H3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
HomeSupportSwitchesS5500 SeriesConfigure & DeployConfiguration GuidesH3C S5500-SI Series Ethernet Switches Operation Manual-Release 1205-(V1.03)
19-ACL Operation
19-ACL Operation 169 KB
Table of Contents
Chapter 1 ACL Overview.. 1-1
1.1 ACL Overview. 1-1
1.2 Time-Based ACL. 1-1
1.3 IPv4 ACL. 1-1
1.3.1 IPv4 ACL Classification. 1-2
1.3.2 IPv4 ACL Match Order 1-2
1.3.3 IP Fragments Filtering with IPv4 ACL. 1-3
1.3.4 IPv4 ACL Creation. 1-3
1.4 IPv6 ACL. 1-4
1.4.1 IPv6 ACL Classification. 1-4
1.4.2 IPv6 ACL Match Order 1-4
1.4.3 IPv6 ACL Creation. 1-4
Chapter 2 IPv4 ACL Configuration. 2-1
2.1 Creating a Time Range. 2-1
2.1.1 Configuration Procedure. 2-1
2.1.2 Configuration Example. 2-2
2.2 Configuring a Basic IPv4 ACL. 2-3
2.2.1 Configuration Prerequisites. 2-3
2.2.2 Configuration Procedure. 2-3
2.2.3 Configuration Example. 2-4
2.3 Configuring an Advanced IPv4 ACL. 2-4
2.3.1 Configuration Prerequisites. 2-5
2.3.2 Configuration Procedure. 2-5
2.3.3 Configuration Example. 2-6
2.4 Configuring an Ethernet Frame Header ACL. 2-6
2.4.1 Configuration Prerequisites. 2-6
2.4.2 Configuration Procedure. 2-6
2.4.3 Configuration Example. 2-7
2.5 Displaying and Maintaining IPv4 ACLs. 2-8
2.6 IPv4 ACL Configuration Example. 2-8
2.6.1 Network Requirements. 2-8
2.6.2 Network Diagram.. 2-8
2.6.3 Configuration Procedure. 2-9
Chapter 3 IPv6 ACL Configuration. 3-1
3.1 Configuring a Time Range. 3-1
3.2 Configuring a Basic IPv6 ACL. 3-1
3.2.1 Configuration Prerequisites. 3-1
3.2.2 Configuration Procedure. 3-1
3.2.3 Configuration Example. 3-2
3.3 Configuring an Advanced IPv6 ACL. 3-3
3.3.1 Configuration Prerequisites. 3-3
3.3.2 Configuration Procedure. 3-3
3.3.3 Configuration Example. 3-4
3.4 Displaying and Maintaining IPv6 ACLs. 3-4
3.5 IPv6 ACL Configuration Example. 3-5
3.5.1 Network Requirements. 3-5
3.5.2 Configuration Procedure. 3-5
1.1  ACL Overview
An access control list (ACL) is used primarily to identify traffic flows. In order to filter data packets, a series of match rules must be configured on the network device to identify the packets to be filtered. After the specific packets are identified, and based on the predefined policy, the network device can permit/prohibit the corresponding packets to pass.
ACLs classify packets based on a series of match conditions, which can be the source addresses, destination addresses and port numbers carried in the packets.
The packet match rules defined by ACLs can be referenced by other functions that need to differentiate traffic flows, such as the definition of traffic classification rules in QoS.
&  Note:
In this manual, IPv4 ACL refers to ACL used for filtering IPv4 packets, and IPv6 ACL refers to ACL used for filtering IPv6 packets.
1.2  Time-Based ACL
A time range-based ACL enables you to implement ACL control over packets by differentiating the time ranges.
A time range can be specified in each rule in an ACL. If the time range specified in a rule is not configured, the system will give a prompt message and allow such a rule to be successfully created. However, the rule does not take effect immediately. It takes effect only when the specified time range is configured and the system time is within the time range. If you remove the time range of an ACL rule, the ACL rule becomes invalid the next time the ACL rule timer refreshes.
1.3  IPv4 ACL
This section covers these topics:
l           IPv4 ACL Classification
l           IPv4 ACL Match Order
l           IP Fragments Filtering with IPv4 ACL
IPv4 ACLs, identified by ACL numbers, fall into the following four categories:
l           Basic IPv4 ACL, based on source IP address. Basic ACLs are numbered 2000 through 2999.
l           Advanced IPv4 ACL, based on source IP address, destination IP address, protocol carried on IP, and other Layer 3 or Layer 4 protocol header information. Advanced ACLs are numbered 3000 through 3999.
l           Ethernet frame header ACL, based on Layer 2 protocol header fields such as source MAC address, destination MAC address, 802.1p priority, and link layer protocol type. Ethernet frame header ACLs are numbered 4000 through 4999.
