- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLS-VPN-BGP-MIB
- 05-HH3C-MPLSCRLSP-MIB
- 06-HH3C-MPLSEXT-MIB
- 07-HH3C-MPLSRSVP-MIB
- 08-HH3C-MPLSSLSP-MIB
- 09-HH3C-MPLSTE-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
20-PW-STD-MIB | 111.19 KB |
PW-STD-MIB
About this MIB
Use this MIB to configure PW related settings.
MIB file name
rfc5601-pw-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).pwStdMIB(246)
Scalar objects
pwIndexNext
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwIndexNext (1.3.6.1.2.1.10.246.1.1) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Next available index for creating a PW entry. |
As per the MIB. |
pwPerfTotalErrorPackets
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwPerfTotalErrorPackets (1.3.6.1.2.1.10.246.1.6) |
read-only |
Counter32 |
Counter32 (0..4294967295) |
Total number of error at the PW processing level. |
Not supported |
pwUpDownNotifEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwUpDownNotifEnable (1.3.6.1.2.1.10.246.1.9) |
read-write |
TruthValue |
true(1), false(2) |
The capability of sending PW up and PW down notifications. |
As per the MIB. |
pwDeletedNotifEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwDeletedNotifEnable (1.3.6.1.2.1.10.246.1.10) |
read-write |
TruthValue |
true(1), false(2) |
The capability of sending PW-deleted notifications. |
As per the MIB. |
pwNotifRate
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwNotifRate (1.3.6.1.2.1.10.246.1.11) |
read-write |
Unsigned32 |
Unsigned32 (1..2147483647) |
The maximum number of PW notifications that can be sent per second. |
Not supported |
Tabular objects
pwTable
About this table
Use this table to configure PWs.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is pwIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwIndex (1.3.6.1.2.1.10.246.1.2.1.1) |
not-accessible |
PwIndexType |
Index of a PW. |
As per the MIB. |
pwType (1.3.6.1.2.1.10.246.1.2.1.2) |
read-create |
IANAPwTypeTC |
other(0), frameRelayDlciMartiniMode(1), atmAal5SduVcc(2), atmTransparent(3), ethernetTagged(4), ethernet(5), hdlc(6), ppp(7), cem(8), atmCellNto1Vcc(9), atmCellNto1Vpc(10), ipLayer2Transport(11), atmCell1to1Vcc(12), atmCell1to1Vpc(13), atmAal5PduVcc(14), frameRelayPortMode(15), cep(16), e1Satop(17), t1Satop(18), e3Satop(19), t3Satop(20), basicCesPsn(21), basicTdmIp(22), tdmCasCesPsn(23), tdmCasTdmIp(24), frDlci(25), wildcard(32767) |
Encapsulation type. |
The set operation supports only ethernetTagged(4) and ethernet(5). |
pwOwner (1.3.6.1.2.1.10.246.1.2.1.3) |
read-create |
INTEGER |
manual(1), pwIdFecSignaling(2), genFecSignaling(3), l2tpControlProtocol(4), other(5) |
PW owner, the protocol used for establishing the PW. |
The set operation supports only manual(1), pwIdFecSignaling(2), and genFecSignaling(3). |
pwPsnType (1.3.6.1.2.1.10.246.1.2.1.4) |
read-create |
IANAPwPsnTypeTC |
mpls(1), l2tp(2), udpOverIp(3), mplsOverIp(4), mplsOverGre(5), other(6) |
PSN type for the PW. |
Supports only the read operation. Supports only mpls(1), mplsOverGre (5), and other (6). |
pwPeerAddrType (1.3.6.1.2.1.10.246.1.2.1.8) |
read-create |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16) |
Type of the peer IP address of the PW. |
Supports only ipv4(1). |
pwPeerAddr (1.3.6.1.2.1.10.246.1.2.1.9) |
read-create |
InetAddress |
OCTET STRING (0..255) |
Peer IP address of the PW. |
Supports only an IPv4 address. |
pwAttachedPwIndex (1.3.6.1.2.1.10.246.1.2.1.10) |
read-create |
PwIndexOrZeroType |
