08-IP组播命令参考
12-IPv6组播VLAN命令
本章节下载: 12-IPv6组播VLAN命令  (95.95 KB)
12-IPv6组播VLAN命令
1 IPv6组播VLAN······························································································································· 1-1
1.1 IPv6组播VLAN配置命令········································································································· 1-1
1.1.1 display multicast-vlan ipv6····························································································· 1-1
1.1.2 multicast-vlan ipv6········································································································· 1-2
1.1.3 multicast-vlan ipv6 entry-limit·························································································· 1-2
1.1.4 subvlan (IPv6 Multicast-VLAN view)················································································ 1-3
1 IPv6组播VLAN
1.1  IPv6组播VLAN配置命令
display multicast-vlan ipv6 [ vlan-id ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
vlan-id:查看指定IPv6组播VLAN的信息,取值范围为1~4094。如果未指定本参数,将显示所有IPv6组播VLAN的信息。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display multicast-vlan ipv6命令用来查看IPv6组播VLAN的信息。
# 查看所有IPv6组播VLAN的信息。
<Sysname> display multicast-vlan ipv6
 Total 1 IPv6 multicast-vlan(s)
 IPv6 Multicast vlan 100
   subvlan list:
    vlan 2  4-6
表1-1 display multicast-vlan ipv6命令显示信息描述表
IPv6组播VLAN的总数
IPv6 Multicast vlan
IPv6组播VLAN
subvlan list
IPv6组播VLAN的子VLAN列表
multicast-vlan ipv6 vlan-id
undo multicast-vlan ipv6 { all | vlan-id }
【缺省级别】
2:系统级
vlan-id:指定VLAN的编号,取值范围为1~4094。
all:删除所有IPv6组播VLAN。
【描述】
multicast-vlan ipv6命令用来配置指定VLAN为IPv6组播VLAN,并进入IPv6组播VLAN视图。undo multicast-vlan ipv6命令用来取消指定VLAN为IPv6组播VLAN。
缺省情况下,VLAN不是IPv6组播VLAN。
·     要配置为IPv6组播VLAN的指定VLAN必须存在。
·     在已使能了IPv6组播路由的设备上不允许再配置IPv6组播VLAN。
·     只需要在IPv6组播VLAN内使能MLD Snooping。
相关配置可参考“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 routing-enable和“IP组播命令参考/MLD Snooping”中的命令mld-snooping enable。
# 在VLAN 100内使能MLD Snooping,将其配置为IPv6组播VLAN,并进入IPv6组播VLAN视图。
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 100
[Sysname-vlan100] mld-snooping enable
[Sysname-vlan100] quit
[Sysname] multicast-vlan ipv6 100
[Sysname-ipv6-mvlan-100]
multicast-vlan ipv6 entry-limit limit
undo multicast-vlan ipv6 entry-limit
【缺省级别】
2:系统级
limit:IPv6组播VLAN内MLD Snooping转发表项的最大数量,取值范围与系统的工作模式有关,详细说明请参见“基础配置指导/设备管理”中的“配置系统工作模式”。
【描述】
multicast-vlan ipv6 entry-limit命令用来配置IPv6组播VLAN内MLD Snooping转发表项的最大数量。undo multicast-vlan ipv6 entry-limit命令用来恢复缺省情况。
缺省情况下,IPv6组播VLAN内MLD Snooping转发表项的最大数量与系统的工作模式有关,详细说明请参见“基础配置指导/设备管理”中的“配置系统工作模式”。
相关配置可参考“IP组播命令参考/MLD Snooping”中的命令entry-limit。
# 配置IPv6组播VLAN内MLD Snooping转发表项的最大数量为512个。
[Sysname] multicast-vlan ipv6 entry-limit 512
subvlan vlan-list
undo subvlan { all | vlan-list }
IPv6组播VLAN视图
【缺省级别】
2:系统级
vlan-list:指定子VLAN列表,表示多个子VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定子VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
all:删除当前IPv6组播VLAN内的所有子VLAN。
【描述】
subvlan命令用来向IPv6组播VLAN内添加子VLAN。undo subvlan命令用来删除IPv6组播VLAN内的子VLAN。
缺省情况下,IPv6组播VLAN内没有子VLAN。
·     要添加到IPv6组播VLAN内的子VLAN必须存在。
·     IPv6组播VLAN内子VLAN的总数不得超过1024。
# 配置VLAN 10到VLAN 15为IPv6组播VLAN 100的子VLAN。
[Sysname-ipv6-mvlan-100] subvlan 10 to 15
