- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLS-VPN-BGP-MIB
- 05-HH3C-MPLSCRLSP-MIB
- 06-HH3C-MPLSEXT-MIB
- 07-HH3C-MPLSRSVP-MIB
- 08-HH3C-MPLSSLSP-MIB
- 09-HH3C-MPLSTE-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
09-HH3C-MPLSTE-MIB | 153.88 KB |
HH3C-MPLSTE-MIB
About this MIB
Use this MIB to manage MPLS TE and RSVP TE settings.
MIB file name
hh3c-mplste.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsTeStdMIB(3)
Scalar objects
hh3cMplsTeStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsTeStatus (1.3.6.1.4.1.25506.2.143.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Globally enable MPLS TE (mpls te) or TE attribute (te attribute enable) for the device. |
As per the MIB. |
hh3cMplsTeRsvpStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsTeRsvpStatus (1.3.6.1.4.1.25506.2.143.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enable global RSVP TE. |
As per the MIB. |
hh3cMplsTeTunnelInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsTeTunnelInfo (1.3.6.1.4.1.25506.2.143.1.1.3) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (1..127) |
MPLS TE tunnel information |
As per the MIB. |
Tabular objects
hh3cMplsTeTable
About this table
This table specifies per-interface MPLS TE settings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported only when the value for hh3cMplsTeCapability is true(1) |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cMplsTeIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsTeIndex (1.3.6.1.4.1.25506.2.143.1.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
Index of an MPLS TE interface. |
As per the MIB. |
hh3cMplsTeCapability (1.3.6.1.4.1.25506.2.143.1.2.1.2) |
read-create |
TruthValue |
true(1), false(2) |
MPLS TE capability of the interface. No MPLS TE capability information can be obtained when MPLS TE is not enabled on the interface. |
As per the MIB. |
hh3cMplsTeRowStatus (1.3.6.1.4.1.25506.2.143.1.2.1.3) |
read-create |
RowStatus |
active(1) createAndGo(4) destroy(6). |
Row status. |
Supports only the following values: active(1), createAndGo(4), and destroy(6). |
hh3cMplsTeRsvpTable
About this table
This table specifies per-interface RSVP TE settings.
Create |
Edit/Modify |
Delete |
Read |
Supported only when the value for hh3cMplsTeRsvpCapability is true(1) |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cMplsTeRsvpIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsTeRsvpIndex (1.3.6.1.4.1.25506.2.143.1.3.1.1) |
not-accessible |
Unsigned32 |
Index of an RSVP TE interface. |
As per the MIB. |
hh3cMplsTeRsvpCapability (1.3.6.1.4.1.25506.2.143.1.3.1.2 |
read-create |
TruthValue |
true(1), false(2) |
RSVP TE capability of the interface. No RSVP TE capability information can be obtained when RSVP is not enabled on the interface. |
As per the MIB. |
hh3cMplsTeRsvpRowStatus (1.3.6.1.4.1.25506.2.143.1.3.1.3) |
read-create |
RowStatus |
Row status. |
Notifications
hh3cMplsTeTunnelHsbSwitch
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.143.0.1 |
The primary LSP fails, and traffic is switched to the hot-standby backup LSP. |
Error |
Major |
1.3.6.1.4.1.25506.2.143.0.2 (hh3cMplsTeTunnelHsbResume) |
ON |
This notification is generated when the primary LSP fails and the system detects a hot-standby backup LSP and switches the traffic to the backup LSP.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.2 |
The main LSP recovers from failure and traffic is switched back from the backup LSP to the main LSP. |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the primary LSP recovers from failure and traffic is switched back from the hot-standby backup LSP to the primary LSP.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsTeTunnelObSwitch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.3 |
The primary LSP fails and traffic is switched to the ordinary backup LSP. |
Error |
Major |
1.3.6.1.4.1.25506.2.143.0.4 (hh3cMplsTeTunnelObResume) |
ON |
This notification is generated when the primary LSP fails and an ordinary backup LSP becomes up and takes over traffic forwarding.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.4 |
The primary LSP recovers from failure and traffic is switched back from the ordinary backup LSP to the primary LSP. |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the primary LSP recovers from failure and traffic is switched back from the ordinary backup LSP to the primary LSP.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsTeTunnelHsbLspDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.5 |
Hot-standby LSP down |
Error |
Major |
1.3.6.1.4.1.25506.2.143.0.6 (hh3cMplsTeTunnelHsbLspUp) |
ON |
This notification is generated when LSP hot standby is configured on an MPLS TE tunnel interface and the hot-standby LSP goes down.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.6 |
Hot-standby LSP up |
Recovery |
N/A |
N/A |
ON |
This notification is generated when LSP hot standby is configured on an MPLS TE tunnel interface and the hot-standby LSP comes up.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsTeTunnelObLspDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.7 |
Ordinary backup LSP down |
Error |
Major |
1.3.6.1.4.1.25506.2.143.0.8 (hh3cMplsTeTunnelObLspUp) |
ON |
This notification is generated when ordinary backup is configured on an MPLS TE tunnel interface and the backup LSP goes down.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.8 |
Ordinary backup LSP up |
Recovery |
N/A |
N/A |
ON |
This notification is generated when ordinary backup is configured on an MPLS TE tunnel interface and the backup LSP comes up.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsTeTunnelMainLspDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.9 |
Primary LSP down |
Error |
Major |
1.3.6.1.4.1.25506.2.143.0.10 (hh3cMplsTeTunnelMainLspUp) |
ON |
This notification is generated when the primary LSP goes down from the up state. At this time, if a backup LSP is available, the tunnel uses the backup LSP to forward traffic, and if no backup LSP is available, the tunnel goes down.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.10 |
Primary LSP up |
Recovery |
N/A |
N/A |
ON |
This notification is generated when the primary LSP comes up from the down state. At this time, if the tunnel is down, the tunnel will come up. If the tunnel uses the backup LSP to forward traffic, the tunnel will switch the traffic back to the primary LSP.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsTeTunnelChangeBw
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.11 |
MPLS TE tunnel bandwidth changes. |
Error |
Major |
None |
ON |
This notification is generated when the bandwidth of the MPLS TE tunnel changes in the following situation:
· Set or edit the bandwidth of the tunnel.
· Automatic bandwidth adjustment is enabled for the tunnel and a traffic change triggers a bandwidth adjustment.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsTeAutoTunnelUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.143.0.12 |
Automatic TE tunnel up |
Error |
Major |
None |
ON |
This notification is generated when an automatic TE tunnel comes up.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