Each ACL is a sequential collection of rules defined with different matching criteria. The order in which a packet is matched against the rules may thus affect how the packet is handled.
At present, the following two match orders are available:
l           config: where rules are compared against in the order in which they are configured.
l           auto: where depth-first match is performed.
I. Depth-first match for a basic IPv4 ACL
The following shows how your device performs depth-first match in a basic IPv4 ACL:
1)         Sort rules by source IP address wildcard first and compare packets against the rule configured with more zeros in the source IP address wildcard prior to other rules.
2)         If two rules are present with the same number of zeros in their source IP address wildcards, compare packets against the rule configured first prior to the others.
For example, the rule with the source IP address wildcard 0.0.0.255 is compared prior to the rule with the source IP address wildcard 0.0.255.255.
II. Depth-first match for an advanced IPv4 ACL
The following shows how your device performs depth-first match in an advanced IPv4 ACL:
2)         If two rules are present with the same number of zeros in their source IP address wildcards, look at the destination IP address wildcards in the rules in addition. Then, compare packets against the rule configured with more zeros in the destination IP address wildcard prior to the other.
3)         If the numbers of zeros in the destination IP address wildcards are the same, compare packets against the rule configured first prior to the other.
III. Depth-first match for an Ethernet frame header IPv4 ACL
The following shows how your device performs depth-first match in an Ethernet frame header ACL:
1)         Sort rules by source MAC address mask first and compare packets against the rule configured with more ones in the source MAC address mask prior to other rules.
2)         If two rules are present with the same number of ones in their source MAC address masks, look at the destination MAC address masks. Then, compare packets against the rule configured with more ones in the destination MAC address mask prior to the other.
3)         If the numbers of ones in the destination MAC address masks are the same, the one configured first is compared prior to the other.
For example, the rule with source MAC address mask FFFF-FFFF-0000 is compared prior to the rule with source MAC address mask FFFF-0000-0000.
The comparison of a packet against an ACL stops once a match is found. The packet is then processed as per the rule.
Traditionally, ACL does not check all IP fragments but first ones. All non-first fragments are handled the way the first fragments are handled. This causes security risk as attackers may fabricate non-first fragments to attack your network.
As for the configuration of a rule of an IPv4 ACL, the fragment keyword specifies that the rule applies to non-first fragment packets only, and does not apply to non-fragment packets or the first fragment packets. ACL rules that do not contain this keyword is applicable to both non-fragment packets and fragment packets.
An IPv4 ACL consists of a set of rules. Before you can configure ACL rules, you must first create an IPv4 ACL.
When creating an IPv4 ACL:
l           You must specify an ACL number (numeric type), and
l           You can optionally specify the match order of the IPv4 ACL.
After an IPv4 ACL is created, the IPv4 ACL view is displayed.
1.4  IPv6 ACL
l           IPv6 ACL Classification
l           IPv6 ACL Match Order
IPv6 ACLs, identified by ACL numbers, fall into the following three categories:
l           Basic IPv6 ACL, based on source IPv6 address. Basic IPv6 ACLs are numbered 2000 through 2999.
l           Advanced IPv6 ACL, based on source IPv6 address, destination IPv6 address, protocol carried on IP, and other Layer 3 or Layer 4 protocol header fields. Advanced ACLs are numbered 3000 through 3999.
Similar to IPv4 ACLs, IPv6 ACLs are sequential collections of rules defined with different matching parameters. The order in which a packet is matched against the rules in an IPv6 ACL may affect how the packet is handled.
Like IPv4 ACLs, the following two match orders are available IPv6 ACLs:
The depth-first mechanism performed by IPv6 ACLs is to match packets against the rule that specifies a narrower address range first. This is done by comparing prefix lengths: the smaller the prefix length, the narrower the address range.
Consider two IPv6 addresses, 2050:6070::/96 and 2050:6070::/64. In the auto match approach, packets are matched against the rule with the address of 2050:6070::/96 first, because that address specifies a narrower address range compared with 2050:6070::/64. In case two rules with the same prefix length are defined in an IPv6 ACL, the one configured first is compared prior to the other one.
