07-IP组播命令参考
04-PIM命令
本章节下载: 04-PIM命令  (335.86 KB)
04-PIM命令
1 PIM配置命令
1.1 PIM配置命令
1.1.1 auto-rp enable
1.1.2 bidir-pim enable (PIM view)
1.1.3 bsm-fragment enable (PIM view)
1.1.4 bsr-policy (PIM view)
1.1.5 c-bsr (PIM view)
1.1.6 c-bsr admin-scope (PIM view)
1.1.7 c-bsr global
1.1.8 c-bsr group
1.1.9 c-bsr hash-length (PIM view)
1.1.10 c-bsr holdtime (PIM view)
1.1.11 c-bsr interval (PIM view)
1.1.12 c-bsr priority (PIM view)
1.1.13 c-rp (PIM view)
1.1.14 c-rp advertisement-interval (PIM view)
1.1.15 c-rp holdtime (PIM view)
1.1.16 crp-policy (PIM view)
1.1.17 display pim bsr-info
1.1.18 display pim claimed-route
1.1.19 display pim control-message counters
1.1.20 display pim df-info
1.1.21 display pim grafts
1.1.22 display pim interface
1.1.23 display pim join-prune
1.1.24 display pim neighbor
1.1.25 display pim routing-table
1.1.26 display pim rp-info
1.1.27 hello-option dr-priority (PIM view)
1.1.28 hello-option holdtime (PIM view)
1.1.29 hello-option lan-delay (PIM view)
1.1.30 hello-option neighbor-tracking (PIM view)
1.1.31 hello-option override-interval (PIM view)
1.1.32 holdtime assert (PIM view)
1.1.33 holdtime join-prune (PIM view)
1.1.34 jp-pkt-size (PIM view)
1.1.35 jp-queue-size (PIM view)
1.1.36 pim
1.1.37 pim bfd enable
1.1.38 pim bsr-boundary
1.1.39 pim dm
1.1.40 pim hello-option dr-priority
1.1.41 pim hello-option holdtime
1.1.42 pim hello-option lan-delay
1.1.43 pim hello-option neighbor-tracking
1.1.44 pim hello-option override-interval
1.1.45 pim holdtime assert
1.1.46 pim holdtime join-prune
1.1.47 pim neighbor-policy
1.1.48 pim require-genid
1.1.49 pim sm
1.1.50 pim state-refresh-capable
1.1.51 pim timer graft-retry
1.1.52 pim timer hello
1.1.53 pim timer join-prune
1.1.54 pim triggered-hello-delay
1.1.55 probe-interval (PIM view)
1.1.56 prune delay (PIM view)
1.1.57 register-policy (PIM view)
1.1.58 register-suppression-timeout (PIM view)
1.1.59 register-whole-checksum (PIM view)
1.1.60 reset pim control-message counters
1.1.61 source-lifetime (PIM view)
1.1.62 source-policy (PIM view)
1.1.63 spt-switch-threshold (PIM view)
1.1.64 ssm-policy (PIM view)
1.1.65 state-refresh-interval (PIM view)
1.1.66 state-refresh-rate-limit (PIM view)
1.1.67 state-refresh-ttl
1.1.68 static-rp (PIM view)
1.1.69 timer hello (PIM view)
1.1.70 timer join-prune (PIM view)
1 PIM配置命令
1.1  PIM配置命令
auto-rp enable
undo auto-rp enable
公网实例PIM视图/VPN实例PIM视图
【缺省级别】
2:系统级
无
【描述】
auto-rp enable命令用来使能自动RP侦听功能。undo auto-rp enable命令用来关闭自动RP侦听功能。
缺省情况下,自动RP侦听功能处于关闭状态。
相关配置可参考命令static-rp。
# 在公网实例中使能自动RP侦听功能。
[Sysname] pim
[Sysname-pim] auto-rp enable
# 在VPN实例mvpn中使能自动RP侦听功能。
[Sysname] pim vpn-instance mvpn
[Sysname-pim-mvpn] auto-rp enable
bidir-pim enable
undo bidir-pim enable
【缺省级别】
2:系统级
无
【描述】
bidir-pim enable命令用来使能双向PIM。undo bidir-pim enable命令用来关闭双向PIM。
缺省情况下,双向PIM处于关闭状态。
需要注意的是,只有在相应实例中先使能了IP组播路由,本命令才能生效。
相关配置可参考命令pim,以及“IP组播命令参考/组播路由与转发”中的命令multicast routing-enable。
# 使能公网实例中的IP组播路由,进入公网实例PIM视图并使能双向PIM。
[Sysname] multicast routing-enable
[Sysname] pim
[Sysname-pim] bidir-pim enable
# 使能VPN实例mvpn中的IP组播路由,进入VPN实例mvpn的PIM视图并使能双向PIM。
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] route-distinguisher 100:1
[Sysname-vpn-instance-mvpn] multicast routing-enable
[Sysname-vpn-instance-mvpn] quit
[Sysname-pim-mvpn] bidir-pim enable
bsm-fragment enable
undo bsm-fragment enable
【缺省级别】
2:系统级
无
【描述】
bsm-fragment enable命令用来使能自举报文语义分片功能。undo bsm-fragment enable命令用来关闭自举报文语义分片功能。
缺省情况下,自举报文语义分片功能处于使能状态。
需要注意的是,当PIM-SM域中存在不支持自举报文语义分片的设备时,请关闭本功能。
# 在公网实例中关闭自举报文语义分片功能。
[Sysname] pim
[Sysname-pim] undo bsm-fragment enable
# 在VPN实例mvpn中关闭自举报文语义分片功能。
[Sysname-pim-mvpn] undo bsm-fragment enable
bsr-policy acl-number
undo bsr-policy
【缺省级别】
2:系统级
acl-number:指定基本ACL的编号,取值范围为2000~2999。在定义该ACL时,使用rule命令中的source参数来指定合法BSR的源地址范围。
【描述】
bsr-policy命令用来配置合法的BSR地址范围,以防止BSR欺骗。undo bsr-policy命令用来取消BSR地址范围的限制。
缺省情况下,BSR的地址范围不受任何限制,即认为来自任意源的自举报文都是合法的。
# 在公网实例中配置合法的BSR地址范围,只允许网段10.1.1.0/24中的设备充当BSR。
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.1.1.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] pim
[Sysname-pim] bsr-policy 2000
# 在VPN实例mvpn中配置合法的BSR地址范围,只允许网段10.1.1.0/24中的设备充当BSR。
[Sysname-pim-mvpn] bsr-policy 2000
c-bsr interface-type interface-number [ hash-length [ priority ] ]
undo c-bsr
【缺省级别】
2:系统级
interface-type interface-number:指定接口类型和接口编号,将该接口配置为C-BSR。
hash-length:指定哈希掩码长度,取值范围为0~32。如果未指定本参数,则取相应的全局值。
priority:指定C-BSR的优先级,取值范围为0~255。数值越大,优先级越高。如果未指定本参数,则取相应的全局值。
【描述】
c-bsr命令用来配置某接口为C-BSR。undo c-bsr命令用来删除C-BSR的相关配置。
缺省情况下,没有配置C-BSR。
需要注意的是,充当C-BSR的接口上必须使能PIM-SM。
相关配置可参考命令pim sm、c-bsr hash-length、c-bsr priority和c-rp。
# 在公网实例中把接口GigabitEthernet2/1/1配置为C-BSR。
[Sysname] pim
[Sysname-pim] c-bsr gigabitethernet 2/1/1
# 在VPN实例mvpn中把接口Ethernet1/1配置为C-BSR。
[Sysname-pim-mvpn] c-bsr ethernet 1/1
c-bsr admin-scope
undo c-bsr admin-scope
【缺省级别】
2:系统级
无
【描述】
c-bsr admin-scope命令用来使能管理域机制。undo c-bsr admin-scope命令用来关闭管理域机制。
缺省情况下,管理域机制处于关闭状态,即每个PIM-SM域中只能有一个BSR。
相关配置可参考命令c-bsr、c-bsr group和c-bsr global。
# 在公网实例中使能管理域机制。
[Sysname] pim
[Sysname-pim] c-bsr admin-scope
# 在VPN实例mvpn中使能管理域机制。
[Sysname-pim-mvpn] c-bsr admin-scope
1.1.7  c-bsr global
c-bsr global [ hash-length hash-length | priority priority ] *
undo c-bsr global
【缺省级别】
2:系统级
hash-length:指定Global域中的哈希掩码长度,取值范围为0~32。如果未指定本参数,则取相应的全局值。
priority:指定Global域中C-BSR的优先级,取值范围为0~255。数值越大,优先级越高。如果未指定本参数,则取相应的全局值。
【描述】
c-bsr global命令用来配置Global域的C-BSR。undo c-bsr global命令用来删除对Global域C-BSR的配置。
缺省情况下,没有配置Global域的C-BSR。
相关配置可参考命令c-bsr group、c-bsr hash-length和c-bsr priority。
# 在公网实例中把本设备配置为Global域的C-BSR,其优先级为1。
[Sysname] pim
[Sysname-pim] c-bsr global priority 1
# 在VPN实例mvpn中配置本设备为Global域的C-BSR,其优先级为1。
[Sysname-pim-mvpn] c-bsr global priority 1
