H3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration GuidesH3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
22-Cluster Operation
22-Cluster Operation 743 KB
Chapter 1  Cluster Management Configuration
1.1  Cluster Management Overview
1.1.1  Introduction to HGMP V2
By employing Huawei group management protocol version 2 (HGMP V2), a network administrator can manage multiple switches using the IP address of a switch operating as the management device. The switches under the management of the management device are member devices. Normally, a cluster member device is not assigned a public IP address, and the network administrator manages and maintains member devices through the management device. The management device, along with the member devices, forms a cluster. Figure 1-1 shows a typical cluster implementation.
Figure 1-1 A typical cluster implementation
A cluster has one (and only one) management device. Note the following when creating a cluster:
l           You need to designate the management device first. The management device of a cluster is the portal of the cluster. That is, any operations performed in external networks and intended for the member devices of a cluster, such as accessing, configuring, managing, and monitoring, are carried out through the management device only.
l           The management device of a cluster recognizes and controls all the member devices in the cluster, regardless of their locations in the network and how they are connected.
l           The management device of a cluster collects and maintains the topology information about all the member devices and candidate devices for you manage the related devices.
l           A management device manages and monitors the devices in the cluster according to the network topology information obtained from the neighbor devices.
HGMPv2 protocol suite implements device management. As HGMPv2 is carried by data link layer packets, there is no need to assign IP addresses for the virtual interfaces of all the devices in a network.
HGMP V2 offers the following advantages:
l           The procedures to configure multiple switches remarkably simplified. When the management device is assigned a public IP address, you can configure/manage a specific member device on the management device instead of logging into it in advance.
l           Functions of topology discovery and display provided, which assist network monitoring and debugging
l           Software upgrading and parameter configuring can be performed simultaneously on multiple switches.
l           Free of topology and physical distance limitations
l           Saving IP address resource
1.1.2  Switch Roles in a Cluster
According to their functions and status in a cluster, switches in the cluster play different roles. You can specify the role a switch plays. A switch also changes its role according to specific rules.
The following three switch roles exist in a cluster: management device, member device, and candidate device.
Table 1-1 Switch roles in a cluster
Role
Configuration
Management device
l      Configured with a public IP address.
l      Receive and process management commands that a user sends through the public network
l      Provide management interfaces for all switches in the cluster
l      Manage member devices through network address translation (NAT)
l      Provide these functions: neighbor discovery, topology information collection, cluster management, and cluster state maintenance.
l      Support proxies
Member device
Normally, a member device is not configured with a public IP address
l      Member in the cluster
l      Neighbor discovery, being managed by the management device, running commands forwarded by proxies, and failure/log reporting
Candidate device
A candidate device is a switch that does not belong to any cluster, although it can be added to a cluster
1.1.3  Switch Role Changes in a Cluster
Figure 1-2 Role switching rules
l           A candidate device becomes a management device after you designate it as the management device of a cluster (you can do this by building a cluster on the device). Each cluster must have one and only one management device. After you specify the management device of a cluster, the management device discovers and determines candidate devices (by collecting NDP/NTDP information), which you can then add into the cluster through manual configuration.
l           A candidate device becomes a member device after being added to a cluster.
l           A member device becomes a candidate device after being removed from the cluster.
l           The management device becomes a candidate device only after you remove the cluster.
1.1.4  Cluster Principle and Implementation
I. Procedure of building a cluster
l           Network neighbor discovery: It uses NDP to discover the information about the directly connected neighbor devices.
l           Network topology discovery. It uses NTDP to collect the information about the network topology, including device connections and candidate device information in the network. The hop range for topology discovery can be adjusted manually.
l           Member recognition: The management device recognizes each member in the cluster by locating each member and then distributes configuration and management commands to the members.
l           Member management: The following events are managed through the management device: adding/removing a member, the member’s authentication on the management device, and handshake interval.
II. Introduction to NDP
NDP is the protocol for discovering the information about the adjacent nodes. NDP operates on the data link layer, so it supports different network layer protocols.
