPE base card specifications
Model |
Subslot quantity |
RX-SPE200 |
2 |
RX-SPE200-E |
2 |
Table 15 Compatibility matrixes between SPE base cards and routers
Model |
SR8804-X |
SR8808-X/SR8812-X |
RX-SPE200 |
Not supported |
Not supported |
Supported |
RX-SPE200-E |
Not supported |
Not supported |
Supported |
Table 16 Compatibility matrixes between SPE base cards and subcards
Subcard model |
RX-SPE200 |
RX-SPE200-E |
PIC-GP10L |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
Not supported |
MIC-CLP4L |
Not supported |
Not supported |
MIC-ET16L |
Not supported |
Not supported |
MIC-CLP2L |
Not supported |
Not supported |
MIC-SP8L |
Not supported |
Not supported |
MIC-SP4L |
Not supported |
Not supported |
MIC-GP4L |
Not supported |
Not supported |
MIC-GP8L |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
MIC-GP10L-V2 |
Not supported |
Not supported |
MIC-GP20L |
Not supported |
Not supported |
MIC-GP20L1 |
Not supported |
Not supported |
MIC-XP2L |
Not supported |
Not supported |
MIC-XP2L-LAN |
Not supported |
Not supported |
MIC-XP4L1 |
Not supported |
Not supported |
MIC-XP5L |
Not supported |
Not supported |
MIC-XP5L1 |
Not supported |
Not supported |
MIC-XP8L |
Not supported |
Not supported |
MIC-XP20L |
Not supported |
Not supported |
MIC-QP1L |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
MIC-CP2L |
Not supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
MIC-CQ2L |
Not supported |
Not supported |
MIC-PSP4L |
Not supported |
Not supported |
MIC-TCP8L |
Not supported |
Not supported |
NIC-GT20L |
Supported |
Not supported |
NIC-GP20L |
Supported |
Not supported |
NIC-GP24L |
Not supported |
Not supported |
NIC-GP24L1 |
Not supported |
Supported |
NIC-GP24L1B |
Not supported |
Not supported |
NIC-XP5L |
Not supported |
Not supported |
NIC-XP10L |
Supported |
Not supported |
NIC-XP20L |
Not supported |
Not supported |
NIC-XP20L1 |
Not supported |
Not supported |
NIC-XP20L1B |
Not supported |
Not supported |
NIC-CC1L |
Not supported |
Not supported |
NIC-CC2L |
Not supported |
Not supported |
NIC-CQ1L |
Supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Not supported |
NIC-CQ2L |
Not supported |
Not supported |
NIC-CQ2LB |
Not supported |
Not supported |
RX-NIC-GP20L |
Supported |
Not supported |
RX-NIC-XP5L |
Supported |
Supported |
RX-NIC-XP10L |
Supported |
Supported |
RX-NIC-XP20L |
Not supported |
Not supported |
RX-NIC-YGS4L |
Supported |
Supported |
RX-NIC-LGQ2L |
Supported |
Supported |
RX-NIC-LGQ4L |
Not supported |
Not supported |
RX-NIC-CQ1LF |
Supported |
Supported |
RX-NIC-CQ2LF |
Not supported |
Not supported |
RX-NIC-CC1L |
Supported |
Supported |
RX-NIC-CC2L |
Not supported |
Not supported |
Subcards
The subcards are installed in the MPE, SPE, or SPEX/CSPEX base cards, instead of being installed in the router directly.
