- 03-Basic Network Configuration
- 01-Layer 2 Static Link Aggregation Configuration Example
- 02-Layer 2 Dynamic Link Aggregation Configuration Example
- 03-PPPoE Client Configuration Example
- 04-Static IPv6 Address Configuration Example
- 05-IPv6 Static Routing Configuration Example
- 06-Static IPv4 DNS Configuration Example
- 07-Static IPv6 DNS Configuration Example
- 08-Dynamic IPv4 DNS Configuration Example
- 09-Dynamic IPv6 DNS Configuration Example
- 10-IPv4 DNS Proxy Configuration Example
- 11-IPv6 DNS Proxy Configuration Example
- 12-Static NAT Configuration Example
- 13-Dynamic NAT Configuration Example
- 14-IPv4 ACL-Based Packet Filter Configuration Example
- 15-IPv6 ACL-Based Packet Filter Configuration Example
- 16-ARP Attack Protection Configuration Example
- 17-ARP Proxy Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
| 06-Static IPv4 DNS Configuration Example | 82.16 KB |
H3C Access Controllers |
Comware 7 Static IPv4 DNS |
Overview
The following information provides an example for configuring static IPv4 DNS to allow users to access a host.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of DNS.
Example: Configuring static IPv4 DNS
As shown in Figure 1, the host at 10.1.1.2 is named host.com. Configure static IPv4 DNS on the AC so that the AC can use the easy-to-remember domain name rather than the IP address to access the host.
Make sure the network connections are available.
Procedures
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Configuration > Network Services > DHCP/DNS.
3. Click the IPv4 DNS tab.
4. Click Manual.
5. Enter host name host.com and IP address 10.1.1.2.
Figure 2 Configuring a static DNS mapping
6. Click the Add icon
# Verify that the AC can use the static domain name resolution to resolve domain name host.com into IP address 10.1.1.2.
<AC> ping host.com
Ping host.com (10.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=128 time=0.599 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=128 time=0.488 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=128 time=0.370 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=128 time=0.524 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=128 time=0.398 ms
--- Ping statistics for host.com ---
round-trip min/avg/max/std-dev = 0.370/0.476/0.599/0.084 ms
Related documentation
H3C Access Controllers Web-Based Configuration Guide