1.1.8  c-bsr group
c-bsr group group-address { mask | mask-length } [ hash-length hash-length | priority priority ] *
undo c-bsr group group-address
【缺省级别】
2:系统级
group-address:指定组播组地址,取值范围为239.0.0.0~239.255.255.255。
mask:指定组播组地址的掩码。
mask-length:指定组播组地址的掩码长度,取值范围为8~32。
hash-length:指定某组播组所对应管理域中的哈希掩码长度,取值范围为0~32。如果未指定本参数,则取相应的全局值。
priority:指定某组播组所对应管理域中C-BSR的优先级,取值范围为0~255。数值越大,优先级越高。如果未指定本参数,则取相应的全局值。
【描述】
c-bsr group命令用来配置管理域的C-BSR。undo c-bsr group命令用来删除对管理域C-BSR的配置。
缺省情况下,没有配置管理域的C-BSR。
相关配置可参考命令c-bsr global、c-bsr admin-scope、c-bsr hash-length和c-bsr priority。
# 在公网实例中配置本设备为239.0.0.0/8所对应管理域的C-BSR,其优先级为10。
[Sysname] pim
[Sysname-pim] c-bsr group 239.0.0.0 255.0.0.0 priority 10
# 在VPN实例mvpn中配置本设备为239.0.0.0/8所对应管理域的C-BSR,其优先级为10。
[Sysname-pim-mvpn] c-bsr group 239.0.0.0 255.0.0.0 priority 10
c-bsr hash-length hash-length
undo c-bsr hash-length
【缺省级别】
2:系统级
【描述】
c-bsr hash-length命令用来配置哈希掩码长度的全局值。undo c-bsr hash-length命令用来恢复缺省情况。
缺省情况下,哈希掩码长度为30。
相关配置可参考命令c-bsr、c-bsr global和c-bsr group。
# 在公网实例中配置哈希掩码长度的全局值为16。
[Sysname] pim
[Sysname-pim] c-bsr hash-length 16
# 在VPN实例mvpn中配置哈希掩码长度的全局值为16。
[Sysname-pim-mvpn] c-bsr hash-length 16
c-bsr holdtime interval
undo c-bsr holdtime
【缺省级别】
2:系统级
interval:指定自举超时时间,取值范围为1~2147483647,单位为秒。
【描述】
c-bsr holdtime命令用来配置自举超时时间,即C-BSR等待接收来自BSR的自举报文的超时时间。undo c-bsr holdtime命令用来恢复缺省情况。
缺省情况下,自举超时时间由如下公式决定:自举超时时间=自举时间间隔×2+10。
缺省情况下,自举时间间隔为60秒,则自举超时时间的缺省值=60×2+10=130(秒)。
相关配置可参考命令c-bsr和c-bsr interval。
# 在公网实例中配置自举超时时间为150秒。
[Sysname] pim
[Sysname-pim] c-bsr holdtime 150
# 在VPN实例mvpn中配置自举超时时间为150秒。
[Sysname-pim-mvpn] c-bsr holdtime 150
c-bsr interval interval
undo c-bsr interval
【缺省级别】
2:系统级
interval:指定自举时间间隔,取值范围为10~2147483647,单位为秒。
【描述】
c-bsr interval命令用来配置自举时间间隔,即BSR发送自举报文的时间间隔。undo c-bsr interval命令用来恢复缺省情况。
缺省情况下,自举时间间隔由如下公式决定:自举时间间隔=(自举超时时间-10)÷2。
缺省情况下,自举超时时间为130秒,则自举时间间隔的缺省值=(130-10)÷2=60(秒)。
相关配置可参考命令c-bsr和c-bsr holdtime。
# 在公网实例中配置自举时间间隔为30秒。
[Sysname] pim
[Sysname-pim] c-bsr interval 30
# 在VPN实例mvpn中配置自举时间间隔为30秒。
[Sysname-pim-mvpn] c-bsr interval 30
c-bsr priority priority
undo c-bsr priority
【缺省级别】
2:系统级
【描述】
c-bsr priority命令用来配置C-BSR优先级的全局值。undo c-bsr priority命令用来恢复缺省情况。
缺省情况下,C-BSR的优先级为64。
# 在公网实例中配置C-BSR优先级的全局值为5。
[Sysname] pim
[Sysname-pim] c-bsr priority 5
# 在VPN实例mvpn中配置C-BSR优先级的全局值为5。
[Sysname-pim-mvpn] c-bsr priority 5
c-rp interface-type interface-number [ group-policy acl-number | priority priority | holdtime hold-interval | advertisement-interval adv-interval ] * [ bidir ]
undo c-rp interface-type interface-number
【缺省级别】
2:系统级
interface-type interface-number:指定接口类型和接口编号,将该接口配置为C-RP。
acl-number:指定基本ACL的编号,取值范围为2000~2999。该ACL规则并不用来进行匹配过滤,而是定义了该C-RP所服务的组播组范围,只要是permit的组播组都会作为RP的服务组范围通告出去,deny的组播组将不被通告。
priority:指定C-RP的优先级,取值范围为0~255,缺省值为192。数值越大,优先级越低。
hold-interval:指定C-RP的超时时间,取值范围为1~65535,单位为秒。如果未指定本参数,则取相应的全局值。
adv-interval:指定发送宣告报文的间隔时间,取值范围为1~65535,单位为秒。如果未指定本参数,则取相应的全局值。
bidir:指定该C-RP服务于双向PIM。如果未指定本参数,该C-RP将服务于PIM-SM。
【描述】
c-rp命令用来配置某接口为C-RP。undo c-rp命令用来删除C-RP的相关配置。
缺省情况下,没有配置C-RP。
·     充当C-RP的接口上必须使能PIM-SM。
·     若没有为C-RP指定其所服务的组播组范围,该C-RP将为所有组播组服务。
·     如果设备想要成为多个组范围的C-RP,则需要在配置group-policy所对应的ACL时将多个组范围用多个rule规则表示出来。
·     如果对于同一接口多次执行本命令,则最新配置将覆盖旧配置。
相关配置可参考命令c-bsr。
# 在公网实例中把接口GigabitEthernet2/1/1配置为225.1.0.0/16和226.2.0.0/16所对应的C-RP,C-RP的优先级为10。
[Sysname-acl-basic-2000] rule permit source 225.1.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule permit source 226.2.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] c-rp gigabitethernet 2/1/1 group-policy 2000 priority 10
# 在VPN实例mvpn中把接口GigabitEthernet2/1/1配置为225.1.0.0/16和226.2.0.0/16所对应的C-RP,C-RP的优先级为10。
[Sysname-pim-mvpn] c-rp gigabitethernet 2/1/1 group-policy 2000 priority 10
c-rp advertisement-interval interval
undo c-rp advertisement-interval
【缺省级别】
2:系统级
interval:指定发送宣告报文的时间间隔,取值范围为1~65535,单位为秒。
【描述】
c-rp advertisement-interval命令用来配置发送宣告报文时间间隔的全局值。undo c-rp advertisement-interval命令用来恢复缺省情况。
缺省情况下,发送宣告报文的时间间隔为60秒。
相关配置可参考命令c-rp。
# 在公网实例中配置发送宣告报文时间间隔的全局值为30秒。
[Sysname] pim
[Sysname-pim] c-rp advertisement-interval 30
# 在VPN实例mvpn中配置发送宣告报文时间间隔的全局值为30秒。
[Sysname-pim-mvpn] c-rp advertisement-interval 30
c-rp holdtime interval
undo c-rp holdtime
【缺省级别】
2:系统级
【描述】
c-rp holdtime命令用来配置C-RP超时时间的全局值,即BSR等待接收来自C-RP的宣告报文的超时时间。undo c-rp holdtime命令用来恢复缺省情况。
缺省情况下,C-RP的超时时间为150秒。
需要注意的是,由于非BSR通过BSR自举报文来更新C-RP的超时时间,所以在配置时,C-RP的超时时间不要小于BSR发送自举报文的时间间隔,且最好为该间隔的2.5倍以上,以防止BSR自举报文中的C-RP信息丢失。
相关配置可参考命令c-rp和c-bsr interval。
# 在公网实例中配置C-RP超时时间的全局值为200秒。
[Sysname] pim
[Sysname-pim] c-rp holdtime 200
# 在VPN实例mvpn中配置C-RP超时时间的全局值为200秒。
[Sysname-pim-mvpn] c-rp holdtime 200
crp-policy acl-number
undo crp-policy
【缺省级别】
2:系统级
acl-number:指定高级ACL的编号,取值范围为3000~3999。在定义该ACL时,使用rule命令中的source参数来指定C-RP的地址,destination参数来指定该C-RP所服务的组播组地址范围。
【描述】
crp-policy命令用来配置合法的C-RP地址范围及其所服务的组播组范围,以防止C-RP欺骗。undo crp-policy命令用来取消C-RP地址范围及其所服务的组播组范围的限制。
缺省情况下,C-RP地址范围及其所服务的组播组范围不受任何限制,即认为所有收到的C-RP报文都是合法的。
需要注意的是,本命令在对C-RP所宣告的组播组范围进行过滤时,只依据其组前缀进行过滤。譬如,当C-RP宣告的组播组范围为224.1.0.0/16,crp-policy命令所规定的合法组播组范围为224.1.0.0/30时,最终通过过滤的组播组范围为224.1.0.0/16。
相关配置可参考命令c-rp。
# 在公网实例中配置合法的C-RP策略,只允许1.1.1.1/24范围内的设备充当C-RP,且只允许其为225.1.1.0/24范围内的组播组服务。
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule permit ip source 1.1.1.1 0.0.0.255 destination 225.1.1.0 0.0.0.255
[Sysname-acl-adv-3000] quit
[Sysname] pim
[Sysname-pim] crp-policy 3000
# 在VPN实例mvpn中配置C-RP策略,只允许1.1.1.1/24范围内的设备充当C-RP,且只允许其为225.1.1.0/24范围内的组播组服务。
[Sysname-pim-mvpn] crp-policy 3000
display pim [ all-instance | vpn-instance vpn-instance-name ] bsr-info [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all-instance:指定所有VPN实例。
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display pim bsr-info命令用来查看PIM-SM域中的BSR信息,以及本地配置并生效的C-RP信息。
