- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLS-VPN-BGP-MIB
- 05-HH3C-MPLSCRLSP-MIB
- 06-HH3C-MPLSEXT-MIB
- 07-HH3C-MPLSRSVP-MIB
- 08-HH3C-MPLSSLSP-MIB
- 09-HH3C-MPLSTE-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
06-HH3C-MPLSEXT-MIB | 103.28 KB |
HH3C-MPLSEXT-MIB
About this MIB
Use this MIB to manage MPLS and LDP capabilities and MPLS BFD sessions.
MIB file name
rfc3812-mpls-te-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsTeStdMIB(3)
Scalar objects
hh3cMplsExtLsrID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLsrID (1.3.6.1.4.1.25506.2.142.1.1.1) |
read-write |
OCTET STRING |
OCTET STRING (0..255) |
Global LSR ID. |
As per the MIB. |
hh3cMplsExtLdpStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLdpStatus (1.3.6.1.4.1.25506.2.142.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of global LDP. |
As per the MIB. |
Tabular objects
hh3cMplsExtTable
About this table
Use this table to configure the MPLS capability for interfaces.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
You cannot set an MTU for a tunnel interface. By default, the MPLS MTU depends on the interface MTU. Different types of interfaces have different MTU values. |
The MTU of a tunnel interface cannot be modified. |
Supported |
Supported |
Columns
The table index is hh3cMplsExtIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtIndex (1.3.6.1.4.1.25506.2.142.1.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
Index of an interface. |
As per the MIB. |
hh3cMplsExtCapability (1.3.6.1.4.1.25506.2.142.1.2.1.2) |
read-create |
TruthValue |
true(1), false(2) |
MPLS capability of the interface. |
As per the MIB. |
hh3cMplsExtMtu (1.3.6.1.4.1.25506.2.142.1.2.1.3) |
read-create |
Unsigned32 |
Unsigned32 (46..65535) |
MPLS MTU of the interface. |
As per the MIB. |
hh3cMplsExtRowStatus (1.3.6.1.4.1.25506.2.142.1.2.1.4) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cMplsExtLdpTable
About this table
Use this table to configure the LDP capability for interfaces.
Create |
Edit/Modify |
Delete |
Read |
When create, the value of hh3cMplsExtLdpCapability must be true(1). |
Supported |
Supported |
Supported |
Columns
The table index is hh3cMplsExtLdpIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLdpIndex (1.3.6.1.4.1.25506.2.142.1.3.1.1) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cMplsExtLdpCapability (1.3.6.1.4.1.25506.2.142.1.3.1.2) |
read-create |
TruthValue |
false(0), |
LDP capability of the interface. |
As per the MIB. |
hh3cMplsExtLdpRowStatus (1.3.6.1.4.1.25506.2.142.1.3.1.3) |
read-create |
RowStatus |
active(1),
Row status. |
hh3cMplsExtBfdTable
About this table
This table contains information about MPLS BFD sessions.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtBfdLocalDiscr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtBfdLocalDiscr (1.3.6.1.4.1.25506.2.142.1.4.1.1) |
not-accessible |
Unsigned32 |
Local discriminator of a BFD session. |
As per the MIB. |
hh3cMplsExtBfdType (1.3.6.1.4.1.25506.2.142.1.4.1.2) |
read-only |
INTEGER |
1: unknown 4: BFD for VPLS PW 5: BFD for TE |
Type of the BFD session. |
As per the MIB. |
hh3cMplsExtBfdBindIfIndex (1.3.6.1.4.1.25506.2.142.1.4.1.3) |
read-only |
InterfaceIndexOrZero |
This object displays a tunnel interface index when the value of hh3cMplsExtBfdType is 5 (BFD for TE) and displays the index of an AC interface bound to a PW when the value of hh3cMplsExtBfdType is 3 (BFD for VPWS PW). This object is invalid and displays 0 when the value of hh3cMplsExtBfdType is not 5 (BFD for TE) or 3 (BFD for VPWS PW). |
Index of the bound local interface. |
As per the MIB. |
hh3cMplsExtBfdBindIfName (1.3.6.1.4.1.25506.2.142.1.4.1.4) |
read-only |
DisplayString |
DisplayString (0..255) |
Name of the bound local interface. |
As per the MIB. |
hh3cMplsExtBfdXcIndex (1.3.6.1.4.1.25506.2.142.1.4.1.5) |
read-only |
OCTET STRING |
OCTET STRING (0..24) |
MplsOutSegmentEntry index for an LSP entry. |
As per the MIB. |
hh3cMplsExtBfdPwBackupFlag (1.3.6.1.4.1.25506.2.142.1.4.1.6) |
read-only |
INTEGER |
1: Non-PW |
Primary or backup flag of a PW. |
As per the MIB. |
hh3cMplsExtBfdPwId (1.3.6.1.4.1.25506.2.142.1.4.1.7) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
PW identifier. |
As per the MIB. |
hh3cMplsExtBfdVsiIndex (1.3.6.1.4.1.25506.2.142.1.4.1.8) |
read-only |
Unsigned32 |
VSI index + 1. |
As per the MIB. |
hh3cMplsExtBfdPwPeerIpType (1.3.6.1.4.1.25506.2.142.1.4.1.9) |
read-only |
InetAddressType |
IPv4 or IPv6. The value of this object is 0 if the BFD session is not for a PW. |
Type of the PW peer address. |
As per the MIB. |
hh3cMplsExtBfdPwPeerIp (1.3.6.1.4.1.25506.2.142.1.4.1.10) |
read-only |
InetAddress |
Peer address of the PW. |
As per the MIB. |