PIC subcards
Table 17 PIC subcard specifications
Model |
Connector |
Number of ports |
Port speed |
PIC-GP10L |
10-port 1000BASE-X optical interface card (SFP, LC) |
LC |
10 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
PIC-TCP8L |
8-port OC-3c/OC-12c POS/GE optical interface card (SFP, LC) |
LC |
8 |
155 Mbps (OC-3/STM-1) |
622 Mbps (OC-12/STM-4) |
1000 Mbps |
10/100/1000 Mbps |
PIC-PSP4L |
4-port OC-48c/STM-16c POS optical interface card (SFP, LC) |
LC |
4 |
2.5 Gbps (OC-48/STM-16) |
PIC-PS2G4L |
2-port OC-48c/STM-16c POS optical interface (SFP, LC) + 4-port 1000BASE-X optical interface card (SFP, LC) |
LC |
2 |
LC |
4 |
1000 Mbps |
10/100/1000 Mbps |
PIC-PUP1L |
1-port OC-192c/STM-64c POS optical interface card (XFP, LC) |
LC |
1 |
10 Gbps (OC-192/STM-64) |
PIC-XP1L |
1-port 10GBASE-R/W Ethernet optical interface card (XFP, LC) |
LC |
1 |
10 Gbps |
MIC subcards
Table 18 MIC subcard specifications
Model |
Connector |
Number of ports |
Port speed |
MIC-GT20L |
20-port 1000BASE-X Ethernet electrical interface card (RJ45) |
RJ-45 |
20 |
10/100/1000 Mbps |
MIC-ET16L |
16-port E1 electrical interface card (HM96 male connector) |
HM96 male |
16 |
E1 |
MIC-CLP2L |
2-port OC-3/STM-1 channelized POS optical interface card (SFP, LC) |
LC |
2 |
MIC-CLP4L |
4-port OC-3/STM-1 channelized POS optical interface card (SFP, LC) |
LC |
4 |
MIC-SP4L |
4-port OC-3c/STM-1c POS/ATM or 1-port OC-12c/STM-4c POS/ATM optical interface card (SFP, LC) |
LC |
4 |
1 |
MIC-SP8L |
8-port OC-3c/STM-1c POS optical interface card (SFP, LC) |
LC |
8 |
MIC-GP4L |
4-port 1000BASE-X/1000BASE-T combo interface card |
RJ-45 |
4 |
10/100/1000 Mbps |
LC |
4 |
100 Mbps |
1000 Mbps |
MIC-GP8L |
8-port 1000BASE-X optical interface card (SFP, LC) |
LC |
8 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
MIC-GP10L1 |
LC |
10 |
1000 Mbps |
10/100/1000 Mbps |
MIC-GP10L-V2 |
10-port 1000BASE-X Ethernet optical interface card (SFP, LC) |
LC |
10 |
1000 Mbps |
10/100/1000 Mbps |
100 Mbps |
MIC-GP20L |
20-port 1000BASE-X Ethernet optical interface card (SFP, LC) |
LC |
20 |
1000 Mbps |
10/100/1000 Mbps |
100 Mbps |
MIC-GP20L1 |
LC |
20 |
1000 Mbps |
10/100/1000 Mbps |
100 Mbps |
MIC-XP2L |
2-port 10GBASE-R Ethernet optical interface card (SFP+, LC) |
LC |
2 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
MIC-XP2L-LAN |
2-port 10GBASE-R Ethernet optical interface card (SFP+, LC)-LAN |
LC |
2 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
MIC-XP4L1 |
4-port 10GBASE-R/W Ethernet optical interface card 1 (SFP+, LC) |
LC |
4 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
MIC-XP5L |
5-port 10GBASE-R/W Ethernet optical interface card (SFP+, LC) |
LC |
5 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
MIC-XP5L1 |
LC |
5 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
MIC-XP8L |
8-port 10GBASE-R/W Ethernet optical interface card (SFP+, LC) |
LC |
8 |
10 Gbps |
MIC-XP20L |
20-port 10GBASE-R/W Ethernet optical interface card (SFP+, LC) |
LC |
20 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
MIC-QP1L |
1-port 40G Ethernet optical interface card (QSFP+, LC) |
LC |
1 |
40 Gbps |
4 |
10 Gbps |
MIC-CP1L |
1-port 100G optical interface card (CFP, LC) |
LC |
1 |
100 Gbps |
MIC-CP1L-V2 |
1-port 100G Ethernet optical interface card (CFP2, LC) |
LC |
1 |
100 Gbps |
MIC-CP2L |
2-port 100G Ethernet optical interface card (CFP2, LC) |
LC |
2 |
100 Gbps |
MIC-CP2L-V2 |
2-port 100G Ethernet optical interface card (QSFP28) |
LC |
2 |
100 Gbps |
MIC-CQ1L1 |
1-port 100G Ethernet optical interface card |
LC |
1 |
100 Gbps |
40 Gbps |
MIC-CQ1L2 |
LC |
1 |
100 Gbps |
40 Gbps |
MIC-CQ2L |
LC |
2 |
100 Gbps |
40 Gbps |
MIC-PSP4L |
LC |
4 |
2.5 Gbps |
MIC-TCP8L |
LC |
8 |
10/100/1000 Mbps |
1000 Mbps |
NIC subcards
Table 19 NIC subcard specifications
Model |
Connector |
Number of ports |
Port speed |
NIC-GT20L |
20-port 1000BASE-T Ethernet copper interface card |
RJ-45 |
20 |
10/100/1000 Mbps |
NIC-GP20L |
20-port 1000BASE-X Ethernet optical interface card |
LC |
20 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
NIC-GP24L |
24-port 1000BASE-X Ethernet optical interface card |
LC |
24 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
NIC-GP24L1 |
LC |
24 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
NIC-GP24L1B |
24-port 1000BASE-X Ethernet optical interface card B |
LC |
24 |
1000 Mbps |
NIC-XP5L |
5-port 10GBASE-R/W Ethernet optical interface card |
LC |
5 |
10 Gbps |
NIC-XP10L |
10-port 10GBASE-R/W Ethernet optical interface card |
LC |
10 |
10 Gbps |
1000 Mbps |
NIC-XP20L |
20-port 10GBASE-R/W Ethernet optical interface card |
LC |
20 |
10 Gbps |
1000 Mbps |
NIC-XP20L1 |
LC |
20 |
10 Gbps |
1000 Mbps |
NIC-XP20L1B |
20-port 10GBASE-R/W Ethernet optical interface card B |
LC |