需要注意的是,如果未指定all-instance和vpn-instance参数,则只显示公网实例的相关信息。
相关配置可参考命令c-bsr和c-rp。
# 查看公网实例PIM-SM域中的BSR信息,以及本地配置并生效的C-RP信息。
<Sysname> display pim bsr-info
 VPN-Instance: public net
 Elected BSR Address: 12.12.12.9
     Priority: 64
     Hash mask length: 30
     State: Elected
     Scope: Global
     Uptime: 00:00:56
     Next BSR message scheduled at: 00:01:14
 Candidate BSR Address: 12.12.12.9
     Priority: 64
     State: Elected
     Scope: Global
 Candidate RP: 12.12.12.9(LoopBack1)
     Priority: 192
     HoldTime: 150
     Advertisement Interval: 60
     Next advertisement scheduled at: 00:00:48
 Candidate RP: 3.3.3.3(GigabitEthernet2/1/1)
     Priority: 200
     HoldTime: 90
     Advertisement Interval: 50
     Next advertisement scheduled at: 00:00:28
 Candidate RP: 5.5.5.5(GigabitEthernet2/1/2)
     Priority: 192
     HoldTime: 80
表1-1 display pim bsr-info命令显示信息描述表
公网实例
Elected BSR Address
当选BSR的地址
候选BSR的地址
Priority
BSR的优先级
Hash mask length
哈希掩码长度
BSR的状态
Scope
BSR所服务的管理域
Uptime
BSR已经存在的时间
发送下一个BSR报文的剩余时间
Candidate RP
候选RP的地址
Priority
候选RP的优先级
HoldTime
候选RP的超时时间
候选RP发送宣告报文时间间隔
候选RP发送下一个宣告报文的剩余时间
PIM-SM is not enabled
PIM-SM尚未使能
display pim [ all-instance | vpn-instance vpn-instance-name ] claimed-route [ source-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
source-address:组播源的IP地址,查看到达指定组播源的单播路由信息。如果未指定本参数,将显示PIM所使用的所有单播路由信息。
【描述】
display pim claimed-route命令用来查看PIM所使用的单播路由信息。
·     如果未指定all-instance和vpn-instance参数,则只显示公网实例的相关信息。
·     如果某(S,G)表项的标志是SPT,则该(S,G)表项会使用单播路由。
# 查看公网实例PIM使用的所有单播路由信息。
<Sysname> display pim claimed-route
 RPF information about: 172.168.0.0
     RPF interface: GigabitEthernet2/1/1, RPF neighbor: 172.168.0.2
     Referenced route/mask: 172.168.0.0/24
     Referenced route type: unicast (direct)
     RPF-route selecting rule: preference-preferred
     The (S,G) or (*,G) list dependent on this route entry
     (172.168.0.12, 227.0.0.1)
表1-2 display pim claimed-route命令显示信息描述表
公网实例
到组播源172.168.0.0的RPF路由信息
RPF interface
RPF接口的名称和编号
RPF neighbor
RPF邻居的IP地址
所用的路由项
所引用的路由类型,可以是下列类型之一:
·     igp:单播路由(内部网关协议)
·     egp:单播路由(外部网关协议)
·     unicast (direct):单播路由(直连)
·     unicast:其它单播路由(如单播静态路由等)
·     mbgp:MBGP路由
·     multicast static:组播静态路由
RPF路由的选择规则
基于此RPF路由的(S,G)或(*,G)列表
display pim [ all-instance | vpn-instance vpn-instance-name ] control-message counters [ message-type { probe | register | register-stop } | [ interface interface-type interface-number | message-type { assert | bsr | crp | graft | graft-ack | hello | join-prune | state-refresh } ] * ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
probe:查看空注册报文的数量。
register:查看注册报文的数量。
register-stop:查看注册停止报文的数量。
interface-type interface-number: 接口类型和接口编号,查看指定接口上的PIM控制报文数量。
assert:查看断言报文的数量。
bsr:查看自举报文的数量。
crp:查看宣告报文的数量。
graft:查看嫁接报文的数量。
graft-ack:查看嫁接应答报文的数量。
hello:查看Hello报文的数量。
join-prune:查看加入/剪枝报文的数量。
state-refresh:查看状态刷新报文的数量。
【描述】
display pim control-message counters命令用来查看PIM控制报文的数量。
# 查看公网实例所有接口上所有类型的PIM控制报文数量。
<Sysname> display pim control-message counters
 PIM global control-message counters:
                  Received         Sent             Invalid
 Register         20               37               2
 Register-Stop    25               20               1
 Probe            10               5                0
 PIM control-message counters for interface: GigabitEthernet2/1/1
 Assert           10               5                0
 Graft            20               37               2
 Graft-Ack        25               20               1
 Hello            1232             453              0
 Join/Prune       15               30               21
 State-Refresh    8                7                1
 BSR              3243             589              1
 C-RP             53               32               0
表1-3 display pim control-message counters命令显示信息描述表
公网实例
统计PIM全局控制报文
统计PIM控制报文的接口
Received
收到的报文数量
Sent
发送的报文数量
Invalid
无效报文的数量
Register
注册报文
Register-Stop
注册停止报文
Probe
空注册报文
Assert
断言报文
Graft
嫁接报文
Graft-Ack
嫁接应答报文
Hello
Hello报文
Join/Prune
加入/剪枝报文
State Refresh
状态刷新报文
BSR
自举报文
C-RP
宣告报文
display pim [ all-instance | vpn-instance vpn-instance-name ] df-info [ rp-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
rp-address:指定双向PIM的RP地址。
【描述】
display pim df-info命令用来查看双向PIM的DF信息。
# 查看公网实例中双向PIM的DF信息。
<Sysname> display pim df-info
 RP Address: 1.1.1.1
  Interface            State   DF-Pref    DF-Metric  DF-Uptime DF-Address
  GE2/1/1              Win     100        1          01:24:09  192.168.2.1 (local)
  Ser2/0/1             Win     100        1          01:24:09  10.110.1.2 (local)
  Ser2/0/2             Lose    0          0          01:23:12  10.110.2.2
表1-4 display pim df-info命令显示信息描述表
公网实例
RP Address
双向PIM的RP地址
接口名称
DF的选举状态:
·     Win:表示获选
·     Lose:表示落选
DF-Pref
DF通告的路由优先级
DF-Metric
DF通告的路由度量值
DF-Uptime
DF的存在时间
DF-Address
DF的IP地址,local表示为本地地址
PIM-SM尚未使能
display pim [ all-instance | vpn-instance vpn-instance-name ] grafts [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display pim grafts命令用来查看尚未确认的PIM-DM嫁接信息。
# 查看公网实例中尚未确认的PIM-DM嫁接信息。
<Sysname> display pim grafts
 Source             Group             Age           RetransmitIn
 192.168.10.1       224.1.1.1         00:00:24      00:00:02
表1-5 display pim grafts命令显示信息描述表
公网实例
Source
嫁接报文中的组播源地址
Group
嫁接报文中的组播组地址
Age
嫁接报文的老化剩余时间
RetransmitIn
重发嫁接报文的剩余时间
PIM-DM is not enabled
PIM-DM尚未使能
display pim [ all-instance | vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:接口类型和接口编号,查看指定接口上的PIM信息。
verbose:查看PIM接口的详细信息。
【描述】
display pim interface命令用来查看接口上的PIM信息。
# 查看公网实例所有接口上的PIM信息。
<Sysname> display pim interface
 Interface           NbrCnt HelloInt   DR-Pri     DR-Address
