- H3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
- 00-1Cover
- 00-2Overview
- 01-Login Operation
- 02-Basic System Configuration and Maintenance Operation
- 03-File System Management Operation
- 04-VLAN Operation
- 05-QinQ-BPDU TUNNEL Operation
- 06-Port Correlation Configuration Operation
- 07-MAC Address Table Management Operation
- 08-MSTP Operation
- 09-IP Address and Performance Operation
- 10-IPv6 Configuration Operation
- 11-Routing Overview Operation
- 12-IPV4 Routing Operation
- 13-IPv6 Routing Operation
- 14-802.1x-HABP-MAC Authentication Operation
- 15-AAA-RADIUS-HWTACACS Operation
- 16-Multicast Protocol Operation
- 17-ARP Operation
- 18-DHCP Operation
- 19-ACL Operation
- 20-QoS Operation
- 21-Port Mirroring Operation
- 22-Cluster Operation
- 23-SNMP-RMON Operation
- 24-NTP Operation
- 25-DNS Operation
- 26-Information Center Operation
- 27-NQA Operation
- 28-SSH Terminal Service Operation
- 29-UDP Helper Operation
- 30-SSL-HTTPS Operation
- 31-PKI Operation
- 32-PoE-PoE Profile Operation
- 33-Appendix
| 09-IP Address and Performance Operation | 665 KB |
Table of Contents
Chapter 1 IP Address Configuration
1.2.1 Assigning an IP Address to an Interface
1.2.2 IP Address Configuration Example
1.3 Displaying and Maintaining IP Address Configuration
Chapter 2 IP Performance Configuration
2.2 Permitting Receiving and Forwarding of Directed Broadcast Packets
2.2.1 Enabling Receiving of Directed Broadcasts
2.2.2 Enabling Forwarding Directed Broadcasts
2.2.3 Receiving and Forwarding of Directed Broadcast Configuration Example
2.3 Configuring TCP Attributes
2.4 Configuring ICMP to Send Error Packets
2.5 Displaying and Maintaining IP Performance
1.1 IP Address Overview
1.1.1 IP Address Classes
Each device interface connected to the Internet must be assigned a globally unique IP address. IP addresses are 32-bit in length, generally expressed in dotted decimal notation. That is, an IP address can be expressed as four decimal integers separated by dots, with each integer corresponding to one byte. 10.1.1.1 is an example.
Each IP address breaks down into two parts:
l net-id, the first several bits of the IP address defining a network, also known as class bits.
l host-id, identifies a host on a network.
For administration sake, IP addresses are divided into five classes. Which class an IP address belongs to depends on the first one to four bits of the net-id, as shown in Figure 1-1.
Table 1-1 describes the address ranges of these five classes. Currently, the first three classes of IP addresses are used in large quantities.
Table 1-1 IP address classes and ranges
Class |
Address range |
A |
0.0.0.0 to 127.255.255.255 |
Address 0.0.0.0 means this host no this network. This address is used by a host at bootstrap when it does not know its IP address. This address is never a valid destination address. Addresses starting with 127 are reserved for loopback test. Packets destined to these addresses are processed locally as input packets rather than sent to the link. |
B |
128.0.0.0 to 191.255.255.255 |
C |
192.0.0.0 to 223.255.255.255 |
D |
224.0.0.0 to 239.255.255.255 |
Multicast address. |
E |
240.0.0.0 to 255.255.255.255 |
Reserved for future use except for the broadcast address 255.255.255.255. |
As the Internet develops rapidly, available IP addresses are being exhausted. To make full use of available IP addresses, a network can be divided into smaller ones (known as subnets) with subnet masks. A network can be divided into subnets by using some bits of the host-id to create a subnet-id. The length of subnet-id is determined by subnet mask.
A subnet mask is 32-bit in length and comprises a series of consecutive ones and a series of consecutive zeros. In a subnet mask, the part containing consecutive ones identifies the combination of net-id and subnet-id, whereas the part containing consecutive zeros identifies the host-id.
A subnet is significant only within a network. From the perspective of an external network, the network has only one net-id. A gateway performs route selection based on subnet-id and finds the destination host only after incoming packets are received by the network.
Figure 1-2 shows how a Class B address is subnetted.
Figure 1-2 Subnetting a Class B address
Note that subnetting is somewhat a tradeoff between subnets and accommodated hosts. For example, a Class B network can accommodate 65,534 hosts before being subnetted. After you break it down into 64 subnets by using the first 6 bits of the host-id for the subnet, you have only 10 bits for the host-id and thus have only 1,022 (210 – 2) (excluding all-one broadcast addresses and all-zero network segment addresses) hosts in each subnet. The maximum number of hosts is thus 64 × 1,022 = 65,408, which is126 less than that before the network is subnetted.