An IPv6 ACL consists of a set of rules. Before you can configure IPv6 ACL rules, you must first create an IPv6 ACL.
When creating an IPv6 ACL:
l           You must specify an IPv6 ACL number (numeric type), and
l           You can optionally specify the match order of the IPv6 ACL.
After an IPv6 ACL is created, the IPv6 ACL view is displayed.
This chapter covers these topics:
l           Creating a Time Range
l           Configuring a Basic IPv4 ACL
l           Configuring an Advanced IPv4 ACL
l           Configuring an Ethernet Frame Header ACL
l           Displaying and Maintaining IPv4 ACLs
l           IPv4 ACL Configuration Example
Three types of time ranges are available:
l           Periodic time range, which recurs periodically on the day or days of the week.
l           Absolute time range, which takes effect only in a period of time and does not recur.
l           Compound time range, which recurs on the day or days of the week within a period.
  Caution:
On the S5500-SI Series Ethernet Switches, the start time of an absolute time range cannot be earlier than 1970/1/1 00:00 and the end time of an absolute time range cannot be later than 2100/12/31 24:00.
Follow these steps to create a time range:
To do…
Use the command…
Remarks
Enter system view
Create a time range
time-range time-name { start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
Required
Note that:
l           Periodic time range created using the time-range time-name start-time to end-time days command. A time range thus created recurs periodically on the day or days of the week.
l           Absolute time range created using the time-range time-name { from time1 date1 [ to time2 date2 ] | to time2 date2 } command. Unlike a periodic time range, a time range thus created does not recur. For example, to create an absolute time range that is active between January 1, 2004 00:00 and December 31, 2004 23:59, you may use the time-range test from 00:00 01/01/2004 to 23:59 12/31/2004 command.
l           Compound time range created using the time-range time-name start-time to end-time days { from time1 date1 [ to time2 date2 ] | to time2 date2 } command. A time range thus created recurs on the day or days of the week only within the specified period. For example, to create a time range that is active from 12:00 to 14:00 on Wednesdays between January 1, 2004 00:00 and December 31, 2004 23:59, you may use the time-range test 12:00 to 14:00 wednesday from 00:00 01/01/2004 to 23:59 12/31/2004 command.
l           You may create individual time ranges identified with the same name. They are regarded as one time range whose active period is the result of ORing periodic ones, ORing absolute ones, and ANDing periodic and absolute ones.
l           If the start time is not specified, the time range starts on the earliest time available from the system and ends on the end date. If the end date is note specified, the time range is from the date of configuration till the largest date available from the system.
l           Up to 256 time ranges can be defined.
# Create a periodic time range that spans from 8:00 to 18:00 every working day.
[Sysname] time-range test 8:00 to 18:00 working-day
[Sysname] display time-range test
Current time is 13:27:32 4/16/2005 Saturday
Time-range : test ( Inactive )
 08:00 to 18:00 working-day
# Create an absolute time range that spans from 15:00 2000/1/28 to 15:00 2004/1/28.
[Sysname] time-range test from 15:00 2000/1/28 to 15:00 2004/1/28
 from 15:00 1/28/2000 to 15:00 1/28/2004
Basic IPv4 ACLs filter packets based on source IP address. They are numbered in the range 2000 to 2999.
If you want to reference a time range to a rule, define it with the time-range command first.
Follow these steps to configure a basic IPv4 ACL:
To do…
Use the command…
Remarks
Enter system view
Create and enter a basic IPv4 ACL view
acl number acl-number [ match-order { config | auto } ]
Required
The default match order is config.
Create or modify a rule
rule [ rule-id ] { permit | deny } [ rule-string ]
Required
To create multiple rules, repeat this step.
Set a rule numbering step
step step-value
Optional
The default step is 5.
Create an ACL description
Optional
Create a rule description
rule rule-id comment text
Optional
When configuring a rule, note that:
l           You will fail to create or modify a rule if its permit/deny statement is exactly the same as another rule. In addition, if the ACL match order is set to auto rather than config, you cannot modify ACL rules.
l           When defining ACL rules, you are not necessarily to assign them IDs. The system can automatically assign rule IDs starting with 0 and increasing in certain rule numbering steps. A rule ID thus assigned is greater than the current highest rule ID. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the next rule will be numbered 30.
l           A newly defined rule cannot be identical with any existing rule, otherwise the rule cannot be successfully created (the system will prompt the rule already exists)
l           Rules created with the auto keyword specified are sorted according to the “depth first” principle regardless of the order they are created. However, the ID of each rule does not change.