 GE2/1/1              1      30         1          10.1.1.2
 GE2/1/2              0      30         1          172.168.0.2    (local)
 GE2/1/3              1      30         1          20.1.1.2
表1-6 display pim interface命令显示信息描述表
公网实例
接口名称
NbrCnt
PIM邻居的数量
HelloInt
发送Hello报文的时间间隔
DR-Pri
竞选DR的优先级
DR-Address
DR的IP地址,local表示为本地地址
# 查看公网实例接口GigabitEthernet2/1/1上的PIM详细信息。
<Sysname> display pim interface gigabitethernet 2/1/1 verbose
 Interface: GigabitEthernet2/1/1, 10.1.1.1
     PIM version: 2
     PIM mode: Sparse
     PIM DR: 10.1.1.2
     PIM DR Priority (configured): 1
     PIM neighbor count: 1
     PIM hello interval: 30 s
     PIM LAN delay (negotiated): 500 ms
     PIM LAN delay (configured): 500 ms
     PIM override interval (negotiated): 2500 ms
     PIM override interval (configured): 2500 ms
     PIM neighbor tracking (negotiated): disabled
     PIM neighbor tracking (configured): disabled
     PIM generation ID: 0xF5712241
     PIM require generation ID: disabled
     PIM hello hold interval: 105 s
     PIM assert hold interval: 180 s
     PIM triggered hello delay: 5 s
     PIM J/P interval: 60 s
     PIM J/P hold interval: 210 s
     PIM BSR domain border: disabled
     Number of routers on network not using DR priority: 0
     Number of routers on network not using LAN delay: 0
     Number of routers on network not using neighbor tracking: 2
表1-7 display pim interface verbose命令显示信息描述表
公网实例
接口名称与IP地址
PIM version
PIM协议的版本号
PIM mode
PIM协议的模式,是密集模式还是稀疏模式
PIM DR
DR的IP地址
竞选DR优先级的配置值
PIM neighbor count
PIM邻居的总数
PIM hello interval
发送Hello报文的时间间隔
发送剪枝报文延迟时间的协商值
发送剪枝报文延迟时间的配置值
剪枝否决时间的协商值
剪枝否决时间的配置值
邻居跟踪使能与否的协商情况
邻居跟踪使能与否的配置情况
PIM generation ID
Generation_ID参数值
是否使能不接受无Generation ID的Hello报文
保持PIM邻居的可达状态的时间
保持断言状态的时间
发送Hello报文的最大延迟时间
PIM J/P interval
发送加入/剪枝报文的时间间隔
保持加入/剪枝状态的时间
该接口是否配置了BSR的服务边界
该接口所在网段上没有使用DR优先级字段的路由器数量
该接口所在网段上未使用LAN-delay字段的路由器数量
该接口所在网段上未使能邻居跟踪的路由器数量
display pim [ all-instance | vpn-instance vpn-instance-name ] join-prune mode { sm [ flags flag-value ] | ssm } [ interface interface-type interface-number | neighbor neighbor-address ] * [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
mode:查看指定PIM模式下待发送的加入/剪枝报文信息。PIM模式包括sm和ssm,分别表示PIM-SM和PIM-SSM类型的路由项。
flags flag-value:查看含有指定标志的PIM路由表项。flag-value的取值及含义如下:
·     rpt:表示共享树上的路由表项;
·     spt:表示最短路径树上的路由表项;
·     wc:表示带WC通配符的路由表项。
interface-type interface-number:接口类型和接口编号,查看指定接口上待发送的加入/剪枝报文信息。
neighbor-address:PIM邻居的IP地址,查看待发送给指定PIM邻居的加入/剪枝报文信息。
verbose:查看待发送的加入/剪枝报文的详细信息。
【描述】
display pim join-prune命令用来查看待发送的加入/剪枝报文信息。
# 查看公网实例PIM-SM模式下待发送的加入/剪枝报文信息。
<Sysname> display pim join-prune mode sm
 Expiry Time: 50 sec
 Upstream nbr: 10.1.1.1 (GigabitEthernet2/1/1)
 1 (*, G) join(s), 0 (S, G) join(s), 1 (S, G, rpt) prune(s)
 Total (*, G) join(s): 1, (S, G) join(s): 0, (S, G, rpt) prune(s): 1
表1-8 display pim join-prune命令显示信息描述表
公网实例
Expiry Time:
发送加入/剪枝报文的剩余时间
Upstream nbr:
上游PIM邻居的IP地址和所在接口
(*, G) join(s)
待发送的(*,G)加入项数量
(S, G) join(s)
待发送的(S,G)加入项数量
待发送的(S,G,rpt)剪枝项数量
display pim [ all-instance | vpn-instance vpn-instance-name ] neighbor [ interface interface-type interface-number | neighbor-address | verbose ] * [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:接口类型和接口编号,查看指定接口上的PIM邻居信息。
neighbor-address:PIM邻居的IP地址,查看指定PIM邻居的信息。
verbose:查看PIM邻居的详细信息。
【描述】
display pim neighbor命令用来查看PIM邻居信息。
# 查看公网实例所有PIM邻居的信息。
<Sysname> display pim neighbor
 Total Number of Neighbors = 2
 Neighbor        Interface           Uptime   Expires  Dr-Priority  Mode
 10.1.1.2        GE2/1/1              02:50:49 00:01:31 1            B
 20.1.1.2        GE2/1/2              02:49:39 00:01:42 1            B
# 查看公网实例中IP地址为11.110.0.20的PIM邻居的详细信息。
<Sysname> display pim neighbor 11.110.0.20 verbose
 Neighbor: 11.110.0.20
     Interface: GigabitEthernet2/1/3
     Uptime: 00:00:10
     Expiry time: 00:00:30
     DR Priority: 1
     Generation ID: 0x2ACEFE15
     Holdtime: 105 s
     LAN delay: 500 ms
     Override interval: 2500 ms
     State refresh interval: 60 s
     Neighbor tracking: Disabled
     Bidirectional PIM: Enabled
表1-9 display pim neighbor命令显示信息描述表
公网实例
PIM邻居的总数
Neighbor
PIM邻居的IP地址
PIM邻居所在接口的名称
Uptime
PIM邻居已存在的时间
Expires/Expiry time
PIM邻居超时的剩余时间,never表示PIM邻居永不超时,即永远可达
Dr-Priority/DR Priority
PIM邻居的优先级
Mode
PIM邻居的模式,B表示双向PIM模式,显示为空则表示非双向PIM模式
Generation ID
PIM邻居的Generation ID(状态随机数)
Holdtime
PIM邻居的生存时间,forever表示PIM邻居永远存在,即永远可达
LAN delay
发送剪枝报文的延迟时间
Override interval
剪枝否决的时间间隔
状态刷新的时间间隔,只有当PIM邻居工作在PIM-DM模式下且具备状态刷新能力时才会显示本字段
Neighbor tracking
邻居跟踪功能是否已使能
Bidirectional PIM
双向PIM是否已使能
display pim [ all-instance | vpn-instance vpn-instance-name ] routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | incoming-interface [ interface-type interface-number | register ] | outgoing-interface { include | exclude | match } { interface-type interface-number | register } | mode mode-type | flags flag-value | fsm ] * [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
group-address:组播组地址,查看指定组播组的PIM路由项,取值范围为224.0.0.0~239.255.255.255。
source-address:组播源地址,查看包含指定组播源的PIM路由项。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
mask-length:指定组播组或组播源地址的掩码长度,取值范围为0~32,缺省值为32。
incoming-interface:查看指定入接口的PIM路由项。
interface-type interface-number:查看指定接口类型和接口编号的入接口的PIM路由项。
register:查看入接口为PIM-SM注册接口的PIM路由项。本参数只有在未指定mode-type,或mode-type取sm时才有效。
outgoing-interface:查看指定出接口的PIM路由项。
include:查看出接口列表中包含指定接口的PIM路由项。
exclude:查看出接口列表中不包含指定接口的PIM路由项。
match:查看出接口列表中包含且仅包含指定接口的PIM路由项。
mode mode-type:PIM模式,查看指定模式下的PIM路由项。mode-type的取值及含义如下:
·     dm:表示PIM-DM模式;
·     sm:表示PIM-SM模式;
·     ssm:表示PIM-SSM模式。
flags flag-value:PIM标志,查看包含指定标志的PIM路由项。flag-value的取值及含义如下:
·     2msdp:表示准备向MSDP发出通知,在下一个SA报文中包含的PIM路由项;
