- 03-Basic Network Configuration
- 01-Layer 2 Static Link Aggregation Configuration Example
- 02-Layer 2 Dynamic Link Aggregation Configuration Example
- 03-PPPoE Client Configuration Example
- 04-Static IPv6 Address Configuration Example
- 05-IPv6 Static Routing Configuration Example
- 06-Static IPv4 DNS Configuration Example
- 07-Static IPv6 DNS Configuration Example
- 08-Dynamic IPv4 DNS Configuration Example
- 09-Dynamic IPv6 DNS Configuration Example
- 10-IPv4 DNS Proxy Configuration Example
- 11-IPv6 DNS Proxy Configuration Example
- 12-Static NAT Configuration Example
- 13-Dynamic NAT Configuration Example
- 14-IPv4 ACL-Based Packet Filter Configuration Example
- 15-IPv6 ACL-Based Packet Filter Configuration Example
- 16-ARP Attack Protection Configuration Example
- 17-ARP Proxy Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
| 17-ARP Proxy Configuration Example | 206.52 KB |
H3C Access Controllers |
Comware 7 ARP Proxy |
Overview
The following information provides an example for configuring ARP proxy.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of ARP proxy.
Example: Configuring ARP proxy
As shown in Figure 1, Client 1 and Client 2 have the same prefix and mask, but they are located on different subnets separated by the switch. Client 1 belongs to VLAN 10, and Client 2 belongs to VLAN 20. No default gateway is configured on Client 1 and Client 2.
Configure ARP proxy on the AC to enable communication between Client 1 and Client 2.
Procedures
Configuring VLANs
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Configuration > VLAN.
The page for configuring VLANs opens.
Figure 2 Configuring VLANs
3. Click the Create VLANs
button
to
create VLAN 10 and VLAN 20.
Figure 3 Creating VLANs
4. Click the Edit button
for VLAN
10.
The page for configuring the VLAN interface opens.
5. Select Create VLAN interface and set the IP address of the VLAN interface to 192.168.10.99/255.255.255.0.
Figure 4 Specifying a VLAN interface address
6. Repeat steps 4 and 5 to create a VLAN interface for VLAN 20 and set the IP address of the VLAN interface to 192.168.20.99/255.255.255.0. (Details not shown.)
Configuring ARP
1. From the navigation pane, select Network Configuration > Network Services > ARP.
2. Click the Advanced settings button
3. In the ARP area, click the right chevron
button
in the ARP proxy row.
Figure 5 Configuring advanced ARP settings
4. Enable ARP proxy for VLAN 10 and VLAN 20.
Figure 6 Enabling ARP proxy
# Verify that Client 1 and Client 2 can communicate with each other. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
