H3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration GuidesH3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
00-2Overview
00-2Overview 1 MB
Chapter 1  Obtaining the Documentation
H3C Technology Co., Ltd. provides various ways for you to obtain documentation, through which you can obtain the product documentations and those concerning newly added features. The documentations are available in one of the following ways:
l           CD-ROMs shipped with the devices
l           H3C website
l           Software release notes
1.1  CD-ROM
H3C delivers a CD-ROM together with each device. The CD-ROM contains a complete product document set, including the operation manual, command manual, installation manual, and compatibility manual. After installing the reader program provided by the CD-ROM, you can search for the desired contents in a convenient way through the reader interface.
The contents in the manual are subject to update on an irregular basis due to product version upgrade or some other reasons. Therefore, the contents in the CD-ROM may not be the latest version. This manual serves the purpose of user guide only. Unless otherwise noted, all the information in the document set does not claim or imply any warranty. For the latest software documentation, go to the H3C website.
1.2  H3C Website
Perform the following steps to query and download the product documentation from the H3C website.
Table 1-1 Acquire product documentation from the H3C website
How to apply for an account
Access the homepage of H3C at http:// www.h3c.com and click on Registration at the top right. In the displayed page, provide your information and click on Submit to register.
How to get documentation
Approach 1:
In the homepage of H3C at http:// www.h3c.com, select Technical Support & Document > Technical Documents from the navigation menu at the top. Then select a product for its documents.
Approach 2:
In the homepage of H3C at http:// www.h3c.com, select Support > Technical Documents. Then select a product for its documents.
1.3  Software Version Release
With software upgrade, new software features may be added. You can acquire the information about the newly added software features through software release notes.
Chapter 2  Product Overview
2.1  Preface
H3C S5500-SI Series Ethernet Switches (hereinafter referred to as S5500-SI series) are Gigabit Ethernet switching products developed by H3C Technology Co., Ltd. S5500-SI series have abundant service features. They provide the IPv6 forwarding function and 10 GE ports. Through H3C-specific cluster management, you can streamline network management. S5500-SI series are designed as convergence and access devices for enterprise networks and metropolitan area networks (MANs), and can also be used for connecting server clusters in data centers.
Currently, S5500-SI series include the following models:
l           S5500-28C-SI
l           S5500-52C-SI
l           S5500-28C-PWR-SI
l           S5500-52C-PWR-SI
The feature-rich S5500-SI series switches support the following services:
l           Broadband Internet access
l           Access of MAN and enterprise network users
l           Multimedia services, such as VOD
l           Delay-sensitive voice services, such as VoIP
l           Multicast audio and video services
S5500-SI series feature the following advantages:
l           Provides full-Gigabit access ports
l           Provides 10 GE ports
l           Supports IPv4/IPv6 dual stack and hardware forwarding
l           Supports jumbo frames
l           Supports LACP
l           Supports 4k VLANs
l           Supports QACL
l           Supports port- and flow-based mirroring
2.2  System Features
Table 2-1 lists the system features of S5500-SI series.
Table 2-1 System features of S5500-SI series
Item
S5500-28C-SI
S5500-52C-SI
S5500-28C-PWR-SI
S5500-52C-PWR-SI
Dimensions
(height × width × depth)
43.6 × 300 × 440 mm (1.72 × 11.8 × 17.3 in.)
43.6 × 420 × 440 mm (1.72 × 16.5 × 17.3 in.)
Weight
4 kg (8.1 lb)
4.5 kg (9.9 lb)
6 kg (13.2 lb)
6.5 kg (14.3 lb)
Console port
One Console port
GE ports on the front panel
24 10/100/1,000 M electrical ports
4 Gigabit SFP Combo ports
48 10/100/1,000 M electrical ports
Optional modules
1-port 10 GE XFP module
2-port 10 GE XFP module
2-port 10 GE CX4 module for short haul
Voltage
AC
Rated voltage range: 100 VAC to 240 V AC, 50/60 Hz
Max voltage range: 90 VAC to 264 VAC, 47/63 Hz
DC
Rated voltage range: 10.8 VDC to 13.2 VDC
Rated voltage range: -52 VDC to -55 VDC
2.3  Service Features
S5500-SI series provide abundant service features that meet varied customer requirements. Table 2-2 summarizes the service features provided by S5500-SI series.