·     act:表示已经有实际数据到达的PIM路由项;
·     bidir:表示由双向PIM创建的PIM路由项;
·     del:表示计划删除的PIM路由项;
·     exprune:表示某些出接口被其它组播路由协议剪枝的PIM路由项;
·     ext:表示包含了由其它组播路由协议提供出接口的PIM路由项;
·     loc:表示在与组播源处于同一网段的设备上的PIM路由项;
·     msdp:表示从MSDP的SA报文中学习到的PIM路由项;
·     niif:表示未确定入接口的PIM路由项;
·     nonbr:表示PIM邻居查找失败的PIM路由项;
·     rpt:表示向RP方向发送过(S,G)RPT位剪枝的PIM路由项;
·     rq:表示Switch-MDT切换接收端的PIM路由项;
·     spt:表示SPT上的PIM路由项;
·     sq:表示Switch-MDT切换发起端的PIM路由项;
·     swt:表示正处于向SPT切换过程中的PIM路由项;
·     wc:表示带WC通配符的PIM路由项。
fsm:查看状态机详细信息。
【描述】
display pim routing-table命令用来查看PIM路由表的内容。
相关配置可参考“IP组播命令参考/组播路由与转发”中的命令display multicast routing-table。
# 查看公网实例PIM路由表的内容。
<Sysname> display pim routing-table
     RP: 2.2.2.2
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: GigabitEthernet2/1/1
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: GigabitEthernet2/1/2
             Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
# 查看公网实例PIM路由表的状态机信息。
<Sysname> display pim routing-table fsm
 Abbreviations for FSM states:
     NI - no info, J - joined, NJ - not joined, P - pruned,
     NP - not pruned, PP - prune pending, W - winner, L - loser,
     F - forwarding, AP - ack pending, DR - designated router,
     NDR - non-designated router, RCV - downstream receivers
     RP: 2.2.2.2
     UpTime: 02:54:43
     Upstream interface: Ethernet1/1
         Join/Prune FSM: [SPT: J] [RPT: NP]
         1: Ethernet1/2
             DR state: [DR]
             Join/Prune FSM: [NI]
             Assert FSM: [NI]
     FSM information for non-downstream interfaces: None
表1-10 display pim routing-table命令显示信息描述表
公网实例
PIM路由表中(S,G)与(*,G)表项的总数
NI - no info, J - joined, NJ - not joined, P – pruned
NP - not pruned, PP - prune pending, W - winner, L – loser
状态机的缩写:NI表示初始状态,J表示加入状态,NJ标识未加入状态,P表示剪枝状态,NP表示未剪枝状态,PP表示剪枝未决状态,W表示断言当选,L表示断言落选,F表示转发状态,AP表示嫁接确认状态,DR表示指定路由器,NDR表示非指定路由器,RCV表示下游接收者
(172.168.0.2, 227.0.0.1)
PIM路由表中的(S,G)表项
RP
RP的地址
Protocol
PIM的模式
Flag
PIM路由表中(S,G)或(*,G)表项的标志:
·     2MSDP:表示准备向MSDP发出通知
·     ACT:表示已有实际数据到达
·     BIDIR:表示由双向PIM创建
·     DEL:表示计划要删除
·     EXPRUNE:表示某些出接口被其它组播路由协议剪枝
·     EXT:表示包含了其它组播路由协议提供的出接口
·     LOC:表示与组播源处于同一网段
·     MSDP:表示从MSDP的SA报文中学习到的
·     NIIF:表示未确定入接口
·     NONBR:表示PIM邻居查找失败
·     RPT:表示向RP方向发送过(S,G)RPT位剪枝
·     RQ:表示Switch-MDT切换的接收端
·     SPT:表示在SPT上
·     SQ:表示Switch-MDT切换的发起端
·     SWT:表示正在向SPT切换
WC:表示带WC通配符
Uptime
(S,G)或(*,G)表项已存在的时间
Upstream interface
(S,G)或(*,G)表项的上游接口名称。如果上游接口是其它VPN中的接口,则显示该VPN的名称
Upstream neighbor
(S,G)或(*,G)表项的上游邻居
RPF prime neighbor
(S,G)或(*,G)表项的RPF邻居:
·     对(*,G)表项来说,当该路由器是RP时,(*,G)表项的RPF邻居是NULL
·     对(S,G)表项来说,当该路由器直连源时,(S,G)表项的RPF邻居是NULL
DR state
DR的状态
Join/Prune FSM
加入/剪枝状态机
Assert FSM
断言状态机
下游接口的信息,包括:
·     下游接口的总数
·     下游接口的名称。如果下游接口是其它VPN中的接口,则显示该VPN的名称
·     下游接口使用的协议类型。如果下游接口是其它VPN中的接口,则显示extra_vpn
·     下游接口的存在时间
·     下游接口的超时时间
非下游接口的状态机信息
display pim [ all-instance | vpn-instance vpn-instance-name ] rp-info [ group-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
group-address:组播组地址,查看指定组播组所对应的RP信息,取值范围为224.0.1.0~239.255.255.255。如果未指定本参数,将显示所有组播组对应的RP信息。
【描述】
display pim rp-info命令用来查看RP的信息。
·     RP信息包括通过BSR机制动态发现的RP信息和静态RP的信息。
# 查看公网实例中组播组224.0.1.1所对应的RP信息。
<Sysname> display pim rp-info 224.0.1.1
 BSR RP Address is: 2.2.2.2
     Priority: 192
     HoldTime: 150
     Uptime: 03:01:10
     Expires: 00:02:30
 RP mapping for this group is: 2.2.2.2
# 查看公网实例中所有组播组对应的RP信息。
 PIM-SM BSR RP information:
 Group/MaskLen: 224.0.0.0/4 [B]
     RP: 2.2.2.2
     Priority: 192
     HoldTime: 150
     Uptime: 03:01:36
     Expires: 00:02:29
表1-11 display pim rp-info命令显示信息描述表
公网实例
BSR RP Address is
RP的IP地址
Group/MaskLen
RP所服务的组播组
[B]
表示RP服务于双向PIM,不显示本字段则表示RP服务于PIM-SM
RP
RP的IP地址
Priority
RP的优先级
HoldTime
RP的超时时间
Uptime
RP已存在的时间
Expires
RP超时的剩余时间
服务于当前组播组的RP的IP地址
PIM-SM尚未使能
undo hello-option dr-priority
【缺省级别】
2:系统级
priority:指定竞选DR的优先级,取值范围为0~4294967295。数值越大,优先级越高。
【描述】
hello-option dr-priority命令用来全局配置竞选DR的优先级。undo hello-option dr-priority命令用来恢复缺省情况。
缺省情况下,竞选DR的优先级为1。
相关配置可参考命令pim hello-option dr-priority。
# 在公网实例中全局配置竞选DR的优先级为3。
[Sysname] pim
[Sysname-pim] hello-option dr-priority 3
# 在VPN实例mvpn中全局配置竞选DR的优先级为3。
[Sysname-pim-mvpn] hello-option dr-priority 3
hello-option holdtime interval
undo hello-option holdtime
【缺省级别】
2:系统级
interval:指定保持PIM邻居可达状态的超时时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
【描述】
hello-option holdtime命令用来全局配置保持PIM邻居可达状态的时间。undo hello-option holdtime命令用来恢复缺省情况。
缺省情况下,保持PIM邻居可达状态的时间为105秒。
相关配置可参考命令pim hello-option holdtime。
# 在公网实例中全局配置保持PIM邻居可达状态的时间为120秒。
[Sysname] pim
[Sysname-pim] hello-option holdtime 120
# 在VPN实例mvpn中全局配置保持PIM邻居可达状态的时间为120秒。
[Sysname-pim-mvpn] hello-option holdtime 120
hello-option lan-delay interval
undo hello-option lan-delay
【缺省级别】
2:系统级
interval:指定发送剪枝报文的延迟时间,取值范围为1~32767,单位为毫秒。
【描述】
hello-option lan-delay命令用来全局配置发送剪枝报文的延迟时间。undo hello-option lan-delay命令用来恢复缺省情况。
缺省情况下,发送剪枝报文的延迟时间为500毫秒。
相关配置可参考命令hello-option override-interval、pim hello-option override-interval和pim hello-option lan-delay。
# 在公网实例中全局配置发送剪枝报文的延迟时间为200毫秒。
[Sysname] pim
[Sysname-pim] hello-option lan-delay 200
# 在VPN实例mvpn中全局配置发送剪枝报文的延迟时间为200毫秒。
[Sysname-pim-mvpn] hello-option lan-delay 200
undo hello-option neighbor-tracking
【缺省级别】
2:系统级
无
【描述】
hello-option neighbor-tracking命令用来全局禁止加入报文抑制能力,即使能邻居跟踪。undo hello-option neighbor-tracking命令用来使能加入报文抑制能力。
缺省情况下,加入消息抑制能力处于使能状态,即禁止邻居跟踪。
相关配置可参考命令pim hello-option neighbor-tracking。
# 在公网实例中全局禁止加入报文抑制能力。
[Sysname] pim
[Sysname-pim] hello-option neighbor-tracking
# 在VPN实例mvpn中全局禁止加入报文抑制能力。
[Sysname-pim-mvpn] hello-option neighbor-tracking
undo hello-option override-interval
【缺省级别】
2:系统级
interval:指定剪枝否决时间,取值范围为1~65535,单位为毫秒。
【描述】