NDP is used to discover the information about directly connected neighbors, including the device type, software/hardware version, and connecting port of the adjacent devices. It can also provide the information concerning device ID, port simplex/duplex status, product version, Bootrom version and so on.
An NDP-enabled device maintains an NDP information table. Each entry in an NDP table ages with time. You can also clear the current NDP information manually to have adjacent information collected again.
An NDP-enabled device broadcasts NDP packets regularly to all ports in up state. An NDP packet carries the holdtime field, which indicates the period for the receiving devices to keep the NDP data. Receiving devices only store the information carried in the received NDP packets rather than forward them. The corresponding data entry in the NDP table is updated when the received information is different from the existing one. Otherwise, only the holdtime of the corresponding entry is updated.
III. Introduction to NTDP
NTDP is a protocol for network topology information collection. NTDP provides the information about the devices that can be added to clusters and collects the topology information within the specified hops for cluster management.
Based on the NDP information table created by NDP, NTDP transmits and forwards NTDP topology collection request to collect the NDP information and neighboring connection information of each device in a specific network range for the management device or the network administrator to implement needed functions.
Upon detecting a change occurred on a neighbor, a member device informs the management device of the change through handshake packets. The management device then collects the specified topology information through NTDP. Such a mechanism enables topology changes to be tracked in time.
IV. Handshake packets
Handshake packets are mainly used to maintain the states of the members in a cluster.
l           After a cluster is built, a member device initiates the handshake process and sends packets. The management device also sends handshake packets to the member device. The management device and member devices do not respond to the handshake packets they received but remain in the Active state.
l           If the management switch receives no handshake packet from a member switch for three consecutive times, it changes the state of the member device to Connect. Likewise, if a member device receives no handshake response packet from the management device for three consecutive times, the state of the member device changes from Active to Connect. You can use the timer command to set the handshake interval for a cluster, which is 10 seconds by default.
l           If the member device in the Connect state receives no handshake packet or management packet within the holdtime (the holdtime can be set by using the holdtime command in cluster view of the management device and is 60 seconds by default) that switches its state to Active, the member device changes to the Disconnect state, and the management device considers the member to be disconnected. A member device in the Active or Connect state is connected.
In addition, handshake packets are used to notify the management device of topology changes of neighboring devices.
1.2  HGMP V2 Configuration Task Overview
Table 1-2 HGMP V2 configuration task overview
Operation
Related section
Configure the management device
Enable NDP globally and for specific ports
Required
See section 1.3.1  "Enabling NDP Globally and for Specific Ports".
Configure NDP-related parameters
Optional
See section 1.3.2  "Configuring NDP-Related Parameters".
Enable NTDP globally and for specific ports
Required
See section 1.3.3  "Enabling NTDP Globally and for Specific Ports".
Configure NTDP-related parameters
Optional
See section 1.3.4  "Configuring NTDP-Related Parameters".
Enable the cluster function
Required
See section 1.3.5  "Enabling the Cluster Function".
Build a cluster
Required
See section 1.3.6  Building a Cluster”.
Configure cluster member management
Required
See section 1.3.7  "Configuring Cluster Member ".
Configure cluster topology management
Required
See section 1.3.8  Configuring Cluster Topology Management”.
Configure cluster parameters
Optional
See section 1.3.9  "Configuring Cluster Parameters".
Configure interaction for the cluster
Optional
See section 1.3.10  "Configuring Interaction for the Cluster".
Configure member devices
Required
See section 1.4.1  "Enabling NDP Globally and on Specific Ports".
Required
See section 1.4.2  "Enabling NTDP Globally and on Specific Ports".
Required
See section 1.4.3  "Enabling the Cluster Function"
Add a device to a cluster
Optional
See section 1.4.4  "Configuring to Add a Candidate Device to the Cluster".
  Caution:
Disabling NDP or NTDP on the management device of a cluster affects the operation of the cluster, although the operation cannot remove the cluster.