Class A, B, and C networks, before being subnetted, use these default masks (also called natural masks): 255.0.0.0, 255.255.0.0, and 255.255.255.0 respectively.
1.2 Configuring IP Addresses
An interface can obtain an IP address using the following methods:
l Through manual IP address assignment
l Through BOOTP
l Through DHCP
These methods are mutually exclusive. An IP address obtained using a new method overwrites that obtained using an old method. For example, if you manually assign an IP address and then obtain another IP address through BOOTP, the IP address obtained from BOOTP will overwrite the old one manually assigned. In this case, the interface is assigned the IP address through BOOTP.
& Note:
This chapter only covers how to assign an IP address manually. For how to obtain an IP address using the other two methods, see the related sections in DHCP part of this manual.
Follow these steps to assign an IP address to an interface:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter interface view |
Assign an IP address to the interface |
ip address ip-address { mask | mask-length } [ sub ] |
Required No IP address is assigned by default. |
Caution:
l One interface can be configured with only one primary IP address. The primary IP address you assigned to the interface can overwrite the old one if there is any.
l You cannot assign secondary IP addresses to an interface using BOOTP or DHCP.
l The primary and secondary IP addresses you assign to the interface can be located on the same network segment.
l With S5500-SI series Ethernet switches, you can configure IP addresses for VLAN interfaces and Loopback interfaces. Only 32-bit subnet masks can be configured on Loopback interfaces.
I. Network requirements
As shown in Figure 1-3, Vlan-interface1 (belonging to VLAN 1) on the switch is connected to a LAN comprising two segments: 172.16.1.0/24 and 172.16.2.0/24. The hosts in external network can communicate with the two network segments through the switch and the hosts between the two segments can communicate with each other.
II. Network diagram
Figure 1-3 Network diagram for IP address configuration
III. Configuration procedure
If only one IP address is configured on Vlan-interface1 of the switch, only part of the hosts can be accessed from external network through the switch. To enable the access to all the hosts in the network through the switch, a secondary IP address needs to be configured for Vlan-interface1. To allow the hosts on the two segments to communicate with each other, the switch needs to be set as the gateway on all the hosts on the two segments.
# Assign a primary IP address and a secondary IP address to Vlan-interface1.
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] ip address 172.16.1.1 255.255.255.0
[Sysname-Vlan-interface1] ip address 172.16.2.1 255.255.255.0 sub
# Set the gateway address to 172.16.1.1 on the PCs attached to the subnet 172.16.1.0/24, and to 172.16.2.1 on the PCs attached to the subnet 172.16.2.0/24.
# Ping a host on the subnet 172.16.1.0/24 from the switch to verify the configuration.
<Sysname> ping 172.16.1.2
PING 172.16.1.2: 56 data bytes, press CTRL_C to break
Reply from 172.16.1.2: bytes=56 Sequence=1 ttl=255 time=25 ms
Reply from 172.16.1.2: bytes=56 Sequence=2 ttl=255 time=27 ms
Reply from 172.16.1.2: bytes=56 Sequence=3 ttl=255 time=26 ms
Reply from 172.16.1.2: bytes=56 Sequence=4 ttl=255 time=26 ms
Reply from 172.16.1.2: bytes=56 Sequence=5 ttl=255 time=26 ms
--- 172.16.1.2 ping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 25/26/27 ms
# Ping a host on the subnet 172.16.2.0/24 from the switch to verify the configuration.
<Sysname> ping 172.16.2.2
PING 172.16.2.2: 56 data bytes, press CTRL_C to break
Reply from 172.16.2.2: bytes=56 Sequence=1 ttl=255 time=25 ms
Reply from 172.16.2.2: bytes=56 Sequence=2 ttl=255 time=26 ms
Reply from 172.16.2.2: bytes=56 Sequence=3 ttl=255 time=26 ms
Reply from 172.16.2.2: bytes=56 Sequence=4 ttl=255 time=26 ms
Reply from 172.16.2.2: bytes=56 Sequence=5 ttl=255 time=26 ms
--- 172.16.2.2 ping statistics ---
0.00% packet loss
round-trip min/avg/max = 25/25/26 ms
# Verify that the hosts on the subnets 172.16.1.0/24 and 172.16.2.0/24 can communicate with each other.
After the above-mentioned configuration, you can use the display command in any view to display IP address configuration, so as to verify configuration result.