hello-option override-interval命令用来全局配置剪枝否决时间。undo hello-option override-interval命令用来恢复缺省情况。
缺省情况下,剪枝否决时间为2500毫秒。
相关配置可参考命令hello-option lan-delay、pim hello-option lan-delay和pim hello-option override-interval。
# 在公网实例中全局配置剪枝否决时间为2000毫秒。
[Sysname] pim
[Sysname-pim] hello-option override-interval 2000
# 在VPN实例mvpn中全局配置剪枝否决时间为2000毫秒。
[Sysname-pim-mvpn] hello-option override-interval 2000
holdtime assert interval
undo holdtime assert
【缺省级别】
2:系统级
interval:指定保持断言状态的时间,取值范围为7~2147483647,单位为秒。
【描述】
holdtime assert命令用来全局配置保持断言状态的时间。undo holdtime assert命令用来恢复缺省情况。
缺省情况下,保持断言状态的时间为180秒。
相关配置可参考命令holdtime join-prune、pim holdtime join-prune和pim holdtime assert。
# 在公网实例中全局配置保持断言状态的时间为100秒。
[Sysname] pim
[Sysname-pim] holdtime assert 100
# 在VPN实例mvpn中全局配置保持断言状态的时间为100秒。
[Sysname-pim-mvpn] holdtime assert 100
holdtime join-prune interval
undo holdtime join-prune
【缺省级别】
2:系统级
interval:指定保持加入/剪枝状态的时间,取值范围为1~65535,单位为秒。
【描述】
holdtime join-prune命令用来全局配置保持加入/剪枝状态的时间。undo holdtime join-prune命令用来恢复缺省情况。
缺省情况下,保持加入/剪枝状态的时间为210秒。
相关配置可参考命令holdtime assert、pim holdtime assert和pim holdtime join-prune。
# 在公网实例中全局配置保持加入/剪枝状态的时间为280秒。
[Sysname] pim
[Sysname-pim] holdtime join-prune 280
# 在VPN实例mvpn中全局配置保持加入/剪枝状态的时间为280秒。
[Sysname-pim-mvpn] holdtime join-prune 280
jp-pkt-size packet-size
undo jp-pkt-size
【缺省级别】
2:系统级
packet-size:指定加入/剪枝报文的最大长度,取值范围为100~8100,单位为字节。
【描述】
jp-pkt-size命令用来配置加入/剪枝报文的最大长度。undo jp-pkt-size命令用来恢复缺省情况。
缺省情况下,加入/剪枝报文的最大长度为8100字节。
相关配置可参考命令jp-queue-size。
# 在公网实例中配置加入/剪枝报文的最大长度为1500字节。
[Sysname] pim
[Sysname-pim] jp-pkt-size 1500
# 在VPN实例mvpn中配置加入/剪枝报文的最大长度为1500字节。
[Sysname-pim-mvpn] jp-pkt-size 1500
jp-queue-size queue-size
undo jp-queue-size
【缺省级别】
2:系统级
queue-size:指定加入/剪枝报文中(S,G)表项的最大数量,取值范围为1~4096。
【描述】
jp-queue-size命令用来配置加入/剪枝报文中(S,G)表项的最大数量。undo jp-queue-size命令用来恢复缺省情况。
缺省情况下,加入/剪枝报文中(S,G)表项的最大数量为1020个。
·     在使用jp-queue-size命令进行配置时,需要考虑产品转发表的实际规格。对于某些不支持分片的网络,当queue-size值配置得较大时,加入/剪枝报文中可能包含较多的组,使该报文的长度可能超过网络所规定的MTU(Maximum Transmission Unit,最大传输单元),某些不支持超过MTU报文传输的产品会将其丢弃。
·     在使用jp-queue-size命令进行配置时,还需要考虑上游设备(S,G)保持加入/剪枝状态的时间。当queue-size值配置得很小时,在队列中的最后一个加入/剪枝报文送达上游设备之前,上游设备相应表项的出接口有可能由于已超时而被剪枝。
相关配置可参考命令jp-pkt-size,holdtime join-prune和pim holdtime join-prune。
# 在公网实例中配置加入/剪枝报文中(S,G)表项的最大数量为2000。
[Sysname] pim
[Sysname-pim] jp-queue-size 2000
# 在VPN实例mvpn中配置加入/剪枝报文中(S,G)表项的最大数量为2000。
[Sysname-pim-mvpn] jp-queue-size 2000
1.1.36  pim
pim [ vpn-instance vpn-instance-name ]
undo pim [ vpn-instance vpn-instance-name ]
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则本配置只针对公网实例。
【描述】
pim命令用来进入公网实例或VPN实例PIM视图。undo pim命令用来清除公网实例或VPN实例PIM视图下的所有配置。
相关配置可参考“IP组播命令参考/组播路由与转发”中的命令multicast routing-enable。
# 使能公网实例中的IP组播路由,进入公网实例PIM视图。
[Sysname] pim
[Sysname-pim]
# 使能VPN实例mvpn中的IP组播路由,进入VPN实例mvpn的PIM视图。
[Sysname-pim-mvpn]
pim bfd enable
undo pim bfd enable
【缺省级别】
2:系统级
无
【描述】
pim bfd enable命令用来使能PIM与BFD联动功能。undo pim bfd enable命令用来关闭PIM与BFD联动功能。
缺省情况下,PIM与BFD联动功能处于关闭状态。
需要注意的是,只有在接口上先使能了PIM-DM或PIM-SM,pim bfd enable命令才能生效。
相关配置可参考命令pim dm和pim sm。
# 使能公网实例中的IP组播路由,在接口Ethernet1/1上使能PIM-SM,并使能PIM与BFD联动功能。
[Sysname] interface ethernet 1/1
[Sysname-Ethernet1/1] pim sm
[Sysname-Ethernet1/1] pim bfd enable
pim bsr-boundary
undo pim bsr-boundary
【缺省级别】
2:系统级
无
【描述】
pim bsr-boundary命令用来配置BSR的服务边界,即PIM-SM域的边界。undo pim bsr-boundary命令用来删除BSR的服务边界。
缺省情况下,没有配置BSR的服务边界。
相关配置可参考命令c-bsr,以及“IP组播命令参考/组播路由与转发”中的命令multicast boundary。
# 配置接口GigabitEthernet2/1/1为BSR的服务边界。
[Sysname] interface gigabitethernet 2/1/1
[Sysname-GigabitEthernet2/1/1] pim bsr-boundary
1.1.39  pim dm
pim dm
undo pim dm
【缺省级别】
2:系统级
无
【描述】
pim dm命令用来使能PIM-DM。undo pim dm命令用来关闭PIM-DM。
缺省情况下,PIM-DM处于关闭状态。
·     只有在相应实例中先使能了IP组播路由,本命令才能生效。
·     在运行PIM-DM时不能使用处于SSM组地址范围内的组播组。
相关配置可参考命令pim sm和ssm-policy,以及“IP组播命令参考/组播路由与转发”中的命令multicast routing-enable。
# 使能公网实例中的IP组播路由,并在接口GigabitEthernet2/1/1上使能PIM-DM。
[Sysname-GigabitEthernet2/1/1] pim dm
pim hello-option dr-priority priority
undo pim hello-option dr-priority
【缺省级别】
2:系统级
【描述】
pim hello-option dr-priority命令用来在接口上配置竞选DR的优先级。undo pim hello-option dr-priority命令用来恢复缺省情况。
缺省情况下,竞选DR的优先级为1。
相关配置可参考命令hello-option dr-priority。
# 在接口GigabitEthernet2/1/1上配置竞选DR的优先级为3。
[Sysname-GigabitEthernet2/1/1] pim hello-option dr-priority 3
pim hello-option holdtime interval
undo pim hello-option holdtime
【缺省级别】
2:系统级
interval:指定保持PIM邻居可达状态的时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
【描述】
pim hello-option holdtime命令用来在接口上配置保持PIM邻居的可达状态的时间。undo pim hello-option holdtime命令用来恢复缺省情况。
相关配置可参考命令hello-option holdtime。
# 在接口GigabitEthernet2/1/1上配置保持PIM邻居可达状态的时间为120秒。
[Sysname-GigabitEthernet2/1/1] pim hello-option holdtime 120
pim hello-option lan-delay interval
undo pim hello-option lan-delay
【缺省级别】
2:系统级
【描述】
pim hello-option lan-delay命令用来在接口上配置发送剪枝报文的延迟时间。undo pim hello-option lan-delay命令用来恢复缺省情况。
相关配置可参考命令pim hello-option override-interval、hello-option override-interval和hello-option lan-delay。
# 在接口GigabitEthernet2/1/1上配置发送剪枝报文的延迟时间为200毫秒。
[Sysname-GigabitEthernet2/1/1] pim hello-option lan-delay 200
undo pim hello-option neighbor-tracking
【缺省级别】
2:系统级
无
【描述】
pim hello-option neighbor-tracking命令用来在接口上禁止加入报文抑制能力,即使能邻居跟踪。undo pim hello-option neighbor-tracking命令用来使能加入报文抑制能力。
缺省情况下,加入报文抑制能力处于使能状态,即禁止邻居跟踪。
相关配置可参考命令hello-option neighbor-tracking。
# 在接口GigabitEthernet2/1/1上禁止加入报文抑制能力。
[Sysname-GigabitEthernet2/1/1] pim hello-option neighbor-tracking
pim hello-option override-interval interval
undo pim hello-option override-interval
【缺省级别】
2:系统级
【描述】
pim hello-option override-interval命令用来在接口上配置剪枝否决时间。undo pim hello-option override-interval命令用来恢复缺省情况。
相关配置可参考命令pim hello-option lan-delay、hello-option lan-delay和hello-option override-interval。