hh3cMplsExtBfdPwSPE (1.3.6.1.4.1.25506.2.142.1.4.1.11) |
read-only |
INTEGER |
1: Non-VPWS PW |
Node information of the VPWS PW. |
As per the MIB. |
hh3cMplsExtBfdPwEncapType (1.3.6.1.4.1.25506.2.142.1.4.1.12) |
read-only |
INTEGER |
1: unknown 2: fr-dlci-martini 3: atm-aal5-sdu 4: atm-trans-cell 5: vlan 6: ethernet 7: hdlc 8: ppp 9: cesom 10: atm-nto1-vcc 11: atm-nto1-vpc 12: ip-interworking 13: atm-1to1-vcc 14: atm-1to1-vpc 15: atm-aal5-pdu 16: fr-port 17: cep 18: satop-e1 19: satop-t1 20: satop-e3 21: satop-t3 22: esopsn-basic 23: tdmoip-aal1-mode 24: tdm-cesopsn-with-cas 25: tdmoip-aal2-mode 26: fr-dlci |
Encapsulation type of the PW. |
As per the MIB. |
hh3cMplsExtVpnStatsTable
About this table
This table contains statistical information about packets received and sent by VPNs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtVpnStatsVrfIndex .
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtVpnStatsVrfIndex (1.3.6.1.4.1.25506.2.142.1.5.1.1) |
not-accessible |
Unsigned32 |
Index of a VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsVpnName (1.3.6.1.4.1.25506.2.142.1.5.1.2) |
read-only |
OCTET STRING |
OCTET STRING (1..31 ) |
Name of the VPN instance. |
As per the MIB. This object is invalid if VPN statistics is not enabled. When read, this object returns a zero-length string. |
hh3cMplsExtVpnStatsInOctets (1.3.6.1.4.1.25506.2.142.1.5.1.3) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Number of octets received by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsInPackets (1.3.6.1.4.1.25506.2.142.1.5.1.4) |
read-only |
Counter64 |
Number of packets received by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsInErrors (1.3.6.1.4.1.25506.2.142.1.5.1.5) |
read-only |
Counter64 |
Number of error packets received by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsInDiscards (1.3.6.1.4.1.25506.2.142.1.5.1.6) |
read-only |
Counter64 |
Number of incoming packets discarded by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutOctets (1.3.6.1.4.1.25506.2.142.1.5.1.7) |
read-only |
Counter64 |
Number of octets sent by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutPackets (1.3.6.1.4.1.25506.2.142.1.5.1.8) |
read-only |
Counter64 |
Number of packets sent by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutErrors (1.3.6.1.4.1.25506.2.142.1.5.1.9) |
read-only |
Counter64 |
Number of error packets sent by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutDiscards (1.3.6.1.4.1.25506.2.142.1.5.1.10) |
read-only |
Counter64 |
Number of outgoing packets discarded by the VPN instance. |
As per the MIB. |
Notifications
mplsTunnelUp
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.10.166.3.0.1 |
Tunnel up |
Recovery |
1.3.6.1.2.1.10.166.3.2.2.1.34 (mplsTunnelAdminStatus) |
ON |
This notification is generated when an MPLS tunnel's operating status (mplsTunnelOperStatus) changes from down to a state other than notPresent.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name) |
Index |
Type |
Value range |
Administrative state of the tunnel. |
No |
INTEGER |
up(1) down(2) testing(3) |
1.3.6.1.2.1.10.166.3.2.2.1.35 (mplsTunnelOperStatus) |
Actual operating status of the tunnel. |
No |
INTEGER |
up(1) down(2) testing(3) unknown(4) dormant(5) notPresent(6) lowerLayerDown(7) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
mplsTunnelDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.3.0.2 |
Tunnel down |
Error |
Major |
ON |
This notification is generated when an MPLS tunnel's operating status (mplsTunnelOperStatus) changes to down from a state other than notPresent.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
No |
INTEGER |
Recommended action
Examine the parameter settings for the tunnel.
If the issue persists, contact H3C Support.
mplsTunnelRerouted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.3.0.3 |
Tunnel rerouted |
Informational |
ON |
This notification is generated when an MPLS tunnel rerouted event occurs. If the mplsTunnelARHopTable has been used, the entry for the tunnel in the mplsTunnelARHopTable might save the rerouted new path for a while after the agent sends the notification.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
No |
INTEGER |
Recommended action
mplsTunnelReoptimized
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.3.0.4 |
Tunnel reoptimized |
Informational |
ON |
This notification is generated when an MPLS tunnel reoptimized event occurs. If the mplsTunnelARHopTable has been used, the entry for the tunnel in the mplsTunnelARHopTable might save the reoptimized new path for a while after the agent sends the notification.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
No |
INTEGER |
Recommended action
Examine the new path for the tunnel.