1.3  Management Device Configuration
1.3.1  Enabling NDP Globally and for Specific Ports
Table 1-3 Enable NDP globally and for specific ports
Operation
Enter system view
Enable NDP globally
ndp enable
Required
By default, NDP is enabled globally.
Enable NDP for the Ethernet port
system view
ndp enable interfaceinterface-list
Either is required.
By default, NDP is enabled on all ports.
Ethernet port view
ndp enable
  Caution:
l      NDP works only if it is enabled globally and on the ports.
l      When a port of an aggregation group is connected with a device in a cluster, the NDP feature must be enabled on all the ports of the aggregation group before the feature can work properly.
1.3.2  Configuring NDP-Related Parameters
Table 1-4 Configure NDP-related parameters
Operation
Enter system view
Configure the holdtime of NDP information
ndp timer aging aging-time
Optional
By default, the aging time of NDP packets is 180 seconds
Configure the interval to send NDP packets
ndp timer hello hello-time
Optional
By default, the interval of sending NDP packets is 60 seconds
1.3.3  Enabling NTDP Globally and for Specific Ports
Table 1-5 Enabling NDP globally and for specific ports
Operation
Enter system view
ntdp enable
Required
Enter Ethernet port view
Enable NTDP for the Ethernet port
ntdp enable
Required
  Caution:
l      NTDP works only if it is enabled globally and on the ports.
l      For an Ethernet port, NTDP is mutually exclusive with the BPDU tunnel function. For information about BPDU tunnel, refer to QinQ-BPDU Tunnel Operation Manual.
1.3.4  Configuring NTDP-Related Parameters
Table 1-6 Configure NTDP parameters
Operation
Enter system view
Configure the range topology information within which is to be collected
ntdp hop hop-value
Optional
By default, the hop range for topology collection is 3 hops
Configure the interval to collect topology information
ntdp timer interval-time
Optional
By default, the interval of topology collection is 1 minute.
Configure the hop delay time to forward topology-collection request packets
ntdp timer hop-delay time
Optional
By default, the hop delay time is 200 ms
Configure the port delay time to forward topology collection request packets for the device whose topology information is collected
ntdp timer port-delay time
Optional
By default, the port delay time is 20 ms
Quit to user view.
Start topology information collection
ntdp explore
Optional
The ntdp enable command is not compatible with the bpdu-tunnel enable command. You cannot configure these two commands at the same time. For information about BPDU Tunnel, refer to QinQ-BPDU Tunnel Operation Manual.
1.3.5  Enabling the Cluster Function
Table 1-7 Enable the cluster function
Operation
Enter system view
Enable the cluster function globally
cluster enable
Optional
By default, the cluster function is enabled
Before building a cluster, you must configure a private IP address pool available for the member devices in the cluster. When a candidate device joins the cluster, the management device dynamically assigns the candidate device a private IP address for inner-cluster communication. This enables the management device to manage and maintain member devices.
  Caution:
When configuring a cluster, make sure the routing tables are not full. Otherwise, the private IP routes of the cluster may not be advertised, causing the handshake packets cannot be exchanged and a device joins and exits the cluster repeatedly. If the routing table of the management device is full when you build a cluster, all the candidate devices will join and exit the cluster repeatedly. If the routing table of a candidate device is full when the candidate device joins the cluster, the candidate device will exit and join the cluster repeatedly.
I. Configuring cluster parameters manually
Table 1-8 Configuring cluster parameters manually
Operation
Enter system view
Specify the management VLAN
management-vlan vlan-id
Optional
By default, VLAN1 is the management VLAN.
Enter cluster view
Cluster
Configure a private IP address pool on the device to be used as the management device for the member devices in the cluster
ip-pool administrator-ip-address { ip-mask | ip-mask-length }
Required
Do not configure the IP addresses of the VLAN interfaces of the management device and member devices on the same network segment. Otherwise, the cluster will not work.
