H3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration GuidesH3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
25-DNS Operation
25-DNS Operation 64 KB
Chapter 1  DNS Configuration
1.1  DNS Overview
Domain name system (DNS) is a distributed database used by TCP/IP applications for transformation between domain names and their corresponding IP addresses. With DNS, you can use memorizable and meaningful domain names in some applications and let the DNS server resolve the correct IP address.
There are two types of DNS services, static and dynamic. Each time the DNS Server receives a name query it checks its static DNS database before looking up the dynamic DNS database. Reduction of the searching time in the dynamic DNS database would increase efficiency. Some frequently used addresses can be put in the static DNS database.
1.1.1  Static Domain Name Resolution
The static domain name resolution means setting up mappings between domain names and IP addresses. IP addresses of the corresponding names can be found in the static domain name resolution database for applications.
1.1.2  Dynamic Domain Name Resolution
I. Resolving procedure
Dynamic domain name resolution is implemented by querying the DNS server. The resolution procedure is as follows:
1)         A user program sends a name query to the resolver in the DNS Client.
2)         The DNS resolver looks up the local domain name cache for a match. If a match is found, it sends the corresponding IP address back. If not, it sends a query to the DNS Server.
3)         The DNS Server looks up its DNS database for a match. If no match is found, it sends a query to a higher DNS Server. This process continues until a result, success or failure, is returned.
4)         The DNS Client performs the next operation according to the result.
Figure 1-1 Dynamic domain name resolution
Figure 1-1 shows the relationship between user program, NDS Client, and DNS Server.
The resolver and cache comprise the DNS Client. The user program and DNS client can run on the same machine or different machines, while the DNS Server and the DNS Client usually must run on different machines.
Dynamic domain name resolution allows the DNS Client to store latest mappings between name and IP address in the dynamic domain name cache. There is no need to send a request to the DNS Server for a repeated query next time. The aged mappings are removed from the cache after some time, and latest entries are required from the DNS Server. The DNS Server decides how long a mapping is valid, and the DNS Client gets the information from DNS messages.
II. DNS suffixes
The DNS Client normally holds a list of suffixes which can be defined by users. It is used when the name to be resolved is incomplete. The resolver can supply the missing part. For example, a user can configure com as the suffix for aabbcc.com. The user only needs to type aabbcc to get the IP address of aabbcc.com. The resolver can add the suffix and delimiter before passing the name to the DNS Server.
When a DNS suffix is used, the resolver will look up the domain name in the following ways according to the form of the domain name you input.
l           If there is no dot in the domain name, such as aabbcc, the resolver will consider this as a host name and add a DNS suffix before processing. The original name such as aabbcc is used if all DNS lookups fail.
l           If there is a dot in the domain name, such as www.aabbcc, the resolver will use this domain name to do DNS lookup first. If the lookup fails, the resolver adds a DNS suffix for another lookup.
l           If the dot is at the end of the domain name, such as aabbcc.com., the resolver will consider this as a fully qualified domain name and return the result, success or a failure. Hence, the dot (.) is called the terminating symbol.
Currently, the S5500-SI series Ethernet switches support static and dynamic DNS services.
&  Note:
If an alias is configured for a domain name on the DNS server, the device can resolve the IP address of the host according to the alias.
1.2  Configuring Static Domain Name Resolution
Follow these steps to configure static domain name resolution:
To do…
Use the command…
Remarks
Enter system view
Configure a mapping between host name and IP address in the static domain name resolution table
ip host hostname ip-address
Required
No mapping between host name and IP address is configured in the static domain name resolution table by default.
&  Note:
The last IP address you assign to the host name last time will overwrite the previous one if there is any.
You may create up to 50 static mappings between domain names and IP addresses.
1.3  Configuring Dynamic Domain Name Resolution
1.3.1  Configuration Procedure
Follow these steps to configure dynamic domain name resolution:
To do…
Use the command…
Remarks
Enter system view
Enable dynamic domain name resolution
dns resolve
Required
Disabled by default
Configure an IP address for the DNS Server
dns server ip-address
Required
No IP address is configured for the DNS Server by default.
Configure DNS suffixes
dns domain domain-name
Optional
No DNS suffix is configured by default
&  Note:
You may configure up to six DNS Servers and ten DNS suffixes.
1.3.2  DNS Configuration Example
I. Network requirements
As shown in Figure 1-2, an S5500-SI series Ethernet switch serving as a DNS Client uses the dynamic domain name resolution feature to access the host with the domain name being host1 and the IP address 1.1.1.2/16. The DNS Server has the IP address 2.1.1.2/16. The DNS suffixes are com and net.
II. Network diagram
Figure 1-2 Network diagram for dynamic domain name resolution
III. Configuration procedure
&  Note:
Before doing the following configuration, make sure that
l      The route between the device and host 1 is reachable.
l      Configurations are done on both the device and host 1. For the IP address of the interfaces, see Figure 1-2.
l      There is a mapping between domain name host1 and IP address 1.1.1.2/16 on the DNS server.
l      The DNS Server works normally.
# Enable dynamic domain name resolution.
[Sysname] dns resolve
# Configure the IP address 2.1.1.2 for the DNS Server
[Sysname] dns server 2.1.1.2
# Configure net as the DNS suffix
[Sysname] dns domain net
# Configure com as the DNS suffix
[Sysname] dns domain com
Execute the ping host1 command on an S5500-SI series Ethernet switch to verify that the communication between the switch and the host is normal and that the corresponding destination IP address is 1.1.1.2.
1.4  Displaying and Maintaining DNS
To do…
Use the command…
Remarks
Display the static DNS database
display ip host
Available in any view
Display the DNS Server information
display dns server [ dynamic ]
Display the DNS suffixes
display dns domain [ dynamic ]
Display the information in the dynamic domain name cache
display dns dynamic-host
Clear the information in the dynamic domain name cache
reset dns dynamic-host
1.5  Troubleshooting DNS Configuration
I. Symptom
After enabling the dynamic domain name resolution, the user cannot get the correct IP address.
II. Solution
l           Use the display dns dynamic-host command to check that the specified domain name is in the cache.
l           If there is no defined domain name, check that dynamic domain name resolution is enabled and the DNS Client can communicate with the DNS Server.
l           If the specified domain name is in the cache, but the IP address is incorrect, check that the DNS Client has the correct IP address of the DNS Server.
l           Check the mapping between the domain name and IP address is correct on the DNS Server.