Unsigned32 (0..2147483647) |
Index of the attached PW. |
Supports only the read operation. |
pwIfIndex (1.3.6.1.2.1.10.246.1.2.1.11) |
read-create |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
Interface index of the PW when the PW is modeled as an interface. |
pwID (1.3.6.1.2.1.10.246.1.2.1.12) |
read-create |
PwIDType |
PW ID. |
As per the MIB. |
pwLocalGroupID (1.3.6.1.2.1.10.246.1.2.1.13) |
read-create |
PwGroupID |
Local group ID of the PW. |
pwGroupAttachmentID (1.3.6.1.2.1.10.246.1.2.1.14) |
read-create |
PwAttachmentIdentifierType |
Local AGI of the PW. |
pwLocalAttachmentID (1.3.6.1.2.1.10.246.1.2.1.15) |
read-create |
Local AII of the PW. |
pwRemoteAttachmentID (1.3.6.1.2.1.10.246.1.2.1.16) |
read-create |
Remote AII of the PW. |
pwCwPreference (1.3.6.1.2.1.10.246.1.2.1.17) |
read-create |
TruthValue |
true(1), false(2) |
Indicates whether the control word is set on the local node. |
As per the MIB. |
pwLocalCapabAdvert (1.3.6.1.2.1.10.246.1.2.1.20) |
read-create |
IANAPwCapabilities |
pwStatusIndication(0), pwVCCV(1) |
Capabilities the local node will advertise to the peer. |
The set operation supports only pwStatusIndication(0). |
pwRemoteGroupID (1.3.6.1.2.1.10.246.1.2.1.21) |
read-only |
PwGroupID |
Remote group ID of the PW. |
The value is always 0. |
pwCwStatus (1.3.6.1.2.1.10.246.1.2.1.22) |
read-only |
PwCwStatusTC |
waitingForNextMsg(1), sentWrongBitErrorCode(2), rxWithdrawWithWrongBitErrorCode(3), illegalReceivedBit(4), cwPresent(5), cwNotPresent(6), notYetKnown(7) |
Status of the control word negotiation, indicating whether the control word is to be present for the PW. |
Supports only cwPresent(5) and cwNotPresent(6). |
pwRemoteIfMtu (1.3.6.1.2.1.10.246.1.2.1.23) |
read-only |
Unsigned32 |
Remote interface MTU for the PW. |
As per the MIB. |
pwRemoteCapabilities (1.3.6.1.2.1.10.246.1.2.1.25) |
read-only |
Capabilities received from the peer node of the PW. |
As per the MIB. |
pwAdminStatus (1.3.6.1.2.1.10.246.1.2.1.37) |
read-create |
INTEGER |
up(1), down(2), testing(3) |
Administrative status of the PW. |
Supports the set operation only on VPWS PWs. For a VPLS PW, the set operation will be ignored. Supports only up(1) and down(2). |
pwOperStatus (1.3.6.1.2.1.10.246.1.2.1.38) |
read-only |
PwOperStatusTC |
up(1), down(2), testing(3), dormant(4), notPresent(5), lowerLayerDown(6) |
Operational status of the PW. |
Supports up(1), down(2), dormant(4), notPresent(5), and lowerLayerDown(6). |
pwLocalStatus (1.3.6.1.2.1.10.246.1.2.1.39) |
read-only |
PwStatus |
pwNotForwarding(0), servicePwRxFault(1), servicePwTxFault(2), psnPwRxFault(3), psnPwTxFault(4) |
Status of the PW on the local node. |
Supports only zero and BITS {pwNotForwarding(0)}. |
pwRemoteStatusCapable (1.3.6.1.2.1.10.246.1.2.1.40) |
read-only |
INTEGER |
notApplicable(1), notYetKnown(2), remoteCapable(3), remoteNotCapable(4) |
Remote node capability to advertise the PW status notification. |
As per the MIB. |
pwRemoteStatus (1.3.6.1.2.1.10.246.1.2.1.41) |
read-only |
PwStatus |
Status of the PW as was advertised by the remote. |
As per the MIB. |
pwTimeElapsed (1.3.6.1.2.1.10.246.1.2.1.42) |
read-only |
Integer32 |
Integer32 (0..86399) |
Number of seconds that have elapsed since the beginning of the current interval measurement period. |
As per the MIB. |
pwValidIntervals (1.3.6.1.2.1.10.246.1.2.1.43) |
read-only |
HCPerfValidIntervals |
Integer32 (0..96) |
Number of valid time intervals for which data was collection. |
Value range: 0 to 4. |