Set the current device as the management device and assign a cluster name
build name
Required
By default, a device is not the management device.
  Caution:
l      When the management VLAN is not VLAN 1, if the port on the management device that is connected to member devices are trunk or hybrid port, to implement cluster management, you must configure the port to permit the packets of management VLAN to pass with tags. If the port on the management device used to connecting member devices is an access port, to implement cluster management, you need to configure the port as a hybrid port or trunk port and configure the port to permit the packets of the management VLAN to pass with tags. See the VLAN Operation for details.
l      When the management VLAN is configured as VLAN1, if the port on the member device that is connected to the management device permits the packets from the management VLAN to pass with tags, configure the management device by following the previous description. If the port on the member device that is connected to management device permits the packets of management VLAN to pass without tags, to implement cluster management, you must perform one of the following configuration tasks: configure the corresponding port on the management device as the access type, or configure the port as trunk and the default VLAN of the port as VLAN1, or configure the port as hybrid and the default VLAN of the port as VLAN1 and permits the packets of management VLAN to pass the port without tags. See the VLAN Operation section for details.
l      You can configure an IP address pool only before the cluster is built. Moreover, you can perform the configuration on the management device only. You cannot change the IP address pool for an existing cluster.
II. Building a cluster automatically
Besides allowing you to build a cluster manually, the system also enables a cluster to be built automatically. You can build a cluster by using the following commands on the management device and following the steps prompted.
During the process of building a cluster automatically, after you enter the name of the cluster to be created as prompted, the system collects the information about all the candidate devices discovered within the specified hop range and add them to the cluster.
You can press <CTRL+C> to exit automatic cluster establishment. After this operation, no new device will be added and the added devices remain in the cluster.
Table 1-9 Building a cluster automatically
Operation
Enter system view
Optional
Enter cluster view
cluster
Configure an IP address pool for the cluster
Required
Build a cluster automatically
auto-build [ recover ]
Required
  Caution:
The VLAN interface IP addresses of the management device and member devices and the IP addresses in the cluster address pool cannot be of the same network segment. Otherwise, the cluster operates improperly.
1.3.7  Configuring Cluster Member Management
Member management covers the following:
l           You can manually designate the candidate device to join a cluster or manually remove the designated member device from the cluster. You must add/remove a member on the management device; otherwise, an error message will be returned.
l           You can control the member device remotely by using the remote control function of the management device. For example, if a member device fails due to incorrect configuration, you can delete the start configuration file and reboot the member device to recover the normal communication between the management device and member devices.
l           On the management device, you can configure and manage the specified member device by switching to the view of the member device. After the configuration is complete, you can switch back to the management device from the member device.
Table 1-10 Configure member management
Operation
Enter system view
Enter cluster view
cluster
Add a candidate device to a cluster
add-member [ member-number ] mac-address mac-address [ password password ]
Optional
Remove a member device from the cluster
delete-member member-number [ to-black-list ]
Optional
Reboot a specified member device
reboot member { member-number | mac-address mac-address } [ eraseflash ]
Optional
Quit to system view
Quit to user view
Switch between the management device view and a member device view
cluster switch-to { member-number | mac-address mac-address | administrator }
Optional
&  Note:
Normally, members are numbered sequentially, and the numbers already assigned to members are tracked by the management device. When a member device joins the cluster again after it exits the cluster, its original member number is assigned to it again if the number is currently not assigned to another member.