# 在接口GigabitEthernet2/1/1上配置剪枝否决时间为2000毫秒。
[Sysname-GigabitEthernet2/1/1] pim hello-option override-interval 2000
pim holdtime assert interval
undo pim holdtime assert
【缺省级别】
2:系统级
【描述】
pim holdtime assert命令用来在接口上配置保持断言状态的时间。undo pim holdtime assert命令用来恢复缺省情况。
相关配置可参考命令holdtime join-prune、pim holdtime join-prune和holdtime assert。
# 在接口GigabitEthernet2/1/1上配置保持断言状态的时间为100秒。
[Sysname-GigabitEthernet2/1/1] pim holdtime assert 100
pim holdtime join-prune interval
undo pim holdtime join-prune
【缺省级别】
2:系统级
【描述】
pim holdtime join-prune命令用来在接口上配置保持加入/剪枝状态的时间。undo pim holdtime join-prune命令用来恢复缺省情况。
相关配置可参考命令holdtime assert、pim holdtime assert和holdtime join-prune。
# 在接口GigabitEthernet2/1/1上配置保持加入/剪枝状态的时间为280秒。
[Sysname-GigabitEthernet2/1/1] pim holdtime join-prune 280
pim neighbor-policy acl-number
undo pim neighbor-policy
【缺省级别】
2:系统级
acl-number:指定基本ACL的编号,取值范围为2000~2999。在定义该ACL时,使用rule命令中的source参数来指定合法Hello报文的源地址范围。
【描述】
pim neighbor-policy命令用来配置合法Hello报文的源地址范围,以防止Hello报文欺骗。undo pim neighbor-policy命令用来恢复缺省情况。
缺省情况下,Hello报文的源地址范围不受任何限制,即认为所有收到的Hello报文都是合法的。
# 在接口GigabitEthernet2/1/1上配置合法Hello报文的源地址范围,只允许与来自网段10.1.1.0/24中的设备建立PIM邻居关系。
[Sysname-GigabitEthernet2/1/1] pim neighbor-policy 2000
pim require-genid
undo pim require-genid
【缺省级别】
2:系统级
无
【描述】
pim require-genid命令用来配置不接受无Generation ID的Hello报文。undo pim require-genid命令用来恢复缺省情况。
缺省情况下,接受无Generation ID的Hello报文。
# 配置接口GigabitEthernet2/1/1不接受无Generation ID的Hello报文。
[Sysname-GigabitEthernet2/1/1] pim require-genid
1.1.49  pim sm
pim sm
undo pim sm
【缺省级别】
2:系统级
无
【描述】
pim sm命令用来使能PIM-SM。undo pim sm命令用来关闭PIM-SM。
缺省情况下,PIM-SM处于关闭状态。
相关配置可参考命令pim dm,以及“IP组播命令参考/组播路由与转发”中的命令multicast routing-enable。
# 使能公网实例中的IP组播路由,并在接口GigabitEthernet2/1/1上使能PIM-SM。
[Sysname-GigabitEthernet2/1/1] pim sm
undo pim state-refresh-capable
【缺省级别】
2:系统级
无
【描述】
pim state-refresh-capable命令用来使能状态刷新能力。undo pim state-refresh-capable命令用来关闭状态刷新能力。
缺省情况下,状态刷新能力处于使能状态。
相关配置可参考命令state-refresh-interval、state-refresh-rate-limit和state-refresh-ttl。
# 在接口GigabitEthernet2/1/1上关闭状态刷新能力。
[Sysname-GigabitEthernet2/1/1] undo pim state-refresh-capable
pim timer graft-retry interval
undo pim timer graft-retry
【缺省级别】
2:系统级
interval:指定嫁接报文的重传时间,取值范围为1~65535,单位为秒。
【描述】
pim timer graft-retry命令用来配置嫁接报文的重传时间。undo pim timer graft-retry命令用来恢复缺省情况。
缺省情况下,嫁接报文的重传时间为3秒。
# 在接口GigabitEthernet2/1/1上配置嫁接报文的重传时间为80秒。
[Sysname-GigabitEthernet2/1/1] pim timer graft-retry 80
pim timer hello interval
undo pim timer hello
【缺省级别】
2:系统级
interval:指定发送Hello报文的时间间隔,取值范围为1~2147483647,单位为秒。
【描述】
pim timer hello命令用来在接口上配置发送Hello报文的时间间隔。undo pim timer hello命令用来恢复缺省情况。
缺省情况下,发送Hello报文的时间间隔为30秒。
相关配置可参考命令timer hello。
# 在接口GigabitEthernet2/1/1上配置发送Hello报文的时间间隔为40秒。
[Sysname-GigabitEthernet2/1/1] pim timer hello 40
pim timer join-prune interval
undo pim timer join-prune
【缺省级别】
2:系统级
interval:指定发送加入/剪枝报文的时间间隔,取值范围为1~2147483647,单位为秒。
【描述】
pim timer join-prune命令用来在接口上配置发送加入/剪枝报文的时间间隔。undo pim timer join-prune命令用来恢复缺省情况。
缺省情况下,发送加入/剪枝报文的时间间隔为60秒。
相关配置可参考命令timer join-prune。
# 在接口GigabitEthernet2/1/1上配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname-GigabitEthernet2/1/1] pim timer join-prune 80
pim triggered-hello-delay interval
undo pim triggered-hello-delay
【缺省级别】
2:系统级
interval:指定触发Hello报文的最大延迟时间,取值范围为1~60,单位为秒。
【描述】
pim triggered-hello-delay命令用来配置触发Hello报文的最大延迟时间。undo pim triggered-hello-delay命令用来恢复缺省情况。
缺省情况下,触发Hello报文的最大延迟时间为5秒。
# 在接口GigabitEthernet2/1/1上配置触发Hello报文的最大延迟时间为3秒。
[Sysname-GigabitEthernet2/1/1] pim triggered-hello-delay 3
probe-interval interval
undo probe-interval
【缺省级别】
2:系统级
interval:指定注册探测时间,取值范围1~1799,单位为秒。
【描述】
probe-interval命令用来配置注册探测时间。undo probe-interval命令用来恢复缺省情况。
缺省情况下,注册探测时间为5秒。
相关配置可参考命令register-suppression-timeout。
# 在公网实例中配置注册探测时间为6秒。
[Sysname] pim
[Sysname-pim] probe-interval 6
# 在VPN实例mvpn中配置注册探测时间为6秒。
[Sysname-pim-mvpn] probe-interval 6
prune delay interval
undo prune delay
【缺省级别】
2:系统级
interval:指定剪枝延迟时间,取值范围1~128,单位为秒。
【描述】
prune delay命令用来配置剪枝延迟时间。undo prune delay命令用来恢复缺省情况。
缺省情况下,未配置剪枝延迟时间。
# 在公网实例中配置剪枝延迟时间为75秒。
[Sysname] pim
[Sysname-pim] prune delay 75
# 在VPN实例mvpn中配置剪枝延迟时间为75秒。
[Sysname-pim-mvpn] prune delay 75
register-policy acl-number
undo register-policy
【缺省级别】
2:系统级
acl-number:指定高级ACL的编号,取值范围为3000~3999。只有与该ACL的permit语句匹配的注册报文才会被RP接受。
【描述】
register-policy命令用来配置注册报文的过滤规则。undo register-policy命令用来删除注册报文的过滤规则。
缺省情况下,没有配置注册报文的过滤规则。
# 在公网实例中配置RP上对注册报文的过滤规则,只接收来自10.10.0.0/16网段的组播源发向225.1.0.0/16网段的组播组的注册报文。
[Sysname-acl-adv-3000] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] register-policy 3000
# 在VPN实例mvpn中配置RP上对注册报文的过滤规则,只接收来自10.10.0.0/16网段的组播源发向225.1.0.0/16网段的组播组的注册报文。
[Sysname-pim-mvpn] register-policy 3000
undo register-suppression-timeout
【缺省级别】
2:系统级
interval:指定注册抑制时间,取值范围为1~65535,单位为秒。
【描述】
register-suppression-timeout命令用来配置注册抑制时间。undo register-suppression-timeout命令用来恢复缺省情况。
缺省情况下,注册抑制时间为60秒。
相关配置可参考命令probe-interval和register-policy。
# 在公网实例中配置注册抑制时间为70秒。
[Sysname] pim
[Sysname-pim] register-suppression-timeout 70
# 在VPN实例mvpn中配置注册抑制时间为70秒。
[Sysname-pim-mvpn] register-suppression-timeout 70
undo register-whole-checksum
【缺省级别】
2:系统级
无
【描述】
register-whole-checksum命令用来配置根据注册报文的全部内容来计算校验和。undo register-whole-checksum命令用来恢复缺省情况。
缺省情况下,仅根据注册报文头来计算校验和。
相关配置可参考命令register-policy和register-suppression-timeout。
# 在公网实例中配置根据注册报文的全部内容来计算校验和。
[Sysname] pim
[Sysname-pim] register-whole-checksum
# 在VPN实例mvpn中配置根据注册报文的全部内容来计算校验和。
[Sysname-pim-mvpn] register-whole-checksum
reset pim [ all-instance | vpn-instance vpn-instance-name ] control-message counters [ interface interface-type interface-number ]
【缺省级别】
1:监控级
interface-type interface-number:接口类型和接口编号,重置指定接口的PIM控制报文计数器。如果未指定本参数,将重置所有接口的PIM控制报文数量。
【描述】
reset pim control-message counters命令用来重置PIM控制报文计数器。
需要注意的是,如果未指定all-instance和vpn-instance参数,则只重置公网实例的相关计数器。
