03-Basic Network Configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10003-Basic Network Configuration
10-IPv4 DNS Proxy Configuration Example
10-IPv4 DNS Proxy Configuration Example 92.28 KB
Comware 7 IPv4 DNS Proxy
Overview
The following information provides an example for configuring IPv4 DNS proxy to allow users to access a host through the DNS proxy. When the DNS server address is changed, you can change the configuration only on the DNS proxy instead of on each DNS client.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of DNS proxy.
Example: Configuring IPv4 DNS proxy
As shown in Figure 1, the AC acts as the DNS proxy to relay DNS packets between wireless client and the DNS server. The wireless client accesses the host with domain name host.com through the DNS proxy.
Figure 1 Network diagram
Configure static routes or a dynamic routing protocol on all devices to make sure the network connections are available.
Procedures
Configuring the DNS server
On the DNS server, configure the mapping between the host's domain name host.com and IPv4 address 3.1.1.1/24. (Details not shown.)
Configuring the AC
1.     Configure basic wireless features on the AC. (Details not shown.)
2.     Specify the DNS server IP address on the AC:
a.     Click the System View tab at the bottom of the page.
b.     From the navigation pane, select Network Configuration > Network Services > DHCP/DNS.
c.     Click the IPv4 DNS tab.
d.     Specify 4.1.1.1 as the DNS server IP address.
Table 1 Specifying the DNS server address
e.     Click the Add icon .
3.     Configure the AC as the DNS proxy:
a.     On the IPv4 DNS tab, click the Advanced settings button .
b.     Enable DNS proxy.
Figure 2 Enabling DNS proxy
Configuring the DNS client
On the DNS client, specify the DNS server 2.1.1.2. (Details not shown.)
# Execute the ping host.com command on the client and verify that the client can resolve domain name host.com into IP address 3.1.1.1.
C:\Users\aa>ping host.com
Ping host.com (3.1.1.1): 56 data bytes
56 bytes from 3.1.1.1: icmp_seq=0 ttl=128 time=0.671 ms
56 bytes from 3.1.1.1: icmp_seq=1 ttl=128 time=0.571 ms
56 bytes from 3.1.1.1: icmp_seq=2 ttl=128 time=0.373 ms
56 bytes from 3.1.1.1: icmp_seq=3 ttl=128 time=0.538 ms
56 bytes from 3.1.1.1: icmp_seq=4 ttl=128 time=0.750 ms
--- 3.1.1.1 ping statistics ---
round-trip min/avg/max = 0.373/0.581/0.750 ms
Related documentation
H3C Access Controllers Web-Based Configuration Guide