Telnet is used when you use the cluster switch-to command to switch between the management device and member devices in a cluster. Note the following when switching between the devices of a cluster.
l           Make sure that the telnet server command is enabled for the peer device before switching. Otherwise, switching fails.
l           Authentication is performed when you switch between the management device and a member device in a cluster. You will fail to switch between the management device and a member device if the level-3 super passwords of the two devices are not the same. When a candidate device joins a cluster, its super password is set to that of the management device. You are not recommended to modify the super passwords of cluster members (including the management device and member devices) after a cluster is established for fear of switching failures caused by inconsistency super passwords.
l           When you switch from the management device to a member device, the view level remains unchanged.
l           When you switch from a member device to the management device, the user level is determined as preset.
l           You will fail to switch a device where Telnet users are full.
l           To prevent resource wasting and performance decrease, avoid closed-loop switching. A closed loop occurs when you switch from the management device to a member device and then switch back to the management device again from the member device. So, after you switch to a member device from the management device, you are recommended to use the quit command to return the management device rather than using the cluster switch-to administrator command to switch to the management device again.
Note that the telnet server command is enabled on the devices where the cluster function is enabled by default. If the undo telnet server enable command and the cluster function are enabled at the same time in the configuration file used to boot the device, the undo telnet server enable command does not take effect when a device boots with the configuration file. Instead, the telnet server command will be enabled for the device automatically.
White lists and black lists provide basis for topology management. Their meanings are described as follows:
l           White list for topology management: Correct network topology confirmed to be correct by network administrators. The information of nodes and their relationship with their neighbors at any give moment can be extracted from the current network topology. Meanwhile, the white list can be maintained based on the current network topology, such as adding, removing, and modifying nodes.
l           Blacklist for topology management: Any device in the blacklist is not allowed to join a cluster automatically. The network Administrator needs blacklist a device manually, including device MAC address. If a device is blacklisted and connected to the network through another device not blacklisted, the access device’s information and the access port will be automatically recorded.
The white list and black list are mutually exclusive: nodes in the white list must not be in the black list, and vice versa. Note that a topology node can be neither in the white list nor the black list. These are usually new nodes and need to be authenticated by administrators.
The white list and black list and will not disappear even if the management switch is powered off. They implement two backup and recovery mechanisms: backups on the FTP server or the Flash of the management switch. In either backup mode, you need to restore the white list or blacklist manually. When the management switch restarts or the cluster management is reconfigured, the management switch restores the white list and blacklist from the Flash. You can use the topology restore-from command to restore the topology using the standard topology information on the FTP server or in the Flash of the management device.
Note that device cannot judge whether the saved standard topology information is right. So, make sure that the saved topology information is correct.
Table 1-11 Configure topology management
Operation
Enter system view
Enter cluster view
cluster
Blacklist a device
black-list add-mac mac-address
Optional
Remove a device from the backlist
black-list delete-mac { all | mac-address }
Optional
Confirm the current topology of the cluster and save it as base topology
topology accept { all [ save-to { ftp-server | local-flash } ] | mac-address mac-address | member-id member-number }
Optional
Save the standard topology information to the FTP server or the Flash of the management device
topology save-to { ftp-server | local-flash }
Optional
Restore the topology using the standard topology information stored the FTP server or in the Flash of the management device
topology restore-from { ftp-server | local-flash }
Optional
1.3.9  Configuring Cluster Parameters
Cluster parameters include device holdtime and handshake interval.
l           Handshake interval: in a cluster, the connections between the member devices and the management device are maintained by handshake packets. The cluster member states and link states are monitored by exchanging handshake packets between member devices and the management device periodically. You can use the timer command in cluster view of the management device to configure the handshake interval.
l           Holdtime of a device: if the management device does not receive handshake packets from a member device in three consecutive handshake intervals, the member device state saved on the management device is switched from the active state to the connect state. Within the holdtime, if a member device in the connect state does not receive handshake packets or management packets which can switch the member device back to the active state, the member device will be switched to the disconnect state. In this case, the management device regards that the member device has left the cluster, and the state of the member device is down on the management device.
Table 1-12 Configure cluster parameters
Operation
Enter system view
Enter cluster view
cluster
Configure the holdtime for a device
holdtime seconds
Optional
By default, the holdtime is 60 seconds.
Configure a handshake interval
timer interval-time
Optional
By default, the handshake interval is 10 seconds.