20 |
10 Gbps |
1000 Mbps |
NIC-CC1L |
LC |
1 |
100 Gbps |
NIC-CC2L |
2-port 100G Ethernet optical interface card |
LC |
2 |
100 Gbps |
NIC-CQ1L |
LC |
1 |
100 Gbps |
NIC-CQ2L |
LC |
2 |
100 Gbps |
NIC-CQ2LB |
2-port 100G Ethernet optical interface card B |
LC |
2 |
100 Gbps |
RX-NIC-GP20L |
LC |
20 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
RX-NIC-XP5L |
LC |
5 |
10 Gbps |
RX-NIC-XP10L |
LC |
10 |
10 Gbps |
RX-NIC-XP20L |
LC |
20 |
10 Gbps |
RX-NIC-YGS4L |
4-port 25G Ethernet optical interface card |
LC |
4 |
10 Gbps |
25 Gbps |
RX-NIC-LGQ2L |
2-port 50G Ethernet optical interface card |
LC |
2 |
· Standard Ethernet mode: 50 Gbps · Flexible Ethernet mode: 50 Gbps |
RX-NIC-LGQ4L |
4-port 50G Ethernet optical interface card |
LC |
4 |
RX-NIC-CQ1LF |
1-port 100G flexible Ethernet optical interface card |
LC |
1 |
· Standard Ethernet mode: 100 Gbps · Flexible Ethernet mode: 100 Gbps |
RX-NIC-CQ2LF |
2-port 100G flexible Ethernet optical interface card |
LC |
2 |
RX-NIC-CC1L |
LC |
1 |
100 Gbps |
RX-NIC-CC2L |
LC |
2 |
100 Gbps |
OAA modules
Table 20 OAA module specifications
Model |
Connector |
Number of ports |
Port speed |
IM-NGFWX-IV |
Firewall module |
RJ-45 |
1 |
10/100/1000 Mbps |
LSU1FWCEA0 |
Firewall module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
LSU3FWCEA0 |
Firewall module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
IM-IPSX-IV |
Intrusion prevention system module |
RJ-45 |
1 |
10/100/1000 Mbps |
LSU1IPSBEA0 |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
IM-ACG1000X-IV |
Application control gateway module |
RJ-45 |
1 |
10/100/1000 Mbps |
LSU1ADECEA0 |
Application delivery module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table 21 Compatibility matrixes between OAA modules and routers
Model |
IM-NGFWX-IV |
Supported |
Supported |
LSU1FWCEA0 |
Supported |
Not supported |
LSU3FWCEA0 |
Supported |
Not supported |
IM-IPSX-IV |
Supported |
Supported |
LSU1IPSBEA0 |
Supported |
Not supported |
IM-ACG1000X-IV |
Supported |
Supported |
LSU1ADECEA0 |
Supported |
Not supported |
IM modules
Universal line processing units
Table 22 Universal line processing unit specifications
Model |
IM-MSUX |
Universal line processing unit |
IM-MSEX-B |
Service processing unit |
IM-SP-B |
Universal expansion service processing module |
Table 23 Compatibility matrixes between universal line processing units and routers
Model |
SR8804-X |
SR8808-X/SR8812-X |
IM-MSUX (1 U) |
Supported |
Supported |
Supported |
IM-MSUX (1.2 U) |
Not supported |
Not supported |
Supported |
IM-MSEX-B |
Not supported |
Not supported |
Supported |
NOTE: · The IM-SP-B must be installed on an IM-MSEX-B for use. It occupies one subcard slot and does not provide ports. · The IM-MSEX-B provides one subcard slot. You can use it without a subcard, or use it with an IM-SP-B for double CGN packet processing rate. |
Security monitor line processing units
Table 24 Security monitor line processing unit specifications
Model |
IM-SMUX |
Security monitor line processing unit |
Table 25 Compatibility matrixes between security monitor line processing units and routers
Model |
SR8804-X |
SR8808-X/SR8812-X |
IM-SMUX |
Not supported |
Not supported |
Supported |
Network data encryption service processing unit
Table 26 Network data encryption service processing unit specifications
Model |
IM-SFMX |
Network data encryption service processing unit |
MIC-SM |
Network data encryption interface card |
Table 27 Compatibility matrixes between network data encryption service processing units and routers
Model |
SR8804-X |
SR8808-X/SR8812-X |
IM-SFMX |
Supported |
Supported |
Supported |
NOTE: · The MIC-SM is not hot swappable. · The MIC-SM must be installed on an IM-SFMX for use. It occupies one subcard slot. · The IM-SFMX provides one subcard slot. When used without a subcard, it uses non-SM algorithms to encrypt and decrypt network data. When used with an MIC-SM, it uses SM algorithms to encrypt and decrypt network data. |
Universal open application platform
CAUTION: The internal console port is provided only for H3C Support to perform maintenance and updates. Operations without permission are not allowed. H3C will not be liable for any consequences caused thereby. |
CAUTION: To avoid data loss on the hard disk, you must shut down the universal open application platform before performing the following operations: · Reboot or hot plug the universal open application platform. · Reboot or shut down the router. |
Table 28 Universal open application platform specifications
Component |
Specification |
Processor |
Intel Skylake Xeon CPU · A maximum power consumption of 205 W · A maximum of 2.6 GHz CPU clock speed · 38.5 MB cache |
Memory |
Support six DDR4 memory modules · Single DIMM capacity: 32 GB · Total memory capacity: 192 GB |