pwRowStatus (1.3.6.1.2.1.10.246.1.2.1.44) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports active(1), notInService(2), createAndGo(4), and destroy(6). |
pwStorageType (1.3.6.1.2.1.10.246.1.2.1.45) |
read-create |
StorageType |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type for the PW. |
Supports only the read operation. The value is always nonVolatile(3). |
pwOamEnable (1.3.6.1.2.1.10.246.1.2.1.46) |
read-create |
TruthValue |
"true(1), false(2)" |
Indicates whether OAM is enabled for the PW. |
As per the MIB. |
pwGenAGIType (1.3.6.1.2.1.10.246.1.2.1.47) |
read-create |
PwGenIdType |
Unsigned32 (0..254) |
AGI type of the PW. |
pwGenLocalAIIType (1.3.6.1.2.1.10.246.1.2.1.48) |
read-create |
PwGenIdType |
Local AII type of the PW. |
pwGenRemoteAIIType (1.3.6.1.2.1.10.246.1.2.1.49) |
read-create |
PwGenIdType |
Remote AII type of the PW. |
pwPerfCurrentTable
About this table
This table provides per-PW performance information for the current interval.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwPerfCurrentInHCPackets (1.3.6.1.2.1.10.246.1.3.1.1) |
read-only |
HCPerfCurrentCount |
Counter64 (0..18446744073709551615) |
High-capacity counter for number of packets received by the PW. |
As per the MIB. |
pwPerfCurrentInHCBytes (1.3.6.1.2.1.10.246.1.3.1.2) |
read-only |
High-capacity counter for number of bytes received by the PW. |
As per the MIB. |
pwPerfCurrentOutHCPackets (1.3.6.1.2.1.10.246.1.3.1.3) |
read-only |
High-capacity counter for number of packets forwarded by the PW. |
As per the MIB. |
pwPerfCurrentOutHCBytes (1.3.6.1.2.1.10.246.1.3.1.4) |
read-only |
High-capacity counter for number of bytes forwarded by the PW. |
As per the MIB. |
pwPerfCurrentInPackets (1.3.6.1.2.1.10.246.1.3.1.5) |
read-only |
PerfCurrentCount |
Gauge32 (0..4294967295) |
Counter for number of packets received by the PW. |
As per the MIB. |
pwPerfCurrentInBytes (1.3.6.1.2.1.10.246.1.3.1.6) |
read-only |
PerfCurrentCount |
Counter for number of bytes received by the PW. |
As per the MIB. |
pwPerfCurrentOutPackets (1.3.6.1.2.1.10.246.1.3.1.7) |
read-only |
PerfCurrentCount |
Counter for number of packets forwarded by the PW. |
As per the MIB. |
pwPerfCurrentOutBytes (1.3.6.1.2.1.10.246.1.3.1.8) |
read-only |
PerfCurrentCount |
Counter for number of bytes forwarded by the PW. |
As per the MIB. |
pwPerfIntervalTable
About this table
This table provides per-PW performance information for the latest four intervals.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pwIndex and pwPerfIntervalNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwPerfIntervalNumber (1.3.6.1.2.1.10.246.1.4.1.1) |
not-accessible |
Integer32 |
Integer32 (1..96) |
Number of a time interval. |
As per the MIB. |
pwPerfIntervalValidData (1.3.6.1.2.1.10.246.1.4.1.2) |
read-only |
TruthValue |
false(2) |
Indicates whether the data for this interval is valid. |
As per the MIB. |
pwPerfIntervalTimeElapsed (1.3.6.1.2.1.10.246.1.4.1.3) |
read-only |
HCPerfTimeElapsed |
Duration of this interval in seconds. |
As per the MIB. |
pwPerfIntervalInHCPackets (1.3.6.1.2.1.10.246.1.4.1.4) |
read-only |
HCPerfIntervalCount |
As per the MIB. |
pwPerfIntervalInHCBytes (1.3.6.1.2.1.10.246.1.4.1.5) |
read-only |
As per the MIB. |
pwPerfIntervalOutHCPackets (1.3.6.1.2.1.10.246.1.4.1.6) |
read-only |
As per the MIB. |
pwPerfIntervalOutHCBytes (1.3.6.1.2.1.10.246.1.4.1.7) |
read-only |
As per the MIB. |
pwPerfIntervalInPackets (1.3.6.1.2.1.10.246.1.4.1.8) |
read-only |
