- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLS-VPN-BGP-MIB
- 05-HH3C-MPLSCRLSP-MIB
- 06-HH3C-MPLSEXT-MIB
- 07-HH3C-MPLSRSVP-MIB
- 08-HH3C-MPLSSLSP-MIB
- 09-HH3C-MPLSTE-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
18-PW-ENET-STD-MIB | 45.62 KB |
PW-ENET-STD-MIB
About this MIB
Use this MIB to configure Ethernet PW related settings.
MIB file name
rfc5603-pw-enet-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pwEnetStdMIB(180)
Tabular objects
pwEnetTable
About this table
This table contains the AC configuration for Ethernet PW.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are pwIndex and pwEnetPwInstance.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwEnetPwInstance (1.3.6.1.2.1.180.1.1.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (0..4294967295) |
Index of an AC configuration entry for an Ethernet PW. |
As per the MIB. |
pwEnetPwVlan (1.3.6.1.2.1.180.1.1.1.2) |
read-create |
VlanIdOrAnyOrNone |
Integer32 (0 | 1..4094 | 4095) |
Negotiated VLAN ID. |
As per the MIB. |
pwEnetVlanMode (1.3.6.1.2.1.180.1.1.1.3) |
read-create |
INTEGER |
other(0), portBased(1), noChange(2), changeVlan(3), addVlan(4), removeVlan(5) |
VLAN handling mode. |
As per the MIB. |
pwEnetPortVlan (1.3.6.1.2.1.180.1.1.1.4) |
read-create |
VlanIdOrAnyOrNone |
Port VLAN ID. |
As per the MIB. |
pwEnetPortIfIndex (1.3.6.1.2.1.180.1.1.1.5) |
read-create |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
Index of the Ethernet port. |
As per the MIB. |
pwEnetRowStatus (1.3.6.1.2.1.180.1.1.1.7) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
pwEnetStorageType (1.3.6.1.2.1.180.1.1.1.8) |
read-create |
StorageType |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type for the AC configuration entry. |
Supports only the read operation. The value is always nonVolatile(3). |
If the AC is an Ethernet service instance, the values for pwType (see PW-STD-MIB), pwEnetPortVlan, pwEnetVlanMode, and pwEnetPwVlan are as follows:
encapsulation |
AC access mode |
pwType |
pwEnetPortVlan |
pwEnetVlanMode |
pwEnetPwVlan |
Implementation |
default | tagged |
ethernet |
ethernet |
4095 |
portBased |
4095 |
For a set operation, the encapsulation supports only default. |
default | tagged |
ethernet |
ethernetTagged |
4095 |
addVlan |
0 or requested VLAN |
default | tagged |
vlan |
ethernet |
4095 |
removeVlan |
0 |
default | tagged |
vlan |
ethernetTagged |
4095 |
noChange or changeVlan |
4095 or requested VLAN |
untagged |
ethernet |
ethernet |
0 |
nochange |
0 |
untagged |
ethernet |
ethernetTagged |
0 |
addVlan |
untagged |
vlan |
ethernet |
0 |
nochange |
0 |
Supports only the read operation. |
untagged |
vlan |
ethernetTagged |
0 |
addVlan |
s-vid [only-tagged] |
ethernet |
ethernet |
s-vid |
noChange |
s-vid |
For a set operation, the encapsulation supports only s-vid. |
ethernet |
ethernetTagged |
s-vid |
addVlan |
vlan |
ethernet |
s-vid |
removeVlan |
0 |
vlan |
ethernetTagged |
s-vid |
s-vid or requested VLAN |
If the AC is a Layer 3 interface, the values for pwType (see PW-STD-MIB), pwEnetPortVlan, pwEnetVlanMode, and pwEnetPwVlan are as follows:
interface type |
AC access mode |
pwType |
pwEnetPortVlan |
pwEnetVlanMode |
pwEnetPwVlan |
main |
ethernet |
ethernet |
4095 |
portBased |
4095 |
main |
ethernet |
ethernetTagged |
4095 |
addVlan |
sub |
vlan |
ethernet |
vlan dot1q |
removeVlan |
4095 |
sub |
vlan |
ethernetTagged |
vlan dot1q |
changeVlan |
requested VLAN |
sub |
vlan |
ethernetTagged |
vlan dot1q |
noChange |
vlan dot1q |
vlan |
vlan |
ethernet |
vlan ID |
removeVlan |
4095 |
vlan |
vlan |
ethernetTagged |
vlan ID |
changeVlan |
requested VLAN |
vlan |
vlan |
ethernetTagged |
vlan ID |
noChange |
vlan ID |