Storage |
Maximum storage capacity: 2 × 960 GB |
Chipset |
Intel C62x Lewisburg chipset compatible with LBG-T SKU |
User port |
· 2 × console ports · 1 × BMC network port · 1 × shared network port (can be used as an Ethernet port or a BMC network port) · 1 × VGA connector · 1 × USB connector (USB 3.0) · 2 × USB connectors (USB 2.0) |
IMPORTANT: · Do not install the universal open application platform in slot 6 of the SR8808-X router or slot 8 of the SR8812-X router. · The shared network interface can operate only at 1000 Mbps and can be connected only with a GE Ethernet port. · Do not use USB extension cables to connect the USB ports on the universal open application platform. |
Table 29 Hard disk specifications
Model |
Capacity |
Interface type |
Interface rate |
UIS-SSD-960GB-SATA-6G-SFF-EV |
960 G |
SATA |
6 Gbps |
UN-SSD-960G-SATA-6G-SFF-EV-1 |
960 G |
SATA |
6 Gbps |
Table 30 Compatibility matrixes between the universal open application platform and routers
Model |
SR8804-X |
SR8808-X/SR8812-X |
IM-OAPX |
Supported |
Supported |
Supported |
Switching fabric modules
CAUTION: The console port on a switching fabric module is only for H3C Support to perform maintenance and updates. Operations without permission are not allowed. H3C will not be liable for any consequences caused thereby. |
CAUTION: · Do not switching fabric modules of different types on the same router. · If you use Type-B, Type-D, Type-E, Type-T, or Type-TG switching fabric modules for the router, a minimum of two are required. You must install one in the lowest numbered slot. For an SR8808H-X router, you must install switching fabric modules in slots 10 and 12. Slot 11 can be used only when five switching fabric modules are required. For an SR8816-X router, you must install switching fabric modules in slots 18 and 20. Slot 19 can be used only when five switching fabric modules are required. For other routers, slots 1, 3, and 4 take precedence over the other slots. · If Type-A switching fabric modules are used, use the four together and install each into the specified slot. Each Type-A switching fabric module has a mark specifying the slot for installation. For example, the SFC-04-1 has the mark Notes:Please insert to Slot 6. |
Table 31 Switching fabric module ordering guide
Chassis model |
Available switching fabric module model |
Number |
SR8804-X |
Type-A: SFC-04-1, SFC-04-2, SFC-04-3, and SFC-04-4 |
1 |
· Type-B: SFC-04B · Type-D: SFC-04D |
2 to 4 |
SR8808-X |
· Type-B: SFC-08B · Type-D: SFC-08D · Type-E: SFC-08E |
2 to 4 |
SR8808H-X |
· Type-E: SFC-08E1 · Type-T: SFC-08T · Type-TG: CSFC-08T-G |
2 to 5 |
SR8812-X |
· Type-B: SFC-12B · Type-D: SFC-12D · Type-E: SFC-12E |
2 to 4 |
SR8816-X |
· Type-E: SFC-16E · Type-T: SFC-16T · Type-TG: CSFC-16T-G |
2 to 5 |
Table 32 Compatibility matrix between switching fabric modules and service modules (1)
Service module |
Type A switching fabric module |
SFC-04B |
SFC-04D |
SFC-08B |
SFC-08D |
SPC-GT48LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GE24L-E |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP24LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP48LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP48LB |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP24XP2LA |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP24XP2LB |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GE16XP4L-E |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP44XP4LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP44XP4LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP2LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP4LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP4LB |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP8LA |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP8LB |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP12LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP12LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP24LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP24LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-XLP6LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-XLP6LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-CP1LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-CP1LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-CP2LA |
Not supported |
Supported |
Supported |
Supported |
Supported |
SPC-CP2LB |
Not supported |
Supported |
Supported |
Supported |
Supported |
CEPC-XP4LX |
Not supported |
Supported |
Supported |
Supported |
Supported |