PerfIntervalCount |
As per the MIB. |
pwPerfIntervalInBytes (1.3.6.1.2.1.10.246.1.4.1.9) |
read-only |
PerfIntervalCount |
As per the MIB. |
pwPerfIntervalOutPackets (1.3.6.1.2.1.10.246.1.4.1.10) |
read-only |
PerfIntervalCount |
As per the MIB. |
pwPerfIntervalOutBytes (1.3.6.1.2.1.10.246.1.4.1.11) |
read-only |
PerfIntervalCount |
As per the MIB. |
pwPerf1DayIntervalTable
About this table
This table provides per-PW performance information for the current day's interval and the previous day's interval.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pwIndex and pwPerf1DayIntervalNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwPerf1DayIntervalNumber (1.3.6.1.2.1.10.246.1.5.1.1) |
read-only |
Unsigned32 |
Unsigned32 (1..31) |
As per the MIB. |
pwPerf1DayIntervalValidData (1.3.6.1.2.1.10.246.1.5.1.2) |
read-only |
TruthValue |
true(1), false(2) |
As per the MIB. |
pwPerf1DayIntervalTimeElapsed (1.3.6.1.2.1.10.246.1.5.1.3) |
read-only |
HCPerfTimeElapsed |
As per the MIB. |
pwPerf1DayIntervalInHCPackets (1.3.6.1.2.1.10.246.1.5.1.4) |
read-only |
Counter64 |
As per the MIB. |
pwPerf1DayIntervalInHCBytes (1.3.6.1.2.1.10.246.1.5.1.5) |
read-only |
Counter64 |
As per the MIB. |
pwPerf1DayIntervalOutHCPackets (1.3.6.1.2.1.10.246.1.5.1.6) |
read-only |
Counter64 |
As per the MIB. |
pwPerf1DayIntervalOutHCBytes (1.3.6.1.2.1.10.246.1.5.1.7) |
read-only |
Counter64 |
As per the MIB. |
pwIndexMappingTable
About this table
This table enables the reverse mapping of the unique PWid parameters [peer IP, PW type, and PW ID] and the pwIndex.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pwIndexMappingPwType, pwIndexMappingPwID, pwIndexMappingPeerAddrType, and pwIndexMappingPeerAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwIndexMappingPwType (1.3.6.1.2.1.10.246.1.7.1.1) |
not-accessible |
IANAPwTypeTC |
PW encapsulation type. |
As per the MIB. |
pwIndexMappingPwID (1.3.6.1.2.1.10.246.1.7.1.2) |
not-accessible |
PwIDType |
Unsigned32 |
PW ID. |
As per the MIB. |
pwIndexMappingPeerAddrType (1.3.6.1.2.1.10.246.1.7.1.3) |
not-accessible |
InetAddressType |
IP address type of the peer node. |
As per the MIB. |
pwIndexMappingPeerAddr (1.3.6.1.2.1.10.246.1.7.1.4) |
not-accessible |
InetAddress |
IP address of the peer node. |
As per the MIB. |
pwIndexMappingPwIndex (1.3.6.1.2.1.10.246.1.7.1.5) |
read-only |
PwIndexType |
Index of the PW in the pwTable. |
As per the MIB. |
pwPeerMappingTable
About this table
This table provides information about mappings between the PW parameters and pwIndex.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pwPeerMappingPeerAddrType, pwPeerMappingPeerAddr, pwPeerMappingPwType, and pwPeerMappingPwID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwPeerMappingPeerAddrType (1.3.6.1.2.1.10.246.1.8.1.1) |
not-accessible |
InetAddressType |
As per the MIB. |
pwPeerMappingPeerAddr (1.3.6.1.2.1.10.246.1.8.1.2) |
not-accessible |
InetAddress |
As per the MIB. |
pwPeerMappingPwType (1.3.6.1.2.1.10.246.1.8.1.3) |
not-accessible |
IANAPwTypeTC |
As per the MIB. |
pwPeerMappingPwID (1.3.6.1.2.1.10.246.1.8.1.4) |
not-accessible |
PwIDType |
Unsigned32(0..4294967295) |
PW ID |
As per the MIB. |
pwPeerMappingPwIndex (1.3.6.1.2.1.10.246.1.8.1.5) |
read-only |
PwIndexType |
As per the MIB. |
pwGenFecIndexMappingTable
About this table
