10-MPLS
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10010-MPLS
08-HH3C-MPLSSLSP-MIB
08-HH3C-MPLSSLSP-MIB 47.07 KB
HH3C-MPLSSLSP-MIB
About this MIB
Use this MIB to notify static LSP traps.
MIB file name
hh3c-mplsslsp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsSlsp(230)
Tabular objects
hh3cMplsSlspBaseInfo
Object (OID)
Access
Value range
Implementation
hh3cMplsSlspBaseInfo (1.3.6.1.4.1.25506.2.230.1.1.1)
accessible-for-notify
OCTET STRING
OCTET STRING (0..127)
Static LSP basic information
As per the MIB.
hh3cMplsSlspExtInfo
Object (OID)
Access
Value range
Implementation
hh3cMplsSlspExtInfo (1.3.6.1.4.1.25506.2.230.1.1.2)
OCTET STRING
Static LSP extended information
As per the MIB.
Notifications
hh3cMplsSlspDown
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.230.0.1
Static LSP down
Error
Major
1.3.6.1.4.1.25506.2.230.0.2(hh3cMplsSlspUp)
ON
This notification is generated when a static LSP goes down. Traffic forwarding over the static LSP will fail.
Status control
ON
CLI: Use the snmp-agent trap enable lsm command.
OFF
CLI: Use the undo snmp-agent trap enable lsm command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.230.1.1.1 (hh3cMplsSlspBaseInfo)
Yes
OCTET STRING
As per the MIB.
1.3.6.1.4.1.25506.2.230.1.1.2 (hh3cMplsSlspExtInfo)
Yes
OCTET STRING
As per the MIB.
Recommended action
No action is required.
hh3cMplsSlspUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.226.0.2
Static LSP up
Recovery
ON
This notification is generated when a static LSP comes up.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Yes
OCTET STRING
As per the MIB.
Yes
OCTET STRING
As per the MIB.
Recommended action
