- 03-Basic Network Configuration
- 01-Layer 2 Static Link Aggregation Configuration Example
- 02-Layer 2 Dynamic Link Aggregation Configuration Example
- 03-PPPoE Client Configuration Example
- 04-Static IPv6 Address Configuration Example
- 05-IPv6 Static Routing Configuration Example
- 06-Static IPv4 DNS Configuration Example
- 07-Static IPv6 DNS Configuration Example
- 08-Dynamic IPv4 DNS Configuration Example
- 09-Dynamic IPv6 DNS Configuration Example
- 10-IPv4 DNS Proxy Configuration Example
- 11-IPv6 DNS Proxy Configuration Example
- 12-Static NAT Configuration Example
- 13-Dynamic NAT Configuration Example
- 14-IPv4 ACL-Based Packet Filter Configuration Example
- 15-IPv6 ACL-Based Packet Filter Configuration Example
- 16-ARP Attack Protection Configuration Example
- 17-ARP Proxy Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
| 16-ARP Attack Protection Configuration Example | 241.76 KB |
H3C Access Controllers |
Comware 7 ARP Attack Protection |
Overview
The following information provides an example for configuring ARP attack protection.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of ARP attack protection.
Example: Configuring ARP attack protection
As shown in Figure 1, configure ARP attack protection for VLAN 10 on the AC so the AC can perform ARP packet validity check and user validity check on Client 1 and Client 2.
Make sure the AC, the switch, and the clients can reach other. (Details not shown.)
Procedures
Configuring the DHCP server
Details not shown.
Configuring the AC
Configuring IP addresses
# Add all interfaces on the AC to VLAN 10. (Details not shown.)
Configuring DHCP snooping
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Configuration > Network Services > DHCP/DNS.
3. Click the DHCP Snooping tab.
4. Click the Enable DHCP Snooping button.
Figure 2 Enabling DHCP snooping
5. Enable the binding record feature on GigabitEthernet 1/0/1 and configure GigabitEthernet 1/0/3 as a trusted port.
Figure 3 Configuring DHCP snooping
6. Click Apply.
1. From the navigation pane, select Network Configuration > Network Services > ARP.
2. Click the Advanced settings
button
to
configure advanced ARP settings.
3. In the Attack protection area, click the
right angle bracket button
in
the ARP attack protection row.
Figure 4 Configuring advanced ARP settings
4. Enable ARP detection on VLAN 10.
Figure 5 Enabling ARP detection
5. In the Settings area, click the right chevron
button
in
the Advanced settings row to configure advanced ARP attack protection.
a. In the ARP packet validity check area, enable source MAC address check, destination MAC address check, and IP address check.
b. In the Trusted interfaces area, configure GigabitEthernet 1/0/3 as a trusted interface.
Figure 6 Configuring advanced ARP attack protection
2. From the navigation pane, select Network Configuration > Network Services > ARP.
3. Verify that the AC has the ARP entry for Client 1 but it does not have the ARP entry for Client 2.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