  Caution:
l      You can modify the match order of an ACL with the acl number acl-number match-order { auto | config } command but only when it does not contain any rules.
l      You can use the rule comment command only for existing ACL rules.
# Create IPv4 ACL 2000 to deny the packets with the source address 1.1.1.1 to pass.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule deny source 1.1.1.1 0
# Verify the configuration.
[Sysname-acl-basic-2000] display acl 2000
Basic ACL  2000, 1 rule,
ACL's step is 5
 rule 0 deny source 1.1.1.1 0 (0 times matched)
Advanced IPv4 ACLs filter packets based on source IP address, destination IP address, upper protocol carried on IP, and other protocol header fields, such as the TCP/UDP source port, TCP/UDP destination port, ICMP message type, and ICMP message code.
In addition, advanced ACLs allow you to filter packets based on three priority criteria: type of service (ToS), IP precedence, and differentiated services codepoint (DSCP) priority.
Advanced ACLs are numbered in the range 3000 to 3999. Compared to basic ACLs, they allow of more flexible and accurate filtering.
&  Note:
l      When you configure both IP priority and ToS priority for a rule, both priorities are valid.
l      When you configure both IP/ToS priority and DSCP for a rule, only DSCP is valid.
Follow these steps to configure an advanced IPv4 ACL:
To do…
Use the command…
Remarks
Enter system view
Create and enter an advanced IPv4 ACL view
Required
rule [ rule-id ] { permit | deny } protocol [ rule-string ]
Required
step step-value
Optional
Optional
Optional
  Caution:
# Create IPv4 ACL 3000 to permit TCP packets with port number 80 sent from 129.9.0.0 to 202.38.160.0.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
[Sysname-acl-adv-3000] display acl 3000
Advanced ACL  3000, 1 rule,
ACL's step is 5
 rule 0 permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq www (0 times matched)
Ethernet frame header ACLs filter packets based on Layer 2 protocol header fields such as source MAC address, destination MAC address, 802.1p priority, and link layer protocol type. They are numbered in the range 4000 to 4999.
Follow these steps to configure an Ethernet frame header ACL:
To do…
Use the command…
Remarks
Enter system view
Create and enter an Ethernet frame header ACL view
Required
Required
step step-value
Optional
Optional
Optional
  Caution:
# Create IPv4 ACL 4000 to deny frames with the 802.1p priority of 3.
[Sysname] acl number 4000
[Sysname-acl-ethernetframe-4000] rule deny cos 3
[Sysname-acl-ethernetframe-4000] display acl 4000
Ethernet frame ACL  4000, 1 rule,
ACL's step is 5
rule 0 deny cos excellent-effort(0 times matched)
To do...
Use the command…
Remarks
Display information about a specified or all IPv4 ACLs
display acl { all | acl-number }
Available in any view
Display the configuration and state of a specified or all time ranges
display time-range { all | time-name }
Clear the statistics about the specified or all ACLs
reset acl counter { all | acl-number }
Available in user view
Different departments of an enterprise are interconnected on the intranet through the ports of a switch. The IP address of the wage query server is 192.168.1.2. Devices of the R&D department are connected to the GigabitEthernet1/0/1 port of the switch. Apply an ACL to deny requests sourced from the R&D department and destined for the wage server during the working hours (8:00 to 18:00).
Figure 2-1 Network diagram for ACL configuration
1)         Create a time range for office hours
# Create a periodic time range spanning 8:00 to 18:00 in working days.
[Sysname] time-range trname 8:00 to 18:00 working-day
2)         Define an ACL to control accesses to the salary server
# Create and enter the view of advanced IPv4 ACL 3000.
# Create a rule to control accesses of the R&D Department to the salary server.
[Sysname-acl-adv-3000] rule 0 deny ip source any destination 192.168.1.2 0.0.0.0 time-range trname
[Sysname-acl-adv-3000] quit
3)         Apply the ACL
# Apply IPv4 ACL 3000 to the inbound direction of interface GigabitEthernet1/0/1.
[Sysname] traffic classifier test
[Sysname-classifier-test] if-match acl 3000
[Sysname-classifier-test] quit
[Sysname] traffic behavior test
[Sysname-behavior-test] filter deny
[Sysname-behavior-test] quit
[Sysname] qos policy test
[Sysname-qospolicy-test] classifier test behavior test
[Sysname-qospolicy-test] quit
[Sysname-GigabitEthernet1/0/1] qos apply policy test inbound
l           Configuring a Time Range
l           Configuring a Basic IPv6 ACL
l           Configuring an Advanced IPv6 ACL
l           Displaying and Maintaining IPv6 ACLs
l           IPv6 ACL Configuration Example
Refer to section 2.1  “Creating a Time Range.”