Follow these steps to display and maintain IP address configuration:
To do… |
Use the command… |
Display information about a specified or all L3 interfaces |
display ip interface [ interface-type interface-number ] |
Display brief information about a specified or all Layer 3 interfaces |
display ip interface brief [ interface-type interface-number ] |
2.1 IP Performance Overview
In some network environments, you need to adjust the IP parameters to achieve best IP performance. IP performance configuration parameters include:
l Receiving and forwarding of directed broadcasts
l TCP timers
l Size of TCP receive/send buffer
l ICMP error packets sending
Directed broadcast packets include network directed broadcast packets, individual-subnet directed broadcast packets and all-subnet directed broadcast packets. If a device is permitted to receive and forward directed broadcast packets, hackers can use such packets to attack the network, which brings potential trouble to network security. Therefore, the receiving and forwarding of directed broadcast packets are disabled on S5500-SI series Ethernet switches by default. When necessary, you can use the related command to permit the device to receive and forward directed broadcast packets.
If the device is permitted to receive directed broadcast packets, the configuration on an interface determines whether these packets can be forwarded. Otherwise, directed broadcast packets are discarded directly.
Follow these steps to enable the receiving of directed broadcasts:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable the device to receive directed broadcasts |
ip forward-broadcast |
Required By default, an interface is not allowed to receive directed broadcasts |
Follow these steps to enable forwarding directed broadcasts:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable forwarding directed broadcasts on an interface |
ip forward-broadcast [ acl acl-number ] |
Required By default, directed broadcasts forwarding is not allowed. |
& Note:
l If you have configured ACL when enabling an interface to forward directed broadcasts, the ACL will discard the directed broadcast packets that do not meet its rules, but forward only those in compliance with the rules.
l If you execute the ip forward-broadcast acl command on an interface for many times, the last executed command takes the final effect. As such, if the last command is one without the acl acl-number, the previous ACL rules will be cancelled.
As shown in Figure 2-1, the PC interface and Vlan-interface3 of Switch A are in the same network segment (1.1.1.0/24). Vlan-interface2 of Switch A and Vlan-interface2 of Switch B are in another network segment (2.2.2.0/24). The default gateway of the PC is Vlan-interface3 (IP address 1.1.1.2/24) of Switch A. Configure a static route on Switch B for the reachability between PC and Switch B.
II. Network diagram
Figure 2-1 Blocking directed broadcasts
l Perform the following configuration on Switch A.
# Configure Switch A to receive directed broadcast packets.
[SwitchA] ip forward-broadcast
# Configure IP addresses for Vlan-interface3 and Vlan-interface2.
[SwitchA] interface Vlan-interface 3
[SwitchA-Vlan-interface3] ip address 1.1.1.2 24
[SwitchA-Vlan-interface3] quit
[SwitchA] interface Vlan-interface 2
[SwitchA-Vlan-interface2] ip address 2.2.2.2 24
# Configure Vlan-interface2 to forward directed broadcast packets.
[SwitchA-Vlan-interface2] ip forward-broadcast
l Perform the following configuration on Switch B
# Configure Switch B to receive directed broadcast packets.
[SwitchB] ip forward-broadcast
# Configure a static route from Switch B to the PC.
[SwitchB] ip route-static 1.1.1.1 24 2.2.2.2
# Configure an IP address for Vlan-interface2.
[SwitchB] interface Vlan-interface 2
[SwitchB-Vlan-interface2] ip address 2.2.2.1 24
After the above configurations, if you ping the subnet broadcast address (2.2.2.255) of Vlan-interface 2 of Switch A on the PC, the ping packets can be received by Vlan-interface 2 of Switch B. However, if you cancel the ip forward-broadcast command, the ping packets can not be received by the Vlan-interface 2 of Switch B.
TCP attributes that can be configured include:
l synwait timer: Before sending a SYN packet, TCP starts the synwait timer. If no response packets are received before synwait timeout, TCP connection is not successfully created.
l finwait timer: When the TCP connection is in FIN_WAIT_2 state, finwait timer will be started. If no FIN packets are received before the timer timeouts, the TCP connection will be terminated. If FIN packets are received, the TCP connection state changes to TIME_WAIT. If non-FIN packets are received, and the system recounts the time from receiving the last non-FIN packet until the connection is broken after the timer timeouts.
l Size of TCP receiving/sending buffer
Follow these steps to configure TCP attributes:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure TCP synwait timer’s timeout value |
tcp timer syn-timeout time-value |
Optional By default, the timeout value is 75 seconds. |
Configure TCP finwait timer’s timeout value |
tcp timer fin-timeout time-value |
Optional By default, the timeout value is 675 seconds. |
Configure the size of TCP receiving/sending buffer |
tcp window window-size |
Optional By default, the buffer is 8k bytes. |
Sending error packets is a major function of ICMP protocol. In case of network abnormalities, ICMP packets are usually sent by the network or transport layer protocols to notify corresponding devices so as to facilitate control and management.
I. Advantage of sending ICMP error packets
There are three kinds of ICMP error packets: redirection packets, timeout packets and destination unreachable packets. Their sending conditions and functions are as follows.