1.3.10  Configuring Interaction for the Cluster
After building a cluster, you can configure FTP server, TFTP server, NMS host, and log host universally on the management device for the cluster. A member device in the cluster will access the server configured through the management device.
All logs of the member devices in the cluster will be output to the log host configured: when member devices output logs, the logs are directly sent to the management device, which then translates the address of the logs and sends them to the log host configured for the cluster. Likewise, all Trap messages sent by member devices are output to the NMS host configured for the cluster.
Table 1-13 Configure interaction for the cluster
Operation
Enter system view
Enter cluster view
cluster
Configure the public FTP server for the cluster
ftp-server ip-address [ user-name username password { simple | cipher } password ]
Optional
By default, the cluster has no public FTP server.
Configure the TFTP server for the cluster
tftp-server ip-address
Optional
By default, the cluster has no public TFTP server.
Configure the log host for the cluster
logging-host ip-address
Optional
By default, the cluster has no public log host.
Configure the SNMP host for the cluster
snmp-host ip-address [ community-string read string1 write string2 ]
Optional
By default, the cluster has no SNMP host configured.
Configure the network management (NM) interface for the cluster
nm-interface vlan-interface vlan-id
Optional
By default, the management VLAN interface functions as the network management interface.
  Caution:
The log host configured for the cluster takes effect only after you use the info-center loghost command in system view. For more about the info-center loghost command, see the "Information Center Commands".
1.4  Configuring Member Devices
1.4.1  Enabling NDP Globally and on Specific Ports
Refer to 1.3.1  Enabling NDP Globally and for Specific Ports.
1.4.2  Enabling NTDP Globally and on Specific Ports
Refer to 1.3.3  Enabling NTDP Globally and for Specific Ports.
1.4.3  Enabling the Cluster Function
Refer to 1.3.5  Enabling the Cluster Function.
1.4.4  Configuring to Add a Candidate Device to the Cluster
Table 1-14 Configure to add a member to the cluster
Operation
Enter system view
Enter cluster view
cluster
Add a candidate device to the cluster
administrator-address mac-address name name
Optional
By default, a device is not a member of any cluster.
1.5  Displaying and Maintaining a Cluster
After the configuration above, you can execute the display command to display the running status after the cluster configuration. You can verify the configuration effect through checking the displayed information.
You can use the reset command in user view to clear NDP statistics.
Table 1-15 Display and maintain cluster configurations
Operation
Display NDP configuration
display ndp [ interface port-list ]
Display the global NTDP information
display ntdp
Display device information collected through NTDP
display ntdp device-list [ verbose ]
Display state and statistics information about a cluster
display cluster
Display the base topology of the cluster
display cluster base-topology [ mac-address mac-address | member-id member-number ]
Display the current blacklist of the cluster
display cluster black-list
Display the information about the candidate devices of a cluster
display cluster candidates [ mac-address mac-address | verbose ]
Display the current topology of the cluster or the topological path between two nodes
display cluster current-topology [ mac-address mac-address [ to-mac-address mac-address ] | member-id member-number [ to-member-id member-number ] ]
Display the information about the cluster members
display cluster members [ member-number | verbose ]
Clear the NDP statistics on a port
reset ndp statistics [ interface interface-list ]
1.6  HGMP V2 Configuration Example
I. Network requirements
Three switches form a cluster, in which:
l           The management device is an S5500-SI series switch.
l           The rest are member devices.
The S55500-SI switch manages the rest two member devices as the management device. The detailed information about the cluster is as follows.
l           The two member devices are connected to GigabitEthernet1/0/2 and GigabitEthernet1/0/3 ports of the management device.
l           The management device is connected to the external network through its GigabitEthernet1/0/1 port.
l           GigabitEthernet1/0/1 port of the management device belongs to VLAN2, whose interface IP address is 163.172.55.1.
l           All the devices in the cluster use the same FTP server and TFTP server.
l           The FTP server and TFTP server share one IP address: 63.172.55.1.
l           The SNMP site and log host share one IP address: 69.172.55.4.
l           The management device collects topology information in every three minutes.
l           Blacklist the device whose MAC address is 00e0-fc01-0013.
