03-Basic Network Configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10003-Basic Network Configuration
07-Static IPv6 DNS Configuration Example
07-Static IPv6 DNS Configuration Example 81.21 KB
Comware 7 Static IPv6 DNS
Overview
The following information provides an example for configuring static IPv6 DNS to allow users to access a host.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of DNS.
Example: Configuring static IPv6 DNS
As shown in Figure 1, the host at 1::2 is named host.com. Configure static IPv6 DNS on the AC so that the AC can use the easy-to-remember domain name rather than the IPv6 address to access the host.
Figure 1 Network diagram
Make sure the network connections are available.
Procedures
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select Network Configuration > Network Services > DHCP/DNS.
3.     Click the IPv6 DNS tab.
4.     Click Manual.
5.     Enter host name host.com and IPv6 address 1::2.
Figure 2 Configuring a static IPv6 DNS mapping
6.     Click the Add icon .
# Verify that the AC can use the static domain name resolution to resolve domain name host.com into IP address 1::2.
<AC> ping ipv6 host.com
Ping6(56 data bytes) 1::1 --> 1::2, press CTRL_C to break
56 bytes from 1::2, icmp_seq=0 hlim=128 time=1.505 ms
56 bytes from 1::2, icmp_seq=1 hlim=128 time=0.497 ms
56 bytes from 1::2, icmp_seq=2 hlim=128 time=0.594 ms
56 bytes from 1::2, icmp_seq=3 hlim=128 time=0.471 ms
56 bytes from 1::2, icmp_seq=4 hlim=128 time=0.436 ms
--- Ping6 statistics for host.com ---
round-trip min/avg/max/std-dev = 0.436/0.701/1.505/0.406 ms
Related documentation
H3C Access Controllers Web-Based Configuration Guide
