03-Basic Network Configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10003-Basic Network Configuration
08-Dynamic IPv4 DNS Configuration Example
08-Dynamic IPv4 DNS Configuration Example 98.71 KB
Comware 7 Dynamic IPv4 DNS
Overview
The following information provides an example for configuring dynamic IPv4 DNS to allow users to access a host.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of DNS.
Example: Configuring dynamic IPv4 DNS
As shown in Figure 1, configure the DNS server to store the mapping between the host's domain name host and IPv4 address 3.1.1.1/16 in the com domain. Configure dynamic IPv4 domain name resolution and specify the DNS suffix as com on the AC so that the client can use domain name host to access the host.
Figure 1 Network diagram
Configure static routes or a dynamic routing protocol on all devices to make sure the network connections are available.
Procedures
Configuring the DNS server
On the DNS server, configure the mapping between the host's domain name host and IPv4 address 3.1.1.1/16 in the com domain. (Details not shown.)
Configuring the DNS client
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select Network Configuration > Network Services > DHCP/DNS.
3.     Click the IPv4 DNS tab.
4.     Specify 2.1.1.2 as the DNS server IP address.
Figure 2 Specifying the DNS server IP address
5.     Click the Add icon .
6.     Click the Advanced settings button .
7.     Enter domain name suffix com.
Figure 3 Configuring the DNS suffix
8.     Click the Add icon .
# Verify that the AC can use the dynamic domain name resolution to resolve domain name host.com into IP address 3.1.1.1.
<AC> ping host
Ping host.com (3.1.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 3.1.1.1: icmp_seq=0 ttl=128 time=0.611 ms
56 bytes from 3.1.1.1: icmp_seq=1 ttl=128 time=0.468 ms
56 bytes from 3.1.1.1: icmp_seq=2 ttl=128 time=0.442 ms
56 bytes from 3.1.1.1: icmp_seq=3 ttl=128 time=0.539 ms
56 bytes from 3.1.1.1: icmp_seq=4 ttl=128 time=0.395 ms
--- Ping statistics for host.com ---
round-trip min/avg/max/std-dev = 0.395/0.491/0.611/0.076 ms
Related documentation
H3C Access Controllers Web-Based Configuration Guide