# 重置公网实例PIM控制报文计数器。
<Sysname> reset pim control-message counters
source-lifetime interval
undo source-lifetime
【缺省级别】
2:系统级
interval:指定组播源的生存时间,取值范围为1~31536000,单位为秒。
【描述】
source-lifetime命令用来配置组播源的生存时间。undo source-lifetime命令用来恢复缺省情况。
缺省情况下,组播源的生存时间为210秒。
# 在公网实例中配置组播源的生存时间为200秒。
[Sysname] pim
[Sysname-pim] source-lifetime 200
# 在VPN实例mvpn中配置组播源的生存时间为200秒。
[Sysname-pim-mvpn] source-lifetime 200
source-policy acl-number
undo source-policy
【缺省级别】
2:系统级
acl-number:指定基本或高级ACL的编号,取值范围为2000~3999。
【描述】
source-policy命令用来配置组播数据过滤器。undo source-policy命令用来删除组播数据过滤器。
缺省情况下,没有配置组播数据过滤器。
·     如果指定的是基本ACL,则对收到的组播数据报文匹配源地址,未通过匹配的报文将被丢弃。
·     如果指定的是高级ACL,则对收到的组播数据报文匹配源地址和组地址,未通过匹配的报文将被丢弃。
·     重复执行本命令,新的配置会覆盖原有配置。
# 在公网实例中配置接收组播源为10.10.1.2的组播数据,丢弃组播源为10.10.1.1的组播数据。
[Sysname-acl-basic-2000] rule permit source 10.10.1.2 0
[Sysname-acl-basic-2000] rule deny source 10.10.1.1 0
[Sysname] pim
[Sysname-pim] source-policy 2000
# 在VPN实例mvpn中配置接收组播源为10.10.1.2的组播数据,丢弃组播源为10.10.1.1的组播数据。
[Sysname-pim-mvpn] source-policy 2000
spt-switch-threshold infinity [ group-policy acl-number [ order order-value ] ]
undo spt-switch-threshold [ group-policy acl-number ]
【缺省级别】
2:系统级
infinity:表示永不发起SPT切换。
group-policy acl-number:表示组策略列表中的一项,与该组策略相匹配的组播组将应用本配置。acl-number表示基本ACL的编号,取值范围为2000~2999。如果未指定本参数,本配置将应用于所有组播组。
order order-value:指定ACL在组策略列表中的序号。order-value的取值范围为1~现有组策略列表中的最大序号+1,但取值范围中不包括该ACL在组策略列表中的原有序号。如果已为某ACL指定了order-value,则不允许为该ACL指定相同的order-value,否则系统将报错;如果未指定本参数,则不改变该ACL在组策略列表中的序号。
【描述】
spt-switch-threshold命令用来配置发起SPT切换的条件。undo spt-switch-threshold命令用来恢复缺省情况。
缺省情况下,设备收到第一个组播数据包后便立即向SPT切换。
·     当需要调整组策略列表中已有ACL的次序时,可以通过配置参数acl-number指定该ACL,并设置其order-value,将该ACL插入到组策略列表的order-value位置。组策略列表中已有的其它ACL保持先后排列次序不变。
·     当需要启用组策略列表中没有的ACL时,可以通过配置参数acl-number指定该ACL,并设置其order-value,将该ACL插入到组策略列表的order-value位置。如果未指定order-value,则将其插入组策略列表的尾部。
·     如果对同一组播组配置了多条该命令,则该组播组按顺序匹配到的第一个命令将生效。
·     一旦建立了组播转发表项,即使有注册出接口,后续的组播数据报文也不会被封装成注册报文进行转发。所以,在可能成为RP的设备(即静态RP或C-RP等)上,不要使用参数infinity配置永不发起SPT切换,以免导致转发失败。
# 新增加一个基本ACL 2010的组策略,并配置永不发起SPT切换,且插在第一位。
[Sysname] pim
[Sysname-pim] spt-switch-threshold infinity group-policy 2010 order 1
ssm-policy acl-number
undo ssm-policy
【缺省级别】
2:系统级
【描述】
ssm-policy命令用来配置SSM组播组的范围。undo ssm-policy命令用来恢复缺省情况。
缺省情况下,SSM组播组的范围为232.0.0.0/8。
通过本命令可以定义允许或拒绝的组播组的地址范围:如果匹配通过,则组播运行模式为PIM-SSM,否则为PIM-SM。
# 在公网实例中配置SSM组播组的范围232.1.0.0/16。
[Sysname-acl-basic-2000] rule permit source 232.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] ssm-policy 2000
# 在VPN实例mvpn中配置SSM组播组的范围232.1.0.0/16。
[Sysname-pim-mvpn] ssm-policy 2000
undo state-refresh-interval
【缺省级别】
2:系统级
interval:指定发送状态刷新报文的时间间隔,取值范围为1~255,单位为秒。
【描述】
state-refresh-interval命令用来配置发送状态刷新报文的时间间隔。undo state-refresh-interval命令用来恢复缺省情况。
缺省情况下,发送状态刷新报文的时间间隔为60秒。
相关配置可参考命令pim state-refresh-capable、state-refresh-rate-limit和state-refresh-ttl。
# 在公网实例中配置发送状态刷新报文的时间间隔为70秒。
[Sysname] pim
[Sysname-pim] state-refresh-interval 70
# 在VPN实例mvpn中配置发送状态刷新报文的时间间隔为70秒。
[Sysname-pim-mvpn] state-refresh-interval 70
state-refresh-rate-limit interval
undo state-refresh-rate-limit
【缺省级别】
2:系统级
interval:指定接收新状态刷新报文的等待时间,取值范围为1~65535,单位为秒。
【描述】
state-refresh-rate-limit命令用来配置接收新状态刷新报文的等待时间。undo state-refresh-rate-limit命令用来恢复缺省情况。
缺省情况下,接收新状态刷新报文的等待时间为30秒。
相关配置可参考命令pim state-refresh-capable、state-refresh-interval和state-refresh-ttl。
# 在公网实例中配置接收新状态刷新报文的等待时间为45秒。
[Sysname] pim
[Sysname-pim] state-refresh-rate-limit 45
# 在VPN实例mvpn中配置接收新状态刷新报文的等待时间为45秒。
[Sysname-pim-mvpn] state-refresh-rate-limit 45
state-refresh-ttl ttl-value
undo state-refresh-ttl
【缺省级别】
2:系统级
ttl-value:指定状态刷新报文的TTL值,取值范围为1~255。
【描述】
state-refresh-ttl命令用来配置状态刷新报文的TTL值。undo state-refresh-ttl命令用来恢复缺省情况。
缺省情况下,状态刷新报文的TTL值为255。
相关配置可参考命令pim state-refresh-capable、state-refresh-interval和state-refresh-rate-limit。
# 在公网实例中配置状态刷新报文的TTL值为45。
[Sysname] pim
[Sysname-pim] state-refresh-ttl 45
# 在VPN实例mvpn中配置状态刷新报文的TTL值为45。
[Sysname-pim-mvpn] state-refresh-ttl 45
static-rp rp-address [ acl-number ] [ preferred ] [ bidir ]
undo static-rp rp-address
【缺省级别】
2:系统级
rp-address:指定静态RP的IP地址。该地址必须是实际存在且合法的单播IP地址,不能配置为127.0.0.0/8网段的地址;但对于服务于双向PIM的静态RP来说,允许将其IP地址指定为一个实际不存在的IP地址。
acl-number:指定基本ACL的编号,取值范围为2000~2999。如果指定了本参数,则配置的静态RP只为能够通过匹配的组播组服务;如果未指定本参数,则配置的静态RP将为所有组播组(224.0.0.0/4)服务。
preferred:指定当静态RP与动态RP冲突时,优先选择静态RP。如果未指定本参数,则优先选择动态RP,如果网络中没有动态RP或动态RP失效,静态RP才能生效。
bidir:指定该静态RP服务于双向PIM。如果未指定本参数,该静态RP将服务于PIM-SM。
【描述】
static-rp命令用来配置静态RP。undo static-rp命令用来删除静态RP。
缺省情况下,没有配置静态RP。
·     作为静态RP的接口不必使能PIM-SM或PIM-DM。
·     当某个静态RP引用的ACL规则发生变化时,需要为所有组播组重新选举RP。
·     重复执行本命令,可以配置多个静态RP。但是,如果配置时所指定的静态RP地址或ACL规则相同,则新配置将覆盖旧配置;如果存在多个静态RP服务于同一组播组的情况,则选择IP地址最大的静态RP为该组服务。
·     一台设备上最多可以配置50个不同的静态RP。
相关配置可参考命令display pim rp-info和auto-rp enable。
# 在公网实例中配置IP地址为11.110.0.6的接口为静态RP,为基本ACL 2001所定义的组播组225.1.1.0/24提供服务,并优先选择静态RP。
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] pim
[Sysname-pim] static-rp 11.110.0.6 2001 preferred
# 在VPN实例mvpn中配置IP地址为11.110.0.6的接口为静态RP,为基本ACL 2001所定义的组播组225.1.1.0/24提供服务,并优先选择静态RP。
[Sysname-pim-mvpn] static-rp 11.110.0.6 2001 preferred
undo timer hello
【缺省级别】
2:系统级
【描述】
timer hello命令用来全局配置发送Hello报文的时间间隔。undo timer hello命令用来恢复缺省情况。
相关配置可参考命令pim timer hello。
# 在公网实例中全局配置发送Hello报文的时间间隔为40秒。
[Sysname] pim
[Sysname-pim] timer hello 40
# 在VPN实例mvpn中全局配置发送Hello报文的时间间隔为40秒。
[Sysname-pim-mvpn] timer hello 40
undo timer join-prune
【缺省级别】
2:系统级
【描述】
timer join-prune命令用来全局配置发送加入/剪枝报文的时间间隔。undo timer join-prune命令用来恢复缺省情况。
相关配置可参考命令pim timer join-prune。
# 在公网实例中全局配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname] pim
[Sysname-pim] timer join-prune 80
# 在VPN实例mvpn中全局配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname-pim-mvpn] timer join-prune 80