CEPC-XP24LX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-XP48RX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CP4RX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CP4RX-L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ16L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPEX-1204 |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1104-E |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1304X |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1404X |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1502X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1504X |
Not supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1602X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1802X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1802XB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1804X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1512X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1612X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1812X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1812X-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-2304X-G |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-2612X-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MPE-1104 |
Supported |
Supported |
Supported |
Supported |
Supported |
RX-SPE200 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-SPE200-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-NGFWX-IV |
Not supported |
Supported |
Supported |
Supported |
Supported |
LSU1FWCEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU3FWCEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-IPSX-IV |
Not supported |
Supported |
Supported |
Supported |
Supported |
LSU1IPSBEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-ACG1000X-IV |
Not supported |
Supported |
Supported |
Supported |
Supported |
LSU1ADECEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-MSUX (1 U) |
Not supported |
Supported |
Supported |
Supported |
Supported |
IM-MSUX (1.2 U) |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-MSEX-B |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-SMUX |
Not supported |
Supported |
Supported |
Supported |
Supported |
IM-SFMX |
Not supported |
Supported |
Supported |
Supported |
Supported |
IM-OAPX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Table 33 Compatibility matrix between switching fabric modules and service modules (2)
Service module |
SFC-12B SFC-12D |
SFC-08E |
SFC-08E1 SFC-16E |
SFC-12E |
SFC-08T SFC-16T |
CSFC-08T-G |
CSFC-16T-G |
SPC-GT48LA1 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GE24L-E |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP24LA1 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP48LA1 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP48LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP24XP2LA |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP24XP2LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GE16XP4L-E |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP44XP4LAX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP44XP4LCX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP2LA1 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP4LA1 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP4LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP8LA |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP8LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP12LAX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP12LCX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP24LAX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP24LCX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XLP6LAX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XLP6LCX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP1LAX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP1LCX |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP2LA |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP2LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-XP4LX |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CEPC-XP24LX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-XP48RX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CP4RX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CP4RX-L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CQ8L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
CEPC-CQ16L1 |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
SPEX-1204 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1104-E |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1304X |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1404X |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1502X |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1504X |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1602X |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1802X |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Supported |