This table provides information about mappings between the GenFec PW parameters and pwIndex.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pwGenFecIndexMappingAGIType, pwGenFecIndexMappingAGI, pwGenFecIndexMappingLocalAIIType, pwGenFecIndexMappingLocalAII, pwGenFecIndexMappingRemoteAIIType, and pwGenFecIndexMappingRemoteAII.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwGenFecIndexMappingAGIType (1.3.6.1.2.1.10.246.1.12.1.1) |
not-accessible |
PwGenIdType |
As per the MIB. |
pwGenFecIndexMappingAGI (1.3.6.1.2.1.10.246.1.12.1.2) |
not-accessible |
AGI value of the PW. |
As per the MIB. |
pwGenFecIndexMappingLocalAIIType (1.3.6.1.2.1.10.246.1.12.1.3) |
not-accessible |
PwGenIdType |
As per the MIB. |
pwGenFecIndexMappingLocalAII (1.3.6.1.2.1.10.246.1.12.1.4) |
not-accessible |
Local AII value of the PW. |
As per the MIB. |
pwGenFecIndexMappingRemoteAIIType (1.3.6.1.2.1.10.246.1.12.1.5) |
not-accessible |
PwGenIdType |
As per the MIB. |
pwGenFecIndexMappingRemoteAII (1.3.6.1.2.1.10.246.1.12.1.6) |
not-accessible |
Remote AII value of the PW. |
As per the MIB. |
pwGenFecIndexMappingPwIndex (1.3.6.1.2.1.10.246.1.12.1.7) |
read-only |
PwIndexType |
As per the MIB. |
Notifications
pwDown
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.10.246.0.1 |
PW down |
Error |
Major |
1.3.6.1.2.1.10.246.0.2 (pwUp) |
OFF |
This notification is generated when the pwOperStatus object for one or more contiguous entries in the pwTable are about to enter the down(2) or lowerLayerDown(6) state from any other state, except for transition from the notPresent(5) state.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-up-down command.
OFF
CLI: undo snmp-agent trap enable l2vpn pw-up-down command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.10.246.1.2.1.38 (pwOperStatus) |
PW operational status. |
No |
PwOperStatusTC |
up(1) down(2) testing(3) dormant(4) notPresent(5) lowerLayerDown(6) |
No |
PwOperStatusTC |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
pwUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.246.0.2 |
PW up |
Recovery |
OFF |
This notification is generated when the pwOperStatus object for one or more contiguous entries in the pwTable are about to enter the up(1) state from some other state except the notPresent(5) state and given that the pwDown notification been issued for these entries.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
PwOperStatusTC |
No |
PwOperStatusTC |
Recommended action
pwDeleted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.246.0.3 |
PW deleted |
Error |
Major |
OFF |
This notification is generated when the PW has been deleted.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-delete command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-delete command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.10.246.1.2.1.2 (pwType) |
PW data encapsulation type. |
No |
IANAPwTypeTC |
other(0) frameRelayDlciMartiniMode(1) atmAal5SduVcc(2) atmTransparent(3) ethernetTagged(4) ethernet(5) hdlc(6) ppp(7) cem(8) -- Historic type atmCellNto1Vcc(9) atmCellNto1Vpc(10) ipLayer2Transport(11) atmCell1to1Vcc(12) atmCell1to1Vpc(13) atmAal5PduVcc(14) frameRelayPortMode(15) cep(16), e1Satop(17) t1Satop(18) e3Satop(19) t3Satop(20) basicCesPsn(21) basicTdmIp(22) tdmCasCesPsn(23) tdmCasTdmIp(24) frDlci(25) wildcard (32767) |
1.3.6.1.2.1.10.246.1.2.1.12 (pwID) |
PW ID. |
No |
PwIDType |
Unsigned32(1..4294967295) |
1.3.6.1.2.1.10.246.1.2.1.8 (pwPeerAddrType) |
No |
InetAddressType |
unknown(0) ipv4(1) ipv6(2) ipv4z(3) ipv6z(4) dns(16) |
1.3.6.1.2.1.10.246.1.2.1.9 (pwPeerAddr) |
No |
InetAddress |
OCTET STRING (SIZE (0..255)) |
Recommended action
