03-Basic Network Configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10003-Basic Network Configuration
18-IGMP Snooping Configuration Example
18-IGMP Snooping Configuration Example 99.13 KB
Comware 7 IGMP Snooping
Overview
The following information provides an example for configuring IGMP snooping on the AC to forward multicast packets to receivers instead of flooding them within a VLAN.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of IGMP snooping.
Example: Configuring IGMP snooping
As shown in Figure 1, Source 1 sends multicast data to multicast group 224.1.1.1. Host A and Host B are receivers of multicast group 224.1.1.1 and run IGMPv2.
Configure the AC as an IGMP querier and specify 192.168.1.10 as the source IP address of IGMP queries. To prevent multicast packet from being flooded in VLAN 10, enable dropping unknown multicast data on all devices.
Figure 1 Network diagram
Procedures
Configuring the AC as an IGMP querier
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select Network Configuration > Network Services > Multicast.
3.     On the IGMP Snooping tab, click Enable IGMP snooping.
Figure 2 Enabling IGMP snooping
4.     On the page that opens, click the Add button .
5.     Configure IGMP snooping for VLAN 10:
a.     Set the IGMP snooping version to 2.
b.     Enable dropping unknown multicast data.
c.     Enable IGMP querier.
d.     Specify 192.168.1.10 as the source IP address of IGMP general queries and IGMP group-specific queries.
Figure 3 Configuring IGMP snooping for VLAN 10
6.     Click Apply.
Configuring IGMP snooping on switches
On Switch A and Switch B, enable IGMPv2 snooping and enable dropping unknown multicast packets for VLAN 10.
Verify that an IGMP snooping forwarding entry is created for multicast group 224.1.1.1 after Host A or Host B joins the multicast group. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
