03-Basic Network Configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10003-Basic Network Configuration
12-Static NAT Configuration Example
12-Static NAT Configuration Example 82.32 KB
Comware 7 Static NAT
Overview
The following information provides an example for configuring static NAT to allow users in the internal network to access the server in the external network.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of NAT.
Example: Configuring static NAT
As shown in Figure 1, configure a static NAT rule to allow the client in the internal network to access the server in the external network.
Figure 1 Network diagram
Configure static routes or a dynamic routing protocol on all devices to make sure the network connections are available.
Procedures
1.     Configure basic wireless features on the AC. (Details not shown.)
2.     Configure a static NAT rule:
a.     Click the System View tab at the bottom of the page.
b.     From the navigation pane, select Network Configuration > Network Services > NAT.
c.     Click Static NAT.
d.     On the Rules tab, click the Add button .
e.     Specify 10.110.10.8 as the private IP address and 202.38.1.100 as the public address.
Figure 2 Creating a static NAT rule
f.     Click Apply.
3.     Apply the static rule to VLAN-interface 20:
a.     Click the Apply tab.
b.     Select VLAN-interface 20.
c.     Click Apply.
Verify that the internal client can access the external server. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