II. Network diagram
Figure 1-3 Network diagram for HGMP cluster configuration
III. Configuration procedure
1)         Configure the member devices (taking one member as an example)
# Enable NDP globally and for GigabitEthernet1/0/1.
[Sysname] ndp enable
[Sysname-GigabitEthernet1/0/1] ndp enable
# Enable NTDP globally and for GigabitEthernet1/0/1.
[Sysname] ntdp enable
[Sysname-GigabitEthernet1/0/1] ntdp enable
# Enable the cluster function.
[Sysname] cluster enable
2)         Configure the management device
# Enable NDP globally and for the GigabitEthernet1/0/2 and GigabitEthernet1/0/3 ports.
[Sysname] interface GigabitEthernet 1/0/2
[Sysname-GigabitEthernet1/0/2] ndp enable
[Sysname-GigabitEthernet1/0/2] quit
[Sysname] interface GigabitEthernet 1/0/3
[Sysname-GigabitEthernet1/0/3] ndp enable
[Sysname-GigabitEthernet1/0/3] quit
# Configure the holdtime of NDP information to be 200 seconds.
[Sysname] ndp timer aging 200
# Configure the interval to send NDP packets to be 70 seconds.
[Sysname] ndp timer hello 70
# Enable NTDP globally and for GigabitEthernet1/0/2 and GigabitEthernet1/0/3 ports.
[Sysname-GigabitEthernet1/0/2] ntdp enable
[Sysname-GigabitEthernet1/0/3] ntdp enable
# Configure the hop count to collect topology to be 2.
[Sysname] ntdp hop 2
# Configure the delay time for topology-collection request packets to be forwarded on member devices to be 150 ms.
[Sysname] ntdp timer hop-delay 150
# Configure the delay time for topology-collection request packets to be forwarded through the ports of member devices to be 15 ms.
[Sysname] ntdp timer port-delay 15
# Configure the interval to collect topology information to be 3 minutes.
[Sysname] ntdp timer 3
# Enter cluster view.
[Sysname] cluster
[Sysname-cluster]
# Configure an IP address pool for the cluster. The IP address pool contains six IP addresses, starting from 172.16.0.1.
[Sysname-cluster] ip-pool 172.16.0.1 255.255.255.248
# Specify a name for the cluster and create the cluster.
[Sysname-cluster] build aaa
[aaa_0.Sysname-cluster]
# Configure the holdtime of the member device information to be 100 seconds.
[aaa_0.Sysname-cluster] holdtime 100
# Configure the interval to send handshake packets to be 10 seconds.
[aaa_0.Sysname-cluster] timer 10
# Configure the FTP Server, TFTP Server, Log host and SNMP host for the cluster.
[aaa_0.Sysname-cluster] ftp-server 63.172.55.1
[aaa_0.Sysname-cluster] tftp-server 63.172.55.1
[aaa_0.Sysname-cluster] logging-host 69.172.55.4
[aaa_0.Sysname-cluster] snmp-host 69.172.55.4
# Blacklist the device whose MAC address is 00e0-fc01-0013.
[aaa_0.Switch-cluster] black-list add-mac 00e0-fc01-0013
&  Note:
l      Upon the completion of the above configurations, you can execute the cluster switch-to { member-number | mac-address H-H-H } command on the management device to switch to a member device to maintain and manage a member device. After the configuration, you can execute the quit command on a member device to return the management device. Make sure that the telnet server command is enabled on the peer before switching.
l      On a member device, you can also use the cluster switch-to administrator command to switch to the management device view.
l      On the management device, you can use the reboot member { member-number | mac-address H-H-H } [ eraseflash ] command to reboot a member device. Refer to the related configuration sections in this manual for details.
l      Upon the completion of the above configurations, logs and SNMP trap messages of all the members in the cluster are sent to the SNMP host.
