- H3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
- 00-1Cover
- 00-2Overview
- 01-Login Operation
- 02-Basic System Configuration and Maintenance Operation
- 03-File System Management Operation
- 04-VLAN Operation
- 05-QinQ-BPDU TUNNEL Operation
- 06-Port Correlation Configuration Operation
- 07-MAC Address Table Management Operation
- 08-MSTP Operation
- 09-IP Address and Performance Operation
- 10-IPv6 Configuration Operation
- 11-Routing Overview Operation
- 12-IPV4 Routing Operation
- 13-IPv6 Routing Operation
- 14-802.1x-HABP-MAC Authentication Operation
- 15-AAA-RADIUS-HWTACACS Operation
- 16-Multicast Protocol Operation
- 17-ARP Operation
- 18-DHCP Operation
- 19-ACL Operation
- 20-QoS Operation
- 21-Port Mirroring Operation
- 22-Cluster Operation
- 23-SNMP-RMON Operation
- 24-NTP Operation
- 25-DNS Operation
- 26-Information Center Operation
- 27-NQA Operation
- 28-SSH Terminal Service Operation
- 29-UDP Helper Operation
- 30-SSL-HTTPS Operation
- 31-PKI Operation
- 32-PoE-PoE Profile Operation
- 33-Appendix
| 21-Port Mirroring Operation | 81 KB |
Table of Contents
Chapter 1 Port Mirroring Configuration
1.1 Introduction to Port Mirroring
1.1.1 Introduction to Port Mirroring
1.1.2 Implementing Port Mirroring
1.2 Configuring Local Port Mirroring
1.4 Examples of Typical Port Mirroring Configuration
Port mirroring refers to the process of copying packets of a specified port to a destination port. A destination port is connected to a data detect device, which you can use to analyze the packets mirrored from the source to the destination port for monitoring and troubleshooting your network.
Figure 1-1 Schematic diagram of port mirroring
Port mirroring is implemented through mirroring groups. S5500-SI series Ethernet switches support the configuration of local mirroring group to implement the local port mirroring function. Local port mirroring is to copy packets from one or more ports (source ports) of a device to a monitor port (destination port) on the same device for traffic analysis and monitoring. In this case, the source ports and the destination port locate at the same device.
Follow these steps to configure a local port mirroring:
Use the command… |
Remarks |
Enter system view |
system-view |
Create local mirroring group |
mirroring-group groupid local |
Required |
Configure mirroring port for the mirroring group |
Configure mirroring port under system view |
mirroring-group groupid mirroring-port mirroring-port-list { inbound | outbound | both } |
One of them is required. You can configure multiple mirroring ports at the same time under system view, or configure a mirroring port under a specific interface view. |
Configure mirroring port under interface view |
[ mirroring-group groupid ] mirroring-port { inbound | outbound | both } |
quit |
Configure monitor port for the mirroring group |
Configure monitor port under system view |
mirroring-group groupid monitor-port monitor-port-id |
One of them is required. The two ways of configuration are the same. |
Configure monitor port under interface view |
[ mirroring-group groupid ] monitor-port |
& Note:
l The local mirroring group takes effect only after a source port and a destination port are added to it.
l A monitor port can’t enable STP RSTP or MSTP; otherwise it will affect the device’s normal functions. And vice versa.
l A monitor port cannot be a member port of the current mirroring group.
l You can configure multiple mirroring ports for a mirroring group, but only one monitor port.
1.3 Displaying Port Mirroring
Follow these steps to display and maintain port mirroring:
To do… |
Use the command… |
Display the configuration information of port mirroring group |
display mirroring-group { groupid | local } |
I. Network requirements
The user’s network is described as follows:
l The packets of Department 1 are connected to Switch C through port GigabitEthernet1/0/1.
l The packets of Department 2 are connected to Switch C through port GigabitEthernet1/0/2.
l The data detect device is connected to Switch C through port GigabitEthernet1/0/3.
The demand is to monitor packets of Department 1 and Department 2 through the Server.
For implementing the demand using local port mirroring, run the following configuration on Switch C:
l Configure GigabitEthernet1/0/1 and GigabitEthernet1/0/2 as the mirroring port.
l Connect the Server’s port GigabitEthernet1/0/3 as the monitor port.
II. Network diagram
Figure 1-2 Configuring Local Port Mirroring Network Diagram
III. Configuration procedure
Configuring Switch C:
# Enter system view.
# Create local mirroring group
[Sysname] mirroring-group 1 local
# Configure mirroring and monitor ports for local mirroring group.
[Sysname] mirroring-group 1 mirroring-port GigabitEthernet 1/0/1 to GigabitEthernet 1/0/2 both
[Sysname] mirroring-group 1 monitor-port GigabitEthernet 1/0/3
# Display configuration information of mirroring group 1.
[Sysname] display mirroring-group 1
mirroring-group 1:
type: local
status: active
mirroring port:
GigabitEthernet1/0/1 both
GigabitEthernet1/0/2 both
monitor port: GigabitEthernet1/0/3
After finishing the configuration, the user can monitor all the packets received and sent by Department 1 and Department 2 on the Server.