Basic IPv6 ACLs filter packets based on source IPv6 address. They are numbered in the range 2000 to 2999.
Follow these steps to configure an IPv6 ACL:
To do…
Use the command…
Remarks
Enter system view
Create and enter a basic IPv6 ACL view
acl ipv6 number acl-number [ match-order { config | auto } ]
Required
Create a rule
Required
step step-value
Optional
Optional
Optional
  Caution:
l      You can modify the match order of an IPv6 ACL with the acl ipv6 number acl6-number match-order { auto | config } command but only when it does not contain any rules.
l      The rule specified in the rule comment command must have existed.
# Create IPv6 ACL 2000 to permit IPv6 packets with source address 2030:5060::9050/64 to pass while denying IPv6 packets with source address fe80:5060::8050/96.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source 2030:5060::9050/64
[Sysname-acl6-basic-2000] rule deny source fe80:5060::8050/96
[Sysname-acl6-basic-2000] display acl ipv6 2000
 Basic IPv6 ACL  2000, 2 rules,
 ACL's step is 5
 rule 0 permit source 2030:5060::9050/64 (0 times matched)
 rule 5 deny source FE80:5060::8050/96 (0 times matched)
Advanced ACLs filter packets based on the source IPv6 address, destination IPv6 address, upper protocol carried on IP, and other protocol header fields such as the TCP/UDP source port, TCP/UDP destination port, ICMP message type, and ICMP message code.
Advanced IPv6 ACLs are numbered in the range 3000 to 3999. Compared to basic IPv6 ACLs, they allow of more flexible and accurate filtering.
Follow these steps to configure an advanced IPv6 ACL:
To do…
Use the command…
Remarks
Enter system view
Create and enter an advanced IPv6 ACL view
Required
Create a rule
Required
step step-value
Optional
Optional
Optional
  Caution:
# Create IPv6 ACL 3000 to permit the TCP packets with the source address 2030:5060::9050/64 to pass.
[Sysname-acl6-adv-3000] rule permit tcp source 2030:5060::9050/64
[Sysname-acl6-adv-3000] display acl ipv6 3000
 Advanced IPv6 ACL  3000, 1 rule,
 ACL's step is 5
 rule 0 permit tcp source 2030:5060::9050/64 (0 times matched)
To do…
Use the command…
Remarks
Display information about a specified or all IPv6 ACLs
display acl ipv6 { all | acl-number }
Clear the statistics about a specified or all IPv6 ACLs
reset acl ipv6 counter { all | acl-number }
Configure packet filtering on interface GigabitEthernet1/0/2 to deny all IPv6 packets but those with source addresses in the range 4050::9000 to 4050::90FF.
1)         Configure ACL6
# Enter system view.
# Configure an ACL rule to permit packets from 4050::9000 to 4050::90FF.
[Sysname-acl6-basic-2000] rule permit source 4050::9000/120
# Configure an ACL rule to deny packets from other addresses.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule deny source any
2)         Configure ACL rules on the inbound direction of the GigabitEthernet1/0/2 port.
# Configure class and traffic behaviors to permit packets from 4050::9000 to 4050::90FF.
[Sysname] traffic classifier c_permit
[Sysname-classifier-c_permit] if-match acl ipv6 2000
[Sysname-classifier-c_permit] quit
[Sysname] traffic behavior b_permit
[Sysname-behavior-b_permit] filter permit
[Sysname-behavior-b_permit] quit
# Configure class and traffic behaviors to deny packets from other addresses.
[Sysname] traffic classifier c_deny
[Sysname-classifier-c_deny] if-match acl ipv6 2001
[Sysname-classifier-c_deny] quit
[Sysname] traffic behavior b_deny
[Sysname-behavior-b_deny] filter deny
[Sysname-behavior-b_deny] quit
# Define a traffic policy and apply it.
[Sysname-qospolicy-test] classifier c_permit behavior b_permit
[Sysname-qospolicy-test] classifier c_deny behavior b_deny
[Sysname] interface GigabitEthernet 1/0/2
[Sysname-GigabitEthernet1/0/2] qos apply policy test inbound