Not supported |
CSPEX-1802XB |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
CSPEX-1804X |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Supported |
Supported |
CSPEX-1512X |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Supported |
Supported |
CSPEX-1612X |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Supported |
Supported |
CSPEX-1812X |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Supported |
Supported |
CSPEX-1812X-E |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Supported |
Supported |
CSPEX-2304X-G |
Not supported |
Supported |
Supported |
Not supported |
Supported |
Supported |
Supported |
CSPEX-2612X-E |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Supported |
Not supported |
MPE-1104 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-SPE200 |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Supported |
Supported |
RX-SPE200-E |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Supported |
Not supported |
IM-NGFWX-IV |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU1FWCEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
LSU3FWCEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-IPSX-IV |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU1IPSBEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-ACG1000X-IV |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU1ADECEA0 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-MSUX (1 U) |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-MSUX (1.2 U) |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
IM-MSEX-B |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Not supported |
IM-SMUX |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Supported |
IM-SFMX |
Supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
IM-OAPX |
Supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
Supported |
Power supplies
Overview
CAUTION: · As a best practice, use an air switch that has a rated current not less than 1.2 times the maximum input current of the power supply. · When the temperature of a power supply exceeds the upper limit or drops below the lower limit, the power supply shuts down automatically. When the temperature falls into the normal range, the power supply starts up automatically. |
The router supports the PSR1200B-12A, LSUM1AC1200, LSUM1AC2500, PSR2500-12A, PSR2400-12D, PSR2400-D, LSUM1DC2400, and PSR2500B-12AHD-F power supplies. You need to install two or more power supplies for the router.
Table 34 Power supply specifications
Item |
Specifications |
PSR1200B-12A LSUM1AC1200 |
LSUM1AC2500 PSR2500-12A |
LSUM1DC2400 PSR2400-12D PSR2400-D |
PSR2500B-12AHD-F |
Rated input voltage range |
100 VAC to 240 VAC @ 50/60 Hz |
· 100 VAC to 240 VAC @ 50/60 Hz · 240 VDC |
–48 VDC to –60 VDC |
· 100 VAC to 240 VAC @ 50/60 Hz · 240 VDC to 380 VDC |
Rated output voltage |
12 VDC |
12 VDC |
12 VDC |
12 VDC |
Maximum input current |
16 A |
16 A |
60 A |
16 A |
Maximum output current |
100 A |
· 208 A (180 VAC to 240 VAC or 240 VDC) · 100 A (100 VAC to 180 VAC) |
200 A |
· 208 A (180 VAC to 290 VAC or 180 VDC to 400 VDC) · 100 A (90 VAC to 180 VAC) |
Maximum output power |
1200 W |
· 1200 W (110 VAC) · 2500 W (220 VAC) |
2400 W |
· 1200 W (90 VAC to 180 VAC) · 2500 W (180 VAC to 290 VAC or 180 VDC to 400 VDC) |
Temperature requirements |
· Operating temperature: –10°C to +50°C (14°F to 122°F) · Storage temperature: –40°C to +70°C (–40°F to +158°F) |
Ordering guide
When you order power supplies, follow these guidelines:
· You need to install two or more power supplies for the router.
· You can select a certain number of power supplies according to the power supply conditions at the installation site and actual power consumption of your SR8800-X router. Make sure the total maximum output power of the installed power supplies is greater than the system power consumption. As a best practice, reserve 20% of the maximum output power.
· Do not install power supplies of different models on the same router.
Table 35 Power supply and chassis compatibility matrix
Power supply model |
Chassis |
SR8804-X |
SR8808-X (one fan tray)/ SR8808-X (dual fan trays) |
SR8808H-X |
SR8812-X |
SR8816-X |
LSUM1AC2500 |
l |
l |
l |
l |
l |
PSR1200B-12A |
l |
l |
l |
l |
l |
PSR2500-12A |
l |
l |
l |
l |
l |
LSUM1DC2400 |
l |
l |
l |
l |
l |
PSR2400-12D |
l |
l |
l |
l |
l |
PSR2400-D |
l |
l |
l |
l |
l |
PSR2500B-12AHD-F |
l |
l |
l |
l |
l |
NOTE: · "l" indicates that the power supply is compatible with the chassis. · "—" indicates that the power supply is not compatible with the chassis. |
Fan trays
The router came with fan trays installed. To replace a fan tray, make sure the new fan tray is compatible with the router.