Table 2-2 Service features of S5500-SI series
Part
Features
01 Login
l      Logging into a switch through the Console port
l      Logging into a switch through an Ethernet port by using Telnet or SSH
l      Logging into a switch through the Console port by using a modem
l      Logging into a switch through Web or NMS
02 System Maintenance and Debugging
l      CLI
l      Hierarchically grouped commands
l      CLI online help
l      Configuring system time
l      Language (Chinese/English) selection
l      Displaying and configuring system device state
03 File System Management
l      File system management
l      Saving, restoring, and deleting the configuration file
l      Configuring the switch as an FTP server/client
l      Configuring the switch as a TFTP client
04 VLAN
l      IEEE 802.1Q-compliant VLANs
l      Port-based VLANs
l      Voice VLANs
l      GARP VLAN Registration Protocol (GVRP)
05 QinQ-BPDU TUNNEL
l      QinQ
l      Configuring TPID value
l      BPDU TUNNEL
06 Port Correlation Configuration
l      Three port states supported: Access, Trunk, and Hybrid
l      Setting broadcast storm suppression globally
l      Loopback detection
l      Cable test
l      Link aggregation control protocol (LACP)
l      Port isolation group
07 MAC Address Table
l      Manually configuring dynamic, static, and black hole MAC addresses
l      Configuring the aging time for MAC addresses
l      MAC address learning limit
08 MSTP
l      STP/RSTP/MSTP
l      MSTP path cost compliant with private standards
09 IP Address and Performance Configuration
l      Configuring an IP addresses for a switch
l      Configuring the TCP attributes of a switch
10 IPv6 Configuration
l      IPv6 overview
l      IPv6 basic applications
11 Routing Overview
l      Routing protocol overview
12 IPv4 Routing Protocols
l      IPv4 static route
l      Routing information protocol (RIP) v1/v2
l      IPv4 routing policy
13 IPv6 Routing Protocols
l      IPv6 static route
l      RIPng
l      IPv6 routing policy
14 802.1x-HABP-MAC Authentication
l      802.1x authentication
l      Guest VLAN
l      Huawei authentication bypass protocol (HABP)
l      Centralized MAC address authentication
15 AAA-RADIUS-HWTACACS
l      Authentication, authorization, and accounting (AAA)
l      Remote authentication dial-in user service (RADIUS)
l      Huawei terminal access controller access control system (HWTACACS)
16 Multicast Protocols
l      Internet group management protocol snooping (IGMP Snooping)
17 ARP
l      Gratuitous ARP
l      Manually configuring ARP entries
18 DHCP
l      DHCP relay
l      DHCP Snooping
l      Using Option82 in DHCP relay
19 ACL
l      Basic ACLs
l      Advanced ACLs
l      Layer2 ACLs
20 QoS
l      Quality of Service (QoS) policy
l      Congestion management
l      Port priority
l      VLAN policy
l      Traffic mirroring
21 Port Mirroring
l      Port mirroring
22 Cluster
l      Huawei group management protocol (HGMP) v2
l      Neighbor discovery protocol (NDP)
l      Neighbor topology discovery protocol (NTDP)
23 SNMP-RMON
l      Simple network management protocol (SNMP) v3, compatible with SNMP v1/v2
l      Remote monitoring (RMON)
24 NTP
Network time protocol (NTP)
25 DNS
Domain Name System (DNS)
26 Information Center
l      System logs
l      Hierarchical alarms
l      Debugging information output
27 NQA
Network Quality Analyzer (NQA)
28 SSH Terminal Service
l      Secure Shell (SSH)
l      Secure FTP (SFTP)
29 UDP Helper
Forwarding UDP broadcast packets by using UDP Helper
30 SSL-HTTPS
l      Secure socket layer (SSL) support
l      HTTP security (HTTPS) support
31 PKI
Public key infrastructure (PKI) support
32 PoE-PoE Profile
l      Power over Ethernet (PoE)
l      Power over Ethernet profile (PoE profile)
Chapter 3  Networking Applications
S5500-SI Series Gigabit Ethernet switches are designed as convergence layer switches or access layer switches for enterprise networks and campus networks. S5500-SI series provide 24 or 48 autosensing Gigabit Ethernet ports and four SFP Combo Gigabit optical interfaces. In addition, S5500-SI series provide two extension slots that allow you to configure XFP/CX4 extension modules. Up to four 10 GE ports can be configured. Implementing flexible networking, S5500-SI series can be applied to Gigabit to the desktop (GTTD) access of enterprise networks, user access of campus networks, and the connection of server clusters in data centers. Several typical networking applications are described as follows.
3.1  Serving as a Convergence Layer Device
In medium- and large-sized enterprise or campus networks, S5500-SI series Ethernet switches can serve as convergence layer switches that provide high-performance and large-capacity switching service and support 10 GE uplink interfaces, providing larger bandwidths for access devices.
Figure 3-1 Application of S5500-SI series at the convergence layer of enterprise networks/campus networks
3.2  Serving as a Access Layer Device
S5500-SI series can serve as access layer switches that provide large access bandwidth and high port density. S5500-SI series also provide PoE. Through Ethernet cables, S5500-SI series can power IP phones, WLAN access points (APs), and other IEEE802.3af-compliant PD devices to facilitate network maintenance and management.
Figure 3-2 Application of S5500-SI series at access layer