1) Sending ICMP redirect packets
A host may have only one route (the default route to the default gateway) in its routing table when starting. The default gateway will send ICMP redirect packets to the source host and notify it to reselect a correct next hop router to send the subsequent packets, if the following conditions are satisfied:
l The receiving and sending interfaces are the same.
l The selected route has not been created or modified by ICMP redirect packets.
l The selected route is not the default route of the device.
l There is no source route option in the packet.
ICMP redirect packets function simplifies host administration and enables a host to gradually establish a sound routing table to find out the best route
2) Sending ICMP timeout packets
A device drops the data packet and sends an ICMP timeout packet to the source when there is a timeout error after the device received an IP data packet.
The device will send an ICMP timeout packet under the following conditions:
l If a device finds the destination of the packet is not local after receiving a data packet whose TTL field is 1, it will send a “TTL timeout” ICMP error message.
l When the device receives the first fragment IP packets whose destination address is local, it will start the timer. If the timer timeouts before receiving all the fragments, the device will send a “reassembly timeout” ICMP error packets.
3) Sending ICMP destination unreachable packets
Sending ICMP destination unreachable packet means when there happens a destination timeout error after a device received an IP data packet, the device will drop the data packet and send an ICMP error packet to the source.
The device will send an ICMP destination unreachable packet under the following conditions:
l When forwarding a packet, if the device finds no corresponding forward route and default route in the routing table, it will send a “network unreachable” ICMP error packet.
l When receiving a data packet whose destination address is local, if the transfer layer protocol is unavailable for the device, then the device sends a “protocol unreachable” ICMP error packet.
l When receiving a data packet with the destination address as local and transfer layer as UDP, if the packet’s port number does not match with the running process, the device will send source a “port unreachable” ICMP error packet.
l When sending packets using “strict source routing", if the intermediate finds that the source point to a device not directly connected to the network, it will send source a “source routing fails” ICMP error packet.
l When forwarding a packet, if the MTU of the forward interface is smaller than the packet but the packet has been set unfragmentable, the device will send source a “fragmenting is required but unavailable” ICMP error packet.
II. Disadvantage of sending ICMP error packets
Although sending ICMP error packets facilitate control and management, it still has the following disadvantage:
l Sending a lot of ICMP packets will increase network traffic.
l If the device receives a lot of malicious packets that sends much ICMP error packets, it will reduce the device's performance.
l As redirecting increases a host’s routing, it will reduce the host’s performance if there is a great increase in the hosting.
l As ICMP destination unreachable packets are unreachable to users' process, if there are malicious attacks, end users may be affected.
In order to prevent such phenomena, you can disable the device from sending ICMP error packets to reduce network traffic and avoid malicious attacks.
Follow these steps to disable sending ICMP error packets:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Disable sending ICMP redirect packets |
undo ip redirects |
Required Sending a device’s ICMP redirection packet is enabled by default |
Disable sending ICMP timeout packets |
undo ip ttl-expires |
Required Sending a device’s ICMP timeout packet is enabled by default. |
Disable sending ICMP destination unreachable packets |
undo ip unreachables |
Required Sending a device’s ICMP destination unreachable packet is enabled by default |
& Note:
l The device stops sending “network unreachable” and “source route unsuccessful” ICMP error packets after sending ICMP destination unreachable packets is disabled. But other destination unreachable packets will be sent normally.
l The device stops sending “TTL timeout” ICMP error packets after sending ICMP timeout packets is disabled. But “reassembly timeout” error packets will be sent normally.
After the above-mentioned configuration, you can use the display command in any view to display the IP performance status, so as to verify configuration result.
You can use the reset command in user view to clear the statistics about IP, TCP, and UDP traffic.
Following these steps to display and maintain IP performance:
To do… |
Use the command… |
Display current TCP connection state |
display tcp status |
Display statistics of TCP connection |
display tcp statistics |
Display statistics of UDP flows |
display udp statistics |
Display statistics of IP packets |
display ip statistics |
Display statistics of ICMP flows |
display icmp statistics |
Display current socket information of the system |
display ip socket [ socktype sock-type ] [ task-id socket-id ] |
Display FIB forward information |
display fib [ | { begin | include | exclude } text | acl acl-number | ip-prefix ip-prefix-name ] |
Display FIB forward information matching the specified destination IP address |
display fib ip-address1 [ { mask1 | mask-length1 } [ ip-address2 { mask2 | mask-length2 } | longer ] | longer ] |
Display statistics about the FIB items |
display fib statistics |
Clear statistics of IP packets |
reset ip statistics |
Clear statistics of TCP flows |
reset tcp statistics |
Clear statistics of UDP flows |
reset udp statistics |