Table 36 Fan tray specifications
Fan tray |
Number of fan trays |
Number of fans in each fan tray |
Fan diameter |
Maximum rotating speed |
Maximum air flow rate |
SR8804-X fan tray |
1 |
8 |
92 mm (3.62 in) |
6000 RPM |
960 CFM |
SR8808-X (one fan tray) fan tray |
1 |
12 |
120 mm (4.72 in) |
5200 RPM |
1152 CFM |
SR8808-X (two fan trays) fan tray |
2 |
12 |
120 mm (4.72 in) |
5200 RPM |
1152 CFM |
SR8812-X fan tray |
2 |
Upper fan tray: 8 Lower fan tray: 4 |
120 mm (4.72 in) |
5200 RPM |
Upper fan tray: 1040 CFM Lower fan tray: 720 CFM |
SR8808H-X fan tray |
8 |
2 |
80 mm (3.15 in) |
12800 RPM |
350 CFM |
SR8816-X fan tray |
15 |
2 |
80 mm (3.15 in) |
12800 RPM |
350 CFM |
Air filters
CAUTION: Clean air filters periodically (once or more times every three months) to guarantee adequate ventilation and to avoid over-temperature. |
To prevent dusts from entering the chassis, you can configure air filters for the router as needed and install them at the air intakes.
H3C SR8800-X air filters include the SR8804-X air filter, SR8808-X air filter, and SR8812-X air filter. Order air filters compatible with your router.
DC power cords
DC power cords are used for connecting the DC power supplies of an SR8800-X router to the external DC power supply system.
Table 37 DC power cord specifications
DC power cord |
Cable length |
0404A0E1 |
3 m (9.84 ft) |
Used for connecting the LSUM1DC2400/PSR2400-12D power supply |
0404A0H8 |
3 m (9.84 ft) |
0404A0E2 |
15 m (49.21 ft) |
0404A0H9 |
15 m (49.21 ft) |
0404A1BE |
20 m (65.62 ft) |
0404A1BF |
20 m (65.62 ft) |
0404A0J5 |
30 m (98.43 ft) |
0404A1BD |
40 m (131.23 ft) |
0404A1M7 |
10 m (32.81 ft) |
Used for connecting the PSR2400-D power supply |
0404A1M6 |
15 m (49.21 ft) |
0404A1M5 |
20 m (65.62 ft) |
0404A1MD |
30 m (98.43 ft) |
AC power cords
An AC power cord is used to connect an AC power supply of a router to the external AC power supply system.
To select an AC power cord for an AC power supply, consider the following items:
· Power capacity of the power supply.
· Current-carrying capacity of the power cord.
· Region-and country-specific plug type.
The AC power supplies available for the router require a 16A AC power cord. Table 38 describes the region-and country-specific plug types for 16A AC power cords.
Table 38 16A AC power cords used in different countries or regions
1 |
Plug type |
Code (Length) |
Countries or regions where the type of power cords conforms to local safety regulations and can be used legally |
Other countries or regions using this type of power cords |
Countries or regions seldom using this type of power cords |
I type |
04043396: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Power cord outline |
Connector outline |
2 |
Plug type |
Code (Length) |
C20 type |
0404A0C2: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
3 |
Plug type |
Code (Length) |
B type |
0404A063: 3 m (9.8 ft) |
Canada and U.S.A |
Mexico, Argentina, Brazil, Columbia, Venezuela, Thailand, Peru, Philippine, and A6 countries or regions |
N/A |
Plug outline |
Connector outline |
4 |
Plug type |
Code (Length) |
F type |
0404A061: 3 m (9.8 ft) |
Holland, Denmark, Sweden, Finland, Norway, Germany, France, Austria, Belgium, and Italy |
Indonesia, Türkiye, Russia, and CIS |
N/A |
Plug outline |
Connector outline |
5 |
Plug type |
Code (Length) |
B type |
0404A062: 3 m (9.8 ft) |
Japan |
N/A |
N/A |
Connector outline |
Connector outline |
6 |
Plug type |
Code (Length) |
I type |
0404A01A: 3 m (9.8 ft) |
Australia |
N/A |
N/A |
Plug outline |
Connector outline |
7 |
Plug type |
Code (Length) |
I type |
0404A0RQ: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
